#include <ossimNitfWriter.h>
| ossimNitfWriter (const ossimFilename &filename=ossimFilename(""), ossimImageSource *inputSource=(ossimImageSource *) NULL) | |
| virtual | ~ossimNitfWriter () |
| virtual bool | open () |
| virtual void | close () |
| virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const |
| void getImageTypeList(std::vector<ossimString>& imageTypeList)const More... | |
| Set the properties. More... | |
| Gets a property. More... | |
| void | addRegisteredTag (ossimRefPtr< ossimNitfRegisteredTag > registeredTag, bool unique=true) |
| void | addRegisteredTag (ossimRefPtr< ossimNitfRegisteredTag > registeredTag, bool unique, const ossim_uint32 &ownerIndex, const ossimString &tagType) |
| Saves the state of the writer to kwl with prefix then calls base class ossimImageFileWriter::saveState. More... | |
| Initializes the state of the writer from kwl with prefix then calls base class ossimImageFileWriter::loadState. More... | |
| virtual bool | addTextToNitf (std::string &inputText) |
| virtual void | getTileSize (ossimIpt &size) const |
| Gets the block size. More... | |
| virtual void | setTileSize (const ossimIpt &tileSize) |
| Sets the nitf output block size. More... | |
| virtual ossimNitfImageHeaderV2_1 * | getImageHeader () |
| Get the image header used for export. More... | |
| virtual ossimNitfFileHeaderV2_1 * | getFileHeader () |
| Get the file header used for export. More... | |
| virtual void | addDataExtensionSegment (const ossimNitfDataExtensionSegmentV2_1 &des, bool allowTreOverflow) |
| Add a DES to the file. More... | |
Public Member Functions inherited from ossimNitfWriterBase | |
| ossimNitfWriterBase () | |
| ossimNitfWriterBase (const ossimFilename &filename, ossimImageSource *inputSource) | |
| Constructor that takes filename and input source. More... | |
| virtual | ~ossimNitfWriterBase () |
| virtual ossimString | getExtension () const |
| Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More... | |
| virtual void | addRegisteredTag (ossimRefPtr< ossimNitfRegisteredTag > registeredTag) |
| virtual void | setFileHeaderV2_1 (ossimRefPtr< ossimNitfFileHeaderV2_1 >, bool preferSource=false) |
| virtual void | setImageHeaderV2_1 (ossimRefPtr< ossimNitfImageHeaderV2_1 >, bool preferSource=false) |
Public Member Functions inherited from ossimImageFileWriter | |
| ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0) | |
| The writer will own the sequencer. More... | |
| virtual | ~ossimImageFileWriter () |
| virtual bool | getOutputHasInternalOverviews (void) const |
| Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More... | |
| virtual bool | hasImageType (const ossimString &imageType) const |
| bool hasImageType(const ossimString& imageType) const More... | |
| virtual bool | writeEnviHeaderFile () |
| Will write an envi header file. More... | |
| virtual bool | writeErsHeaderFile () |
| Will write an ER Mapper header file. More... | |
| virtual bool | writeExternalGeometryFile () |
| Will write an external geometry file. More... | |
| virtual bool | writeFgdcFile () |
| Will write an fgdc file. More... | |
| virtual bool | writeHistogramFile () |
| Returns true on success, false on error. More... | |
| virtual bool | writeJpegWorldFile () |
| Will write a jpeg world file. More... | |
| virtual bool | writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false) |
| Write out an ossim overview file from the source_file. More... | |
| virtual bool | writeReadmeFile () |
| Will write a readme file. More... | |
| virtual bool | writeTiffWorldFile () |
| Will write a world file. More... | |
| virtual bool | writeWorldFile () |
| virtual bool | writeMetaDataFiles () |
| Convenience method that calls meta data write methods that are flagged to be called. More... | |
| virtual void | setAreaOfInterest (const ossimIrect &inputRect) |
| virtual void | changeSequencer (ossimImageSourceSequencer *sequencer) |
| Sets the sequencer and connects it to the input of this. More... | |
| virtual ossimImageSourceSequencer * | getSequencer () |
| Initialize method. More... | |
| virtual bool | execute () |
| Calls: writeFile() writeMetaDataFiles() More... | |
| virtual bool | writeStream () |
| Method to write the image to a stream. More... | |
| virtual bool | setOutputStream (ossimRefPtr< ossimOStream > stream) |
| Sets the output stream to write to. More... | |
| virtual bool | setOutputStream (std::ostream &str) |
| tmp drb More... | |
| virtual ossimRefPtr< ossimOStream > | getOutputStream () const |
| Method to return the stream attached to output. More... | |
| virtual void | setPercentComplete (double percentComplete) |
| virtual void | setOutputImageType (ossim_int32 type) |
| virtual void | setOutputImageType (const ossimString &type) |
| virtual ossim_int32 | getOutputImageType () const |
| virtual ossimString | getOutputImageTypeString () const |
| virtual void | setOutputName (const ossimString &outputName) |
| virtual void | setFilename (const ossimFilename &file) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | getWriteImageFlag () const |
| Control flags... More... | |
| virtual bool | getWriteHistogramFlag () const |
| virtual bool | getWriteOverviewFlag () const |
| virtual bool | getScaleToEightBitFlag () const |
| virtual bool | getWriteEnviHeaderFlag () const |
| virtual bool | getWriteErsHeaderFlag () const |
| virtual bool | getWriteExternalGeometryFlag () const |
| virtual bool | getWriteFgdcFlag () const |
| virtual bool | getWriteJpegWorldFileFlag () const |
| virtual bool | getWriteReadmeFlag () const |
| virtual bool | getWriteTiffWorldFileFlag () const |
| virtual bool | getWriteWorldFileFlag () const |
| virtual void | setWriteImageFlag (bool flag) |
| virtual void | setWriteOverviewFlag (bool flag) |
| virtual void | setWriteHistogramFlag (bool flag) |
| virtual void | setScaleToEightBitFlag (bool flag) |
| virtual void | setWriteEnviHeaderFlag (bool flag) |
| virtual void | setWriteErsHeaderFlag (bool flag) |
| virtual void | setWriteExternalGeometryFlag (bool flag) |
| virtual void | setWriteFgdcFlag (bool flag) |
| virtual void | setWriteJpegWorldFile (bool flag) |
| virtual void | setWriteReadme (bool flag) |
| virtual void | setWriteTiffWorldFile (bool flag) |
| virtual void | setWriteWorldFile (bool flag) |
| virtual ossim_uint16 | getOverviewCompressType () const |
| virtual ossim_int32 | getOverviewJpegCompressQuality () const |
| virtual void | setOverviewCompressType (ossim_uint16 type) |
| virtual void | setOverviewJpegCompressQuality (ossim_int32 quality) |
| Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More... | |
| Overrides base "removeListener". More... | |
| virtual void | setPixelType (ossimPixelType type) |
| If "point" the coordinate tie points are relative to the center of the pixel. More... | |
| virtual void | setPixelType (const ossimString &type) |
| virtual ossimPixelType | getPixelType () const |
| virtual void | getPixelTypeString (ossimString &type) const |
Public Member Functions inherited from ossimImageWriter | |
| ossimImageWriter (ossimObject *owner=NULL) | |
| ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed) | |
| virtual | ~ossimImageWriter () |
| virtual bool | setViewingRect (const ossimIrect &aRect) |
| virtual ossimIrect | getAreaOfInterest () const |
Public Member Functions inherited from ossimOutputSource | |
| ossimOutputSource (ossimObject *owner=NULL) | |
| ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
| virtual | ~ossimOutputSource () |
| virtual bool | open (const ossimString &outputName) |
| virtual const ossimString & | getOutputName () |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual bool | writeFile () |
| virtual bool | writeBlockBandSeparate () |
| write out block band separate More... | |
| virtual bool | writeBlockBandSequential () |
| Outputs in band sequential format. More... | |
Protected Member Functions inherited from ossimNitfWriterBase | |
| void | writeGeometry (ossimNitfImageHeaderV2_X *hdr, ossimImageSourceSequencer *seq) |
| Populates tags with geometry info from projection. More... | |
| void | addBlockaTag (ossimMapProjectionInfo &mapInfo, ossimNitfImageHeaderV2_X *hdr) |
| Adds the BLOCKA tag. More... | |
| void | addGeolobTag (const ossimMapProjection *mapProj, ossimNitfImageHeaderV2_X *hdr) |
| Adds the GEOLOB tag. More... | |
| void | addRpcbTag (const ossimIrect &rect, ossimProjection *proj, ossimNitfImageHeaderV2_X *hdr) |
| Adds the RPC00B tag. More... | |
| void | setComplexityLevel (std::streamoff, ossimNitfFileHeaderV2_X *hdr) |
| Sets the complexity level of theFileHeader. More... | |
| void | setComplexityLevel (ossimNitfFileHeaderV2_X *hdr, ossim_uint64 width=0, ossim_uint64 height=0) |
| virtual void | initializeDefaultsFromConfigFile (ossimNitfFileHeaderV2_X *fileHdr, ossimNitfImageHeaderV2_X *imgHdr) |
| Sets file header and image header defaults from config file if found in preferences. More... | |
Protected Member Functions inherited from ossimImageFileWriter | |
| bool | writeWorldFile (const ossimFilename &file) |
| Common world file writer method. More... | |
Private Member Functions | |
| void | takeOverflowTags (bool useFileHeader, bool userDefinedTags) |
Public Types inherited from ossimProcessInterface | |
| enum | ossimProcessStatus { PROCESS_STATUS_UNKNOWN = 0, PROCESS_STATUS_EXECUTING = 1, PROCESS_STATUS_ABORTED = 2, PROCESS_STATUS_ABORT_REQUEST = 3, PROCESS_STATUS_NOT_EXECUTING = 4 } |
Definition at line 32 of file ossimNitfWriter.h.
| ossimNitfWriter::ossimNitfWriter | ( | const ossimFilename & | filename = ossimFilename(""), |
| ossimImageSource * | inputSource = (ossimImageSource*)NULL |
Definition at line 50 of file ossimNitfWriter.cpp.
References ossim::defaultTileSize(), ossimRefPtr< T >::get(), ossimNitfWriterBase::initializeDefaultsFromConfigFile(), m_blockSize, m_fileHeader, m_imageHeader, ossimNitfFileHeaderV2_X::setEncryption(), ossimNitfImageHeaderV2_X::setJustification(), and ossimImageFileWriter::theOutputImageType.
Definition at line 92 of file ossimNitfWriter.cpp.
References close(), m_fileHeader, m_imageHeader, and m_textHeader.
| des | The DES to add to the file. |
Definition at line 887 of file ossimNitfWriter.cpp.
References ossimNitfDataExtensionSegmentV2_1::DESID_KW, ossimNitfDataExtensionSegmentV2_1::getProperty(), m_dataExtensionSegments, ossimRefPtr< T >::valid(), and ossimProperty::valueToString().
Referenced by takeOverflowTags().
Reimplemented from ossimNitfWriterBase.
Definition at line 749 of file ossimNitfWriter.cpp.
Definition at line 755 of file ossimNitfWriter.cpp.
References ossimNitfImageHeader::addTag(), ossimNitfFileHeaderV2_1::addTag(), ossimRefPtr< T >::get(), m_fileHeader, m_imageHeader, ossimNitfTagInformation::setTagData(), and ossimNitfTagInformation::setTagType().
Definition at line 783 of file ossimNitfWriter.cpp.
References m_textEntry, m_textHeader, and ossimRefPtr< T >::valid().
Generic interface to allow one to close a consumer. For displays this might minimize the window and free up internal pointers for file writers it will make sure the file stream is closed and flushed.
Implements ossimOutputSource.
Definition at line 134 of file ossimNitfWriter.cpp.
References m_str.
Referenced by open(), and ~ossimNitfWriter().
Definition at line 882 of file ossimNitfWriter.cpp.
References ossimRefPtr< T >::get(), and m_fileHeader.
Definition at line 877 of file ossimNitfWriter.cpp.
References ossimRefPtr< T >::get(), and m_imageHeader.
Appends this writer image types to list "imageTypeList".
This writer has the following types: nitf_block_band_separate nitf_block_band_sequential
| imageTypeList | stl::vector<ossimString> list to append to. |
Implements ossimImageFileWriter.
Definition at line 188 of file ossimNitfWriter.cpp.
Gets a property.
| The | name of the property to get. |
Definition at line 235 of file ossimNitfWriter.cpp.
References ossimContainerProperty::addChildren(), ossimStringProperty::addConstraint(), ossimNitfWriterBase::getProperty(), ossimPropertyInterface::getPropertyList(), m_blockSize, m_fileHeader, m_imageHeader, ossimString::toString(), and ossimIpt::x.
| propertyNames | Array to populate with property names. |
Definition at line 293 of file ossimNitfWriter.cpp.
References ossimNitfWriterBase::getPropertyNames().
Definition at line 794 of file ossimNitfWriter.cpp.
References m_blockSize, and size.
Definition at line 104 of file ossimNitfWriter.cpp.
References m_str.
Referenced by open(), and writeFile().
| kwl | Keyword list to initialize from. |
| prefix | Usually something like: "object2." |
Definition at line 871 of file ossimNitfWriter.cpp.
References ossimNitfWriterBase::loadState().
Allows a generic interface to open a consumer for writing. If you are a display writer then you would probably show the window or init the device context for writing.
Definition at line 109 of file ossimNitfWriter.cpp.
References ossimString::c_str(), close(), isOpen(), m_str, and ossimImageFileWriter::theFilename.
Referenced by writeFile().
| kwl | Keyword list to save to. |
Definition at line 865 of file ossimNitfWriter.cpp.
References ossimNitfWriterBase::saveState().
Set the properties.
| property | The property to set. |
Definition at line 194 of file ossimNitfWriter.cpp.
References ossimRefPtr< T >::get(), ossimContainerProperty::getPropertyList(), m_fileHeader, m_imageHeader, PTR_CAST, ossimPropertyInterface::setProperties(), ossimNitfWriterBase::setProperty(), setTileSize(), ossimIpt::x, and ossimIpt::y.
Must be divisible by 16.
Note: This is not called setBlockSize just because there was already a virtual setTileSize.
| tileSize | Block size. |
Reimplemented from ossimImageFileWriter.
Definition at line 799 of file ossimNitfWriter.cpp.
References ossimIpt::x, and ossimIpt::y.
Referenced by setProperty().
private |
Definition at line 903 of file ossimNitfWriter.cpp.
References addDataExtensionSegment(), ossimNitfDataExtensionSegment::DE_KW, ossimNitfDataExtensionSegmentV2_1::DESID_KW, ossimNitfDataExtensionSegment::DESITEM_KW, ossimNitfDataExtensionSegment::DESOFLW_KW, ossimNitfDataExtensionSegment::DESVER_KW, m_dataExtensionSegments, m_fileHeader, m_imageHeader, ossimNitfDataExtensionSegmentV2_1::setProperty(), ossimNitfDataExtensionSegmentV2_1::setTagList(), ossimNitfImageHeaderV2_1::takeOverflowTags(), and ossimNitfFileHeaderV2_1::takeOverflowTags().
Referenced by writeBlockBandSeparate().
protectedvirtual |
Definition at line 304 of file ossimNitfWriter.cpp.
References ossimNitfFileHeaderV2_1::addDataExtSegInfoRecord(), ossimNitfFileHeaderV2_1::addImageInfoRecord(), ossimNitfFileHeaderV2_1::addTextInfoRecord(), ossimRefPtr< T >::get(), ossim::getActualBitsPerPixel(), ossim::getBitsPerPixel(), ossimImageSourceSequencer::getBoundingRect(), ossimImageData::getBuf(), ossimNitfImageHeaderV2_X::getCompressionCode(), ossimImageData::getHeight(), ossimImageSourceSequencer::getNextTile(), ossimNitfCommon::getNitfPixelType(), ossimImageData::getNumberOfBands(), ossimImageSource::getNumberOfOutputBands(), ossimImageSourceSequencer::getNumberOfTiles(), ossimImageSourceSequencer::getNumberOfTilesHorizontal(), ossimImageSourceSequencer::getNumberOfTilesVertical(), ossimImageSourceSequencer::getOutputScalarType(), ossimRectilinearDataObject::getScalarType(), ossimImageData::getSizeInBytes(), ossimEndian::getSystemEndianType(), ossimImageData::getWidth(), ossimIrect::height(), m_blockSize, m_dataExtensionSegments, m_fileHeader, m_imageHeader, m_str, m_textEntry, m_textHeader, ossimProcessInterface::needsAborting(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_LITTLE_ENDIAN, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNitfFileHeaderV2_1::replaceImageInfoRecord(), ossim::scalarSizeInBytes(), ossimNitfImageHeaderV2_X::setActualBitsPerPixel(), ossimNitfImageHeaderV2_1::setBandInfo(), ossimNitfImageBandV2_0::setBandRepresentation(), ossimNitfImageHeaderV2_X::setBitsPerPixel(), ossimNitfImageDataMaskV2_1::setBlockCount(), ossimNitfImageDataMaskV2_1::setBlockLengthInBytes(), ossimNitfImageHeaderV2_X::setBlocksPerCol(), ossimNitfImageHeaderV2_X::setBlocksPerRow(), ossimNitfImageHeaderV2_X::setCategory(), ossimNitfWriterBase::setComplexityLevel(), ossimNitfFileHeaderV2_X::setDate(), ossimNitfFileHeaderV2_1::setFileLength(), ossimNitfFileHeaderV2_1::setHeaderLength(), ossimNitfImageInfoRecordV2_1::setImageLength(), ossimNitfImageHeaderV2_X::setImageMode(), ossimNitfImageDataMaskV2_1::setIncludeBlock(), ossimNitfImageHeaderV2_1::setNumberOfBands(), ossimNitfImageHeaderV2_1::setNumberOfCols(), ossimNitfImageHeaderV2_X::setNumberOfPixelsPerBlockCol(), ossimNitfImageHeaderV2_X::setNumberOfPixelsPerBlockRow(), ossimNitfImageHeaderV2_1::setNumberOfRows(), ossimImageFileWriter::setPercentComplete(), ossimNitfImageHeaderV2_X::setPixelType(), ossimNitfImageHeaderV2_X::setRepresentation(), ossimNitfImageInfoRecordV2_1::setSubheaderLength(), ossimNitfTextFileInfoRecordV2_1::setSubheaderLength(), ossimNitfTextFileInfoRecordV2_1::setTextLength(), ossimImageSourceSequencer::setTileSize(), ossimImageSourceSequencer::setToStartOfSequence(), ossimEndian::swap(), takeOverflowTags(), ossimNitfDataExtSegInfoRecordV2_1::theDataExtSegLength, ossimNitfDataExtSegInfoRecordV2_1::theDataExtSegSubheaderLength, ossimImageFileWriter::theInputConnection, tileNumber, ossimRefPtr< T >::valid(), ossimIrect::width(), write(), ossimNitfTextHeaderV2_1::writeStream(), ossimNitfImageHeaderV2_1::writeStream(), ossimNitfImageDataMaskV2_1::writeStream(), ossimNitfFileHeaderV2_1::writeStream(), ossimIpt::x, and ossimIpt::y.
protectedvirtual |
Band 1 is followed by band 2, ... etc.
Definition at line 552 of file ossimNitfWriter.cpp.
References ossimNitfFileHeaderV2_1::addImageInfoRecord(), ossimNitfFileHeaderV2_1::addTextInfoRecord(), ossimRefPtr< T >::get(), ossim::getActualBitsPerPixel(), ossim::getBitsPerPixel(), ossimImageSourceSequencer::getBoundingRect(), ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageSourceSequencer::getNextTile(), ossimNitfCommon::getNitfPixelType(), ossimImageData::getNumberOfBands(), ossimImageSource::getNumberOfOutputBands(), ossimImageSourceSequencer::getNumberOfTiles(), ossimImageSourceSequencer::getNumberOfTilesHorizontal(), ossimImageSourceSequencer::getNumberOfTilesVertical(), ossimImageSourceSequencer::getOutputScalarType(), ossimRectilinearDataObject::getScalarType(), ossimEndian::getSystemEndianType(), ossimImageData::getWidth(), ossimIrect::height(), m_blockSize, m_fileHeader, m_imageHeader, m_str, m_textEntry, m_textHeader, ossimProcessInterface::needsAborting(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_LITTLE_ENDIAN, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNitfFileHeaderV2_1::replaceImageInfoRecord(), ossim::scalarSizeInBytes(), ossimNitfImageHeaderV2_X::setActualBitsPerPixel(), ossimNitfImageHeaderV2_1::setBandInfo(), ossimNitfImageBandV2_0::setBandRepresentation(), ossimNitfImageHeaderV2_X::setBitsPerPixel(), ossimNitfImageHeaderV2_X::setBlocksPerCol(), ossimNitfImageHeaderV2_X::setBlocksPerRow(), ossimNitfImageHeaderV2_X::setCategory(), ossimNitfWriterBase::setComplexityLevel(), ossimNitfFileHeaderV2_X::setDate(), ossimNitfFileHeaderV2_1::setFileLength(), ossimNitfFileHeaderV2_1::setHeaderLength(), ossimNitfImageInfoRecordV2_1::setImageLength(), ossimNitfImageHeaderV2_X::setImageMode(), ossimNitfImageHeaderV2_1::setNumberOfBands(), ossimNitfImageHeaderV2_1::setNumberOfCols(), ossimNitfImageHeaderV2_X::setNumberOfPixelsPerBlockCol(), ossimNitfImageHeaderV2_X::setNumberOfPixelsPerBlockRow(), ossimNitfImageHeaderV2_1::setNumberOfRows(), ossimImageFileWriter::setPercentComplete(), ossimNitfImageHeaderV2_X::setPixelType(), ossimNitfImageHeaderV2_X::setRepresentation(), ossimNitfImageInfoRecordV2_1::setSubheaderLength(), ossimNitfTextFileInfoRecordV2_1::setSubheaderLength(), ossimNitfTextFileInfoRecordV2_1::setTextLength(), ossimImageSourceSequencer::setTileSize(), ossimImageSourceSequencer::setToStartOfSequence(), ossimEndian::swap(), ossimImageFileWriter::theInputConnection, tileNumber, ossimRefPtr< T >::valid(), ossimIrect::width(), ossimNitfTextHeaderV2_1::writeStream(), ossimNitfImageHeaderV2_1::writeStream(), ossimNitfFileHeaderV2_1::writeStream(), ossimIpt::x, and ossimIpt::y.
protectedvirtual |
Definition at line 143 of file ossimNitfWriter.cpp.
References ossimImageSourceSequencer::isMaster(), isOpen(), open(), ossimImageSourceSequencer::slaveProcessTiles(), and ossimImageFileWriter::theInputConnection.
protected |
Definition at line 166 of file ossimNitfWriter.h.
Referenced by getProperty(), getTileSize(), ossimNitfWriter(), writeBlockBandSeparate(), and writeBlockBandSequential().
protected |
Definition at line 163 of file ossimNitfWriter.h.
Referenced by addDataExtensionSegment(), takeOverflowTags(), and writeBlockBandSeparate().
protected |
Definition at line 161 of file ossimNitfWriter.h.
Referenced by addRegisteredTag(), getFileHeader(), getProperty(), ossimNitfWriter(), setProperty(), takeOverflowTags(), writeBlockBandSeparate(), writeBlockBandSequential(), and ~ossimNitfWriter().
protected |
Definition at line 162 of file ossimNitfWriter.h.
Referenced by addRegisteredTag(), getImageHeader(), getProperty(), ossimNitfWriter(), setProperty(), takeOverflowTags(), writeBlockBandSeparate(), writeBlockBandSequential(), and ~ossimNitfWriter().
protected |
Currently disabled...
Definition at line 160 of file ossimNitfWriter.h.
Referenced by close(), isOpen(), open(), writeBlockBandSeparate(), and writeBlockBandSequential().
protected |
Definition at line 165 of file ossimNitfWriter.h.
Referenced by addTextToNitf(), writeBlockBandSeparate(), and writeBlockBandSequential().
protected |
Definition at line 164 of file ossimNitfWriter.h.
Referenced by addTextToNitf(), writeBlockBandSeparate(), writeBlockBandSequential(), and ~ossimNitfWriter().
