| | ossimTiffOverviewBuilder () |
| | default constructor More...
| virtual | ~ossimTiffOverviewBuilder () |
| | virtual destructor More...
| void | setResampleType (ossimFilterResampler::ossimFilterResamplerType resampleType) |
| | Supports BOX or NEAREST NEIGHBOR. More...
| bool | buildOverview (const ossimFilename &overview_file, bool copy_all=false) |
| | Builds overview file and sets "theOutputFile" to that of the overview_file. More...
| virtual bool | execute () |
| | Calls buildOverview. More...
| void | setCompressionType (ossim_uint16 compression_type) |
| | Sets the compression type to use when building overviews. More...
| void | setJpegCompressionQuality (ossim_int32 quality) |
| | Sets the compression quality for use when using a compression type of COMPRESSION_JPEG. More...
| bool | getCopyAllFlag () const |
| | Method to return copy all flag. More...
| void | setInternalOverviewsFlag (bool flag) |
| | Sets internal overviews flag. More...
| bool | getInternalOverviewsFlag () const |
| void | setCopyAllFlag (bool flag) |
| | Sets theCopyAllFlag. More...
| virtual bool | canConnectMyInputTo (ossim_int32 index, const ossimConnectableObject *obj) const |
| virtual bool | setInputSource (ossimImageHandler *imageSource) |
| | Sets the input to the builder. More...
| virtual void | setOutputFile (const ossimFilename &file) |
| | Sets the output filename. More...
| virtual ossimFilename | getOutputFile () const |
| | Gets the output file name. More...
| void | setOutputTileSize (const ossimIpt &tileSize) |
| virtual bool | setOverviewType (const ossimString &type) |
| | Sets the overview output type. More...
| virtual ossimString | getOverviewType () const |
| | Gets the overview type. More...
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| | Method to populate class supported types. More...
| | Method to set properties. More...
| | Method to populate the list of property names. More...
| | ossimOverviewBuilderBase () |
| virtual bool | setOutputWriter (ossimImageFileWriter *outputWriter) |
| | Sets an optional file writer to the builder. More...
| virtual bool | hasOverviewType (const ossimString &type) const |
| | Method to check if builder can handle type. More...
| virtual ossim_uint32 | getOverviewStopDimension () const |
| | Get the overview stop dimension. More...
| virtual void | setOverviewStopDimension (ossim_uint32 dim) |
| | Sets the overview stop dimension. More...
| ossimHistogramMode | getHistogramMode () const |
| | Gets the histogram accumulation mode. More...
| void | setHistogramMode (ossimHistogramMode mode) |
| | Sets the histogram accumulation mode. More...
| virtual void | finalize () |
| | Finalize method. More...
| void | setBitMaskSpec (const ossimKeywordlist &bit_mask_spec) |
| | Specifies parameters (in KWL) for generation of an alpha (bit) mask such that any full or partial null pixels will be masked out. More...
| void | setScanForMinMax (bool flag) |
| | Turn on/off scan for min max flag. More...
| bool | getScanForMinMax () const |
| void | setScanForMinMaxNull (bool flag) |
| | Turn on/off scan for min, max, null flag. More...
| bool | getScanForMinMaxNull () const |
| | ossimSource (ossimObject *owner=0) |
| | ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) |
| virtual | ~ossimSource () |
| | Outputs theErrorStatus as an ossimErrorCode and an ossimString. More...
| | ossimConnectableObject (ossimObject *owner=0) |
| | Base constructor of this object. More...
| | ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) |
| | All connectable objects will have id's. More...
| | Will allow us to get this object's id. More...
| | Fetches the current owner, most likely a container but not limited to one. More...
| | Permits changing the object's owner. More...
| | will check the direction specified to see if all slots are full. More...
| | OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) |
| | OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) |
| | OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) |
| | OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) |
| | Return a valid index of the input list if the passed in object is found else return -1. More...
| | Return a valid index of the input list if the passed id is found else return -1. More...
| | Return a valid index of the output list if the passed in object is found else return -1. More...
| | Should return the first available index to connect to. More...
| | default implementation is to allow anyone to connect to us. More...
| | Will disconnect the object passed in. More...
| | Will disconnect the object at the given input index and generate a connection event. More...
| | Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More...
| | Will disconnect the object at the given output index and generate a connection event. More...
| | Will disconnect the output object. More...
| | Will disconnect all of the input objects. More...
| | Will disconnect all of the output objects. More...
| | Will try to connect this objects input to the passed in object. More...
| | Will connect the specified input to the passed in object. More...
| | Will try to connect this objects output to the passed in object. More...
| | Will disconnect itself from all inputs and reset to the passed in input list. More...
| | Will disconnect itself from all outputs and reset to the passed in output list. More...
| | Returns the number of input objects. More...
| | Return the number of output objects. More...
| | returns the object at the specified index. More...
| | Will set the number of inputs. More...
| | Will set the number of outputs. More...
| | OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) |
| | OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) |
| | Save the state of all inputs to a keyword list. More...
| | Inserts this object and all of its children and inputs into the container provided. More...
| | Moves the input connection matching id up one in the connection list. More...
| | Moves the input connection matching id down one in the connection list. More...
| | Moves the input connection matching id to the top of the connection list. More...
| | Moves the input connection matching id to the bottom of the connection list. More...
| | We will add a visitor interface for all connectable objects. More...
| | ossimObject () |
| | ossimReferenced () |
| | ossimReferenced (const ossimReferenced &) |
| | increment the reference count by one, indicating that this object has another pointer which is referencing it. More...
| | decrement the reference count by one, indicating that a pointer to this object is referencing it. More...
| | ossimListenerManager () |
| | ossimPropertyInterface () |
| | ossimErrorStatusInterface () |
| bool | hasError () const |
| | ossimProcessInterface () |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual void | setPercentComplete (double percentComplete) |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| | ossimConnectableObjectListener () |
| | ProcessEvent. More...
| virtual void | disconnectInputEvent (ossimConnectionEvent &) |
| virtual void | connectInputEvent (ossimConnectionEvent &) |
| virtual void | propertyEvent (ossimPropertyEvent &) |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| | ossimListener () |
| void | enableListener () |
| void | disableListener () |
