#include <ossimViewController.h>
| ossimViewController () | |
| ossimViewController (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListFixedFlag=true, bool outputListFixedFlag=false) | |
| virtual | ~ossimViewController () |
| virtual bool | propagateView () |
| virtual bool | setView (ossimObject *object) |
| virtual ossimObject * | getView () |
| virtual const ossimObject * | getView () const |
| virtual bool | canConnectMyInputTo (ossim_int32 index, const ossimConnectableObject *obj) const |
| virtual const ossimObject * | findFirstViewOfType (RTTItypeid typeId) const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Protected Attributes | |
| ossimRefPtr< ossimObject > | theView |
Protected Attributes inherited from ossimSource | |
| bool | theEnableFlag |
| bool | theInitializedFlag |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
All view sources will derive from this class. For example we can have a mapped view or Perspective view of the scene being rendered. All sources within the containers are expected to derive from the view interface.
Definition at line 20 of file ossimViewController.h.
| ossimViewController::ossimViewController | ( | ) |
Definition at line 12 of file ossimViewController.cpp.
References theView.
| ossimViewController::ossimViewController | ( | ossimObject * | owner, |
| ossim_uint32 | inputListSize, | ||
| ossim_uint32 | outputListSize, | ||
| bool | inputListFixedFlag = true, |
| bool | outputListFixedFlag = false |
Definition at line 19 of file ossimViewController.cpp.
References theView.
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 49 of file ossimViewController.cpp.
Definition at line 118 of file ossimViewController.cpp.
References RTTItypeid::can_cast(), ossimConnectableContainerInterface::findAllObjectsOfType(), ossimObject::getType(), ossimViewInterface::getView(), PTR_CAST, STATIC_TYPE_INFO, and ossimConnectableObject::theOwner.
Referenced by ossimMapViewController::changeOwner(), and ossimMapViewController::ossimMapViewController().
Reimplemented in ossimMapViewController.
Definition at line 44 of file ossimViewController.cpp.
Definition at line 39 of file ossimViewController.cpp.
Definition at line 108 of file ossimViewController.cpp.
References ossimRefPtr< T >::get(), and theView.
Referenced by ossimMapViewController::saveState().
Definition at line 113 of file ossimViewController.cpp.
Definition at line 55 of file ossimViewController.cpp.
References ossimConnectableContainerInterface::findAllObjectsOfType(), ossimRefPtr< T >::get(), ossimObject::getClassName(), ossimNotify(), ossimNotifyLevel_FATAL, PTR_CAST, ossimViewInterface::setView(), STATIC_TYPE_INFO, ossimConnectableObject::theOwner, and theView.
Referenced by ossimMapViewController::changeOwner().
Definition at line 101 of file ossimViewController.cpp.
References theView.
Referenced by ossimMapViewController::setView().
protected |
Definition at line 46 of file ossimViewController.h.
Referenced by ossimMapViewController::changeOwner(), getView(), ossimMapViewController::ossimMapViewController(), ossimViewController(), propagateView(), setView(), and ~ossimViewController().
