OSSIM nitf writer base class to hold methods common to all nitf writers. More...
#include <ossimNitfWriterBase.h>
| ossimNitfWriterBase () | |
| ossimNitfWriterBase (const ossimFilename &filename, ossimImageSource *inputSource) | |
| Constructor that takes filename and input source. More... | |
| virtual | ~ossimNitfWriterBase () |
| Set the properties. More... | |
| Gets a property. More... | |
| Saves the state of the writer to kwl with prefix then calls base class ossimImageFileWriter::saveState. More... | |
| Initializes the state of the writer from kwl with prefix then calls base class ossimImageFileWriter::loadState. More... | |
| virtual ossimString | getExtension () const |
| Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More... | |
| virtual void | addRegisteredTag (ossimRefPtr< ossimNitfRegisteredTag > registeredTag) |
| virtual void | addRegisteredTag (ossimRefPtr< ossimNitfRegisteredTag > registeredTag, bool unique) |
| virtual void | addRegisteredTag (ossimRefPtr< ossimNitfRegisteredTag > registeredTag, bool unique, const ossim_uint32 &ownerIndex, const ossimString &tagType) |
| virtual void | setFileHeaderV2_1 (ossimRefPtr< ossimNitfFileHeaderV2_1 >, bool preferSource=false) |
| virtual void | setImageHeaderV2_1 (ossimRefPtr< ossimNitfImageHeaderV2_1 >, bool preferSource=false) |
Public Member Functions inherited from ossimImageFileWriter | |
| ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0) | |
| The writer will own the sequencer. More... | |
| virtual | ~ossimImageFileWriter () |
| virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const =0 |
| void getImageTypeList(std::vector<ossimString>& imageTypeList)const More... | |
| virtual bool | getOutputHasInternalOverviews (void) const |
| Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More... | |
| virtual bool | hasImageType (const ossimString &imageType) const |
| bool hasImageType(const ossimString& imageType) const More... | |
| virtual void | setTileSize (const ossimIpt &tileSize) |
| Sets the output image tiling size if supported by the writer. More... | |
| virtual bool | writeEnviHeaderFile () |
| Will write an envi header file. More... | |
| virtual bool | writeErsHeaderFile () |
| Will write an ER Mapper header file. More... | |
| virtual bool | writeExternalGeometryFile () |
| Will write an external geometry file. More... | |
| virtual bool | writeFgdcFile () |
| Will write an fgdc file. More... | |
| virtual bool | writeHistogramFile () |
| Returns true on success, false on error. More... | |
| virtual bool | writeJpegWorldFile () |
| Will write a jpeg world file. More... | |
| virtual bool | writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false) |
| Write out an ossim overview file from the source_file. More... | |
| virtual bool | writeReadmeFile () |
| Will write a readme file. More... | |
| virtual bool | writeTiffWorldFile () |
| Will write a world file. More... | |
| virtual bool | writeWorldFile () |
| virtual bool | writeMetaDataFiles () |
| Convenience method that calls meta data write methods that are flagged to be called. More... | |
| virtual void | setAreaOfInterest (const ossimIrect &inputRect) |
| virtual void | changeSequencer (ossimImageSourceSequencer *sequencer) |
| Sets the sequencer and connects it to the input of this. More... | |
| virtual ossimImageSourceSequencer * | getSequencer () |
| Initialize method. More... | |
| virtual bool | execute () |
| Calls: writeFile() writeMetaDataFiles() More... | |
| virtual bool | writeStream () |
| Method to write the image to a stream. More... | |
| virtual bool | setOutputStream (ossimRefPtr< ossimOStream > stream) |
| Sets the output stream to write to. More... | |
| virtual bool | setOutputStream (std::ostream &str) |
| tmp drb More... | |
| virtual ossimRefPtr< ossimOStream > | getOutputStream () const |
| Method to return the stream attached to output. More... | |
| virtual void | setPercentComplete (double percentComplete) |
| virtual void | setOutputImageType (ossim_int32 type) |
| virtual void | setOutputImageType (const ossimString &type) |
| virtual ossim_int32 | getOutputImageType () const |
| virtual ossimString | getOutputImageTypeString () const |
| virtual void | setOutputName (const ossimString &outputName) |
| virtual void | setFilename (const ossimFilename &file) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | getWriteImageFlag () const |
| Control flags... More... | |
| virtual bool | getWriteHistogramFlag () const |
| virtual bool | getWriteOverviewFlag () const |
| virtual bool | getScaleToEightBitFlag () const |
| virtual bool | getWriteEnviHeaderFlag () const |
| virtual bool | getWriteErsHeaderFlag () const |
| virtual bool | getWriteExternalGeometryFlag () const |
| virtual bool | getWriteFgdcFlag () const |
| virtual bool | getWriteJpegWorldFileFlag () const |
| virtual bool | getWriteReadmeFlag () const |
| virtual bool | getWriteTiffWorldFileFlag () const |
| virtual bool | getWriteWorldFileFlag () const |
| virtual void | setWriteImageFlag (bool flag) |
| virtual void | setWriteOverviewFlag (bool flag) |
| virtual void | setWriteHistogramFlag (bool flag) |
| virtual void | setScaleToEightBitFlag (bool flag) |
| virtual void | setWriteEnviHeaderFlag (bool flag) |
| virtual void | setWriteErsHeaderFlag (bool flag) |
| virtual void | setWriteExternalGeometryFlag (bool flag) |
| virtual void | setWriteFgdcFlag (bool flag) |
| virtual void | setWriteJpegWorldFile (bool flag) |
| virtual void | setWriteReadme (bool flag) |
| virtual void | setWriteTiffWorldFile (bool flag) |
| virtual void | setWriteWorldFile (bool flag) |
| virtual ossim_uint16 | getOverviewCompressType () const |
| virtual ossim_int32 | getOverviewJpegCompressQuality () const |
| virtual void | setOverviewCompressType (ossim_uint16 type) |
| virtual void | setOverviewJpegCompressQuality (ossim_int32 quality) |
| Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More... | |
| Overrides base "removeListener". More... | |
| virtual void | setPixelType (ossimPixelType type) |
| If "point" the coordinate tie points are relative to the center of the pixel. More... | |
| virtual void | setPixelType (const ossimString &type) |
| virtual ossimPixelType | getPixelType () const |
| virtual void | getPixelTypeString (ossimString &type) const |
Public Member Functions inherited from ossimImageWriter | |
| ossimImageWriter (ossimObject *owner=NULL) | |
| ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed) | |
| virtual | ~ossimImageWriter () |
| virtual bool | setViewingRect (const ossimIrect &aRect) |
| virtual ossimIrect | getAreaOfInterest () const |
Public Member Functions inherited from ossimOutputSource | |
| ossimOutputSource (ossimObject *owner=NULL) | |
| ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
| virtual | ~ossimOutputSource () |
| virtual bool | isOpen () const =0 |
| virtual bool | open ()=0 |
| virtual bool | open (const ossimString &outputName) |
| virtual const ossimString & | getOutputName () |
| virtual void | close ()=0 |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| void | writeGeometry (ossimNitfImageHeaderV2_X *hdr, ossimImageSourceSequencer *seq) |
| Populates tags with geometry info from projection. More... | |
| void | addBlockaTag (ossimMapProjectionInfo &mapInfo, ossimNitfImageHeaderV2_X *hdr) |
| Adds the BLOCKA tag. More... | |
| void | addGeolobTag (const ossimMapProjection *mapProj, ossimNitfImageHeaderV2_X *hdr) |
| Adds the GEOLOB tag. More... | |
| void | addRpcbTag (const ossimIrect &rect, ossimProjection *proj, ossimNitfImageHeaderV2_X *hdr) |
| Adds the RPC00B tag. More... | |
| void | setComplexityLevel (std::streamoff, ossimNitfFileHeaderV2_X *hdr) |
| Sets the complexity level of theFileHeader. More... | |
| void | setComplexityLevel (ossimNitfFileHeaderV2_X *hdr, ossim_uint64 width=0, ossim_uint64 height=0) |
| virtual void | initializeDefaultsFromConfigFile (ossimNitfFileHeaderV2_X *fileHdr, ossimNitfImageHeaderV2_X *imgHdr) |
| Sets file header and image header defaults from config file if found in preferences. More... | |
Protected Member Functions inherited from ossimImageFileWriter | |
| bool | writeWorldFile (const ossimFilename &file) |
| Common world file writer method. More... | |
| virtual bool | writeFile ()=0 |
| Write out the file. More... | |
Public Types inherited from ossimProcessInterface | |
| enum | ossimProcessStatus { PROCESS_STATUS_UNKNOWN = 0, PROCESS_STATUS_EXECUTING = 1, PROCESS_STATUS_ABORTED = 2, PROCESS_STATUS_ABORT_REQUEST = 3, PROCESS_STATUS_NOT_EXECUTING = 4 } |
Definition at line 31 of file ossimNitfWriterBase.h.
| ossimNitfWriterBase::ossimNitfWriterBase | ( | ) |
default constructor
Definition at line 46 of file ossimNitfWriterBase.cpp.
| ossimNitfWriterBase::ossimNitfWriterBase | ( | const ossimFilename & | filename, |
| ossimImageSource * | inputSource | ||
| filename | The output file name. |
| inputSource | The input source to write to file. |
Definition at line 54 of file ossimNitfWriterBase.cpp.
Definition at line 63 of file ossimNitfWriterBase.cpp.
protected |
| mapInfo | ossimMapProjectionInfo to use to set tag with. |
| hdr | The header to write to. |
Definition at line 250 of file ossimNitfWriterBase.cpp.
References ossimMapProjectionInfo::getPixelType(), ossimMapProjectionInfo::linesPerImage(), ossimMapProjectionInfo::llGroundPt(), ossimMapProjectionInfo::lrGroundPt(), OSSIM_PIXEL_IS_AREA, ossimNitfBlockaTag::setBlockInstance(), ossimNitfBlockaTag::setFrfcLoc(), ossimNitfBlockaTag::setFrlcLoc(), ossimNitfBlockaTag::setLLines(), ossimNitfBlockaTag::setLrfcLoc(), ossimNitfBlockaTag::setLrlcLoc(), ossimMapProjectionInfo::setPixelType(), ossimMapProjectionInfo::ulGroundPt(), and ossimMapProjectionInfo::urGroundPt().
Referenced by writeGeometry().
protected |
This will only be added if projection is geographic.
Definition at line 301 of file ossimNitfWriterBase.cpp.
References ossimNitfImageHeader::addTag(), ossimRefPtr< T >::get(), ossimMapProjection::getDecimalDegreesPerPixel(), ossimMapProjection::getUlGpt(), ossimDpt::hasNans(), ossimGpt::hasNans(), ossimMapProjection::isGeographic(), ossimGpt::lat, ossimGpt::lon, ossimNitfGeolobTag::setDegreesPerPixelLat(), ossimNitfGeolobTag::setDegreesPerPixelLon(), ossimNitfGeolobTag::setLso(), ossimNitfGeolobTag::setPso(), true, ossimDpt::x, and ossimDpt::y.
Reimplemented in ossimNitf20Writer.
Definition at line 442 of file ossimNitfWriterBase.cpp.
Reimplemented in ossimNitfWriter.
Definition at line 446 of file ossimNitfWriterBase.cpp.
Definition at line 450 of file ossimNitfWriterBase.cpp.
protected |
| rect | Requested rectangle of image to write. |
| proj | The output projection. |
Definition at line 347 of file ossimNitfWriterBase.cpp.
References ossimNitfImageHeader::addTag(), ossimRpcSolver::getNitfRpcBTag(), PTR_CAST, and ossimRpcSolver::solveCoefficients().
| imageType | string representing image type. |
Reimplemented from ossimImageFileWriter.
Reimplemented in ossimKakaduNitfWriter.
Definition at line 437 of file ossimNitfWriterBase.cpp.
Gets a property.
| The | name of the property to get. |
Reimplemented in ossimKakaduNitfWriter, ossimNitfWriter, and ossimNitf20Writer.
Definition at line 92 of file ossimNitfWriterBase.cpp.
Referenced by ossimNitfWriter::getProperty(), and ossimKakaduNitfWriter::getProperty().
| propertyNames | Array to populate with property names. |
Definition at line 117 of file ossimNitfWriterBase.cpp.
References ossimImageFileWriter::getPropertyNames().
Referenced by ossimNitfWriter::getPropertyNames(), and ossimKakaduNitfWriter::getPropertyNames().
protectedvirtual |
Definition at line 462 of file ossimNitfWriterBase.cpp.
References ossimKeywordlist::addFile(), ossimPreferences::instance(), ossimNitfFileHeaderV2_X::loadState(), and ossimNitfImageHeaderV2_X::loadState().
Referenced by ossimNitf20Writer::ossimNitf20Writer(), and ossimNitfWriter::ossimNitfWriter().
| kwl | Keyword list to initialize from. |
| prefix | Usually something like: "object2." |
Keywords picked up by loadState:
enable_rpcb_tag: true
enable_blocka_tag: true
Reimplemented in ossimNitfWriter, ossimNitf20Writer, and ossimKakaduNitfWriter.
Definition at line 138 of file ossimNitfWriterBase.cpp.
References ossimKeywordlist::find().
Referenced by ossimKakaduNitfWriter::loadState(), ossimNitf20Writer::loadState(), and ossimNitfWriter::loadState().
| kwl | Keyword list to save to. |
Keywords saved by saveState:
Definition at line 128 of file ossimNitfWriterBase.cpp.
References ossimKeywordlist::add().
Referenced by ossimKakaduNitfWriter::saveState(), ossimNitf20Writer::saveState(), and ossimNitfWriter::saveState().
protected |
| endPosition | This should be the end seek position of the file. |
Definition at line 388 of file ossimNitfWriterBase.cpp.
Referenced by ossimNitf20Writer::writeBlockBandSeparate(), ossimNitfWriter::writeBlockBandSeparate(), ossimNitf20Writer::writeBlockBandSequential(), and ossimNitfWriter::writeBlockBandSequential().
protected |
Definition at line 423 of file ossimNitfWriterBase.cpp.
References max, and ossimNitfFileHeaderV2_X::setComplexityLevel().
Definition at line 454 of file ossimNitfWriterBase.cpp.
Definition at line 458 of file ossimNitfWriterBase.cpp.
Set the properties.
| property | The property to set. |
Definition at line 67 of file ossimNitfWriterBase.cpp.
References ossimRefPtr< T >::valid().
Referenced by ossimNitfWriter::setProperty(), and ossimKakaduNitfWriter::setProperty().
protected |
Will write an rpcb tag if theEnableRpcbTagFlag if set to true.
| seq | The input connection or image source. |
Definition at line 170 of file ossimNitfWriterBase.cpp.
References addBlockaTag(), addGeolobTag(), addRpcbTag(), ossimImageSourceSequencer::getBoundingRect(), ossimImageGeometry::getCornerGpts(), ossimUtmProjection::getHemisphere(), ossimImageSource::getImageGeometry(), ossimImageGeometry::getProjection(), ossimUtmProjection::getZone(), ossimImageGeometry::hasProjection(), ossimMapProjectionInfo::llEastingNorthingPt(), ossimMapProjectionInfo::llGroundPt(), ossimMapProjectionInfo::lrEastingNorthingPt(), ossimMapProjectionInfo::lrGroundPt(), OSSIM_PIXEL_IS_AREA, PTR_CAST, ossimNitfImageHeaderV2_X::setGeographicLocationDms(), ossimMapProjectionInfo::setPixelType(), ossimNitfImageHeaderV2_X::setUtmNorth(), ossimNitfImageHeaderV2_X::setUtmSouth(), status, theEnableBlockaTagFlag, theEnableGeolobTagFlag, theEnableRpcbTagFlag, ossimImageFileWriter::theInputConnection, ossimMapProjectionInfo::ulEastingNorthingPt(), ossimMapProjectionInfo::ulGroundPt(), ossimMapProjectionInfo::urEastingNorthingPt(), ossimMapProjectionInfo::urGroundPt(), and ossimRefPtr< T >::valid().
protected |
If true user wants to set BLOCKA tag.
(DEFAULT = true) Currently only valid for map projected images.
Definition at line 197 of file ossimNitfWriterBase.h.
protected |
If true user wants to set GEOLOG tag.
(DEFAULT = true) This will only be set if a geographic projection.
Definition at line 203 of file ossimNitfWriterBase.h.
protected |
If true user wants to set RPC00B tag.
(DEFAULT = false)
Definition at line 191 of file ossimNitfWriterBase.h.
