#include <ossimOutputSource.h>
| ossimOutputSource (ossimObject *owner=NULL) | |
| ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
| virtual | ~ossimOutputSource () |
| virtual bool | isOpen () const =0 |
| virtual bool | open ()=0 |
| virtual bool | open (const ossimString &outputName) |
| virtual void | setOutputName (const ossimString &outputName) |
| virtual const ossimString & | getOutputName () |
| virtual void | close ()=0 |
| virtual | ~ossimSource () |
| virtual bool | canConnectMyInputTo (ossim_int32 myInputIndex, const ossimConnectableObject *object) const =0 |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Protected Attributes | |
| ossimString | theOutputName |
Protected Attributes inherited from ossimSource | |
| bool | theEnableFlag |
| bool | theInitializedFlag |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
Definition at line 19 of file ossimOutputSource.h.
inline |
Definition at line 22 of file ossimOutputSource.h.
inline |
Definition at line 25 of file ossimOutputSource.h.
inlinevirtual |
Definition at line 38 of file ossimOutputSource.h.
pure virtual |
Generic interface to allow one to close a consumer. For displays this might minimize the window and free up internal pointers for file writers it will make sure the file stream is closed and flushed.
Implemented in ossimGpkgWriter, ossimBitMaskWriter, ossimPdfWriter, ossimWriter, ossimVertexExtractor, ossimPngWriter, ossimKmlSuperOverlayWriter, ossimOpjJp2Writer, ossimTiffWriter, ossimGeneralRasterWriter, ossimHistogramWriter, ossimGdalWriter, ossimKakaduNitfWriter, ossimKakaduJp2Writer, ossimJpegWriter, ossimNitfWriter, ossimNitf20Writer, and ossimArcInfoGridWriter.
inlinevirtual |
Definition at line 69 of file ossimOutputSource.h.
pure virtual |
Implemented in ossimGpkgWriter, ossimBitMaskWriter, ossimPdfWriter, ossimWriter, ossimVertexExtractor, ossimPngWriter, ossimTiffWriter, ossimKmlSuperOverlayWriter, ossimOpjJp2Writer, ossimGeneralRasterWriter, ossimGdalWriter, ossimKakaduNitfWriter, ossimKakaduJp2Writer, ossimJpegWriter, ossimHistogramWriter, ossimNitfWriter, ossimNitf20Writer, and ossimArcInfoGridWriter.
Reimplemented in ossimImageFileWriter, ossimWriter, ossimPdfWriter, ossimTiffWriter, ossimNitfWriterBase, ossimGpkgWriter, ossimBitMaskWriter, ossimNitfWriter, ossimNitf20Writer, ossimPngWriter, ossimKmlSuperOverlayWriter, ossimOpjJp2Writer, ossimHistogramWriter, ossimGeneralRasterWriter, ossimGdalWriter, ossimKakaduNitfWriter, ossimKakaduJp2Writer, ossimJpegWriter, ossimImageWriter, and ossimArcInfoGridWriter.
Definition at line 11 of file ossimOutputSource.cpp.
References ossimSource::loadState().
Referenced by ossimImageWriter::loadState(), and ossimHistogramWriter::loadState().
pure virtual |
Allows a generic interface to open a consumer for writing. If you are a display writer then you would probably show the window or init the device context for writing.
Implemented in ossimGpkgWriter, ossimBitMaskWriter, ossimPdfWriter, ossimWriter, ossimVertexExtractor, ossimPngWriter, ossimKmlSuperOverlayWriter, ossimOpjJp2Writer, ossimTiffWriter, ossimGeneralRasterWriter, ossimGdalWriter, ossimHistogramWriter, ossimKakaduNitfWriter, ossimKakaduJp2Writer, ossimJpegWriter, ossimNitfWriter, ossimNitf20Writer, and ossimArcInfoGridWriter.
Referenced by ossimHistogramWriter::open(), and ossimImageFileWriter::writeHistogramFile().
inlinevirtual |
Will set the output name and open the output device.
Definition at line 52 of file ossimOutputSource.h.
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Reimplemented in ossimImageFileWriter, ossimWriter, ossimPdfWriter, ossimTiffWriter, ossimGpkgWriter, ossimNitfWriterBase, ossimNitfWriter, ossimNitf20Writer, ossimPngWriter, ossimKmlSuperOverlayWriter, ossimOpjJp2Writer, ossimHistogramWriter, ossimGeneralRasterWriter, ossimGdalWriter, ossimKakaduNitfWriter, ossimImageWriter, ossimKakaduJp2Writer, ossimJpegWriter, and ossimArcInfoGridWriter.
Definition at line 5 of file ossimOutputSource.cpp.
References ossimSource::saveState().
Referenced by ossimImageWriter::saveState(), and ossimHistogramWriter::saveState().
inlinevirtual |
This is a generic interface to allow one to set the output name of the writer. If its a Visual display this could be used to set the title. If this is a file output then this could be a directory or a file name.
Reimplemented in ossimImageFileWriter, ossimHistogramWriter, ossimVertexExtractor, and ossimImageDisplayWriter.
Definition at line 64 of file ossimOutputSource.h.
Referenced by ossimVertexExtractor::setOutputName(), ossimHistogramWriter::setOutputName(), and ossimImageFileWriter::setOutputName().
protected |
Definition at line 88 of file ossimOutputSource.h.
Referenced by ossimBitMaskWriter::close(), ossimBitMaskWriter::connectMyInputTo(), and ossimBitMaskWriter::loadState().
