Class to write out meta data in a Federal Geographic Data Committe (FGDC) format. More...
#include <ossimFgdcFileWriter.h>
| ossimFgdcFileWriter () | |
| constructor More... | |
| Method to load the state from a keyword list. More... | |
| virtual void | getMetadatatypeList (std::vector< ossimString > &metadatatypeList) const |
| Satisfies pure virtual from ossimMetadataWriter base. More... | |
| virtual bool | hasMetadataType (const ossimString &metadataType) const |
| ossim_uint32 | getIndentionLevel () const |
| void | setIndentionLevel (ossim_uint32 level) |
| Sets the current indentation level. More... | |
| ossimString | getTabString () const |
| void | setTabString (const ossimString &tabString) |
| Sets the tab string. More... | |
| void | setTitle (const ossimString &pubDate) |
| void | setTemplate (const ossimFilename &xmlTemplateFile) |
| ossimString | find (const ossimString &xpath) const |
| bool | writeTemplate (const ossimFilename &file) const |
Public Member Functions inherited from ossimMetadataFileWriter | |
| ossimMetadataFileWriter () | |
| virtual bool | execute () |
| virtual void | setPercentComplete (double percentComplete) |
| virtual void | setFilename (const ossimFilename &file) |
| const ossimFilename & | getFilename () const |
| virtual void | setPixelType (ossimPixelType pixelType) |
| Ossim uses a concept of "pixel is point" internally. More... | |
| virtual ossimPixelType | getPixelType () const |
| virtual void | setAreaOfInterest (const ossimIrect &areaOfInterest) |
| Sets the area of interest to write the meta data for. More... | |
| virtual ossimIrect | getAreaOfInterest () const |
| ossimObject () | |
| ossimListenerManager () | |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimFgdcFileWriter () |
| destructor More... | |
| virtual bool | writeFile () |
| Writes file to disk. More... | |
Protected Member Functions inherited from ossimMetadataFileWriter | |
| virtual | ~ossimMetadataFileWriter () |
Private Member Functions | |
| void | openTag (std::ostream &os, const ossimString &tag, bool newLine) const |
| Writes openning tag adding any indentation and brackets. More... | |
| void | closeTag (std::ostream &os, const ossimString &tag, bool decrementLevel) const |
| Closes tag decrementing indentation. More... | |
Private Attributes | |
| ossim_uint32 | theIndentionLevel |
| ossimString | theTabString |
| ossimXmlDocument | theTemplate |
| ossimFilename | theSourceImageFilename |
Definition at line 26 of file ossimFgdcFileWriter.h.
| ossimFgdcFileWriter::ossimFgdcFileWriter | ( | ) |
constructor
Definition at line 35 of file ossimFgdcFileWriter.cpp.
protectedvirtual |
private |
e.g.: <metadata>
| os | otream to write to. |
| tag | String representing tag with no brackets. |
| decrementLevel | If true indentation level is decremented. |
Definition at line 895 of file ossimFgdcFileWriter.cpp.
References ossimString::c_str(), ossimString::size(), theIndentionLevel, and theTabString.
Referenced by writeFile(), and writeTemplate().
| ossimString ossimFgdcFileWriter::find | ( | const ossimString & | xpath | ) | const |
Definition at line 923 of file ossimFgdcFileWriter.cpp.
References ossimXmlDocument::findNodes(), ossimErrorStatusInterface::getErrorStatus(), and theTemplate.
Referenced by writeFile().
| ossim_uint32 ossimFgdcFileWriter::getIndentionLevel | ( | ) | const |
Definition at line 851 of file ossimFgdcFileWriter.cpp.
References theIndentionLevel.
Appends the writers image types to the "metadatatypeList".
| metadatatypeList | stl::vector<ossimString> list to append to. |
Implements ossimMetadataFileWriter.
Definition at line 945 of file ossimFgdcFileWriter.cpp.
| ossimString ossimFgdcFileWriter::getTabString | ( | ) | const |
Definition at line 861 of file ossimFgdcFileWriter.cpp.
References theTabString.
| imageType | string representing image type. |
Definition at line 951 of file ossimFgdcFileWriter.cpp.
| kwl | Keyword list to load state from. |
| prefix | Prefix to attatch to keyword (like "object1."). default=NULL |
Keywords picked up by this loadState:
source_image_filename: foo.ntf tab_string: "\t" fgdc_template_doc: fgdc_template.xml
Reimplemented from ossimMetadataFileWriter.
Definition at line 824 of file ossimFgdcFileWriter.cpp.
References ossimKeywordlist::find(), ossimMetadataFileWriter::loadState(), setTemplate(), theSourceImageFilename, and theTabString.
private |
Increments indentation level.
| tag | String representing tag with no brackets, i.e. "metadata". |
| newLine | If true a new line "\n" is added. |
Definition at line 871 of file ossimFgdcFileWriter.cpp.
| void ossimFgdcFileWriter::setIndentionLevel | ( | ossim_uint32 | level | ) |
| level | Indentation level. "0" equals no indentation. |
Definition at line 856 of file ossimFgdcFileWriter.cpp.
| void ossimFgdcFileWriter::setTabString | ( | const ossimString & | tabString | ) |
Usually "\t" or spaces " ".
| tabString | String to use for indentation. |
Definition at line 866 of file ossimFgdcFileWriter.cpp.
| void ossimFgdcFileWriter::setTemplate | ( | const ossimFilename & | xmlTemplateFile | ) |
Definition at line 918 of file ossimFgdcFileWriter.cpp.
References ossimXmlDocument::openFile(), and theTemplate.
Referenced by loadState().
| void ossimFgdcFileWriter::setTitle | ( | const ossimString & | pubDate | ) |
| title | Tile of data usually the image file name. |
protectedvirtual |
Definition at line 48 of file ossimFgdcFileWriter.cpp.
References ossimString::c_str(), closeTag(), find(), ossimImageSource::getBoundingRect(), ossimImageSource::getImageGeometry(), ossimImageGeometry::getProjection(), ossimMapProjection::isGeographic(), ossimFilename::NIL, openTag(), ossimNotify(), ossimNotifyLevel_WARN, PTR_CAST, ossimMetadataFileWriter::theFilename, ossimMetadataFileWriter::theInputConnection, theSourceImageFilename, ossimString::toString(), and ossimRefPtr< T >::valid().
| bool ossimFgdcFileWriter::writeTemplate | ( | const ossimFilename & | file | ) | const |
Definition at line 491 of file ossimFgdcFileWriter.cpp.
References ossimString::c_str(), closeTag(), openTag(), ossimNotify(), and ossimNotifyLevel_WARN.
mutableprivate |
Definition at line 149 of file ossimFgdcFileWriter.h.
Referenced by closeTag(), getIndentionLevel(), openTag(), and setIndentionLevel().
private |
Definition at line 152 of file ossimFgdcFileWriter.h.
Referenced by loadState(), and writeFile().
private |
Definition at line 150 of file ossimFgdcFileWriter.h.
Referenced by closeTag(), getTabString(), loadState(), openTag(), and setTabString().
private |
Definition at line 151 of file ossimFgdcFileWriter.h.
Referenced by find(), and setTemplate().
