References: More...
#include <ossimPdfWriter.h>
Public Types | |
| enum | ossimPdfImageType { UNKNOWN = 0, JPEG = 1, RAW = 2 } |
Public Types inherited from ossimProcessInterface | |
| enum | ossimProcessStatus { PROCESS_STATUS_UNKNOWN = 0, PROCESS_STATUS_EXECUTING = 1, PROCESS_STATUS_ABORTED = 2, PROCESS_STATUS_ABORT_REQUEST = 3, PROCESS_STATUS_NOT_EXECUTING = 4 } |
| ossimPdfWriter () | |
| virtual | ~ossimPdfWriter () |
| virtual ossimString | getExtension () const |
| Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More... | |
| virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const |
| void getImageTypeList(std::vector<ossimString>& imageTypeList)const More... | |
| virtual bool | open () |
| Open method. More... | |
| virtual void | close () |
| Closes file. More... | |
| saves the state of the object. More... | |
| Will set the property whose name matches the argument "property->getName()". More... | |
| Gets property for name. More... | |
| Pushes this's names onto the list of property names. More... | |
| virtual bool | hasImageType (const ossimString &imageType) const |
| bool hasImageType(const ossimString& imageType) const More... | |
| virtual bool | writeStream () |
| Method to write the image to a stream. More... | |
| virtual bool | setOutputStream (std::ostream &stream) |
| Sets the output stream to write to. More... | |
Public Member Functions inherited from ossimImageFileWriter | |
| ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0) | |
| The writer will own the sequencer. More... | |
| virtual | ~ossimImageFileWriter () |
| virtual bool | getOutputHasInternalOverviews (void) const |
| Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More... | |
| virtual void | setTileSize (const ossimIpt &tileSize) |
| Sets the output image tiling size if supported by the writer. More... | |
| virtual bool | writeEnviHeaderFile () |
| Will write an envi header file. More... | |
| virtual bool | writeErsHeaderFile () |
| Will write an ER Mapper header file. More... | |
| virtual bool | writeExternalGeometryFile () |
| Will write an external geometry file. More... | |
| virtual bool | writeFgdcFile () |
| Will write an fgdc file. More... | |
| virtual bool | writeHistogramFile () |
| Returns true on success, false on error. More... | |
| virtual bool | writeJpegWorldFile () |
| Will write a jpeg world file. More... | |
| virtual bool | writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false) |
| Write out an ossim overview file from the source_file. More... | |
| virtual bool | writeReadmeFile () |
| Will write a readme file. More... | |
| virtual bool | writeTiffWorldFile () |
| Will write a world file. More... | |
| virtual bool | writeWorldFile () |
| virtual bool | writeMetaDataFiles () |
| Convenience method that calls meta data write methods that are flagged to be called. More... | |
| virtual void | setAreaOfInterest (const ossimIrect &inputRect) |
| virtual void | changeSequencer (ossimImageSourceSequencer *sequencer) |
| Sets the sequencer and connects it to the input of this. More... | |
| virtual ossimImageSourceSequencer * | getSequencer () |
| Initialize method. More... | |
| virtual bool | execute () |
| Calls: writeFile() writeMetaDataFiles() More... | |
| virtual bool | setOutputStream (ossimRefPtr< ossimOStream > stream) |
| virtual ossimRefPtr< ossimOStream > | getOutputStream () const |
| Method to return the stream attached to output. More... | |
| virtual void | setPercentComplete (double percentComplete) |
| virtual void | setOutputImageType (ossim_int32 type) |
| virtual void | setOutputImageType (const ossimString &type) |
| virtual ossim_int32 | getOutputImageType () const |
| virtual ossimString | getOutputImageTypeString () const |
| virtual void | setOutputName (const ossimString &outputName) |
| virtual void | setFilename (const ossimFilename &file) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | getWriteImageFlag () const |
| Control flags... More... | |
| virtual bool | getWriteHistogramFlag () const |
| virtual bool | getWriteOverviewFlag () const |
| virtual bool | getScaleToEightBitFlag () const |
| virtual bool | getWriteEnviHeaderFlag () const |
| virtual bool | getWriteErsHeaderFlag () const |
| virtual bool | getWriteExternalGeometryFlag () const |
| virtual bool | getWriteFgdcFlag () const |
| virtual bool | getWriteJpegWorldFileFlag () const |
| virtual bool | getWriteReadmeFlag () const |
| virtual bool | getWriteTiffWorldFileFlag () const |
| virtual bool | getWriteWorldFileFlag () const |
| virtual void | setWriteImageFlag (bool flag) |
| virtual void | setWriteOverviewFlag (bool flag) |
| virtual void | setWriteHistogramFlag (bool flag) |
| virtual void | setScaleToEightBitFlag (bool flag) |
| virtual void | setWriteEnviHeaderFlag (bool flag) |
| virtual void | setWriteErsHeaderFlag (bool flag) |
| virtual void | setWriteExternalGeometryFlag (bool flag) |
| virtual void | setWriteFgdcFlag (bool flag) |
| virtual void | setWriteJpegWorldFile (bool flag) |
| virtual void | setWriteReadme (bool flag) |
| virtual void | setWriteTiffWorldFile (bool flag) |
| virtual void | setWriteWorldFile (bool flag) |
| virtual ossim_uint16 | getOverviewCompressType () const |
| virtual ossim_int32 | getOverviewJpegCompressQuality () const |
| virtual void | setOverviewCompressType (ossim_uint16 type) |
| virtual void | setOverviewJpegCompressQuality (ossim_int32 quality) |
| Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More... | |
| Overrides base "removeListener". More... | |
| virtual void | setPixelType (ossimPixelType type) |
| If "point" the coordinate tie points are relative to the center of the pixel. More... | |
| virtual void | setPixelType (const ossimString &type) |
| virtual ossimPixelType | getPixelType () const |
| virtual void | getPixelTypeString (ossimString &type) const |
Public Member Functions inherited from ossimImageWriter | |
| ossimImageWriter (ossimObject *owner=NULL) | |
| ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed) | |
| virtual | ~ossimImageWriter () |
| virtual bool | setViewingRect (const ossimIrect &aRect) |
| virtual ossimIrect | getAreaOfInterest () const |
Public Member Functions inherited from ossimOutputSource | |
| ossimOutputSource (ossimObject *owner=NULL) | |
| ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
| virtual | ~ossimOutputSource () |
| virtual bool | open (const ossimString &outputName) |
| virtual const ossimString & | getOutputName () |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Private Member Functions | |
| virtual bool | writeFile () |
| Writes the file to disk or a stream. More... | |
| void | writeHeader (std::ostream *str) |
| Writes header. More... | |
| void | writeCatalog (std::ostream *str, std::vector< std::streamoff > &xref) |
| Writes Catalog object. More... | |
| void | writePages (std::ostream *str, std::vector< std::streamoff > &xref) |
| Writes Outlines object. More... | |
| void | writeInfo (std::ostream *str, std::vector< std::streamoff > &xref) |
| Writes document infomation dictionary. More... | |
| bool | writeImage (std::ostream *str) |
| Writes the image dictionary and associated objects. More... | |
| void | writeJpegTile (std::ostream *str, std::vector< std::streamoff > &xref, ossimImageData *id, const ossimIrect &aoi, ossimIrect &outputTileRect) |
| Write a JPEG-compresses the raster tile buffer to the output stream provided. More... | |
| void | writeRawTile (std::ostream *str, std::vector< std::streamoff > &xref, ossimImageData *id, const ossimIrect &aoi, ossimIrect &outputTileRect) |
| Write raw raster tile buffer to the output stream provided. More... | |
| void | writeXref (std::ostream *str, const std::vector< std::streamoff > &xref) |
| Writes Cross Reference(xref) section. More... | |
| void | writeTrailer (std::ostream *str, ossim_uint32 entrySize, std::streamoff xrefOffset) |
| Writes trailer. More... | |
| void | setupInputChain () |
| Writes "dummy" or blank object just to keep object references in line. More... | |
| ossimPdfImageType | getImageType () const |
| Gets the enumerated value of IMAGE_TYPE_KW lookup. More... | |
| void | getImageType (std::string &type) const |
| Initializes image type from IMAGE_TYPE_KW lookup. More... | |
| void | addOption (const std::string &key, const std::string &value) |
| Adds option to m_kwl with mutex lock. More... | |
| void | getLowerLeftPageOffset (const ossimIrect &aoi, ossimIpt &offset) const |
| Gets the page size. More... | |
| void | getLgiDict (ossimImageGeometry *geom, const ossimIrect &aoi, std::string &s) const |
| Get the LGIDict string. More... | |
| void | getLgiDictProjection (ossimImageGeometry *geom, std::string &s) const |
| Gets projection part of LGIDict string. More... | |
| void | getLgiDictCtm (ossimImageGeometry *geom, const ossimIrect &aoi, std::string &s) const |
| Gets Coordinate Transformation Matrix(CTM) part of LGIDict string from geom. More... | |
| void | getLgiDictDatum (ossimImageGeometry *geom, std::string &s) const |
| Gets datum part of LGIDict string from geom. More... | |
| void | getLgiDictDescription (ossimImageGeometry *geom, std::string &s) const |
| Gets description part of LGIDict string from geom. More... | |
| void | getLgiDictProjectionType (ossimImageGeometry *geom, std::string &s) const |
| Gets neatline part of LGIDict string from geom. More... | |
| ossim_uint32 | getEpsgCode (const ossimImageGeometry *geom) const |
| Gets the EPSG/PCS code from geometry. More... | |
| void | getTitle (std::string &s) const |
| Gets the Title. More... | |
| void | getAuthor (std::string &s) const |
| Gets the Author. More... | |
| void | getSubject (std::string &s) const |
| Gets the Subject. More... | |
| void | getKeywords (std::string &s) const |
| Gets the Keywords. More... | |
| void | getCreator (std::string &s) const |
| Gets the Creator. More... | |
| void | getProducer (std::string &s) const |
| Gets the Producer. More... | |
| void | getCreationDate (std::string &s) const |
| void | getModDate (std::string &s) const |
| void | getGmtDate (std::string &s) const |
| Get's the date in format of: (D:YYYYMMDDHHmmSSZ00'00') More... | |
| void | getTileSize (std::string &s) const |
| Gets tiles size as string. More... | |
| void | getTileSize (ossimIpt &tileSize) const |
| Gets Tile size as integer point. More... | |
| std::string | getTileString (ossim_uint32 x, ossim_uint32 y) const |
Private Attributes | |
| std::ostream * | m_str |
| bool | m_ownsStream |
| ossimRefPtr< ossimConnectableObject > | m_savedInput |
| Holds the origin end of the chain connected to theInputConnection. More... | |
| ossimRefPtr< ossimKeywordlist > | m_kwl |
| Holds all options in key, value pair map. More... | |
| std::mutex | m_mutex |
References:
Adobe PDF Reference sixth edition, Version 1.7 November 2006 pdf_reference_1-7.pdf
PDF Georegistration Encoding Best Practice Version (2.2 OGC 08-139r3) 08-139r3_PDF_Geo-registration_Encoding_Best_Practice_Version_2.2.pdf
Definition at line 45 of file ossimPdfWriter.h.
| Enumerator | |
| UNKNOWN | |
| JPEG | |
| RAW | |
Definition at line 49 of file ossimPdfWriter.h.
| ossimPdfWriter::ossimPdfWriter | ( | ) |
default constructor
virtual destructor
private |
| key | |
| value |
Definition at line 1405 of file ossimPdfWriter.cpp.
References ossimKeywordlist::addPair(), m_kwl, m_mutex, and ossimRefPtr< T >::valid().
Referenced by setProperty().
Closes file.
Implements ossimOutputSource.
Definition at line 1082 of file ossimPdfWriter.cpp.
References m_ownsStream, and m_str.
Referenced by open().
private |
Gets the Author.
Looks in m_kwl for options keyword: "Author"
Defaults to "ossim" if not found.
| s | Initialed by this. |
Definition at line 1761 of file ossimPdfWriter.cpp.
References ossimKeywordlist::findKey(), and m_kwl.
Referenced by getProperty().
private |
Gets the Producer.
Looks in m_kwl for options keyword: "CreationDate"
Defaults to current time if not found.
NOTE: This is a formatted string in the form of: D:YYYYMMDDHHmmSSOHH'mm'
Definition at line 1806 of file ossimPdfWriter.cpp.
References ossimKeywordlist::findKey(), getGmtDate(), and m_kwl.
private |
Gets the Creator.
Looks in m_kwl for options keyword: "Creator"
Definition at line 1784 of file ossimPdfWriter.cpp.
private |
| geom | Image geometry. |
Definition at line 1703 of file ossimPdfWriter.cpp.
References ossimRefPtr< T >::get(), ossimMapProjection::getPcsCode(), ossimImageGeometry::getProjection(), and ossimRefPtr< T >::valid().
| imageType | string representing image type. |
Reimplemented from ossimImageFileWriter.
Definition at line 1102 of file ossimPdfWriter.cpp.
private |
NOTE: Date code is NOT thread safe.
Definition at line 1828 of file ossimPdfWriter.cpp.
Referenced by getCreationDate(), and getModDate().
private |
This is the image type of the stream embedded in the pdf. Default "raw" if not found.
Definition at line 1369 of file ossimPdfWriter.cpp.
References ossimString::downcase(), JPEG, ossimNotify(), ossimNotifyLevel_WARN, RAW, ossimString::string(), and UNKNOWN.
Referenced by getProperty(), and while().
private |
| type | Initialized by this. |
Definition at line 1396 of file ossimPdfWriter.cpp.
References ossimKeywordlist::findKey(), ossimKeywordNames::IMAGE_TYPE_KW, and m_kwl.
Appends this writer image types to list "imageTypeList".
This writer only has one type "pdf".
| imageTypeList | stl::vector<ossimString> list to append to. |
Implements ossimImageFileWriter.
Definition at line 1097 of file ossimPdfWriter.cpp.
private |
Gets the Keywords.
Looks in m_kwl for options keyword: "Keywords"
Default: No default, empty string if not found.
Definition at line 1778 of file ossimPdfWriter.cpp.
private |
| aoi | Area of interest. |
| s | Initialized by this. |
Definition at line 1451 of file ossimPdfWriter.cpp.
References getLgiDictCtm(), getLgiDictDescription(), getLgiDictProjection(), and ossimIrect::hasNans().
private |
| s | Initialized by this or cleared on error. |
Definition at line 1605 of file ossimPdfWriter.cpp.
References ossimRefPtr< T >::get(), ossimImageGeometry::getDegreesPerPixel(), ossimImageGeometry::getProjection(), ossimDpt::hasNans(), ossimMapProjection::isGeographic(), ossim::isnan(), ossimGpt::lat, ossimIrect::ll(), ossimImageGeometry::localToWorld(), ossimGpt::lon, ossimDpt::makeNan(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
Referenced by getLgiDict().
private |
Definition at line 1506 of file ossimPdfWriter.cpp.
References ossimDatum::code(), ossimImageGeometry::getAsMapProjection(), ossimMapProjection::getDatum(), ossimString::string(), and ossimRefPtr< T >::valid().
Referenced by getLgiDictProjection().
private |
Definition at line 1527 of file ossimPdfWriter.cpp.
Referenced by getLgiDict(), and getLgiDictProjection().
private |
Definition at line 1569 of file ossimPdfWriter.cpp.
References getLgiDictDatum(), getLgiDictDescription(), and getLgiDictProjectionType().
private |
| s | Initialized by this or cleared on error. Gets projection type part of LGIDict string from geom. |
Definition at line 1663 of file ossimPdfWriter.cpp.
References ossimRefPtr< T >::get(), ossimImageGeometry::getAsMapProjection(), ossimUtmProjection::getHemisphere(), ossimUtmProjection::getZone(), ossimMapProjection::isGeographic(), and ossimRefPtr< T >::valid().
private |
Gets the page size.
Takes into account image width, height, and annotations.
| width | Width of image. |
| height | Height of image. |
| size | Initialized by this. Gets page offset for image from lower left corner of media box. |
| offset | Initialized by this. |
Definition at line 1432 of file ossimPdfWriter.cpp.
References ossimIrect::hasNans(), ossimIpt::x, and ossimIpt::y.
Referenced by if().
private |
Gets the Producer.
Looks in m_kwl for options keyword: "ModDate"
Definition at line 1817 of file ossimPdfWriter.cpp.
private |
Gets the Producer.
Looks in m_kwl for options keyword: "Producer"
Definition at line 1795 of file ossimPdfWriter.cpp.
| name | Name of property to return. |
Definition at line 1146 of file ossimPdfWriter.cpp.
References ossimRefPtr< T >::get(), getAuthor(), getCreationDate(), getCreator(), getImageType(), getKeywords(), getModDate(), ossimImageFileWriter::getProperty(), getSubject(), getTileSize(), ossimKeywordNames::IMAGE_TYPE_KW, ossimKeywordNames::OUTPUT_TILE_SIZE_KW, ossimString::size(), and ossimString::string().
| propertyNames | array to add this's property names to. |
Definition at line 1249 of file ossimPdfWriter.cpp.
References ossimImageFileWriter::getPropertyNames(), ossimKeywordNames::IMAGE_TYPE_KW, and ossimKeywordNames::OUTPUT_TILE_SIZE_KW.
private |
Gets the Subject.
Looks in m_kwl for options keyword: "Subject"
Definition at line 1772 of file ossimPdfWriter.cpp.
private |
Looks in m_kwl for options keyword: "output_tile_size"
Defaults to 1024 if not found.
Definition at line 1850 of file ossimPdfWriter.cpp.
References ossim::defaultTileSize(), ossimKeywordlist::findKey(), m_kwl, ossimKeywordNames::OUTPUT_TILE_SIZE_KW, ossimString::string(), ossimString::toString(), and ossimIpt::x.
Referenced by getProperty(), and getTileSize().
private |
Defaults to 1024x1024 if not found.
| tileSize | Initialized by this. |
Definition at line 1862 of file ossimPdfWriter.cpp.
References getTileSize(), ossimString::toInt32(), ossimIpt::x, and ossimIpt::y.
private |
Definition at line 1877 of file ossimPdfWriter.cpp.
Referenced by for(), and if().
private |
Gets the Title.
Looks in m_kwl for options keyword: "Title"
Defaults to basename of output file if not found.
Definition at line 1746 of file ossimPdfWriter.cpp.
References ossimFilename::file(), ossimKeywordlist::findKey(), m_kwl, ossimString::size(), ossimString::string(), and ossimImageFileWriter::theFilename.
Definition at line 1107 of file ossimPdfWriter.cpp.
Definition at line 1036 of file ossimPdfWriter.cpp.
References m_str.
Definition at line 1030 of file ossimPdfWriter.cpp.
References ossimImageFileWriter::loadState().
Open method.
Definition at line 1056 of file ossimPdfWriter.cpp.
References ossimString::c_str(), close(), m_ownsStream, m_str, ossimString::size(), and ossimImageFileWriter::theFilename.
Definition at line 1024 of file ossimPdfWriter.cpp.
References ossimImageFileWriter::saveState().
The stream will not be closed/deleted by this object.
| output | The stream to write to. |
Definition at line 1265 of file ossimPdfWriter.cpp.
| property | Object containing property to set. |
Definition at line 1117 of file ossimPdfWriter.cpp.
References addOption(), ossimKeywordNames::IMAGE_TYPE_KW, ossimKeywordNames::OUTPUT_TILE_SIZE_KW, ossimImageFileWriter::setProperty(), ossimRefPtr< T >::valid(), and ossimProperty::valueToString().
private |
| str | Stream to write to. |
| xref | To capture object positions. Sets up input image source. This sets up the chain fed to theInputConnection which is an image source sequencer. This will remap input to eight bit if not already and make input one or three band depending on number of bands. Also sets m_saveInput for reconnection at the end of write. |
Definition at line 1276 of file ossimPdfWriter.cpp.
References ossimRefPtr< T >::get(), ossimConnectableObject::getInput(), ossimImageSource::getNumberOfOutputBands(), ossimImageSourceSequencer::getOutputScalarType(), m_savedInput, OSSIM_UINT8, and ossimImageFileWriter::theInputConnection.
private |
| xref | To capture object positions. |
privatevirtual |
private |
Writes header.
private |
private |
| xrefOffset | Offset to cross reference(xref) table. |
private |
| id | Pointer to tile data. |
| outputTileRect | Initialized by this with output tile rect clamped to aoi. |
Definition at line 721 of file ossimPdfWriter.cpp.
References ossimImageData::getHeight(), ossimImageData::getImageRectangle(), ossimImageData::getOrigin(), ossimImageData::getUcharBuf(), ossimImageData::getWidth(), ossimImageData::initialize(), jpeg_cpp_stream_dest(), ossimIrect::lr(), OSSIM_BIP, OSSIM_UINT8, ossimImageData::setOrigin(), TRUE, ossimIpt::x, and ossimIpt::y.
Referenced by while().
private |
| xref | To capture object positions. Writes Pages object. |
private |
Definition at line 862 of file ossimPdfWriter.cpp.
References ossimImageData::getHeight(), ossimImageData::getImageRectangle(), ossimImageData::getOrigin(), ossimImageData::getSizeInBytes(), ossimImageData::getUcharBuf(), ossimImageData::getWidth(), ossimImageData::initialize(), ossimIrect::lr(), OSSIM_BIP, OSSIM_UINT8, ossimImageData::setOrigin(), ossimIpt::x, and ossimIpt::y.
private |
Writes trailer.
| entrySize | Number of entries, one plus object count. |
Definition at line 974 of file ossimPdfWriter.cpp.
private |
| xref | Array of object offsets. |
Definition at line 942 of file ossimPdfWriter.cpp.
private |
Definition at line 547 of file ossimPdfWriter.h.
Referenced by addOption(), getAuthor(), getCreationDate(), getCreator(), getImageType(), getKeywords(), getModDate(), getProducer(), getSubject(), getTileSize(), and getTitle().
private |
Definition at line 549 of file ossimPdfWriter.h.
Referenced by addOption().
private |
Definition at line 539 of file ossimPdfWriter.h.
Referenced by close(), open(), and setOutputStream().
private |
Definition at line 544 of file ossimPdfWriter.h.
Referenced by setupInputChain().
private |
Definition at line 538 of file ossimPdfWriter.h.
Referenced by close(), isOpen(), open(), and setOutputStream().
