This class is able to read the ASAR MainProcessingParameters record. More...
#include <MainProcessingParameters.h>
| MainProcessingParameters () | |
| Constructor. More... | |
| virtual | ~MainProcessingParameters () |
| Destructor. More... | |
| MainProcessingParameters (const MainProcessingParameters &rhs) | |
| Copy constructor. More... | |
| MainProcessingParameters & | operator= (const MainProcessingParameters &rhs) |
| Copy operator. More... | |
| EnvisatAsarRecord * | Instanciate () |
| This function is able to create a new instance of the class. More... | |
| EnvisatAsarRecord * | Clone () |
| This function is able to create a new instance of the class initialised with the data of the calling instance. More... | |
| void | Read (std::istream &is) |
| Reads the class data from a stream. More... | |
| void | Write (std::ostream &os) |
| Writes the class to a stream. More... | |
| std::string | get_first_zero_doppler_time () |
| first_zero_doppler_time More... | |
| bool | get_attach_flag () |
| attach_flag More... | |
| std::string | get_last_zero_doppler_time () |
| last_zero_doppler_time More... | |
| std::string | get_work_order_id () |
| work_order_id More... | |
| float | get_time_diff () |
| time_diff More... | |
| std::string | get_swath_num () |
| swath_num More... | |
| float | get_range_spacing () |
| range_spacing More... | |
| float | get_azimut_spacing () |
| azimut_spacing More... | |
| float | get_line_time_interval () |
| line_time_interval More... | |
| unsigned int | get_num_output_lines () |
| num_output_lines More... | |
| unsigned int | get_num_samples_per_line () |
| num_samples_per_line More... | |
| std::string | get_data_type () |
| data_type More... | |
| unsigned int | get_num_range_lines_per_burst () |
| num_range_lines_per_burst More... | |
| float | get_time_diff_zero_doppler () |
| time_diff_zero_doppler More... | |
| bool | get_data_analysis_flag () |
| data_analysis_flag More... | |
| bool | get_ant_elev_coor_flag () |
| ant_elev_coor_flag More... | |
| bool | get_chirp_extract_flag () |
| chirp_extract_flag More... | |
| bool | get_srgr_flag () |
| srgr_flag More... | |
| bool | get_dop_cen_flag () |
| dop_cen_flag More... | |
| bool | get_dop_amb_flag () |
| dop_amb_flag More... | |
| bool | get_range_spread_comp_flag () |
| range_spread_comp_flag More... | |
| bool | get_detected_flag () |
| detected_flag More... | |
| bool | get_look_sum_flag () |
| look_sum_flag More... | |
| bool | get_rms_equal_flag () |
| rms_equal_flag More... | |
| bool | get_ant_scal_flag () |
| ant_scal_flag More... | |
| bool | get_vga_com_echo_flag () |
| vga_com_echo_flag More... | |
| bool | get_vga_com_cal_flag () |
| vga_com_cal_flag More... | |
| bool | get_vga_com_nom_time_flag () |
| vga_com_nom_time_flag More... | |
| bool | get_gm_rng_comp_inv_filter_flag () |
| gm_rng_comp_inv_filter_flag More... | |
| std::string | get_raw_data_analysis () |
| raw_data_analysis More... | |
| std::string | get_start_time_mds1 () |
| start_time_mds1 More... | |
| std::string | get_start_time_mds2 () |
| start_time_mds2 More... | |
| std::string | get_parameter_code () |
| parameter_code More... | |
| std::string | get_errors_counters () |
| errors_counters More... | |
| std::string | get_image_parameters1 () |
| image_parameters block1 More... | |
| float * | get_prf_values () |
| prf_values[5] More... | |
| float | get_prf () |
| prf (i.e prf_values[0]) More... | |
| std::string | get_image_parameters2 () |
| image_parameters block2 More... | |
| unsigned int | get_first_proc_range_samp () |
| first_proc_range_samp More... | |
| float | get_range_ref () |
| range_ref More... | |
| float | get_range_samp_rate () |
| range_samp_rate More... | |
| float | get_radar_freq () |
| radar_freq More... | |
| unsigned short | get_num_looks_range () |
| num_looks_range More... | |
| std::string | get_filter_range () |
| filter_range More... | |
| float | get_filter_coef_range () |
| filter_coef_range More... | |
| std::string | get_bandwidth () |
| bandwidth More... | |
| std::string | get_nominal_chirp () |
| nominal_chirp More... | |
| unsigned int | get_num_lines_proc () |
| num_lines_proc More... | |
| unsigned short | get_num_look_az () |
| num_look_az More... | |
| float | get_look_bw_az () |
| look_bw_az More... | |
| float | get_to_bw_az () |
| to_bw_az More... | |
| std::string | get_filter_az () |
| filter_az More... | |
| float | get_filter_coef_az () |
| filter_coef_az More... | |
| float * | get_az_fm_rate () |
| az_fm_rate[3] More... | |
| float | get_ax_fm_origin () |
| ax_fm_origin More... | |
| float | get_dop_amb_coef () |
| dop_amb_coef More... | |
| std::string | get_calibration_factors () |
| calibration_factors More... | |
| std::string | get_noise_estimation () |
| noise_estimation More... | |
| std::string | get_output_statistics () |
| output_statistics More... | |
| float | get_avg_scene_height_ellpsoid () |
| avg_scene_height_ellpsoid More... | |
| std::string | get_echo_comp () |
| echo_comp More... | |
| std::string | get_echo_comp_ratio () |
| echo_comp_ratio More... | |
| std::string | get_init_cal_comp () |
| init_cal_comp More... | |
| std::string | get_init_cal_ratio () |
| init_cal_ratio More... | |
| std::string | get_per_cal_comp () |
| per_cal_comp More... | |
| std::string | get_per_cal_ratio () |
| per_cal_ratio More... | |
| std::string | get_noise_comp () |
| noise_comp More... | |
| std::string | get_noise_comp_ratio () |
| noise_comp_ratio More... | |
| unsigned int * | get_beam_overlap () |
| beam_overlap[4] More... | |
| float * | get_beam_param () |
| beam_param[4] More... | |
| unsigned int * | get_lines_per_burst () |
| lines_per_burst[5] More... | |
| std::string | get_time_first_SS1_echo () |
| time_first_SS1_echo More... | |
| int | get_state_vector_time_1_day () |
| state_vector_time_1 day More... | |
| unsigned int | get_state_vector_time_1_sec () |
| state_vector_time_1 sec More... | |
| unsigned int | get_state_vector_time_1_microsec () |
| state_vector_time_1 microsec More... | |
| int | get_x_pos_1 () |
| x_pos_1 More... | |
| int | get_y_pos_1 () |
| y_pos_1 More... | |
| int | get_z_pos_1 () |
| z_pos_1 More... | |
| int | get_x_vel_1 () |
| x_vel_1 More... | |
| int | get_y_vel_1 () |
| y_vel_1 More... | |
| int | get_z_vel_1 () |
| z_vel_1 More... | |
| int | get_state_vector_time_2_day () |
| state_vector_time_2 day More... | |
| unsigned int | get_state_vector_time_2_sec () |
| state_vector_time_2 sec More... | |
| unsigned int | get_state_vector_time_2_microsec () |
| int | get_x_pos_2 () |
| x_pos_2 More... | |
| int | get_y_pos_2 () |
| y_pos_2 More... | |
| int | get_z_pos_2 () |
| z_pos_2 More... | |
| int | get_x_vel_2 () |
| x_vel_2 More... | |
| int | get_y_vel_2 () |
| y_vel_2 More... | |
| int | get_z_vel_2 () |
| z_vel_2 More... | |
| int | get_state_vector_time_3_day () |
| state_vector_time_3 day More... | |
| unsigned int | get_state_vector_time_3_sec () |
| state_vector_time_3 sec More... | |
| unsigned int | get_state_vector_time_3_microsec () |
| state_vector_time_3 microsec More... | |
| int | get_x_pos_3 () |
| x_pos_3 More... | |
| int | get_y_pos_3 () |
| y_pos_3 More... | |
| int | get_z_pos_3 () |
| z_pos_3 More... | |
| int | get_x_vel_3 () |
| x_vel_3 More... | |
| int | get_y_vel_3 () |
| y_vel_3 More... | |
| int | get_z_vel_3 () |
| z_vel_3 More... | |
| int | get_state_vector_time_4_day () |
| state_vector_time_4 day More... | |
| unsigned int | get_state_vector_time_4_sec () |
| unsigned int | get_state_vector_time_4_microsec () |
| state_vector_time_4 microsec More... | |
| int | get_x_pos_4 () |
| x_pos_4 More... | |
| int | get_y_pos_4 () |
| y_pos_4 More... | |
| int | get_z_pos_4 () |
| z_pos_4 More... | |
| int | get_x_vel_4 () |
| x_vel_4 More... | |
| int | get_y_vel_4 () |
| y_vel_4 More... | |
| int | get_z_vel_4 () |
| z_vel_4 More... | |
| int | get_state_vector_time_5_day () |
| state_vector_time_5 day More... | |
| unsigned int | get_state_vector_time_5_sec () |
| state_vector_time_5 sec More... | |
| unsigned int | get_state_vector_time_5_microsec () |
| state_vector_time_5 microsec More... | |
| int | get_x_pos_5 () |
| x_pos_5 More... | |
| int | get_y_pos_5 () |
| y_pos_5 More... | |
| int | get_z_pos_5 () |
| z_pos_5 More... | |
| int | get_x_vel_5 () |
| x_vel_5 More... | |
| int | get_y_vel_5 () |
| y_vel_5 More... | |
| int | get_z_vel_5 () |
| z_vel_5 More... | |
Public Member Functions inherited from ossimplugins::EnvisatAsarRecord | |
| EnvisatAsarRecord (std::string mnemonic) | |
| virtual | ~EnvisatAsarRecord () |
| EnvisatAsarRecord (const EnvisatAsarRecord &rhs) | |
| std::string | get_mnemonic () |
| Returns the mnemonic of the record. More... | |
Public Attributes | |
| std::string | _first_zero_doppler_time |
| bool | _attach_flag |
| std::string | _last_zero_doppler_time |
| std::string | _work_order_id |
| float | _time_diff |
| std::string | _swath_num |
| float | _range_spacing |
| float | _azimut_spacing |
| float | _line_time_interval |
| unsigned int | _num_output_lines |
| unsigned int | _num_samples_per_line |
| std::string | _data_type |
| unsigned int | _num_range_lines_per_burst |
| float | _time_diff_zero_doppler |
| bool | _data_analysis_flag |
| bool | _ant_elev_coor_flag |
| bool | _chirp_extract_flag |
| bool | _srgr_flag |
| bool | _dop_cen_flag |
| bool | _dop_amb_flag |
| bool | _range_spread_comp_flag |
| bool | _detected_flag |
| bool | _look_sum_flag |
| bool | _rms_equal_flag |
| bool | _ant_scal_flag |
| bool | _vga_com_echo_flag |
| bool | _vga_com_cal_flag |
| bool | _vga_com_nom_time_flag |
| bool | _gm_rng_comp_inv_filter_flag |
| std::string | _raw_data_analysis |
| std::string | _start_time_mds1 |
| std::string | _start_time_mds2 |
| std::string | _parameter_code |
| std::string | _errors_counters |
| std::string | _image_parameters1 |
| image_parameters block 1 More... | |
| float | _prf_values [5] |
| PRF. More... | |
| std::string | _image_parameters2 |
| image_parameters block 2 More... | |
| unsigned int | _first_proc_range_samp |
| float | _range_ref |
| float | _range_samp_rate |
| float | _radar_freq |
| unsigned short | _num_looks_range |
| std::string | _filter_range |
| float | _filter_coef_range |
| std::string | _bandwidth |
| std::string | _nominal_chirp |
| unsigned int | _num_lines_proc |
| unsigned short | _num_look_az |
| float | _look_bw_az |
| float | _to_bw_az |
| std::string | _filter_az |
| float | _filter_coef_az |
| float | _az_fm_rate [3] |
| float | _ax_fm_origin |
| float | _dop_amb_coef |
| std::string | _calibration_factors |
| std::string | _noise_estimation |
| std::string | _output_statistics |
| float | _avg_scene_height_ellpsoid |
| std::string | _echo_comp |
| std::string | _echo_comp_ratio |
| std::string | _init_cal_comp |
| std::string | _init_cal_ratio |
| std::string | _per_cal_comp |
| std::string | _per_cal_ratio |
| std::string | _noise_comp |
| std::string | _noise_comp_ratio |
| unsigned int | _beam_overlap [4] |
| float | _beam_param [4] |
| unsigned int | _lines_per_burst [5] |
| std::string | _time_first_SS1_echo |
| int | _state_vector_time_1_day |
| state_vector_time_1_day More... | |
| unsigned int | _state_vector_time_1_sec |
| state_vector_time_1_sec More... | |
| unsigned int | _state_vector_time_1_microsec |
| state_vector_time_1_microsec More... | |
| int | _x_pos_1 |
| x_pos_1 More... | |
| int | _y_pos_1 |
| y_pos_1 More... | |
| int | _z_pos_1 |
| z_pos_1 More... | |
| int | _x_vel_1 |
| x_vel_1 More... | |
| int | _y_vel_1 |
| y_vel_1 More... | |
| int | _z_vel_1 |
| z_vel_1 More... | |
| int | _state_vector_time_2_day |
| state_vector_time_2_day More... | |
| unsigned int | _state_vector_time_2_sec |
| state_vector_time_2_sec More... | |
| unsigned int | _state_vector_time_2_microsec |
| state_vector_time_2_microsec More... | |
| int | _x_pos_2 |
| x_pos_2 More... | |
| int | _y_pos_2 |
| y_pos_2 More... | |
| int | _z_pos_2 |
| z_pos_2 More... | |
| int | _x_vel_2 |
| x_vel_2 More... | |
| int | _y_vel_2 |
| y_vel_2 More... | |
| int | _z_vel_2 |
| z_vel_2 More... | |
| int | _state_vector_time_3_day |
| state_vector_time_3_day More... | |
| unsigned int | _state_vector_time_3_sec |
| state_vector_time_3_sec More... | |
| unsigned int | _state_vector_time_3_microsec |
| state_vector_time_3_microsec More... | |
| int | _x_pos_3 |
| x_pos_3 More... | |
| int | _y_pos_3 |
| y_pos_3 More... | |
| int | _z_pos_3 |
| z_pos_3 More... | |
| int | _x_vel_3 |
| x_vel_3 More... | |
| int | _y_vel_3 |
| y_vel_3 More... | |
| int | _z_vel_3 |
| z_vel_3 More... | |
| int | _state_vector_time_4_day |
| state_vector_time_4_day More... | |
| unsigned int | _state_vector_time_4_sec |
| state_vector_time_4_sec More... | |
| unsigned int | _state_vector_time_4_microsec |
| state_vector_time_4_microsec More... | |
| int | _x_pos_4 |
| x_pos_4 More... | |
| int | _y_pos_4 |
| y_pos_4 More... | |
| int | _z_pos_4 |
| z_pos_4 More... | |
| int | _x_vel_4 |
| x_vel_4 More... | |
| int | _y_vel_4 |
| y_vel_4 More... | |
| int | _z_vel_4 |
| z_vel_4 More... | |
| int | _state_vector_time_5_day |
| state_vector_time_5_day More... | |
| unsigned int | _state_vector_time_5_sec |
| state_vector_time_5_sec More... | |
| unsigned int | _state_vector_time_5_microsec |
| state_vector_time_5_microsec More... | |
| int | _x_pos_5 |
| x_pos_5 More... | |
| int | _y_pos_5 |
| y_pos_5 More... | |
| int | _z_pos_5 |
| z_pos_5 More... | |
| int | _x_vel_5 |
| x_vel_5 More... | |
| int | _y_vel_5 |
| y_vel_5 More... | |
| int | _z_vel_5 |
| z_vel_5 More... | |
Friends | |
| std::ostream & | operator<< (std::ostream &os, const MainProcessingParameters &data) |
| This function writes the MainProcessingParameters in a stream. More... | |
| std::istream & | operator>> (std::istream &is, MainProcessingParameters &data) |
| This function reads a MainProcessingParameters from a stream. More... | |
Protected Member Functions inherited from ossimplugins::EnvisatAsarRecord | |
| template<typename T > | |
| void | SwitchEndian (T &value) |
| This function switches the LSB value and the MSB value of the parameter. More... | |
Protected Attributes inherited from ossimplugins::EnvisatAsarRecord | |
| std::string | _mnemonic |
Definition at line 25 of file MainProcessingParameters.h.
| ossimplugins::MainProcessingParameters::MainProcessingParameters | ( | ) |
Constructor.
Definition at line 17 of file MainProcessingParameters.cpp.
Referenced by Clone(), and Instanciate().
| ossimplugins::MainProcessingParameters::MainProcessingParameters | ( | const MainProcessingParameters & | rhs | ) |
Copy constructor.
Definition at line 704 of file MainProcessingParameters.cpp.
References _az_fm_rate, _beam_overlap, _beam_param, _lines_per_burst, and _prf_values.
inlinevirtual |
Implements ossimplugins::EnvisatAsarRecord.
Definition at line 69 of file MainProcessingParameters.h.
References MainProcessingParameters().
inline |
ant_elev_coor_flag
Definition at line 199 of file MainProcessingParameters.h.
References _ant_elev_coor_flag.
inline |
ant_scal_flag
Definition at line 262 of file MainProcessingParameters.h.
References _ant_scal_flag.
inline |
attach_flag
Definition at line 101 of file MainProcessingParameters.h.
References _attach_flag.
inline |
Definition at line 507 of file MainProcessingParameters.h.
References _avg_scene_height_ellpsoid.
Referenced by ossimplugins::ossimEnvisatAsarModel::saveState().
inline |
ax_fm_origin
Definition at line 472 of file MainProcessingParameters.h.
References _ax_fm_origin.
inline |
az_fm_rate[3]
Definition at line 465 of file MainProcessingParameters.h.
References _az_fm_rate.
inline |
azimut_spacing
Definition at line 143 of file MainProcessingParameters.h.
References _azimut_spacing.
inline |
bandwidth
Definition at line 409 of file MainProcessingParameters.h.
References _bandwidth.
inline |
beam_overlap[4]
Definition at line 570 of file MainProcessingParameters.h.
References _beam_overlap.
inline |
beam_param[4]
Definition at line 577 of file MainProcessingParameters.h.
References _beam_param.
inline |
calibration_factors
Definition at line 486 of file MainProcessingParameters.h.
References _calibration_factors.
inline |
chirp_extract_flag
Definition at line 206 of file MainProcessingParameters.h.
References _chirp_extract_flag.
inline |
data_analysis_flag
Definition at line 192 of file MainProcessingParameters.h.
References _data_analysis_flag.
inline |
data_type
Definition at line 171 of file MainProcessingParameters.h.
References _data_type.
inline |
detected_flag
Definition at line 241 of file MainProcessingParameters.h.
References _detected_flag.
inline |
dop_amb_coef
Definition at line 479 of file MainProcessingParameters.h.
References _dop_amb_coef.
inline |
dop_amb_flag
Definition at line 227 of file MainProcessingParameters.h.
References _dop_amb_flag.
inline |
dop_cen_flag
Definition at line 220 of file MainProcessingParameters.h.
References _dop_cen_flag.
inline |
echo_comp
Definition at line 514 of file MainProcessingParameters.h.
References _echo_comp.
inline |
echo_comp_ratio
Definition at line 521 of file MainProcessingParameters.h.
References _echo_comp_ratio.
inline |
errors_counters
Definition at line 325 of file MainProcessingParameters.h.
References _errors_counters.
inline |
filter_az
Definition at line 451 of file MainProcessingParameters.h.
References _filter_az.
inline |
filter_coef_az
Definition at line 458 of file MainProcessingParameters.h.
References _filter_coef_az.
inline |
filter_coef_range
Definition at line 402 of file MainProcessingParameters.h.
References _filter_coef_range.
inline |
filter_range
Definition at line 395 of file MainProcessingParameters.h.
References _filter_range.
inline |
Definition at line 360 of file MainProcessingParameters.h.
References _first_proc_range_samp.
inline |
Definition at line 94 of file MainProcessingParameters.h.
References _first_zero_doppler_time.
inline |
Definition at line 290 of file MainProcessingParameters.h.
References _gm_rng_comp_inv_filter_flag.
inline |
Definition at line 332 of file MainProcessingParameters.h.
References _image_parameters1.
inline |
Definition at line 353 of file MainProcessingParameters.h.
References _image_parameters2.
inline |
init_cal_comp
Definition at line 528 of file MainProcessingParameters.h.
References _init_cal_comp.
inline |
init_cal_ratio
Definition at line 535 of file MainProcessingParameters.h.
References _init_cal_ratio.
inline |
Definition at line 108 of file MainProcessingParameters.h.
References _last_zero_doppler_time.
inline |
line_time_interval
Definition at line 150 of file MainProcessingParameters.h.
References _line_time_interval.
inline |
lines_per_burst[5]
Definition at line 584 of file MainProcessingParameters.h.
References _lines_per_burst.
inline |
look_bw_az
Definition at line 437 of file MainProcessingParameters.h.
References _look_bw_az.
inline |
look_sum_flag
Definition at line 248 of file MainProcessingParameters.h.
References _look_sum_flag.
inline |
noise_comp
Definition at line 556 of file MainProcessingParameters.h.
References _noise_comp.
inline |
noise_comp_ratio
Definition at line 563 of file MainProcessingParameters.h.
References _noise_comp_ratio.
inline |
noise_estimation
Definition at line 493 of file MainProcessingParameters.h.
References _noise_estimation.
inline |
nominal_chirp
Definition at line 416 of file MainProcessingParameters.h.
References _nominal_chirp.
inline |
num_lines_proc
Definition at line 423 of file MainProcessingParameters.h.
References _num_lines_proc.
inline |
num_look_az
Definition at line 430 of file MainProcessingParameters.h.
References _num_look_az.
inline |
num_looks_range
Definition at line 388 of file MainProcessingParameters.h.
References _num_looks_range.
inline |
num_output_lines
Definition at line 157 of file MainProcessingParameters.h.
References _num_output_lines.
inline |
Definition at line 178 of file MainProcessingParameters.h.
References _num_range_lines_per_burst.
inline |
Definition at line 164 of file MainProcessingParameters.h.
References _num_samples_per_line.
inline |
output_statistics
Definition at line 500 of file MainProcessingParameters.h.
References _output_statistics.
inline |
parameter_code
Definition at line 318 of file MainProcessingParameters.h.
References _parameter_code.
inline |
per_cal_comp
Definition at line 542 of file MainProcessingParameters.h.
References _per_cal_comp.
inline |
per_cal_ratio
Definition at line 549 of file MainProcessingParameters.h.
References _per_cal_ratio.
inline |
Definition at line 346 of file MainProcessingParameters.h.
References _prf_values.
inline |
prf_values[5]
Definition at line 339 of file MainProcessingParameters.h.
inline |
radar_freq
Definition at line 381 of file MainProcessingParameters.h.
References _radar_freq.
inline |
range_ref
Definition at line 367 of file MainProcessingParameters.h.
References _range_ref.
inline |
range_samp_rate
Definition at line 374 of file MainProcessingParameters.h.
References _range_samp_rate.
inline |
range_spacing
Definition at line 136 of file MainProcessingParameters.h.
References _range_spacing.
inline |
Definition at line 234 of file MainProcessingParameters.h.
References _range_spread_comp_flag.
inline |
raw_data_analysis
Definition at line 297 of file MainProcessingParameters.h.
References _raw_data_analysis.
inline |
rms_equal_flag
Definition at line 255 of file MainProcessingParameters.h.
References _rms_equal_flag.
inline |
srgr_flag
Definition at line 213 of file MainProcessingParameters.h.
References _srgr_flag.
inline |
start_time_mds1
Definition at line 304 of file MainProcessingParameters.h.
References _start_time_mds1.
inline |
start_time_mds2
Definition at line 311 of file MainProcessingParameters.h.
References _start_time_mds2.
inline |
Definition at line 598 of file MainProcessingParameters.h.
References _state_vector_time_1_day.
inline |
Definition at line 612 of file MainProcessingParameters.h.
References _state_vector_time_1_microsec.
inline |
Definition at line 605 of file MainProcessingParameters.h.
References _state_vector_time_1_sec.
inline |
Definition at line 661 of file MainProcessingParameters.h.
References _state_vector_time_2_day.
inline |
Definition at line 675 of file MainProcessingParameters.h.
References _state_vector_time_2_microsec.
inline |
Definition at line 668 of file MainProcessingParameters.h.
References _state_vector_time_2_sec.
inline |
Definition at line 724 of file MainProcessingParameters.h.
References _state_vector_time_3_day.
inline |
Definition at line 738 of file MainProcessingParameters.h.
References _state_vector_time_3_microsec.
inline |
Definition at line 731 of file MainProcessingParameters.h.
References _state_vector_time_3_sec.
inline |
Definition at line 787 of file MainProcessingParameters.h.
References _state_vector_time_4_day.
inline |
Definition at line 801 of file MainProcessingParameters.h.
References _state_vector_time_4_microsec.
inline |
Definition at line 794 of file MainProcessingParameters.h.
References _state_vector_time_4_sec.
inline |
Definition at line 850 of file MainProcessingParameters.h.
References _state_vector_time_5_day.
inline |
Definition at line 864 of file MainProcessingParameters.h.
References _state_vector_time_5_microsec.
inline |
Definition at line 857 of file MainProcessingParameters.h.
References _state_vector_time_5_sec.
inline |
swath_num
Definition at line 129 of file MainProcessingParameters.h.
References _swath_num.
inline |
time_diff
Definition at line 122 of file MainProcessingParameters.h.
References _time_diff.
inline |
Definition at line 185 of file MainProcessingParameters.h.
References _time_diff_zero_doppler.
inline |
time_first_SS1_echo
Definition at line 591 of file MainProcessingParameters.h.
References _time_first_SS1_echo.
inline |
to_bw_az
Definition at line 444 of file MainProcessingParameters.h.
References _to_bw_az.
inline |
vga_com_cal_flag
Definition at line 276 of file MainProcessingParameters.h.
References _vga_com_cal_flag.
inline |
vga_com_echo_flag
Definition at line 269 of file MainProcessingParameters.h.
References _vga_com_echo_flag.
inline |
Definition at line 283 of file MainProcessingParameters.h.
References _vga_com_nom_time_flag.
inline |
work_order_id
Definition at line 115 of file MainProcessingParameters.h.
References _work_order_id.
inline |
x_pos_1
Definition at line 619 of file MainProcessingParameters.h.
References _x_pos_1.
inline |
x_pos_2
Definition at line 682 of file MainProcessingParameters.h.
References _x_pos_2.
inline |
x_pos_3
Definition at line 745 of file MainProcessingParameters.h.
References _x_pos_3.
inline |
x_pos_4
Definition at line 808 of file MainProcessingParameters.h.
References _x_pos_4.
inline |
x_pos_5
Definition at line 871 of file MainProcessingParameters.h.
References _x_pos_5.
inline |
x_vel_1
Definition at line 640 of file MainProcessingParameters.h.
References _x_vel_1.
inline |
x_vel_2
Definition at line 703 of file MainProcessingParameters.h.
References _x_vel_2.
inline |
x_vel_3
Definition at line 766 of file MainProcessingParameters.h.
References _x_vel_3.
inline |
x_vel_4
Definition at line 829 of file MainProcessingParameters.h.
References _x_vel_4.
inline |
x_vel_5
Definition at line 892 of file MainProcessingParameters.h.
References _x_vel_5.
inline |
y_pos_1
Definition at line 626 of file MainProcessingParameters.h.
References _y_pos_1.
inline |
y_pos_2
Definition at line 689 of file MainProcessingParameters.h.
References _y_pos_2.
inline |
y_pos_3
Definition at line 752 of file MainProcessingParameters.h.
References _y_pos_3.
inline |
y_pos_4
Definition at line 815 of file MainProcessingParameters.h.
References _y_pos_4.
inline |
y_pos_5
Definition at line 878 of file MainProcessingParameters.h.
References _y_pos_5.
inline |
y_vel_1
Definition at line 647 of file MainProcessingParameters.h.
References _y_vel_1.
inline |
y_vel_2
Definition at line 710 of file MainProcessingParameters.h.
References _y_vel_2.
inline |
y_vel_3
Definition at line 773 of file MainProcessingParameters.h.
References _y_vel_3.
inline |
y_vel_4
Definition at line 836 of file MainProcessingParameters.h.
References _y_vel_4.
inline |
y_vel_5
Definition at line 899 of file MainProcessingParameters.h.
References _y_vel_5.
inline |
z_pos_1
Definition at line 633 of file MainProcessingParameters.h.
References _z_pos_1.
inline |
z_pos_2
Definition at line 696 of file MainProcessingParameters.h.
References _z_pos_2.
inline |
z_pos_3
Definition at line 759 of file MainProcessingParameters.h.
References _z_pos_3.
inline |
z_pos_4
Definition at line 822 of file MainProcessingParameters.h.
References _z_pos_4.
inline |
z_pos_5
Definition at line 885 of file MainProcessingParameters.h.
References _z_pos_5.
inline |
z_vel_1
Definition at line 654 of file MainProcessingParameters.h.
References _z_vel_1.
inline |
z_vel_2
Definition at line 717 of file MainProcessingParameters.h.
References _z_vel_2.
inline |
z_vel_3
Definition at line 780 of file MainProcessingParameters.h.
References _z_vel_3.
inline |
z_vel_4
Definition at line 843 of file MainProcessingParameters.h.
References _z_vel_4.
inline |
z_vel_5
Definition at line 906 of file MainProcessingParameters.h.
References _z_vel_5.
inlinevirtual |
Definition at line 61 of file MainProcessingParameters.h.
| MainProcessingParameters & ossimplugins::MainProcessingParameters::operator= | ( | const MainProcessingParameters & | rhs | ) |
Copy operator.
Definition at line 846 of file MainProcessingParameters.cpp.
References _ant_elev_coor_flag, _ant_scal_flag, _attach_flag, _avg_scene_height_ellpsoid, _ax_fm_origin, _az_fm_rate, _azimut_spacing, _bandwidth, _beam_overlap, _beam_param, _calibration_factors, _chirp_extract_flag, _data_analysis_flag, _data_type, _detected_flag, _dop_amb_coef, _dop_amb_flag, _dop_cen_flag, _echo_comp, _echo_comp_ratio, _errors_counters, _filter_az, _filter_coef_az, _filter_coef_range, _filter_range, _first_proc_range_samp, _first_zero_doppler_time, _gm_rng_comp_inv_filter_flag, _image_parameters1, _image_parameters2, _init_cal_comp, _init_cal_ratio, _last_zero_doppler_time, _line_time_interval, _lines_per_burst, _look_bw_az, _look_sum_flag, _noise_comp, _noise_comp_ratio, _noise_estimation, _nominal_chirp, _num_lines_proc, _num_look_az, _num_looks_range, _num_output_lines, _num_range_lines_per_burst, _num_samples_per_line, _output_statistics, _parameter_code, _per_cal_comp, _per_cal_ratio, _prf_values, _radar_freq, _range_ref, _range_samp_rate, _range_spacing, _range_spread_comp_flag, _raw_data_analysis, _rms_equal_flag, _srgr_flag, _start_time_mds1, _start_time_mds2, _state_vector_time_1_day, _state_vector_time_1_microsec, _state_vector_time_1_sec, _state_vector_time_2_day, _state_vector_time_2_microsec, _state_vector_time_2_sec, _state_vector_time_3_day, _state_vector_time_3_microsec, _state_vector_time_3_sec, _state_vector_time_4_day, _state_vector_time_4_microsec, _state_vector_time_4_sec, _state_vector_time_5_day, _state_vector_time_5_microsec, _state_vector_time_5_sec, _swath_num, _time_diff, _time_diff_zero_doppler, _time_first_SS1_echo, _to_bw_az, _vga_com_cal_flag, _vga_com_echo_flag, _vga_com_nom_time_flag, _work_order_id, _x_pos_1, _x_pos_2, _x_pos_3, _x_pos_4, _x_pos_5, _x_vel_1, _x_vel_2, _x_vel_3, _x_vel_4, _x_vel_5, _y_pos_1, _y_pos_2, _y_pos_3, _y_pos_4, _y_pos_5, _y_vel_1, _y_vel_2, _y_vel_3, _y_vel_4, _y_vel_5, _z_pos_1, _z_pos_2, _z_pos_3, _z_pos_4, _z_pos_5, _z_vel_1, _z_vel_2, _z_vel_3, _z_vel_4, and _z_vel_5.
inlinevirtual |
Definition at line 77 of file MainProcessingParameters.h.
inlinevirtual |
Definition at line 85 of file MainProcessingParameters.h.
friend |
Definition at line 25 of file MainProcessingParameters.cpp.
friend |
Definition at line 270 of file MainProcessingParameters.cpp.
| bool ossimplugins::MainProcessingParameters::_ant_elev_coor_flag |
ant_elev_coor_flag
Definition at line 974 of file MainProcessingParameters.h.
Referenced by get_ant_elev_coor_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| bool ossimplugins::MainProcessingParameters::_ant_scal_flag |
ant_scal_flag
Definition at line 1010 of file MainProcessingParameters.h.
Referenced by get_ant_scal_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| bool ossimplugins::MainProcessingParameters::_attach_flag |
attach_flag
Definition at line 918 of file MainProcessingParameters.h.
Referenced by get_attach_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::MainProcessingParameters::_avg_scene_height_ellpsoid |
Definition at line 1146 of file MainProcessingParameters.h.
Referenced by get_avg_scene_height_ellpsoid(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::MainProcessingParameters::_ax_fm_origin |
ax_fm_origin
Definition at line 1126 of file MainProcessingParameters.h.
Referenced by get_ax_fm_origin(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::MainProcessingParameters::_az_fm_rate[3] |
az_fm_rate[3]
Definition at line 1122 of file MainProcessingParameters.h.
Referenced by get_az_fm_rate(), MainProcessingParameters(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::MainProcessingParameters::_azimut_spacing |
azimut_spacing
Definition at line 942 of file MainProcessingParameters.h.
Referenced by get_azimut_spacing(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_bandwidth |
bandwidth
Definition at line 1090 of file MainProcessingParameters.h.
Referenced by get_bandwidth(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::MainProcessingParameters::_beam_overlap[4] |
beam_overlap[4]
Definition at line 1182 of file MainProcessingParameters.h.
Referenced by get_beam_overlap(), MainProcessingParameters(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::MainProcessingParameters::_beam_param[4] |
beam_overlap[4]
Definition at line 1186 of file MainProcessingParameters.h.
Referenced by get_beam_param(), MainProcessingParameters(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_calibration_factors |
calibration_factors
Definition at line 1134 of file MainProcessingParameters.h.
Referenced by get_calibration_factors(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| bool ossimplugins::MainProcessingParameters::_chirp_extract_flag |
chirp_extract_flag
Definition at line 978 of file MainProcessingParameters.h.
Referenced by get_chirp_extract_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| bool ossimplugins::MainProcessingParameters::_data_analysis_flag |
data_analysis_flag
Definition at line 970 of file MainProcessingParameters.h.
Referenced by get_data_analysis_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_data_type |
data_type
Definition at line 958 of file MainProcessingParameters.h.
Referenced by get_data_type(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| bool ossimplugins::MainProcessingParameters::_detected_flag |
detected_flag
Definition at line 998 of file MainProcessingParameters.h.
Referenced by get_detected_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::MainProcessingParameters::_dop_amb_coef |
dop_amb_coef
Definition at line 1130 of file MainProcessingParameters.h.
Referenced by get_dop_amb_coef(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| bool ossimplugins::MainProcessingParameters::_dop_amb_flag |
dop_amb_flag
Definition at line 990 of file MainProcessingParameters.h.
Referenced by get_dop_amb_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| bool ossimplugins::MainProcessingParameters::_dop_cen_flag |
dop_cen_flag
Definition at line 986 of file MainProcessingParameters.h.
Referenced by get_dop_cen_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_echo_comp |
echo_comp
Definition at line 1150 of file MainProcessingParameters.h.
Referenced by get_echo_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_echo_comp_ratio |
echo_comp_ratio
Definition at line 1154 of file MainProcessingParameters.h.
Referenced by get_echo_comp_ratio(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_errors_counters |
errors_counters
Definition at line 1046 of file MainProcessingParameters.h.
Referenced by get_errors_counters(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_filter_az |
filter_az
Definition at line 1114 of file MainProcessingParameters.h.
Referenced by get_filter_az(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::MainProcessingParameters::_filter_coef_az |
filter_coef_az
Definition at line 1118 of file MainProcessingParameters.h.
Referenced by get_filter_coef_az(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::MainProcessingParameters::_filter_coef_range |
filter_coef_range
Definition at line 1086 of file MainProcessingParameters.h.
Referenced by get_filter_coef_range(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_filter_range |
filter_range
Definition at line 1082 of file MainProcessingParameters.h.
Referenced by get_filter_range(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::MainProcessingParameters::_first_proc_range_samp |
Definition at line 1062 of file MainProcessingParameters.h.
Referenced by get_first_proc_range_samp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_first_zero_doppler_time |
Definition at line 909 of file MainProcessingParameters.h.
Referenced by get_first_zero_doppler_time(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| bool ossimplugins::MainProcessingParameters::_gm_rng_comp_inv_filter_flag |
Definition at line 1026 of file MainProcessingParameters.h.
Referenced by get_gm_rng_comp_inv_filter_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_image_parameters1 |
Definition at line 1050 of file MainProcessingParameters.h.
Referenced by get_image_parameters1(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_image_parameters2 |
Definition at line 1058 of file MainProcessingParameters.h.
Referenced by get_image_parameters2(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_init_cal_comp |
init_cal_comp
Definition at line 1158 of file MainProcessingParameters.h.
Referenced by get_init_cal_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_init_cal_ratio |
init_cal_ratio
Definition at line 1162 of file MainProcessingParameters.h.
Referenced by get_init_cal_ratio(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_last_zero_doppler_time |
Definition at line 922 of file MainProcessingParameters.h.
Referenced by get_last_zero_doppler_time(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::MainProcessingParameters::_line_time_interval |
line_time_interval
Definition at line 946 of file MainProcessingParameters.h.
Referenced by get_line_time_interval(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::MainProcessingParameters::_lines_per_burst[5] |
lines_per_burst[5]
Definition at line 1190 of file MainProcessingParameters.h.
Referenced by get_lines_per_burst(), MainProcessingParameters(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::MainProcessingParameters::_look_bw_az |
look_bw_az
Definition at line 1106 of file MainProcessingParameters.h.
Referenced by get_look_bw_az(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| bool ossimplugins::MainProcessingParameters::_look_sum_flag |
look_sum_flag
Definition at line 1002 of file MainProcessingParameters.h.
Referenced by get_look_sum_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_noise_comp |
noise_comp
Definition at line 1174 of file MainProcessingParameters.h.
Referenced by get_noise_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_noise_comp_ratio |
noise_comp_ratio
Definition at line 1178 of file MainProcessingParameters.h.
Referenced by get_noise_comp_ratio(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_noise_estimation |
noise_estimation
Definition at line 1138 of file MainProcessingParameters.h.
Referenced by get_noise_estimation(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_nominal_chirp |
nominal_chirp
Definition at line 1094 of file MainProcessingParameters.h.
Referenced by get_nominal_chirp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::MainProcessingParameters::_num_lines_proc |
num_lines_proc
Definition at line 1098 of file MainProcessingParameters.h.
Referenced by get_num_lines_proc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned short ossimplugins::MainProcessingParameters::_num_look_az |
num_look_az
Definition at line 1102 of file MainProcessingParameters.h.
Referenced by get_num_look_az(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned short ossimplugins::MainProcessingParameters::_num_looks_range |
num_looks_range
Definition at line 1078 of file MainProcessingParameters.h.
Referenced by get_num_looks_range(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::MainProcessingParameters::_num_output_lines |
num_output_lines
Definition at line 950 of file MainProcessingParameters.h.
Referenced by get_num_output_lines(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::MainProcessingParameters::_num_range_lines_per_burst |
Definition at line 962 of file MainProcessingParameters.h.
Referenced by get_num_range_lines_per_burst(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::MainProcessingParameters::_num_samples_per_line |
Definition at line 954 of file MainProcessingParameters.h.
Referenced by get_num_samples_per_line(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_output_statistics |
output_statistics
Definition at line 1142 of file MainProcessingParameters.h.
Referenced by get_output_statistics(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_parameter_code |
parameter_code
Definition at line 1042 of file MainProcessingParameters.h.
Referenced by get_parameter_code(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_per_cal_comp |
per_cal_comp
Definition at line 1166 of file MainProcessingParameters.h.
Referenced by get_per_cal_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_per_cal_ratio |
per_cal_ratio
Definition at line 1170 of file MainProcessingParameters.h.
Referenced by get_per_cal_ratio(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::MainProcessingParameters::_prf_values[5] |
PRF.
Definition at line 1054 of file MainProcessingParameters.h.
Referenced by get_prf(), get_prf_values(), MainProcessingParameters(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::MainProcessingParameters::_radar_freq |
radar_freq
Definition at line 1074 of file MainProcessingParameters.h.
Referenced by get_radar_freq(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::MainProcessingParameters::_range_ref |
range_ref
Definition at line 1066 of file MainProcessingParameters.h.
Referenced by get_range_ref(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::MainProcessingParameters::_range_samp_rate |
range_samp_rate
Definition at line 1070 of file MainProcessingParameters.h.
Referenced by get_range_samp_rate(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::MainProcessingParameters::_range_spacing |
range_spacing
Definition at line 938 of file MainProcessingParameters.h.
Referenced by get_range_spacing(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| bool ossimplugins::MainProcessingParameters::_range_spread_comp_flag |
Definition at line 994 of file MainProcessingParameters.h.
Referenced by get_range_spread_comp_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_raw_data_analysis |
raw_data_analysis
Definition at line 1030 of file MainProcessingParameters.h.
Referenced by get_raw_data_analysis(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| bool ossimplugins::MainProcessingParameters::_rms_equal_flag |
rms_equal_flag
Definition at line 1006 of file MainProcessingParameters.h.
Referenced by get_rms_equal_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| bool ossimplugins::MainProcessingParameters::_srgr_flag |
srgr_flag
Definition at line 982 of file MainProcessingParameters.h.
Referenced by get_srgr_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_start_time_mds1 |
start_time_mds1
Definition at line 1034 of file MainProcessingParameters.h.
Referenced by get_start_time_mds1(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_start_time_mds2 |
start_time_mds2
Definition at line 1038 of file MainProcessingParameters.h.
Referenced by get_start_time_mds2(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_state_vector_time_1_day |
Definition at line 1198 of file MainProcessingParameters.h.
Referenced by get_state_vector_time_1_day(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::MainProcessingParameters::_state_vector_time_1_microsec |
Definition at line 1206 of file MainProcessingParameters.h.
Referenced by get_state_vector_time_1_microsec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::MainProcessingParameters::_state_vector_time_1_sec |
Definition at line 1202 of file MainProcessingParameters.h.
Referenced by get_state_vector_time_1_sec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_state_vector_time_2_day |
Definition at line 1234 of file MainProcessingParameters.h.
Referenced by get_state_vector_time_2_day(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::MainProcessingParameters::_state_vector_time_2_microsec |
Definition at line 1242 of file MainProcessingParameters.h.
Referenced by get_state_vector_time_2_microsec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::MainProcessingParameters::_state_vector_time_2_sec |
Definition at line 1238 of file MainProcessingParameters.h.
Referenced by get_state_vector_time_2_sec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_state_vector_time_3_day |
Definition at line 1270 of file MainProcessingParameters.h.
Referenced by get_state_vector_time_3_day(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::MainProcessingParameters::_state_vector_time_3_microsec |
Definition at line 1278 of file MainProcessingParameters.h.
Referenced by get_state_vector_time_3_microsec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::MainProcessingParameters::_state_vector_time_3_sec |
Definition at line 1274 of file MainProcessingParameters.h.
Referenced by get_state_vector_time_3_sec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_state_vector_time_4_day |
Definition at line 1306 of file MainProcessingParameters.h.
Referenced by get_state_vector_time_4_day(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::MainProcessingParameters::_state_vector_time_4_microsec |
Definition at line 1314 of file MainProcessingParameters.h.
Referenced by get_state_vector_time_4_microsec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::MainProcessingParameters::_state_vector_time_4_sec |
Definition at line 1310 of file MainProcessingParameters.h.
Referenced by get_state_vector_time_4_sec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_state_vector_time_5_day |
Definition at line 1342 of file MainProcessingParameters.h.
Referenced by get_state_vector_time_5_day(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::MainProcessingParameters::_state_vector_time_5_microsec |
Definition at line 1350 of file MainProcessingParameters.h.
Referenced by get_state_vector_time_5_microsec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::MainProcessingParameters::_state_vector_time_5_sec |
Definition at line 1346 of file MainProcessingParameters.h.
Referenced by get_state_vector_time_5_sec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_swath_num |
swath_num
Definition at line 934 of file MainProcessingParameters.h.
Referenced by get_swath_num(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::MainProcessingParameters::_time_diff |
time_diff
Definition at line 930 of file MainProcessingParameters.h.
Referenced by get_time_diff(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::MainProcessingParameters::_time_diff_zero_doppler |
Definition at line 966 of file MainProcessingParameters.h.
Referenced by get_time_diff_zero_doppler(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_time_first_SS1_echo |
time_first_SS1_echo
Definition at line 1194 of file MainProcessingParameters.h.
Referenced by get_time_first_SS1_echo(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::MainProcessingParameters::_to_bw_az |
to_bw_az
Definition at line 1110 of file MainProcessingParameters.h.
Referenced by get_to_bw_az(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| bool ossimplugins::MainProcessingParameters::_vga_com_cal_flag |
vga_com_cal_flag
Definition at line 1018 of file MainProcessingParameters.h.
Referenced by get_vga_com_cal_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| bool ossimplugins::MainProcessingParameters::_vga_com_echo_flag |
vga_com_echo_flag
Definition at line 1014 of file MainProcessingParameters.h.
Referenced by get_vga_com_echo_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| bool ossimplugins::MainProcessingParameters::_vga_com_nom_time_flag |
Definition at line 1022 of file MainProcessingParameters.h.
Referenced by get_vga_com_nom_time_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::MainProcessingParameters::_work_order_id |
work_order_id
Definition at line 926 of file MainProcessingParameters.h.
Referenced by get_work_order_id(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_x_pos_1 |
x_pos_1
Definition at line 1210 of file MainProcessingParameters.h.
Referenced by get_x_pos_1(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_x_pos_2 |
x_pos_2
Definition at line 1246 of file MainProcessingParameters.h.
Referenced by get_x_pos_2(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_x_pos_3 |
x_pos_3
Definition at line 1282 of file MainProcessingParameters.h.
Referenced by get_x_pos_3(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_x_pos_4 |
x_pos_4
Definition at line 1318 of file MainProcessingParameters.h.
Referenced by get_x_pos_4(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_x_pos_5 |
x_pos_5
Definition at line 1354 of file MainProcessingParameters.h.
Referenced by get_x_pos_5(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_x_vel_1 |
x_vel_1
Definition at line 1222 of file MainProcessingParameters.h.
Referenced by get_x_vel_1(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_x_vel_2 |
x_vel_2
Definition at line 1258 of file MainProcessingParameters.h.
Referenced by get_x_vel_2(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_x_vel_3 |
x_vel_3
Definition at line 1294 of file MainProcessingParameters.h.
Referenced by get_x_vel_3(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_x_vel_4 |
x_vel_4
Definition at line 1330 of file MainProcessingParameters.h.
Referenced by get_x_vel_4(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_x_vel_5 |
x_vel_5
Definition at line 1366 of file MainProcessingParameters.h.
Referenced by get_x_vel_5(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_y_pos_1 |
y_pos_1
Definition at line 1214 of file MainProcessingParameters.h.
Referenced by get_y_pos_1(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_y_pos_2 |
y_pos_2
Definition at line 1250 of file MainProcessingParameters.h.
Referenced by get_y_pos_2(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_y_pos_3 |
y_pos_3
Definition at line 1286 of file MainProcessingParameters.h.
Referenced by get_y_pos_3(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_y_pos_4 |
y_pos_4
Definition at line 1322 of file MainProcessingParameters.h.
Referenced by get_y_pos_4(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_y_pos_5 |
y_pos_5
Definition at line 1358 of file MainProcessingParameters.h.
Referenced by get_y_pos_5(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_y_vel_1 |
y_vel_1
Definition at line 1226 of file MainProcessingParameters.h.
Referenced by get_y_vel_1(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_y_vel_2 |
y_vel_2
Definition at line 1262 of file MainProcessingParameters.h.
Referenced by get_y_vel_2(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_y_vel_3 |
y_vel_3
Definition at line 1298 of file MainProcessingParameters.h.
Referenced by get_y_vel_3(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_y_vel_4 |
y_vel_4
Definition at line 1334 of file MainProcessingParameters.h.
Referenced by get_y_vel_4(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_y_vel_5 |
y_vel_5
Definition at line 1370 of file MainProcessingParameters.h.
Referenced by get_y_vel_5(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_z_pos_1 |
z_pos_1
Definition at line 1218 of file MainProcessingParameters.h.
Referenced by get_z_pos_1(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_z_pos_2 |
z_pos_2
Definition at line 1254 of file MainProcessingParameters.h.
Referenced by get_z_pos_2(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_z_pos_3 |
z_pos_3
Definition at line 1290 of file MainProcessingParameters.h.
Referenced by get_z_pos_3(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_z_pos_4 |
z_pos_4
Definition at line 1326 of file MainProcessingParameters.h.
Referenced by get_z_pos_4(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_z_pos_5 |
z_pos_5
Definition at line 1362 of file MainProcessingParameters.h.
Referenced by get_z_pos_5(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_z_vel_1 |
z_vel_1
Definition at line 1230 of file MainProcessingParameters.h.
Referenced by get_z_vel_1(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_z_vel_2 |
z_vel_2
Definition at line 1266 of file MainProcessingParameters.h.
Referenced by get_z_vel_2(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_z_vel_3 |
z_vel_3
Definition at line 1302 of file MainProcessingParameters.h.
Referenced by get_z_vel_3(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_z_vel_4 |
z_vel_4
Definition at line 1338 of file MainProcessingParameters.h.
Referenced by get_z_vel_4(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::MainProcessingParameters::_z_vel_5 |
z_vel_5
Definition at line 1374 of file MainProcessingParameters.h.
Referenced by get_z_vel_5(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
