ossimWriter - Generic image writer. More...
#include <ossimWriter.h>
| ossimWriter () | |
| virtual | ~ossimWriter () |
| virtual ossimString | getExtension () const |
| Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More... | |
| virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const |
| getImageTypeList method. More... | |
| isOpen More... | |
| virtual bool | open () |
| open More... | |
| virtual void | close () |
| close Flushes and deletes stream if we own it. More... | |
| bool | hasImageType (const ossimString &imageType) const |
| bool hasImageType(const ossimString& imageType) const More... | |
| virtual bool | writeStream () |
| Method to write the image to a stream. More... | |
| virtual bool | setOutputStream (std::ostream &str) |
| Sets the output stream to write to. More... | |
| virtual void | setTileSize (const ossimIpt &tileSize) |
| Sets the output tile size for tiled formats. More... | |
| virtual const ossimIpt & | getOutputTileSize () const |
| Gets the tile size. More... | |
| Saves the state of the object. More... | |
| Will set the property whose name matches the argument "property->getName()". More... | |
| Pushes this's names onto the list of property names. More... | |
Public Member Functions inherited from ossimImageFileWriter | |
| ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0) | |
| The writer will own the sequencer. More... | |
| virtual | ~ossimImageFileWriter () |
| virtual bool | getOutputHasInternalOverviews (void) const |
| Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More... | |
| virtual bool | writeEnviHeaderFile () |
| Will write an envi header file. More... | |
| virtual bool | writeErsHeaderFile () |
| Will write an ER Mapper header file. More... | |
| virtual bool | writeExternalGeometryFile () |
| Will write an external geometry file. More... | |
| virtual bool | writeFgdcFile () |
| Will write an fgdc file. More... | |
| virtual bool | writeHistogramFile () |
| Returns true on success, false on error. More... | |
| virtual bool | writeJpegWorldFile () |
| Will write a jpeg world file. More... | |
| virtual bool | writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false) |
| Write out an ossim overview file from the source_file. More... | |
| virtual bool | writeReadmeFile () |
| Will write a readme file. More... | |
| virtual bool | writeTiffWorldFile () |
| Will write a world file. More... | |
| virtual bool | writeWorldFile () |
| virtual bool | writeMetaDataFiles () |
| Convenience method that calls meta data write methods that are flagged to be called. More... | |
| virtual void | setAreaOfInterest (const ossimIrect &inputRect) |
| virtual void | changeSequencer (ossimImageSourceSequencer *sequencer) |
| Sets the sequencer and connects it to the input of this. More... | |
| virtual ossimImageSourceSequencer * | getSequencer () |
| Initialize method. More... | |
| virtual bool | execute () |
| Calls: writeFile() writeMetaDataFiles() More... | |
| virtual bool | setOutputStream (ossimRefPtr< ossimOStream > stream) |
| virtual ossimRefPtr< ossimOStream > | getOutputStream () const |
| Method to return the stream attached to output. More... | |
| virtual void | setPercentComplete (double percentComplete) |
| virtual void | setOutputImageType (ossim_int32 type) |
| virtual void | setOutputImageType (const ossimString &type) |
| virtual ossim_int32 | getOutputImageType () const |
| virtual ossimString | getOutputImageTypeString () const |
| virtual void | setOutputName (const ossimString &outputName) |
| virtual void | setFilename (const ossimFilename &file) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | getWriteImageFlag () const |
| Control flags... More... | |
| virtual bool | getWriteHistogramFlag () const |
| virtual bool | getWriteOverviewFlag () const |
| virtual bool | getScaleToEightBitFlag () const |
| virtual bool | getWriteEnviHeaderFlag () const |
| virtual bool | getWriteErsHeaderFlag () const |
| virtual bool | getWriteExternalGeometryFlag () const |
| virtual bool | getWriteFgdcFlag () const |
| virtual bool | getWriteJpegWorldFileFlag () const |
| virtual bool | getWriteReadmeFlag () const |
| virtual bool | getWriteTiffWorldFileFlag () const |
| virtual bool | getWriteWorldFileFlag () const |
| virtual void | setWriteImageFlag (bool flag) |
| virtual void | setWriteOverviewFlag (bool flag) |
| virtual void | setWriteHistogramFlag (bool flag) |
| virtual void | setScaleToEightBitFlag (bool flag) |
| virtual void | setWriteEnviHeaderFlag (bool flag) |
| virtual void | setWriteErsHeaderFlag (bool flag) |
| virtual void | setWriteExternalGeometryFlag (bool flag) |
| virtual void | setWriteFgdcFlag (bool flag) |
| virtual void | setWriteJpegWorldFile (bool flag) |
| virtual void | setWriteReadme (bool flag) |
| virtual void | setWriteTiffWorldFile (bool flag) |
| virtual void | setWriteWorldFile (bool flag) |
| virtual ossim_uint16 | getOverviewCompressType () const |
| virtual ossim_int32 | getOverviewJpegCompressQuality () const |
| virtual void | setOverviewCompressType (ossim_uint16 type) |
| virtual void | setOverviewJpegCompressQuality (ossim_int32 quality) |
| Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More... | |
| Overrides base "removeListener". More... | |
| virtual void | setPixelType (ossimPixelType type) |
| If "point" the coordinate tie points are relative to the center of the pixel. More... | |
| virtual void | setPixelType (const ossimString &type) |
| virtual ossimPixelType | getPixelType () const |
| virtual void | getPixelTypeString (ossimString &type) const |
Public Member Functions inherited from ossimImageWriter | |
| ossimImageWriter (ossimObject *owner=NULL) | |
| ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed) | |
| virtual | ~ossimImageWriter () |
| virtual bool | setViewingRect (const ossimIrect &aRect) |
| virtual ossimIrect | getAreaOfInterest () const |
Public Member Functions inherited from ossimOutputSource | |
| ossimOutputSource (ossimObject *owner=NULL) | |
| ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
| virtual | ~ossimOutputSource () |
| virtual bool | open (const ossimString &outputName) |
| virtual const ossimString & | getOutputName () |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual bool | writeFile () |
| Write out the file. More... | |
Protected Member Functions inherited from ossimImageFileWriter | |
| bool | writeWorldFile (const ossimFilename &file) |
| Common world file writer method. More... | |
Private Member Functions | |
| bool | writeStreamTtbs () |
| Writes a tiled tiff band separate to stream. More... | |
| bool | writeTiffHdr () |
| Writes tiff header to stream. More... | |
| bool | writeTiffTags (const std::vector< ossim_uint64 > &tile_offsets, const std::vector< ossim_uint64 > &tile_byte_counts, const std::vector< ossim_float64 > &minBands, const std::vector< ossim_float64 > &maxBands) |
| Writes tags to image file directory(IFD). More... | |
| bool | writeMinMaxTiffTags (std::streamoff &arrayWritePos) |
| Writes tags TIFFTAG_MINSAMPLEVALUE(280) and TIFFTAG_MAXSAMPLEVALUE(281). More... | |
| bool | writeSMinSMaxTiffTags (const std::vector< ossim_float64 > &minBands, const std::vector< ossim_float64 > &maxBands, std::streamoff &arrayWritePos) |
| Writes tags TIFFTAG_SMINSAMPLEVALUE(340) and TIFFTAG_SMAXSAMPLEVALUE(341). More... | |
| template<class T > | |
| void | writeTiffTag (ossim_uint16 tag, ossim_uint16 type, ossim_uint64 count, const T *value, std::streamoff &arrayWritePos) |
| Writes tiff tag to image file directory(IFD). More... | |
| bool | writeTiffTilesBandSeparate (std::vector< ossim_uint64 > &tile_offsets, std::vector< ossim_uint64 > &tile_byte_counts, std::vector< ossim_float64 > &minBands, std::vector< ossim_float64 > &maxBands) |
| Writes image data to stream. More... | |
| ossim_uint16 | getTiffSampleFormat () const |
| Gets the tiff sample format based on scalar type. More... | |
| bool | isTiled () const |
| bool | getAlignTilesFlag () const |
| ossim_int64 | getBlockSize () const |
| bool | getFlushTilesFlag () const |
| bool | getWriteBlanksFlag () const |
| bool | needsMinMax () const |
Private Attributes | |
| std::ostream * | m_str |
| bool | m_ownsStreamFlag |
| ossimRefPtr< ossimKeywordlist > | m_kwl |
| Hold all options. More... | |
| ossimIpt | m_outputTileSize |
Please do NOT add any external library dependencies. drb - 26 May 2016
Definition at line 28 of file ossimWriter.h.
| ossimWriter::ossimWriter | ( | ) |
default constructor
Definition at line 37 of file ossimWriter.cpp.
References ossimKeywordlist::addPair(), ossim::defaultTileSize(), m_kwl, and m_outputTileSize.
virtual destructor
Definition at line 54 of file ossimWriter.cpp.
References close(), and m_kwl.
Implements ossimOutputSource.
Definition at line 62 of file ossimWriter.cpp.
References m_ownsStreamFlag, and m_str.
Referenced by open(), writeFile(), and ~ossimWriter().
private |
Definition at line 1219 of file ossimWriter.cpp.
References ossimKeywordlist::findKey(), and m_kwl.
private |
Definition at line 1230 of file ossimWriter.cpp.
| imageType | string representing image type. |
Reimplemented from ossimImageFileWriter.
Definition at line 92 of file ossimWriter.cpp.
References ossimImageFileWriter::theOutputImageType.
private |
Definition at line 1252 of file ossimWriter.cpp.
Satisfies ossimImageFileWriter::getImageTypeList pure virtual.
Appends the writers image types to the "imageTypeList".
Current write type: ossim_ttbs - tiled tiff band separate, big tiff format.
| imageTypeList | list to append to. |
Implements ossimImageFileWriter.
Definition at line 102 of file ossimWriter.cpp.
Definition at line 82 of file ossimWriter.cpp.
Gets the tile size.
Definition at line 1008 of file ossimWriter.cpp.
References m_outputTileSize.
| name | Name of property to return. |
Definition at line 1113 of file ossimWriter.cpp.
References ossimString::string().
| propertyNames | array to add this's property names to. |
Definition at line 1170 of file ossimWriter.cpp.
Definition at line 77 of file ossimWriter.cpp.
private |
E.g SAMPLEFORMAT_UINT, SAMPLEFORMAT_INT or SAMPLEFORMAT_IEEEFP.
Definition at line 1180 of file ossimWriter.cpp.
References ossimImageSourceSequencer::getOutputScalarType(), ossim::OSAMPLEFORMAT_IEEEFP, ossim::OSAMPLEFORMAT_INT, ossim::OSAMPLEFORMAT_UINT, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SINT16, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, and ossimImageFileWriter::theInputConnection.
Referenced by writeTiffTags().
private |
Definition at line 1263 of file ossimWriter.cpp.
Definition at line 139 of file ossimWriter.cpp.
Referenced by open().
isOpen
Definition at line 108 of file ossimWriter.cpp.
References m_str.
Referenced by writeFile(), and writeStream().
private |
Definition at line 1214 of file ossimWriter.cpp.
Definition at line 1020 of file ossimWriter.cpp.
References ossimKeywordlist::findKey(), ossimImageFileWriter::loadState(), and ossimImageFileWriter::theOutputImageType.
private |
Definition at line 1274 of file ossimWriter.cpp.
References ossimImageSourceSequencer::getOutputScalarType(), OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SINT16, OSSIM_UINT32, and ossimImageFileWriter::theInputConnection.
open
Definition at line 113 of file ossimWriter.cpp.
References ossimString::c_str(), close(), hasImageType(), m_ownsStreamFlag, m_str, ossimString::size(), status, ossimImageFileWriter::theFilename, and ossimImageFileWriter::theOutputImageType.
Referenced by writeFile().
Definition at line 1013 of file ossimWriter.cpp.
References ossimKeywordlist::add(), ossimRefPtr< T >::get(), m_kwl, and ossimImageFileWriter::saveState().
This sets the stream and sets m_ownsStreamFlag to false. So destructor will not delete the stream if this method is used.
| stream | The stream to write to. |
Definition at line 975 of file ossimWriter.cpp.
| property | Object containing property to set. |
Definition at line 1068 of file ossimWriter.cpp.
References ossimRefPtr< T >::valid().
| tileSize | Must be a multiple of 16. |
Definition at line 986 of file ossimWriter.cpp.
References ossimIpt::x, and ossimIpt::y.
protectedvirtual |
Write out the file.
Definition at line 149 of file ossimWriter.cpp.
References close(), ossimErrorStatusInterface::getErrorStatus(), ossimImageSourceSequencer::isMaster(), isOpen(), open(), ossimErrorCodes::OSSIM_OK, status, ossimImageFileWriter::theInputConnection, ossimRefPtr< T >::valid(), and writeStream().
private |
Only written if scalar type is an unsigned byte or short.
Definition at line 632 of file ossimWriter.cpp.
References ossimImageSourceSequencer::getOutputScalarType(), OSSIM_UINT16, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, ossim::OTIFF_SHORT, ossim::OTIFFTAG_MAXSAMPLEVALUE, ossim::OTIFFTAG_MINSAMPLEVALUE, status, and ossimImageFileWriter::theInputConnection.
private |
Only written if scalar type is not an unsigned byte or short.
| minBands | Array of min values from image write. |
| maxBands | Array of max values from image write. |
Definition at line 693 of file ossimWriter.cpp.
References ossimImageSourceSequencer::getOutputScalarType(), OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SINT16, OSSIM_UINT32, ossim::OTIFF_FLOAT, ossim::OTIFFTAG_SMAXSAMPLEVALUE, ossim::OTIFFTAG_SMINSAMPLEVALUE, status, and ossimImageFileWriter::theInputConnection.
Definition at line 180 of file ossimWriter.cpp.
References ossimImageSourceSequencer::getTileHeight(), ossimImageSourceSequencer::getTileWidth(), isOpen(), m_outputTileSize, ossimImageSourceSequencer::setTileSize(), status, ossimImageFileWriter::theInputConnection, ossimImageFileWriter::theOutputImageType, ossimRefPtr< T >::valid(), writeStreamTtbs(), ossimIpt::x, and ossimIpt::y.
private |
Definition at line 211 of file ossimWriter.cpp.
References status, writeTiffHdr(), writeTiffTags(), and writeTiffTilesBandSeparate().
Referenced by writeStream().
private |
Definition at line 239 of file ossimWriter.cpp.
References ossim::byteOrder(), m_str, and OSSIM_LITTLE_ENDIAN.
Referenced by writeStreamTtbs().
private |
| tag | |
| type | |
| count | |
| value(s) | or offset to array. |
| arrayWritePos | Position to write array to. This will be updated if array is written with new offset. |
Definition at line 734 of file ossimWriter.cpp.
References m_str.
private |
| tile_offsets | |
| tile_byte_counts | |
| minBands | |
| maxBands |
Definition at line 275 of file ossimWriter.cpp.
References ossimEllipsoid::a(), ossimEllipsoid::b(), ossim::COMPRESSION_NONE, ossimDatum::ellipsoid(), ossimDatum::epsgCode(), ossimRefPtr< T >::get(), ossim::getBitsPerPixel(), ossimMapProjection::getDatum(), ossimMapProjection::getDecimalDegreesPerPixel(), ossimEllipsoid::getEpsgCode(), ossimImageSource::getImageGeometry(), ossimMapProjection::getMetersPerPixel(), ossimImageSource::getNumberOfOutputBands(), ossimImageSourceSequencer::getOutputScalarType(), ossimMapProjection::getPcsCode(), ossimImageGeometry::getProjection(), getTiffSampleFormat(), ossimIrect::height(), ossimMapProjection::isGeographic(), isTiled(), ossimGpt::lat, ossimMapProjection::lineSampleToEastingNorthing(), ossimMapProjection::lineSampleToWorld(), ossimGpt::lon, m_outputTileSize, m_str, ossim::OANGULAR_DEGREE, ossim::OGEO_DOUBLE_PARAMS_TAG, ossim::OGEO_KEY_DIRECTORY_TAG, ossim::OGEOG_ANGULAR_UNITS_GEO_KEY, ossim::OGEOG_ELLIPSOID_GEO_KEY, ossim::OGEOG_GEODETIC_DATUM_GEO_KEY, ossim::OGEOG_SEMI_MAJOR_AXIS, ossim::OGEOG_SEMI_MINOR_AXIS, ossim::OGEOGRAPHIC_TYPE_GEO_KEY, ossim::OGT_MODEL_TYPE_GEO_KEY, ossim::OGT_RASTER_TYPE_GEO_KEY, ossim::OLINEAR_METER, ossim::OMODEL_PIXEL_SCALE_TAG, ossim::OMODEL_TIE_POINT_TAG, ossim::OMODEL_TYPE_GEOGRAPHIC, ossim::OMODEL_TYPE_PROJECTED, ossim::OPHOTO_MINISBLACK, ossim::OPHOTO_RGB, ossim::OPIXEL_IS_POINT, ossim::OPROJ_LINEAR_UNITS_GEO_KEY, ossim::OPROJECTED_CS_TYPE_GEO_KEY, ossim::OPROJECTION_GEO_KEY, OSSIM_DEFAULT_MAX_PIX_UINT16, ossim::OTIFF_DOUBLE, ossim::OTIFF_LONG, ossim::OTIFF_LONG8, ossim::OTIFF_SHORT, ossim::OTIFFTAG_BITSPERSAMPLE, ossim::OTIFFTAG_COMPRESSION, ossim::OTIFFTAG_IMAGELENGTH, ossim::OTIFFTAG_IMAGEWIDTH, ossim::OTIFFTAG_PHOTOMETRIC, ossim::OTIFFTAG_PLANARCONFIG, ossim::OTIFFTAG_PLANARCONFIG_SEPARATE, ossim::OTIFFTAG_SAMPLEFORMAT, ossim::OTIFFTAG_SAMPLESPERPIXEL, ossim::OTIFFTAG_TILEBYTECOUNTS, ossim::OTIFFTAG_TILELENGTH, ossim::OTIFFTAG_TILEOFFSETS, ossim::OTIFFTAG_TILEWIDTH, status, ossimImageWriter::theAreaOfInterest, ossimImageFileWriter::theInputConnection, true, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimIrect::width(), writeMinMaxTiffTags(), writeSMinSMaxTiffTags(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
private |
Data is in a band separate tile layout(PLANARCONFIG_SEPARATE), i.e. all the red tiles, all the green tiles, all the blue tiles.
| tile_offsets | Initialized by this with offset for each tile. |
| tile_byte_counts | Initialized by this with the byte count of each tile. |
| minBands | Initialized by this with the min values for each band. |
| maxBands | Initialized by this with the max values for each band. |
Definition at line 776 of file ossimWriter.cpp.
private |
Hold all options.
Definition at line 293 of file ossimWriter.h.
Referenced by getAlignTilesFlag(), getBlockSize(), getFlushTilesFlag(), getWriteBlanksFlag(), ossimWriter(), saveState(), and ~ossimWriter().
private |
Definition at line 295 of file ossimWriter.h.
Referenced by getOutputTileSize(), ossimWriter(), writeStream(), and writeTiffTags().
private |
Definition at line 290 of file ossimWriter.h.
Referenced by close(), open(), and setOutputStream().
private |
Definition at line 289 of file ossimWriter.h.
Referenced by close(), isOpen(), open(), setOutputStream(), writeTiffHdr(), writeTiffTag(), and writeTiffTags().
