#include <ossimJpegWriter.h>
| ossimJpegWriter () | |
| virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const |
| void getImageTypeList(std::vector<ossimString>& imageTypeList)const More... | |
| virtual void | setQuality (ossim_int32 quality) |
| Sets the jpeg compression quality. More... | |
| virtual bool | open () |
| virtual void | close () |
| saves the state of the object. More... | |
| Will set the property whose name matches the argument "property->getName()". More... | |
| Pushes this's names onto the list of property names. More... | |
| virtual ossimString | getExtension () const |
| Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More... | |
| bool | hasImageType (const ossimString &imageType) const |
| bool hasImageType(const ossimString& imageType) const More... | |
Public Member Functions inherited from ossimImageFileWriter | |
| ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0) | |
| The writer will own the sequencer. More... | |
| virtual | ~ossimImageFileWriter () |
| virtual bool | getOutputHasInternalOverviews (void) const |
| Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More... | |
| virtual void | setTileSize (const ossimIpt &tileSize) |
| Sets the output image tiling size if supported by the writer. More... | |
| virtual bool | writeEnviHeaderFile () |
| Will write an envi header file. More... | |
| virtual bool | writeErsHeaderFile () |
| Will write an ER Mapper header file. More... | |
| virtual bool | writeExternalGeometryFile () |
| Will write an external geometry file. More... | |
| virtual bool | writeFgdcFile () |
| Will write an fgdc file. More... | |
| virtual bool | writeHistogramFile () |
| Returns true on success, false on error. More... | |
| virtual bool | writeJpegWorldFile () |
| Will write a jpeg world file. More... | |
| virtual bool | writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false) |
| Write out an ossim overview file from the source_file. More... | |
| virtual bool | writeReadmeFile () |
| Will write a readme file. More... | |
| virtual bool | writeTiffWorldFile () |
| Will write a world file. More... | |
| virtual bool | writeWorldFile () |
| virtual bool | writeMetaDataFiles () |
| Convenience method that calls meta data write methods that are flagged to be called. More... | |
| virtual void | setAreaOfInterest (const ossimIrect &inputRect) |
| virtual void | changeSequencer (ossimImageSourceSequencer *sequencer) |
| Sets the sequencer and connects it to the input of this. More... | |
| virtual ossimImageSourceSequencer * | getSequencer () |
| Initialize method. More... | |
| virtual bool | execute () |
| Calls: writeFile() writeMetaDataFiles() More... | |
| virtual bool | writeStream () |
| Method to write the image to a stream. More... | |
| virtual bool | setOutputStream (ossimRefPtr< ossimOStream > stream) |
| Sets the output stream to write to. More... | |
| virtual bool | setOutputStream (std::ostream &str) |
| tmp drb More... | |
| virtual ossimRefPtr< ossimOStream > | getOutputStream () const |
| Method to return the stream attached to output. More... | |
| virtual void | setPercentComplete (double percentComplete) |
| virtual void | setOutputImageType (ossim_int32 type) |
| virtual void | setOutputImageType (const ossimString &type) |
| virtual ossim_int32 | getOutputImageType () const |
| virtual ossimString | getOutputImageTypeString () const |
| virtual void | setOutputName (const ossimString &outputName) |
| virtual void | setFilename (const ossimFilename &file) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | getWriteImageFlag () const |
| Control flags... More... | |
| virtual bool | getWriteHistogramFlag () const |
| virtual bool | getWriteOverviewFlag () const |
| virtual bool | getScaleToEightBitFlag () const |
| virtual bool | getWriteEnviHeaderFlag () const |
| virtual bool | getWriteErsHeaderFlag () const |
| virtual bool | getWriteExternalGeometryFlag () const |
| virtual bool | getWriteFgdcFlag () const |
| virtual bool | getWriteJpegWorldFileFlag () const |
| virtual bool | getWriteReadmeFlag () const |
| virtual bool | getWriteTiffWorldFileFlag () const |
| virtual bool | getWriteWorldFileFlag () const |
| virtual void | setWriteImageFlag (bool flag) |
| virtual void | setWriteOverviewFlag (bool flag) |
| virtual void | setWriteHistogramFlag (bool flag) |
| virtual void | setScaleToEightBitFlag (bool flag) |
| virtual void | setWriteEnviHeaderFlag (bool flag) |
| virtual void | setWriteErsHeaderFlag (bool flag) |
| virtual void | setWriteExternalGeometryFlag (bool flag) |
| virtual void | setWriteFgdcFlag (bool flag) |
| virtual void | setWriteJpegWorldFile (bool flag) |
| virtual void | setWriteReadme (bool flag) |
| virtual void | setWriteTiffWorldFile (bool flag) |
| virtual void | setWriteWorldFile (bool flag) |
| virtual ossim_uint16 | getOverviewCompressType () const |
| virtual ossim_int32 | getOverviewJpegCompressQuality () const |
| virtual void | setOverviewCompressType (ossim_uint16 type) |
| virtual void | setOverviewJpegCompressQuality (ossim_int32 quality) |
| Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More... | |
| Overrides base "removeListener". More... | |
| virtual void | setPixelType (ossimPixelType type) |
| If "point" the coordinate tie points are relative to the center of the pixel. More... | |
| virtual void | setPixelType (const ossimString &type) |
| virtual ossimPixelType | getPixelType () const |
| virtual void | getPixelTypeString (ossimString &type) const |
Public Member Functions inherited from ossimImageWriter | |
| ossimImageWriter (ossimObject *owner=NULL) | |
| ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed) | |
| virtual | ~ossimImageWriter () |
| virtual bool | setViewingRect (const ossimIrect &aRect) |
| virtual ossimIrect | getAreaOfInterest () const |
Public Member Functions inherited from ossimOutputSource | |
| ossimOutputSource (ossimObject *owner=NULL) | |
| ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
| virtual | ~ossimOutputSource () |
| virtual bool | open (const ossimString &outputName) |
| virtual const ossimString & | getOutputName () |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimJpegWriter () |
Protected Member Functions inherited from ossimImageFileWriter | |
| bool | writeWorldFile (const ossimFilename &file) |
| Common world file writer method. More... | |
Private Member Functions | |
| virtual bool | writeFile () |
| Write out the file. More... | |
Private Attributes | |
| ossim_int32 | theQuality |
| FILE * | theOutputFilePtr |
Definition at line 23 of file ossimJpegWriter.h.
| ossimJpegWriter::ossimJpegWriter | ( | ) |
default constructor
Definition at line 44 of file ossimJpegWriter.cpp.
protectedvirtual |
Generic interface to allow one to close a consumer. For displays this might minimize the window and free up internal pointers for file writers it will make sure the file stream is closed and flushed.
Implements ossimOutputSource.
Definition at line 393 of file ossimJpegWriter.cpp.
References theOutputFilePtr.
Referenced by open(), and ~ossimJpegWriter().
| imageType | string representing image type. |
Reimplemented from ossimImageFileWriter.
Definition at line 407 of file ossimJpegWriter.cpp.
Appends this writer image types to list "imageTypeList".
This writer only has one type "jpeg".
| imageTypeList | stl::vector<ossimString> list to append to. |
Implements ossimImageFileWriter.
Definition at line 402 of file ossimJpegWriter.cpp.
| name | Name of property to return. |
Definition at line 440 of file ossimJpegWriter.cpp.
References ossimKeywordNames::COMPRESSION_QUALITY_KW, ossimImageFileWriter::getProperty(), ossimNumericProperty::ossimNumericPropertyType_INT, ossimNumericProperty::setNumericType(), theQuality, and ossimString::toString().
| propertyNames | array to add this's property names to. |
Definition at line 456 of file ossimJpegWriter.cpp.
References ossimKeywordNames::COMPRESSION_QUALITY_KW, and ossimImageFileWriter::getPropertyNames().
Definition at line 412 of file ossimJpegWriter.cpp.
References ossimImageFileWriter::hasImageType().
Definition at line 370 of file ossimJpegWriter.cpp.
Referenced by writeFile().
Definition at line 321 of file ossimJpegWriter.cpp.
References ossimKeywordNames::COMPRESSION_QUALITY_KW, ossimKeywordlist::find(), ossimImageFileWriter::loadState(), setQuality(), and ossimImageFileWriter::theOutputImageType.
Allows a generic interface to open a consumer for writing. If you are a display writer then you would probably show the window or init the device context for writing.
Definition at line 375 of file ossimJpegWriter.cpp.
References ossimString::c_str(), close(), ossimString::empty(), ossimImageFileWriter::theFilename, and theOutputFilePtr.
Definition at line 311 of file ossimJpegWriter.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::COMPRESSION_QUALITY_KW, ossimImageFileWriter::saveState(), and theQuality.
| property | Object containing property to set. |
Definition at line 423 of file ossimJpegWriter.cpp.
References ossimKeywordNames::COMPRESSION_QUALITY_KW, ossimProperty::getName(), ossimImageFileWriter::setProperty(), setQuality(), ossimString::toInt32(), and ossimRefPtr< T >::valid().
| quality | Compression quality. (valid range is 1 to 100) |
Definition at line 336 of file ossimJpegWriter.cpp.
References theQuality.
Referenced by loadState(), and setProperty().
privatevirtual |
Write out the file.
Definition at line 58 of file ossimJpegWriter.cpp.
References ossimString::c_str(), ossimConnectableObject::connectMyInputTo(), ossimRefPtr< T >::get(), ossimErrorStatusInterface::getErrorStatus(), ossimConnectableObject::getInput(), ossimImageSource::getNumberOfOutputBands(), ossimImageSourceSequencer::getOutputScalarType(), ossimImageSourceSequencer::initialize(), ossimImageSourceSequencer::isMaster(), isOpen(), open(), ossimErrorCodes::OSSIM_OK, OSSIM_UINT8, ossimNotify(), ossimNotifyLevel_WARN, ossimImageFileWriter::theFilename, ossimImageFileWriter::theInputConnection, and theOutputFilePtr.
private |
Definition at line 110 of file ossimJpegWriter.h.
Referenced by close(), isOpen(), open(), and writeFile().
private |
Definition at line 109 of file ossimJpegWriter.h.
Referenced by getProperty(), saveState(), and setQuality().
