#include <ossimKmlSuperOverlayWriter.h>
| ossimKmlSuperOverlayWriter () | |
| virtual | ~ossimKmlSuperOverlayWriter () |
| virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const |
| void getImageTypeList(std::vector<ossimString>& imageTypeList)const More... | |
| virtual bool | open () |
| virtual void | close () |
| saves the state of the object. More... | |
| Will set the property whose name matches the argument "property->getName()". More... | |
| Pushes this's names onto the list of property names. More... | |
| virtual ossimString | getExtension () const |
| Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More... | |
| bool | hasImageType (const ossimString &imageType) const |
| bool hasImageType(const ossimString& imageType) const More... | |
| virtual bool | writeStream () |
| Method to write the image to a stream. More... | |
Public Member Functions inherited from ossimImageFileWriter | |
| ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0) | |
| The writer will own the sequencer. More... | |
| virtual | ~ossimImageFileWriter () |
| virtual bool | getOutputHasInternalOverviews (void) const |
| Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More... | |
| virtual void | setTileSize (const ossimIpt &tileSize) |
| Sets the output image tiling size if supported by the writer. More... | |
| virtual bool | writeEnviHeaderFile () |
| Will write an envi header file. More... | |
| virtual bool | writeErsHeaderFile () |
| Will write an ER Mapper header file. More... | |
| virtual bool | writeExternalGeometryFile () |
| Will write an external geometry file. More... | |
| virtual bool | writeFgdcFile () |
| Will write an fgdc file. More... | |
| virtual bool | writeHistogramFile () |
| Returns true on success, false on error. More... | |
| virtual bool | writeJpegWorldFile () |
| Will write a jpeg world file. More... | |
| virtual bool | writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false) |
| Write out an ossim overview file from the source_file. More... | |
| virtual bool | writeReadmeFile () |
| Will write a readme file. More... | |
| virtual bool | writeTiffWorldFile () |
| Will write a world file. More... | |
| virtual bool | writeWorldFile () |
| virtual bool | writeMetaDataFiles () |
| Convenience method that calls meta data write methods that are flagged to be called. More... | |
| virtual void | setAreaOfInterest (const ossimIrect &inputRect) |
| virtual void | changeSequencer (ossimImageSourceSequencer *sequencer) |
| Sets the sequencer and connects it to the input of this. More... | |
| virtual ossimImageSourceSequencer * | getSequencer () |
| Initialize method. More... | |
| virtual bool | execute () |
| Calls: writeFile() writeMetaDataFiles() More... | |
| virtual bool | setOutputStream (ossimRefPtr< ossimOStream > stream) |
| Sets the output stream to write to. More... | |
| virtual bool | setOutputStream (std::ostream &str) |
| tmp drb More... | |
| virtual ossimRefPtr< ossimOStream > | getOutputStream () const |
| Method to return the stream attached to output. More... | |
| virtual void | setPercentComplete (double percentComplete) |
| virtual void | setOutputImageType (ossim_int32 type) |
| virtual void | setOutputImageType (const ossimString &type) |
| virtual ossim_int32 | getOutputImageType () const |
| virtual ossimString | getOutputImageTypeString () const |
| virtual void | setOutputName (const ossimString &outputName) |
| virtual void | setFilename (const ossimFilename &file) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | getWriteImageFlag () const |
| Control flags... More... | |
| virtual bool | getWriteHistogramFlag () const |
| virtual bool | getWriteOverviewFlag () const |
| virtual bool | getScaleToEightBitFlag () const |
| virtual bool | getWriteEnviHeaderFlag () const |
| virtual bool | getWriteErsHeaderFlag () const |
| virtual bool | getWriteExternalGeometryFlag () const |
| virtual bool | getWriteFgdcFlag () const |
| virtual bool | getWriteJpegWorldFileFlag () const |
| virtual bool | getWriteReadmeFlag () const |
| virtual bool | getWriteTiffWorldFileFlag () const |
| virtual bool | getWriteWorldFileFlag () const |
| virtual void | setWriteImageFlag (bool flag) |
| virtual void | setWriteOverviewFlag (bool flag) |
| virtual void | setWriteHistogramFlag (bool flag) |
| virtual void | setScaleToEightBitFlag (bool flag) |
| virtual void | setWriteEnviHeaderFlag (bool flag) |
| virtual void | setWriteErsHeaderFlag (bool flag) |
| virtual void | setWriteExternalGeometryFlag (bool flag) |
| virtual void | setWriteFgdcFlag (bool flag) |
| virtual void | setWriteJpegWorldFile (bool flag) |
| virtual void | setWriteReadme (bool flag) |
| virtual void | setWriteTiffWorldFile (bool flag) |
| virtual void | setWriteWorldFile (bool flag) |
| virtual ossim_uint16 | getOverviewCompressType () const |
| virtual ossim_int32 | getOverviewJpegCompressQuality () const |
| virtual void | setOverviewCompressType (ossim_uint16 type) |
| virtual void | setOverviewJpegCompressQuality (ossim_int32 quality) |
| Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More... | |
| Overrides base "removeListener". More... | |
| virtual void | setPixelType (ossimPixelType type) |
| If "point" the coordinate tie points are relative to the center of the pixel. More... | |
| virtual void | setPixelType (const ossimString &type) |
| virtual ossimPixelType | getPixelType () const |
| virtual void | getPixelTypeString (ossimString &type) const |
Public Member Functions inherited from ossimImageWriter | |
| ossimImageWriter (ossimObject *owner=NULL) | |
| ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed) | |
| virtual | ~ossimImageWriter () |
| virtual bool | setViewingRect (const ossimIrect &aRect) |
| virtual ossimIrect | getAreaOfInterest () const |
Public Member Functions inherited from ossimOutputSource | |
| ossimOutputSource (ossimObject *owner=NULL) | |
| ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
| virtual | ~ossimOutputSource () |
| virtual bool | open (const ossimString &outputName) |
| virtual const ossimString & | getOutputName () |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual bool | writeFile () |
| Writes the file to disk or a stream. More... | |
| bool | generateRootKml (ossimString filename, ossim_float64 north, ossim_float64 south, ossim_float64 east, ossim_float64 west, ossim_int32 tilesize) |
| bool | generateChildKml (ossimString filename, ossim_int32 zoom, ossim_int32 yloop, ossim_int32 ix, ossim_int32 iy, ossim_int32 dxsize, ossim_int32 dysize, ossim_int32 xsize, ossim_int32 ysize, ossim_int32 maxzoom, ossimRefPtr< ossimMapProjection > proj, ossimString fileExt) |
| void | generateTile (ossimString filename, ossim_int32 ix, ossim_int32 iy, ossim_int32 dxsize, ossim_int32 dysize) |
| bool | zipWithMinizip (std::vector< ossimString > srcFiles, ossimString srcDirectory, ossimString targetFile) |
| void | propagateViewChange () |
| Sends a view interface visitor to the input connetion. More... | |
Protected Member Functions inherited from ossimImageFileWriter | |
| bool | writeWorldFile (const ossimFilename &file) |
| Common world file writer method. More... | |
Public Types inherited from ossimProcessInterface | |
| enum | ossimProcessStatus { PROCESS_STATUS_UNKNOWN = 0, PROCESS_STATUS_EXECUTING = 1, PROCESS_STATUS_ABORTED = 2, PROCESS_STATUS_ABORT_REQUEST = 3, PROCESS_STATUS_NOT_EXECUTING = 4 } |
Definition at line 32 of file ossimKmlSuperOverlayWriter.h.
| ossimKmlSuperOverlayWriter::ossimKmlSuperOverlayWriter | ( | ) |
default constructor
Definition at line 43 of file ossimKmlSuperOverlayWriter.cpp.
References getShortName(), and ossimImageFileWriter::setOutputImageType().
Generic interface to allow one to close a consumer. For displays this might minimize the window and free up internal pointers for file writers it will make sure the file stream is closed and flushed.
Implements ossimOutputSource.
Definition at line 478 of file ossimKmlSuperOverlayWriter.cpp.
References m_imageWriter, m_mapProjection, and ossimRefPtr< T >::valid().
Referenced by ~ossimKmlSuperOverlayWriter().
protected |
Definition at line 619 of file ossimKmlSuperOverlayWriter.cpp.
References ossimString::c_str(), ossimGpt::lat, ossimMapProjection::lineSampleToWorld(), ossimIrect::ll(), ossimGpt::lon, ossimIrect::lr(), m_mapProjection, ossimGpt::makeNan(), ossimIrect::ul(), ossimIrect::ur(), and ossimRefPtr< T >::valid().
protected |
Definition at line 561 of file ossimKmlSuperOverlayWriter.cpp.
References ossimString::c_str(), ossimFilename::fileNoExtension(), and ossimImageFileWriter::theFilename.
protected |
Definition at line 543 of file ossimKmlSuperOverlayWriter.cpp.
References ossimImageFileWriter::execute(), m_imageWriter, ossimImageFileWriter::setAreaOfInterest(), and ossimImageFileWriter::setFilename().
Definition at line 69 of file ossimKmlSuperOverlayWriter.cpp.
Referenced by zipWithMinizip().
| imageType | string representing image type. |
Reimplemented from ossimImageFileWriter.
Definition at line 495 of file ossimKmlSuperOverlayWriter.cpp.
References ossimString::empty(), ossimFilename::ext(), and ossimImageFileWriter::theFilename.
Appends this writer image types to list "imageTypeList".
This writer has type "kml" or "kmz".
| imageTypeList | stl::vector<ossimString> list to append to. |
Implements ossimImageFileWriter.
Definition at line 490 of file ossimKmlSuperOverlayWriter.cpp.
References getShortName().
Definition at line 64 of file ossimKmlSuperOverlayWriter.cpp.
| name | Name of property to return. |
Definition at line 531 of file ossimKmlSuperOverlayWriter.cpp.
References ossimImageFileWriter::getProperty().
| propertyNames | array to add this's property names to. |
Definition at line 537 of file ossimKmlSuperOverlayWriter.cpp.
References ossimImageFileWriter::getPropertyNames().
Definition at line 59 of file ossimKmlSuperOverlayWriter.cpp.
Referenced by getImageTypeList(), hasImageType(), and ossimKmlSuperOverlayWriter().
Definition at line 504 of file ossimKmlSuperOverlayWriter.cpp.
Definition at line 448 of file ossimKmlSuperOverlayWriter.cpp.
References ossimString::size(), and ossimImageFileWriter::theFilename.
Referenced by writeFile().
Definition at line 442 of file ossimKmlSuperOverlayWriter.cpp.
References ossimImageFileWriter::loadState().
Allows a generic interface to open a consumer for writing. If you are a display writer then you would probably show the window or init the device context for writing.
Definition at line 457 of file ossimKmlSuperOverlayWriter.cpp.
protected |
This will find all view interfaces, set the view, and send a property event to output so that the combiner, if present, can reinitialize.
Definition at line 923 of file ossimKmlSuperOverlayWriter.cpp.
References ossimConnectableObject::accept(), ossimRefPtr< T >::get(), m_mapProjection, ossimImageFileWriter::theInputConnection, ossimRefPtr< T >::valid(), ossimVisitor::VISIT_CHILDREN, and ossimVisitor::VISIT_INPUTS.
Definition at line 436 of file ossimKmlSuperOverlayWriter.cpp.
References ossimImageFileWriter::saveState().
| property | Object containing property to set. |
Definition at line 515 of file ossimKmlSuperOverlayWriter.cpp.
References ossimString::downcase(), ossimRefPtr< T >::get(), ossimProperty::getName(), m_isPngFormat, and ossimImageFileWriter::setProperty().
protectedvirtual |
Definition at line 74 of file ossimKmlSuperOverlayWriter.cpp.
References ossimErrorStatusInterface::getErrorStatus(), ossimImageSourceSequencer::isMaster(), isOpen(), open(), ossimErrorCodes::OSSIM_OK, ossimImageSourceSequencer::setAreaOfInterest(), ossimImageSourceSequencer::setToStartOfSequence(), ossimImageSourceSequencer::slaveProcessTiles(), ossimImageWriter::theAreaOfInterest, ossimImageFileWriter::theInputConnection, ossimRefPtr< T >::valid(), and writeStream().
Definition at line 110 of file ossimKmlSuperOverlayWriter.cpp.
protected |
Definition at line 825 of file ossimKmlSuperOverlayWriter.cpp.
References ossimString::c_str(), ossimString::find(), getClassName(), ossimErrorCodes::OSSIM_ERROR, ossimSetError(), ossimString::size(), and ossimString::string().
protected |
Definition at line 166 of file ossimKmlSuperOverlayWriter.h.
Referenced by close(), and generateTile().
protected |
Definition at line 168 of file ossimKmlSuperOverlayWriter.h.
protected |
Definition at line 169 of file ossimKmlSuperOverlayWriter.h.
Referenced by setProperty().
protected |
Definition at line 167 of file ossimKmlSuperOverlayWriter.h.
Referenced by close(), generateChildKml(), and propagateViewChange().
