Class for writing a "ENVI" style header. More...
#include <ossimEnviHeaderFileWriter.h>
| ossimEnviHeaderFileWriter () | |
| Initializes the state of the writer. More... | |
| virtual void | getMetadatatypeList (std::vector< ossimString > &metadatatypeList) const |
| Satisfies pure virtual from ossimMetadataWriter base. More... | |
| virtual bool | hasMetadataType (const ossimString &metadataType) const |
Public Member Functions inherited from ossimMetadataFileWriter | |
| ossimMetadataFileWriter () | |
| virtual bool | execute () |
| virtual void | setPercentComplete (double percentComplete) |
| virtual void | setFilename (const ossimFilename &file) |
| const ossimFilename & | getFilename () const |
| virtual void | setPixelType (ossimPixelType pixelType) |
| Ossim uses a concept of "pixel is point" internally. More... | |
| virtual ossimPixelType | getPixelType () const |
| virtual void | setAreaOfInterest (const ossimIrect &areaOfInterest) |
| Sets the area of interest to write the meta data for. More... | |
| virtual ossimIrect | getAreaOfInterest () const |
| ossimObject () | |
| ossimListenerManager () | |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimEnviHeaderFileWriter () |
Protected Member Functions inherited from ossimMetadataFileWriter | |
| virtual | ~ossimMetadataFileWriter () |
Private Member Functions | |
| virtual bool | writeFile () |
| Write out the file. More... | |
Private Attributes | |
| ossimEnviHeader | theHdr |
Definition at line 29 of file ossimEnviHeaderFileWriter.h.
| ossimEnviHeaderFileWriter::ossimEnviHeaderFileWriter | ( | ) |
default constructor
protectedvirtual |
Appends the writers image types to the "metadatatypeList".
| metadatatypeList | stl::vector<ossimString> list to append to. |
Implements ossimMetadataFileWriter.
Definition at line 91 of file ossimEnviHeaderFileWriter.cpp.
| imageType | string representing image type. |
Definition at line 97 of file ossimEnviHeaderFileWriter.cpp.
Users should use this to set the envi header fields that are not taken from theInputConnection prior to calling execute.
Reimplemented from ossimMetadataFileWriter.
Definition at line 43 of file ossimEnviHeaderFileWriter.cpp.
References ossimMetadataFileWriter::loadState(), ossimEnviHeader::loadState(), and theHdr.
privatevirtual |
Write out the file.
Definition at line 63 of file ossimEnviHeaderFileWriter.cpp.
References ossimMapProjectionInfo::getGeom(), ossimImageSource::getImageGeometry(), ossimImageSource::getNumberOfOutputBands(), ossimImageGeometry::getProjection(), ossimIrect::height(), PTR_CAST, ossimEnviHeader::setBands(), ossimEnviHeader::setLines(), ossimEnviHeader::setMapInfo(), ossimEnviHeader::setSamples(), ossimMetadataFileWriter::theAreaOfInterest, ossimMetadataFileWriter::theFilename, theHdr, ossimMetadataFileWriter::theInputConnection, ossimRefPtr< T >::valid(), ossimIrect::width(), and ossimEnviHeader::writeFile().
private |
Definition at line 74 of file ossimEnviHeaderFileWriter.h.
Referenced by loadState(), and writeFile().
