#include <ossimNitf20Writer.h>
| ossimNitf20Writer (const ossimFilename &filename=ossimFilename(""), ossimImageSource *inputSource=(ossimImageSource *) NULL) | |
| virtual | ~ossimNitf20Writer () |
| virtual bool | open () |
| virtual void | close () |
| virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const |
| void getImageTypeList(std::vector<ossimString>& imageTypeList)const More... | |
| Set the properties. More... | |
| Gets a property. More... | |
| void | addRegisteredTag (ossimRefPtr< ossimNitfRegisteredTag > registeredTag) |
| Saves the state of the writer to kwl with prefix then calls base class ossimImageFileWriter::saveState. More... | |
| Initializes the state of the writer from kwl with prefix then calls base class ossimImageFileWriter::loadState. More... | |
Public Member Functions inherited from ossimNitfWriterBase | |
| ossimNitfWriterBase () | |
| ossimNitfWriterBase (const ossimFilename &filename, ossimImageSource *inputSource) | |
| Constructor that takes filename and input source. More... | |
| virtual | ~ossimNitfWriterBase () |
| virtual ossimString | getExtension () const |
| Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More... | |
| virtual void | addRegisteredTag (ossimRefPtr< ossimNitfRegisteredTag > registeredTag, bool unique) |
| virtual void | addRegisteredTag (ossimRefPtr< ossimNitfRegisteredTag > registeredTag, bool unique, const ossim_uint32 &ownerIndex, const ossimString &tagType) |
| virtual void | setFileHeaderV2_1 (ossimRefPtr< ossimNitfFileHeaderV2_1 >, bool preferSource=false) |
| virtual void | setImageHeaderV2_1 (ossimRefPtr< ossimNitfImageHeaderV2_1 >, bool preferSource=false) |
Public Member Functions inherited from ossimImageFileWriter | |
| ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0) | |
| The writer will own the sequencer. More... | |
| virtual | ~ossimImageFileWriter () |
| virtual bool | getOutputHasInternalOverviews (void) const |
| Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More... | |
| virtual bool | hasImageType (const ossimString &imageType) const |
| bool hasImageType(const ossimString& imageType) const More... | |
| virtual void | setTileSize (const ossimIpt &tileSize) |
| Sets the output image tiling size if supported by the writer. More... | |
| virtual bool | writeEnviHeaderFile () |
| Will write an envi header file. More... | |
| virtual bool | writeErsHeaderFile () |
| Will write an ER Mapper header file. More... | |
| virtual bool | writeExternalGeometryFile () |
| Will write an external geometry file. More... | |
| virtual bool | writeFgdcFile () |
| Will write an fgdc file. More... | |
| virtual bool | writeHistogramFile () |
| Returns true on success, false on error. More... | |
| virtual bool | writeJpegWorldFile () |
| Will write a jpeg world file. More... | |
| virtual bool | writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false) |
| Write out an ossim overview file from the source_file. More... | |
| virtual bool | writeReadmeFile () |
| Will write a readme file. More... | |
| virtual bool | writeTiffWorldFile () |
| Will write a world file. More... | |
| virtual bool | writeWorldFile () |
| virtual bool | writeMetaDataFiles () |
| Convenience method that calls meta data write methods that are flagged to be called. More... | |
| virtual void | setAreaOfInterest (const ossimIrect &inputRect) |
| virtual void | changeSequencer (ossimImageSourceSequencer *sequencer) |
| Sets the sequencer and connects it to the input of this. More... | |
| virtual ossimImageSourceSequencer * | getSequencer () |
| Initialize method. More... | |
| virtual bool | execute () |
| Calls: writeFile() writeMetaDataFiles() More... | |
| virtual bool | writeStream () |
| Method to write the image to a stream. More... | |
| virtual bool | setOutputStream (ossimRefPtr< ossimOStream > stream) |
| Sets the output stream to write to. More... | |
| virtual bool | setOutputStream (std::ostream &str) |
| tmp drb More... | |
| virtual ossimRefPtr< ossimOStream > | getOutputStream () const |
| Method to return the stream attached to output. More... | |
| virtual void | setPercentComplete (double percentComplete) |
| virtual void | setOutputImageType (ossim_int32 type) |
| virtual void | setOutputImageType (const ossimString &type) |
| virtual ossim_int32 | getOutputImageType () const |
| virtual ossimString | getOutputImageTypeString () const |
| virtual void | setOutputName (const ossimString &outputName) |
| virtual void | setFilename (const ossimFilename &file) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | getWriteImageFlag () const |
| Control flags... More... | |
| virtual bool | getWriteHistogramFlag () const |
| virtual bool | getWriteOverviewFlag () const |
| virtual bool | getScaleToEightBitFlag () const |
| virtual bool | getWriteEnviHeaderFlag () const |
| virtual bool | getWriteErsHeaderFlag () const |
| virtual bool | getWriteExternalGeometryFlag () const |
| virtual bool | getWriteFgdcFlag () const |
| virtual bool | getWriteJpegWorldFileFlag () const |
| virtual bool | getWriteReadmeFlag () const |
| virtual bool | getWriteTiffWorldFileFlag () const |
| virtual bool | getWriteWorldFileFlag () const |
| virtual void | setWriteImageFlag (bool flag) |
| virtual void | setWriteOverviewFlag (bool flag) |
| virtual void | setWriteHistogramFlag (bool flag) |
| virtual void | setScaleToEightBitFlag (bool flag) |
| virtual void | setWriteEnviHeaderFlag (bool flag) |
| virtual void | setWriteErsHeaderFlag (bool flag) |
| virtual void | setWriteExternalGeometryFlag (bool flag) |
| virtual void | setWriteFgdcFlag (bool flag) |
| virtual void | setWriteJpegWorldFile (bool flag) |
| virtual void | setWriteReadme (bool flag) |
| virtual void | setWriteTiffWorldFile (bool flag) |
| virtual void | setWriteWorldFile (bool flag) |
| virtual ossim_uint16 | getOverviewCompressType () const |
| virtual ossim_int32 | getOverviewJpegCompressQuality () const |
| virtual void | setOverviewCompressType (ossim_uint16 type) |
| virtual void | setOverviewJpegCompressQuality (ossim_int32 quality) |
| Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More... | |
| Overrides base "removeListener". More... | |
| virtual void | setPixelType (ossimPixelType type) |
| If "point" the coordinate tie points are relative to the center of the pixel. More... | |
| virtual void | setPixelType (const ossimString &type) |
| virtual ossimPixelType | getPixelType () const |
| virtual void | getPixelTypeString (ossimString &type) const |
Public Member Functions inherited from ossimImageWriter | |
| ossimImageWriter (ossimObject *owner=NULL) | |
| ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed) | |
| virtual | ~ossimImageWriter () |
| virtual bool | setViewingRect (const ossimIrect &aRect) |
| virtual ossimIrect | getAreaOfInterest () const |
Public Member Functions inherited from ossimOutputSource | |
| ossimOutputSource (ossimObject *owner=NULL) | |
| ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
| virtual | ~ossimOutputSource () |
| virtual bool | open (const ossimString &outputName) |
| virtual const ossimString & | getOutputName () |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual bool | writeFile () |
| virtual bool | writeBlockBandSeparate () |
| write out block band separate More... | |
| virtual bool | writeBlockBandSequential () |
| Outputs in band sequential format. More... | |
| void | addTags () |
Protected Member Functions inherited from ossimNitfWriterBase | |
| void | writeGeometry (ossimNitfImageHeaderV2_X *hdr, ossimImageSourceSequencer *seq) |
| Populates tags with geometry info from projection. More... | |
| void | addBlockaTag (ossimMapProjectionInfo &mapInfo, ossimNitfImageHeaderV2_X *hdr) |
| Adds the BLOCKA tag. More... | |
| void | addGeolobTag (const ossimMapProjection *mapProj, ossimNitfImageHeaderV2_X *hdr) |
| Adds the GEOLOB tag. More... | |
| void | addRpcbTag (const ossimIrect &rect, ossimProjection *proj, ossimNitfImageHeaderV2_X *hdr) |
| Adds the RPC00B tag. More... | |
| void | setComplexityLevel (std::streamoff, ossimNitfFileHeaderV2_X *hdr) |
| Sets the complexity level of theFileHeader. More... | |
| void | setComplexityLevel (ossimNitfFileHeaderV2_X *hdr, ossim_uint64 width=0, ossim_uint64 height=0) |
| virtual void | initializeDefaultsFromConfigFile (ossimNitfFileHeaderV2_X *fileHdr, ossimNitfImageHeaderV2_X *imgHdr) |
| Sets file header and image header defaults from config file if found in preferences. More... | |
Protected Member Functions inherited from ossimImageFileWriter | |
| bool | writeWorldFile (const ossimFilename &file) |
| Common world file writer method. More... | |
Public Types inherited from ossimProcessInterface | |
| enum | ossimProcessStatus { PROCESS_STATUS_UNKNOWN = 0, PROCESS_STATUS_EXECUTING = 1, PROCESS_STATUS_ABORTED = 2, PROCESS_STATUS_ABORT_REQUEST = 3, PROCESS_STATUS_NOT_EXECUTING = 4 } |
Definition at line 26 of file ossimNitf20Writer.h.
| ossimNitf20Writer::ossimNitf20Writer | ( | const ossimFilename & | filename = ossimFilename(""), |
| ossimImageSource * | inputSource = (ossimImageSource*)NULL |
Definition at line 51 of file ossimNitf20Writer.cpp.
References ossimRefPtr< T >::get(), ossimNitfWriterBase::initializeDefaultsFromConfigFile(), ossimNitfFileHeaderV2_X::setEncryption(), ossimNitfImageHeaderV2_X::setJustification(), ossimImageFileWriter::setWriteExternalGeometryFlag(), theFileHeader, theImageHeader, and ossimImageFileWriter::theOutputImageType.
Definition at line 82 of file ossimNitf20Writer.cpp.
References close(), theFileHeader, and theImageHeader.
Reimplemented from ossimNitfWriterBase.
Definition at line 624 of file ossimNitf20Writer.cpp.
References ossimNitfImageHeader::addTag(), ossimRefPtr< T >::get(), ossimNitfTagInformation::setTagData(), and theImageHeader.
protected |
Definition at line 632 of file ossimNitf20Writer.cpp.
References ossimConnectableObject::accept(), ossimNitfFileHeader::addTag(), ossimString::begin(), ossimString::contains(), ossimRefPtr< T >::get(), ossimNitfTileSource::getCurrentImageHeader(), ossimNitfTileSource::getFileHeader(), ossimNitfFileHeader::getNumberOfTags(), ossimCollectionVisitor::getObjectAs(), ossimCollectionVisitor::getObjects(), ossimPropertyInterface::getPropertyValueAsString(), ossimNitfFileHeader::getTagInformation(), min, ossimNitfFileHeaderV2_X::setDate(), ossimPropertyInterface::setProperty(), ossimString::size(), theCopyFieldsFlag, theFileHeader, theImageHeader, ossimRefPtr< T >::valid(), ossimVisitor::VISIT_CHILDREN, and ossimVisitor::VISIT_INPUTS.
Generic interface to allow one to close a consumer. For displays this might minimize the window and free up internal pointers for file writers it will make sure the file stream is closed and flushed.
Implements ossimOutputSource.
Definition at line 110 of file ossimNitf20Writer.cpp.
References theOutputStream.
Referenced by open(), and ~ossimNitf20Writer().
Appends this writer image types to list "imageTypeList".
This writer has the following types: nitf_block_band_separate nitf_block_band_sequential
| imageTypeList | stl::vector<ossimString> list to append to. |
Implements ossimImageFileWriter.
Definition at line 165 of file ossimNitf20Writer.cpp.
Gets a property.
| The | name of the property to get. |
Definition at line 220 of file ossimNitf20Writer.cpp.
References ossimContainerProperty::addChildren(), ossimImageFileWriter::getProperty(), ossimPropertyInterface::getPropertyList(), theCopyFieldsFlag, theEnableBlockaTagFlag, theEnableRpcbTagFlag, theFileHeader, and theImageHeader.
| propertyNames | Array to populate with property names. |
Definition at line 273 of file ossimNitf20Writer.cpp.
References ossimImageFileWriter::getPropertyNames().
Definition at line 93 of file ossimNitf20Writer.cpp.
Referenced by open(), and writeFile().
| kwl | Keyword list to initialize from. |
| prefix | Usually something like: "object2." |
Definition at line 836 of file ossimNitf20Writer.cpp.
References ossimNitfWriterBase::loadState().
Allows a generic interface to open a consumer for writing. If you are a display writer then you would probably show the window or init the device context for writing.
Definition at line 98 of file ossimNitf20Writer.cpp.
References ossimString::c_str(), close(), isOpen(), ossimImageFileWriter::theFilename, and theOutputStream.
Referenced by writeFile().
| kwl | Keyword list to save to. |
Definition at line 830 of file ossimNitf20Writer.cpp.
References ossimNitfWriterBase::saveState().
Set the properties.
| property | The property to set. |
Definition at line 171 of file ossimNitf20Writer.cpp.
References ossimRefPtr< T >::get(), ossimContainerProperty::getPropertyList(), PTR_CAST, ossimPropertyInterface::setProperties(), ossimNitfImageHeaderV2_0::setProperty(), ossimNitfFileHeaderV2_0::setProperty(), ossimImageFileWriter::setProperty(), theCopyFieldsFlag, theEnableBlockaTagFlag, theEnableRpcbTagFlag, theFileHeader, and theImageHeader.
protectedvirtual |
Definition at line 284 of file ossimNitf20Writer.cpp.
References ossimNitfFileHeaderV2_0::addImageInfoRecord(), ossimRefPtr< T >::get(), ossim::getActualBitsPerPixel(), ossim::getBitsPerPixel(), ossimImageSourceSequencer::getBoundingRect(), ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageSourceSequencer::getNextTile(), ossimNitfCommon::getNitfPixelType(), ossimImageData::getNumberOfBands(), ossimImageSource::getNumberOfOutputBands(), ossimImageSourceSequencer::getNumberOfTiles(), ossimImageSourceSequencer::getOutputScalarType(), ossimRectilinearDataObject::getScalarType(), ossimImageData::getSizeInBytes(), ossimEndian::getSystemEndianType(), ossimImageData::getWidth(), ossimIrect::height(), ossimProcessInterface::needsAborting(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_LITTLE_ENDIAN, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNitfFileHeaderV2_0::replaceImageInfoRecord(), ossim::scalarSizeInBytes(), ossimNitfImageHeaderV2_X::setActualBitsPerPixel(), ossimNitfImageHeaderV2_0::setBandInfo(), ossimNitfImageBandV2_0::setBandRepresentation(), ossimNitfImageHeaderV2_X::setBitsPerPixel(), ossimNitfImageHeaderV2_X::setBlocksPerCol(), ossimNitfImageHeaderV2_X::setBlocksPerRow(), ossimNitfImageHeaderV2_X::setCategory(), ossimNitfWriterBase::setComplexityLevel(), ossimNitfFileHeaderV2_0::setFileLength(), ossimNitfFileHeaderV2_0::setHeaderLength(), ossimNitfImageInfoRecordV2_0::setImageLength(), ossimNitfImageHeaderV2_X::setImageMode(), ossimNitfImageHeaderV2_0::setNumberOfBands(), ossimNitfImageHeaderV2_0::setNumberOfCols(), ossimNitfImageHeaderV2_X::setNumberOfPixelsPerBlockCol(), ossimNitfImageHeaderV2_X::setNumberOfPixelsPerBlockRow(), ossimNitfImageHeaderV2_0::setNumberOfRows(), ossimImageFileWriter::setPercentComplete(), ossimNitfImageHeaderV2_X::setPixelType(), ossimNitfImageHeaderV2_X::setRepresentation(), ossimNitfImageInfoRecordV2_0::setSubheaderLength(), ossimImageSourceSequencer::setTileSize(), ossimImageSourceSequencer::setToStartOfSequence(), ossimEndian::swap(), theFileHeader, theImageHeader, ossimImageFileWriter::theInputConnection, theOutputStream, tileNumber, ossimRefPtr< T >::valid(), ossimIrect::width(), ossimNitfImageHeaderV2_0::writeStream(), ossimNitfFileHeaderV2_0::writeStream(), ossimIpt::x, and ossimIpt::y.
protectedvirtual |
Band 1 is followed by band 2, ... etc.
Definition at line 443 of file ossimNitf20Writer.cpp.
References ossimNitfFileHeaderV2_0::addImageInfoRecord(), ossimRefPtr< T >::get(), ossim::getActualBitsPerPixel(), ossim::getBitsPerPixel(), ossimImageSourceSequencer::getBoundingRect(), ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageSourceSequencer::getNextTile(), ossimNitfCommon::getNitfPixelType(), ossimImageData::getNumberOfBands(), ossimImageSource::getNumberOfOutputBands(), ossimImageSourceSequencer::getNumberOfTiles(), ossimImageSourceSequencer::getNumberOfTilesHorizontal(), ossimImageSourceSequencer::getNumberOfTilesVertical(), ossimImageSourceSequencer::getOutputScalarType(), ossimRectilinearDataObject::getScalarType(), ossimEndian::getSystemEndianType(), ossimImageData::getWidth(), ossimIrect::height(), ossimProcessInterface::needsAborting(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_LITTLE_ENDIAN, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNitfFileHeaderV2_0::replaceImageInfoRecord(), ossim::scalarSizeInBytes(), ossimNitfImageHeaderV2_X::setActualBitsPerPixel(), ossimNitfImageHeaderV2_0::setBandInfo(), ossimNitfImageBandV2_0::setBandRepresentation(), ossimNitfImageHeaderV2_X::setBitsPerPixel(), ossimNitfImageHeaderV2_X::setBlocksPerCol(), ossimNitfImageHeaderV2_X::setBlocksPerRow(), ossimNitfImageHeaderV2_X::setCategory(), ossimNitfWriterBase::setComplexityLevel(), ossimNitfFileHeaderV2_X::setDate(), ossimNitfFileHeaderV2_0::setFileLength(), ossimNitfFileHeaderV2_0::setHeaderLength(), ossimNitfImageInfoRecordV2_0::setImageLength(), ossimNitfImageHeaderV2_X::setImageMode(), ossimNitfImageHeaderV2_0::setNumberOfBands(), ossimNitfImageHeaderV2_0::setNumberOfCols(), ossimNitfImageHeaderV2_X::setNumberOfPixelsPerBlockCol(), ossimNitfImageHeaderV2_X::setNumberOfPixelsPerBlockRow(), ossimNitfImageHeaderV2_0::setNumberOfRows(), ossimImageFileWriter::setPercentComplete(), ossimNitfImageHeaderV2_X::setPixelType(), ossimNitfImageHeaderV2_X::setRepresentation(), ossimNitfImageInfoRecordV2_0::setSubheaderLength(), ossimImageSourceSequencer::setTileSize(), ossimImageSourceSequencer::setToStartOfSequence(), ossimEndian::swap(), theFileHeader, theImageHeader, ossimImageFileWriter::theInputConnection, theOutputStream, tileNumber, ossimRefPtr< T >::valid(), ossimIrect::width(), ossimNitfImageHeaderV2_0::writeStream(), ossimNitfFileHeaderV2_0::writeStream(), ossimIpt::x, and ossimIpt::y.
protectedvirtual |
Definition at line 120 of file ossimNitf20Writer.cpp.
References ossimImageSourceSequencer::isMaster(), isOpen(), open(), ossimImageSourceSequencer::slaveProcessTiles(), and ossimImageFileWriter::theInputConnection.
protected |
If true this will enable searching the input connnection for another NITF handler and bring the fields to this writers output fields and will maintin as many field values as possible.
Definition at line 130 of file ossimNitf20Writer.h.
Referenced by addTags(), getProperty(), and setProperty().
protected |
If true user wants to set BLOCKA tag.
(DEFAULT = true) Currently only valid for map projected images.
Definition at line 122 of file ossimNitf20Writer.h.
Referenced by getProperty(), and setProperty().
protected |
If true user wants to set RPC00B tag.
(DEFAULT = false)
Definition at line 116 of file ossimNitf20Writer.h.
protected |
Definition at line 112 of file ossimNitf20Writer.h.
Referenced by addTags(), getProperty(), ossimNitf20Writer(), setProperty(), writeBlockBandSeparate(), writeBlockBandSequential(), and ~ossimNitf20Writer().
protected |
Definition at line 113 of file ossimNitf20Writer.h.
Referenced by addRegisteredTag(), addTags(), getProperty(), ossimNitf20Writer(), setProperty(), writeBlockBandSeparate(), writeBlockBandSequential(), and ~ossimNitf20Writer().
protected |
Definition at line 110 of file ossimNitf20Writer.h.
Referenced by close(), isOpen(), open(), writeBlockBandSeparate(), and writeBlockBandSequential().
