ossimImageFileWriter.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // Author: Frank Warmerdam ([email protected])
6 //
7 // Description:
8 //
9 // Contains class declaration for ossimImageFileWriter.
10 //*******************************************************************
11 // $Id: ossimImageFileWriter.cpp 23068 2015-01-07 23:08:29Z okramer $
12
13
14 #include <tiff.h> /* for tiff compression defines */
15
16 #include <ossim/ossimConfig.h>
45 #include <ossim/base/ossimTrace.h>
49
50 static ossimTrace traceDebug("ossimImageFileWriter:debug");
51 static const ossimString AUTO_CREATE_DIRECTORY_KW("auto_create_directory");
52
53 #if OSSIM_ID_ENABLED
54 static const char OSSIM_ID[] = "$Id: ossimImageFileWriter.cpp 23068 2015-01-07 23:08:29Z okramer $";
55 #endif
56
58  "ossimImageFileWriter",
62
63 static const char SCALE_TO_EIGHT_BIT_KW[] = "scale_to_eight_bit";
64
66  ossimImageSource* inputSource,
67  ossimObject* owner)
68  : ossimImageWriter(owner,
69  1,
70  0,
71  true,
72  false),
75  theViewController(NULL),
76  theProgressListener(NULL),
77  theFilename(file),
78  theOutputImageType(ossimImageTypeLut().getEntryString(OSSIM_IMAGE_TYPE_UNKNOWN)),
79  theWriteImageFlag(true),
80  theWriteOverviewFlag(false),
81  theWriteHistogramFlag(false),
82  theScaleToEightBitFlag(false),
83  theOverviewCompressType(COMPRESSION_NONE),
84  theOverviewJpegCompressQuality(75),
85  theWriteEnviHeaderFlag(false),
86  theWriteErsHeaderFlag(false),
87  theWriteExternalGeometryFlag(false),
88  theWriteFgdcFlag(false),
89  theWriteJpegWorldFileFlag(false),
90  theWriteReadmeFlag(false),
91  theWriteTiffWorldFileFlag(false),
92  theWriteWorldFileFlag(false),
93  theAutoCreateDirectoryFlag(true),
94  theLinearUnits(OSSIM_UNIT_UNKNOWN),
95  thePixelType(OSSIM_PIXEL_IS_POINT)
96 {
97  if (traceDebug())
98  {
100  << "ossimImageFileWriter::ossimImageFileWriter entered..."
101  << std::endl;
102 #ifdef OSSIM_ID_ENABLED
104  << "OSSIM_ID: " << OSSIM_ID << std::endl;
105 #endif
106  }
107
109
110  // now map the sequencer to the same input
111  connectMyInputTo(0, inputSource);
112  initialize();
113
114  // make sure we listen to our input changes so we can change
115  // it for the sequencer as well.
117
118  theInputConnection->connectMyInputTo(0, inputSource, false);
120 }
121
123 {
124  theInputConnection = 0;
125  theProgressListener = NULL;
127 }
128
130 {
132  {
134
135  //---
136  // Area Of Interest(AOI):
137  // There are two AOIs to keep in sync.
138  // One owned by this base: ossimImageWriter::theAreaOfInterest
139  // One owned by the theInputConntion: ossimImageSourceSequencer::theAreaOfInterest
140  //---
141  if ( theAreaOfInterest.hasNans() == false )
142  {
143  //---
144  // ossimImageSourceSequencer::setAreaOfInterest does more than just set the
145  // variable, so only call if out of sync to avoid wasted cycles.
146  //---
148  {
150  }
151  }
152  else
153  {
154  // Set this AOI to bounding rect of input.
156  }
157  }
158 }
159
161 {
162  if( sequencer )
163  {
164  theInputConnection = sequencer;
166  }
167 }
168
170  const char* prefix)const
171 {
172  kwl.add(prefix,
174  getClassName(),
175  true);
176
177  kwl.add(prefix,
179  theFilename.c_str(),
180  true);
181
182  kwl.add(prefix,
183  "create_envi_hdr",
185  true);
186
187  kwl.add(prefix,
188  "create_ers_hdr",
190  true);
191
192  kwl.add(prefix,
195  true);
196
197  kwl.add(prefix,
198  "create_fgdc",
200  true);
201
202  kwl.add(prefix,
203  "create_jpeg_world_file",
205  true);
206
207  kwl.add(prefix,
208  "create_readme",
210  true);
211
212  kwl.add(prefix,
213  "create_tiff_world_file",
215  true);
216
217  kwl.add(prefix,
218  "create_world_file",
220  true);
221
222  kwl.add(prefix,
225  true);
226
227  kwl.add(prefix,
230  true);
231
232  kwl.add(prefix,
235  true);
236
237  kwl.add(prefix,
238  SCALE_TO_EIGHT_BIT_KW,
240  true);
241  kwl.add(prefix,
242  AUTO_CREATE_DIRECTORY_KW,
244  true);
245  kwl.add(prefix,
248  true);
249
250  kwl.add(prefix,
253  true);
254
255  ossimImageTypeLut lut;
256  kwl.add(prefix,
259  true);
260
261  //---
262  // When "theLinearUnits" == "unknown" that is a key to the writer to just
263  // use whatever units makes sense for the projection. Since "unknown"
264  // doesn't look good to the average user in a spec file, change to
265  // "default" if "unknown". When read back in by the lookup table since
266  // "default" is not a valid "string" theLinearUnits will remain "unknown".
267  // Kind of a hack but it works:) (drb)
268  //---
270  getEntryString(theLinearUnits);
271  if (os == "unknown")
272  {
273  os = "default"; // Avoid saving as unknown for user readability.
274  }
275  kwl.add(prefix, "linear_units", os, true);
276
277  // Set the pixel type.
278  ossimString pixelType;
279  getPixelTypeString(pixelType);
280  kwl.add(prefix,
282  pixelType.c_str(),
283  true);
284
285  return ossimSource::saveState(kwl, prefix);
286 }
287
289  const char* prefix)
290 {
291  // Load the state of the base class.
292  bool result = ossimSource::loadState(kwl, prefix);
293
294  // Get the filename...
295  const char* lookup = kwl.find(prefix, ossimKeywordNames::FILENAME_KW);
296  if(lookup)
297  {
298  ossimString filename = lookup;
299
300  lookup = kwl.find(prefix, ossimKeywordNames::FILEPATH_KW);
301  if(lookup)
302  {
303  filename = ossimString(lookup) + filename;
304  }
305
306  setFilename(filename);
307  }
308
309  lookup = kwl.find(prefix, ossimKeywordNames::PIXEL_TYPE_KW);
310  if(lookup)
311  {
312  if(ossimString(lookup).downcase().contains("area"))
313  {
315  }
316  else
317  {
319  }
320  }
321
322  lookup = kwl.find(prefix, "linear_units");
323  if(lookup)
324  {
326  getEntryNumber(lookup, true);
327  if ( (units == OSSIM_METERS) ||
328  (units == OSSIM_FEET) ||
329  (units == OSSIM_US_SURVEY_FEET) )
330  {
331  theLinearUnits = units;
332  }
333  }
334
336  if(lookup)
337  {
338  ossimString s = lookup;
340  }
341
342  lookup = kwl.find(prefix, "create_envi_hdr");
343  if(lookup)
344  {
345  ossimString s = lookup;
347  }
348
349  lookup = kwl.find(prefix, "create_ers_hdr");
350  if(lookup)
351  {
352  ossimString s = lookup;
354  }
355
356  lookup = kwl.find(prefix, "create_fgdc");
357  if(lookup)
358  {
359  ossimString s = lookup;
360  theWriteFgdcFlag = s.toBool();
361  }
362
363  lookup = kwl.find(prefix, "create_jpeg_world_file");
364  if(lookup)
365  {
366  ossimString s = lookup;
368  }
369
370  lookup = kwl.find(prefix, "create_readme");
371  if(lookup)
372  {
373  ossimString s = lookup;
375  }
376
377  lookup = kwl.find(prefix, "create_tiff_world_file");
378  if(lookup)
379  {
380  ossimString s = lookup;
382  }
383
384  lookup = kwl.find(prefix, "create_world_file");
385  if(lookup)
386  {
387  ossimString s = lookup;
389  }
390
391  lookup = kwl.find(prefix, ossimKeywordNames::CREATE_IMAGE_KW);
392  if(lookup)
393  {
394  ossimString s = lookup;
396  }
397
398  lookup = kwl.find(prefix, ossimKeywordNames::CREATE_OVERVIEW_KW);
399  if(lookup)
400  {
401  ossimString s = lookup;
403  }
404
405  lookup = kwl.find(prefix, ossimKeywordNames::CREATE_HISTOGRAM_KW);
406  if(lookup)
407  {
408  ossimString s = lookup;
410  }
411
412  lookup = kwl.find(prefix, SCALE_TO_EIGHT_BIT_KW);
413  if(lookup)
414  {
415  ossimString s = lookup;
417  }
418
419  lookup = kwl.find(prefix, AUTO_CREATE_DIRECTORY_KW);
420  if(lookup)
421  {
423  }
425  if(lookup)
426  {
427  ossimString s = lookup;
428  theOverviewCompressType = static_cast<ossim_uint16>(s.toUInt32());
429  }
430
432  if(lookup)
433  {
434  ossimString s = lookup;
436  }
437
438  const char* outputImageType = kwl.find(prefix, ossimKeywordNames::IMAGE_TYPE_KW);
439  if(outputImageType)
440  {
441  theOutputImageType = outputImageType;
442  }
443
444  if(theInputObjectList.size() != 2)
445  {
446  theInputObjectList.resize(2);
448  }
449
450  theOutputListIsFixedFlag = false;
451
452  return result;
453 }
454
456  ossim_int32 jpeg_compress_quality,
457  bool includeR0)
458 {
459  if(theFilename == "") return false;
460
461  // Get an image handler for the source file.
464
465  if (ih.valid() == false)
466  {
467  // Set the error...
468  return false;
469  }
470
472
473  if ( ob->setInputSource(ih.get()) )
474  {
475  // Give the listener to the overview builder if set.
477  {
479  }
480
481  // Build a new file name for the overview.
482  ossimFilename overview_file = theFilename;
483  overview_file.setExtension(ossimString("ovr"));
484  ob->setCompressionType(tiff_compress_type);
485  ob->setJpegCompressionQuality(jpeg_compress_quality);
486  ob->setOutputFile(overview_file);
487  ob->setCopyAllFlag(includeR0);
488  ob->execute();
489
490  // Remove the listener from the overview builder.
492  {
494  }
495  }
496
497  return true;
498 }
499
501 {
502  if( (theFilename == "") || !theInputConnection ||
504  {
505  return false;
506  }
507
508  // Make the file name.
509  ossimFilename outputFile = theFilename;
510  outputFile.setExtension(ossimString("hdr"));
511
512  // Make the writer.
515
516  // Set things up.
518  writer->initialize();
519  writer->setFilename(outputFile);
520  writer->setPixelType(thePixelType);
522
523  // Write it to disk.
524  return writer->execute();
525 }
526
528 {
529  if( (theFilename == "") || !theInputConnection ||
531  {
532  return false;
533  }
534
535  // Make the file name.
536  ossimFilename outputFile = theFilename;
537  outputFile.setExtension(ossimString("ers"));
538
539  // Make the writer.
541  new ossimERSFileWriter();
542
543  // Set things up.
545  writer->initialize();
546  writer->setFilename(outputFile);
547  writer->setPixelType(thePixelType);
549
550  // Write it to disk.
551  return writer->execute();
552 }
553
555 {
556  if( (theFilename == "") || !theInputConnection ||
558  {
559  return false;
560  }
561
562  // Make the file name.
563  ossimFilename geomFile = theFilename;
564  geomFile.setExtension(ossimString("geom"));
565
566  // Make the writer.
568
569  // Set things up.
570 // writer->connectMyInputTo(0, theInputConnection.get());
572  writer->setFilename(geomFile);
573  writer->initialize();
574  writer->setPixelType(thePixelType);
576
577  // Write it to disk.
578  return writer->execute();
579 }
580
582 {
583  if( (theFilename == "") || !theInputConnection ||
585  {
586  return false;
587  }
588
589  // Make the file name.
590  ossimFilename outputFile = theFilename;
591  outputFile.setExtension(ossimString("xml"));
592
593  // Make the writer.
595
596  // Set things up.
598  writer->initialize();
599  writer->setFilename(outputFile);
600  writer->setPixelType(thePixelType);
602
603  // Write it to disk.
604  return writer->execute();
605 }
606
608 {
609  if(theFilename == "")
610  {
611  return false;
612  }
613
614  // Make the file name.
615  ossimFilename file = theFilename;
616  file.setExtension(ossimString("jpw")); // jpw???
617
618  return writeWorldFile(file);
619 }
620
622 {
623  if( (theFilename == "") || !theInputConnection ||
625  {
626  return false;
627  }
628
629  // Make the file name.
630  ossimFilename outputFile = theFilename.noExtension();
631
632  outputFile += "_readme.txt";
633
634  // Make the writer.
636  new ossimReadmeFileWriter();
637
638  // Set things up.
640  writer->initialize();
641  writer->setFilename(outputFile);
642  writer->setPixelType(thePixelType);
644
645  // Write it to disk.
646  return writer->execute();
647 }
648
650 {
651  if(theFilename == "")
652  {
653  return false;
654  }
655
656  // Make the file name.
657  ossimFilename file = theFilename;
658  file.setExtension(ossimString("tfw"));
659
660  return writeWorldFile(file);
661 }
662
664 {
665  bool status = true;
666
668  {
669  if(writeEnviHeaderFile() == false)
670  {
671  status = false;
672
674  << "Write of envi header file failed!" << endl;
675  }
676  }
677
679  {
680  if(writeErsHeaderFile() == false)
681  {
682  status = false;
683
685  << "Write of ers header file failed!" << endl;
686  }
687  }
688
690  {
691  if( writeExternalGeometryFile() == false)
692  {
693  status = false;
694  if(traceDebug())
695  {
697  << "Write of geometry file failed!" << endl;
698  }
699  }
700  }
702  {
703  if(writeFgdcFile() == false)
704  {
705  status = false;
706  if(traceDebug())
707  {
709  << "Write of fgdc file failed!" << endl;
710  }
711  }
712  }
714  {
715  if(writeJpegWorldFile() == false)
716  {
717  status = false;
718  if(traceDebug())
719  {
721  << "Write of jpeg world file failed!" << endl;
722  }
723  }
724  }
726  {
727  if(writeReadmeFile() == false)
728  {
729  status = false;
730
731  if(traceDebug())
732  {
734  << "Write of readme file failed!" << endl;
735  }
736  }
737  }
739  {
740  if(writeTiffWorldFile() == false)
741  {
742  status = false;
743  if(traceDebug())
744  {
746  << "Write of tiff world file failed!" << endl;
747  }
748  }
749  }
750
752  {
753  if(writeWorldFile() == false)
754  {
755  status = false;
756  if(traceDebug())
757  {
759  << "Write of world file failed!" << endl;
760  }
761  }
762  }
763
765  {
766  if (!writeHistogramFile())
767  {
768  status = false;
769  if(traceDebug())
770  {
772  << "Write of histogram file failed!" << endl;
773  }
774  }
775  }
776
777  return status;
778 }
779
781 {
782  if(needsAborting()) return false;
783  if(theFilename == "") return false;
784
785  ossimFilename histogram_file = theFilename;
786  histogram_file.setExtension(ossimString("his"));
787
789  open(theFilename);
790
791  if (!handler)
792  {
793  return false;
794  }
795
797
799  histoSource->setMaxNumberOfRLevels(1); // Only compute for r0.
800  histoSource->connectMyInputTo(0, handler.get());
801  histoSource->enableSource();
802  writer->connectMyInputTo(0, histoSource.get());
803  writer->setFilename(histogram_file);
804  writer->addListener(&theStdOutProgress);
805  writer->execute();
806  writer->disconnect();
807  histoSource->disconnect();
808  handler->disconnect();
809  writer = 0; histoSource = 0; handler = 0;
810  return true;
811 }
812
814 {
815  if(!getInput(0))
816  {
818  }
820
821  initialize();
822 }
823
825 {
827  getInput(0),
828  false);
830  initialize();
831 }
832
834 {
835  initialize();
836 }
837
839 {
840  theOutputImageType = type;
841 }
842
844 {
845  ossimImageTypeLut lut;
847 }
848
850 {
851  return theOutputImageType;
852
853 }
854
856 {
857  ossimImageTypeLut lut;
859 }
860
861
863 {
864  return theWriteImageFlag;
865 }
866
868 {
869  return theWriteHistogramFlag;
870 }
871
873 {
874  return theWriteOverviewFlag;
875 }
876
878 {
879  return theScaleToEightBitFlag;
880 }
881
883 {
884  return theWriteEnviHeaderFlag;
885 }
886
888 {
889  return theWriteErsHeaderFlag;
890 }
891
893 {
895 }
896
898 {
899  return theWriteFgdcFlag;
900 }
901
903 {
905 }
906
908 {
909  return theWriteReadmeFlag;
910 }
911
913 {
915 }
916
918 {
919  return theWriteWorldFileFlag;
920 }
921
923 {
924  theWriteOverviewFlag = flag;
925 }
926
928 {
929  theWriteImageFlag = flag;
930 }
931
933 {
934  theWriteHistogramFlag = flag;
935 }
936
938 {
939  theScaleToEightBitFlag = flag;
940 }
941
943 {
944  theWriteEnviHeaderFlag = flag;
945 }
946
948 {
949  theWriteErsHeaderFlag = flag;
950 }
951
953 {
955 }
956
958 {
959  theWriteFgdcFlag = flag;
960 }
961
963 {
965 }
966
968 {
969  theWriteReadmeFlag = flag;
970 }
971
973 {
975 }
976
978 {
979  theWriteWorldFileFlag = flag;
980 }
981
983 {
984  return this;
985 }
986
988 {
989  return this;
990 }
991
993 {
994  // This sets "theAreaOfInterest".
996
997  if( theInputConnection.valid() )
998  {
999  //---
1000  // ossimImageSourceSequencer::setAreaOfInterest does more than just set the
1001  // variable, so only call if out of sync to avoid wasted cycles.
1002  //---
1004  {
1005  // Set the sequencer area of interest.
1007  }
1008  }
1009 }
1010
1012 {
1013  return theInputConnection.get();
1014 }
1015
1017 {
1018  static const char MODULE[] = "ossimImageFileWriter::execute";
1019
1020  if (!theInputConnection) // Must have a sequencer...
1021  {
1022  if (traceDebug())
1023  {
1025  << MODULE << " DEBUG:\ntheInputConnection is NULL!" << endl;
1026  }
1027  return false;
1028  }
1029
1030  if (theFilename == "") // Must have a filename...
1031  {
1032  if (traceDebug())
1033  {
1035  << MODULE << " DEBUG:\ntheFilename is empty!" << endl;
1036  }
1037  return false;
1038  }
1039
1040
1041  // make sure we have a region of interest
1043  {
1046  }
1047  else
1048  {
1050  }
1051
1052  if(theAreaOfInterest.hasNans()) // Must have an area of interest...
1053  {
1054  if (traceDebug())
1055  {
1057  << MODULE << " ERROR: Area of interest has nans!"
1058  << "Area of interest: "
1060  << "\nReturning..." << endl;
1061  }
1062
1063  return false;
1064  }
1065
1066  if (traceDebug())
1067  {
1069  << MODULE << " DEBUG:\n"
1070  << "Area of interest: " << theAreaOfInterest << endl;
1071  }
1072
1073  ossimRefPtr<ossimImageSource> savedInput;
1075  {
1077  {
1078  savedInput = new ossimScalarRemapper;
1079
1080  savedInput->connectMyInputTo(0, theInputConnection->getInput(0));
1081  theInputConnection->connectMyInputTo(0, savedInput.get());
1083  }
1084  }
1085
1086  ossimFilename path = theFilename.path();
1087  if (!path.empty() && !path.exists() )
1088  {
1089  path.createDirectory(true);
1090  }
1092  //setPercentComplete(0.0); let writeFile set the precent complete
1093  bool wroteFile = true;
1094  bool result = true;
1095  if (theWriteImageFlag)
1096  {
1097  wroteFile = writeFile();
1098  }
1099
1100  /*
1101  if(needsAborting())
1102  {
1103  setProcessStatus(ossimProcessInterface::PROCESS_STATUS_ABORTED);
1104  }
1105  else
1106  {
1107  setProcessStatus(ossimProcessInterface::PROCESS_STATUS_NOT_EXECUTING);
1108  }
1109  */
1111  {
1112  // Writing overviews has been mpi'd so do on all processes.
1115  {
1116  if(traceDebug())
1117  {
1119  << "Write of overview file failed!" << endl;
1120  }
1121  }
1122  }
1123
1124  if(!needsAborting())
1125  {
1126  // Do these only on the master process. Note left to right precedence!
1127  if (getSequencer() && getSequencer()->isMaster())
1128  {
1129  if (wroteFile)
1130  {
1131  if (writeMetaDataFiles() == false)
1132  {
1133  if(traceDebug())
1134  {
1136  << "Write of metadata file failed!" << endl;
1137  }
1138  result = false;
1139  }
1140  }
1141
1142  } // End of "if (getSequencer() && getSequencer()->isMaster()))
1143  }
1144
1145  if(savedInput.valid())
1146  {
1148  if(obj)
1149  {
1151  }
1152  }
1153  if(!needsAborting())
1154  {
1156  }
1157  else
1158  {
1160  }
1161
1162  savedInput = 0;
1163  return result;
1164 }
1165
1167 {
1168  //---
1169  // Not implemented in this class. Derived classed should implement if
1170  // they can write to a stream.
1171  //---
1172  return false;
1173 }
1174
1176 {
1177  //---
1178  // Not implemented in this class. Derived classed should implement if
1179  // they can write to a stream.
1180  //---
1181  return ossimRefPtr<ossimOStream>();
1182 }
1183
1185  ossimRefPtr<ossimOStream> /* stream */ )
1186 {
1187  //---
1188  // Not implemented in this class. Derived classed should implement if
1189  // they can write to a stream.
1190  //---
1191  return false;
1192 }
1193
1195 {
1196  //---
1197  // Not implemented in this class. Derived classed should implement if
1198  // they can write to a stream.
1199  //---
1200  return false;
1201 }
1202
1203
1204 void ossimImageFileWriter::setPercentComplete(double percentComplete)
1205 {
1207  ossimProcessProgressEvent event(this, percentComplete);
1208  fireEvent(event);
1209 }
1210
1212 {
1213  ossimImageWriter::setOutputName(outputName);
1214  setFilename(ossimFilename(outputName));
1215 }
1216
1218 {
1219  theFilename = file;
1220 }
1221
1223 {
1224  return theFilename;
1225 }
1226
1228  const ossimConnectableObject* object)const
1229 {
1230  return (object&&
1231  ( (PTR_CAST(ossimImageSource, object)&&inputIndex == 0)||
1232  (PTR_CAST(ossimViewController, object)&&inputIndex == 1)) );
1233 }
1234
1236 {
1237  return theOverviewCompressType;
1238 }
1239
1241 {
1243 }
1244
1246 {
1247  theOverviewCompressType = type;
1248 }
1249
1251 {
1253 }
1254
1256 {
1257  if(!property) return;
1258
1259  if(property->getName() == ossimKeywordNames::FILENAME_KW)
1260  {
1261  theFilename = property->valueToString();
1262  }
1263  else if (property->getName() == "create_envi_hdr")
1264  {
1265  theWriteEnviHeaderFlag = property->valueToString().toBool();
1266  }
1267  else if (property->getName() == "create_ers_hdr")
1268  {
1269  theWriteErsHeaderFlag = property->valueToString().toBool();
1270  }
1271  else if (property->getName() ==
1273  {
1274  theWriteExternalGeometryFlag = property->valueToString().toBool();
1275  }
1276  else if (property->getName() == "create_fgdc")
1277  {
1278  theWriteFgdcFlag = property->valueToString().toBool();
1279  }
1280  else if (property->getName() == "create_jpeg_world_file")
1281  {
1282  theWriteJpegWorldFileFlag = property->valueToString().toBool();
1283  }
1284  else if (property->getName() == "create_readme")
1285  {
1286  theWriteReadmeFlag = property->valueToString().toBool();
1287  }
1288  else if (property->getName() == "create_tiff_world_file")
1289  {
1290  theWriteTiffWorldFileFlag = property->valueToString().toBool();
1291  }
1292  else if (property->getName() == "create_world_file")
1293  {
1294  theWriteWorldFileFlag = property->valueToString().toBool();
1295  }
1296  else if (property->getName() == ossimKeywordNames::CREATE_IMAGE_KW)
1297  {
1298  theWriteImageFlag = property->valueToString().toBool();
1299  }
1300  else if (property->getName() == ossimKeywordNames::CREATE_OVERVIEW_KW)
1301  {
1302  theWriteOverviewFlag = property->valueToString().toBool();
1303  }
1304  else if (property->getName() == ossimKeywordNames::CREATE_HISTOGRAM_KW)
1305  {
1306  theWriteHistogramFlag = property->valueToString().toBool();
1307  }
1308  else if (property->getName() == SCALE_TO_EIGHT_BIT_KW)
1309  {
1310  theScaleToEightBitFlag = property->valueToString().toBool();
1311  }
1312  else if(property->getName() == AUTO_CREATE_DIRECTORY_KW)
1313  {
1314  theAutoCreateDirectoryFlag = property->valueToString().toBool();
1315  }
1316  else if (property->getName() == "linear_units")
1317  {
1320  getEntryNumber(property->valueToString()));
1321  }
1322  else if(property->getName() == ossimKeywordNames::IMAGE_TYPE_KW)
1323  {
1324  setOutputImageType(property->valueToString());
1325  }
1326  else if(property->getName() == ossimKeywordNames::PIXEL_TYPE_KW)
1327  {
1329  property.get());
1330  if (stringProperty)
1331  {
1332  ossimString s;
1333  stringProperty->valueToString(s);
1334  setPixelType(s);
1335  }
1336  }
1337  else
1338  {
1340  }
1341 }
1342
1344 {
1345  if(name == ossimKeywordNames::FILENAME_KW)
1346  {
1347  ossimFilenameProperty* filenameProp =
1349
1351
1352  return filenameProp;
1353  }
1354  else if(name == ossimKeywordNames::IMAGE_TYPE_KW)
1355  {
1357  std::vector<ossimString> typeList;
1358  getImageTypeList(typeList);
1359  if(typeList.size() > 1)
1360  {
1361  prop->setReadOnlyFlag(false);
1362  prop->setConstraints(typeList);
1364  }
1365  else
1366  {
1367  prop->setReadOnlyFlag(true);
1368  }
1369  return prop;
1370  }
1371  else if(name == AUTO_CREATE_DIRECTORY_KW)
1372  {
1374  }
1375  else if (name == "create_envi_hdr")
1376  {
1377  return new ossimBooleanProperty(name, theWriteEnviHeaderFlag);
1378  }
1379  else if (name == "create_ers_hdr")
1380  {
1381  return new ossimBooleanProperty(name, theWriteErsHeaderFlag);
1382  }
1384  {
1386  }
1387  else if (name == "create_fgdc")
1388  {
1389  return new ossimBooleanProperty(name, theWriteFgdcFlag);
1390  }
1391  else if (name == "create_jpeg_world_file")
1392  {
1394  }
1395  else if (name == "create_readme")
1396  {
1397  return new ossimBooleanProperty(name, theWriteReadmeFlag);
1398  }
1399  else if (name == "create_tiff_world_file")
1400  {
1402  }
1403  else if (name == "create_world_file")
1404  {
1405  return new ossimBooleanProperty(name, theWriteWorldFileFlag);
1406  }
1407  else if (name == ossimKeywordNames::CREATE_IMAGE_KW)
1408  {
1409  return new ossimBooleanProperty(name, theWriteImageFlag);
1410  }
1411  else if (name == ossimKeywordNames::CREATE_OVERVIEW_KW)
1412  {
1413  return new ossimBooleanProperty(name, theWriteOverviewFlag);
1414  }
1415  else if (name == ossimKeywordNames::CREATE_HISTOGRAM_KW)
1416  {
1417  return new ossimBooleanProperty(name, theWriteHistogramFlag);
1418  }
1419  else if (name == SCALE_TO_EIGHT_BIT_KW)
1420  {
1421  return new ossimBooleanProperty(name, theScaleToEightBitFlag);
1422  }
1423  else if (name == "linear_units")
1424  {
1425  // property value
1427  getEntryString(theLinearUnits);
1428
1429  //---
1430  // theLinearUnits is set to unknown as a default. This keys the
1431  // writer to use whatever makes sense for the given output.
1432  // Since "unknown" is a bad name to present to users, we will
1433  // use "default" if theLinearUnits is == "unknown".
1434  //---
1435  if (value == "unknown")
1436  {
1437  value = "default";
1438  }
1439
1440  // constraint list
1441  vector<ossimString> constraintList;
1442  constraintList.push_back(ossimString("default"));
1443  constraintList.push_back(ossimString("meters"));
1444  constraintList.push_back(ossimString("feet"));
1445  constraintList.push_back(ossimString("us_survey_feet"));
1446
1447  return new ossimStringProperty(name,
1448  value,
1449  false, // not editable
1450  constraintList);
1451  }
1452  else if (name == ossimKeywordNames::PIXEL_TYPE_KW)
1453  {
1454  ossimString value;
1455  getPixelTypeString(value);
1456  ossimStringProperty* stringProp =
1457  new ossimStringProperty(name,
1458  value,
1459  false); // editable flag
1460  stringProp->addConstraint(ossimString("point"));
1461  stringProp->addConstraint(ossimString("area"));
1462  return stringProp;
1463  }
1464
1465  return ossimImageWriter::getProperty(name);
1466 }
1467
1468 void ossimImageFileWriter::getPropertyNames(std::vector<ossimString>& propertyNames)const
1469 {
1470  ossimImageWriter::getPropertyNames(propertyNames);
1471
1472  propertyNames.push_back(ossimString(ossimKeywordNames::FILENAME_KW));
1473  propertyNames.push_back(ossimString("create_envi_hdr"));
1475  propertyNames.push_back(ossimString("create_fgdc"));
1476  propertyNames.push_back(ossimString("create_jpeg_world_file"));
1477  propertyNames.push_back(ossimString("create_readme"));
1478  propertyNames.push_back(ossimString("create_tiff_world_file"));
1479  propertyNames.push_back(ossimString("create_world_file"));
1480  propertyNames.push_back(ossimString(ossimKeywordNames::CREATE_IMAGE_KW));
1481  propertyNames.push_back(ossimString(ossimKeywordNames::CREATE_OVERVIEW_KW));
1482  propertyNames.push_back(ossimString(ossimKeywordNames::CREATE_HISTOGRAM_KW));
1483  propertyNames.push_back(ossimString(AUTO_CREATE_DIRECTORY_KW));
1484  propertyNames.push_back(ossimString(SCALE_TO_EIGHT_BIT_KW));
1485  propertyNames.push_back(ossimString("linear_units"));
1486  propertyNames.push_back(ossimString(ossimKeywordNames::PIXEL_TYPE_KW));
1487  propertyNames.push_back(ossimString(ossimKeywordNames::IMAGE_TYPE_KW));
1488
1489 }
1490
1492 {
1493  // default unknown file extension
1494  return ossimString("ext");
1495 }
1496
1498 {
1499  // default value: don't assume internal overviews will
1500  // be generated by image writers.
1501  return false;
1502 }
1503
1505 {
1506  std::vector<ossimString> imageTypeList;
1507  getImageTypeList(imageTypeList);
1508
1509  std::vector<ossimString>::const_iterator i = imageTypeList.begin();
1510
1511  while (i != imageTypeList.end())
1512  {
1513  if ( (*i) == imageType )
1514  {
1515  return true;
1516  }
1517  ++i;
1518  }
1519
1520  return false; // not found...
1521 }
1522
1524 {
1525  theProgressListener = listener;
1526  return ossimImageWriter::addListener(listener);
1527 }
1528
1530 {
1531  if (listener == theProgressListener)
1532  {
1533  theProgressListener = NULL;
1534  }
1535  return ossimImageWriter::removeListener(listener);
1536 }
1537
1539 {
1540  thePixelType = type;
1541 }
1542
1544 {
1545  ossimString s = type;
1546  s.downcase();
1547  if (s == "point")
1548  {
1550  }
1551  else if (s == "area")
1552  {
1554  }
1555 }
1556
1558 {
1559  return thePixelType;
1560 }
1561
1563 {
1565  {
1566  type = "point";
1567  }
1568  else
1569  {
1570  type = "area";
1571  }
1572 }
1573
1575 {
1576  if (theInputConnection.valid())
1577  {
1578  theInputConnection->setTileSize(tileSize);
1579  }
1580 }
1581
1583 {
1584  bool result = false;
1585
1586  if( theFilename.size() )
1587  {
1588  // Make the file name.
1589  ossimFilename file = theFilename;
1590  ossimString ext = file.ext().downcase();
1591
1592  ossimString wfExt = ""; // World file extension.
1593
1594  if ( ( ext == "tif" ) || ( ext == "tiff" ) )
1595  {
1596  wfExt = "tfw";
1597  }
1598  else if ( ( ext == "jpg" ) || ( ext == "jpeg" ) )
1599  {
1600  wfExt = "jpw";
1601  }
1602  else if ( ext == "png" )
1603  {
1604  wfExt = "pgw";
1605  }
1606  else if ( ext == "sid" )
1607  {
1608  wfExt = "sdw";
1609  }
1610
1611  if ( ext.size() )
1612  {
1613  file.setExtension(wfExt);
1614
1615  result = writeWorldFile(file);
1616  }
1617  else
1618  {
1620  << "Could not derive world file extension for: " << theFilename << "\n";
1621  }
1622  }
1623
1624  if ( !result )
1625  {
1627  << "Write of world file failed!\n";
1628  }
1629
1630  return result;
1631 }
1632
1634 {
1636  {
1637  return false;
1638  }
1639
1640  // Make the writer.
1642
1643  // Set things up.
1644  writer->connectMyInputTo(0, theInputConnection.get());
1645  writer->initialize();
1646  writer->setFilename(file);
1648  writer->setLinearUnits(theLinearUnits);
1649  writer->setPixelType(thePixelType);
1650
1651  // Write it to disk.
1652  return writer->execute();
1653 }
virtual bool writeHistogramFile()
virtual void valueToString(ossimString &valueResult) const =0
virtual ossimRefPtr< ossimConnectableObject > disconnectMyInput(ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true)
Will disconnect the object at the given input index and generate a connection event.
virtual bool addListener(ossimListener *listener)
virtual void setOutputImageType(ossim_int32 type)
virtual ossim_uint16 getOverviewCompressType() const
virtual void setWriteImageFlag(bool flag)
virtual void setAreaOfInterest(const ossimIrect &areaOfInterest)
Sets the area of interest to write the meta data for.
virtual ossimObject * getObject()
ossimFilename noExtension() const
virtual bool writeErsHeaderFile()
Will write an ER Mapper header file.
virtual bool writeWorldFile()
Will write a world file.
virtual void setWriteJpegWorldFile(bool flag)
virtual bool execute()
Calls buildOverview.
virtual ossimImageHandler * open(const ossimFilename &fileName, bool trySuffixFirst=true, bool openOverview=true) const
open that takes a filename.
virtual void disconnect(ossimConnectableObject *object=0)
Will disconnect the object passed in.
static const char * CREATE_HISTOGRAM_KW
ossimUnitType
virtual ossimString getExtension() const
Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for...
Definition: ossimSource.cpp:55
virtual void setWriteErsHeaderFlag(bool flag)
virtual void setWriteTiffWorldFile(bool flag)
virtual void setScaleToEightBitFlag(bool flag)
bool valid() const
Definition: ossimRefPtr.h:75
virtual bool getOutputHasInternalOverviews(void) const
Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nit...
Definition: ossimSource.cpp:66
ossimRefPtr< ossimViewController > theViewController
virtual void setPixelType(ossimPixelType type)
If "point" the coordinate tie points are relative to the center of the pixel.
Overrides base "addListener" this will capture the pointer and then call the base class "addListener"...
virtual void setOverviewJpegCompressQuality(ossim_int32 quality)
ossimUnitType theLinearUnits
If not a geographic projection this allows the user to set the linear units of the output tag to be: ...
virtual ossimString getEntryString(ossim_int32 entry_number) const
virtual bool writeFile()=0
Write out the file.
virtual void disconnectInputEvent(ossimConnectionEvent &event)
static const char * OVERVIEW_COMPRESSION_TYPE_KW
virtual bool writeReadmeFile()
Will write a readme file.
Class to write out meta data in a Federal Geographic Data Committe (FGDC) format. ...
ossimIrect theAreaOfInterest
void setCopyAllFlag(bool flag)
Sets theCopyAllFlag.
void setChangeType(int type, bool on=true)
virtual bool getWriteTiffWorldFileFlag() const
ossimWorldFileWriter
virtual void setTileSize(const ossimIpt &tileSize)
Sets the output image tiling size if supported by the writer.
virtual void setPercentComplete(double percentComplete)
virtual ossimString getClassName() const
Definition: ossimObject.cpp:64
static const char * FILEPATH_KW
virtual bool getWriteErsHeaderFlag() const
ossim_uint32 toUInt32() const
virtual bool writeTiffWorldFile()
OSSIM_DLL ossimStdOutProgress theStdOutProgress
virtual void setReadOnlyFlag(bool flag)
void addConstraint(const ossimString &value)
Pure virtual base class for image file writers.
virtual bool canConnectMyInputTo(ossim_int32 inputIndex, const ossimConnectableObject *object) const
required to be overriden by derived classes
virtual void connectInputEvent(ossimConnectionEvent &event)
unsigned short ossim_uint16
virtual void setProcessStatus(ossimProcessStatus processStatus)
virtual void fireEvent(ossimEvent &event)
virtual bool setOutputStream(ossimRefPtr< ossimOStream > stream)
Sets the output stream to write to.
virtual bool getScaleToEightBitFlag() const
virtual ossimImageSourceSequencer * getSequencer()
static const char * TYPE_KW
virtual bool writeMetaDataFiles()
Convenience method that calls meta data write methods that are flagged to be called.
virtual ossim_int32 getOverviewJpegCompressQuality() const
ossimImageFileWriter(const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0)
The writer will own the sequencer.
virtual void setOutputName(const ossimString &outputName)
bool theWriteEnviHeaderFlag
External meta data writer flags.
virtual ossim_int32 getEntryNumber(const char *entry_string, bool case_insensitive=true) const
virtual void getImageTypeList(std::vector< ossimString > &imageTypeList) const =0
void getImageTypeList(std::vector<ossimString>& imageTypeList)const
ossim_int32 toInt32() const
virtual bool getWriteJpegWorldFileFlag() const
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
void setJpegCompressionQuality(ossim_int32 quality)
Sets the compression quality for use when using a compression type of COMPRESSION_JPEG.
virtual bool writeOverviewFile(ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false)
Write out an ossim overview file from the source_file.
Class for writing a "ERS" style header.
virtual void getPixelTypeString(ossimString &type) const
bool exists() const
virtual bool setInputSource(ossimImageHandler *imageSource)
Sets the input to the builder.
std::string::size_type size() const
Definition: ossimString.h:405
ossimRefPtr< ossimImageSourceSequencer > theInputConnection
virtual bool getWriteEnviHeaderFlag() const
static const char * CREATE_OVERVIEW_KW
bool toBool() const
String to numeric methods.
This will return the bounding rect of the source.
virtual bool writeStream()
Method to write the image to a stream.
unsigned int ossim_uint32
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
virtual void setWriteWorldFile(bool flag)
virtual void enableSource()
Definition: ossimSource.cpp:84
virtual bool getWriteWorldFileFlag() const
virtual ossimPixelType getPixelType() const
void setCompressionType(ossim_uint16 compression_type)
Sets the compression type to use when building overviews.
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
virtual void setWriteReadme(bool flag)
virtual void setAreaOfInterest(const ossimIrect &inputAreaOfInterest)
virtual bool hasImageType(const ossimString &imageType) const
bool hasImageType(const ossimString& imageType) const
static const char * CREATE_EXTERNAL_GEOMETRY_KW
virtual bool getWriteHistogramFlag() const
virtual bool getWriteOverviewFlag() const
virtual bool getWriteFgdcFlag() const
virtual ossimString getOutputImageTypeString() const
return status
virtual void setFilename(const ossimFilename &file)
ossimPixelType thePixelType
OSSIM_PIXEL_IS_POINT = 0, OSSIM_PIXEL_IS_AREA = 1.
virtual void setOutputFile(const ossimFilename &file)
Sets the output filename.
virtual void setWriteEnviHeaderFlag(bool flag)
virtual void setOverviewCompressType(ossim_uint16 type)
void setLinearUnits(ossimUnitType units)
Sets the linear units of the output file to either feet, us_survey_feet, or meters.
virtual bool writeFgdcFile()
Will write an fgdc file.
ossim_int32 theOverviewJpegCompressQuality
virtual bool writeExternalGeometryFile()
Will write an external geometry file.
ossimPixelType
virtual bool writeJpegWorldFile()
Will write a jpeg world file.
ConnectableObjectList theInputObjectList
Holds a list of input objects.
virtual const ossimFilename & getFilename() const
virtual void setPixelType(ossimPixelType pixelType)
Ossim uses a concept of "pixel is point" internally.
static const char * CREATE_IMAGE_KW
ossim_uint16 theOverviewCompressType
virtual void initialize()
Initialize method.
virtual void setWriteExternalGeometryFlag(bool flag)
virtual bool getWriteExternalGeometryFlag() const
virtual void setWriteFgdcFlag(bool flag)
void setIoType(ossimFilenamePropertyIoType ioType)
virtual bool open()=0
void makeNan()
Definition: ossimIrect.h:329
static const char * PIXEL_TYPE_KW
virtual void setAreaOfInterest(const ossimIrect &inputRect)
const char * c_str() const
Definition: ossimString.h:396
virtual bool writeEnviHeaderFile()
Will write an envi header file.
bool theInputListIsFixedFlag
Indicates whether the theInputObjectList is fixed.
bool empty() const
Definition: ossimString.h:411
virtual bool getWriteImageFlag() const
Control flags...
virtual ossimRefPtr< ossimOStream > getOutputStream() const
Method to return the stream attached to output.
virtual void changeSequencer(ossimImageSourceSequencer *sequencer)
Sets the sequencer and connects it to the input of this.
virtual bool getWriteReadmeFlag() const
bool hasNans() const
Definition: ossimIrect.h:337
virtual void setMaxNumberOfRLevels(ossim_uint32 number)
ossimString ext() const
const ossimIrect & getAreaOfInterest() const
static ossimImageHandlerRegistry * instance()
RTTI_DEF3(ossimImageFileWriter, "ossimImageFileWriter", ossimImageWriter, ossimProcessInterface, ossimConnectableObjectListener) static const char SCALE_TO_EIGHT_BIT_KW[]
8 bit unsigned integer
bool theOutputListIsFixedFlag
Indicates whether the theOutputObjectList is fixed.
static const char * IMAGE_TYPE_KW
static const char * OVERVIEW_COMPRESSION_QUALITY_KW
virtual void setWriteHistogramFlag(bool flag)
virtual ossim_int32 getOutputImageType() const
virtual void setFilename(const ossimFilename &filename)
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
virtual bool removeListener(ossimListener *listener)
Overrides base "removeListener".
bool createDirectory(bool recurseFlag=true, int perm=0775) const
static ossimUnitTypeLut * instance()
Returns the static instance of an ossimUnitTypeLut object.
virtual void propertyEvent(ossimPropertyEvent &event)
static const char * FILENAME_KW
ossimFilename path() const
virtual void setWriteOverviewFlag(bool flag)
Class for writing a "ENVI" style header.
ossimGeomFileWriter
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
Calls: writeFile() writeMetaDataFiles()
void setConstraints(const std::vector< ossimString > &constraintList)
const ossimString & getName() const
ossimListener * theProgressListener
int ossim_int32
