#include <ossimGdalWriter.h>
Public Types | |
| enum | ossimGdalOverviewType { ossimGdalOverviewType_NONE = 0, ossimGdalOverviewType_NEAREST = 1, ossimGdalOverviewType_AVERAGE = 2 } |
Public Types inherited from ossimProcessInterface | |
| enum | ossimProcessStatus { PROCESS_STATUS_UNKNOWN = 0, PROCESS_STATUS_EXECUTING = 1, PROCESS_STATUS_ABORTED = 2, PROCESS_STATUS_ABORT_REQUEST = 3, PROCESS_STATUS_NOT_EXECUTING = 4 } |
| ossimGdalWriter () | |
| virtual | ~ossimGdalWriter () |
| ossimGdalWriter (ossimImageSource *inputSource, const ossimFilename &filename) | |
| virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const |
| void getImageTypeList(std::vector<ossimString>& imageTypeList)const More... | |
| virtual bool | hasImageType (const ossimString &imageType) const |
| bool hasImageType(const ossimString& imageType) const More... | |
| virtual ossimString | getExtension () const |
| Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More... | |
| virtual bool | open () |
| virtual void | close () |
| virtual void | setOutputImageType (const ossimString &type) |
| void | setLut (const ossimNBandLutDataObject &lut) |
Public Member Functions inherited from ossimImageFileWriter | |
| ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0) | |
| The writer will own the sequencer. More... | |
| virtual | ~ossimImageFileWriter () |
| virtual bool | getOutputHasInternalOverviews (void) const |
| Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More... | |
| virtual void | setTileSize (const ossimIpt &tileSize) |
| Sets the output image tiling size if supported by the writer. More... | |
| virtual bool | writeEnviHeaderFile () |
| Will write an envi header file. More... | |
| virtual bool | writeErsHeaderFile () |
| Will write an ER Mapper header file. More... | |
| virtual bool | writeExternalGeometryFile () |
| Will write an external geometry file. More... | |
| virtual bool | writeFgdcFile () |
| Will write an fgdc file. More... | |
| virtual bool | writeHistogramFile () |
| Returns true on success, false on error. More... | |
| virtual bool | writeJpegWorldFile () |
| Will write a jpeg world file. More... | |
| virtual bool | writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false) |
| Write out an ossim overview file from the source_file. More... | |
| virtual bool | writeReadmeFile () |
| Will write a readme file. More... | |
| virtual bool | writeTiffWorldFile () |
| Will write a world file. More... | |
| virtual bool | writeWorldFile () |
| virtual bool | writeMetaDataFiles () |
| Convenience method that calls meta data write methods that are flagged to be called. More... | |
| virtual void | setAreaOfInterest (const ossimIrect &inputRect) |
| virtual void | changeSequencer (ossimImageSourceSequencer *sequencer) |
| Sets the sequencer and connects it to the input of this. More... | |
| virtual ossimImageSourceSequencer * | getSequencer () |
| Initialize method. More... | |
| virtual bool | execute () |
| Calls: writeFile() writeMetaDataFiles() More... | |
| virtual bool | writeStream () |
| Method to write the image to a stream. More... | |
| virtual bool | setOutputStream (ossimRefPtr< ossimOStream > stream) |
| Sets the output stream to write to. More... | |
| virtual bool | setOutputStream (std::ostream &str) |
| tmp drb More... | |
| virtual ossimRefPtr< ossimOStream > | getOutputStream () const |
| Method to return the stream attached to output. More... | |
| virtual void | setPercentComplete (double percentComplete) |
| virtual void | setOutputImageType (ossim_int32 type) |
| virtual ossim_int32 | getOutputImageType () const |
| virtual ossimString | getOutputImageTypeString () const |
| virtual void | setOutputName (const ossimString &outputName) |
| virtual void | setFilename (const ossimFilename &file) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | getWriteImageFlag () const |
| Control flags... More... | |
| virtual bool | getWriteHistogramFlag () const |
| virtual bool | getWriteOverviewFlag () const |
| virtual bool | getScaleToEightBitFlag () const |
| virtual bool | getWriteEnviHeaderFlag () const |
| virtual bool | getWriteErsHeaderFlag () const |
| virtual bool | getWriteExternalGeometryFlag () const |
| virtual bool | getWriteFgdcFlag () const |
| virtual bool | getWriteJpegWorldFileFlag () const |
| virtual bool | getWriteReadmeFlag () const |
| virtual bool | getWriteTiffWorldFileFlag () const |
| virtual bool | getWriteWorldFileFlag () const |
| virtual void | setWriteImageFlag (bool flag) |
| virtual void | setWriteOverviewFlag (bool flag) |
| virtual void | setWriteHistogramFlag (bool flag) |
| virtual void | setScaleToEightBitFlag (bool flag) |
| virtual void | setWriteEnviHeaderFlag (bool flag) |
| virtual void | setWriteErsHeaderFlag (bool flag) |
| virtual void | setWriteExternalGeometryFlag (bool flag) |
| virtual void | setWriteFgdcFlag (bool flag) |
| virtual void | setWriteJpegWorldFile (bool flag) |
| virtual void | setWriteReadme (bool flag) |
| virtual void | setWriteTiffWorldFile (bool flag) |
| virtual void | setWriteWorldFile (bool flag) |
| virtual ossim_uint16 | getOverviewCompressType () const |
| virtual ossim_int32 | getOverviewJpegCompressQuality () const |
| virtual void | setOverviewCompressType (ossim_uint16 type) |
| virtual void | setOverviewJpegCompressQuality (ossim_int32 quality) |
| Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More... | |
| Overrides base "removeListener". More... | |
| virtual void | setPixelType (ossimPixelType type) |
| If "point" the coordinate tie points are relative to the center of the pixel. More... | |
| virtual void | setPixelType (const ossimString &type) |
| virtual ossimPixelType | getPixelType () const |
| virtual void | getPixelTypeString (ossimString &type) const |
Public Member Functions inherited from ossimImageWriter | |
| ossimImageWriter (ossimObject *owner=NULL) | |
| ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed) | |
| virtual | ~ossimImageWriter () |
| virtual bool | setViewingRect (const ossimIrect &aRect) |
| virtual ossimIrect | getAreaOfInterest () const |
Public Member Functions inherited from ossimOutputSource | |
| ossimOutputSource (ossimObject *owner=NULL) | |
| ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
| virtual | ~ossimOutputSource () |
| virtual bool | open (const ossimString &outputName) |
| virtual const ossimString & | getOutputName () |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| static void | getSupportedWriters (vector< ossimString > &writers) |
| virtual bool | writeFile () |
| Write out the file. More... | |
| virtual bool | writeBlockFile () |
| virtual void | writeProjectionInfo (GDALDatasetH dataset) |
| virtual void | writeColorMap (int bands) |
| virtual void | setOptions (ossimKeywordlist &kwl, const char *prefix=NULL) |
| void | deleteGdalDriverOptions () |
| ossimString | convertToDriverName (const ossimString &imageTypeName) const |
| GDALDataType | getGdalDataType (ossimScalarType scalar) |
| void | getGdalPropertyNames (std::vector< ossimString > &propertyNames) const |
| const ossimRefPtr< ossimXmlNode > | getGdalOptions () const |
| ossim_int32 | findOptionIdx (const ossimString &name) const |
| void | allocateGdalDriverOptions () |
| void | storeProperty (const ossimString &name, const ossimString &value) |
| bool | getStoredPropertyValue (const ossimString &name, ossimString &value) const |
| bool | validProperty (const ossimString &name) const |
| ossimString | gdalOverviewTypeToString () const |
| ossimGdalOverviewType | gdalOverviewTypeFromString (const ossimString &typeString) const |
| void | buildGdalOverviews () |
| void | appendGdalOption (const ossimString &name, const ossimString &value, bool replaceFlag=true) |
| void | postProcessOutput () const |
| Method called after good writeFile to clean up any unwanted files. More... | |
| bool | isLutEnabled () const |
| void | checkColorLut () |
| bool | isInputDataIndexed () |
| Check input to see if it's indexed. More... | |
Protected Member Functions inherited from ossimImageFileWriter | |
| bool | writeWorldFile (const ossimFilename &file) |
| Common world file writer method. More... | |
Definition at line 19 of file ossimGdalWriter.h.
| Enumerator | |
| ossimGdalOverviewType_NONE | |
| ossimGdalOverviewType_NEAREST | |
| ossimGdalOverviewType_AVERAGE | |
Definition at line 22 of file ossimGdalWriter.h.
| ossimGdalWriter::ossimGdalWriter | ( | ) |
Definition at line 59 of file ossimGdalWriter.cpp.
Definition at line 75 of file ossimGdalWriter.cpp.
References close(), deleteGdalDriverOptions(), theDataset, and theDriverName.
| ossimGdalWriter::ossimGdalWriter | ( | ossimImageSource * | inputSource, |
| const ossimFilename & | filename | ||
protected |
Definition at line 895 of file ossimGdalWriter.cpp.
References deleteGdalDriverOptions(), ossimKeywordlist::find(), ossimImageSourceSequencer::getOutputScalarType(), ossimKeywordlist::getSubstringKeyList(), OSSIM_UINT8, theDriverOptionValues, theGdalDriverOptions, ossimImageFileWriter::theInputConnection, ossimString::toDouble(), and ossimRefPtr< T >::valid().
protected |
Definition at line 969 of file ossimGdalWriter.cpp.
References ossimKeywordlist::add(), ossimKeywordlist::find(), ossimKeywordlist::getSubstringKeyList(), theDriverOptionValues, and ossimString::toString().
protected |
Definition at line 1794 of file ossimGdalWriter.cpp.
References gdalOverviewTypeToString(), ossimImageSourceSequencer::getBoundingRect(), ossimIrect::height(), ossim::min(), ossimNotify(), ossimNotifyLevel_WARN, theDataset, ossimImageFileWriter::theInputConnection, and ossimIrect::width().
protected |
Definition at line 264 of file ossimGdalWriter.cpp.
References ossimConnectableContainerInterface::findAllObjectsOfType(), ossimRefPtr< T >::get(), ossimConnectableObject::getInputList(), ossimImageHandler::getLut(), ossimImageHandler::hasLut(), PTR_CAST, setLut(), STATIC_TYPE_INFO, and ossimImageFileWriter::theInputConnection.
Generic interface to allow one to close a consumer. For displays this might minimize the window and free up internal pointers for file writers it will make sure the file stream is closed and flushed.
Implements ossimOutputSource.
Definition at line 101 of file ossimGdalWriter.cpp.
References theDataset.
Referenced by ~ossimGdalWriter().
protected |
Definition at line 1026 of file ossimGdalWriter.cpp.
References ossimString::c_str(), and ossimString::substitute().
Referenced by getExtension(), getGdalOptions(), getGdalPropertyNames(), open(), and setProperty().
protected |
Definition at line 1007 of file ossimGdalWriter.cpp.
References theGdalDriverOptions.
Referenced by allocateGdalDriverOptions(), and ~ossimGdalWriter().
protected |
protected |
Definition at line 1776 of file ossimGdalWriter.cpp.
References ossimString::downcase(), ossimGdalOverviewType_AVERAGE, ossimGdalOverviewType_NEAREST, ossimGdalOverviewType_NONE, and ossimString::trim().
Referenced by setProperty().
protected |
Definition at line 1755 of file ossimGdalWriter.cpp.
References ossimGdalOverviewType_AVERAGE, ossimGdalOverviewType_NEAREST, ossimGdalOverviewType_NONE, and theGdalOverviewType.
Referenced by buildGdalOverviews().
| imageType | string representing image type. |
Reimplemented from ossimImageFileWriter.
Definition at line 1245 of file ossimGdalWriter.cpp.
References ossimString::c_str(), convertToDriverName(), ossimString::downcase(), ossimString::split(), and ossimImageFileWriter::theOutputImageType.
protected |
Definition at line 854 of file ossimGdalWriter.cpp.
References OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, and OSSIM_USHORT16.
protected |
Definition at line 1655 of file ossimGdalWriter.cpp.
References ossimString::c_str(), convertToDriverName(), ossimXmlNode::findChildNodes(), and ossimImageFileWriter::theOutputImageType.
Referenced by getGdalPropertyNames().
protected |
Definition at line 1614 of file ossimGdalWriter.cpp.
References ossimString::c_str(), convertToDriverName(), ossimXmlNode::findChildNodes(), getGdalOptions(), ossimImageFileWriter::theOutputImageType, and ossimRefPtr< T >::valid().
Referenced by validProperty().
Appends this writer image types to list "imageTypeList".
| imageTypeList | stl::vector<ossimString> list to append to. |
Implements ossimImageFileWriter.
Definition at line 1175 of file ossimGdalWriter.cpp.
Referenced by ossimGdalImageWriterFactory::getImageTypeList().
Definition at line 1432 of file ossimGdalWriter.cpp.
Definition at line 1602 of file ossimGdalWriter.cpp.
protected |
Definition at line 1711 of file ossimGdalWriter.cpp.
References ossimKeywordlist::find(), ossimKeywordlist::getSubstringKeyList(), and theDriverOptionValues.
static |
Definition at line 255 of file ossimGdalWriter.cpp.
Definition at line 1204 of file ossimGdalWriter.cpp.
References ossimImageFileWriter::hasImageType().
Referenced by ossimGdalImageWriterFactory::createWriter().
protected |
Definition at line 1863 of file ossimGdalWriter.cpp.
References ossimImageSource::isIndexedData(), ossimImageFileWriter::theInputConnection, and ossimRefPtr< T >::valid().
protected |
Definition at line 83 of file ossimGdalWriter.cpp.
References theDriver.
Definition at line 181 of file ossimGdalWriter.cpp.
References ossimKeywordlist::find(), and ossimImageFileWriter::loadState().
Referenced by ossimGdalImageWriterFactory::getImageFileWritersByMimeType(), and ossimGdalImageWriterFactory::getImageFileWritersBySuffix().
Allows a generic interface to open a consumer for writing. If you are a display writer then you would probably show the window or init the device context for writing.
Definition at line 88 of file ossimGdalWriter.cpp.
References ossimString::c_str(), convertToDriverName(), theDriver, theDriverName, and ossimImageFileWriter::theOutputImageType.
protected |
Definition at line 1832 of file ossimGdalWriter.cpp.
References ossimFilename::exists(), ossimNotify(), ossimNotifyLevel_NOTICE, ossimFilename::remove(), theDriver, and ossimImageFileWriter::theFilename.
saves the state of the object.
Definition at line 125 of file ossimGdalWriter.cpp.
| void ossimGdalWriter::setLut | ( | const ossimNBandLutDataObject & | lut | ) |
Definition at line 116 of file ossimGdalWriter.cpp.
References ossimNBandLutDataObject::dup(), theColorLut, and theColorLutFlag.
Referenced by checkColorLut().
protectedvirtual |
Definition at line 824 of file ossimGdalWriter.cpp.
Definition at line 110 of file ossimGdalWriter.cpp.
References ossimKeywordlist::clear(), ossimImageFileWriter::setOutputImageType(), and theDriverOptionValues.
Referenced by ossimGdalImageWriterFactory::createWriter(), ossimGdalImageWriterFactory::getImageFileWritersByMimeType(), and ossimGdalImageWriterFactory::getImageFileWritersBySuffix().
Definition at line 1384 of file ossimGdalWriter.cpp.
References ossimKeywordlist::clear(), convertToDriverName(), gdalOverviewTypeFromString(), ossimProperty::getName(), ossimNBandLutDataObject::open(), ossimImageFileWriter::setProperty(), storeProperty(), ossimString::substitute(), theColorLut, theColorLutFlag, theDriverOptionValues, theGdalOverviewType, theLutFilename, ossimImageFileWriter::theOutputImageType, ossimString::toBool(), ossimRefPtr< T >::valid(), validProperty(), and ossimProperty::valueToString().
protected |
Definition at line 1678 of file ossimGdalWriter.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimKeywordlist::find(), ossimKeywordlist::getSize(), ossimKeywordlist::getSubstringKeyList(), theDriverOptionValues, and ossimString::toString().
protected |
Definition at line 1732 of file ossimGdalWriter.cpp.
References getGdalPropertyNames().
protectedvirtual |
Definition at line 619 of file ossimGdalWriter.cpp.
References ossimString::c_str(), ossimRefPtr< T >::get(), ossimImageSourceSequencer::setAreaOfInterest(), MEMTiledDataset::setNoDataValueFlag(), ossimImageSourceSequencer::setToStartOfSequence(), ossimImageWriter::theAreaOfInterest, theDataset, theDriver, ossimImageFileWriter::theFilename, theGdalDriverOptions, ossimImageFileWriter::theInputConnection, and writeProjectionInfo().
protectedvirtual |
Definition at line 684 of file ossimGdalWriter.cpp.
References ossimNBandLutDataObject::getEntryLabels(), ossimNBandLutDataObject::getNumberOfBands(), ossimNBandLutDataObject::getNumberOfEntries(), theColorLut, theDataset, and ossimRefPtr< T >::valid().
protectedvirtual |
Write out the file.
Definition at line 325 of file ossimGdalWriter.cpp.
protectedvirtual |
Definition at line 734 of file ossimGdalWriter.cpp.
References ossimMapProjection::getDecimalDegreesPerPixel(), ossimImageSource::getImageGeometry(), ossimMapProjection::getMetersPerPixel(), ossimMapProjection::getPcsCode(), ossimImageGeometry::getProjection(), ossimMapProjection::getProjectionName(), ossimMapProjection::isGeographic(), ossimMapProjection::lineSampleToEastingNorthing(), ossimMapProjection::lineSampleToWorld(), PTR_CAST, ossimMapProjection::saveState(), ossimImageWriter::theAreaOfInterest, ossimImageFileWriter::theInputConnection, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
Referenced by writeBlockFile().
protected |
Definition at line 139 of file ossimGdalWriter.h.
Referenced by setLut(), setProperty(), and writeColorMap().
protected |
Definition at line 138 of file ossimGdalWriter.h.
Referenced by isLutEnabled(), setLut(), and setProperty().
protected |
Definition at line 130 of file ossimGdalWriter.h.
Referenced by buildGdalOverviews(), close(), writeBlockFile(), writeColorMap(), and ~ossimGdalWriter().
protected |
Definition at line 129 of file ossimGdalWriter.h.
Referenced by isOpen(), open(), postProcessOutput(), and writeBlockFile().
protected |
Definition at line 127 of file ossimGdalWriter.h.
Referenced by open(), and ~ossimGdalWriter().
protected |
Definition at line 133 of file ossimGdalWriter.h.
Referenced by allocateGdalDriverOptions(), appendGdalOption(), getStoredPropertyValue(), setOutputImageType(), setProperty(), and storeProperty().
protected |
Definition at line 135 of file ossimGdalWriter.h.
Referenced by allocateGdalDriverOptions(), deleteGdalDriverOptions(), and writeBlockFile().
protected |
Definition at line 136 of file ossimGdalWriter.h.
Referenced by gdalOverviewTypeToString(), and setProperty().
protected |
Definition at line 132 of file ossimGdalWriter.h.
protected |
Definition at line 140 of file ossimGdalWriter.h.
mutableprotected |
Definition at line 141 of file ossimGdalWriter.h.
