#include <ossimWorldFileWriter.h>
| ossimWorldFileWriter () | |
| Load state method: More... | |
| virtual void | getMetadatatypeList (std::vector< ossimString > &metadatatypeList) const |
| Satisfies pure virtual from ossimMetadataWriter base. More... | |
| virtual bool | hasMetadataType (const ossimString &metadataType) const |
| void | setLinearUnits (ossimUnitType units) |
| Sets the linear units of the output file to either feet, us_survey_feet, or meters. More... | |
Public Member Functions inherited from ossimMetadataFileWriter | |
| ossimMetadataFileWriter () | |
| virtual bool | execute () |
| virtual void | setPercentComplete (double percentComplete) |
| virtual void | setFilename (const ossimFilename &file) |
| const ossimFilename & | getFilename () const |
| virtual void | setPixelType (ossimPixelType pixelType) |
| Ossim uses a concept of "pixel is point" internally. More... | |
| virtual ossimPixelType | getPixelType () const |
| virtual void | setAreaOfInterest (const ossimIrect &areaOfInterest) |
| Sets the area of interest to write the meta data for. More... | |
| virtual ossimIrect | getAreaOfInterest () const |
| ossimObject () | |
| ossimListenerManager () | |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimWorldFileWriter () |
| virtual bool | writeFile () |
| Write out the file. More... | |
Protected Member Functions inherited from ossimMetadataFileWriter | |
| virtual | ~ossimMetadataFileWriter () |
Public Types inherited from ossimProcessInterface | |
| enum | ossimProcessStatus { PROCESS_STATUS_UNKNOWN = 0, PROCESS_STATUS_EXECUTING = 1, PROCESS_STATUS_ABORTED = 2, PROCESS_STATUS_ABORT_REQUEST = 3, PROCESS_STATUS_NOT_EXECUTING = 4 } |
Definition at line 17 of file ossimWorldFileWriter.h.
| ossimWorldFileWriter::ossimWorldFileWriter | ( | ) |
default constructor
protectedvirtual |
default constructor
Appends the writers image types to the "metadatatypeList".
| metadatatypeList | stl::vector<ossimString> list to append to. |
Implements ossimMetadataFileWriter.
| imageType | string representing image type. |
Load state method:
This method call base class ossimMetadataFileWriter::loadState after looking for its keywords.
| kwl | Keyword list to initialize from. |
| prefix | Usually something like: "object1." |
Keywords picked up by loadState:
(linear units must be "feet", "us_survey_feet", or "meters") (If projection is geographic units will always be decimal degrees.)
linear_units: us_survey_feet
Reimplemented from ossimMetadataFileWriter.
| void ossimWorldFileWriter::setLinearUnits | ( | ossimUnitType | units | ) |
If the projection is geographic, the call has no affect.
If units is not feet, us_survey_feet or meters this call has no effect.
| units | Desired output units of the world file. |
Referenced by ossimImageFileWriter::writeWorldFile().
protectedvirtual |
protected |
Definition at line 84 of file ossimWorldFileWriter.h.
