#include <ossimKakaduJp2Writer.h>
| ossimKakaduJp2Writer () | |
| virtual | ~ossimKakaduJp2Writer () |
| virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const |
| Appends this writer image types to list "imageTypeList". More... | |
| virtual bool | open () |
| virtual void | close () |
| saves the state of the object. More... | |
| Will set the property whose name matches the argument "property->getName()". More... | |
| Pushes this's names onto the list of property names. More... | |
| virtual ossimString | getExtension () const |
| Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More... | |
| virtual bool | getOutputHasInternalOverviews (void) const |
| Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More... | |
| bool | hasImageType (const ossimString &imageType) const |
| bool hasImageType(const ossimString& imageType) const More... | |
| virtual bool | writeStream () |
| Method to write the image to a stream. More... | |
| virtual bool | setOutputStream (std::ostream &stream) |
| Sets the output stream to write to. More... | |
Public Member Functions inherited from ossimImageFileWriter | |
| ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0) | |
| The writer will own the sequencer. More... | |
| virtual | ~ossimImageFileWriter () |
| virtual void | setTileSize (const ossimIpt &tileSize) |
| Sets the output image tiling size if supported by the writer. More... | |
| virtual bool | writeEnviHeaderFile () |
| Will write an envi header file. More... | |
| virtual bool | writeErsHeaderFile () |
| Will write an ER Mapper header file. More... | |
| virtual bool | writeExternalGeometryFile () |
| Will write an external geometry file. More... | |
| virtual bool | writeFgdcFile () |
| Will write an fgdc file. More... | |
| virtual bool | writeHistogramFile () |
| Returns true on success, false on error. More... | |
| virtual bool | writeJpegWorldFile () |
| Will write a jpeg world file. More... | |
| virtual bool | writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false) |
| Write out an ossim overview file from the source_file. More... | |
| virtual bool | writeReadmeFile () |
| Will write a readme file. More... | |
| virtual bool | writeTiffWorldFile () |
| Will write a world file. More... | |
| virtual bool | writeWorldFile () |
| virtual bool | writeMetaDataFiles () |
| Convenience method that calls meta data write methods that are flagged to be called. More... | |
| virtual void | setAreaOfInterest (const ossimIrect &inputRect) |
| virtual void | changeSequencer (ossimImageSourceSequencer *sequencer) |
| Sets the sequencer and connects it to the input of this. More... | |
| virtual ossimImageSourceSequencer * | getSequencer () |
| Initialize method. More... | |
| virtual bool | execute () |
| Calls: writeFile() writeMetaDataFiles() More... | |
| virtual bool | setOutputStream (ossimRefPtr< ossimOStream > stream) |
| virtual ossimRefPtr< ossimOStream > | getOutputStream () const |
| Method to return the stream attached to output. More... | |
| virtual void | setPercentComplete (double percentComplete) |
| virtual void | setOutputImageType (ossim_int32 type) |
| virtual void | setOutputImageType (const ossimString &type) |
| virtual ossim_int32 | getOutputImageType () const |
| virtual ossimString | getOutputImageTypeString () const |
| virtual void | setOutputName (const ossimString &outputName) |
| virtual void | setFilename (const ossimFilename &file) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | getWriteImageFlag () const |
| Control flags... More... | |
| virtual bool | getWriteHistogramFlag () const |
| virtual bool | getWriteOverviewFlag () const |
| virtual bool | getScaleToEightBitFlag () const |
| virtual bool | getWriteEnviHeaderFlag () const |
| virtual bool | getWriteErsHeaderFlag () const |
| virtual bool | getWriteExternalGeometryFlag () const |
| virtual bool | getWriteFgdcFlag () const |
| virtual bool | getWriteJpegWorldFileFlag () const |
| virtual bool | getWriteReadmeFlag () const |
| virtual bool | getWriteTiffWorldFileFlag () const |
| virtual bool | getWriteWorldFileFlag () const |
| virtual void | setWriteImageFlag (bool flag) |
| virtual void | setWriteOverviewFlag (bool flag) |
| virtual void | setWriteHistogramFlag (bool flag) |
| virtual void | setScaleToEightBitFlag (bool flag) |
| virtual void | setWriteEnviHeaderFlag (bool flag) |
| virtual void | setWriteErsHeaderFlag (bool flag) |
| virtual void | setWriteExternalGeometryFlag (bool flag) |
| virtual void | setWriteFgdcFlag (bool flag) |
| virtual void | setWriteJpegWorldFile (bool flag) |
| virtual void | setWriteReadme (bool flag) |
| virtual void | setWriteTiffWorldFile (bool flag) |
| virtual void | setWriteWorldFile (bool flag) |
| virtual ossim_uint16 | getOverviewCompressType () const |
| virtual ossim_int32 | getOverviewJpegCompressQuality () const |
| virtual void | setOverviewCompressType (ossim_uint16 type) |
| virtual void | setOverviewJpegCompressQuality (ossim_int32 quality) |
| Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More... | |
| Overrides base "removeListener". More... | |
| virtual void | setPixelType (ossimPixelType type) |
| If "point" the coordinate tie points are relative to the center of the pixel. More... | |
| virtual void | setPixelType (const ossimString &type) |
| virtual ossimPixelType | getPixelType () const |
| virtual void | getPixelTypeString (ossimString &type) const |
Public Member Functions inherited from ossimImageWriter | |
| ossimImageWriter (ossimObject *owner=NULL) | |
| ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed) | |
| virtual | ~ossimImageWriter () |
| virtual bool | setViewingRect (const ossimIrect &aRect) |
| virtual ossimIrect | getAreaOfInterest () const |
Public Member Functions inherited from ossimOutputSource | |
| ossimOutputSource (ossimObject *owner=NULL) | |
| ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
| virtual | ~ossimOutputSource () |
| virtual bool | open (const ossimString &outputName) |
| virtual const ossimString & | getOutputName () |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual bool | writeFile () |
| Writes the file to disk or a stream. More... | |
Protected Member Functions inherited from ossimImageFileWriter | |
| bool | writeWorldFile (const ossimFilename &file) |
| Common world file writer method. More... | |
Private Member Functions | |
| bool | writeGeotiffBox (ossimKakaduCompressor *compressor) |
| Writes geotiff box if input has good geometry. More... | |
| bool | writeGmlBox (ossimKakaduCompressor *compressor) |
| Writes GML box if input has good geometry. More... | |
Private Attributes | |
| ossimKakaduCompressor * | m_compressor |
| std::ostream * | m_outputStream |
| bool | m_ownsStreamFlag |
Definition at line 24 of file ossimKakaduJp2Writer.h.
| ossimKakaduJp2Writer::ossimKakaduJp2Writer | ( | ) |
default constructor
Definition at line 55 of file ossimKakaduJp2Writer.cpp.
Definition at line 78 of file ossimKakaduJp2Writer.cpp.
References close(), and m_compressor.
Generic interface to allow one to close a consumer. For displays this might minimize the window and free up internal pointers for file writers it will make sure the file stream is closed and flushed.
Implements ossimOutputSource.
Definition at line 386 of file ossimKakaduJp2Writer.cpp.
References m_outputStream, and m_ownsStreamFlag.
Referenced by open(), and ~ossimKakaduJp2Writer().
Definition at line 100 of file ossimKakaduJp2Writer.cpp.
| imageType | string representing image type. |
Reimplemented from ossimImageFileWriter.
Definition at line 405 of file ossimKakaduJp2Writer.cpp.
| imageTypeList | stl::vector<ossimString> list to append to. |
Implements ossimImageFileWriter.
Definition at line 400 of file ossimKakaduJp2Writer.cpp.
References getShortName().
Definition at line 95 of file ossimKakaduJp2Writer.cpp.
Definition at line 410 of file ossimKakaduJp2Writer.cpp.
| name | Name of property to return. |
Definition at line 438 of file ossimKakaduJp2Writer.cpp.
References ossimKakaduCompressor::getProperty(), ossimImageFileWriter::getProperty(), and m_compressor.
| propertyNames | array to add this's property names to. |
Definition at line 451 of file ossimKakaduJp2Writer.cpp.
References ossimKakaduCompressor::getPropertyNames(), ossimImageFileWriter::getPropertyNames(), and m_compressor.
Definition at line 90 of file ossimKakaduJp2Writer.cpp.
Referenced by getImageTypeList(), and hasImageType().
Definition at line 415 of file ossimKakaduJp2Writer.cpp.
Definition at line 346 of file ossimKakaduJp2Writer.cpp.
References m_outputStream.
Definition at line 338 of file ossimKakaduJp2Writer.cpp.
References ossimKakaduCompressor::loadState(), ossimImageFileWriter::loadState(), and m_compressor.
Allows a generic interface to open a consumer for writing. If you are a display writer then you would probably show the window or init the device context for writing.
Definition at line 351 of file ossimKakaduJp2Writer.cpp.
References ossimString::c_str(), close(), m_outputStream, m_ownsStreamFlag, ossimString::size(), and ossimImageFileWriter::theFilename.
Definition at line 330 of file ossimKakaduJp2Writer.cpp.
References m_compressor, ossimKakaduCompressor::saveState(), and ossimImageFileWriter::saveState().
The stream will not be closed/deleted by this object.
| output | The stream to write to. |
Definition at line 459 of file ossimKakaduJp2Writer.cpp.
| property | Object containing property to set. |
Definition at line 426 of file ossimKakaduJp2Writer.cpp.
References m_compressor, ossimKakaduCompressor::setProperty(), ossimImageFileWriter::setProperty(), and ossimRefPtr< T >::valid().
protectedvirtual |
Definition at line 105 of file ossimKakaduJp2Writer.cpp.
References ossimErrorStatusInterface::getErrorStatus(), ossimErrorCodes::OSSIM_OK, ossimImageSourceSequencer::setTileSize(), ossimImageFileWriter::theInputConnection, and ossimRefPtr< T >::valid().
private |
| compressor | Writes to this. |
Definition at line 283 of file ossimKakaduJp2Writer.cpp.
References ossimFilename::fileNoExtension(), ossimRefPtr< T >::get(), ossimImageSourceSequencer::getBoundingRect(), ossimImageSource::getImageGeometry(), ossimImageFileWriter::getPixelType(), ossimImageFileWriter::theFilename, ossimImageFileWriter::theInputConnection, ossimRefPtr< T >::valid(), and ossimKakaduCompressor::writeGeotiffBox().
private |
Definition at line 310 of file ossimKakaduJp2Writer.cpp.
References ossimRefPtr< T >::get(), ossimImageSourceSequencer::getBoundingRect(), ossimImageSource::getImageGeometry(), ossimImageFileWriter::theInputConnection, ossimRefPtr< T >::valid(), and ossimKakaduCompressor::writeGmlBox().
Definition at line 145 of file ossimKakaduJp2Writer.cpp.
private |
Definition at line 151 of file ossimKakaduJp2Writer.h.
Referenced by getProperty(), getPropertyNames(), loadState(), saveState(), setProperty(), and ~ossimKakaduJp2Writer().
private |
Definition at line 152 of file ossimKakaduJp2Writer.h.
Referenced by close(), isOpen(), open(), and setOutputStream().
private |
Definition at line 153 of file ossimKakaduJp2Writer.h.
Referenced by close(), open(), and setOutputStream().
