Class for writing a "ERS" style header. More...
#include <ossimERSFileWriter.h>
| ossimERSFileWriter () | |
| Initializes the state of the writer. More... | |
| virtual void | getMetadatatypeList (std::vector< ossimString > &metadatatypeList) const |
| Satisfies pure virtual from ossimMetadataWriter base. More... | |
| virtual bool | hasMetadataType (const ossimString &metadataType) const |
Public Member Functions inherited from ossimMetadataFileWriter | |
| ossimMetadataFileWriter () | |
| virtual bool | execute () |
| virtual void | setPercentComplete (double percentComplete) |
| virtual void | setFilename (const ossimFilename &file) |
| const ossimFilename & | getFilename () const |
| virtual void | setPixelType (ossimPixelType pixelType) |
| Ossim uses a concept of "pixel is point" internally. More... | |
| virtual ossimPixelType | getPixelType () const |
| virtual void | setAreaOfInterest (const ossimIrect &areaOfInterest) |
| Sets the area of interest to write the meta data for. More... | |
| virtual ossimIrect | getAreaOfInterest () const |
| ossimObject () | |
| ossimListenerManager () | |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimERSFileWriter () |
| virtual bool | writeFile () |
| Write out the file. More... | |
Protected Member Functions inherited from ossimMetadataFileWriter | |
| virtual | ~ossimMetadataFileWriter () |
Public Types inherited from ossimProcessInterface | |
| enum | ossimProcessStatus { PROCESS_STATUS_UNKNOWN = 0, PROCESS_STATUS_EXECUTING = 1, PROCESS_STATUS_ABORTED = 2, PROCESS_STATUS_ABORT_REQUEST = 3, PROCESS_STATUS_NOT_EXECUTING = 4 } |
Definition at line 26 of file ossimERSFileWriter.h.
| ossimERSFileWriter::ossimERSFileWriter | ( | ) |
default constructor
protectedvirtual |
Appends the writers image types to the "metadatatypeList".
| metadatatypeList | stl::vector<ossimString> list to append to. |
Implements ossimMetadataFileWriter.
Definition at line 214 of file ossimERSFileWriter.cpp.
| imageType | string representing image type. |
Definition at line 220 of file ossimERSFileWriter.cpp.
Users should use this to set the ERS header fields that are not taken from theInputConnection prior to calling execute.
Reimplemented from ossimMetadataFileWriter.
Definition at line 41 of file ossimERSFileWriter.cpp.
References ossimMetadataFileWriter::loadState().
protectedvirtual |
Write out the file.
Definition at line 48 of file ossimERSFileWriter.cpp.
References ossimString::after(), ossimString::before(), ossim::byteOrder(), ossimKeywordNames::DATUM_KW, ossimKeywordlist::find(), ossimMapProjectionInfo::getGeom(), ossimImageSource::getImageGeometry(), ossimImageSource::getNumberOfOutputBands(), ossimImageSource::getOutputScalarType(), ossimImageGeometry::getProjection(), ossimIrect::height(), ossimKeywordNames::HEMISPHERE_KW, OSSIM_BIG_ENDIAN, OSSIM_DEGREES, OSSIM_METERS, OSSIM_PIXEL_IS_POINT, ossimNotify(), ossimNotifyLevel_WARN, ossimKeywordNames::PIXEL_SCALE_XY_KW, PTR_CAST, ossimMetadataFileWriter::theAreaOfInterest, ossimERS::theBands, ossimERS::theByteorder, ossimERS::theCellSizeX, ossimERS::theCellSizeY, ossimERS::theCelltype, ossimERS::theCoordSysType, ossimERS::theDatasetType, ossimERS::theDatatype, ossimERS::theDatum, ossimMetadataFileWriter::theFilename, theHdr, ossimMetadataFileWriter::theInputConnection, ossimERS::theLine, ossimERS::theOriginX, ossimERS::theOriginY, ossimMetadataFileWriter::thePixelType, ossimERS::theProjection, ossimERS::theSample, ossimERS::theTieUnitType, ossimKeywordNames::TIE_POINT_XY_KW, ossimString::toDouble(), ossimString::trim(), ossimKeywordNames::TYPE_KW, ossimRefPtr< T >::valid(), ossimIrect::width(), ossimERS::writeFile(), and ossimKeywordNames::ZONE_KW.
protected |
Definition at line 70 of file ossimERSFileWriter.h.
Referenced by writeFile().
