#include <ossimArcInfoGridWriter.h>
| ossimArcInfoGridWriter () | |
| virtual | ~ossimArcInfoGridWriter () |
| ossimArcInfoGridWriter (ossimImageSource *inputSource, const ossimFilename &filename) | |
| virtual bool | open () |
| virtual void | close () |
| virtual ossimString | getExtension () const |
| Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More... | |
Public Member Functions inherited from ossimImageFileWriter | |
| ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0) | |
| The writer will own the sequencer. More... | |
| virtual | ~ossimImageFileWriter () |
| virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const =0 |
| void getImageTypeList(std::vector<ossimString>& imageTypeList)const More... | |
| virtual bool | getOutputHasInternalOverviews (void) const |
| Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More... | |
| virtual bool | hasImageType (const ossimString &imageType) const |
| bool hasImageType(const ossimString& imageType) const More... | |
| virtual void | setTileSize (const ossimIpt &tileSize) |
| Sets the output image tiling size if supported by the writer. More... | |
| virtual bool | writeEnviHeaderFile () |
| Will write an envi header file. More... | |
| virtual bool | writeErsHeaderFile () |
| Will write an ER Mapper header file. More... | |
| virtual bool | writeExternalGeometryFile () |
| Will write an external geometry file. More... | |
| virtual bool | writeFgdcFile () |
| Will write an fgdc file. More... | |
| virtual bool | writeHistogramFile () |
| Returns true on success, false on error. More... | |
| virtual bool | writeJpegWorldFile () |
| Will write a jpeg world file. More... | |
| virtual bool | writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false) |
| Write out an ossim overview file from the source_file. More... | |
| virtual bool | writeReadmeFile () |
| Will write a readme file. More... | |
| virtual bool | writeTiffWorldFile () |
| Will write a world file. More... | |
| virtual bool | writeWorldFile () |
| virtual bool | writeMetaDataFiles () |
| Convenience method that calls meta data write methods that are flagged to be called. More... | |
| virtual void | setAreaOfInterest (const ossimIrect &inputRect) |
| virtual void | changeSequencer (ossimImageSourceSequencer *sequencer) |
| Sets the sequencer and connects it to the input of this. More... | |
| virtual ossimImageSourceSequencer * | getSequencer () |
| Initialize method. More... | |
| virtual bool | execute () |
| Calls: writeFile() writeMetaDataFiles() More... | |
| virtual bool | writeStream () |
| Method to write the image to a stream. More... | |
| virtual bool | setOutputStream (ossimRefPtr< ossimOStream > stream) |
| Sets the output stream to write to. More... | |
| virtual bool | setOutputStream (std::ostream &str) |
| tmp drb More... | |
| virtual ossimRefPtr< ossimOStream > | getOutputStream () const |
| Method to return the stream attached to output. More... | |
| virtual void | setPercentComplete (double percentComplete) |
| virtual void | setOutputImageType (ossim_int32 type) |
| virtual void | setOutputImageType (const ossimString &type) |
| virtual ossim_int32 | getOutputImageType () const |
| virtual ossimString | getOutputImageTypeString () const |
| virtual void | setOutputName (const ossimString &outputName) |
| virtual void | setFilename (const ossimFilename &file) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | getWriteImageFlag () const |
| Control flags... More... | |
| virtual bool | getWriteHistogramFlag () const |
| virtual bool | getWriteOverviewFlag () const |
| virtual bool | getScaleToEightBitFlag () const |
| virtual bool | getWriteEnviHeaderFlag () const |
| virtual bool | getWriteErsHeaderFlag () const |
| virtual bool | getWriteExternalGeometryFlag () const |
| virtual bool | getWriteFgdcFlag () const |
| virtual bool | getWriteJpegWorldFileFlag () const |
| virtual bool | getWriteReadmeFlag () const |
| virtual bool | getWriteTiffWorldFileFlag () const |
| virtual bool | getWriteWorldFileFlag () const |
| virtual void | setWriteImageFlag (bool flag) |
| virtual void | setWriteOverviewFlag (bool flag) |
| virtual void | setWriteHistogramFlag (bool flag) |
| virtual void | setScaleToEightBitFlag (bool flag) |
| virtual void | setWriteEnviHeaderFlag (bool flag) |
| virtual void | setWriteErsHeaderFlag (bool flag) |
| virtual void | setWriteExternalGeometryFlag (bool flag) |
| virtual void | setWriteFgdcFlag (bool flag) |
| virtual void | setWriteJpegWorldFile (bool flag) |
| virtual void | setWriteReadme (bool flag) |
| virtual void | setWriteTiffWorldFile (bool flag) |
| virtual void | setWriteWorldFile (bool flag) |
| virtual ossim_uint16 | getOverviewCompressType () const |
| virtual ossim_int32 | getOverviewJpegCompressQuality () const |
| virtual void | setOverviewCompressType (ossim_uint16 type) |
| virtual void | setOverviewJpegCompressQuality (ossim_int32 quality) |
| Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More... | |
| Overrides base "removeListener". More... | |
| virtual void | setPixelType (ossimPixelType type) |
| If "point" the coordinate tie points are relative to the center of the pixel. More... | |
| virtual void | setPixelType (const ossimString &type) |
| virtual ossimPixelType | getPixelType () const |
| virtual void | getPixelTypeString (ossimString &type) const |
Public Member Functions inherited from ossimImageWriter | |
| ossimImageWriter (ossimObject *owner=NULL) | |
| ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed) | |
| virtual | ~ossimImageWriter () |
| virtual bool | setViewingRect (const ossimIrect &aRect) |
| virtual ossimIrect | getAreaOfInterest () const |
Public Member Functions inherited from ossimOutputSource | |
| ossimOutputSource (ossimObject *owner=NULL) | |
| ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
| virtual | ~ossimOutputSource () |
| virtual bool | open (const ossimString &outputName) |
| virtual const ossimString & | getOutputName () |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Private Member Functions | |
| virtual bool | writeFile () |
| Write out the file. More... | |
| virtual bool | writeBinaryAigHeader () |
| virtual bool | writeBinaryAigBounds () |
| virtual bool | writeBinaryAigStats () |
Private Attributes | |
| ossimIpt | theOutputTileSize |
Definition at line 20 of file ossimArcInfoGridWriter.h.
| ossimArcInfoGridWriter::ossimArcInfoGridWriter | ( | ) |
Definition at line 45 of file ossimArcInfoGridWriter.cpp.
| ossimArcInfoGridWriter::ossimArcInfoGridWriter | ( | ossimImageSource * | inputSource, |
| const ossimFilename & | filename | ||
Definition at line 51 of file ossimArcInfoGridWriter.cpp.
Generic interface to allow one to close a consumer. For displays this might minimize the window and free up internal pointers for file writers it will make sure the file stream is closed and flushed.
Implements ossimOutputSource.
Definition at line 236 of file ossimArcInfoGridWriter.cpp.
Referenced by ~ossimArcInfoGridWriter().
| imageType | string representing image type. |
Reimplemented from ossimImageFileWriter.
Definition at line 371 of file ossimArcInfoGridWriter.cpp.
Definition at line 205 of file ossimArcInfoGridWriter.cpp.
References ossimFilename::exists(), ossimFilename::isDir(), and ossimImageFileWriter::theFilename.
Referenced by writeBinaryAigBounds(), writeBinaryAigHeader(), and writeBinaryAigStats().
Definition at line 198 of file ossimArcInfoGridWriter.cpp.
References ossimImageFileWriter::loadState().
Allows a generic interface to open a consumer for writing. If you are a display writer then you would probably show the window or init the device context for writing.
Definition at line 210 of file ossimArcInfoGridWriter.cpp.
References ossimFilename::exists(), ossimFilename::isDir(), ossimNotify(), ossimNotifyLevel_WARN, ossimFilename::path(), and ossimImageFileWriter::theFilename.
Referenced by writeFile().
saves the state of the object.
Definition at line 192 of file ossimArcInfoGridWriter.cpp.
References ossimImageFileWriter::saveState().
privatevirtual |
Definition at line 307 of file ossimArcInfoGridWriter.cpp.
References ossimString::c_str(), ossimImageSourceSequencer::getBoundingRect(), ossimIrect::hasNans(), ossimIrect::height(), isOpen(), ossimAigBounds::ll_x, ossimAigBounds::ll_y, ossimImageFileWriter::theFilename, ossimImageFileWriter::theInputConnection, ossimAigBounds::ur_x, ossimAigBounds::ur_y, and ossimIrect::width().
privatevirtual |
Definition at line 241 of file ossimArcInfoGridWriter.cpp.
References ossimString::c_str(), ossimImageSourceSequencer::getNumberOfTilesHorizontal(), ossimImageSourceSequencer::getNumberOfTilesVertical(), ossimImageSourceSequencer::getOutputScalarType(), ossimImageSourceSequencer::getTileHeight(), ossimImageSourceSequencer::getTileWidth(), isOpen(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, ossimAigHeader::setFloatCoverage(), ossimImageFileWriter::theFilename, ossimAigHeader::theHeightOfTileInPixels, ossimImageFileWriter::theInputConnection, ossimAigHeader::theNumberOfTilesPerColumn, ossimAigHeader::theNumberOfTilesPerRow, and ossimAigHeader::theWidthOfTileInPixels.
privatevirtual |
Definition at line 344 of file ossimArcInfoGridWriter.cpp.
References ossimString::c_str(), ossimImageSourceSequencer::getMaxPixelValue(), ossimImageSourceSequencer::getMinPixelValue(), isOpen(), ossimImageFileWriter::theFilename, ossimImageFileWriter::theInputConnection, ossimAigStatistics::theMax, ossimAigStatistics::theMean, ossimAigStatistics::theMin, and ossimAigStatistics::writeStream().
privatevirtual |
Write out the file.
Implements ossimImageFileWriter.
Definition at line 65 of file ossimArcInfoGridWriter.cpp.
References ossimString::c_str(), ossimConnectableObject::connectMyInputTo(), ossimRefPtr< T >::get(), ossimImageSourceSequencer::getAreaOfInterest(), ossimImageSourceSequencer::getNextTile(), ossimImageSourceSequencer::getNumberOfTiles(), ossimImageSourceSequencer::getTileHeight(), ossimImageSourceSequencer::getTileWidth(), ossimIrect::hasNans(), ossimCastTileSourceFilter::initialize(), ossimImageSourceSequencer::initialize(), open(), OSSIM_FLOAT, ossimNotify(), ossimNotifyLevel_NOTICE, ossimImageSourceSequencer::setAreaOfInterest(), ossimCastTileSourceFilter::setOutputScalarType(), ossimImageSourceSequencer::setTileSize(), ossimImageSourceSequencer::setToStartOfSequence(), ossimImageWriter::theAreaOfInterest, ossimImageFileWriter::theFilename, ossimAigDataFileHeader::theFileSize, ossimAigIndexFileHeader::theFileSize, ossimImageFileWriter::theInputConnection, theOutputTileSize, ossimAigDataFileHeader::theTileSize, tileNumber, writeBinaryAigBounds(), writeBinaryAigHeader(), writeBinaryAigStats(), ossimAigDataFileHeader::writeStream(), and ossimAigIndexFileHeader::writeStream().
private |
Definition at line 63 of file ossimArcInfoGridWriter.h.
