#include <ossimTiffWriter.h>
Public Types | |
| enum | UnitType { UNDEFINED = 0, LINEAR_METER = 9001, LINEAR_FOOT = 9002, LINEAR_FOOT_US_SURVEY = 9003, ANGULAR_DEGREES = 9102 } |
| enum | { USER_DEFINED = 32767 } |
Public Types inherited from ossimProcessInterface | |
| enum | ossimProcessStatus { PROCESS_STATUS_UNKNOWN = 0, PROCESS_STATUS_EXECUTING = 1, PROCESS_STATUS_ABORTED = 2, PROCESS_STATUS_ABORT_REQUEST = 3, PROCESS_STATUS_NOT_EXECUTING = 4 } |
| ossimTiffWriter () | |
| virtual | ~ossimTiffWriter () |
| virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const |
| void getImageTypeList(std::vector<ossimString>& imageTypeList)const More... | |
| virtual bool | open () |
| virtual void | close () |
| virtual void | setJpegQuality (ossim_int32 quality) |
| Ranges from 1 to 100 with 100 being the best. More... | |
| virtual ossim_int32 | getJpegQuality () const |
| virtual void | setCompressionType (const ossimString &type) |
| compression type can be JPEG, PACKBITS, or ZIP/DEFLATE More... | |
| virtual ossimString | getCompressionType () const |
| virtual bool | getGeotiffFlag () const |
| virtual void | setGeotiffFlag (bool flag) |
| virtual void | setTileSize (const ossimIpt &tileSize) |
| Sets the output image tiling size if supported by the writer. More... | |
| virtual ossimIpt | getOutputTileSize () const |
| virtual ossim_int32 | setProjectionInfo (const ossimMapProjectionInfo &proj) |
| void | setLut (const ossimNBandLutDataObject &lut) |
| saves the state of the object. More... | |
| Will set the property whose name matches the argument "property->getName()". More... | |
| Pushes this's names onto the list of property names. More... | |
| virtual ossimString | getExtension () const |
| Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More... | |
| bool | hasImageType (const ossimString &imageType) const |
| bool hasImageType(const ossimString& imageType) const More... | |
Public Member Functions inherited from ossimImageFileWriter | |
| ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0) | |
| The writer will own the sequencer. More... | |
| virtual | ~ossimImageFileWriter () |
| virtual bool | getOutputHasInternalOverviews (void) const |
| Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More... | |
| virtual bool | writeEnviHeaderFile () |
| Will write an envi header file. More... | |
| virtual bool | writeErsHeaderFile () |
| Will write an ER Mapper header file. More... | |
| virtual bool | writeExternalGeometryFile () |
| Will write an external geometry file. More... | |
| virtual bool | writeFgdcFile () |
| Will write an fgdc file. More... | |
| virtual bool | writeHistogramFile () |
| Returns true on success, false on error. More... | |
| virtual bool | writeJpegWorldFile () |
| Will write a jpeg world file. More... | |
| virtual bool | writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false) |
| Write out an ossim overview file from the source_file. More... | |
| virtual bool | writeReadmeFile () |
| Will write a readme file. More... | |
| virtual bool | writeTiffWorldFile () |
| Will write a world file. More... | |
| virtual bool | writeWorldFile () |
| virtual bool | writeMetaDataFiles () |
| Convenience method that calls meta data write methods that are flagged to be called. More... | |
| virtual void | setAreaOfInterest (const ossimIrect &inputRect) |
| virtual void | changeSequencer (ossimImageSourceSequencer *sequencer) |
| Sets the sequencer and connects it to the input of this. More... | |
| virtual ossimImageSourceSequencer * | getSequencer () |
| Initialize method. More... | |
| virtual bool | execute () |
| Calls: writeFile() writeMetaDataFiles() More... | |
| virtual bool | writeStream () |
| Method to write the image to a stream. More... | |
| virtual bool | setOutputStream (ossimRefPtr< ossimOStream > stream) |
| Sets the output stream to write to. More... | |
| virtual bool | setOutputStream (std::ostream &str) |
| tmp drb More... | |
| virtual ossimRefPtr< ossimOStream > | getOutputStream () const |
| Method to return the stream attached to output. More... | |
| virtual void | setPercentComplete (double percentComplete) |
| virtual void | setOutputImageType (ossim_int32 type) |
| virtual void | setOutputImageType (const ossimString &type) |
| virtual ossim_int32 | getOutputImageType () const |
| virtual ossimString | getOutputImageTypeString () const |
| virtual void | setOutputName (const ossimString &outputName) |
| virtual void | setFilename (const ossimFilename &file) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | getWriteImageFlag () const |
| Control flags... More... | |
| virtual bool | getWriteHistogramFlag () const |
| virtual bool | getWriteOverviewFlag () const |
| virtual bool | getScaleToEightBitFlag () const |
| virtual bool | getWriteEnviHeaderFlag () const |
| virtual bool | getWriteErsHeaderFlag () const |
| virtual bool | getWriteExternalGeometryFlag () const |
| virtual bool | getWriteFgdcFlag () const |
| virtual bool | getWriteJpegWorldFileFlag () const |
| virtual bool | getWriteReadmeFlag () const |
| virtual bool | getWriteTiffWorldFileFlag () const |
| virtual bool | getWriteWorldFileFlag () const |
| virtual void | setWriteImageFlag (bool flag) |
| virtual void | setWriteOverviewFlag (bool flag) |
| virtual void | setWriteHistogramFlag (bool flag) |
| virtual void | setScaleToEightBitFlag (bool flag) |
| virtual void | setWriteEnviHeaderFlag (bool flag) |
| virtual void | setWriteErsHeaderFlag (bool flag) |
| virtual void | setWriteExternalGeometryFlag (bool flag) |
| virtual void | setWriteFgdcFlag (bool flag) |
| virtual void | setWriteJpegWorldFile (bool flag) |
| virtual void | setWriteReadme (bool flag) |
| virtual void | setWriteTiffWorldFile (bool flag) |
| virtual void | setWriteWorldFile (bool flag) |
| virtual ossim_uint16 | getOverviewCompressType () const |
| virtual ossim_int32 | getOverviewJpegCompressQuality () const |
| virtual void | setOverviewCompressType (ossim_uint16 type) |
| virtual void | setOverviewJpegCompressQuality (ossim_int32 quality) |
| Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More... | |
| Overrides base "removeListener". More... | |
| virtual void | setPixelType (ossimPixelType type) |
| If "point" the coordinate tie points are relative to the center of the pixel. More... | |
| virtual void | setPixelType (const ossimString &type) |
| virtual ossimPixelType | getPixelType () const |
| virtual void | getPixelTypeString (ossimString &type) const |
Public Member Functions inherited from ossimImageWriter | |
| ossimImageWriter (ossimObject *owner=NULL) | |
| ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed) | |
| virtual | ~ossimImageWriter () |
| virtual bool | setViewingRect (const ossimIrect &aRect) |
| virtual ossimIrect | getAreaOfInterest () const |
Public Member Functions inherited from ossimOutputSource | |
| ossimOutputSource (ossimObject *owner=NULL) | |
| ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
| virtual | ~ossimOutputSource () |
| virtual bool | open (const ossimString &outputName) |
| virtual const ossimString & | getOutputName () |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| static void | dumpTileToFile (ossimRefPtr< ossimImageData > t, const ossimFilename &f) |
| Will take an ossimIMageData tile and write it to disk as a general raster file. More... | |
| virtual bool | writeFile () |
| Write out the file. More... | |
| bool | openTiff () |
| bool | closeTiff () |
| bool | writeToTiles () |
| Writes image data to a tiled tiff format. More... | |
| bool | writeToTilesBandSep () |
| Writes image data to a tiled tiff band separate format. More... | |
| bool | writeToStrips () |
| Writes image data to a strip tiff format. More... | |
| bool | writeToStripsBandSep () |
| Writes image data to a strip tiff band separate format. More... | |
| bool | writeTiffTags () |
| Writes tiff tags from ossimMapProjectionInfo to tiff file. More... | |
| bool | writeGeotiffTags (ossimRefPtr< ossimMapProjectionInfo > projectionInfo) |
| Writes geotiff tags from ossimMapProjectionInfo to tiff file. More... | |
| bool | isTiled () const |
| void | writeMinMaxTags (const vector< ossim_float64 > &minBand, const vector< ossim_float64 > &maxBand) |
| bool | isLutEnabled () const |
| UnitType | getUnitType (ossim_int32 pcsCode, const ossimString &projName) const |
| UnitType | getPcsUnitType (ossim_int32 pcsCode) const |
| void | checkColorLut () |
Protected Member Functions inherited from ossimImageFileWriter | |
| bool | writeWorldFile (const ossimFilename &file) |
| Common world file writer method. More... | |
Definition at line 25 of file ossimTiffWriter.h.
| anonymous enum |
| Enumerator | |
| USER_DEFINED | |
Definition at line 42 of file ossimTiffWriter.h.
| Enumerator | |
| UNDEFINED | |
| LINEAR_METER | |
| LINEAR_FOOT | |
| LINEAR_FOOT_US_SURVEY | |
| ANGULAR_DEGREES | |
Definition at line 33 of file ossimTiffWriter.h.
| ossimTiffWriter::ossimTiffWriter | ( | ) |
Definition at line 61 of file ossimTiffWriter.cpp.
Referenced by dumpTileToFile().
protected |
Definition at line 390 of file ossimTiffWriter.cpp.
References ossimConnectableContainerInterface::findAllObjectsOfType(), ossimRefPtr< T >::get(), ossimConnectableObject::getInputList(), ossimImageHandler::getLut(), PTR_CAST, setLut(), STATIC_TYPE_INFO, and ossimImageFileWriter::theInputConnection.
Generic interface to allow one to close a consumer. For displays this might minimize the window and free up internal pointers for file writers it will make sure the file stream is closed and flushed.
Implements ossimOutputSource.
Definition at line 1580 of file ossimTiffWriter.cpp.
References closeTiff().
Referenced by ATP::AtpAnnotatedImage::write().
protected |
Definition at line 152 of file ossimTiffWriter.cpp.
References theTif.
Referenced by close(), open(), openTiff(), and ~ossimTiffWriter().
static |
Definition at line 1755 of file ossimTiffWriter.cpp.
References ossimRefPtr< T >::get(), OSSIM_UINT8, ossimTiffWriter(), and ossimMemoryImageSource::setImage().
Definition at line 1620 of file ossimTiffWriter.cpp.
References theCompressionType.
Referenced by getProperty().
| imageType | string representing image type. |
Reimplemented from ossimImageFileWriter.
Definition at line 1656 of file ossimTiffWriter.cpp.
Definition at line 1625 of file ossimTiffWriter.cpp.
References theOutputGeotiffTagsFlag.
Appends this writer image types to list "imageTypeList".
This writer has the following types: tiff_strip tiff_strip_band_separate tiff_tiled tiff_tiled_band_separate
| imageTypeList | stl::vector<ossimString> list to append to. |
Implements ossimImageFileWriter.
Definition at line 1648 of file ossimTiffWriter.cpp.
Definition at line 1609 of file ossimTiffWriter.cpp.
References theJpegQuality.
protected |
Definition at line 1730 of file ossimTiffWriter.cpp.
References ossimMapProjection::getProjectionUnits(), ossimEpsgProjectionDatabase::instance(), LINEAR_FOOT_US_SURVEY, LINEAR_METER, OSSIM_METERS, PTR_CAST, UNDEFINED, and ossimRefPtr< T >::valid().
Referenced by getUnitType().
| name | Name of property to return. |
Definition at line 1471 of file ossimTiffWriter.cpp.
References ossimStringProperty::addConstraint(), ossimFilenameProperty::addFilter(), ossimKeywordNames::COMPRESSION_QUALITY_KW, ossimKeywordNames::COMPRESSION_TYPE_KW, ossimRefPtr< T >::get(), getCompressionType(), ossimImageFileWriter::getProperty(), ossimFilenameProperty::ossimFilenamePropertyIoType_INPUT, ossimNumericProperty::ossimNumericPropertyType_INT, ossimKeywordNames::OUTPUT_TILE_SIZE_KW, PTR_CAST, ossimNumericProperty::setNumericType(), theColorLutFlag, theForceBigTiffFlag, theJpegQuality, theLutFilename, theOutputTileSize, ossimString::toString(), ossimRefPtr< T >::valid(), and ossimIpt::x.
| propertyNames | array to add this's property names to. |
Definition at line 1552 of file ossimTiffWriter.cpp.
References ossimKeywordNames::COMPRESSION_QUALITY_KW, ossimKeywordNames::COMPRESSION_TYPE_KW, ossimImageFileWriter::getPropertyNames(), and ossimKeywordNames::OUTPUT_TILE_SIZE_KW.
protected |
Definition at line 1682 of file ossimTiffWriter.cpp.
References ANGULAR_DEGREES, getPcsUnitType(), LINEAR_FOOT, LINEAR_FOOT_US_SURVEY, LINEAR_METER, OSSIM_FEET, OSSIM_METERS, OSSIM_US_SURVEY_FEET, ossimImageFileWriter::theLinearUnits, and UNDEFINED.
Definition at line 1661 of file ossimTiffWriter.cpp.
References ossimImageFileWriter::hasImageType().
protected |
Definition at line 1566 of file ossimTiffWriter.cpp.
References theTif.
Referenced by ~ossimTiffWriter().
protected |
Definition at line 847 of file ossimTiffWriter.cpp.
References ossimImageFileWriter::theOutputImageType.
Referenced by writeTiffTags().
Definition at line 735 of file ossimTiffWriter.cpp.
References ossim::defaultTileSize(), and ossimKeywordlist::find().
Allows a generic interface to open a consumer for writing. If you are a display writer then you would probably show the window or init the device context for writing.
Definition at line 1571 of file ossimTiffWriter.cpp.
References closeTiff(), openTiff(), and theTif.
protected |
Definition at line 95 of file ossimTiffWriter.cpp.
References ossimString::c_str(), closeTiff(), ossimImageSourceSequencer::getBoundingRect(), ossimObject::getClassName(), ossimImageSource::getNumberOfOutputBands(), ossimImageSourceSequencer::getOutputScalarType(), ossimIrect::height(), ossimErrorCodes::OSSIM_ERROR, ossimSetError(), ossim::scalarSizeInBytes(), ossimErrorStatusInterface::setErrorStatus(), ossimString::size(), status, theBigTiffFlag, ossimImageFileWriter::theFilename, theForceBigTiffFlag, ossimImageFileWriter::theInputConnection, theTif, and ossimIrect::width().
Referenced by open().
Definition at line 681 of file ossimTiffWriter.cpp.
References ossimKeywordlist::add(), and theOutputGeotiffTagsFlag.
Definition at line 1615 of file ossimTiffWriter.cpp.
Referenced by setProperty().
Definition at line 1630 of file ossimTiffWriter.cpp.
Referenced by writeRaster(), and ossimHlzTool::writeSlopeImage().
This value is only used if the compression type is set to jpeg. (default = 75)
| quality | Value to set theJpegQuality to. |
Definition at line 1585 of file ossimTiffWriter.cpp.
| void ossimTiffWriter::setLut | ( | const ossimNBandLutDataObject & | lut | ) |
Definition at line 675 of file ossimTiffWriter.cpp.
References ossimNBandLutDataObject::dup(), theColorLut, and theColorLutFlag.
Referenced by checkColorLut().
Definition at line 1640 of file ossimTiffWriter.cpp.
References ossimErrorCodes::OSSIM_OK, and theProjectionInfo.
| property | Object containing property to set. |
Definition at line 1420 of file ossimTiffWriter.cpp.
References ossimKeywordNames::COMPRESSION_QUALITY_KW, ossimKeywordNames::COMPRESSION_TYPE_KW, ossimRefPtr< T >::get(), ossimProperty::getName(), ossimNBandLutDataObject::open(), ossimKeywordNames::OUTPUT_TILE_SIZE_KW, PTR_CAST, setCompressionType(), setJpegQuality(), ossimImageFileWriter::setProperty(), theColorLut, theColorLutFlag, theForceBigTiffFlag, theLutFilename, theOutputTileSize, ossimProperty::valueToString(), ossimStringProperty::valueToString(), ossimIpt::x, and ossimIpt::y.
If not supported this simply sets the sequencer(input) tile size.
Definition at line 1337 of file ossimTiffWriter.cpp.
References ossimIpt::x, and ossimIpt::y.
protectedvirtual |
Write out the file.
Definition at line 464 of file ossimTiffWriter.cpp.
protected |
Definition at line 376 of file ossimTiffWriter.cpp.
References theTif, ossimRefPtr< T >::valid(), and ossimGeoTiff::writeTags().
protected |
Definition at line 1355 of file ossimTiffWriter.cpp.
References theTif.
protected |
Definition at line 162 of file ossimTiffWriter.cpp.
References ossim::COMPRESSION_NONE, ossimString::downcase(), ossimObject::getClassName(), ossimImageSourceSequencer::getMaxPixelValue(), ossimImageSourceSequencer::getMinPixelValue(), ossimNBandLutDataObject::getNumberOfEntries(), ossimImageSource::getNumberOfOutputBands(), ossimImageSourceSequencer::getOutputScalarType(), ossimIpt::hasNans(), ossimIrect::height(), isTiled(), ossimErrorCodes::OSSIM_ERROR, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SINT16, OSSIM_UCHAR, OSSIM_UINT16, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, ossimSetError(), ossimErrorStatusInterface::setErrorStatus(), ossimImageWriter::theAreaOfInterest, theColorLut, theColorLutFlag, theCompressionType, ossimImageFileWriter::theInputConnection, theJpegQuality, ossimImageFileWriter::theOutputImageType, theOutputTileSize, thePhotoMetric, theTif, ossimIrect::width(), writeMinMaxTags(), ossimIpt::x, and ossimIpt::y.
protected |
Definition at line 1102 of file ossimTiffWriter.cpp.
References theTif.
protected |
Definition at line 1218 of file ossimTiffWriter.cpp.
References theTif.
protected |
Definition at line 857 of file ossimTiffWriter.cpp.
References theTif.
protected |
Definition at line 981 of file ossimTiffWriter.cpp.
References theTif.
protected |
Definition at line 228 of file ossimTiffWriter.h.
Referenced by openTiff().
protected |
Definition at line 225 of file ossimTiffWriter.h.
Referenced by setLut(), setProperty(), and writeTiffTags().
protected |
Definition at line 222 of file ossimTiffWriter.h.
Referenced by getProperty(), isLutEnabled(), setLut(), setProperty(), and writeTiffTags().
protected |
Definition at line 218 of file ossimTiffWriter.h.
Referenced by getCompressionType(), setCompressionType(), and writeTiffTags().
protected |
Definition at line 227 of file ossimTiffWriter.h.
Referenced by getProperty(), openTiff(), and setProperty().
protected |
Definition at line 220 of file ossimTiffWriter.h.
Referenced by getJpegQuality(), getProperty(), setJpegQuality(), and writeTiffTags().
protected |
Definition at line 226 of file ossimTiffWriter.h.
Referenced by getProperty(), and setProperty().
mutableprotected |
Definition at line 229 of file ossimTiffWriter.h.
protected |
Definition at line 221 of file ossimTiffWriter.h.
Referenced by getGeotiffFlag(), saveState(), and setGeotiffFlag().
protected |
Definition at line 224 of file ossimTiffWriter.h.
Referenced by getOutputTileSize(), getProperty(), setProperty(), and writeTiffTags().
protected |
Definition at line 219 of file ossimTiffWriter.h.
protected |
Definition at line 223 of file ossimTiffWriter.h.
Referenced by setProjectionInfo().
protected |
Definition at line 217 of file ossimTiffWriter.h.
Referenced by closeTiff(), isOpen(), open(), openTiff(), writeGeotiffTags(), writeMinMaxTags(), writeTiffTags(), writeToStrips(), writeToStripsBandSep(), writeToTiles(), and writeToTilesBandSep().
