#include <ossimGeneralRasterWriter.h>
| ossimGeneralRasterWriter () | |
| virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const |
| void getImageTypeList(std::vector<ossimString>& imageTypeList)const More... | |
| virtual ossimString | getExtension () const |
| Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More... | |
| virtual void | set_rr_level (ossim_uint32 rr) |
| virtual bool | open () |
| virtual void | close () |
| saves the state of the object. More... | |
| virtual bool | writeStream () |
| Method to write the image to a stream. More... | |
| virtual bool | setOutputStream (std::ostream &stream) |
| Sets the output stream to write to. More... | |
Public Member Functions inherited from ossimImageFileWriter | |
| ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0) | |
| The writer will own the sequencer. More... | |
| virtual | ~ossimImageFileWriter () |
| virtual bool | getOutputHasInternalOverviews (void) const |
| Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More... | |
| virtual bool | hasImageType (const ossimString &imageType) const |
| bool hasImageType(const ossimString& imageType) const More... | |
| virtual void | setTileSize (const ossimIpt &tileSize) |
| Sets the output image tiling size if supported by the writer. More... | |
| virtual bool | writeEnviHeaderFile () |
| Will write an envi header file. More... | |
| virtual bool | writeErsHeaderFile () |
| Will write an ER Mapper header file. More... | |
| virtual bool | writeExternalGeometryFile () |
| Will write an external geometry file. More... | |
| virtual bool | writeFgdcFile () |
| Will write an fgdc file. More... | |
| virtual bool | writeHistogramFile () |
| Returns true on success, false on error. More... | |
| virtual bool | writeJpegWorldFile () |
| Will write a jpeg world file. More... | |
| virtual bool | writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false) |
| Write out an ossim overview file from the source_file. More... | |
| virtual bool | writeReadmeFile () |
| Will write a readme file. More... | |
| virtual bool | writeTiffWorldFile () |
| Will write a world file. More... | |
| virtual bool | writeWorldFile () |
| virtual bool | writeMetaDataFiles () |
| Convenience method that calls meta data write methods that are flagged to be called. More... | |
| virtual void | setAreaOfInterest (const ossimIrect &inputRect) |
| virtual void | changeSequencer (ossimImageSourceSequencer *sequencer) |
| Sets the sequencer and connects it to the input of this. More... | |
| virtual ossimImageSourceSequencer * | getSequencer () |
| Initialize method. More... | |
| virtual bool | execute () |
| Calls: writeFile() writeMetaDataFiles() More... | |
| virtual bool | setOutputStream (ossimRefPtr< ossimOStream > stream) |
| virtual ossimRefPtr< ossimOStream > | getOutputStream () const |
| Method to return the stream attached to output. More... | |
| virtual void | setPercentComplete (double percentComplete) |
| virtual void | setOutputImageType (ossim_int32 type) |
| virtual void | setOutputImageType (const ossimString &type) |
| virtual ossim_int32 | getOutputImageType () const |
| virtual ossimString | getOutputImageTypeString () const |
| virtual void | setOutputName (const ossimString &outputName) |
| virtual void | setFilename (const ossimFilename &file) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | getWriteImageFlag () const |
| Control flags... More... | |
| virtual bool | getWriteHistogramFlag () const |
| virtual bool | getWriteOverviewFlag () const |
| virtual bool | getScaleToEightBitFlag () const |
| virtual bool | getWriteEnviHeaderFlag () const |
| virtual bool | getWriteErsHeaderFlag () const |
| virtual bool | getWriteExternalGeometryFlag () const |
| virtual bool | getWriteFgdcFlag () const |
| virtual bool | getWriteJpegWorldFileFlag () const |
| virtual bool | getWriteReadmeFlag () const |
| virtual bool | getWriteTiffWorldFileFlag () const |
| virtual bool | getWriteWorldFileFlag () const |
| virtual void | setWriteImageFlag (bool flag) |
| virtual void | setWriteOverviewFlag (bool flag) |
| virtual void | setWriteHistogramFlag (bool flag) |
| virtual void | setScaleToEightBitFlag (bool flag) |
| virtual void | setWriteEnviHeaderFlag (bool flag) |
| virtual void | setWriteErsHeaderFlag (bool flag) |
| virtual void | setWriteExternalGeometryFlag (bool flag) |
| virtual void | setWriteFgdcFlag (bool flag) |
| virtual void | setWriteJpegWorldFile (bool flag) |
| virtual void | setWriteReadme (bool flag) |
| virtual void | setWriteTiffWorldFile (bool flag) |
| virtual void | setWriteWorldFile (bool flag) |
| virtual ossim_uint16 | getOverviewCompressType () const |
| virtual ossim_int32 | getOverviewJpegCompressQuality () const |
| virtual void | setOverviewCompressType (ossim_uint16 type) |
| virtual void | setOverviewJpegCompressQuality (ossim_int32 quality) |
| Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More... | |
| Overrides base "removeListener". More... | |
| virtual void | setPixelType (ossimPixelType type) |
| If "point" the coordinate tie points are relative to the center of the pixel. More... | |
| virtual void | setPixelType (const ossimString &type) |
| virtual ossimPixelType | getPixelType () const |
| virtual void | getPixelTypeString (ossimString &type) const |
Public Member Functions inherited from ossimImageWriter | |
| ossimImageWriter (ossimObject *owner=NULL) | |
| ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed) | |
| virtual | ~ossimImageWriter () |
| virtual bool | setViewingRect (const ossimIrect &aRect) |
| virtual ossimIrect | getAreaOfInterest () const |
Public Member Functions inherited from ossimOutputSource | |
| ossimOutputSource (ossimObject *owner=NULL) | |
| ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
| virtual | ~ossimOutputSource () |
| virtual bool | open (const ossimString &outputName) |
| virtual const ossimString & | getOutputName () |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual bool | writeFile () |
| Write out the file. More... | |
| virtual | ~ossimGeneralRasterWriter () |
| Protected ( this is a ossimRefPtr) destructor. More... | |
Protected Member Functions inherited from ossimImageFileWriter | |
| bool | writeWorldFile (const ossimFilename &file) |
| Common world file writer method. More... | |
Private Member Functions | |
| bool | writeToBip () |
| Writes image data to output file in BIP(Band Interleaved by Pixel) format. More... | |
| bool | writeToBil () |
| Writes image data to output file in BIL(Band Interleaved by Line) format. More... | |
| bool | writeToBsq () |
| Writes image data to output file in BSQ(Band Sequential) format. More... | |
| void | writeHeader () const |
| Writes an ossim header file which can be used to load file in ossim. More... | |
| void | writeEnviHeader () const |
| Writes an envi header file which can be used to load file in envi. More... | |
| ossimString | getInterleaveString () const |
Private Attributes | |
| std::ostream * | theOutputStream |
| bool | theOwnsStreamFlag |
| ossim_uint32 | theRlevel |
| ossimByteOrder | theOutputByteOrder |
| std::vector< double > | theMinPerBand |
| Populated while writting the data. More... | |
| std::vector< double > | theMaxPerBand |
Definition at line 25 of file ossimGeneralRasterWriter.h.
| ossimGeneralRasterWriter::ossimGeneralRasterWriter | ( | ) |
default constructor
Definition at line 35 of file ossimGeneralRasterWriter.cpp.
References ossimEndian::getSystemEndianType(), OSSIM_GENERAL_RASTER_BSQ, ossimImageFileWriter::setOutputImageType(), ossimImageFileWriter::setWriteExternalGeometryFlag(), and theOutputByteOrder.
protectedvirtual |
Definition at line 52 of file ossimGeneralRasterWriter.cpp.
References close(), and isOpen().
Generic interface to allow one to close a consumer. For displays this might minimize the window and free up internal pointers for file writers it will make sure the file stream is closed and flushed.
Implements ossimOutputSource.
Definition at line 93 of file ossimGeneralRasterWriter.cpp.
References theOutputStream, and theOwnsStreamFlag.
Referenced by open(), writeFile(), and ~ossimGeneralRasterWriter().
| imageType | string representing image type. |
Reimplemented from ossimImageFileWriter.
Definition at line 819 of file ossimGeneralRasterWriter.cpp.
Appends this writer image types to list "imageTypeList".
This writer has the following types: general_raster_bip general_raster_bil general_raster_bsq
| imageTypeList | stl::vector<ossimString> list to append to. |
Implements ossimImageFileWriter.
Definition at line 825 of file ossimGeneralRasterWriter.cpp.
private |
Definition at line 835 of file ossimGeneralRasterWriter.cpp.
References ossimImageFileWriter::theOutputImageType.
Definition at line 60 of file ossimGeneralRasterWriter.cpp.
References theOutputStream.
Referenced by writeFile(), and ~ossimGeneralRasterWriter().
Definition at line 651 of file ossimGeneralRasterWriter.cpp.
References ossimKeywordNames::BYTE_ORDER_KW, ossim::byteOrder(), ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), ossimEndian::getSystemEndianType(), ossimKeywordNames::INPUT_RR_LEVEL_KW, ossimImageFileWriter::loadState(), OSSIM_BIG_ENDIAN, OSSIM_LITTLE_ENDIAN, ossimImageFileWriter::setFilename(), theOutputByteOrder, ossimImageFileWriter::theOutputImageType, and theRlevel.
Allows a generic interface to open a consumer for writing. If you are a display writer then you would probably show the window or init the device context for writing.
Definition at line 65 of file ossimGeneralRasterWriter.cpp.
References ossimString::c_str(), close(), ossimString::size(), ossimImageFileWriter::theFilename, theOutputStream, and theOwnsStreamFlag.
Referenced by writeFile().
Definition at line 640 of file ossimGeneralRasterWriter.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::BYTE_ORDER_KW, OSSIM_LITTLE_ENDIAN, ossimImageFileWriter::saveState(), and theOutputByteOrder.
inlinevirtual |
Definition at line 56 of file ossimGeneralRasterWriter.h.
The stream will not be closed/deleted by this object.
| output | The stream to write to. |
Definition at line 856 of file ossimGeneralRasterWriter.cpp.
private |
If the output image file is "foo.ras" then the ossim header file will be "foo.hdr".
Definition at line 789 of file ossimGeneralRasterWriter.cpp.
protectedvirtual |
Write out the file.
Definition at line 107 of file ossimGeneralRasterWriter.cpp.
References close(), ossimString::contains(), ossimErrorStatusInterface::getErrorStatus(), ossimImageFileWriter::getSequencer(), ossimImageSourceSequencer::isMaster(), isOpen(), open(), ossimErrorCodes::OSSIM_OK, ossimImageFileWriter::theInputConnection, ossimImageFileWriter::theOutputImageType, ossimRefPtr< T >::valid(), writeEnviHeader(), writeHeader(), and writeStream().
private |
Definition at line 704 of file ossimGeneralRasterWriter.cpp.
Callers must call setOutputStream(...) method prior to this.
Definition at line 154 of file ossimGeneralRasterWriter.cpp.
References ossimErrorStatusInterface::getErrorStatus(), ossimImageSourceSequencer::isMaster(), ossimErrorCodes::OSSIM_OK, ossimNotify(), ossimNotifyLevel_FATAL, ossimImageSourceSequencer::slaveProcessTiles(), ossimImageFileWriter::theInputConnection, ossimImageFileWriter::theOutputImageType, theOutputStream, ossimRefPtr< T >::valid(), writeToBil(), writeToBip(), and writeToBsq().
private |
Definition at line 354 of file ossimGeneralRasterWriter.cpp.
Referenced by writeStream().
private |
Definition at line 207 of file ossimGeneralRasterWriter.cpp.
private |
Definition at line 489 of file ossimGeneralRasterWriter.cpp.
private |
Definition at line 152 of file ossimGeneralRasterWriter.h.
private |
Definition at line 151 of file ossimGeneralRasterWriter.h.
private |
Definition at line 146 of file ossimGeneralRasterWriter.h.
Referenced by loadState(), ossimGeneralRasterWriter(), and saveState().
private |
Definition at line 143 of file ossimGeneralRasterWriter.h.
Referenced by close(), isOpen(), open(), setOutputStream(), and writeStream().
private |
Definition at line 144 of file ossimGeneralRasterWriter.h.
Referenced by close(), open(), and setOutputStream().
private |
Definition at line 145 of file ossimGeneralRasterWriter.h.
Referenced by loadState().
