Namespaces | |
| ossim | |
Classes | |
| class | AlosPalsarData |
| This class is able to read the Leader file of the AlosPalsar file structure. More... | |
| class | AlosPalsarDataFileDescriptor |
| This class is able to read the SAR leader file descriptor record of the leader file. More... | |
| class | AlosPalsarDataSetSummary |
| This class is able to read the SAR leader data set summary record of the leader file. More... | |
| class | AlosPalsarFacilityData |
| class | AlosPalsarFileDescriptor |
| class | AlosPalsarLeader |
| class | AlosPalsarLeaderFactory |
| This class is a facory able to construct Record base classes. More... | |
| class | AlosPalsarMapProjectionData |
| class | AlosPalsarPlatformPositionData |
| This class is able to read a Platform position data record. More... | |
| class | AlosPalsarPositionVectorRecord |
| This class is able to read a position vector record. More... | |
| class | AlosPalsarRadiometricData |
| This class is able to read a radiometric data record. More... | |
| class | AlosPalsarRecord |
| This class is the base class of all the record classes. More... | |
| class | AlosPalsarRecordFactory |
| This class is a facory able to construct Record base classes given the id of the record wanted. More... | |
| class | AlosPalsarRecordHeader |
| This class is able to read a record header. More... | |
| class | AlosPalsarSignalData |
| This class is able to read the header of the Signal Data Records of the image file. More... | |
| class | AntennaElevationPatterns |
| This class is able to read the ASAR AntennaElevationPatterns record. More... | |
| class | AttitudeData |
| This class is able to read a Attitude data record. More... | |
| class | BeamInformationRecord |
| This class is able to read a Beam information record. More... | |
| class | BeamPixelCountRecord |
| This class is able to read a Beam pixel count record. More... | |
| class | ChirpParameters |
| This class is able to read the ASAR ChirpParameters record. More... | |
| class | CivilDateTime |
| This class represents a date and time in the civil format. More... | |
| class | CompensationDataRecord |
| This class is able to read a Compensation data record. More... | |
| class | Coordinate |
| This class represents a coordinate. More... | |
| class | Data |
| This class is able to read the data file of the RadarSat file structure. More... | |
| class | DataFactory |
| This class is a factory able to construct Record base classes. More... | |
| class | DataHistogramProcessedData |
| This class is able to read a data histogram record - Processed data. More... | |
| class | DataHistogramRecord |
| This class is able to read a data histogram record. More... | |
| class | DataHistogramSignalData |
| This class is able to read a data histogram record - Signal data. More... | |
| class | DataPointDataRecord |
| This class is able to read a Data point data record. More... | |
| class | DataQuality |
| This class is able to read a data quality record. More... | |
| class | DataSetSummary |
| class | DopplerCentroidEstimateRecord |
| This class is able to read a Doppler centroid estimates record. More... | |
| class | DopplerCentroidParameters |
| This class is able to read the ASAR DopplerCentroidParameters record. More... | |
| class | dsd |
| This class is able to read the ASAR dsd record. More... | |
| class | EnvisatAsarData |
| This class is able to read the Envisat file structure. More... | |
| class | EnvisatAsarDataFactory |
| class | EnvisatAsarRecord |
| This class is the base class of all the Envisat ASAR record classes. More... | |
| class | EnvisatAsarRecordFactory |
| This class is a factory able to construct Record base classes given the id of the record wanted. More... | |
| class | Ephemeris |
| This class represents an ephemeris. More... | |
| class | Equation |
| This class manages and solves an equation of the fourth degree. More... | |
| class | ErsSarDataSetSummary |
| class | ErsSarFacilityData |
| class | ErsSarFileDescriptor |
| class | ErsSarLeader |
| This class is able to read the Leader file of the ErsSar file structure. More... | |
| class | ErsSarLeaderFactory |
| class | ErsSarMapProjectionData |
| class | ErsSarPlatformPositionData |
| class | ErsSarPositionVectorRecord |
| class | ErsSarRecord |
| class | ErsSarRecordFactory |
| class | ErsSarRecordHeader |
| class | FileDescriptor |
| class | FilePointerRecord |
| class | GalileanEphemeris |
| This class represents an ephemeris in Galilean coordinates system. More... | |
| class | GeodesicCoordinate |
| This class represents a coordinate in a geodesic reference. More... | |
| class | GeographicEphemeris |
| This class represent an ephemeris in Geographic coordinates system. More... | |
| class | GeolocationGrid |
| This class is able to read the ASAR GeolocationGrid record. More... | |
| class | GMSTDateTime |
| This class represents a date. More... | |
| class | HermiteInterpolator |
| Abstract interpolator. More... | |
| class | ImageNoise |
| This class represents an ImageNoise. More... | |
| class | ImageOptionsFileDescriptor |
| This class is able to read an Image options file descriptor record. More... | |
| class | IncidenceAngles |
| This class represents Incidence Angles. More... | |
| class | InfoIncidenceAngle |
| This class represents an InfoIncidenceAngle. More... | |
| class | InfoSceneCoord |
| This class represents an InfoSceneCoord. More... | |
| class | JSDDateTime |
| class | JulianDate |
| This class represents a date in the julian referential. More... | |
| class | Leader |
| This class is able to read the leader file of the RadarSat file structure. More... | |
| class | LeaderFactory |
| class | MainProcessingParameters |
| This class is able to read the ASAR MainProcessingParameters record. More... | |
| class | MisregistrationRecord |
| This class is able to read a misregistration record. More... | |
| class | MJDDateTime |
| This class represents an MJD date (Modified Julian date) More... | |
| class | mph |
| This class is able to read the ASAR mph record of the leader file. More... | |
| class | Noise |
| This class represents an Noise. More... | |
| class | ossimAlosPalsarModel |
| This class is able to direct localisation and indirect localisation using the AlosPalsar sensor model. More... | |
| class | ossimCosmoSkymedModel |
| This class allows for direct localisation and indirect localisation using the CosmoSkymed sensor model. More... | |
| class | ossimEnvisatAsarModel |
| This class is able to direct localisation and indirect localisation using the EnvisatAsar sensor model. More... | |
| class | ossimErsSarModel |
| This class is able to direct localisation and indirect localisation using the ErsSar sensor model. More... | |
| class | ossimFormosatModel |
| class | ossimGeometricSarSensorModel |
| This class allows for direct localisation and indirect localisation using the geometric model of SAR sensors. More... | |
| class | ossimPleiadesDimapSupportData |
| class | ossimPleiadesModel |
| class | ossimPluginProjectionFactory |
| class | ossimPluginReaderFactory |
| Image handler factory for ossim plugins plugin. More... | |
| class | ossimRadarSat2Model |
| This class allows for direct localisation and indirect localisation using the RadarSat2 sensor model. More... | |
| class | ossimRadarSat2ProductDoc |
| Class to encapsulate parsing RadarSat2 product.xml file. More... | |
| class | ossimRadarSat2RPCModel |
| class | ossimRadarSat2TiffReader |
| class | ossimRadarSatModel |
| This class is able to direct localisation and indirect localisation using the RadarSat sensor model. More... | |
| class | ossimSpot6DimapSupportData |
| class | ossimSpot6Model |
| class | ossimTerraSarModel |
| This class allows for direct localisation and indirect localisation using the TerraSar sensor model. More... | |
| class | ossimTerraSarProductDoc |
| Class to encapsulate parsing TerraSAR product xml file. More... | |
| class | ossimTerraSarTiffReader |
| class | ossimTileMapModel |
| class | PlatformPosition |
| This class handles the platform position. More... | |
| class | PlatformPositionData |
| class | PositionVectorRecord |
| class | ProcessedDataRecord |
| This class is able to read an Processed Data Record. More... | |
| class | ProcessingParameters |
| This class is able to read a Detailed processing parameters record. More... | |
| class | RadarSat2NoiseLevel |
| class | RadarSatRecord |
| class | RadarSatRecordFactory |
| This class is a factory able to construct Record base classes given the id of the wanted record. More... | |
| class | RadarSatRecordHeader |
| class | RadiometricCompensationData |
| This class is able to read a Radiometric Compensation data record. More... | |
| class | RadiometricData |
| class | RadiometryUncertaintyRecord |
| This class is able to read a radiometry uncertainty record. More... | |
| class | RectangularCoordinate |
| This class represents a coordinate in a rectangular reference. More... | |
| class | RefPoint |
| This class handles the referential point. More... | |
| class | SarSensor |
| This class provides basic location services for SAR sensors. More... | |
| class | SceneCoord |
| This class represents Scence coordinate. More... | |
| class | Sensor |
| This class provides basic location services. More... | |
| class | SensorParams |
| This class handles the sensor parameters. More... | |
| class | sph |
| This class is able to read the SAR sph record of the ASAR file. More... | |
| class | SQ_ADSR |
| This class is able to read the ASAR SQ_ADSR record. More... | |
| class | SRGRCoefficientSetRecord |
| This class is able to read a SRGR coefficients set record. More... | |
| class | SRGRConversionParameters |
| This class is able to read the ASAR SRGRConversionParameters record. More... | |
| class | TemperatureSettingsRecord |
| This class is able to read a Temperature Settings record. More... | |
| class | TextRecord |
| This class is able to read the Text record of the volume directory file. More... | |
| class | Trailer |
| This class is able to read the trailer file of the RadarSat file structure. More... | |
| class | TrailerFactory |
| class | VolumeDescriptorRecord |
| class | VolumeDir |
| This class is able to read the volume directory file of the RadarSat file structure. More... | |
| class | VolumeDirFactory |
Typedefs | |
| typedef DataHistogramSignalData | DataHistogramProcessedData8 |
| typedef FilePointerRecord | SARLeaderFilePointerRecord |
| typedef FilePointerRecord | ImageOptionsFilePointerRecord |
| typedef FilePointerRecord | SARTrailerFilePointerRecord |
Functions | |
| std::ostream & | operator<< (std::ostream &os, const AlosPalsarData &data) |
| std::istream & | operator>> (std::istream &is, AlosPalsarData &data) |
| std::ostream & | operator<< (std::ostream &os, const AlosPalsarDataFileDescriptor &data) |
| std::istream & | operator>> (std::istream &is, AlosPalsarDataFileDescriptor &data) |
| std::ostream & | operator<< (std::ostream &os, const AlosPalsarDataSetSummary &data) |
| std::istream & | operator>> (std::istream &is, AlosPalsarDataSetSummary &data) |
| std::ostream & | operator<< (std::ostream &os, const AlosPalsarFacilityData &data) |
| std::istream & | operator>> (std::istream &is, AlosPalsarFacilityData &data) |
| std::ostream & | operator<< (std::ostream &os, const AlosPalsarFileDescriptor &data) |
| std::istream & | operator>> (std::istream &is, AlosPalsarFileDescriptor &data) |
| std::ostream & | operator<< (std::ostream &os, const AlosPalsarLeader &data) |
| std::istream & | operator>> (std::istream &is, AlosPalsarLeader &data) |
| std::ostream & | operator<< (std::ostream &os, const AlosPalsarMapProjectionData &data) |
| std::istream & | operator>> (std::istream &is, AlosPalsarMapProjectionData &data) |
| std::ostream & | operator<< (std::ostream &os, const AlosPalsarPlatformPositionData &data) |
| std::istream & | operator>> (std::istream &is, AlosPalsarPlatformPositionData &data) |
| std::ostream & | operator<< (std::ostream &os, const AlosPalsarPositionVectorRecord &data) |
| std::istream & | operator>> (std::istream &is, AlosPalsarPositionVectorRecord &data) |
| std::ostream & | operator<< (std::ostream &os, const AlosPalsarRadiometricData &data) |
| std::istream & | operator>> (std::istream &is, AlosPalsarRadiometricData &data) |
| std::ostream & | operator<< (std::ostream &os, const AlosPalsarRecordHeader &data) |
| std::istream & | operator>> (std::istream &is, AlosPalsarRecordHeader &data) |
| std::ostream & | operator<< (std::ostream &os, const AlosPalsarSignalData &data) |
| std::istream & | operator>> (std::istream &is, AlosPalsarSignalData &data) |
| std::ostream & | operator<< (std::ostream &os, const AntennaElevationPatterns &data) |
| std::istream & | operator>> (std::istream &is, AntennaElevationPatterns &data) |
| std::ostream & | operator<< (std::ostream &os, const ChirpParameters &data) |
| std::istream & | operator>> (std::istream &is, ChirpParameters &data) |
| std::ostream & | operator<< (std::ostream &os, const DopplerCentroidParameters &data) |
| std::istream & | operator>> (std::istream &is, DopplerCentroidParameters &data) |
| std::ostream & | operator<< (std::ostream &os, const dsd &data) |
| std::istream & | operator>> (std::istream &is, dsd &data) |
| std::ostream & | operator<< (std::ostream &os, const EnvisatAsarData &data) |
| std::istream & | operator>> (std::istream &is, EnvisatAsarData &data) |
| std::ostream & | operator<< (std::ostream &os, const GeolocationGrid &data) |
| std::istream & | operator>> (std::istream &is, GeolocationGrid &data) |
| std::ostream & | operator<< (std::ostream &os, const MainProcessingParameters &data) |
| std::istream & | operator>> (std::istream &is, MainProcessingParameters &data) |
| std::ostream & | operator<< (std::ostream &os, const mph &data) |
| std::istream & | operator>> (std::istream &is, mph &data) |
| std::ostream & | operator<< (std::ostream &os, const sph &data) |
| std::istream & | operator>> (std::istream &is, sph &data) |
| std::ostream & | operator<< (std::ostream &os, const SQ_ADSR &data) |
| std::istream & | operator>> (std::istream &is, SQ_ADSR &data) |
| std::ostream & | operator<< (std::ostream &os, const SRGRConversionParameters &data) |
| std::istream & | operator>> (std::istream &is, SRGRConversionParameters &data) |
| std::ostream & | operator<< (std::ostream &os, const ErsSarDataSetSummary &data) |
| std::istream & | operator>> (std::istream &is, ErsSarDataSetSummary &data) |
| std::ostream & | operator<< (std::ostream &os, const ErsSarFacilityData &data) |
| std::istream & | operator>> (std::istream &is, ErsSarFacilityData &data) |
| std::ostream & | operator<< (std::ostream &os, const ErsSarFileDescriptor &data) |
| std::istream & | operator>> (std::istream &is, ErsSarFileDescriptor &data) |
| std::ostream & | operator<< (std::ostream &os, const ErsSarLeader &data) |
| std::istream & | operator>> (std::istream &is, ErsSarLeader &data) |
| std::ostream & | operator<< (std::ostream &os, const ErsSarMapProjectionData &data) |
| std::istream & | operator>> (std::istream &is, ErsSarMapProjectionData &data) |
| std::ostream & | operator<< (std::ostream &os, const ErsSarPlatformPositionData &data) |
| std::istream & | operator>> (std::istream &is, ErsSarPlatformPositionData &data) |
| std::ostream & | operator<< (std::ostream &os, const ErsSarPositionVectorRecord &data) |
| std::istream & | operator>> (std::istream &is, ErsSarPositionVectorRecord &data) |
| std::ostream & | operator<< (std::ostream &os, const ErsSarRecordHeader &data) |
| std::istream & | operator>> (std::istream &is, ErsSarRecordHeader &data) |
| RTTI_DEF1 (ossimAlosPalsarModel, "ossimAlosPalsarModel", ossimGeometricSarSensorModel) | |
| RTTI_DEF1 (ossimCosmoSkymedModel, "ossimCosmoSkymedModel", ossimGeometricSarSensorModel) | |
| RTTI_DEF1 (ossimEnvisatAsarModel, "ossimEnvisatAsarModel", ossimGeometricSarSensorModel) | |
| RTTI_DEF1 (ossimErsSarModel, "ossimErsSarModel", ossimGeometricSarSensorModel) | |
| RTTI_DEF1 (ossimFormosatModel, "ossimFormosatModel", ossimSensorModel) | |
| RTTI_DEF1 (ossimGeometricSarSensorModel, "ossimGeometricSarSensorModel", ossimSensorModel) | |
| RTTI_DEF1 (ossimPleiadesModel, "ossimPleiadesModel", ossimRpcModel) | |
| const char * | getCnesDescription () |
| int | getCnesNumberOfClassNames () |
| const char * | getCnesClassName (int idx) |
| OSSIM_PLUGINS_DLL void | ossimSharedLibraryInitialize (ossimSharedObjectInfo **info) |
| OSSIM_PLUGINS_DLL void | ossimSharedLibraryFinalize () |
| RTTI_DEF1 (ossimPluginReaderFactory, "ossimPluginReaderFactory", ossimImageHandlerFactoryBase) | |
| RTTI_DEF1 (ossimRadarSat2Model, "ossimRadarSat2Model", ossimGeometricSarSensorModel) | |
| RTTI_DEF1 (ossimRadarSat2RPCModel, "ossimRadarSat2RPCModel", ossimRpcModel) | |
| RTTI_DEF1 (ossimRadarSatModel, "ossimRadarSatModel", ossimGeometricSarSensorModel) | |
| RTTI_DEF1 (ossimSpot6Model, "ossimSpot6Model", ossimRpcModel) | |
| RTTI_DEF1 (ossimTerraSarModel, "ossimTerraSarModel", ossimGeometricSarSensorModel) | |
| RTTI_DEF1 (ossimTileMapModel, "ossimTileMapModel", ossimSensorModel) | |
| long | inint (double x) |
| double | fnint (double x) |
| std::ostream & | operator<< (std::ostream &out, const CivilDateTime &obj) |
| std::ostream & | operator<< (std::ostream &os, const AttitudeData &data) |
| std::istream & | operator>> (std::istream &is, AttitudeData &data) |
| std::ostream & | operator<< (std::ostream &os, const BeamInformationRecord &data) |
| std::istream & | operator>> (std::istream &is, BeamInformationRecord &data) |
| std::ostream & | operator<< (std::ostream &os, const BeamPixelCountRecord &data) |
| std::istream & | operator>> (std::istream &is, BeamPixelCountRecord &data) |
| std::ostream & | operator<< (std::ostream &os, const CompensationDataRecord &data) |
| std::istream & | operator>> (std::istream &is, CompensationDataRecord &data) |
| std::ostream & | operator<< (std::ostream &os, const DataHistogramRecord &data) |
| std::istream & | operator>> (std::istream &is, DataHistogramRecord &data) |
| std::ostream & | operator<< (std::ostream &os, const DataHistogramSignalData &data) |
| std::istream & | operator>> (std::istream &is, DataHistogramSignalData &data) |
| std::ostream & | operator<< (std::ostream &os, const DataPointDataRecord &data) |
| std::istream & | operator>> (std::istream &is, DataPointDataRecord &data) |
| std::ostream & | operator<< (std::ostream &os, const DataQuality &data) |
| std::istream & | operator>> (std::istream &is, DataQuality &data) |
| std::ostream & | operator<< (std::ostream &os, const DataSetSummary &data) |
| std::istream & | operator>> (std::istream &is, DataSetSummary &data) |
| std::ostream & | operator<< (std::ostream &os, const DopplerCentroidEstimateRecord &data) |
| std::istream & | operator>> (std::istream &is, DopplerCentroidEstimateRecord &data) |
| std::ostream & | operator<< (std::ostream &os, const FileDescriptor &data) |
| std::istream & | operator>> (std::istream &is, FileDescriptor &data) |
| std::ostream & | operator<< (std::ostream &os, const MisregistrationRecord &data) |
| std::istream & | operator>> (std::istream &is, MisregistrationRecord &data) |
| std::ostream & | operator<< (std::ostream &os, const ProcessingParameters &data) |
| std::istream & | operator>> (std::istream &is, ProcessingParameters &data) |
| std::ostream & | operator<< (std::ostream &os, const RadiometricCompensationData &data) |
| std::istream & | operator>> (std::istream &is, RadiometricCompensationData &data) |
| std::ostream & | operator<< (std::ostream &os, const RadiometricData &data) |
| std::istream & | operator>> (std::istream &is, RadiometricData &data) |
| std::ostream & | operator<< (std::ostream &os, const RadiometryUncertaintyRecord &data) |
| std::istream & | operator>> (std::istream &is, RadiometryUncertaintyRecord &data) |
| std::ostream & | operator<< (std::ostream &os, const SRGRCoefficientSetRecord &data) |
| std::istream & | operator>> (std::istream &is, SRGRCoefficientSetRecord &data) |
| std::ostream & | operator<< (std::ostream &os, const TemperatureSettingsRecord &data) |
| std::istream & | operator>> (std::istream &is, TemperatureSettingsRecord &data) |
| std::ostream & | operator<< (std::ostream &os, const Data &data) |
| std::istream & | operator>> (std::istream &is, Data &data) |
| std::ostream & | operator<< (std::ostream &os, const ImageOptionsFileDescriptor &data) |
| std::istream & | operator>> (std::istream &is, ImageOptionsFileDescriptor &data) |
| std::ostream & | operator<< (std::ostream &os, const ProcessedDataRecord &data) |
| void | SwitchEndian (int &value) |
| std::istream & | operator>> (std::istream &is, ProcessedDataRecord &data) |
| std::ostream & | operator<< (std::ostream &os, const DataHistogramProcessedData &data) |
| std::istream & | operator>> (std::istream &is, DataHistogramProcessedData &data) |
| std::ostream & | operator<< (std::ostream &os, const Leader &data) |
| std::istream & | operator>> (std::istream &is, Leader &data) |
| std::ostream & | operator<< (std::ostream &os, const PlatformPositionData &data) |
| std::istream & | operator>> (std::istream &is, PlatformPositionData &data) |
| std::ostream & | operator<< (std::ostream &os, const PositionVectorRecord &data) |
| std::istream & | operator>> (std::istream &is, PositionVectorRecord &data) |
| std::ostream & | operator<< (std::ostream &os, const RadarSatRecordHeader &data) |
| std::istream & | operator>> (std::istream &is, RadarSatRecordHeader &data) |
| std::ostream & | operator<< (std::ostream &os, const Trailer &data) |
| std::istream & | operator>> (std::istream &is, Trailer &data) |
| std::ostream & | operator<< (std::ostream &os, const FilePointerRecord &data) |
| std::istream & | operator>> (std::istream &is, FilePointerRecord &data) |
| std::ostream & | operator<< (std::ostream &os, const TextRecord &data) |
| std::istream & | operator>> (std::istream &is, TextRecord &data) |
| std::ostream & | operator<< (std::ostream &os, const VolumeDescriptorRecord &data) |
| std::istream & | operator>> (std::istream &is, VolumeDescriptorRecord &data) |
| std::ostream & | operator<< (std::ostream &os, const VolumeDir &data) |
| std::istream & | operator>> (std::istream &is, VolumeDir &data) |
Variables | |
| std::string | _ds_name |
| std::string | _ds_type |
| std::string | _filename |
| double | _ds_offset |
| double | _ds_size |
| int | _num_dsr |
| int | _dsr_size |
| ossimSharedObjectInfo | cnesInfo |
| ossimString | cnesDescription |
| std::vector< ossimString > | cnesObjList |
Definition at line 158 of file DataHistogramSignalData.h.
Definition at line 302 of file FilePointerRecord.h.
Definition at line 301 of file FilePointerRecord.h.
Definition at line 303 of file FilePointerRecord.h.
| double ossimplugins::fnint | ( | double | x | ) |
Definition at line 35 of file Arithmetic.h.
References x.
Referenced by ossimplugins::JSDDateTime::NormDate().
| const char* ossimplugins::getCnesClassName | ( | int | idx | ) |
Definition at line 51 of file ossimPluginInit.cpp.
References cnesObjList.
Referenced by ossimSharedLibraryInitialize().
| const char* ossimplugins::getCnesDescription | ( | ) |
Definition at line 43 of file ossimPluginInit.cpp.
References ossimString::c_str(), and cnesDescription.
| int ossimplugins::getCnesNumberOfClassNames | ( | ) |
Definition at line 47 of file ossimPluginInit.cpp.
| long ossimplugins::inint | ( | double | x | ) |
Definition at line 26 of file Arithmetic.h.
References x.
| std::ostream& ossimplugins::operator<< | ( | std::ostream & | os, |
| const DataHistogramProcessedData & | data | ||
Definition at line 24 of file DataHistogramProcessedData.cpp.
References ossimplugins::DataHistogramProcessedData::_histogram1, ossimplugins::DataHistogramProcessedData::_histogram2, ossimplugins::DataHistogramProcessedData::_ltab, ossimplugins::DataHistogramProcessedData::_ntab, ossimplugins::DataHistogramProcessedData::_rec_seq, and ossimplugins::DataHistogramProcessedData::_sar_chn.
| const PlatformPositionData & | data | ||
Definition at line 24 of file PlatformPositionData.cpp.
References ossimplugins::PlatformPositionData::_alt_poserr, ossimplugins::PlatformPositionData::_alt_velerr, ossimplugins::PlatformPositionData::_crt_poserr, ossimplugins::PlatformPositionData::_crt_velerr, ossimplugins::PlatformPositionData::_data_int, ossimplugins::PlatformPositionData::_day, ossimplugins::PlatformPositionData::_gmt_day, ossimplugins::PlatformPositionData::_gmt_sec, ossimplugins::PlatformPositionData::_hr_angle, ossimplugins::PlatformPositionData::_month, ossimplugins::PlatformPositionData::_ndata, ossimplugins::PlatformPositionData::_orbit_ele, ossimplugins::PlatformPositionData::_orbit_ele_desg, ossimplugins::PlatformPositionData::_pos_vect, ossimplugins::PlatformPositionData::_rad_poserr, ossimplugins::PlatformPositionData::_rad_velerr, ossimplugins::PlatformPositionData::_ref_coord, and ossimplugins::PlatformPositionData::_year.
| const PositionVectorRecord & | data | ||
Definition at line 24 of file PositionVectorRecord.cpp.
References ossimplugins::PositionVectorRecord::_pos, and ossimplugins::PositionVectorRecord::_vel.
| const RadarSatRecordHeader & | data | ||
Definition at line 24 of file RadarSatRecordHeader.cpp.
References ossimplugins::RadarSatRecordHeader::_length, ossimplugins::RadarSatRecordHeader::_rec_seq, ossimplugins::RadarSatRecordHeader::_rec_sub1, ossimplugins::RadarSatRecordHeader::_rec_sub2, ossimplugins::RadarSatRecordHeader::_rec_sub3, and ossimplugins::RadarSatRecordHeader::_rec_type.
| const FilePointerRecord & | data | ||
Definition at line 24 of file FilePointerRecord.cpp.
References ossimplugins::FilePointerRecord::_ascii_flag, ossimplugins::FilePointerRecord::_data_code, ossimplugins::FilePointerRecord::_data_type, ossimplugins::FilePointerRecord::_file_class, ossimplugins::FilePointerRecord::_file_code, ossimplugins::FilePointerRecord::_file_name, ossimplugins::FilePointerRecord::_file_num, ossimplugins::FilePointerRecord::_first_len, ossimplugins::FilePointerRecord::_first_phyvol, ossimplugins::FilePointerRecord::_first_rec, ossimplugins::FilePointerRecord::_last_phyvol, ossimplugins::FilePointerRecord::_last_rec, ossimplugins::FilePointerRecord::_len_code, ossimplugins::FilePointerRecord::_len_type, ossimplugins::FilePointerRecord::_max_len, and ossimplugins::FilePointerRecord::_nrec.
| const dsd & | data | ||
Definition at line 24 of file dsd.cpp.
References ossimplugins::dsd::_ds_name, ossimplugins::dsd::_ds_offset, ossimplugins::dsd::_ds_size, ossimplugins::dsd::_ds_type, ossimplugins::dsd::_dsr_size, ossimplugins::dsd::_filename, and ossimplugins::dsd::_num_dsr.
| const mph & | data | ||
Definition at line 24 of file mph.cpp.
References ossimplugins::mph::_abs_orbit, ossimplugins::mph::_absolute_orbit_title, ossimplugins::mph::_acq_stat_id_title, ossimplugins::mph::_acq_station, ossimplugins::mph::_clock_step, ossimplugins::mph::_clock_step_title, ossimplugins::mph::_clock_step_units, ossimplugins::mph::_cycle, ossimplugins::mph::_cycle_title, ossimplugins::mph::_delta_ut1, ossimplugins::mph::_delta_ut1_title, ossimplugins::mph::_delta_ut1_units, ossimplugins::mph::_dsd_size, ossimplugins::mph::_leap_err, ossimplugins::mph::_leap_err_title, ossimplugins::mph::_leap_sign, ossimplugins::mph::_leap_sign_title, ossimplugins::mph::_leap_utc, ossimplugins::mph::_leap_utc_title, ossimplugins::mph::_num_data_sets, ossimplugins::mph::_num_dsd, ossimplugins::mph::_number_of_ds_att_title, ossimplugins::mph::_number_of_dsd_title, ossimplugins::mph::_phase, ossimplugins::mph::_phase_title, ossimplugins::mph::_proc_center, ossimplugins::mph::_proc_center_title, ossimplugins::mph::_proc_stage, ossimplugins::mph::_proc_stage_title, ossimplugins::mph::_proc_time, ossimplugins::mph::_proc_time_title, ossimplugins::mph::_product, ossimplugins::mph::_product_err, ossimplugins::mph::_product_err_title, ossimplugins::mph::_product_name, ossimplugins::mph::_ref_doc, ossimplugins::mph::_ref_doc_title, ossimplugins::mph::_rel_orbit, ossimplugins::mph::_relative_orbit_title, ossimplugins::mph::_sat_binary_time, ossimplugins::mph::_sat_binary_time_title, ossimplugins::mph::_sensing_start, ossimplugins::mph::_sensing_start_title, ossimplugins::mph::_sensing_stop, ossimplugins::mph::_sensing_stop_title, ossimplugins::mph::_size_of_dsd_title, ossimplugins::mph::_size_of_dsd_units, ossimplugins::mph::_soft_version, ossimplugins::mph::_soft_version_title, ossimplugins::mph::_spare_4, ossimplugins::mph::_sph_size, ossimplugins::mph::_sph_size_title, ossimplugins::mph::_sph_size_units, ossimplugins::mph::_state_vector_time, ossimplugins::mph::_state_vector_time_title, ossimplugins::mph::_tot_size, ossimplugins::mph::_total_size_title, ossimplugins::mph::_total_size_units, ossimplugins::mph::_utc_sbt_time, ossimplugins::mph::_utc_sbt_time_title, ossimplugins::mph::_vector_source, ossimplugins::mph::_vector_source_title, ossimplugins::mph::_x_position, ossimplugins::mph::_x_position_title, ossimplugins::mph::_x_position_units, ossimplugins::mph::_x_velocity, ossimplugins::mph::_x_velocity_title, ossimplugins::mph::_x_velocity_units, ossimplugins::mph::_y_position, ossimplugins::mph::_y_position_title, ossimplugins::mph::_y_position_units, ossimplugins::mph::_y_velocity, ossimplugins::mph::_y_velocity_title, ossimplugins::mph::_y_velocity_units, ossimplugins::mph::_z_position, ossimplugins::mph::_z_position_title, ossimplugins::mph::_z_position_units, ossimplugins::mph::_z_velocity, ossimplugins::mph::_z_velocity_title, and ossimplugins::mph::_z_velocity_units.
| const TextRecord & | data | ||
Definition at line 24 of file TextRecord.cpp.
References ossimplugins::TextRecord::_ascii_flag, ossimplugins::TextRecord::_cont_flag, ossimplugins::TextRecord::_copyright_info, ossimplugins::TextRecord::_phyvol_id, ossimplugins::TextRecord::_product_create, ossimplugins::TextRecord::_product_type, ossimplugins::TextRecord::_scene_id, and ossimplugins::TextRecord::_scene_loc.
| const VolumeDescriptorRecord & | data | ||
Definition at line 24 of file VolumeDescriptorRecord.cpp.
References ossimplugins::VolumeDescriptorRecord::_ascii_flag, ossimplugins::VolumeDescriptorRecord::_curr_phyvol, ossimplugins::VolumeDescriptorRecord::_first_file, ossimplugins::VolumeDescriptorRecord::_first_phyvol, ossimplugins::VolumeDescriptorRecord::_format_doc, ossimplugins::VolumeDescriptorRecord::_format_rev, ossimplugins::VolumeDescriptorRecord::_format_ver, ossimplugins::VolumeDescriptorRecord::_last_phyvol, ossimplugins::VolumeDescriptorRecord::_logvol_agency, ossimplugins::VolumeDescriptorRecord::_logvol_country, ossimplugins::VolumeDescriptorRecord::_logvol_date, ossimplugins::VolumeDescriptorRecord::_logvol_facility, ossimplugins::VolumeDescriptorRecord::_logvol_id, ossimplugins::VolumeDescriptorRecord::_logvol_time, ossimplugins::VolumeDescriptorRecord::_n_filepoint, ossimplugins::VolumeDescriptorRecord::_n_voldir, ossimplugins::VolumeDescriptorRecord::_phyvol_cnt, ossimplugins::VolumeDescriptorRecord::_phyvol_id, ossimplugins::VolumeDescriptorRecord::_phyvol_log, ossimplugins::VolumeDescriptorRecord::_product_id, ossimplugins::VolumeDescriptorRecord::_software_id, ossimplugins::VolumeDescriptorRecord::_volset_id, and ossimplugins::VolumeDescriptorRecord::_volset_log.
| const SRGRConversionParameters & | data | ||
Definition at line 24 of file SRGRConversionParameters.cpp.
References ossimplugins::SRGRConversionParameters::_attach_flag, ossimplugins::SRGRConversionParameters::_first_zero_doppler_time_day, ossimplugins::SRGRConversionParameters::_first_zero_doppler_time_microsec, ossimplugins::SRGRConversionParameters::_first_zero_doppler_time_sec, ossimplugins::SRGRConversionParameters::_ground_range_origin, ossimplugins::SRGRConversionParameters::_slant_range_time, and ossimplugins::SRGRConversionParameters::_srgr_coef.
| const BeamInformationRecord & | data | ||
| const BeamPixelCountRecord & | data | ||
Definition at line 24 of file BeamPixelCountRecord.cpp.
References ossimplugins::BeamPixelCountRecord::_n_pix, and ossimplugins::BeamPixelCountRecord::_pix_update.
| const CompensationDataRecord & | data | ||
Definition at line 24 of file CompensationDataRecord.cpp.
References ossimplugins::CompensationDataRecord::_beam_tab, ossimplugins::CompensationDataRecord::_beam_tab_inc, ossimplugins::CompensationDataRecord::_beam_tab_size, ossimplugins::CompensationDataRecord::_beam_type, ossimplugins::CompensationDataRecord::_comp_descr, ossimplugins::CompensationDataRecord::_comp_desig, ossimplugins::CompensationDataRecord::_comp_seq_no, ossimplugins::CompensationDataRecord::_look_angle, and ossimplugins::CompensationDataRecord::_n_comp_rec.
| const DataPointDataRecord & | data | ||
Definition at line 24 of file DataPointDataRecord.cpp.
References ossimplugins::DataPointDataRecord::_gmt_day, ossimplugins::DataPointDataRecord::_gmt_sec, ossimplugins::DataPointDataRecord::_pitch, ossimplugins::DataPointDataRecord::_pitch_flag, ossimplugins::DataPointDataRecord::_pitch_rate, ossimplugins::DataPointDataRecord::_pitch_rate_flag, ossimplugins::DataPointDataRecord::_roll, ossimplugins::DataPointDataRecord::_roll_flag, ossimplugins::DataPointDataRecord::_roll_rate, ossimplugins::DataPointDataRecord::_roll_rate_flag, ossimplugins::DataPointDataRecord::_yaw, ossimplugins::DataPointDataRecord::_yaw_flag, ossimplugins::DataPointDataRecord::_yaw_rate, and ossimplugins::DataPointDataRecord::_yaw_rate_flag.
| const DataQuality & | data | ||
Definition at line 24 of file DataQuality.cpp.
References ossimplugins::DataQuality::_alt_locerr, ossimplugins::DataQuality::_alt_scale, ossimplugins::DataQuality::_azi_ambig, ossimplugins::DataQuality::_azi_res, ossimplugins::DataQuality::_ber, ossimplugins::DataQuality::_cali_date, ossimplugins::DataQuality::_crt_locerr, ossimplugins::DataQuality::_crt_scale, ossimplugins::DataQuality::_dis_skew, ossimplugins::DataQuality::_dyn_rng, ossimplugins::DataQuality::_enl, ossimplugins::DataQuality::_islr, ossimplugins::DataQuality::_misreg, ossimplugins::DataQuality::_nchn, ossimplugins::DataQuality::_nesz, ossimplugins::DataQuality::_ori_err, ossimplugins::DataQuality::_pslr, ossimplugins::DataQuality::_rad_res, ossimplugins::DataQuality::_rad_unc, ossimplugins::DataQuality::_rad_unc_db, ossimplugins::DataQuality::_rad_unc_deg, ossimplugins::DataQuality::_rec_seq, ossimplugins::DataQuality::_rng_ambig, ossimplugins::DataQuality::_rng_res, ossimplugins::DataQuality::_sar_chn, ossimplugins::DataQuality::_snr, and ossimplugins::DataQuality::_tb_update.
| const DataSetSummary & | data | ||
Definition at line 24 of file DataSetSummary.cpp.
References ossimplugins::DataSetSummary::_algor_id, ossimplugins::DataSetSummary::_alt_dopcen, ossimplugins::DataSetSummary::_alt_rate, ossimplugins::DataSetSummary::_ampl_coef, ossimplugins::DataSetSummary::_asc_des, ossimplugins::DataSetSummary::_auto_focus, ossimplugins::DataSetSummary::_azi_res, ossimplugins::DataSetSummary::_azi_weight, ossimplugins::DataSetSummary::_azim_beam, ossimplugins::DataSetSummary::_baseband_f, ossimplugins::DataSetSummary::_bnd_azi, ossimplugins::DataSetSummary::_bnd_azilok, ossimplugins::DataSetSummary::_bnd_rng, ossimplugins::DataSetSummary::_bnd_rnglok, ossimplugins::DataSetSummary::_chirp_ext_ind, ossimplugins::DataSetSummary::_chn_bits, ossimplugins::DataSetSummary::_clock_ang, ossimplugins::DataSetSummary::_clutter_lock, ossimplugins::DataSetSummary::_crt_dopcen, ossimplugins::DataSetSummary::_crt_rate, ossimplugins::DataSetSummary::_data_inpsrc, ossimplugins::DataSetSummary::_earth_mass, ossimplugins::DataSetSummary::_echo_track, ossimplugins::DataSetSummary::_ele_sight, ossimplugins::DataSetSummary::_elev_beam, ossimplugins::DataSetSummary::_ellip_des, ossimplugins::DataSetSummary::_ellip_j, ossimplugins::DataSetSummary::_ellip_maj, ossimplugins::DataSetSummary::_ellip_min, ossimplugins::DataSetSummary::_fa, ossimplugins::DataSetSummary::_fac_code, ossimplugins::DataSetSummary::_fac_id, ossimplugins::DataSetSummary::_fr, ossimplugins::DataSetSummary::_gn_cross, ossimplugins::DataSetSummary::_gn_polar, ossimplugins::DataSetSummary::_grav_const, ossimplugins::DataSetSummary::_i_bias, ossimplugins::DataSetSummary::_incident_ang, ossimplugins::DataSetSummary::_inp_sctim, ossimplugins::DataSetSummary::_iq_ratio, ossimplugins::DataSetSummary::_lev_code, ossimplugins::DataSetSummary::_line_cont, ossimplugins::DataSetSummary::_line_spacing, ossimplugins::DataSetSummary::_mech_sight, ossimplugins::DataSetSummary::_mission_id, ossimplugins::DataSetSummary::_motion_comp, ossimplugins::DataSetSummary::_n_azilok, ossimplugins::DataSetSummary::_n_rnglok, ossimplugins::DataSetSummary::_nchn, ossimplugins::DataSetSummary::_orbit_num, ossimplugins::DataSetSummary::_phas_coef, ossimplugins::DataSetSummary::_pix_spacing, ossimplugins::DataSetSummary::_plat_head, ossimplugins::DataSetSummary::_plat_lat, ossimplugins::DataSetSummary::_plat_long, ossimplugins::DataSetSummary::_pro_head, ossimplugins::DataSetSummary::_pro_lat, ossimplugins::DataSetSummary::_pro_long, ossimplugins::DataSetSummary::_prod_type, ossimplugins::DataSetSummary::_pulse_code, ossimplugins::DataSetSummary::_q_bias, ossimplugins::DataSetSummary::_quant_desc, ossimplugins::DataSetSummary::_radi_stretch, ossimplugins::DataSetSummary::_rng_gate, ossimplugins::DataSetSummary::_rng_length, ossimplugins::DataSetSummary::_rng_res, ossimplugins::DataSetSummary::_rng_weight, ossimplugins::DataSetSummary::_rngcmp_desg, ossimplugins::DataSetSummary::_rngcmp_f, ossimplugins::DataSetSummary::_sar_chn, ossimplugins::DataSetSummary::_sat_bintim, ossimplugins::DataSetSummary::_sat_clkinc, ossimplugins::DataSetSummary::_sat_clktim, ossimplugins::DataSetSummary::_sc_lin, ossimplugins::DataSetSummary::_sc_pix, ossimplugins::DataSetSummary::_scene_des, ossimplugins::DataSetSummary::_scene_id, ossimplugins::DataSetSummary::_scene_len, ossimplugins::DataSetSummary::_scene_wid, ossimplugins::DataSetSummary::_sensor_id, ossimplugins::DataSetSummary::_seq_num, ossimplugins::DataSetSummary::_sys_id, ossimplugins::DataSetSummary::_terrain_h, ossimplugins::DataSetSummary::_time_dir_lin, ossimplugins::DataSetSummary::_time_dir_pix, ossimplugins::DataSetSummary::_ver_id, and ossimplugins::DataSetSummary::_wave_length.
| const DopplerCentroidEstimateRecord & | data | ||
| const FileDescriptor & | data | ||
Definition at line 24 of file FileDescriptor.cpp.
References ossimplugins::FileDescriptor::_ascii_flag, ossimplugins::FileDescriptor::_code_len, ossimplugins::FileDescriptor::_code_loc, ossimplugins::FileDescriptor::_design_rev, ossimplugins::FileDescriptor::_file_name, ossimplugins::FileDescriptor::_file_num, ossimplugins::FileDescriptor::_format_doc, ossimplugins::FileDescriptor::_format_ver, ossimplugins::FileDescriptor::_l_anno_data, ossimplugins::FileDescriptor::_l_att_data, ossimplugins::FileDescriptor::_l_cal, ossimplugins::FileDescriptor::_l_data_his, ossimplugins::FileDescriptor::_l_dataset, ossimplugins::FileDescriptor::_l_dem_desc, ossimplugins::FileDescriptor::_l_det_proc, ossimplugins::FileDescriptor::_l_fac_data, ossimplugins::FileDescriptor::_l_gcp, ossimplugins::FileDescriptor::_l_map_proj, ossimplugins::FileDescriptor::_l_plat_pos, ossimplugins::FileDescriptor::_l_qual_sum, ossimplugins::FileDescriptor::_l_radar_par, ossimplugins::FileDescriptor::_l_radi_comp, ossimplugins::FileDescriptor::_l_radi_data, ossimplugins::FileDescriptor::_l_rang_spec, ossimplugins::FileDescriptor::_n_anno_data, ossimplugins::FileDescriptor::_n_att_data, ossimplugins::FileDescriptor::_n_cal, ossimplugins::FileDescriptor::_n_data_his, ossimplugins::FileDescriptor::_n_dataset, ossimplugins::FileDescriptor::_n_dem_desc, ossimplugins::FileDescriptor::_n_det_proc, ossimplugins::FileDescriptor::_n_fac_data, ossimplugins::FileDescriptor::_n_gcp, ossimplugins::FileDescriptor::_n_map_proj, ossimplugins::FileDescriptor::_n_plat_pos, ossimplugins::FileDescriptor::_n_qual_sum, ossimplugins::FileDescriptor::_n_radar_par, ossimplugins::FileDescriptor::_n_radi_comp, ossimplugins::FileDescriptor::_n_radi_data, ossimplugins::FileDescriptor::_n_rang_spec, ossimplugins::FileDescriptor::_rec_code, ossimplugins::FileDescriptor::_rec_len, ossimplugins::FileDescriptor::_rec_seq, ossimplugins::FileDescriptor::_rlen_len, ossimplugins::FileDescriptor::_rlen_loc, ossimplugins::FileDescriptor::_seq_len, ossimplugins::FileDescriptor::_seq_loc, and ossimplugins::FileDescriptor::_software_id.
| const MisregistrationRecord & | data | ||
Definition at line 24 of file MisregistrationRecord.cpp.
References ossimplugins::MisregistrationRecord::_alt_m, and ossimplugins::MisregistrationRecord::_crt_m.
| const ProcessingParameters & | data | ||
Definition at line 24 of file ProcessingParameters.cpp.
References ossimplugins::ProcessingParameters::_act_ing_start, ossimplugins::ProcessingParameters::_act_ing_stop, ossimplugins::ProcessingParameters::_adc_samp_rate, ossimplugins::ProcessingParameters::_angle_first, ossimplugins::ProcessingParameters::_angle_last, ossimplugins::ProcessingParameters::_appl_type, ossimplugins::ProcessingParameters::_apply_dtm, ossimplugins::ProcessingParameters::_beam_edge_conf, ossimplugins::ProcessingParameters::_beam_edge_rqd, ossimplugins::ProcessingParameters::_beam_info, ossimplugins::ProcessingParameters::_bit_err_rate, ossimplugins::ProcessingParameters::_centre_lat, ossimplugins::ProcessingParameters::_centre_long, ossimplugins::ProcessingParameters::_complete_msg, ossimplugins::ProcessingParameters::_date_incons, ossimplugins::ProcessingParameters::_delay_changes, ossimplugins::ProcessingParameters::_density_in, ossimplugins::ProcessingParameters::_density_out, ossimplugins::ProcessingParameters::_dop_amb_err, ossimplugins::ProcessingParameters::_dopamb_conf, ossimplugins::ProcessingParameters::_dopcen_est, ossimplugins::ProcessingParameters::_dopcen_inc, ossimplugins::ProcessingParameters::_eph_orb_data, ossimplugins::ProcessingParameters::_err_amp_coef, ossimplugins::ProcessingParameters::_err_phas_coef, ossimplugins::ProcessingParameters::_exp_ing_start, ossimplugins::ProcessingParameters::_exp_ing_stop, ossimplugins::ProcessingParameters::_fm_crc_err, ossimplugins::ProcessingParameters::_gics_reqd, ossimplugins::ProcessingParameters::_gn_corctn_fctr, ossimplugins::ProcessingParameters::_img_cumu_dist, ossimplugins::ProcessingParameters::_img_hist_mean, ossimplugins::ProcessingParameters::_inp_media, ossimplugins::ProcessingParameters::_large_gap, ossimplugins::ProcessingParameters::_map_system, ossimplugins::ProcessingParameters::_media_id, ossimplugins::ProcessingParameters::_miss_ln, ossimplugins::ProcessingParameters::_mn_sig_lev, ossimplugins::ProcessingParameters::_n_beams, ossimplugins::ProcessingParameters::_n_dopcen, ossimplugins::ProcessingParameters::_n_image_pix, ossimplugins::ProcessingParameters::_n_pix_updates, ossimplugins::ProcessingParameters::_n_srgr, ossimplugins::ProcessingParameters::_n_tape_id, ossimplugins::ProcessingParameters::_n_temp_set, ossimplugins::ProcessingParameters::_num_state_vectors, ossimplugins::ProcessingParameters::_orb_data_src, ossimplugins::ProcessingParameters::_pix_count, ossimplugins::ProcessingParameters::_pix_overlap, ossimplugins::ProcessingParameters::_pixel_spacing, ossimplugins::ProcessingParameters::_post_img_gn, ossimplugins::ProcessingParameters::_prc_satur_pix, ossimplugins::ProcessingParameters::_prc_zero_pix, ossimplugins::ProcessingParameters::_pre_img_gn, ossimplugins::ProcessingParameters::_prf_changes, ossimplugins::ProcessingParameters::_proc_start, ossimplugins::ProcessingParameters::_proc_stop, ossimplugins::ProcessingParameters::_prod_type, ossimplugins::ProcessingParameters::_pulse_bandw, ossimplugins::ProcessingParameters::_pulse_cnt_1, ossimplugins::ProcessingParameters::_pulse_cnt_2, ossimplugins::ProcessingParameters::_pwin_end, ossimplugins::ProcessingParameters::_pwin_start, ossimplugins::ProcessingParameters::_rec_seq, ossimplugins::ProcessingParameters::_recd_type, ossimplugins::ProcessingParameters::_rej_bf_start, ossimplugins::ProcessingParameters::_rej_few_fram, ossimplugins::ProcessingParameters::_rej_ln, ossimplugins::ProcessingParameters::_rej_many_fram, ossimplugins::ProcessingParameters::_rej_mchn_err, ossimplugins::ProcessingParameters::_rej_rec_type, ossimplugins::ProcessingParameters::_rej_vchn_err, ossimplugins::ProcessingParameters::_rep_agc_attn, ossimplugins::ProcessingParameters::_rep_energy_gn, ossimplugins::ProcessingParameters::_rng_amp_coef, ossimplugins::ProcessingParameters::_rng_phas_coef, ossimplugins::ProcessingParameters::_rng_ref_src, ossimplugins::ProcessingParameters::_satellite_id, ossimplugins::ProcessingParameters::_scene_id, ossimplugins::ProcessingParameters::_scr_data_ind, ossimplugins::ProcessingParameters::_sens_config, ossimplugins::ProcessingParameters::_sens_orient, ossimplugins::ProcessingParameters::_skipd_frams, ossimplugins::ProcessingParameters::_slow_time_coef, ossimplugins::ProcessingParameters::_span_x, ossimplugins::ProcessingParameters::_span_y, ossimplugins::ProcessingParameters::_srgr_coefset, ossimplugins::ProcessingParameters::_state_time, ossimplugins::ProcessingParameters::_state_time_inc, ossimplugins::ProcessingParameters::_sych_marker, ossimplugins::ProcessingParameters::_tape_id, ossimplugins::ProcessingParameters::_temp, ossimplugins::ProcessingParameters::_temp_set_inc, ossimplugins::ProcessingParameters::_user_id, ossimplugins::ProcessingParameters::_wo_date, and ossimplugins::ProcessingParameters::_wo_number.
| const RadiometricCompensationData & | data | ||
Definition at line 24 of file RadiometricCompensationData.cpp.
References ossimplugins::RadiometricCompensationData::_chan_ind, ossimplugins::RadiometricCompensationData::_dset, ossimplugins::RadiometricCompensationData::_dset_size, ossimplugins::RadiometricCompensationData::_n_dset, and ossimplugins::RadiometricCompensationData::_seq_num.
| const RadiometryUncertaintyRecord & | data | ||
Definition at line 24 of file RadiometryUncertaintyRecord.cpp.
References ossimplugins::RadiometryUncertaintyRecord::_db, and ossimplugins::RadiometryUncertaintyRecord::_deg.
| const SRGRCoefficientSetRecord & | data | ||
Definition at line 24 of file SRGRCoefficientSetRecord.cpp.
References ossimplugins::SRGRCoefficientSetRecord::_srgr_coef, and ossimplugins::SRGRCoefficientSetRecord::_srgr_update.
| const TemperatureSettingsRecord & | data | ||
Definition at line 24 of file TemperatureSettingsRecord.cpp.
References ossimplugins::TemperatureSettingsRecord::_temp_set.
| const ProcessedDataRecord & | data | ||
Definition at line 25 of file ProcessedDataRecord.cpp.
References ossimplugins::ProcessedDataRecord::_acq_day, ossimplugins::ProcessedDataRecord::_acq_msec, ossimplugins::ProcessedDataRecord::_acq_year, ossimplugins::ProcessedDataRecord::_east_first, ossimplugins::ProcessedDataRecord::_east_last, ossimplugins::ProcessedDataRecord::_fdc_first, ossimplugins::ProcessedDataRecord::_fdc_last, ossimplugins::ProcessedDataRecord::_fdc_mid, ossimplugins::ProcessedDataRecord::_geo_updf, ossimplugins::ProcessedDataRecord::_heading, ossimplugins::ProcessedDataRecord::_ka_first, ossimplugins::ProcessedDataRecord::_ka_last, ossimplugins::ProcessedDataRecord::_ka_mid, ossimplugins::ProcessedDataRecord::_lat_first, ossimplugins::ProcessedDataRecord::_lat_last, ossimplugins::ProcessedDataRecord::_lat_mid, ossimplugins::ProcessedDataRecord::_line_num, ossimplugins::ProcessedDataRecord::_lon_first, ossimplugins::ProcessedDataRecord::_lon_last, ossimplugins::ProcessedDataRecord::_lon_mid, ossimplugins::ProcessedDataRecord::_n_data_pixel, ossimplugins::ProcessedDataRecord::_n_left_pixel, ossimplugins::ProcessedDataRecord::_n_right_pixel, ossimplugins::ProcessedDataRecord::_nadir_ang, ossimplugins::ProcessedDataRecord::_north_first, ossimplugins::ProcessedDataRecord::_north_last, ossimplugins::ProcessedDataRecord::_prf, ossimplugins::ProcessedDataRecord::_rec_num, ossimplugins::ProcessedDataRecord::_recv_polar, ossimplugins::ProcessedDataRecord::_sar_chan_code, ossimplugins::ProcessedDataRecord::_sar_chan_ind, ossimplugins::ProcessedDataRecord::_sensor_updf, ossimplugins::ProcessedDataRecord::_squint_ang, ossimplugins::ProcessedDataRecord::_sr_first, ossimplugins::ProcessedDataRecord::_sr_last, and ossimplugins::ProcessedDataRecord::_tran_polar.
| const MainProcessingParameters & | data | ||
Definition at line 25 of file MainProcessingParameters.cpp.
References ossimplugins::MainProcessingParameters::_ant_elev_coor_flag, ossimplugins::MainProcessingParameters::_ant_scal_flag, ossimplugins::MainProcessingParameters::_attach_flag, ossimplugins::MainProcessingParameters::_avg_scene_height_ellpsoid, ossimplugins::MainProcessingParameters::_ax_fm_origin, ossimplugins::MainProcessingParameters::_az_fm_rate, ossimplugins::MainProcessingParameters::_azimut_spacing, ossimplugins::MainProcessingParameters::_bandwidth, ossimplugins::MainProcessingParameters::_beam_overlap, ossimplugins::MainProcessingParameters::_calibration_factors, ossimplugins::MainProcessingParameters::_chirp_extract_flag, ossimplugins::MainProcessingParameters::_data_analysis_flag, ossimplugins::MainProcessingParameters::_data_type, ossimplugins::MainProcessingParameters::_detected_flag, ossimplugins::MainProcessingParameters::_dop_amb_coef, ossimplugins::MainProcessingParameters::_dop_amb_flag, ossimplugins::MainProcessingParameters::_dop_cen_flag, ossimplugins::MainProcessingParameters::_echo_comp, ossimplugins::MainProcessingParameters::_echo_comp_ratio, ossimplugins::MainProcessingParameters::_errors_counters, ossimplugins::MainProcessingParameters::_filter_az, ossimplugins::MainProcessingParameters::_filter_coef_az, ossimplugins::MainProcessingParameters::_filter_coef_range, ossimplugins::MainProcessingParameters::_filter_range, ossimplugins::MainProcessingParameters::_first_proc_range_samp, ossimplugins::MainProcessingParameters::_first_zero_doppler_time, ossimplugins::MainProcessingParameters::_gm_rng_comp_inv_filter_flag, ossimplugins::MainProcessingParameters::_image_parameters1, ossimplugins::MainProcessingParameters::_image_parameters2, ossimplugins::MainProcessingParameters::_init_cal_comp, ossimplugins::MainProcessingParameters::_init_cal_ratio, ossimplugins::MainProcessingParameters::_last_zero_doppler_time, ossimplugins::MainProcessingParameters::_line_time_interval, ossimplugins::MainProcessingParameters::_lines_per_burst, ossimplugins::MainProcessingParameters::_look_bw_az, ossimplugins::MainProcessingParameters::_look_sum_flag, ossimplugins::MainProcessingParameters::_noise_comp, ossimplugins::MainProcessingParameters::_noise_comp_ratio, ossimplugins::MainProcessingParameters::_noise_estimation, ossimplugins::MainProcessingParameters::_nominal_chirp, ossimplugins::MainProcessingParameters::_num_lines_proc, ossimplugins::MainProcessingParameters::_num_look_az, ossimplugins::MainProcessingParameters::_num_looks_range, ossimplugins::MainProcessingParameters::_num_output_lines, ossimplugins::MainProcessingParameters::_num_range_lines_per_burst, ossimplugins::MainProcessingParameters::_num_samples_per_line, ossimplugins::MainProcessingParameters::_output_statistics, ossimplugins::MainProcessingParameters::_parameter_code, ossimplugins::MainProcessingParameters::_per_cal_comp, ossimplugins::MainProcessingParameters::_per_cal_ratio, ossimplugins::MainProcessingParameters::_prf_values, ossimplugins::MainProcessingParameters::_radar_freq, ossimplugins::MainProcessingParameters::_range_ref, ossimplugins::MainProcessingParameters::_range_samp_rate, ossimplugins::MainProcessingParameters::_range_spacing, ossimplugins::MainProcessingParameters::_range_spread_comp_flag, ossimplugins::MainProcessingParameters::_raw_data_analysis, ossimplugins::MainProcessingParameters::_rms_equal_flag, ossimplugins::MainProcessingParameters::_srgr_flag, ossimplugins::MainProcessingParameters::_start_time_mds1, ossimplugins::MainProcessingParameters::_start_time_mds2, ossimplugins::MainProcessingParameters::_state_vector_time_1_day, ossimplugins::MainProcessingParameters::_state_vector_time_1_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_1_sec, ossimplugins::MainProcessingParameters::_state_vector_time_2_day, ossimplugins::MainProcessingParameters::_state_vector_time_2_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_2_sec, ossimplugins::MainProcessingParameters::_state_vector_time_3_day, ossimplugins::MainProcessingParameters::_state_vector_time_3_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_3_sec, ossimplugins::MainProcessingParameters::_state_vector_time_4_day, ossimplugins::MainProcessingParameters::_state_vector_time_4_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_4_sec, ossimplugins::MainProcessingParameters::_state_vector_time_5_day, ossimplugins::MainProcessingParameters::_state_vector_time_5_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_5_sec, ossimplugins::MainProcessingParameters::_swath_num, ossimplugins::MainProcessingParameters::_time_diff, ossimplugins::MainProcessingParameters::_time_diff_zero_doppler, ossimplugins::MainProcessingParameters::_time_first_SS1_echo, ossimplugins::MainProcessingParameters::_to_bw_az, ossimplugins::MainProcessingParameters::_vga_com_cal_flag, ossimplugins::MainProcessingParameters::_vga_com_echo_flag, ossimplugins::MainProcessingParameters::_vga_com_nom_time_flag, ossimplugins::MainProcessingParameters::_work_order_id, ossimplugins::MainProcessingParameters::_x_pos_1, ossimplugins::MainProcessingParameters::_x_pos_2, ossimplugins::MainProcessingParameters::_x_pos_3, ossimplugins::MainProcessingParameters::_x_pos_4, ossimplugins::MainProcessingParameters::_x_pos_5, ossimplugins::MainProcessingParameters::_x_vel_1, ossimplugins::MainProcessingParameters::_x_vel_2, ossimplugins::MainProcessingParameters::_x_vel_3, ossimplugins::MainProcessingParameters::_x_vel_4, ossimplugins::MainProcessingParameters::_x_vel_5, ossimplugins::MainProcessingParameters::_y_pos_1, ossimplugins::MainProcessingParameters::_y_pos_2, ossimplugins::MainProcessingParameters::_y_pos_3, ossimplugins::MainProcessingParameters::_y_pos_4, ossimplugins::MainProcessingParameters::_y_pos_5, ossimplugins::MainProcessingParameters::_y_vel_1, ossimplugins::MainProcessingParameters::_y_vel_2, ossimplugins::MainProcessingParameters::_y_vel_3, ossimplugins::MainProcessingParameters::_y_vel_4, ossimplugins::MainProcessingParameters::_y_vel_5, ossimplugins::MainProcessingParameters::_z_pos_1, ossimplugins::MainProcessingParameters::_z_pos_2, ossimplugins::MainProcessingParameters::_z_pos_3, ossimplugins::MainProcessingParameters::_z_pos_4, ossimplugins::MainProcessingParameters::_z_pos_5, ossimplugins::MainProcessingParameters::_z_vel_1, ossimplugins::MainProcessingParameters::_z_vel_2, ossimplugins::MainProcessingParameters::_z_vel_3, ossimplugins::MainProcessingParameters::_z_vel_4, and ossimplugins::MainProcessingParameters::_z_vel_5.
| const GeolocationGrid & | data | ||
Definition at line 25 of file GeolocationGrid.cpp.
References ossimplugins::GeolocationGrid::_angles, ossimplugins::GeolocationGrid::_attach_flag, ossimplugins::GeolocationGrid::_first_zero_doppler_time_day, ossimplugins::GeolocationGrid::_first_zero_doppler_time_microsec, ossimplugins::GeolocationGrid::_first_zero_doppler_time_sec, ossimplugins::GeolocationGrid::_last_line_tie_points, ossimplugins::GeolocationGrid::_last_zero_doppler_time, ossimplugins::GeolocationGrid::_lats, ossimplugins::GeolocationGrid::_line_num, ossimplugins::GeolocationGrid::_longs, ossimplugins::GeolocationGrid::_num_lines, ossimplugins::GeolocationGrid::_samp_numbers, ossimplugins::GeolocationGrid::_slant_range_times, and ossimplugins::GeolocationGrid::_sub_sat_track.
| const ErsSarDataSetSummary & | data | ||
Definition at line 25 of file ErsSarDataSetSummary.cpp.
References ossimplugins::ErsSarDataSetSummary::_algor_id, ossimplugins::ErsSarDataSetSummary::_alt_dopcen, ossimplugins::ErsSarDataSetSummary::_alt_rate, ossimplugins::ErsSarDataSetSummary::_ampl_coef, ossimplugins::ErsSarDataSetSummary::_asc_des, ossimplugins::ErsSarDataSetSummary::_auto_focus, ossimplugins::ErsSarDataSetSummary::_azi_res, ossimplugins::ErsSarDataSetSummary::_azi_weight, ossimplugins::ErsSarDataSetSummary::_baseband_f, ossimplugins::ErsSarDataSetSummary::_bnd_azi, ossimplugins::ErsSarDataSetSummary::_bnd_azilok, ossimplugins::ErsSarDataSetSummary::_bnd_rng, ossimplugins::ErsSarDataSetSummary::_bnd_rnglok, ossimplugins::ErsSarDataSetSummary::_chirp_ext_ind, ossimplugins::ErsSarDataSetSummary::_chn_bits, ossimplugins::ErsSarDataSetSummary::_clock_ang, ossimplugins::ErsSarDataSetSummary::_clutter_lock, ossimplugins::ErsSarDataSetSummary::_crt_dopcen, ossimplugins::ErsSarDataSetSummary::_crt_rate, ossimplugins::ErsSarDataSetSummary::_data_inpsrc, ossimplugins::ErsSarDataSetSummary::_earth_mass, ossimplugins::ErsSarDataSetSummary::_ellip_des, ossimplugins::ErsSarDataSetSummary::_ellip_j, ossimplugins::ErsSarDataSetSummary::_ellip_maj, ossimplugins::ErsSarDataSetSummary::_ellip_min, ossimplugins::ErsSarDataSetSummary::_fa, ossimplugins::ErsSarDataSetSummary::_fac_id, ossimplugins::ErsSarDataSetSummary::_fr, ossimplugins::ErsSarDataSetSummary::_gn_cross, ossimplugins::ErsSarDataSetSummary::_gn_polar, ossimplugins::ErsSarDataSetSummary::_grav_const, ossimplugins::ErsSarDataSetSummary::_i_bias, ossimplugins::ErsSarDataSetSummary::_incident_ang, ossimplugins::ErsSarDataSetSummary::_inp_sctim, ossimplugins::ErsSarDataSetSummary::_iq_ratio, ossimplugins::ErsSarDataSetSummary::_line_cont, ossimplugins::ErsSarDataSetSummary::_line_spacing, ossimplugins::ErsSarDataSetSummary::_mech_sight, ossimplugins::ErsSarDataSetSummary::_mission_id, ossimplugins::ErsSarDataSetSummary::_motion_comp, ossimplugins::ErsSarDataSetSummary::_n_azilok, ossimplugins::ErsSarDataSetSummary::_n_rnglok, ossimplugins::ErsSarDataSetSummary::_nchn, ossimplugins::ErsSarDataSetSummary::_orbit_num, ossimplugins::ErsSarDataSetSummary::_phas_coef, ossimplugins::ErsSarDataSetSummary::_pix_spacing, ossimplugins::ErsSarDataSetSummary::_plat_head, ossimplugins::ErsSarDataSetSummary::_plat_lat, ossimplugins::ErsSarDataSetSummary::_plat_long, ossimplugins::ErsSarDataSetSummary::_pro_head, ossimplugins::ErsSarDataSetSummary::_pro_lat, ossimplugins::ErsSarDataSetSummary::_pro_long, ossimplugins::ErsSarDataSetSummary::_prod_type, ossimplugins::ErsSarDataSetSummary::_pulse_code, ossimplugins::ErsSarDataSetSummary::_q_bias, ossimplugins::ErsSarDataSetSummary::_quant_desc, ossimplugins::ErsSarDataSetSummary::_rng_gate, ossimplugins::ErsSarDataSetSummary::_rng_length, ossimplugins::ErsSarDataSetSummary::_rng_res, ossimplugins::ErsSarDataSetSummary::_rng_weight, ossimplugins::ErsSarDataSetSummary::_rngcmp_desg, ossimplugins::ErsSarDataSetSummary::_rngcmp_f, ossimplugins::ErsSarDataSetSummary::_sar_chn, ossimplugins::ErsSarDataSetSummary::_sat_bintim, ossimplugins::ErsSarDataSetSummary::_sat_clkinc, ossimplugins::ErsSarDataSetSummary::_sat_clktim, ossimplugins::ErsSarDataSetSummary::_sc_lin, ossimplugins::ErsSarDataSetSummary::_sc_pix, ossimplugins::ErsSarDataSetSummary::_scene_des, ossimplugins::ErsSarDataSetSummary::_scene_id, ossimplugins::ErsSarDataSetSummary::_scene_len, ossimplugins::ErsSarDataSetSummary::_scene_wid, ossimplugins::ErsSarDataSetSummary::_sensor_id, ossimplugins::ErsSarDataSetSummary::_seq_num, ossimplugins::ErsSarDataSetSummary::_sys_id, ossimplugins::ErsSarDataSetSummary::_terrain_h, ossimplugins::ErsSarDataSetSummary::_time_dir_lin, ossimplugins::ErsSarDataSetSummary::_time_dir_pix, ossimplugins::ErsSarDataSetSummary::_ver_id, ossimplugins::ErsSarDataSetSummary::_wave_length, ossimplugins::ErsSarDataSetSummary::_zero_dop_az_time_c_pixel, ossimplugins::ErsSarDataSetSummary::_zero_dop_az_time_f_pixel, ossimplugins::ErsSarDataSetSummary::_zero_dop_az_time_l_pixel, ossimplugins::ErsSarDataSetSummary::_zero_dop_range_time_c_pixel, ossimplugins::ErsSarDataSetSummary::_zero_dop_range_time_f_pixel, and ossimplugins::ErsSarDataSetSummary::_zero_dop_range_time_l_pixel.
| const AntennaElevationPatterns & | data | ||
| const ErsSarFacilityData & | data | ||
Definition at line 25 of file ErsSarFacilityData.cpp.
References ossimplugins::ErsSarFacilityData::_3_dB_look_bandwidth, ossimplugins::ErsSarFacilityData::_3_dB_look_proc_dopp_bandw, ossimplugins::ErsSarFacilityData::_3_dB_width_CCF, ossimplugins::ErsSarFacilityData::_abs_cal_const_K, ossimplugins::ErsSarFacilityData::_antenna_elev_flag, ossimplugins::ErsSarFacilityData::_asc_node_pos_X_comp, ossimplugins::ErsSarFacilityData::_asc_node_pos_Y_comp, ossimplugins::ErsSarFacilityData::_asc_node_pos_Z_comp, ossimplugins::ErsSarFacilityData::_asc_node_vel_X_comp, ossimplugins::ErsSarFacilityData::_asc_node_vel_Y_comp, ossimplugins::ErsSarFacilityData::_asc_node_vel_Z_comp, ossimplugins::ErsSarFacilityData::_autom_look_scal_gain_flag, ossimplugins::ErsSarFacilityData::_azimuth_baseband_convers_flag, ossimplugins::ErsSarFacilityData::_azimuth_FFT_IFFT_ratio, ossimplugins::ErsSarFacilityData::_cal_gain_change_flag, ossimplugins::ErsSarFacilityData::_cal_gain_changes, ossimplugins::ErsSarFacilityData::_cal_sys_gain, ossimplugins::ErsSarFacilityData::_cal_syst_gain_last_proc, ossimplugins::ErsSarFacilityData::_center_range_pix_mid_az_inc, ossimplugins::ErsSarFacilityData::_coef_ant_elev_1, ossimplugins::ErsSarFacilityData::_coef_ant_elev_2, ossimplugins::ErsSarFacilityData::_coef_ant_elev_3, ossimplugins::ErsSarFacilityData::_coef_ant_elev_4, ossimplugins::ErsSarFacilityData::_coef_ant_elev_5, ossimplugins::ErsSarFacilityData::_coef_ground_range_1, ossimplugins::ErsSarFacilityData::_coef_ground_range_2, ossimplugins::ErsSarFacilityData::_coef_ground_range_3, ossimplugins::ErsSarFacilityData::_coef_ground_range_4, ossimplugins::ErsSarFacilityData::_datation_flag, ossimplugins::ErsSarFacilityData::_dopp_ambig_conf_meas, ossimplugins::ErsSarFacilityData::_dopp_ambig_conf_meas_flag, ossimplugins::ErsSarFacilityData::_dopp_ambig_num, ossimplugins::ErsSarFacilityData::_dopp_cent_conf_meas, ossimplugins::ErsSarFacilityData::_dopp_cent_conf_meas_flag, ossimplugins::ErsSarFacilityData::_dopp_cent_val_flag, ossimplugins::ErsSarFacilityData::_doppler_ambiguity_estimat_flag, ossimplugins::ErsSarFacilityData::_doppler_centroid_cubic_coeff, ossimplugins::ErsSarFacilityData::_estim_bit_error_rate, ossimplugins::ErsSarFacilityData::_first_processed_range_sample, ossimplugins::ErsSarFacilityData::_first_range_pixel_mid_az_inc, ossimplugins::ErsSarFacilityData::_first_rec_gain_read, ossimplugins::ErsSarFacilityData::_first_replica_sample, ossimplugins::ErsSarFacilityData::_first_side_lobe_lev_of_ACF, ossimplugins::ErsSarFacilityData::_first_side_lobe_level, ossimplugins::ErsSarFacilityData::_form_num_range_line_used, ossimplugins::ErsSarFacilityData::_I_channel_bias_correction, ossimplugins::ErsSarFacilityData::_I_channel_gain_correction, ossimplugins::ErsSarFacilityData::_I_gain_imb_lower_bound, ossimplugins::ErsSarFacilityData::_I_gain_imb_upper_bound, ossimplugins::ErsSarFacilityData::_I_Q_quad_depar_lower_bound, ossimplugins::ErsSarFacilityData::_I_Q_quad_depar_upper_bound, ossimplugins::ErsSarFacilityData::_initial_doppler_ambiguity_num, ossimplugins::ErsSarFacilityData::_inp_data_I_mean, ossimplugins::ErsSarFacilityData::_inp_data_I_stddev, ossimplugins::ErsSarFacilityData::_inp_data_Q_mean, ossimplugins::ErsSarFacilityData::_inp_data_Q_stddev, ossimplugins::ErsSarFacilityData::_inp_data_stat_flag, ossimplugins::ErsSarFacilityData::_inp_state_vect_pos_X_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_pos_Y_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_pos_Z_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_vel_Vx_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_vel_Vy_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_vel_Vz_comp, ossimplugins::ErsSarFacilityData::_inp_state_vector_type_flag, ossimplugins::ErsSarFacilityData::_int_cal_utc, ossimplugins::ErsSarFacilityData::_ISLR_CCF_between_last, ossimplugins::ErsSarFacilityData::_ISLR_of_ACF, ossimplugins::ErsSarFacilityData::_K_gen_date, ossimplugins::ErsSarFacilityData::_K_vers_num, ossimplugins::ErsSarFacilityData::_last_range_pix_mid_az_inc, ossimplugins::ErsSarFacilityData::_last_release_cal_date, ossimplugins::ErsSarFacilityData::_last_release_qc_date, ossimplugins::ErsSarFacilityData::_look_detecion_flag, ossimplugins::ErsSarFacilityData::_look_scalar_gain_1, ossimplugins::ErsSarFacilityData::_look_scalar_gain_2, ossimplugins::ErsSarFacilityData::_look_scalar_gain_3, ossimplugins::ErsSarFacilityData::_look_scalar_gain_4, ossimplugins::ErsSarFacilityData::_look_scalar_gain_5, ossimplugins::ErsSarFacilityData::_look_scalar_gain_6, ossimplugins::ErsSarFacilityData::_look_scalar_gain_7, ossimplugins::ErsSarFacilityData::_look_scalar_gain_8, ossimplugins::ErsSarFacilityData::_low_bound_K, ossimplugins::ErsSarFacilityData::_max_error_range_line_timing, ossimplugins::ErsSarFacilityData::_max_value_look_scalar_gain, ossimplugins::ErsSarFacilityData::_mean_cal_pulse_power, ossimplugins::ErsSarFacilityData::_mean_noise_power, ossimplugins::ErsSarFacilityData::_missing_lines, ossimplugins::ErsSarFacilityData::_noise_power, ossimplugins::ErsSarFacilityData::_norm_ref_range_ro, ossimplugins::ErsSarFacilityData::_num_azimuth_blocks_proc, ossimplugins::ErsSarFacilityData::_num_duplic_input_lines, ossimplugins::ErsSarFacilityData::_num_input_raw_data_lines, ossimplugins::ErsSarFacilityData::_num_range_samp_discarded, ossimplugins::ErsSarFacilityData::_num_valid_cal_pulses, ossimplugins::ErsSarFacilityData::_num_valid_noise_pulses, ossimplugins::ErsSarFacilityData::_num_valid_pixels_per_range, ossimplugins::ErsSarFacilityData::_num_valid_replicas, ossimplugins::ErsSarFacilityData::_OGOB_flag, ossimplugins::ErsSarFacilityData::_out_image_max_value, ossimplugins::ErsSarFacilityData::_out_image_mean, ossimplugins::ErsSarFacilityData::_out_image_std_dev, ossimplugins::ErsSarFacilityData::_out_pixel_bit_length, ossimplugins::ErsSarFacilityData::_outp_data_mean_flag, ossimplugins::ErsSarFacilityData::_peak_loc_CCF_betw_last, ossimplugins::ErsSarFacilityData::_peak_loc_cross_correl_fun, ossimplugins::ErsSarFacilityData::_PRF_changes, ossimplugins::ErsSarFacilityData::_prf_code_change_flag, ossimplugins::ErsSarFacilityData::_PRF_code_first_range_line, ossimplugins::ErsSarFacilityData::_PRF_code_last_range_line, ossimplugins::ErsSarFacilityData::_proc_gain_param_1, ossimplugins::ErsSarFacilityData::_proc_gain_param_2, ossimplugins::ErsSarFacilityData::_proc_gain_param_3, ossimplugins::ErsSarFacilityData::_proc_noise_scale_fact, ossimplugins::ErsSarFacilityData::_pulse_width_of_ACF_3db, ossimplugins::ErsSarFacilityData::_Q_channel_bias_correction, ossimplugins::ErsSarFacilityData::_Q_channel_gain_correction, ossimplugins::ErsSarFacilityData::_Q_channel_I_Q_correction, ossimplugins::ErsSarFacilityData::_qa_summary_flag, ossimplugins::ErsSarFacilityData::_quirp_qu_flag, ossimplugins::ErsSarFacilityData::_range_comp_norm_fact, ossimplugins::ErsSarFacilityData::_range_lines_skip_factor, ossimplugins::ErsSarFacilityData::_range_spread_loss_comp_flag, ossimplugins::ErsSarFacilityData::_range_time_origin_ant, ossimplugins::ErsSarFacilityData::_raw_data_correction_flag, ossimplugins::ErsSarFacilityData::_rec_gain_changes, ossimplugins::ErsSarFacilityData::_receiver_gain_last_proc, ossimplugins::ErsSarFacilityData::_replica_norm_method_flag, ossimplugins::ErsSarFacilityData::_replica_power, ossimplugins::ErsSarFacilityData::_Roll_Tilt_Mode_flag, ossimplugins::ErsSarFacilityData::_samp_win_start_first, ossimplugins::ErsSarFacilityData::_samp_win_start_last, ossimplugins::ErsSarFacilityData::_samp_window_start_time_bias, ossimplugins::ErsSarFacilityData::_samples_per_line_used, ossimplugins::ErsSarFacilityData::_sampling_win_change_flag, ossimplugins::ErsSarFacilityData::_sampling_win_changes, ossimplugins::ErsSarFacilityData::_sat_binary_time_of_first, ossimplugins::ErsSarFacilityData::_thresh_no_10_flag, ossimplugins::ErsSarFacilityData::_thresh_no_11_flag, ossimplugins::ErsSarFacilityData::_thresh_no_1_flag, ossimplugins::ErsSarFacilityData::_thresh_no_2_flag, ossimplugins::ErsSarFacilityData::_thresh_no_3_flag, ossimplugins::ErsSarFacilityData::_thresh_no_4_flag, ossimplugins::ErsSarFacilityData::_thresh_no_5_flag, ossimplugins::ErsSarFacilityData::_thresh_no_6_flag, ossimplugins::ErsSarFacilityData::_thresh_no_7_flag, ossimplugins::ErsSarFacilityData::_thresh_no_8_flag, ossimplugins::ErsSarFacilityData::_thresh_no_9_flag, ossimplugins::ErsSarFacilityData::_time_asc_node_state_vectors, ossimplugins::ErsSarFacilityData::_time_of_inp_state_vectors, ossimplugins::ErsSarFacilityData::_time_raw_data_first_input, ossimplugins::ErsSarFacilityData::_update_period_range_match, ossimplugins::ErsSarFacilityData::_upp_bound_K, ossimplugins::ErsSarFacilityData::_win_coeff_for_azi_match, and ossimplugins::ErsSarFacilityData::_win_coeff_for_range_match.
| const DataHistogramSignalData & | data | ||
Definition at line 25 of file DataHistogramSignalData.cpp.
References ossimplugins::DataHistogramSignalData::_histogram, ossimplugins::DataHistogramSignalData::_ltab, ossimplugins::DataHistogramSignalData::_ntab, ossimplugins::DataHistogramSignalData::_rec_seq, and ossimplugins::DataHistogramSignalData::_sar_chn.
| const ErsSarMapProjectionData & | data | ||
Definition at line 25 of file ErsSarMapProjectionData.cpp.
References ossimplugins::ErsSarMapProjectionData::_asc_node_long, ossimplugins::ErsSarMapProjectionData::_first_line_first_pixel_lat, ossimplugins::ErsSarMapProjectionData::_first_line_first_pixel_lon, ossimplugins::ErsSarMapProjectionData::_first_line_last_pixel_lat, ossimplugins::ErsSarMapProjectionData::_first_line_last_pixel_lon, ossimplugins::ErsSarMapProjectionData::_last_line_first_pixel_lat, ossimplugins::ErsSarMapProjectionData::_last_line_first_pixel_lon, ossimplugins::ErsSarMapProjectionData::_last_line_last_pixel_lat, ossimplugins::ErsSarMapProjectionData::_last_line_last_pixel_lon, ossimplugins::ErsSarMapProjectionData::_map_proj_des, ossimplugins::ErsSarMapProjectionData::_name_of_ref_ellipsoid, ossimplugins::ErsSarMapProjectionData::_nom_interline_dist, ossimplugins::ErsSarMapProjectionData::_nom_interpixel_dist, ossimplugins::ErsSarMapProjectionData::_num_lines, ossimplugins::ErsSarMapProjectionData::_num_pix_in_line, ossimplugins::ErsSarMapProjectionData::_orbit_incl, ossimplugins::ErsSarMapProjectionData::_orientation_at_center, ossimplugins::ErsSarMapProjectionData::_platform_heading, ossimplugins::ErsSarMapProjectionData::_semi_maj_axis, and ossimplugins::ErsSarMapProjectionData::_semi_min_axis.
| const ChirpParameters & | data | ||
Definition at line 25 of file ChirpParameters.cpp.
References ossimplugins::ChirpParameters::_attach_flag, ossimplugins::ChirpParameters::_cal_pulse_info, ossimplugins::ChirpParameters::_chirp_islr, ossimplugins::ChirpParameters::_chirp_peak_loc, ossimplugins::ChirpParameters::_chirp_quality_flag, ossimplugins::ChirpParameters::_chirp_sidelobe, ossimplugins::ChirpParameters::_chirp_width, ossimplugins::ChirpParameters::_elev_chirp_power, ossimplugins::ChirpParameters::_normalisation_source, ossimplugins::ChirpParameters::_polar, ossimplugins::ChirpParameters::_re_chirp_power, ossimplugins::ChirpParameters::_ref_chirp_power, ossimplugins::ChirpParameters::_swath, and ossimplugins::ChirpParameters::_zero_doppler_time.
| const RadiometricData & | data | ||
Definition at line 25 of file RadiometricData.cpp.
References ossimplugins::RadiometricData::_calib_const, ossimplugins::RadiometricData::_chan_ind, ossimplugins::RadiometricData::_field_size, ossimplugins::RadiometricData::_lookup_tab, ossimplugins::RadiometricData::_n_data, ossimplugins::RadiometricData::_n_samp, ossimplugins::RadiometricData::_noise_scale, ossimplugins::RadiometricData::_offset, ossimplugins::RadiometricData::_samp_inc, ossimplugins::RadiometricData::_samp_type, ossimplugins::RadiometricData::_seq_num, and ossimplugins::RadiometricData::_table_desig.
| const DopplerCentroidParameters & | data | ||
Definition at line 25 of file DopplerCentroidParameters.cpp.
References ossimplugins::DopplerCentroidParameters::_attach_flag, ossimplugins::DopplerCentroidParameters::_delta_dopp_coeff, ossimplugins::DopplerCentroidParameters::_dop_coef, ossimplugins::DopplerCentroidParameters::_dop_conf, ossimplugins::DopplerCentroidParameters::_dop_conf_below_thresh_flag, ossimplugins::DopplerCentroidParameters::_slant_range_time, and ossimplugins::DopplerCentroidParameters::_zero_doppler_time.
| const AttitudeData & | data | ||
Definition at line 26 of file AttitudeData.cpp.
References ossimplugins::AttitudeData::_att_vect, ossimplugins::AttitudeData::_npoint, ossimplugins::AttitudeData::_pitch_bias, ossimplugins::AttitudeData::_roll_bias, and ossimplugins::AttitudeData::_yaw_bias.
| const SQ_ADSR & | data | ||
Definition at line 26 of file SQ_ADSR.cpp.
References ossimplugins::SQ_ADSR::_attach_flag, ossimplugins::SQ_ADSR::_chirp_flag, ossimplugins::SQ_ADSR::_dop_amb_flag, ossimplugins::SQ_ADSR::_dop_cen_flag, ossimplugins::SQ_ADSR::_exp_input_mean, ossimplugins::SQ_ADSR::_exp_input_std_dev, ossimplugins::SQ_ADSR::_exp_output_mean, ossimplugins::SQ_ADSR::_exp_output_std_dev, ossimplugins::SQ_ADSR::_input_gaps_flag, ossimplugins::SQ_ADSR::_input_mean, ossimplugins::SQ_ADSR::_input_mean_flag, ossimplugins::SQ_ADSR::_input_missing_lines_flag, ossimplugins::SQ_ADSR::_input_std_dev, ossimplugins::SQ_ADSR::_input_std_dev_flag, ossimplugins::SQ_ADSR::_invalid_downlink_flag, ossimplugins::SQ_ADSR::_lines_per_gaps, ossimplugins::SQ_ADSR::_missing_data_set_flag, ossimplugins::SQ_ADSR::_num_gaps, ossimplugins::SQ_ADSR::_num_missing_lines, ossimplugins::SQ_ADSR::_output_mean, ossimplugins::SQ_ADSR::_output_mean_flag, ossimplugins::SQ_ADSR::_output_std_dev, ossimplugins::SQ_ADSR::_output_std_dev_flag, ossimplugins::SQ_ADSR::_thres_chirp_broadening, ossimplugins::SQ_ADSR::_thresh_chirp_islr, ossimplugins::SQ_ADSR::_thresh_chirp_sidelobe, ossimplugins::SQ_ADSR::_thresh_dop_amb, ossimplugins::SQ_ADSR::_thresh_dop_cen, ossimplugins::SQ_ADSR::_thresh_input_gaps, ossimplugins::SQ_ADSR::_thresh_input_mean, ossimplugins::SQ_ADSR::_thresh_input_missing_lines, ossimplugins::SQ_ADSR::_thresh_input_std_dev, ossimplugins::SQ_ADSR::_thresh_output_mean, ossimplugins::SQ_ADSR::_thresh_output_std_dev, ossimplugins::SQ_ADSR::_tot_errors, and ossimplugins::SQ_ADSR::_zero_doppler_time.
| const AlosPalsarDataSetSummary & | data | ||
from 1767 to 4096 to be added
Definition at line 26 of file AlosPalsarDataSetSummary.cpp.
References ossimplugins::AlosPalsarDataSetSummary::_algor_id, ossimplugins::AlosPalsarDataSetSummary::_alt_dopcen, ossimplugins::AlosPalsarDataSetSummary::_alt_rate, ossimplugins::AlosPalsarDataSetSummary::_ampl_coef, ossimplugins::AlosPalsarDataSetSummary::_asc_des, ossimplugins::AlosPalsarDataSetSummary::_auto_focus, ossimplugins::AlosPalsarDataSetSummary::_azi_res, ossimplugins::AlosPalsarDataSetSummary::_azi_weight, ossimplugins::AlosPalsarDataSetSummary::_baseband_f, ossimplugins::AlosPalsarDataSetSummary::_bnd_azi, ossimplugins::AlosPalsarDataSetSummary::_bnd_azilok, ossimplugins::AlosPalsarDataSetSummary::_bnd_rng, ossimplugins::AlosPalsarDataSetSummary::_bnd_rnglok, ossimplugins::AlosPalsarDataSetSummary::_chirp_ext_ind, ossimplugins::AlosPalsarDataSetSummary::_chn_bits, ossimplugins::AlosPalsarDataSetSummary::_clock_ang, ossimplugins::AlosPalsarDataSetSummary::_clutter_lock, ossimplugins::AlosPalsarDataSetSummary::_crt_dopcen, ossimplugins::AlosPalsarDataSetSummary::_crt_rate, ossimplugins::AlosPalsarDataSetSummary::_data_inpsrc, ossimplugins::AlosPalsarDataSetSummary::_dopcen_range, ossimplugins::AlosPalsarDataSetSummary::_earth_mass, ossimplugins::AlosPalsarDataSetSummary::_ellip_des, ossimplugins::AlosPalsarDataSetSummary::_ellip_j, ossimplugins::AlosPalsarDataSetSummary::_ellip_maj, ossimplugins::AlosPalsarDataSetSummary::_ellip_min, ossimplugins::AlosPalsarDataSetSummary::_fa, ossimplugins::AlosPalsarDataSetSummary::_fac_id, ossimplugins::AlosPalsarDataSetSummary::_fr, ossimplugins::AlosPalsarDataSetSummary::_gn_cross, ossimplugins::AlosPalsarDataSetSummary::_gn_polar, ossimplugins::AlosPalsarDataSetSummary::_grav_const, ossimplugins::AlosPalsarDataSetSummary::_i_bias, ossimplugins::AlosPalsarDataSetSummary::_incident_ang, ossimplugins::AlosPalsarDataSetSummary::_inp_sctim, ossimplugins::AlosPalsarDataSetSummary::_iq_ratio, ossimplugins::AlosPalsarDataSetSummary::_line_cont, ossimplugins::AlosPalsarDataSetSummary::_line_spacing, ossimplugins::AlosPalsarDataSetSummary::_mech_sight, ossimplugins::AlosPalsarDataSetSummary::_mission_id, ossimplugins::AlosPalsarDataSetSummary::_motion_comp, ossimplugins::AlosPalsarDataSetSummary::_n_azilok, ossimplugins::AlosPalsarDataSetSummary::_n_rnglok, ossimplugins::AlosPalsarDataSetSummary::_nchn, ossimplugins::AlosPalsarDataSetSummary::_orbit_num, ossimplugins::AlosPalsarDataSetSummary::_phas_coef, ossimplugins::AlosPalsarDataSetSummary::_pix_spacing, ossimplugins::AlosPalsarDataSetSummary::_plat_head, ossimplugins::AlosPalsarDataSetSummary::_plat_lat, ossimplugins::AlosPalsarDataSetSummary::_plat_long, ossimplugins::AlosPalsarDataSetSummary::_pro_head, ossimplugins::AlosPalsarDataSetSummary::_pro_lat, ossimplugins::AlosPalsarDataSetSummary::_pro_long, ossimplugins::AlosPalsarDataSetSummary::_prod_type, ossimplugins::AlosPalsarDataSetSummary::_pulse_code, ossimplugins::AlosPalsarDataSetSummary::_q_bias, ossimplugins::AlosPalsarDataSetSummary::_quant_desc, ossimplugins::AlosPalsarDataSetSummary::_rng_gate, ossimplugins::AlosPalsarDataSetSummary::_rng_length, ossimplugins::AlosPalsarDataSetSummary::_rng_res, ossimplugins::AlosPalsarDataSetSummary::_rng_weight, ossimplugins::AlosPalsarDataSetSummary::_rngcmp_desg, ossimplugins::AlosPalsarDataSetSummary::_rngcmp_f, ossimplugins::AlosPalsarDataSetSummary::_sar_chn, ossimplugins::AlosPalsarDataSetSummary::_sat_bintim, ossimplugins::AlosPalsarDataSetSummary::_sat_clkinc, ossimplugins::AlosPalsarDataSetSummary::_sat_clktim, ossimplugins::AlosPalsarDataSetSummary::_sc_lin, ossimplugins::AlosPalsarDataSetSummary::_sc_pix, ossimplugins::AlosPalsarDataSetSummary::_scene_des, ossimplugins::AlosPalsarDataSetSummary::_scene_id, ossimplugins::AlosPalsarDataSetSummary::_scene_len, ossimplugins::AlosPalsarDataSetSummary::_scene_wid, ossimplugins::AlosPalsarDataSetSummary::_sensor_id, ossimplugins::AlosPalsarDataSetSummary::_seq_num, ossimplugins::AlosPalsarDataSetSummary::_sys_id, ossimplugins::AlosPalsarDataSetSummary::_terrain_h, ossimplugins::AlosPalsarDataSetSummary::_time_dir_lin, ossimplugins::AlosPalsarDataSetSummary::_time_dir_pix, ossimplugins::AlosPalsarDataSetSummary::_ver_id, and ossimplugins::AlosPalsarDataSetSummary::_wave_length.
| const AlosPalsarMapProjectionData & | data | ||
Definition at line 26 of file AlosPalsarMapProjectionData.cpp.
References ossimplugins::AlosPalsarMapProjectionData::_asc_node_long, ossimplugins::AlosPalsarMapProjectionData::_first_line_first_pixel_lat, ossimplugins::AlosPalsarMapProjectionData::_first_line_first_pixel_lon, ossimplugins::AlosPalsarMapProjectionData::_first_line_last_pixel_lat, ossimplugins::AlosPalsarMapProjectionData::_first_line_last_pixel_lon, ossimplugins::AlosPalsarMapProjectionData::_last_line_first_pixel_lat, ossimplugins::AlosPalsarMapProjectionData::_last_line_first_pixel_lon, ossimplugins::AlosPalsarMapProjectionData::_last_line_last_pixel_lat, ossimplugins::AlosPalsarMapProjectionData::_last_line_last_pixel_lon, ossimplugins::AlosPalsarMapProjectionData::_map_proj_des, ossimplugins::AlosPalsarMapProjectionData::_name_of_ref_ellipsoid, ossimplugins::AlosPalsarMapProjectionData::_nom_interline_dist, ossimplugins::AlosPalsarMapProjectionData::_nom_interpixel_dist, ossimplugins::AlosPalsarMapProjectionData::_num_lines, ossimplugins::AlosPalsarMapProjectionData::_num_pix_in_line, ossimplugins::AlosPalsarMapProjectionData::_orbit_incl, ossimplugins::AlosPalsarMapProjectionData::_orientation_at_center, ossimplugins::AlosPalsarMapProjectionData::_platform_heading, ossimplugins::AlosPalsarMapProjectionData::_semi_maj_axis, and ossimplugins::AlosPalsarMapProjectionData::_semi_min_axis.
| const ErsSarFileDescriptor & | data | ||
Definition at line 26 of file ErsSarFileDescriptor.cpp.
References ossimplugins::ErsSarFileDescriptor::_ascii_flag, ossimplugins::ErsSarFileDescriptor::_code_len, ossimplugins::ErsSarFileDescriptor::_code_loc, ossimplugins::ErsSarFileDescriptor::_design_rev, ossimplugins::ErsSarFileDescriptor::_file_name, ossimplugins::ErsSarFileDescriptor::_file_num, ossimplugins::ErsSarFileDescriptor::_format_doc, ossimplugins::ErsSarFileDescriptor::_format_ver, ossimplugins::ErsSarFileDescriptor::_l_anno_data, ossimplugins::ErsSarFileDescriptor::_l_att_data, ossimplugins::ErsSarFileDescriptor::_l_cal, ossimplugins::ErsSarFileDescriptor::_l_data_his, ossimplugins::ErsSarFileDescriptor::_l_dataset, ossimplugins::ErsSarFileDescriptor::_l_dem_desc, ossimplugins::ErsSarFileDescriptor::_l_det_proc, ossimplugins::ErsSarFileDescriptor::_l_fac_data, ossimplugins::ErsSarFileDescriptor::_l_gcp, ossimplugins::ErsSarFileDescriptor::_l_map_proj, ossimplugins::ErsSarFileDescriptor::_l_plat_pos, ossimplugins::ErsSarFileDescriptor::_l_qual_sum, ossimplugins::ErsSarFileDescriptor::_l_radar_par, ossimplugins::ErsSarFileDescriptor::_l_radi_comp, ossimplugins::ErsSarFileDescriptor::_l_radi_data, ossimplugins::ErsSarFileDescriptor::_l_rang_spec, ossimplugins::ErsSarFileDescriptor::_n_anno_data, ossimplugins::ErsSarFileDescriptor::_n_att_data, ossimplugins::ErsSarFileDescriptor::_n_cal, ossimplugins::ErsSarFileDescriptor::_n_data_his, ossimplugins::ErsSarFileDescriptor::_n_dataset, ossimplugins::ErsSarFileDescriptor::_n_dem_desc, ossimplugins::ErsSarFileDescriptor::_n_det_proc, ossimplugins::ErsSarFileDescriptor::_n_fac_data, ossimplugins::ErsSarFileDescriptor::_n_gcp, ossimplugins::ErsSarFileDescriptor::_n_map_proj, ossimplugins::ErsSarFileDescriptor::_n_plat_pos, ossimplugins::ErsSarFileDescriptor::_n_qual_sum, ossimplugins::ErsSarFileDescriptor::_n_radar_par, ossimplugins::ErsSarFileDescriptor::_n_radi_comp, ossimplugins::ErsSarFileDescriptor::_n_radi_data, ossimplugins::ErsSarFileDescriptor::_n_rang_spec, ossimplugins::ErsSarFileDescriptor::_rec_code, ossimplugins::ErsSarFileDescriptor::_rec_len, ossimplugins::ErsSarFileDescriptor::_rec_seq, ossimplugins::ErsSarFileDescriptor::_rlen_len, ossimplugins::ErsSarFileDescriptor::_rlen_loc, ossimplugins::ErsSarFileDescriptor::_seq_len, ossimplugins::ErsSarFileDescriptor::_seq_loc, and ossimplugins::ErsSarFileDescriptor::_software_id.
| const AlosPalsarFacilityData & | data | ||
Definition at line 26 of file AlosPalsarFacilityData.cpp.
References ossimplugins::AlosPalsarFacilityData::_3_dB_look_bandwidth, ossimplugins::AlosPalsarFacilityData::_3_dB_look_proc_dopp_bandw, ossimplugins::AlosPalsarFacilityData::_3_dB_width_CCF, ossimplugins::AlosPalsarFacilityData::_abs_cal_const_K, ossimplugins::AlosPalsarFacilityData::_antenna_elev_flag, ossimplugins::AlosPalsarFacilityData::_asc_node_pos_X_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_pos_Y_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_pos_Z_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_vel_X_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_vel_Y_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_vel_Z_comp, ossimplugins::AlosPalsarFacilityData::_autom_look_scal_gain_flag, ossimplugins::AlosPalsarFacilityData::_azimuth_baseband_convers_flag, ossimplugins::AlosPalsarFacilityData::_azimuth_FFT_IFFT_ratio, ossimplugins::AlosPalsarFacilityData::_cal_gain_change_flag, ossimplugins::AlosPalsarFacilityData::_cal_gain_changes, ossimplugins::AlosPalsarFacilityData::_cal_sys_gain, ossimplugins::AlosPalsarFacilityData::_cal_syst_gain_last_proc, ossimplugins::AlosPalsarFacilityData::_center_range_pix_mid_az_inc, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_1, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_2, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_3, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_4, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_5, ossimplugins::AlosPalsarFacilityData::_coef_ground_range_1, ossimplugins::AlosPalsarFacilityData::_coef_ground_range_2, ossimplugins::AlosPalsarFacilityData::_coef_ground_range_3, ossimplugins::AlosPalsarFacilityData::_coef_ground_range_4, ossimplugins::AlosPalsarFacilityData::_datation_flag, ossimplugins::AlosPalsarFacilityData::_dopp_ambig_conf_meas, ossimplugins::AlosPalsarFacilityData::_dopp_ambig_conf_meas_flag, ossimplugins::AlosPalsarFacilityData::_dopp_ambig_num, ossimplugins::AlosPalsarFacilityData::_dopp_cent_conf_meas, ossimplugins::AlosPalsarFacilityData::_dopp_cent_conf_meas_flag, ossimplugins::AlosPalsarFacilityData::_dopp_cent_val_flag, ossimplugins::AlosPalsarFacilityData::_doppler_ambiguity_estimat_flag, ossimplugins::AlosPalsarFacilityData::_doppler_centroid_cubic_coeff, ossimplugins::AlosPalsarFacilityData::_estim_bit_error_rate, ossimplugins::AlosPalsarFacilityData::_first_processed_range_sample, ossimplugins::AlosPalsarFacilityData::_first_range_pixel_mid_az_inc, ossimplugins::AlosPalsarFacilityData::_first_rec_gain_read, ossimplugins::AlosPalsarFacilityData::_first_replica_sample, ossimplugins::AlosPalsarFacilityData::_first_side_lobe_lev_of_ACF, ossimplugins::AlosPalsarFacilityData::_first_side_lobe_level, ossimplugins::AlosPalsarFacilityData::_form_num_range_line_used, ossimplugins::AlosPalsarFacilityData::_I_channel_bias_correction, ossimplugins::AlosPalsarFacilityData::_I_channel_gain_correction, ossimplugins::AlosPalsarFacilityData::_I_gain_imb_lower_bound, ossimplugins::AlosPalsarFacilityData::_I_gain_imb_upper_bound, ossimplugins::AlosPalsarFacilityData::_I_Q_quad_depar_lower_bound, ossimplugins::AlosPalsarFacilityData::_I_Q_quad_depar_upper_bound, ossimplugins::AlosPalsarFacilityData::_initial_doppler_ambiguity_num, ossimplugins::AlosPalsarFacilityData::_inp_data_I_mean, ossimplugins::AlosPalsarFacilityData::_inp_data_I_stddev, ossimplugins::AlosPalsarFacilityData::_inp_data_Q_mean, ossimplugins::AlosPalsarFacilityData::_inp_data_Q_stddev, ossimplugins::AlosPalsarFacilityData::_inp_data_stat_flag, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_pos_X_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_pos_Y_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_pos_Z_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_vel_Vx_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_vel_Vy_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_vel_Vz_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vector_type_flag, ossimplugins::AlosPalsarFacilityData::_int_cal_utc, ossimplugins::AlosPalsarFacilityData::_ISLR_CCF_between_last, ossimplugins::AlosPalsarFacilityData::_ISLR_of_ACF, ossimplugins::AlosPalsarFacilityData::_K_gen_date, ossimplugins::AlosPalsarFacilityData::_K_vers_num, ossimplugins::AlosPalsarFacilityData::_last_range_pix_mid_az_inc, ossimplugins::AlosPalsarFacilityData::_last_release_cal_date, ossimplugins::AlosPalsarFacilityData::_last_release_qc_date, ossimplugins::AlosPalsarFacilityData::_look_detecion_flag, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_1, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_2, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_3, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_4, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_5, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_6, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_7, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_8, ossimplugins::AlosPalsarFacilityData::_low_bound_K, ossimplugins::AlosPalsarFacilityData::_max_error_range_line_timing, ossimplugins::AlosPalsarFacilityData::_max_value_look_scalar_gain, ossimplugins::AlosPalsarFacilityData::_mean_cal_pulse_power, ossimplugins::AlosPalsarFacilityData::_mean_noise_power, ossimplugins::AlosPalsarFacilityData::_missing_lines, ossimplugins::AlosPalsarFacilityData::_noise_power, ossimplugins::AlosPalsarFacilityData::_norm_ref_range_ro, ossimplugins::AlosPalsarFacilityData::_num_azimuth_blocks_proc, ossimplugins::AlosPalsarFacilityData::_num_duplic_input_lines, ossimplugins::AlosPalsarFacilityData::_num_input_raw_data_lines, ossimplugins::AlosPalsarFacilityData::_num_range_samp_discarded, ossimplugins::AlosPalsarFacilityData::_num_valid_cal_pulses, ossimplugins::AlosPalsarFacilityData::_num_valid_noise_pulses, ossimplugins::AlosPalsarFacilityData::_num_valid_pixels_per_range, ossimplugins::AlosPalsarFacilityData::_num_valid_replicas, ossimplugins::AlosPalsarFacilityData::_OGOB_flag, ossimplugins::AlosPalsarFacilityData::_out_image_max_value, ossimplugins::AlosPalsarFacilityData::_out_image_mean, ossimplugins::AlosPalsarFacilityData::_out_image_std_dev, ossimplugins::AlosPalsarFacilityData::_out_pixel_bit_length, ossimplugins::AlosPalsarFacilityData::_outp_data_mean_flag, ossimplugins::AlosPalsarFacilityData::_peak_loc_CCF_betw_last, ossimplugins::AlosPalsarFacilityData::_peak_loc_cross_correl_fun, ossimplugins::AlosPalsarFacilityData::_PRF_changes, ossimplugins::AlosPalsarFacilityData::_prf_code_change_flag, ossimplugins::AlosPalsarFacilityData::_PRF_code_first_range_line, ossimplugins::AlosPalsarFacilityData::_PRF_code_last_range_line, ossimplugins::AlosPalsarFacilityData::_proc_gain_param_1, ossimplugins::AlosPalsarFacilityData::_proc_gain_param_2, ossimplugins::AlosPalsarFacilityData::_proc_gain_param_3, ossimplugins::AlosPalsarFacilityData::_proc_noise_scale_fact, ossimplugins::AlosPalsarFacilityData::_pulse_width_of_ACF_3db, ossimplugins::AlosPalsarFacilityData::_Q_channel_bias_correction, ossimplugins::AlosPalsarFacilityData::_Q_channel_gain_correction, ossimplugins::AlosPalsarFacilityData::_Q_channel_I_Q_correction, ossimplugins::AlosPalsarFacilityData::_qa_summary_flag, ossimplugins::AlosPalsarFacilityData::_quirp_qu_flag, ossimplugins::AlosPalsarFacilityData::_range_comp_norm_fact, ossimplugins::AlosPalsarFacilityData::_range_lines_skip_factor, ossimplugins::AlosPalsarFacilityData::_range_spread_loss_comp_flag, ossimplugins::AlosPalsarFacilityData::_range_time_origin_ant, ossimplugins::AlosPalsarFacilityData::_raw_data_correction_flag, ossimplugins::AlosPalsarFacilityData::_rec_gain_changes, ossimplugins::AlosPalsarFacilityData::_receiver_gain_last_proc, ossimplugins::AlosPalsarFacilityData::_replica_norm_method_flag, ossimplugins::AlosPalsarFacilityData::_replica_power, ossimplugins::AlosPalsarFacilityData::_Roll_Tilt_Mode_flag, ossimplugins::AlosPalsarFacilityData::_samp_win_start_first, ossimplugins::AlosPalsarFacilityData::_samp_win_start_last, ossimplugins::AlosPalsarFacilityData::_samp_window_start_time_bias, ossimplugins::AlosPalsarFacilityData::_samples_per_line_used, ossimplugins::AlosPalsarFacilityData::_sampling_win_change_flag, ossimplugins::AlosPalsarFacilityData::_sampling_win_changes, ossimplugins::AlosPalsarFacilityData::_sat_binary_time_of_first, ossimplugins::AlosPalsarFacilityData::_thresh_no_10_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_11_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_1_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_2_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_3_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_4_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_5_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_6_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_7_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_8_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_9_flag, ossimplugins::AlosPalsarFacilityData::_time_asc_node_state_vectors, ossimplugins::AlosPalsarFacilityData::_time_of_inp_state_vectors, ossimplugins::AlosPalsarFacilityData::_time_raw_data_first_input, ossimplugins::AlosPalsarFacilityData::_update_period_range_match, ossimplugins::AlosPalsarFacilityData::_upp_bound_K, ossimplugins::AlosPalsarFacilityData::_win_coeff_for_azi_match, and ossimplugins::AlosPalsarFacilityData::_win_coeff_for_range_match.
| std::ostream& ossimplugins::operator<< | ( | std::ostream & | os, |
| const ErsSarPlatformPositionData & | data | ||
Definition at line 26 of file ErsSarPlatformPositionData.cpp.
References ossimplugins::ErsSarPlatformPositionData::_alt_poserr, ossimplugins::ErsSarPlatformPositionData::_alt_velerr, ossimplugins::ErsSarPlatformPositionData::_crt_poserr, ossimplugins::ErsSarPlatformPositionData::_crt_velerr, ossimplugins::ErsSarPlatformPositionData::_data_int, ossimplugins::ErsSarPlatformPositionData::_day, ossimplugins::ErsSarPlatformPositionData::_gmt_day, ossimplugins::ErsSarPlatformPositionData::_gmt_sec, ossimplugins::ErsSarPlatformPositionData::_hr_angle, ossimplugins::ErsSarPlatformPositionData::_month, ossimplugins::ErsSarPlatformPositionData::_ndata, ossimplugins::ErsSarPlatformPositionData::_orbit_ele, ossimplugins::ErsSarPlatformPositionData::_orbit_ele_desg, ossimplugins::ErsSarPlatformPositionData::_pos_vect, ossimplugins::ErsSarPlatformPositionData::_rad_poserr, ossimplugins::ErsSarPlatformPositionData::_rad_velerr, ossimplugins::ErsSarPlatformPositionData::_ref_coord, and ossimplugins::ErsSarPlatformPositionData::_year.
| const ErsSarPositionVectorRecord & | data | ||
Definition at line 26 of file ErsSarPositionVectorRecord.cpp.
References ossimplugins::ErsSarPositionVectorRecord::_pos, and ossimplugins::ErsSarPositionVectorRecord::_vel.
| const ErsSarRecordHeader & | data | ||
Definition at line 26 of file ErsSarRecordHeader.cpp.
References ossimplugins::ErsSarRecordHeader::_length, ossimplugins::ErsSarRecordHeader::_rec_seq, ossimplugins::ErsSarRecordHeader::_rec_sub1, ossimplugins::ErsSarRecordHeader::_rec_sub2, ossimplugins::ErsSarRecordHeader::_rec_sub3, and ossimplugins::ErsSarRecordHeader::_rec_type.
| const AlosPalsarFileDescriptor & | data | ||
Definition at line 27 of file AlosPalsarFileDescriptor.cpp.
References ossimplugins::AlosPalsarFileDescriptor::_ascii_flag, ossimplugins::AlosPalsarFileDescriptor::_code_len, ossimplugins::AlosPalsarFileDescriptor::_code_loc, ossimplugins::AlosPalsarFileDescriptor::_continuation_flag, ossimplugins::AlosPalsarFileDescriptor::_design_rev, ossimplugins::AlosPalsarFileDescriptor::_file_name, ossimplugins::AlosPalsarFileDescriptor::_file_num, ossimplugins::AlosPalsarFileDescriptor::_format_doc, ossimplugins::AlosPalsarFileDescriptor::_format_ver, ossimplugins::AlosPalsarFileDescriptor::_l_anno_data, ossimplugins::AlosPalsarFileDescriptor::_l_att_data, ossimplugins::AlosPalsarFileDescriptor::_l_cal, ossimplugins::AlosPalsarFileDescriptor::_l_data_his, ossimplugins::AlosPalsarFileDescriptor::_l_dataset, ossimplugins::AlosPalsarFileDescriptor::_l_dem_desc, ossimplugins::AlosPalsarFileDescriptor::_l_det_proc, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data10, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data11, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data2, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data3, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data4, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data5, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data6, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data7, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data8, ossimplugins::AlosPalsarFileDescriptor::_l_fac_data9, ossimplugins::AlosPalsarFileDescriptor::_l_gcp, ossimplugins::AlosPalsarFileDescriptor::_l_map_proj, ossimplugins::AlosPalsarFileDescriptor::_l_plat_pos, ossimplugins::AlosPalsarFileDescriptor::_l_qual_sum, ossimplugins::AlosPalsarFileDescriptor::_l_radar_par, ossimplugins::AlosPalsarFileDescriptor::_l_radi_comp, ossimplugins::AlosPalsarFileDescriptor::_l_radi_data, ossimplugins::AlosPalsarFileDescriptor::_l_rang_spec, ossimplugins::AlosPalsarFileDescriptor::_n_anno_data, ossimplugins::AlosPalsarFileDescriptor::_n_att_data, ossimplugins::AlosPalsarFileDescriptor::_n_cal, ossimplugins::AlosPalsarFileDescriptor::_n_data_his, ossimplugins::AlosPalsarFileDescriptor::_n_dataset, ossimplugins::AlosPalsarFileDescriptor::_n_dem_desc, ossimplugins::AlosPalsarFileDescriptor::_n_det_proc, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data10, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data11, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data2, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data3, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data4, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data5, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data6, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data7, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data8, ossimplugins::AlosPalsarFileDescriptor::_n_fac_data9, ossimplugins::AlosPalsarFileDescriptor::_n_gcp, ossimplugins::AlosPalsarFileDescriptor::_n_map_proj, ossimplugins::AlosPalsarFileDescriptor::_n_plat_pos, ossimplugins::AlosPalsarFileDescriptor::_n_qual_sum, ossimplugins::AlosPalsarFileDescriptor::_n_radar_par, ossimplugins::AlosPalsarFileDescriptor::_n_radi_comp, ossimplugins::AlosPalsarFileDescriptor::_n_radi_data, ossimplugins::AlosPalsarFileDescriptor::_n_rang_spec, ossimplugins::AlosPalsarFileDescriptor::_rec_code, ossimplugins::AlosPalsarFileDescriptor::_rec_len, ossimplugins::AlosPalsarFileDescriptor::_rec_seq, ossimplugins::AlosPalsarFileDescriptor::_rlen_len, ossimplugins::AlosPalsarFileDescriptor::_rlen_loc, ossimplugins::AlosPalsarFileDescriptor::_seq_len, ossimplugins::AlosPalsarFileDescriptor::_seq_loc, and ossimplugins::AlosPalsarFileDescriptor::_software_id.
| const AlosPalsarRadiometricData & | data | ||
Definition at line 27 of file AlosPalsarRadiometricData.cpp.
References ossimplugins::AlosPalsarRadiometricData::_calibration_factor.
| const AlosPalsarPositionVectorRecord & | data | ||
Definition at line 27 of file AlosPalsarPositionVectorRecord.cpp.
References ossimplugins::AlosPalsarPositionVectorRecord::_pos, and ossimplugins::AlosPalsarPositionVectorRecord::_vel.
| const AlosPalsarDataFileDescriptor & | data | ||
Definition at line 27 of file AlosPalsarDataFileDescriptor.cpp.
References ossimplugins::AlosPalsarDataFileDescriptor::_num_lines, and ossimplugins::AlosPalsarDataFileDescriptor::_num_pix_in_line.
| const AlosPalsarRecordHeader & | data | ||
Definition at line 27 of file AlosPalsarRecordHeader.cpp.
References ossimplugins::AlosPalsarRecordHeader::_length, ossimplugins::AlosPalsarRecordHeader::_rec_seq, ossimplugins::AlosPalsarRecordHeader::_rec_sub1, ossimplugins::AlosPalsarRecordHeader::_rec_sub2, ossimplugins::AlosPalsarRecordHeader::_rec_sub3, and ossimplugins::AlosPalsarRecordHeader::_rec_type.
| const AlosPalsarPlatformPositionData & | data | ||
Definition at line 27 of file AlosPalsarPlatformPositionData.cpp.
References ossimplugins::AlosPalsarPlatformPositionData::_alt_poserr, ossimplugins::AlosPalsarPlatformPositionData::_alt_velerr, ossimplugins::AlosPalsarPlatformPositionData::_crt_poserr, ossimplugins::AlosPalsarPlatformPositionData::_crt_velerr, ossimplugins::AlosPalsarPlatformPositionData::_data_int, ossimplugins::AlosPalsarPlatformPositionData::_day, ossimplugins::AlosPalsarPlatformPositionData::_gmt_day, ossimplugins::AlosPalsarPlatformPositionData::_gmt_sec, ossimplugins::AlosPalsarPlatformPositionData::_hr_angle, ossimplugins::AlosPalsarPlatformPositionData::_month, ossimplugins::AlosPalsarPlatformPositionData::_ndata, ossimplugins::AlosPalsarPlatformPositionData::_orbit_ele, ossimplugins::AlosPalsarPlatformPositionData::_orbit_ele_desg, ossimplugins::AlosPalsarPlatformPositionData::_pos_vect, ossimplugins::AlosPalsarPlatformPositionData::_rad_poserr, ossimplugins::AlosPalsarPlatformPositionData::_rad_velerr, ossimplugins::AlosPalsarPlatformPositionData::_ref_coord, and ossimplugins::AlosPalsarPlatformPositionData::_year.
| const ImageOptionsFileDescriptor & | data | ||
Definition at line 28 of file ImageOptionsFileDescriptor.cpp.
References ossimplugins::ImageOptionsFileDescriptor::_ascii_flag, ossimplugins::ImageOptionsFileDescriptor::_bias_loc, ossimplugins::ImageOptionsFileDescriptor::_cali_loc, ossimplugins::ImageOptionsFileDescriptor::_chn_loc, ossimplugins::ImageOptionsFileDescriptor::_code_len, ossimplugins::ImageOptionsFileDescriptor::_code_loc, ossimplugins::ImageOptionsFileDescriptor::_design_rev, ossimplugins::ImageOptionsFileDescriptor::_file_name, ossimplugins::ImageOptionsFileDescriptor::_file_num, ossimplugins::ImageOptionsFileDescriptor::_format_doc, ossimplugins::ImageOptionsFileDescriptor::_format_rev, ossimplugins::ImageOptionsFileDescriptor::_gain_loc, ossimplugins::ImageOptionsFileDescriptor::_intleav, ossimplugins::ImageOptionsFileDescriptor::_justify, ossimplugins::ImageOptionsFileDescriptor::_l_dataset, ossimplugins::ImageOptionsFileDescriptor::_left_fill, ossimplugins::ImageOptionsFileDescriptor::_left_loc, ossimplugins::ImageOptionsFileDescriptor::_lin_loc, ossimplugins::ImageOptionsFileDescriptor::_n_dataset, ossimplugins::ImageOptionsFileDescriptor::_n_prefix, ossimplugins::ImageOptionsFileDescriptor::_n_sar, ossimplugins::ImageOptionsFileDescriptor::_n_suffix, ossimplugins::ImageOptionsFileDescriptor::_nbit, ossimplugins::ImageOptionsFileDescriptor::_nbott, ossimplugins::ImageOptionsFileDescriptor::_nbyte, ossimplugins::ImageOptionsFileDescriptor::_nchn, ossimplugins::ImageOptionsFileDescriptor::_ngrp, ossimplugins::ImageOptionsFileDescriptor::_nleft, ossimplugins::ImageOptionsFileDescriptor::_nlin, ossimplugins::ImageOptionsFileDescriptor::_nrec_chn, ossimplugins::ImageOptionsFileDescriptor::_nrec_lin, ossimplugins::ImageOptionsFileDescriptor::_nright, ossimplugins::ImageOptionsFileDescriptor::_nsamp, ossimplugins::ImageOptionsFileDescriptor::_ntop, ossimplugins::ImageOptionsFileDescriptor::_pad_ind, ossimplugins::ImageOptionsFileDescriptor::_pix_rng, ossimplugins::ImageOptionsFileDescriptor::_qual_loc, ossimplugins::ImageOptionsFileDescriptor::_rec_code, ossimplugins::ImageOptionsFileDescriptor::_rec_len, ossimplugins::ImageOptionsFileDescriptor::_rec_seq, ossimplugins::ImageOptionsFileDescriptor::_right_fill, ossimplugins::ImageOptionsFileDescriptor::_right_loc, ossimplugins::ImageOptionsFileDescriptor::_rlen_len, ossimplugins::ImageOptionsFileDescriptor::_rlen_loc, ossimplugins::ImageOptionsFileDescriptor::_seq_len, ossimplugins::ImageOptionsFileDescriptor::_seq_loc, ossimplugins::ImageOptionsFileDescriptor::_software_id, ossimplugins::ImageOptionsFileDescriptor::_tim_loc, ossimplugins::ImageOptionsFileDescriptor::_type_code, and ossimplugins::ImageOptionsFileDescriptor::_type_id.
| const AlosPalsarSignalData & | data | ||
Definition at line 29 of file AlosPalsarSignalData.cpp.
References ossimplugins::AlosPalsarSignalData::_pulse_repetition_frequency, and ossimplugins::AlosPalsarSignalData::_slant_range_to_1st_data_sample.
| const VolumeDir & | data | ||
Definition at line 34 of file VolumeDir.cpp.
References ossimplugins::VolumeDir::_records.
| const sph & | data | ||
Definition at line 34 of file sph.cpp.
References ossimplugins::sph::_algo_title, ossimplugins::sph::_algorithm, ossimplugins::sph::_azimut_looks, ossimplugins::sph::_azimut_looks_title, ossimplugins::sph::_azimut_spacing, ossimplugins::sph::_azimut_spacing_title, ossimplugins::sph::_azimut_spacing_unit, ossimplugins::sph::_compression, ossimplugins::sph::_compression_title, ossimplugins::sph::_data_type, ossimplugins::sph::_data_type_title, ossimplugins::sph::_first_far_lat, ossimplugins::sph::_first_far_lat_title, ossimplugins::sph::_first_far_lat_units, ossimplugins::sph::_first_far_long, ossimplugins::sph::_first_far_long_title, ossimplugins::sph::_first_far_long_units, ossimplugins::sph::_first_line_time, ossimplugins::sph::_first_line_time_title, ossimplugins::sph::_first_mid_lat, ossimplugins::sph::_first_mid_lat_title, ossimplugins::sph::_first_mid_lat_units, ossimplugins::sph::_first_mid_long, ossimplugins::sph::_first_mid_long_title, ossimplugins::sph::_first_mid_long_units, ossimplugins::sph::_first_near_lat, ossimplugins::sph::_first_near_lat_title, ossimplugins::sph::_first_near_lat_units, ossimplugins::sph::_first_near_long, ossimplugins::sph::_first_near_long_title, ossimplugins::sph::_first_near_long_units, ossimplugins::sph::_last_far_lat, ossimplugins::sph::_last_far_lat_title, ossimplugins::sph::_last_far_lat_units, ossimplugins::sph::_last_far_long, ossimplugins::sph::_last_far_long_title, ossimplugins::sph::_last_far_long_units, ossimplugins::sph::_last_line_time, ossimplugins::sph::_last_line_time_title, ossimplugins::sph::_last_mid_lat, ossimplugins::sph::_last_mid_lat_title, ossimplugins::sph::_last_mid_lat_units, ossimplugins::sph::_last_mid_long, ossimplugins::sph::_last_mid_long_title, ossimplugins::sph::_last_mid_long_units, ossimplugins::sph::_last_near_lat, ossimplugins::sph::_last_near_lat_title, ossimplugins::sph::_last_near_lat_units, ossimplugins::sph::_last_near_long, ossimplugins::sph::_last_near_long_title, ossimplugins::sph::_last_near_long_units, ossimplugins::sph::_line_length, ossimplugins::sph::_line_length_title, ossimplugins::sph::_line_length_units, ossimplugins::sph::_line_time_interv_units, ossimplugins::sph::_line_time_interval, ossimplugins::sph::_line_time_interval_title, ossimplugins::sph::_mds1_tx_rx_polar, ossimplugins::sph::_mds1_tx_rx_polar_title, ossimplugins::sph::_mds2_tx_rx_polar, ossimplugins::sph::_mds2_tx_rx_polar_title, ossimplugins::sph::_num_slices, ossimplugins::sph::_num_slices_title, ossimplugins::sph::_pass, ossimplugins::sph::_pass_title, ossimplugins::sph::_range_looks, ossimplugins::sph::_range_looks_title, ossimplugins::sph::_range_spacing, ossimplugins::sph::_range_spacing_title, ossimplugins::sph::_range_spacing_unit, ossimplugins::sph::_sample_type, ossimplugins::sph::_sample_type_title, ossimplugins::sph::_slice_pos_title, ossimplugins::sph::_slice_position, ossimplugins::sph::_sph_desc, ossimplugins::sph::_sph_desc_title, ossimplugins::sph::_strip_cont_ind, ossimplugins::sph::_strip_cont_ind_title, ossimplugins::sph::_swath, and ossimplugins::sph::_swath_title.
| const EnvisatAsarData & | data | ||
Definition at line 37 of file EnvisatAsarData.cpp.
References ossimplugins::EnvisatAsarData::_records.
| const Data & | data | ||
Definition at line 37 of file Data.cpp.
References ossimplugins::Data::_records.
| const AlosPalsarData & | data | ||
Definition at line 42 of file AlosPalsarData.cpp.
References ossimplugins::AlosPalsarData::_records.
| const Trailer & | data | ||
Definition at line 47 of file Trailer.cpp.
References ossimplugins::Trailer::_records.
| const AlosPalsarLeader & | data | ||
Definition at line 47 of file AlosPalsarLeader.cpp.
References ossimplugins::AlosPalsarLeader::_records.
| const ErsSarLeader & | data | ||
Definition at line 48 of file ErsSarLeader.cpp.
References ossimplugins::ErsSarLeader::theRecords.
| const Leader & | data | ||
Definition at line 52 of file Leader.cpp.
References ossimplugins::Leader::_records.
| const DataHistogramRecord & | data | ||
Definition at line 82 of file DataHistogramRecord.cpp.
References ossimplugins::DataHistogramRecord::_hist, ossimplugins::DataHistogramRecord::_hist_desc, ossimplugins::DataHistogramRecord::_max_hist, ossimplugins::DataHistogramRecord::_max_smp, ossimplugins::DataHistogramRecord::_mean_hist, ossimplugins::DataHistogramRecord::_mean_smp, ossimplugins::DataHistogramRecord::_min_hist, ossimplugins::DataHistogramRecord::_min_smp, ossimplugins::DataHistogramRecord::_nbin, ossimplugins::DataHistogramRecord::_ngrp_lin, ossimplugins::DataHistogramRecord::_ngrp_pix, ossimplugins::DataHistogramRecord::_nhist, ossimplugins::DataHistogramRecord::_nrec, ossimplugins::DataHistogramRecord::_ns_lin, ossimplugins::DataHistogramRecord::_ns_pix, ossimplugins::DataHistogramRecord::_nsamp_lin, ossimplugins::DataHistogramRecord::_nsamp_pix, ossimplugins::DataHistogramRecord::_smp_inc, ossimplugins::DataHistogramRecord::_std_hist, ossimplugins::DataHistogramRecord::_std_smp, and ossimplugins::DataHistogramRecord::_tab_seq.
| std::ostream& ossimplugins::operator<< | ( | std::ostream & | out, |
| const CivilDateTime & | obj | ||
Definition at line 469 of file CivilDateTime.cpp.
References ossimplugins::CivilDateTime::print().
| std::istream& ossimplugins::operator>> | ( | std::istream & | is, |
| MisregistrationRecord & | data | ||
Definition at line 31 of file MisregistrationRecord.cpp.
References ossimplugins::MisregistrationRecord::_alt_m, and ossimplugins::MisregistrationRecord::_crt_m.
| RadiometryUncertaintyRecord & | data | ||
Definition at line 31 of file RadiometryUncertaintyRecord.cpp.
References ossimplugins::RadiometryUncertaintyRecord::_db, and ossimplugins::RadiometryUncertaintyRecord::_deg.
Definition at line 34 of file AlosPalsarRadiometricData.cpp.
Definition at line 34 of file AlosPalsarDataFileDescriptor.cpp.
| TemperatureSettingsRecord & | data | ||
Definition at line 34 of file TemperatureSettingsRecord.cpp.
References ossimplugins::TemperatureSettingsRecord::_temp_set.
| RadarSatRecordHeader & | data | ||
Definition at line 35 of file RadarSatRecordHeader.cpp.
References ossimplugins::RadarSatRecordHeader::_length, ossimplugins::RadarSatRecordHeader::_rec_seq, ossimplugins::RadarSatRecordHeader::_rec_sub1, ossimplugins::RadarSatRecordHeader::_rec_sub2, ossimplugins::RadarSatRecordHeader::_rec_sub3, ossimplugins::RadarSatRecordHeader::_rec_type, and ossimplugins::RadarSatRecordHeader::SwitchEndian().
| BeamPixelCountRecord & | data | ||
Definition at line 35 of file BeamPixelCountRecord.cpp.
References ossimplugins::BeamPixelCountRecord::_n_pix, and ossimplugins::BeamPixelCountRecord::_pix_update.
| SRGRCoefficientSetRecord & | data | ||
Definition at line 35 of file SRGRCoefficientSetRecord.cpp.
References ossimplugins::SRGRCoefficientSetRecord::_srgr_coef, and ossimplugins::SRGRCoefficientSetRecord::_srgr_update.
| DopplerCentroidEstimateRecord & | data | ||
| dsd & | data | ||
Definition at line 37 of file dsd.cpp.
References ossimplugins::dsd::_ds_name, ossimplugins::dsd::_ds_offset, ossimplugins::dsd::_ds_size, ossimplugins::dsd::_ds_type, ossimplugins::dsd::_dsr_size, ossimplugins::dsd::_filename, and ossimplugins::dsd::_num_dsr.
| TextRecord & | data | ||
Definition at line 37 of file TextRecord.cpp.
References ossimplugins::TextRecord::_ascii_flag, ossimplugins::TextRecord::_cont_flag, ossimplugins::TextRecord::_copyright_info, ossimplugins::TextRecord::_phyvol_id, ossimplugins::TextRecord::_product_create, ossimplugins::TextRecord::_product_type, ossimplugins::TextRecord::_scene_id, and ossimplugins::TextRecord::_scene_loc.
| BeamInformationRecord & | data | ||
Definition at line 37 of file ErsSarRecordHeader.cpp.
References ossimplugins::ErsSarRecordHeader::_length, ossimplugins::ErsSarRecordHeader::_rec_seq, ossimplugins::ErsSarRecordHeader::_rec_sub1, ossimplugins::ErsSarRecordHeader::_rec_sub2, ossimplugins::ErsSarRecordHeader::_rec_sub3, ossimplugins::ErsSarRecordHeader::_rec_type, and ossimplugins::ErsSarRecordHeader::SwitchEndian().
Definition at line 38 of file PositionVectorRecord.cpp.
References ossimplugins::PositionVectorRecord::_pos, and ossimplugins::PositionVectorRecord::_vel.
Definition at line 38 of file AlosPalsarRecordHeader.cpp.
References ossimplugins::AlosPalsarRecordHeader::_length, ossimplugins::AlosPalsarRecordHeader::_rec_seq, ossimplugins::AlosPalsarRecordHeader::_rec_sub1, ossimplugins::AlosPalsarRecordHeader::_rec_sub2, ossimplugins::AlosPalsarRecordHeader::_rec_sub3, ossimplugins::AlosPalsarRecordHeader::_rec_type, and ossimplugins::AlosPalsarRecordHeader::SwitchEndian().
Definition at line 39 of file AttitudeData.cpp.
Definition at line 39 of file AlosPalsarSignalData.cpp.
References ossimplugins::AlosPalsarSignalData::_pulse_repetition_frequency, ossimplugins::AlosPalsarSignalData::_slant_range_to_1st_data_sample, ossimEndian::getSystemEndianType(), OSSIM_LITTLE_ENDIAN, and ossimEndian::swap().
Definition at line 40 of file ErsSarPositionVectorRecord.cpp.
Definition at line 41 of file AlosPalsarPositionVectorRecord.cpp.
Definition at line 41 of file DataHistogramSignalData.cpp.
| DataHistogramProcessedData & | data | ||
Definition at line 41 of file DataHistogramProcessedData.cpp.
References ossimplugins::DataHistogramProcessedData::_histogram1, ossimplugins::DataHistogramProcessedData::_histogram2, ossimplugins::DataHistogramProcessedData::_ltab, ossimplugins::DataHistogramProcessedData::_ntab, ossimplugins::DataHistogramProcessedData::_rec_seq, and ossimplugins::DataHistogramProcessedData::_sar_chn.
Definition at line 41 of file AntennaElevationPatterns.cpp.
References ossimplugins::AntennaElevationPatterns::_attach_flag, ossimplugins::AntennaElevationPatterns::_elevation_pattern, ossimplugins::AntennaElevationPatterns::_swath, ossimplugins::AntennaElevationPatterns::_zero_doppler_time, and ossimplugins::EnvisatAsarRecord::SwitchEndian().
| RadiometricCompensationData & | data | ||
Definition at line 41 of file RadiometricCompensationData.cpp.
References ossimplugins::RadiometricCompensationData::_chan_ind, ossimplugins::RadiometricCompensationData::_dset, ossimplugins::RadiometricCompensationData::_dset_size, ossimplugins::RadiometricCompensationData::_n_dset, and ossimplugins::RadiometricCompensationData::_seq_num.
| DataPointDataRecord & | data | ||
Definition at line 43 of file DataPointDataRecord.cpp.
References ossimplugins::DataPointDataRecord::_gmt_day, ossimplugins::DataPointDataRecord::_gmt_sec, ossimplugins::DataPointDataRecord::_pitch, ossimplugins::DataPointDataRecord::_pitch_flag, ossimplugins::DataPointDataRecord::_pitch_rate, ossimplugins::DataPointDataRecord::_pitch_rate_flag, ossimplugins::DataPointDataRecord::_roll, ossimplugins::DataPointDataRecord::_roll_flag, ossimplugins::DataPointDataRecord::_roll_rate, ossimplugins::DataPointDataRecord::_roll_rate_flag, ossimplugins::DataPointDataRecord::_yaw, ossimplugins::DataPointDataRecord::_yaw_flag, ossimplugins::DataPointDataRecord::_yaw_rate, and ossimplugins::DataPointDataRecord::_yaw_rate_flag.
| FilePointerRecord & | data | ||
Definition at line 45 of file FilePointerRecord.cpp.
References ossimplugins::FilePointerRecord::_ascii_flag, ossimplugins::FilePointerRecord::_data_code, ossimplugins::FilePointerRecord::_data_type, ossimplugins::FilePointerRecord::_file_class, ossimplugins::FilePointerRecord::_file_code, ossimplugins::FilePointerRecord::_file_name, ossimplugins::FilePointerRecord::_file_num, ossimplugins::FilePointerRecord::_first_len, ossimplugins::FilePointerRecord::_first_phyvol, ossimplugins::FilePointerRecord::_first_rec, ossimplugins::FilePointerRecord::_last_phyvol, ossimplugins::FilePointerRecord::_last_rec, ossimplugins::FilePointerRecord::_len_code, ossimplugins::FilePointerRecord::_len_type, ossimplugins::FilePointerRecord::_max_len, and ossimplugins::FilePointerRecord::_nrec.
Definition at line 46 of file VolumeDir.cpp.
References ossimplugins::VolumeDir::_records, ossimplugins::VolumeDir::ClearRecords(), ossimplugins::RadarSatRecordFactory::Instanciate(), and ossimplugins::RadarSatRecord::Read().
| SRGRConversionParameters & | data | ||
Definition at line 46 of file SRGRConversionParameters.cpp.
References ossimplugins::SRGRConversionParameters::_attach_flag, ossimplugins::SRGRConversionParameters::_first_zero_doppler_time_day, ossimplugins::SRGRConversionParameters::_first_zero_doppler_time_microsec, ossimplugins::SRGRConversionParameters::_first_zero_doppler_time_sec, ossimplugins::SRGRConversionParameters::_ground_range_origin, ossimplugins::SRGRConversionParameters::_slant_range_time, ossimplugins::SRGRConversionParameters::_srgr_coef, and ossimplugins::EnvisatAsarRecord::SwitchEndian().
| Data & | data | ||
Definition at line 49 of file Data.cpp.
References ossimplugins::Data::_records, ossimplugins::Data::ClearRecords(), ossimplugins::Data::FirstProcessedDataRecordID, ossimplugins::Data::get_ImageOptionsFileDescriptor(), ossimplugins::Data::ImageOptionsFileDescriptorID, ossimplugins::RadarSatRecordFactory::Instanciate(), ossimplugins::Data::LastProcessedDataRecordID, ossimNotify(), ossimNotifyLevel_DEBUG, ossimNotifyLevel_WARN, ossimplugins::RadarSatRecord::Read(), and ossimplugins::ImageOptionsFileDescriptor::set_nlin().
Definition at line 49 of file EnvisatAsarData.cpp.
References ossimplugins::EnvisatAsarData::_records, ossimplugins::EnvisatAsarData::ClearRecords(), ossimplugins::EnvisatAsarRecordFactory::Instanciate(), and ossimplugins::EnvisatAsarRecord::Read().
| CompensationDataRecord & | data | ||
Definition at line 49 of file CompensationDataRecord.cpp.
References ossimplugins::CompensationDataRecord::_beam_tab, ossimplugins::CompensationDataRecord::_beam_tab_inc, ossimplugins::CompensationDataRecord::_beam_tab_size, ossimplugins::CompensationDataRecord::_beam_type, ossimplugins::CompensationDataRecord::_comp_descr, ossimplugins::CompensationDataRecord::_comp_desig, ossimplugins::CompensationDataRecord::_comp_seq_no, ossimplugins::CompensationDataRecord::_look_angle, and ossimplugins::CompensationDataRecord::_n_comp_rec.
Definition at line 53 of file DopplerCentroidParameters.cpp.
References ossimplugins::DopplerCentroidParameters::_attach_flag, ossimplugins::DopplerCentroidParameters::_delta_dopp_coeff, ossimplugins::DopplerCentroidParameters::_dop_coef, ossimplugins::DopplerCentroidParameters::_dop_conf, ossimplugins::DopplerCentroidParameters::_dop_conf_below_thresh_flag, ossimplugins::DopplerCentroidParameters::_slant_range_time, ossimplugins::DopplerCentroidParameters::_zero_doppler_time, and ossimplugins::EnvisatAsarRecord::SwitchEndian().
Definition at line 54 of file AlosPalsarData.cpp.
References ossimplugins::AlosPalsarData::_records, ossimplugins::AlosPalsarData::ClearRecords(), and ossimplugins::AlosPalsarRecord::Read().
| VolumeDescriptorRecord & | data | ||
Definition at line 54 of file VolumeDescriptorRecord.cpp.
References ossimplugins::VolumeDescriptorRecord::_ascii_flag, ossimplugins::VolumeDescriptorRecord::_curr_phyvol, ossimplugins::VolumeDescriptorRecord::_first_file, ossimplugins::VolumeDescriptorRecord::_first_phyvol, ossimplugins::VolumeDescriptorRecord::_format_doc, ossimplugins::VolumeDescriptorRecord::_format_rev, ossimplugins::VolumeDescriptorRecord::_format_ver, ossimplugins::VolumeDescriptorRecord::_last_phyvol, ossimplugins::VolumeDescriptorRecord::_logvol_agency, ossimplugins::VolumeDescriptorRecord::_logvol_country, ossimplugins::VolumeDescriptorRecord::_logvol_date, ossimplugins::VolumeDescriptorRecord::_logvol_facility, ossimplugins::VolumeDescriptorRecord::_logvol_id, ossimplugins::VolumeDescriptorRecord::_logvol_time, ossimplugins::VolumeDescriptorRecord::_n_filepoint, ossimplugins::VolumeDescriptorRecord::_n_voldir, ossimplugins::VolumeDescriptorRecord::_phyvol_cnt, ossimplugins::VolumeDescriptorRecord::_phyvol_id, ossimplugins::VolumeDescriptorRecord::_phyvol_log, ossimplugins::VolumeDescriptorRecord::_product_id, ossimplugins::VolumeDescriptorRecord::_software_id, ossimplugins::VolumeDescriptorRecord::_volset_id, and ossimplugins::VolumeDescriptorRecord::_volset_log.
Definition at line 57 of file RadiometricData.cpp.
Definition at line 59 of file Trailer.cpp.
References ossimplugins::Trailer::_records, ossimplugins::Trailer::ClearRecords(), ossimplugins::RadarSatRecordFactory::Instanciate(), and ossimplugins::RadarSatRecord::Read().
Definition at line 59 of file AlosPalsarLeader.cpp.
References ossimplugins::AlosPalsarLeader::_records, ossimplugins::AlosPalsarLeader::ClearRecords(), ossimplugins::AlosPalsarRecordFactory::Instanciate(), and ossimplugins::AlosPalsarRecord::Read().
Definition at line 60 of file ErsSarLeader.cpp.
References ossimplugins::ErsSarLeader::ClearRecords(), ossimplugins::ErsSarRecordFactory::Instanciate(), ossimplugins::ErsSarRecord::Read(), and ossimplugins::ErsSarLeader::theRecords.
Definition at line 61 of file ChirpParameters.cpp.
References ossimplugins::ChirpParameters::_attach_flag, ossimplugins::ChirpParameters::_cal_pulse_info, ossimplugins::ChirpParameters::_chirp_islr, ossimplugins::ChirpParameters::_chirp_peak_loc, ossimplugins::ChirpParameters::_chirp_quality_flag, ossimplugins::ChirpParameters::_chirp_sidelobe, ossimplugins::ChirpParameters::_chirp_width, ossimplugins::ChirpParameters::_elev_chirp_power, ossimplugins::ChirpParameters::_normalisation_source, ossimplugins::ChirpParameters::_polar, ossimplugins::ChirpParameters::_re_chirp_power, ossimplugins::ChirpParameters::_ref_chirp_power, ossimplugins::ChirpParameters::_swath, ossimplugins::ChirpParameters::_zero_doppler_time, and ossimplugins::EnvisatAsarRecord::SwitchEndian().
Definition at line 64 of file Leader.cpp.
References ossimplugins::Leader::_records, ossimplugins::Leader::ClearRecords(), ossimplugins::RadarSatRecordFactory::Instanciate(), and ossimplugins::RadarSatRecord::Read().
| GeolocationGrid & | data | ||
Definition at line 69 of file GeolocationGrid.cpp.
References ossimplugins::GeolocationGrid::_angles, ossimplugins::GeolocationGrid::_attach_flag, ossimplugins::GeolocationGrid::_first_zero_doppler_time_day, ossimplugins::GeolocationGrid::_first_zero_doppler_time_microsec, ossimplugins::GeolocationGrid::_first_zero_doppler_time_sec, ossimplugins::GeolocationGrid::_last_line_tie_points, ossimplugins::GeolocationGrid::_last_zero_doppler_time, ossimplugins::GeolocationGrid::_lats, ossimplugins::GeolocationGrid::_line_num, ossimplugins::GeolocationGrid::_longs, ossimplugins::GeolocationGrid::_num_lines, ossimplugins::GeolocationGrid::_samp_numbers, ossimplugins::GeolocationGrid::_slant_range_times, ossimplugins::GeolocationGrid::_sub_sat_track, and ossimplugins::EnvisatAsarRecord::SwitchEndian().
Definition at line 71 of file PlatformPositionData.cpp.
References ossimplugins::PlatformPositionData::_alt_poserr, ossimplugins::PlatformPositionData::_alt_velerr, ossimplugins::PlatformPositionData::_crt_poserr, ossimplugins::PlatformPositionData::_crt_velerr, ossimplugins::PlatformPositionData::_data_int, ossimplugins::PlatformPositionData::_day, ossimplugins::PlatformPositionData::_gmt_day, ossimplugins::PlatformPositionData::_gmt_sec, ossimplugins::PlatformPositionData::_hr_angle, ossimplugins::PlatformPositionData::_month, ossimplugins::PlatformPositionData::_ndata, ossimplugins::PlatformPositionData::_orbit_ele, ossimplugins::PlatformPositionData::_orbit_ele_desg, ossimplugins::PlatformPositionData::_pos_vect, ossimplugins::PlatformPositionData::_rad_poserr, ossimplugins::PlatformPositionData::_rad_velerr, ossimplugins::PlatformPositionData::_ref_coord, and ossimplugins::PlatformPositionData::_year.
Definition at line 71 of file ErsSarMapProjectionData.cpp.
Definition at line 72 of file AlosPalsarMapProjectionData.cpp.
Definition at line 73 of file ErsSarPlatformPositionData.cpp.
Definition at line 74 of file AlosPalsarPlatformPositionData.cpp.
Definition at line 77 of file FileDescriptor.cpp.
References ossimplugins::FileDescriptor::_ascii_flag, ossimplugins::FileDescriptor::_code_len, ossimplugins::FileDescriptor::_code_loc, ossimplugins::FileDescriptor::_design_rev, ossimplugins::FileDescriptor::_file_name, ossimplugins::FileDescriptor::_file_num, ossimplugins::FileDescriptor::_format_doc, ossimplugins::FileDescriptor::_format_ver, ossimplugins::FileDescriptor::_l_anno_data, ossimplugins::FileDescriptor::_l_att_data, ossimplugins::FileDescriptor::_l_cal, ossimplugins::FileDescriptor::_l_data_his, ossimplugins::FileDescriptor::_l_dataset, ossimplugins::FileDescriptor::_l_dem_desc, ossimplugins::FileDescriptor::_l_det_proc, ossimplugins::FileDescriptor::_l_fac_data, ossimplugins::FileDescriptor::_l_gcp, ossimplugins::FileDescriptor::_l_map_proj, ossimplugins::FileDescriptor::_l_plat_pos, ossimplugins::FileDescriptor::_l_qual_sum, ossimplugins::FileDescriptor::_l_radar_par, ossimplugins::FileDescriptor::_l_radi_comp, ossimplugins::FileDescriptor::_l_radi_data, ossimplugins::FileDescriptor::_l_rang_spec, ossimplugins::FileDescriptor::_n_anno_data, ossimplugins::FileDescriptor::_n_att_data, ossimplugins::FileDescriptor::_n_cal, ossimplugins::FileDescriptor::_n_data_his, ossimplugins::FileDescriptor::_n_dataset, ossimplugins::FileDescriptor::_n_dem_desc, ossimplugins::FileDescriptor::_n_det_proc, ossimplugins::FileDescriptor::_n_fac_data, ossimplugins::FileDescriptor::_n_gcp, ossimplugins::FileDescriptor::_n_map_proj, ossimplugins::FileDescriptor::_n_plat_pos, ossimplugins::FileDescriptor::_n_qual_sum, ossimplugins::FileDescriptor::_n_radar_par, ossimplugins::FileDescriptor::_n_radi_comp, ossimplugins::FileDescriptor::_n_radi_data, ossimplugins::FileDescriptor::_n_rang_spec, ossimplugins::FileDescriptor::_rec_code, ossimplugins::FileDescriptor::_rec_len, ossimplugins::FileDescriptor::_rec_seq, ossimplugins::FileDescriptor::_rlen_len, ossimplugins::FileDescriptor::_rlen_loc, ossimplugins::FileDescriptor::_seq_len, ossimplugins::FileDescriptor::_seq_loc, and ossimplugins::FileDescriptor::_software_id.
Definition at line 79 of file ErsSarFileDescriptor.cpp.
| ProcessedDataRecord & | data | ||
Definition at line 81 of file ProcessedDataRecord.cpp.
References ossimplugins::ProcessedDataRecord::_acq_day, ossimplugins::ProcessedDataRecord::_acq_msec, ossimplugins::ProcessedDataRecord::_acq_year, ossimplugins::ProcessedDataRecord::_east_first, ossimplugins::ProcessedDataRecord::_east_last, ossimplugins::ProcessedDataRecord::_fdc_first, ossimplugins::ProcessedDataRecord::_fdc_last, ossimplugins::ProcessedDataRecord::_fdc_mid, ossimplugins::ProcessedDataRecord::_geo_updf, ossimplugins::ProcessedDataRecord::_heading, ossimplugins::ProcessedDataRecord::_ka_first, ossimplugins::ProcessedDataRecord::_ka_last, ossimplugins::ProcessedDataRecord::_ka_mid, ossimplugins::ProcessedDataRecord::_lat_first, ossimplugins::ProcessedDataRecord::_lat_last, ossimplugins::ProcessedDataRecord::_lat_mid, ossimplugins::ProcessedDataRecord::_line_num, ossimplugins::ProcessedDataRecord::_lon_first, ossimplugins::ProcessedDataRecord::_lon_last, ossimplugins::ProcessedDataRecord::_lon_mid, ossimplugins::ProcessedDataRecord::_n_data_pixel, ossimplugins::ProcessedDataRecord::_n_left_pixel, ossimplugins::ProcessedDataRecord::_n_right_pixel, ossimplugins::ProcessedDataRecord::_nadir_ang, ossimplugins::ProcessedDataRecord::_north_first, ossimplugins::ProcessedDataRecord::_north_last, ossimplugins::ProcessedDataRecord::_prf, ossimplugins::ProcessedDataRecord::_rec_num, ossimplugins::ProcessedDataRecord::_recv_polar, ossimplugins::ProcessedDataRecord::_sar_chan_code, ossimplugins::ProcessedDataRecord::_sar_chan_ind, ossimplugins::ProcessedDataRecord::_sensor_updf, ossimplugins::ProcessedDataRecord::_squint_ang, ossimplugins::ProcessedDataRecord::_sr_first, ossimplugins::ProcessedDataRecord::_sr_last, ossimplugins::ProcessedDataRecord::_sr_mid, ossimplugins::ProcessedDataRecord::_tran_polar, and ossimplugins::ProcessedDataRecord::SwitchEndian().
| DataQuality & | data | ||
Definition at line 91 of file DataQuality.cpp.
References ossimplugins::DataQuality::_alt_locerr, ossimplugins::DataQuality::_alt_scale, ossimplugins::DataQuality::_azi_ambig, ossimplugins::DataQuality::_azi_res, ossimplugins::DataQuality::_ber, ossimplugins::DataQuality::_cali_date, ossimplugins::DataQuality::_crt_locerr, ossimplugins::DataQuality::_crt_scale, ossimplugins::DataQuality::_dis_skew, ossimplugins::DataQuality::_dyn_rng, ossimplugins::DataQuality::_enl, ossimplugins::DataQuality::_islr, ossimplugins::DataQuality::_misreg, ossimplugins::DataQuality::_nchn, ossimplugins::DataQuality::_nesz, ossimplugins::DataQuality::_ori_err, ossimplugins::DataQuality::_pslr, ossimplugins::DataQuality::_rad_res, ossimplugins::DataQuality::_rad_unc, ossimplugins::DataQuality::_rad_unc_db, ossimplugins::DataQuality::_rad_unc_deg, ossimplugins::DataQuality::_rec_seq, ossimplugins::DataQuality::_rng_ambig, ossimplugins::DataQuality::_rng_res, ossimplugins::DataQuality::_sar_chn, ossimplugins::DataQuality::_snr, and ossimplugins::DataQuality::_tb_update.
Definition at line 101 of file AlosPalsarFileDescriptor.cpp.
Definition at line 108 of file SQ_ADSR.cpp.
References ossimplugins::SQ_ADSR::_attach_flag, ossimplugins::SQ_ADSR::_chirp_flag, ossimplugins::SQ_ADSR::_dop_amb_flag, ossimplugins::SQ_ADSR::_dop_cen_flag, ossimplugins::SQ_ADSR::_exp_input_mean, ossimplugins::SQ_ADSR::_exp_input_std_dev, ossimplugins::SQ_ADSR::_exp_output_mean, ossimplugins::SQ_ADSR::_exp_output_std_dev, ossimplugins::SQ_ADSR::_input_gaps_flag, ossimplugins::SQ_ADSR::_input_mean, ossimplugins::SQ_ADSR::_input_mean_flag, ossimplugins::SQ_ADSR::_input_missing_lines_flag, ossimplugins::SQ_ADSR::_input_std_dev, ossimplugins::SQ_ADSR::_input_std_dev_flag, ossimplugins::SQ_ADSR::_invalid_downlink_flag, ossimplugins::SQ_ADSR::_lines_per_gaps, ossimplugins::SQ_ADSR::_missing_data_set_flag, ossimplugins::SQ_ADSR::_num_gaps, ossimplugins::SQ_ADSR::_num_missing_lines, ossimplugins::SQ_ADSR::_output_mean, ossimplugins::SQ_ADSR::_output_mean_flag, ossimplugins::SQ_ADSR::_output_std_dev, ossimplugins::SQ_ADSR::_output_std_dev_flag, ossimplugins::SQ_ADSR::_thres_chirp_broadening, ossimplugins::SQ_ADSR::_thresh_chirp_islr, ossimplugins::SQ_ADSR::_thresh_chirp_sidelobe, ossimplugins::SQ_ADSR::_thresh_dop_amb, ossimplugins::SQ_ADSR::_thresh_dop_cen, ossimplugins::SQ_ADSR::_thresh_input_gaps, ossimplugins::SQ_ADSR::_thresh_input_mean, ossimplugins::SQ_ADSR::_thresh_input_missing_lines, ossimplugins::SQ_ADSR::_thresh_input_std_dev, ossimplugins::SQ_ADSR::_thresh_output_mean, ossimplugins::SQ_ADSR::_thresh_output_std_dev, ossimplugins::SQ_ADSR::_tot_errors, ossimplugins::SQ_ADSR::_zero_doppler_time, and ossimplugins::EnvisatAsarRecord::SwitchEndian().
Definition at line 131 of file DataHistogramRecord.cpp.
Definition at line 133 of file ImageOptionsFileDescriptor.cpp.
References ossimplugins::ImageOptionsFileDescriptor::_ascii_flag, ossimplugins::ImageOptionsFileDescriptor::_bias_loc, ossimplugins::ImageOptionsFileDescriptor::_cali_loc, ossimplugins::ImageOptionsFileDescriptor::_chn_loc, ossimplugins::ImageOptionsFileDescriptor::_code_len, ossimplugins::ImageOptionsFileDescriptor::_code_loc, ossimplugins::ImageOptionsFileDescriptor::_design_rev, ossimplugins::ImageOptionsFileDescriptor::_file_name, ossimplugins::ImageOptionsFileDescriptor::_file_num, ossimplugins::ImageOptionsFileDescriptor::_format_doc, ossimplugins::ImageOptionsFileDescriptor::_format_rev, ossimplugins::ImageOptionsFileDescriptor::_gain_loc, ossimplugins::ImageOptionsFileDescriptor::_intleav, ossimplugins::ImageOptionsFileDescriptor::_justify, ossimplugins::ImageOptionsFileDescriptor::_l_dataset, ossimplugins::ImageOptionsFileDescriptor::_left_fill, ossimplugins::ImageOptionsFileDescriptor::_left_loc, ossimplugins::ImageOptionsFileDescriptor::_lin_loc, ossimplugins::ImageOptionsFileDescriptor::_n_dataset, ossimplugins::ImageOptionsFileDescriptor::_n_prefix, ossimplugins::ImageOptionsFileDescriptor::_n_sar, ossimplugins::ImageOptionsFileDescriptor::_n_suffix, ossimplugins::ImageOptionsFileDescriptor::_nbit, ossimplugins::ImageOptionsFileDescriptor::_nbott, ossimplugins::ImageOptionsFileDescriptor::_nbyte, ossimplugins::ImageOptionsFileDescriptor::_nchn, ossimplugins::ImageOptionsFileDescriptor::_ngrp, ossimplugins::ImageOptionsFileDescriptor::_nleft, ossimplugins::ImageOptionsFileDescriptor::_nlin, ossimplugins::ImageOptionsFileDescriptor::_nrec_chn, ossimplugins::ImageOptionsFileDescriptor::_nrec_lin, ossimplugins::ImageOptionsFileDescriptor::_nright, ossimplugins::ImageOptionsFileDescriptor::_nsamp, ossimplugins::ImageOptionsFileDescriptor::_ntop, ossimplugins::ImageOptionsFileDescriptor::_pad_ind, ossimplugins::ImageOptionsFileDescriptor::_pix_rng, ossimplugins::ImageOptionsFileDescriptor::_qual_loc, ossimplugins::ImageOptionsFileDescriptor::_rec_code, ossimplugins::ImageOptionsFileDescriptor::_rec_len, ossimplugins::ImageOptionsFileDescriptor::_rec_seq, ossimplugins::ImageOptionsFileDescriptor::_right_fill, ossimplugins::ImageOptionsFileDescriptor::_right_loc, ossimplugins::ImageOptionsFileDescriptor::_rlen_len, ossimplugins::ImageOptionsFileDescriptor::_rlen_loc, ossimplugins::ImageOptionsFileDescriptor::_seq_len, ossimplugins::ImageOptionsFileDescriptor::_seq_loc, ossimplugins::ImageOptionsFileDescriptor::_software_id, ossimplugins::ImageOptionsFileDescriptor::_tim_loc, ossimplugins::ImageOptionsFileDescriptor::_type_code, ossimplugins::ImageOptionsFileDescriptor::_type_id, ossimNotify(), and ossimNotifyLevel_DEBUG.
| mph & | data | ||
Definition at line 190 of file mph.cpp.
References ossimplugins::mph::_abs_orbit, ossimplugins::mph::_absolute_orbit_title, ossimplugins::mph::_acq_stat_id_title, ossimplugins::mph::_acq_station, ossimplugins::mph::_clock_step, ossimplugins::mph::_clock_step_title, ossimplugins::mph::_clock_step_units, ossimplugins::mph::_cycle, ossimplugins::mph::_cycle_title, ossimplugins::mph::_delta_ut1, ossimplugins::mph::_delta_ut1_title, ossimplugins::mph::_delta_ut1_units, ossimplugins::mph::_dsd_size, ossimplugins::mph::_leap_err, ossimplugins::mph::_leap_err_title, ossimplugins::mph::_leap_sign, ossimplugins::mph::_leap_sign_title, ossimplugins::mph::_leap_utc, ossimplugins::mph::_leap_utc_title, ossimplugins::mph::_num_data_sets, ossimplugins::mph::_num_dsd, ossimplugins::mph::_number_of_ds_att_title, ossimplugins::mph::_number_of_dsd_title, ossimplugins::mph::_phase, ossimplugins::mph::_phase_title, ossimplugins::mph::_proc_center, ossimplugins::mph::_proc_center_title, ossimplugins::mph::_proc_stage, ossimplugins::mph::_proc_stage_title, ossimplugins::mph::_proc_time, ossimplugins::mph::_proc_time_title, ossimplugins::mph::_product, ossimplugins::mph::_product_err, ossimplugins::mph::_product_err_title, ossimplugins::mph::_product_name, ossimplugins::mph::_ref_doc, ossimplugins::mph::_ref_doc_title, ossimplugins::mph::_rel_orbit, ossimplugins::mph::_relative_orbit_title, ossimplugins::mph::_sat_binary_time, ossimplugins::mph::_sat_binary_time_title, ossimplugins::mph::_sensing_start, ossimplugins::mph::_sensing_start_title, ossimplugins::mph::_sensing_stop, ossimplugins::mph::_sensing_stop_title, ossimplugins::mph::_size_of_dsd_title, ossimplugins::mph::_size_of_dsd_units, ossimplugins::mph::_soft_version, ossimplugins::mph::_soft_version_title, ossimplugins::mph::_spare_4, ossimplugins::mph::_sph_size, ossimplugins::mph::_sph_size_title, ossimplugins::mph::_sph_size_units, ossimplugins::mph::_state_vector_time, ossimplugins::mph::_state_vector_time_title, ossimplugins::mph::_tot_size, ossimplugins::mph::_total_size_title, ossimplugins::mph::_total_size_units, ossimplugins::mph::_utc_sbt_time, ossimplugins::mph::_utc_sbt_time_title, ossimplugins::mph::_vector_source, ossimplugins::mph::_vector_source_title, ossimplugins::mph::_x_position, ossimplugins::mph::_x_position_title, ossimplugins::mph::_x_position_units, ossimplugins::mph::_x_velocity, ossimplugins::mph::_x_velocity_title, ossimplugins::mph::_x_velocity_units, ossimplugins::mph::_y_position, ossimplugins::mph::_y_position_title, ossimplugins::mph::_y_position_units, ossimplugins::mph::_y_velocity, ossimplugins::mph::_y_velocity_title, ossimplugins::mph::_y_velocity_units, ossimplugins::mph::_z_position, ossimplugins::mph::_z_position_title, ossimplugins::mph::_z_position_units, ossimplugins::mph::_z_velocity, ossimplugins::mph::_z_velocity_title, and ossimplugins::mph::_z_velocity_units.
| sph & | data | ||
Definition at line 200 of file sph.cpp.
References ossimplugins::sph::_algo_title, ossimplugins::sph::_algorithm, ossimplugins::sph::_azimut_looks, ossimplugins::sph::_azimut_looks_title, ossimplugins::sph::_azimut_spacing, ossimplugins::sph::_azimut_spacing_title, ossimplugins::sph::_azimut_spacing_unit, ossimplugins::sph::_compression, ossimplugins::sph::_compression_title, ossimplugins::sph::_data_type, ossimplugins::sph::_data_type_title, ossimplugins::sph::_dsd_vector, ossimplugins::sph::_first_far_lat, ossimplugins::sph::_first_far_lat_title, ossimplugins::sph::_first_far_lat_units, ossimplugins::sph::_first_far_long, ossimplugins::sph::_first_far_long_title, ossimplugins::sph::_first_far_long_units, ossimplugins::sph::_first_line_time, ossimplugins::sph::_first_line_time_title, ossimplugins::sph::_first_mid_lat, ossimplugins::sph::_first_mid_lat_title, ossimplugins::sph::_first_mid_lat_units, ossimplugins::sph::_first_mid_long, ossimplugins::sph::_first_mid_long_title, ossimplugins::sph::_first_mid_long_units, ossimplugins::sph::_first_near_lat, ossimplugins::sph::_first_near_lat_title, ossimplugins::sph::_first_near_lat_units, ossimplugins::sph::_first_near_long, ossimplugins::sph::_first_near_long_title, ossimplugins::sph::_first_near_long_units, ossimplugins::sph::_last_far_lat, ossimplugins::sph::_last_far_lat_title, ossimplugins::sph::_last_far_lat_units, ossimplugins::sph::_last_far_long, ossimplugins::sph::_last_far_long_title, ossimplugins::sph::_last_far_long_units, ossimplugins::sph::_last_line_time, ossimplugins::sph::_last_line_time_title, ossimplugins::sph::_last_mid_lat, ossimplugins::sph::_last_mid_lat_title, ossimplugins::sph::_last_mid_lat_units, ossimplugins::sph::_last_mid_long, ossimplugins::sph::_last_mid_long_title, ossimplugins::sph::_last_mid_long_units, ossimplugins::sph::_last_near_lat, ossimplugins::sph::_last_near_lat_title, ossimplugins::sph::_last_near_lat_units, ossimplugins::sph::_last_near_long, ossimplugins::sph::_last_near_long_title, ossimplugins::sph::_last_near_long_units, ossimplugins::sph::_line_length, ossimplugins::sph::_line_length_title, ossimplugins::sph::_line_length_units, ossimplugins::sph::_line_time_interv_units, ossimplugins::sph::_line_time_interval, ossimplugins::sph::_line_time_interval_title, ossimplugins::sph::_mds1_tx_rx_polar, ossimplugins::sph::_mds1_tx_rx_polar_title, ossimplugins::sph::_mds2_tx_rx_polar, ossimplugins::sph::_mds2_tx_rx_polar_title, ossimplugins::sph::_num_dsd, ossimplugins::sph::_num_slices, ossimplugins::sph::_num_slices_title, ossimplugins::sph::_pass, ossimplugins::sph::_pass_title, ossimplugins::sph::_range_looks, ossimplugins::sph::_range_looks_title, ossimplugins::sph::_range_spacing, ossimplugins::sph::_range_spacing_title, ossimplugins::sph::_range_spacing_unit, ossimplugins::sph::_sample_type, ossimplugins::sph::_sample_type_title, ossimplugins::sph::_slice_pos_title, ossimplugins::sph::_slice_position, ossimplugins::sph::_sph_desc, ossimplugins::sph::_sph_desc_title, ossimplugins::sph::_strip_cont_ind, ossimplugins::sph::_strip_cont_ind_title, ossimplugins::sph::_swath, and ossimplugins::sph::_swath_title.
| AlosPalsarDataSetSummary & | data | ||
from 1767 to 4096 to be added
Definition at line 204 of file AlosPalsarDataSetSummary.cpp.
References ossimplugins::AlosPalsarDataSetSummary::_algor_id, ossimplugins::AlosPalsarDataSetSummary::_alt_dopcen, ossimplugins::AlosPalsarDataSetSummary::_alt_rate, ossimplugins::AlosPalsarDataSetSummary::_ampl_coef, ossimplugins::AlosPalsarDataSetSummary::_asc_des, ossimplugins::AlosPalsarDataSetSummary::_auto_focus, ossimplugins::AlosPalsarDataSetSummary::_azi_res, ossimplugins::AlosPalsarDataSetSummary::_azi_weight, ossimplugins::AlosPalsarDataSetSummary::_baseband_f, ossimplugins::AlosPalsarDataSetSummary::_bnd_azi, ossimplugins::AlosPalsarDataSetSummary::_bnd_azilok, ossimplugins::AlosPalsarDataSetSummary::_bnd_rng, ossimplugins::AlosPalsarDataSetSummary::_bnd_rnglok, ossimplugins::AlosPalsarDataSetSummary::_chirp_ext_ind, ossimplugins::AlosPalsarDataSetSummary::_chn_bits, ossimplugins::AlosPalsarDataSetSummary::_clock_ang, ossimplugins::AlosPalsarDataSetSummary::_clutter_lock, ossimplugins::AlosPalsarDataSetSummary::_crt_dopcen, ossimplugins::AlosPalsarDataSetSummary::_crt_rate, ossimplugins::AlosPalsarDataSetSummary::_data_inpsrc, ossimplugins::AlosPalsarDataSetSummary::_dopcen_range, ossimplugins::AlosPalsarDataSetSummary::_earth_mass, ossimplugins::AlosPalsarDataSetSummary::_ellip_des, ossimplugins::AlosPalsarDataSetSummary::_ellip_j, ossimplugins::AlosPalsarDataSetSummary::_ellip_maj, ossimplugins::AlosPalsarDataSetSummary::_ellip_min, ossimplugins::AlosPalsarDataSetSummary::_fa, ossimplugins::AlosPalsarDataSetSummary::_fac_id, ossimplugins::AlosPalsarDataSetSummary::_fr, ossimplugins::AlosPalsarDataSetSummary::_gn_cross, ossimplugins::AlosPalsarDataSetSummary::_gn_polar, ossimplugins::AlosPalsarDataSetSummary::_grav_const, ossimplugins::AlosPalsarDataSetSummary::_i_bias, ossimplugins::AlosPalsarDataSetSummary::_incident_ang, ossimplugins::AlosPalsarDataSetSummary::_inp_sctim, ossimplugins::AlosPalsarDataSetSummary::_iq_ratio, ossimplugins::AlosPalsarDataSetSummary::_line_cont, ossimplugins::AlosPalsarDataSetSummary::_line_spacing, ossimplugins::AlosPalsarDataSetSummary::_mech_sight, ossimplugins::AlosPalsarDataSetSummary::_mission_id, ossimplugins::AlosPalsarDataSetSummary::_motion_comp, ossimplugins::AlosPalsarDataSetSummary::_n_azilok, ossimplugins::AlosPalsarDataSetSummary::_n_rnglok, ossimplugins::AlosPalsarDataSetSummary::_nchn, ossimplugins::AlosPalsarDataSetSummary::_orbit_num, ossimplugins::AlosPalsarDataSetSummary::_phas_coef, ossimplugins::AlosPalsarDataSetSummary::_pix_spacing, ossimplugins::AlosPalsarDataSetSummary::_plat_head, ossimplugins::AlosPalsarDataSetSummary::_plat_lat, ossimplugins::AlosPalsarDataSetSummary::_plat_long, ossimplugins::AlosPalsarDataSetSummary::_pro_head, ossimplugins::AlosPalsarDataSetSummary::_pro_lat, ossimplugins::AlosPalsarDataSetSummary::_pro_long, ossimplugins::AlosPalsarDataSetSummary::_prod_type, ossimplugins::AlosPalsarDataSetSummary::_pulse_code, ossimplugins::AlosPalsarDataSetSummary::_q_bias, ossimplugins::AlosPalsarDataSetSummary::_quant_desc, ossimplugins::AlosPalsarDataSetSummary::_rng_gate, ossimplugins::AlosPalsarDataSetSummary::_rng_length, ossimplugins::AlosPalsarDataSetSummary::_rng_res, ossimplugins::AlosPalsarDataSetSummary::_rng_weight, ossimplugins::AlosPalsarDataSetSummary::_rngcmp_desg, ossimplugins::AlosPalsarDataSetSummary::_rngcmp_f, ossimplugins::AlosPalsarDataSetSummary::_sar_chn, ossimplugins::AlosPalsarDataSetSummary::_sat_bintim, ossimplugins::AlosPalsarDataSetSummary::_sat_clkinc, ossimplugins::AlosPalsarDataSetSummary::_sat_clktim, ossimplugins::AlosPalsarDataSetSummary::_sc_lin, ossimplugins::AlosPalsarDataSetSummary::_sc_pix, ossimplugins::AlosPalsarDataSetSummary::_scene_des, ossimplugins::AlosPalsarDataSetSummary::_scene_id, ossimplugins::AlosPalsarDataSetSummary::_scene_len, ossimplugins::AlosPalsarDataSetSummary::_scene_wid, ossimplugins::AlosPalsarDataSetSummary::_sensor_id, ossimplugins::AlosPalsarDataSetSummary::_seq_num, ossimplugins::AlosPalsarDataSetSummary::_sys_id, ossimplugins::AlosPalsarDataSetSummary::_terrain_h, ossimplugins::AlosPalsarDataSetSummary::_time_dir_lin, ossimplugins::AlosPalsarDataSetSummary::_time_dir_pix, ossimplugins::AlosPalsarDataSetSummary::_ver_id, and ossimplugins::AlosPalsarDataSetSummary::_wave_length.
| ErsSarDataSetSummary & | data | ||
Definition at line 208 of file ErsSarDataSetSummary.cpp.
References ossimplugins::ErsSarDataSetSummary::_algor_id, ossimplugins::ErsSarDataSetSummary::_alt_dopcen, ossimplugins::ErsSarDataSetSummary::_alt_rate, ossimplugins::ErsSarDataSetSummary::_ampl_coef, ossimplugins::ErsSarDataSetSummary::_asc_des, ossimplugins::ErsSarDataSetSummary::_auto_focus, ossimplugins::ErsSarDataSetSummary::_azi_res, ossimplugins::ErsSarDataSetSummary::_azi_weight, ossimplugins::ErsSarDataSetSummary::_baseband_f, ossimplugins::ErsSarDataSetSummary::_bnd_azi, ossimplugins::ErsSarDataSetSummary::_bnd_azilok, ossimplugins::ErsSarDataSetSummary::_bnd_rng, ossimplugins::ErsSarDataSetSummary::_bnd_rnglok, ossimplugins::ErsSarDataSetSummary::_chirp_ext_ind, ossimplugins::ErsSarDataSetSummary::_chn_bits, ossimplugins::ErsSarDataSetSummary::_clock_ang, ossimplugins::ErsSarDataSetSummary::_clutter_lock, ossimplugins::ErsSarDataSetSummary::_crt_dopcen, ossimplugins::ErsSarDataSetSummary::_crt_rate, ossimplugins::ErsSarDataSetSummary::_data_inpsrc, ossimplugins::ErsSarDataSetSummary::_earth_mass, ossimplugins::ErsSarDataSetSummary::_ellip_des, ossimplugins::ErsSarDataSetSummary::_ellip_j, ossimplugins::ErsSarDataSetSummary::_ellip_maj, ossimplugins::ErsSarDataSetSummary::_ellip_min, ossimplugins::ErsSarDataSetSummary::_fa, ossimplugins::ErsSarDataSetSummary::_fac_id, ossimplugins::ErsSarDataSetSummary::_fr, ossimplugins::ErsSarDataSetSummary::_gn_cross, ossimplugins::ErsSarDataSetSummary::_gn_polar, ossimplugins::ErsSarDataSetSummary::_grav_const, ossimplugins::ErsSarDataSetSummary::_i_bias, ossimplugins::ErsSarDataSetSummary::_incident_ang, ossimplugins::ErsSarDataSetSummary::_inp_sctim, ossimplugins::ErsSarDataSetSummary::_iq_ratio, ossimplugins::ErsSarDataSetSummary::_line_cont, ossimplugins::ErsSarDataSetSummary::_line_spacing, ossimplugins::ErsSarDataSetSummary::_mech_sight, ossimplugins::ErsSarDataSetSummary::_mission_id, ossimplugins::ErsSarDataSetSummary::_motion_comp, ossimplugins::ErsSarDataSetSummary::_n_azilok, ossimplugins::ErsSarDataSetSummary::_n_rnglok, ossimplugins::ErsSarDataSetSummary::_nchn, ossimplugins::ErsSarDataSetSummary::_orbit_num, ossimplugins::ErsSarDataSetSummary::_phas_coef, ossimplugins::ErsSarDataSetSummary::_pix_spacing, ossimplugins::ErsSarDataSetSummary::_plat_head, ossimplugins::ErsSarDataSetSummary::_plat_lat, ossimplugins::ErsSarDataSetSummary::_plat_long, ossimplugins::ErsSarDataSetSummary::_pro_head, ossimplugins::ErsSarDataSetSummary::_pro_lat, ossimplugins::ErsSarDataSetSummary::_pro_long, ossimplugins::ErsSarDataSetSummary::_prod_type, ossimplugins::ErsSarDataSetSummary::_pulse_code, ossimplugins::ErsSarDataSetSummary::_q_bias, ossimplugins::ErsSarDataSetSummary::_quant_desc, ossimplugins::ErsSarDataSetSummary::_rng_gate, ossimplugins::ErsSarDataSetSummary::_rng_length, ossimplugins::ErsSarDataSetSummary::_rng_res, ossimplugins::ErsSarDataSetSummary::_rng_weight, ossimplugins::ErsSarDataSetSummary::_rngcmp_desg, ossimplugins::ErsSarDataSetSummary::_rngcmp_f, ossimplugins::ErsSarDataSetSummary::_sar_chn, ossimplugins::ErsSarDataSetSummary::_sat_bintim, ossimplugins::ErsSarDataSetSummary::_sat_clkinc, ossimplugins::ErsSarDataSetSummary::_sat_clktim, ossimplugins::ErsSarDataSetSummary::_sc_lin, ossimplugins::ErsSarDataSetSummary::_sc_pix, ossimplugins::ErsSarDataSetSummary::_scene_des, ossimplugins::ErsSarDataSetSummary::_scene_id, ossimplugins::ErsSarDataSetSummary::_scene_len, ossimplugins::ErsSarDataSetSummary::_scene_wid, ossimplugins::ErsSarDataSetSummary::_sensor_id, ossimplugins::ErsSarDataSetSummary::_seq_num, ossimplugins::ErsSarDataSetSummary::_sys_id, ossimplugins::ErsSarDataSetSummary::_terrain_h, ossimplugins::ErsSarDataSetSummary::_time_dir_lin, ossimplugins::ErsSarDataSetSummary::_time_dir_pix, ossimplugins::ErsSarDataSetSummary::_ver_id, ossimplugins::ErsSarDataSetSummary::_wave_length, ossimplugins::ErsSarDataSetSummary::_zero_dop_az_time_c_pixel, ossimplugins::ErsSarDataSetSummary::_zero_dop_az_time_f_pixel, ossimplugins::ErsSarDataSetSummary::_zero_dop_az_time_l_pixel, ossimplugins::ErsSarDataSetSummary::_zero_dop_range_time_c_pixel, ossimplugins::ErsSarDataSetSummary::_zero_dop_range_time_f_pixel, and ossimplugins::ErsSarDataSetSummary::_zero_dop_range_time_l_pixel.
Definition at line 210 of file DataSetSummary.cpp.
References ossimplugins::DataSetSummary::_algor_id, ossimplugins::DataSetSummary::_alt_dopcen, ossimplugins::DataSetSummary::_alt_rate, ossimplugins::DataSetSummary::_ampl_coef, ossimplugins::DataSetSummary::_asc_des, ossimplugins::DataSetSummary::_auto_focus, ossimplugins::DataSetSummary::_azi_res, ossimplugins::DataSetSummary::_azi_weight, ossimplugins::DataSetSummary::_azim_beam, ossimplugins::DataSetSummary::_baseband_f, ossimplugins::DataSetSummary::_bnd_azi, ossimplugins::DataSetSummary::_bnd_azilok, ossimplugins::DataSetSummary::_bnd_rng, ossimplugins::DataSetSummary::_bnd_rnglok, ossimplugins::DataSetSummary::_chirp_ext_ind, ossimplugins::DataSetSummary::_chn_bits, ossimplugins::DataSetSummary::_clock_ang, ossimplugins::DataSetSummary::_clutter_lock, ossimplugins::DataSetSummary::_crt_dopcen, ossimplugins::DataSetSummary::_crt_rate, ossimplugins::DataSetSummary::_data_inpsrc, ossimplugins::DataSetSummary::_earth_mass, ossimplugins::DataSetSummary::_echo_track, ossimplugins::DataSetSummary::_ele_sight, ossimplugins::DataSetSummary::_elev_beam, ossimplugins::DataSetSummary::_ellip_des, ossimplugins::DataSetSummary::_ellip_j, ossimplugins::DataSetSummary::_ellip_maj, ossimplugins::DataSetSummary::_ellip_min, ossimplugins::DataSetSummary::_fa, ossimplugins::DataSetSummary::_fac_code, ossimplugins::DataSetSummary::_fac_id, ossimplugins::DataSetSummary::_fr, ossimplugins::DataSetSummary::_gn_cross, ossimplugins::DataSetSummary::_gn_polar, ossimplugins::DataSetSummary::_grav_const, ossimplugins::DataSetSummary::_i_bias, ossimplugins::DataSetSummary::_incident_ang, ossimplugins::DataSetSummary::_inp_sctim, ossimplugins::DataSetSummary::_iq_ratio, ossimplugins::DataSetSummary::_lev_code, ossimplugins::DataSetSummary::_line_cont, ossimplugins::DataSetSummary::_line_spacing, ossimplugins::DataSetSummary::_mech_sight, ossimplugins::DataSetSummary::_mission_id, ossimplugins::DataSetSummary::_motion_comp, ossimplugins::DataSetSummary::_n_azilok, ossimplugins::DataSetSummary::_n_rnglok, ossimplugins::DataSetSummary::_nchn, ossimplugins::DataSetSummary::_orbit_num, ossimplugins::DataSetSummary::_phas_coef, ossimplugins::DataSetSummary::_pix_spacing, ossimplugins::DataSetSummary::_plat_head, ossimplugins::DataSetSummary::_plat_lat, ossimplugins::DataSetSummary::_plat_long, ossimplugins::DataSetSummary::_pro_head, ossimplugins::DataSetSummary::_pro_lat, ossimplugins::DataSetSummary::_pro_long, ossimplugins::DataSetSummary::_prod_type, ossimplugins::DataSetSummary::_pulse_code, ossimplugins::DataSetSummary::_q_bias, ossimplugins::DataSetSummary::_quant_desc, ossimplugins::DataSetSummary::_radi_stretch, ossimplugins::DataSetSummary::_rng_gate, ossimplugins::DataSetSummary::_rng_length, ossimplugins::DataSetSummary::_rng_res, ossimplugins::DataSetSummary::_rng_weight, ossimplugins::DataSetSummary::_rngcmp_desg, ossimplugins::DataSetSummary::_rngcmp_f, ossimplugins::DataSetSummary::_sar_chn, ossimplugins::DataSetSummary::_sat_bintim, ossimplugins::DataSetSummary::_sat_clkinc, ossimplugins::DataSetSummary::_sat_clktim, ossimplugins::DataSetSummary::_sc_lin, ossimplugins::DataSetSummary::_sc_pix, ossimplugins::DataSetSummary::_scene_des, ossimplugins::DataSetSummary::_scene_id, ossimplugins::DataSetSummary::_scene_len, ossimplugins::DataSetSummary::_scene_wid, ossimplugins::DataSetSummary::_sensor_id, ossimplugins::DataSetSummary::_seq_num, ossimplugins::DataSetSummary::_sys_id, ossimplugins::DataSetSummary::_terrain_h, ossimplugins::DataSetSummary::_time_dir_lin, ossimplugins::DataSetSummary::_time_dir_pix, ossimplugins::DataSetSummary::_ver_id, and ossimplugins::DataSetSummary::_wave_length.
| ProcessingParameters & | data | ||
Definition at line 264 of file ProcessingParameters.cpp.
References ossimplugins::ProcessingParameters::_act_ing_start, ossimplugins::ProcessingParameters::_act_ing_stop, ossimplugins::ProcessingParameters::_adc_samp_rate, ossimplugins::ProcessingParameters::_angle_first, ossimplugins::ProcessingParameters::_angle_last, ossimplugins::ProcessingParameters::_appl_type, ossimplugins::ProcessingParameters::_apply_dtm, ossimplugins::ProcessingParameters::_beam_edge_conf, ossimplugins::ProcessingParameters::_beam_edge_rqd, ossimplugins::ProcessingParameters::_beam_info, ossimplugins::ProcessingParameters::_bit_err_rate, ossimplugins::ProcessingParameters::_centre_lat, ossimplugins::ProcessingParameters::_centre_long, ossimplugins::ProcessingParameters::_complete_msg, ossimplugins::ProcessingParameters::_date_incons, ossimplugins::ProcessingParameters::_delay_changes, ossimplugins::ProcessingParameters::_density_in, ossimplugins::ProcessingParameters::_density_out, ossimplugins::ProcessingParameters::_dop_amb_err, ossimplugins::ProcessingParameters::_dopamb_conf, ossimplugins::ProcessingParameters::_dopcen_est, ossimplugins::ProcessingParameters::_dopcen_inc, ossimplugins::ProcessingParameters::_eph_orb_data, ossimplugins::ProcessingParameters::_err_amp_coef, ossimplugins::ProcessingParameters::_err_phas_coef, ossimplugins::ProcessingParameters::_exp_ing_start, ossimplugins::ProcessingParameters::_exp_ing_stop, ossimplugins::ProcessingParameters::_fm_crc_err, ossimplugins::ProcessingParameters::_gics_reqd, ossimplugins::ProcessingParameters::_gn_corctn_fctr, ossimplugins::ProcessingParameters::_img_cumu_dist, ossimplugins::ProcessingParameters::_img_hist_mean, ossimplugins::ProcessingParameters::_inp_media, ossimplugins::ProcessingParameters::_large_gap, ossimplugins::ProcessingParameters::_map_system, ossimplugins::ProcessingParameters::_media_id, ossimplugins::ProcessingParameters::_miss_ln, ossimplugins::ProcessingParameters::_mn_sig_lev, ossimplugins::ProcessingParameters::_n_beams, ossimplugins::ProcessingParameters::_n_dopcen, ossimplugins::ProcessingParameters::_n_image_pix, ossimplugins::ProcessingParameters::_n_pix_updates, ossimplugins::ProcessingParameters::_n_srgr, ossimplugins::ProcessingParameters::_n_tape_id, ossimplugins::ProcessingParameters::_n_temp_set, ossimplugins::ProcessingParameters::_num_state_vectors, ossimplugins::ProcessingParameters::_orb_data_src, ossimplugins::ProcessingParameters::_pix_count, ossimplugins::ProcessingParameters::_pix_overlap, ossimplugins::ProcessingParameters::_pixel_spacing, ossimplugins::ProcessingParameters::_post_img_gn, ossimplugins::ProcessingParameters::_prc_satur_pix, ossimplugins::ProcessingParameters::_prc_zero_pix, ossimplugins::ProcessingParameters::_pre_img_gn, ossimplugins::ProcessingParameters::_prf_changes, ossimplugins::ProcessingParameters::_proc_start, ossimplugins::ProcessingParameters::_proc_stop, ossimplugins::ProcessingParameters::_prod_type, ossimplugins::ProcessingParameters::_pulse_bandw, ossimplugins::ProcessingParameters::_pulse_cnt_1, ossimplugins::ProcessingParameters::_pulse_cnt_2, ossimplugins::ProcessingParameters::_pwin_end, ossimplugins::ProcessingParameters::_pwin_start, ossimplugins::ProcessingParameters::_rec_seq, ossimplugins::ProcessingParameters::_recd_type, ossimplugins::ProcessingParameters::_rej_bf_start, ossimplugins::ProcessingParameters::_rej_few_fram, ossimplugins::ProcessingParameters::_rej_ln, ossimplugins::ProcessingParameters::_rej_many_fram, ossimplugins::ProcessingParameters::_rej_mchn_err, ossimplugins::ProcessingParameters::_rej_rec_type, ossimplugins::ProcessingParameters::_rej_vchn_err, ossimplugins::ProcessingParameters::_rep_agc_attn, ossimplugins::ProcessingParameters::_rep_energy_gn, ossimplugins::ProcessingParameters::_rng_amp_coef, ossimplugins::ProcessingParameters::_rng_phas_coef, ossimplugins::ProcessingParameters::_rng_ref_src, ossimplugins::ProcessingParameters::_satellite_id, ossimplugins::ProcessingParameters::_scene_id, ossimplugins::ProcessingParameters::_scr_data_ind, ossimplugins::ProcessingParameters::_sens_config, ossimplugins::ProcessingParameters::_sens_orient, ossimplugins::ProcessingParameters::_skipd_frams, ossimplugins::ProcessingParameters::_slow_time_coef, ossimplugins::ProcessingParameters::_span_x, ossimplugins::ProcessingParameters::_span_y, ossimplugins::ProcessingParameters::_srgr_coefset, ossimplugins::ProcessingParameters::_state_time, ossimplugins::ProcessingParameters::_state_time_inc, ossimplugins::ProcessingParameters::_sych_marker, ossimplugins::ProcessingParameters::_tape_id, ossimplugins::ProcessingParameters::_temp, ossimplugins::ProcessingParameters::_temp_set_inc, ossimplugins::ProcessingParameters::_user_id, ossimplugins::ProcessingParameters::_wo_date, and ossimplugins::ProcessingParameters::_wo_number.
| MainProcessingParameters & | data | ||
Definition at line 270 of file MainProcessingParameters.cpp.
References ossimplugins::MainProcessingParameters::_ant_elev_coor_flag, ossimplugins::MainProcessingParameters::_ant_scal_flag, ossimplugins::MainProcessingParameters::_attach_flag, ossimplugins::MainProcessingParameters::_avg_scene_height_ellpsoid, ossimplugins::MainProcessingParameters::_ax_fm_origin, ossimplugins::MainProcessingParameters::_az_fm_rate, ossimplugins::MainProcessingParameters::_azimut_spacing, ossimplugins::MainProcessingParameters::_bandwidth, ossimplugins::MainProcessingParameters::_beam_overlap, ossimplugins::MainProcessingParameters::_beam_param, ossimplugins::MainProcessingParameters::_calibration_factors, ossimplugins::MainProcessingParameters::_chirp_extract_flag, ossimplugins::MainProcessingParameters::_data_analysis_flag, ossimplugins::MainProcessingParameters::_data_type, ossimplugins::MainProcessingParameters::_detected_flag, ossimplugins::MainProcessingParameters::_dop_amb_coef, ossimplugins::MainProcessingParameters::_dop_amb_flag, ossimplugins::MainProcessingParameters::_dop_cen_flag, ossimplugins::MainProcessingParameters::_echo_comp, ossimplugins::MainProcessingParameters::_echo_comp_ratio, ossimplugins::MainProcessingParameters::_errors_counters, ossimplugins::MainProcessingParameters::_filter_az, ossimplugins::MainProcessingParameters::_filter_coef_az, ossimplugins::MainProcessingParameters::_filter_coef_range, ossimplugins::MainProcessingParameters::_filter_range, ossimplugins::MainProcessingParameters::_first_proc_range_samp, ossimplugins::MainProcessingParameters::_first_zero_doppler_time, ossimplugins::MainProcessingParameters::_gm_rng_comp_inv_filter_flag, ossimplugins::MainProcessingParameters::_image_parameters1, ossimplugins::MainProcessingParameters::_image_parameters2, ossimplugins::MainProcessingParameters::_init_cal_comp, ossimplugins::MainProcessingParameters::_init_cal_ratio, ossimplugins::MainProcessingParameters::_last_zero_doppler_time, ossimplugins::MainProcessingParameters::_line_time_interval, ossimplugins::MainProcessingParameters::_lines_per_burst, ossimplugins::MainProcessingParameters::_look_bw_az, ossimplugins::MainProcessingParameters::_look_sum_flag, ossimplugins::MainProcessingParameters::_noise_comp, ossimplugins::MainProcessingParameters::_noise_comp_ratio, ossimplugins::MainProcessingParameters::_noise_estimation, ossimplugins::MainProcessingParameters::_nominal_chirp, ossimplugins::MainProcessingParameters::_num_lines_proc, ossimplugins::MainProcessingParameters::_num_look_az, ossimplugins::MainProcessingParameters::_num_looks_range, ossimplugins::MainProcessingParameters::_num_output_lines, ossimplugins::MainProcessingParameters::_num_range_lines_per_burst, ossimplugins::MainProcessingParameters::_num_samples_per_line, ossimplugins::MainProcessingParameters::_output_statistics, ossimplugins::MainProcessingParameters::_parameter_code, ossimplugins::MainProcessingParameters::_per_cal_comp, ossimplugins::MainProcessingParameters::_per_cal_ratio, ossimplugins::MainProcessingParameters::_prf_values, ossimplugins::MainProcessingParameters::_radar_freq, ossimplugins::MainProcessingParameters::_range_ref, ossimplugins::MainProcessingParameters::_range_samp_rate, ossimplugins::MainProcessingParameters::_range_spacing, ossimplugins::MainProcessingParameters::_range_spread_comp_flag, ossimplugins::MainProcessingParameters::_raw_data_analysis, ossimplugins::MainProcessingParameters::_rms_equal_flag, ossimplugins::MainProcessingParameters::_srgr_flag, ossimplugins::MainProcessingParameters::_start_time_mds1, ossimplugins::MainProcessingParameters::_start_time_mds2, ossimplugins::MainProcessingParameters::_state_vector_time_1_day, ossimplugins::MainProcessingParameters::_state_vector_time_1_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_1_sec, ossimplugins::MainProcessingParameters::_state_vector_time_2_day, ossimplugins::MainProcessingParameters::_state_vector_time_2_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_2_sec, ossimplugins::MainProcessingParameters::_state_vector_time_3_day, ossimplugins::MainProcessingParameters::_state_vector_time_3_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_3_sec, ossimplugins::MainProcessingParameters::_state_vector_time_4_day, ossimplugins::MainProcessingParameters::_state_vector_time_4_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_4_sec, ossimplugins::MainProcessingParameters::_state_vector_time_5_day, ossimplugins::MainProcessingParameters::_state_vector_time_5_microsec, ossimplugins::MainProcessingParameters::_state_vector_time_5_sec, ossimplugins::MainProcessingParameters::_swath_num, ossimplugins::MainProcessingParameters::_time_diff, ossimplugins::MainProcessingParameters::_time_diff_zero_doppler, ossimplugins::MainProcessingParameters::_time_first_SS1_echo, ossimplugins::MainProcessingParameters::_to_bw_az, ossimplugins::MainProcessingParameters::_vga_com_cal_flag, ossimplugins::MainProcessingParameters::_vga_com_echo_flag, ossimplugins::MainProcessingParameters::_vga_com_nom_time_flag, ossimplugins::MainProcessingParameters::_work_order_id, ossimplugins::MainProcessingParameters::_x_pos_1, ossimplugins::MainProcessingParameters::_x_pos_2, ossimplugins::MainProcessingParameters::_x_pos_3, ossimplugins::MainProcessingParameters::_x_pos_4, ossimplugins::MainProcessingParameters::_x_pos_5, ossimplugins::MainProcessingParameters::_x_vel_1, ossimplugins::MainProcessingParameters::_x_vel_2, ossimplugins::MainProcessingParameters::_x_vel_3, ossimplugins::MainProcessingParameters::_x_vel_4, ossimplugins::MainProcessingParameters::_x_vel_5, ossimplugins::MainProcessingParameters::_y_pos_1, ossimplugins::MainProcessingParameters::_y_pos_2, ossimplugins::MainProcessingParameters::_y_pos_3, ossimplugins::MainProcessingParameters::_y_pos_4, ossimplugins::MainProcessingParameters::_y_pos_5, ossimplugins::MainProcessingParameters::_y_vel_1, ossimplugins::MainProcessingParameters::_y_vel_2, ossimplugins::MainProcessingParameters::_y_vel_3, ossimplugins::MainProcessingParameters::_y_vel_4, ossimplugins::MainProcessingParameters::_y_vel_5, ossimplugins::MainProcessingParameters::_z_pos_1, ossimplugins::MainProcessingParameters::_z_pos_2, ossimplugins::MainProcessingParameters::_z_pos_3, ossimplugins::MainProcessingParameters::_z_pos_4, ossimplugins::MainProcessingParameters::_z_pos_5, ossimplugins::MainProcessingParameters::_z_vel_1, ossimplugins::MainProcessingParameters::_z_vel_2, ossimplugins::MainProcessingParameters::_z_vel_3, ossimplugins::MainProcessingParameters::_z_vel_4, ossimplugins::MainProcessingParameters::_z_vel_5, and ossimplugins::EnvisatAsarRecord::SwitchEndian().
| ErsSarFacilityData & | data | ||
Definition at line 339 of file ErsSarFacilityData.cpp.
References ossimplugins::ErsSarFacilityData::_3_dB_look_bandwidth, ossimplugins::ErsSarFacilityData::_3_dB_look_proc_dopp_bandw, ossimplugins::ErsSarFacilityData::_3_dB_width_CCF, ossimplugins::ErsSarFacilityData::_abs_cal_const_K, ossimplugins::ErsSarFacilityData::_antenna_elev_flag, ossimplugins::ErsSarFacilityData::_asc_node_pos_X_comp, ossimplugins::ErsSarFacilityData::_asc_node_pos_Y_comp, ossimplugins::ErsSarFacilityData::_asc_node_pos_Z_comp, ossimplugins::ErsSarFacilityData::_asc_node_vel_X_comp, ossimplugins::ErsSarFacilityData::_asc_node_vel_Y_comp, ossimplugins::ErsSarFacilityData::_asc_node_vel_Z_comp, ossimplugins::ErsSarFacilityData::_autom_look_scal_gain_flag, ossimplugins::ErsSarFacilityData::_azimuth_baseband_convers_flag, ossimplugins::ErsSarFacilityData::_azimuth_FFT_IFFT_ratio, ossimplugins::ErsSarFacilityData::_cal_gain_change_flag, ossimplugins::ErsSarFacilityData::_cal_gain_changes, ossimplugins::ErsSarFacilityData::_cal_sys_gain, ossimplugins::ErsSarFacilityData::_cal_syst_gain_last_proc, ossimplugins::ErsSarFacilityData::_center_range_pix_mid_az_inc, ossimplugins::ErsSarFacilityData::_coef_ant_elev_1, ossimplugins::ErsSarFacilityData::_coef_ant_elev_2, ossimplugins::ErsSarFacilityData::_coef_ant_elev_3, ossimplugins::ErsSarFacilityData::_coef_ant_elev_4, ossimplugins::ErsSarFacilityData::_coef_ant_elev_5, ossimplugins::ErsSarFacilityData::_coef_ground_range_1, ossimplugins::ErsSarFacilityData::_coef_ground_range_2, ossimplugins::ErsSarFacilityData::_coef_ground_range_3, ossimplugins::ErsSarFacilityData::_coef_ground_range_4, ossimplugins::ErsSarFacilityData::_datation_flag, ossimplugins::ErsSarFacilityData::_dopp_ambig_conf_meas, ossimplugins::ErsSarFacilityData::_dopp_ambig_conf_meas_flag, ossimplugins::ErsSarFacilityData::_dopp_ambig_num, ossimplugins::ErsSarFacilityData::_dopp_cent_conf_meas, ossimplugins::ErsSarFacilityData::_dopp_cent_conf_meas_flag, ossimplugins::ErsSarFacilityData::_dopp_cent_val_flag, ossimplugins::ErsSarFacilityData::_doppler_ambiguity_estimat_flag, ossimplugins::ErsSarFacilityData::_doppler_centroid_cubic_coeff, ossimplugins::ErsSarFacilityData::_estim_bit_error_rate, ossimplugins::ErsSarFacilityData::_first_processed_range_sample, ossimplugins::ErsSarFacilityData::_first_range_pixel_mid_az_inc, ossimplugins::ErsSarFacilityData::_first_rec_gain_read, ossimplugins::ErsSarFacilityData::_first_replica_sample, ossimplugins::ErsSarFacilityData::_first_side_lobe_lev_of_ACF, ossimplugins::ErsSarFacilityData::_first_side_lobe_level, ossimplugins::ErsSarFacilityData::_form_num_range_line_used, ossimplugins::ErsSarFacilityData::_I_channel_bias_correction, ossimplugins::ErsSarFacilityData::_I_channel_gain_correction, ossimplugins::ErsSarFacilityData::_I_gain_imb_lower_bound, ossimplugins::ErsSarFacilityData::_I_gain_imb_upper_bound, ossimplugins::ErsSarFacilityData::_I_Q_quad_depar_lower_bound, ossimplugins::ErsSarFacilityData::_I_Q_quad_depar_upper_bound, ossimplugins::ErsSarFacilityData::_initial_doppler_ambiguity_num, ossimplugins::ErsSarFacilityData::_inp_data_I_mean, ossimplugins::ErsSarFacilityData::_inp_data_I_stddev, ossimplugins::ErsSarFacilityData::_inp_data_Q_mean, ossimplugins::ErsSarFacilityData::_inp_data_Q_stddev, ossimplugins::ErsSarFacilityData::_inp_data_stat_flag, ossimplugins::ErsSarFacilityData::_inp_state_vect_pos_X_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_pos_Y_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_pos_Z_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_vel_Vx_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_vel_Vy_comp, ossimplugins::ErsSarFacilityData::_inp_state_vect_vel_Vz_comp, ossimplugins::ErsSarFacilityData::_inp_state_vector_type_flag, ossimplugins::ErsSarFacilityData::_int_cal_utc, ossimplugins::ErsSarFacilityData::_ISLR_CCF_between_last, ossimplugins::ErsSarFacilityData::_ISLR_of_ACF, ossimplugins::ErsSarFacilityData::_K_gen_date, ossimplugins::ErsSarFacilityData::_K_vers_num, ossimplugins::ErsSarFacilityData::_last_range_pix_mid_az_inc, ossimplugins::ErsSarFacilityData::_last_release_cal_date, ossimplugins::ErsSarFacilityData::_last_release_qc_date, ossimplugins::ErsSarFacilityData::_look_detecion_flag, ossimplugins::ErsSarFacilityData::_look_scalar_gain_1, ossimplugins::ErsSarFacilityData::_look_scalar_gain_2, ossimplugins::ErsSarFacilityData::_look_scalar_gain_3, ossimplugins::ErsSarFacilityData::_look_scalar_gain_4, ossimplugins::ErsSarFacilityData::_look_scalar_gain_5, ossimplugins::ErsSarFacilityData::_look_scalar_gain_6, ossimplugins::ErsSarFacilityData::_look_scalar_gain_7, ossimplugins::ErsSarFacilityData::_look_scalar_gain_8, ossimplugins::ErsSarFacilityData::_low_bound_K, ossimplugins::ErsSarFacilityData::_max_error_range_line_timing, ossimplugins::ErsSarFacilityData::_max_value_look_scalar_gain, ossimplugins::ErsSarFacilityData::_mean_cal_pulse_power, ossimplugins::ErsSarFacilityData::_mean_noise_power, ossimplugins::ErsSarFacilityData::_missing_lines, ossimplugins::ErsSarFacilityData::_name_of_facil_rec, ossimplugins::ErsSarFacilityData::_noise_power, ossimplugins::ErsSarFacilityData::_norm_ref_range_ro, ossimplugins::ErsSarFacilityData::_num_azimuth_blocks_proc, ossimplugins::ErsSarFacilityData::_num_duplic_input_lines, ossimplugins::ErsSarFacilityData::_num_input_raw_data_lines, ossimplugins::ErsSarFacilityData::_num_range_samp_discarded, ossimplugins::ErsSarFacilityData::_num_valid_cal_pulses, ossimplugins::ErsSarFacilityData::_num_valid_noise_pulses, ossimplugins::ErsSarFacilityData::_num_valid_pixels_per_range, ossimplugins::ErsSarFacilityData::_num_valid_replicas, ossimplugins::ErsSarFacilityData::_OGOB_flag, ossimplugins::ErsSarFacilityData::_out_image_max_value, ossimplugins::ErsSarFacilityData::_out_image_mean, ossimplugins::ErsSarFacilityData::_out_image_std_dev, ossimplugins::ErsSarFacilityData::_out_pixel_bit_length, ossimplugins::ErsSarFacilityData::_outp_data_mean_flag, ossimplugins::ErsSarFacilityData::_peak_loc_CCF_betw_last, ossimplugins::ErsSarFacilityData::_peak_loc_cross_correl_fun, ossimplugins::ErsSarFacilityData::_PRF_changes, ossimplugins::ErsSarFacilityData::_prf_code_change_flag, ossimplugins::ErsSarFacilityData::_PRF_code_first_range_line, ossimplugins::ErsSarFacilityData::_PRF_code_last_range_line, ossimplugins::ErsSarFacilityData::_proc_gain_param_1, ossimplugins::ErsSarFacilityData::_proc_gain_param_2, ossimplugins::ErsSarFacilityData::_proc_gain_param_3, ossimplugins::ErsSarFacilityData::_proc_noise_scale_fact, ossimplugins::ErsSarFacilityData::_pulse_width_of_ACF_3db, ossimplugins::ErsSarFacilityData::_Q_channel_bias_correction, ossimplugins::ErsSarFacilityData::_Q_channel_gain_correction, ossimplugins::ErsSarFacilityData::_Q_channel_I_Q_correction, ossimplugins::ErsSarFacilityData::_qa_summary_flag, ossimplugins::ErsSarFacilityData::_quirp_qu_flag, ossimplugins::ErsSarFacilityData::_range_comp_norm_fact, ossimplugins::ErsSarFacilityData::_range_lines_skip_factor, ossimplugins::ErsSarFacilityData::_range_spread_loss_comp_flag, ossimplugins::ErsSarFacilityData::_range_time_origin_ant, ossimplugins::ErsSarFacilityData::_raw_data_correction_flag, ossimplugins::ErsSarFacilityData::_rec_gain_changes, ossimplugins::ErsSarFacilityData::_receiver_gain_last_proc, ossimplugins::ErsSarFacilityData::_replica_norm_method_flag, ossimplugins::ErsSarFacilityData::_replica_power, ossimplugins::ErsSarFacilityData::_Roll_Tilt_Mode_flag, ossimplugins::ErsSarFacilityData::_samp_win_start_first, ossimplugins::ErsSarFacilityData::_samp_win_start_last, ossimplugins::ErsSarFacilityData::_samp_window_start_time_bias, ossimplugins::ErsSarFacilityData::_samples_per_line_used, ossimplugins::ErsSarFacilityData::_sampling_win_change_flag, ossimplugins::ErsSarFacilityData::_sampling_win_changes, ossimplugins::ErsSarFacilityData::_sat_binary_time_of_first, ossimplugins::ErsSarFacilityData::_thresh_no_10_flag, ossimplugins::ErsSarFacilityData::_thresh_no_11_flag, ossimplugins::ErsSarFacilityData::_thresh_no_1_flag, ossimplugins::ErsSarFacilityData::_thresh_no_2_flag, ossimplugins::ErsSarFacilityData::_thresh_no_3_flag, ossimplugins::ErsSarFacilityData::_thresh_no_4_flag, ossimplugins::ErsSarFacilityData::_thresh_no_5_flag, ossimplugins::ErsSarFacilityData::_thresh_no_6_flag, ossimplugins::ErsSarFacilityData::_thresh_no_7_flag, ossimplugins::ErsSarFacilityData::_thresh_no_8_flag, ossimplugins::ErsSarFacilityData::_thresh_no_9_flag, ossimplugins::ErsSarFacilityData::_time_asc_node_state_vectors, ossimplugins::ErsSarFacilityData::_time_of_inp_state_vectors, ossimplugins::ErsSarFacilityData::_time_raw_data_first_input, ossimplugins::ErsSarFacilityData::_update_period_range_match, ossimplugins::ErsSarFacilityData::_upp_bound_K, ossimplugins::ErsSarFacilityData::_win_coeff_for_azi_match, and ossimplugins::ErsSarFacilityData::_win_coeff_for_range_match.
| std::istream& ossimplugins::operator>> | ( | std::istream & | is, |
| AlosPalsarFacilityData & | data | ||
Definition at line 340 of file AlosPalsarFacilityData.cpp.
References ossimplugins::AlosPalsarFacilityData::_3_dB_look_bandwidth, ossimplugins::AlosPalsarFacilityData::_3_dB_look_proc_dopp_bandw, ossimplugins::AlosPalsarFacilityData::_3_dB_width_CCF, ossimplugins::AlosPalsarFacilityData::_abs_cal_const_K, ossimplugins::AlosPalsarFacilityData::_antenna_elev_flag, ossimplugins::AlosPalsarFacilityData::_asc_node_pos_X_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_pos_Y_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_pos_Z_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_vel_X_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_vel_Y_comp, ossimplugins::AlosPalsarFacilityData::_asc_node_vel_Z_comp, ossimplugins::AlosPalsarFacilityData::_autom_look_scal_gain_flag, ossimplugins::AlosPalsarFacilityData::_azimuth_baseband_convers_flag, ossimplugins::AlosPalsarFacilityData::_azimuth_FFT_IFFT_ratio, ossimplugins::AlosPalsarFacilityData::_cal_gain_change_flag, ossimplugins::AlosPalsarFacilityData::_cal_gain_changes, ossimplugins::AlosPalsarFacilityData::_cal_sys_gain, ossimplugins::AlosPalsarFacilityData::_cal_syst_gain_last_proc, ossimplugins::AlosPalsarFacilityData::_center_range_pix_mid_az_inc, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_1, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_2, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_3, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_4, ossimplugins::AlosPalsarFacilityData::_coef_ant_elev_5, ossimplugins::AlosPalsarFacilityData::_coef_ground_range_1, ossimplugins::AlosPalsarFacilityData::_coef_ground_range_2, ossimplugins::AlosPalsarFacilityData::_coef_ground_range_3, ossimplugins::AlosPalsarFacilityData::_coef_ground_range_4, ossimplugins::AlosPalsarFacilityData::_datation_flag, ossimplugins::AlosPalsarFacilityData::_dopp_ambig_conf_meas, ossimplugins::AlosPalsarFacilityData::_dopp_ambig_conf_meas_flag, ossimplugins::AlosPalsarFacilityData::_dopp_ambig_num, ossimplugins::AlosPalsarFacilityData::_dopp_cent_conf_meas, ossimplugins::AlosPalsarFacilityData::_dopp_cent_conf_meas_flag, ossimplugins::AlosPalsarFacilityData::_dopp_cent_val_flag, ossimplugins::AlosPalsarFacilityData::_doppler_ambiguity_estimat_flag, ossimplugins::AlosPalsarFacilityData::_doppler_centroid_cubic_coeff, ossimplugins::AlosPalsarFacilityData::_estim_bit_error_rate, ossimplugins::AlosPalsarFacilityData::_first_processed_range_sample, ossimplugins::AlosPalsarFacilityData::_first_range_pixel_mid_az_inc, ossimplugins::AlosPalsarFacilityData::_first_rec_gain_read, ossimplugins::AlosPalsarFacilityData::_first_replica_sample, ossimplugins::AlosPalsarFacilityData::_first_side_lobe_lev_of_ACF, ossimplugins::AlosPalsarFacilityData::_first_side_lobe_level, ossimplugins::AlosPalsarFacilityData::_form_num_range_line_used, ossimplugins::AlosPalsarFacilityData::_I_channel_bias_correction, ossimplugins::AlosPalsarFacilityData::_I_channel_gain_correction, ossimplugins::AlosPalsarFacilityData::_I_gain_imb_lower_bound, ossimplugins::AlosPalsarFacilityData::_I_gain_imb_upper_bound, ossimplugins::AlosPalsarFacilityData::_I_Q_quad_depar_lower_bound, ossimplugins::AlosPalsarFacilityData::_I_Q_quad_depar_upper_bound, ossimplugins::AlosPalsarFacilityData::_initial_doppler_ambiguity_num, ossimplugins::AlosPalsarFacilityData::_inp_data_I_mean, ossimplugins::AlosPalsarFacilityData::_inp_data_I_stddev, ossimplugins::AlosPalsarFacilityData::_inp_data_Q_mean, ossimplugins::AlosPalsarFacilityData::_inp_data_Q_stddev, ossimplugins::AlosPalsarFacilityData::_inp_data_stat_flag, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_pos_X_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_pos_Y_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_pos_Z_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_vel_Vx_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_vel_Vy_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vect_vel_Vz_comp, ossimplugins::AlosPalsarFacilityData::_inp_state_vector_type_flag, ossimplugins::AlosPalsarFacilityData::_int_cal_utc, ossimplugins::AlosPalsarFacilityData::_ISLR_CCF_between_last, ossimplugins::AlosPalsarFacilityData::_ISLR_of_ACF, ossimplugins::AlosPalsarFacilityData::_K_gen_date, ossimplugins::AlosPalsarFacilityData::_K_vers_num, ossimplugins::AlosPalsarFacilityData::_last_range_pix_mid_az_inc, ossimplugins::AlosPalsarFacilityData::_last_release_cal_date, ossimplugins::AlosPalsarFacilityData::_last_release_qc_date, ossimplugins::AlosPalsarFacilityData::_look_detecion_flag, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_1, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_2, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_3, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_4, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_5, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_6, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_7, ossimplugins::AlosPalsarFacilityData::_look_scalar_gain_8, ossimplugins::AlosPalsarFacilityData::_low_bound_K, ossimplugins::AlosPalsarFacilityData::_max_error_range_line_timing, ossimplugins::AlosPalsarFacilityData::_max_value_look_scalar_gain, ossimplugins::AlosPalsarFacilityData::_mean_cal_pulse_power, ossimplugins::AlosPalsarFacilityData::_mean_noise_power, ossimplugins::AlosPalsarFacilityData::_missing_lines, ossimplugins::AlosPalsarFacilityData::_name_of_facil_rec, ossimplugins::AlosPalsarFacilityData::_noise_power, ossimplugins::AlosPalsarFacilityData::_norm_ref_range_ro, ossimplugins::AlosPalsarFacilityData::_num_azimuth_blocks_proc, ossimplugins::AlosPalsarFacilityData::_num_duplic_input_lines, ossimplugins::AlosPalsarFacilityData::_num_input_raw_data_lines, ossimplugins::AlosPalsarFacilityData::_num_range_samp_discarded, ossimplugins::AlosPalsarFacilityData::_num_valid_cal_pulses, ossimplugins::AlosPalsarFacilityData::_num_valid_noise_pulses, ossimplugins::AlosPalsarFacilityData::_num_valid_pixels_per_range, ossimplugins::AlosPalsarFacilityData::_num_valid_replicas, ossimplugins::AlosPalsarFacilityData::_OGOB_flag, ossimplugins::AlosPalsarFacilityData::_out_image_max_value, ossimplugins::AlosPalsarFacilityData::_out_image_mean, ossimplugins::AlosPalsarFacilityData::_out_image_std_dev, ossimplugins::AlosPalsarFacilityData::_out_pixel_bit_length, ossimplugins::AlosPalsarFacilityData::_outp_data_mean_flag, ossimplugins::AlosPalsarFacilityData::_peak_loc_CCF_betw_last, ossimplugins::AlosPalsarFacilityData::_peak_loc_cross_correl_fun, ossimplugins::AlosPalsarFacilityData::_PRF_changes, ossimplugins::AlosPalsarFacilityData::_prf_code_change_flag, ossimplugins::AlosPalsarFacilityData::_PRF_code_first_range_line, ossimplugins::AlosPalsarFacilityData::_PRF_code_last_range_line, ossimplugins::AlosPalsarFacilityData::_proc_gain_param_1, ossimplugins::AlosPalsarFacilityData::_proc_gain_param_2, ossimplugins::AlosPalsarFacilityData::_proc_gain_param_3, ossimplugins::AlosPalsarFacilityData::_proc_noise_scale_fact, ossimplugins::AlosPalsarFacilityData::_pulse_width_of_ACF_3db, ossimplugins::AlosPalsarFacilityData::_Q_channel_bias_correction, ossimplugins::AlosPalsarFacilityData::_Q_channel_gain_correction, ossimplugins::AlosPalsarFacilityData::_Q_channel_I_Q_correction, ossimplugins::AlosPalsarFacilityData::_qa_summary_flag, ossimplugins::AlosPalsarFacilityData::_quirp_qu_flag, ossimplugins::AlosPalsarFacilityData::_range_comp_norm_fact, ossimplugins::AlosPalsarFacilityData::_range_lines_skip_factor, ossimplugins::AlosPalsarFacilityData::_range_spread_loss_comp_flag, ossimplugins::AlosPalsarFacilityData::_range_time_origin_ant, ossimplugins::AlosPalsarFacilityData::_raw_data_correction_flag, ossimplugins::AlosPalsarFacilityData::_rec_gain_changes, ossimplugins::AlosPalsarFacilityData::_receiver_gain_last_proc, ossimplugins::AlosPalsarFacilityData::_replica_norm_method_flag, ossimplugins::AlosPalsarFacilityData::_replica_power, ossimplugins::AlosPalsarFacilityData::_Roll_Tilt_Mode_flag, ossimplugins::AlosPalsarFacilityData::_samp_win_start_first, ossimplugins::AlosPalsarFacilityData::_samp_win_start_last, ossimplugins::AlosPalsarFacilityData::_samp_window_start_time_bias, ossimplugins::AlosPalsarFacilityData::_samples_per_line_used, ossimplugins::AlosPalsarFacilityData::_sampling_win_change_flag, ossimplugins::AlosPalsarFacilityData::_sampling_win_changes, ossimplugins::AlosPalsarFacilityData::_sat_binary_time_of_first, ossimplugins::AlosPalsarFacilityData::_thresh_no_10_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_11_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_1_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_2_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_3_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_4_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_5_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_6_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_7_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_8_flag, ossimplugins::AlosPalsarFacilityData::_thresh_no_9_flag, ossimplugins::AlosPalsarFacilityData::_time_asc_node_state_vectors, ossimplugins::AlosPalsarFacilityData::_time_of_inp_state_vectors, ossimplugins::AlosPalsarFacilityData::_time_raw_data_first_input, ossimplugins::AlosPalsarFacilityData::_update_period_range_match, ossimplugins::AlosPalsarFacilityData::_upp_bound_K, ossimplugins::AlosPalsarFacilityData::_win_coeff_for_azi_match, and ossimplugins::AlosPalsarFacilityData::_win_coeff_for_range_match.
| OSSIM_PLUGINS_DLL void ossimplugins::ossimSharedLibraryFinalize | ( | ) |
Definition at line 88 of file ossimPluginInit.cpp.
References ossimplugins::ossimPluginProjectionFactory::instance(), ossimProjectionFactoryRegistry::instance(), ossimplugins::ossimPluginReaderFactory::instance(), and ossimImageHandlerRegistry::instance().
| OSSIM_PLUGINS_DLL void ossimplugins::ossimSharedLibraryInitialize | ( | ossimSharedObjectInfo ** | info | ) |
Register the readers...
Register the projection factory. Note that this must be pushed to the front of the factory or bilinear projection will be picked up.
Definition at line 61 of file ossimPluginInit.cpp.
References cnesDescription, cnesInfo, cnesObjList, ossimSharedObjectInfo::getClassName, getCnesClassName(), getCnesDescription(), getCnesNumberOfClassNames(), ossimSharedObjectInfo::getDescription, ossimSharedObjectInfo::getNumberOfClassNames, ossimplugins::ossimPluginProjectionFactory::getTypeNameList(), ossimplugins::ossimPluginReaderFactory::getTypeNameList(), ossimplugins::ossimPluginProjectionFactory::instance(), ossimProjectionFactoryRegistry::instance(), ossimplugins::ossimPluginReaderFactory::instance(), and ossimImageHandlerRegistry::instance().
| ossimplugins::RTTI_DEF1 | ( | ossimCosmoSkymedModel | , |
| "ossimCosmoSkymedModel" | , | ||
| ossimGeometricSarSensorModel | |||
| ossimplugins::RTTI_DEF1 | ( | ossimPluginReaderFactory | , |
| "ossimPluginReaderFactory" | , | ||
| ossimImageHandlerFactoryBase | |||
| ossimplugins::RTTI_DEF1 | ( | ossimTileMapModel | , |
| "ossimTileMapModel" | , | ||
| ossimSensorModel | |||
| ossimplugins::RTTI_DEF1 | ( | ossimFormosatModel | , |
| "ossimFormosatModel" | , | ||
| ossimplugins::RTTI_DEF1 | ( | ossimEnvisatAsarModel | , |
| "ossimEnvisatAsarModel" | , | ||
| ossimplugins::RTTI_DEF1 | ( | ossimErsSarModel | , |
| "ossimErsSarModel" | , | ||
| ossimplugins::RTTI_DEF1 | ( | ossimGeometricSarSensorModel | , |
| "ossimGeometricSarSensorModel" | , | ||
| ossimplugins::RTTI_DEF1 | ( | ossimAlosPalsarModel | , |
| "ossimAlosPalsarModel" | , | ||
| ossimplugins::RTTI_DEF1 | ( | ossimRadarSatModel | , |
| "ossimRadarSatModel" | , | ||
| ossimplugins::RTTI_DEF1 | ( | ossimRadarSat2Model | , |
| "ossimRadarSat2Model" | , | ||
| ossimplugins::RTTI_DEF1 | ( | ossimRadarSat2RPCModel | , |
| "ossimRadarSat2RPCModel" | , | ||
| ossimRpcModel | |||
| ossimplugins::RTTI_DEF1 | ( | ossimSpot6Model | , |
| "ossimSpot6Model" | , | ||
| ossimRpcModel | |||
| ossimplugins::RTTI_DEF1 | ( | ossimPleiadesModel | , |
| "ossimPleiadesModel" | , | ||
| ossimRpcModel | |||
| ossimplugins::RTTI_DEF1 | ( | ossimTerraSarModel | , |
| "ossimTerraSarModel" | , | ||
| void ossimplugins::SwitchEndian | ( | int & | value | ) |
Definition at line 67 of file ProcessedDataRecord.cpp.
| ossimString ossimplugins::cnesDescription |
Definition at line 41 of file ossimPluginInit.cpp.
Referenced by getCnesDescription(), and ossimSharedLibraryInitialize().
| ossimSharedObjectInfo ossimplugins::cnesInfo |
Definition at line 40 of file ossimPluginInit.cpp.
Referenced by ossimSharedLibraryInitialize().
| std::vector<ossimString> ossimplugins::cnesObjList |
Definition at line 42 of file ossimPluginInit.cpp.
Referenced by getCnesClassName(), getCnesNumberOfClassNames(), and ossimSharedLibraryInitialize().
