This class is able to read a Detailed processing parameters record. More...
#include <ProcessingParameters.h>
| ProcessingParameters () | |
| Constructor. More... | |
| ~ProcessingParameters () | |
| Destructor. More... | |
| ProcessingParameters (const ProcessingParameters &rhs) | |
| Copy constructor. More... | |
| ProcessingParameters & | operator= (const ProcessingParameters &rhs) |
| Copy operator. More... | |
| RadarSatRecord * | Instanciate () |
| This function is able to create a new instance of the class. More... | |
| RadarSatRecord * | Clone () |
| This function is able to create a new instance of the class initialised with the data of the calling instance. More... | |
| void | Read (std::istream &is) |
| Reads the class data from a stream. More... | |
| void | Write (std::ostream &os) |
| Writes the class to a stream. More... | |
| int | get_rec_seq () |
| Record sequence number. More... | |
| std::string | get_inp_media () |
Input media More... | |
| int | get_n_tape_id () |
Number of tape input ids More... | |
| std::string * | get_tape_id () |
Tape identifiers More... | |
| std::string | get_exp_ing_start () |
Expected ingest start time More... | |
| std::string | get_exp_ing_stop () |
Expected ingest stop time More... | |
| std::string | get_act_ing_start () |
Actual ingest start time More... | |
| std::string | get_act_ing_stop () |
Actual ingest stop time More... | |
| std::string | get_proc_start () |
Processing start time More... | |
| std::string | get_proc_stop () |
Processing stop time More... | |
| double * | get_mn_sig_lev () |
Mean signal levels across range More... | |
| int | get_scr_data_ind () |
Source data quality indicator More... | |
| int | get_miss_ln () |
Number of missing lines More... | |
| int | get_rej_ln () |
Number of rejected lines More... | |
| int | get_large_gap () |
Number of time inconsistencies (large gaps) More... | |
| double | get_bit_err_rate () |
Measured bit error rate More... | |
| double | get_fm_crc_err () |
Percent of frames with CRC errors More... | |
| int | get_date_incons () |
Number of date inconsistencies More... | |
| int | get_prf_changes () |
Number of unexpected PRF changes More... | |
| int | get_delay_changes () |
Number of delay changes More... | |
| int | get_skipd_frams () |
Number of skipped frames More... | |
| int | get_rej_bf_start () |
Range lines rejected before start time More... | |
| int | get_rej_few_fram () |
Range lines rejected due to too few frames More... | |
| int | get_rej_many_fram () |
Range lines rejected due to too many frames More... | |
| int | get_rej_mchn_err () |
Frames rejected due to master channel error More... | |
| int | get_rej_vchn_err () |
Frames rejected due to virtual channel error More... | |
| int | get_rej_rec_type () |
Frames rejected due to incorrect recording type More... | |
| std::string | get_sens_config () |
Sensor configuration More... | |
| std::string | get_sens_orient () |
Sensor orientation More... | |
| std::string | get_sych_marker () |
Frame synch marker More... | |
| std::string | get_rng_ref_src () |
Range reference function source More... | |
| double * | get_rng_amp_coef () |
Range reference amplitude coefficients More... | |
| double * | get_rng_phas_coef () |
Range reference phase coefficients More... | |
| double * | get_err_amp_coef () |
Error function amplitude coefficients More... | |
| double * | get_err_phas_coef () |
Error function phase coefficients More... | |
| int | get_pulse_bandw () |
Pulse bandwidth code More... | |
| std::string | get_adc_samp_rate () |
ADC sampling rate More... | |
| double | get_rep_agc_attn () |
Replica AGC attenuation More... | |
| double | get_gn_corctn_fctr () |
Gain correction factor (dB) More... | |
| double | get_rep_energy_gn () |
Replica energy gain correction More... | |
| std::string | get_orb_data_src () |
Orbit data source More... | |
| int | get_pulse_cnt_1 () |
Pulse count 1 More... | |
| int | get_pulse_cnt_2 () |
Pulse count 2 More... | |
| std::string | get_beam_edge_rqd () |
Beam edge detection requested More... | |
| double | get_beam_edge_conf () |
Beam edge confidence measure More... | |
| int | get_pix_overlap () |
Number of pixels in beam overlap More... | |
| int | get_n_beams () |
Number of beams More... | |
| BeamInformationRecord * | get_beam_info () |
Beam info More... | |
| int | get_n_pix_updates () |
Number of pixel count updates More... | |
| BeamPixelCountRecord * | get_pix_count () |
| Beam pixel counts. More... | |
| double | get_pwin_start () |
Processing window start time (sec) More... | |
| double | get_pwin_end () |
Processing window end time (sec) More... | |
| std::string | get_recd_type () |
Recording type More... | |
| double | get_temp_set_inc () |
Time increment between temperature settings (sec) More... | |
| int | get_n_temp_set () |
Number of temperature settings More... | |
| TemperatureSettingsRecord * | get_temp () |
| Temperature settings. More... | |
| int | get_n_image_pix () |
Number of image pixels More... | |
| double | get_prc_zero_pix () |
Percent zero pixels More... | |
| double | get_prc_satur_pix () |
Percent saturated pixels More... | |
| double | get_img_hist_mean () |
Image histogram mean intensity More... | |
| double * | get_img_cumu_dist () |
Image cumulative distribution More... | |
| double | get_pre_img_gn () |
Pre-image calibration gain factor More... | |
| double | get_post_img_gn () |
Post-image calibration gain factor More... | |
| double | get_dopcen_inc () |
Time increment between Dopcen estimates (sec) More... | |
| int | get_n_dopcen () |
Number of Doppler centroid estimates More... | |
| DopplerCentroidEstimateRecord * | get_dopcen_est () |
| Doppler centroid estimates. More... | |
| int | get_dop_amb_err () |
Doppler ambiguity error More... | |
| double | get_dopamb_conf () |
Doppler ambiguity confidence measure More... | |
| double * | get_eph_orb_data () |
Ephemeris orbit data More... | |
| std::string | get_appl_type () |
Application type More... | |
| double * | get_slow_time_coef () |
Slow time coefficients More... | |
| int | get_n_srgr () |
Number of SRGR coefficient sets More... | |
| SRGRCoefficientSetRecord * | get_srgr_coefset () |
| SRGR coefficient sets. More... | |
| double | get_pixel_spacing () |
SGF product pixel spacing More... | |
| std::string | get_gics_reqd () |
GICS product required More... | |
| std::string | get_wo_number () |
Work order identifier More... | |
| std::string | get_wo_date () |
Work order entry date More... | |
| std::string | get_satellite_id () |
Satellite identifier More... | |
| std::string | get_user_id () |
User id More... | |
| std::string | get_complete_msg () |
Completion message required flag More... | |
| std::string | get_scene_id () |
SGF product scene identifier More... | |
| std::string | get_density_in () |
Density of SGF product media More... | |
| std::string | get_media_id () |
SGF product identifier More... | |
| double | get_angle_first () |
Incidence angle of first pixel in SGF product line More... | |
| double | get_angle_last () |
Incidence angle of last pixel in SGF product line More... | |
| std::string | get_prod_type () |
GICS output product type More... | |
| std::string | get_map_system () |
Map system identifier More... | |
| double | get_centre_lat () |
GICS output product scene centre latitude More... | |
| double | get_centre_long () |
GICS output product scene centre longitude More... | |
| double | get_span_x () |
GICS output product size - map eastings (km) More... | |
| double | get_span_y () |
GICS output product size - map northings (km) More... | |
| std::string | get_apply_dtm () |
DTM correction to be applied flag More... | |
| std::string | get_density_out () |
GICS output product density More... | |
| std::string | get_state_time () |
Time of the first state vector More... | |
| int | get_num_state_vectors () |
Number of state vectors More... | |
| double | get_state_time_inc () |
Time increment between state vectors More... | |
Public Member Functions inherited from ossimplugins::RadarSatRecord | |
| RadarSatRecord (std::string mnemonic) | |
| virtual | ~RadarSatRecord () |
| RadarSatRecord (const RadarSatRecord &rhs) | |
| std::string | get_mnemonic () |
Protected Attributes | |
| int | _rec_seq |
| std::string | _inp_media |
| int | _n_tape_id |
| std::string | _tape_id [10] |
| std::string | _exp_ing_start |
| std::string | _exp_ing_stop |
| std::string | _act_ing_start |
| std::string | _act_ing_stop |
| std::string | _proc_start |
| std::string | _proc_stop |
| double | _mn_sig_lev [10] |
| int | _scr_data_ind |
| int | _miss_ln |
| int | _rej_ln |
| int | _large_gap |
| double | _bit_err_rate |
| double | _fm_crc_err |
| int | _date_incons |
| int | _prf_changes |
| int | _delay_changes |
| int | _skipd_frams |
| int | _rej_bf_start |
| int | _rej_few_fram |
| int | _rej_many_fram |
| int | _rej_mchn_err |
| int | _rej_vchn_err |
| int | _rej_rec_type |
| std::string | _sens_config |
| std::string | _sens_orient |
| std::string | _sych_marker |
| std::string | _rng_ref_src |
| double | _rng_amp_coef [4] |
| double | _rng_phas_coef [4] |
| double | _err_amp_coef [16] |
| double | _err_phas_coef [4] |
| int | _pulse_bandw |
| std::string | _adc_samp_rate |
| double | _rep_agc_attn |
| double | _gn_corctn_fctr |
| double | _rep_energy_gn |
| std::string | _orb_data_src |
| int | _pulse_cnt_1 |
| int | _pulse_cnt_2 |
| std::string | _beam_edge_rqd |
| double | _beam_edge_conf |
| int | _pix_overlap |
| int | _n_beams |
| BeamInformationRecord | _beam_info [4] |
| int | _n_pix_updates |
| BeamPixelCountRecord | _pix_count [20] |
| double | _pwin_start |
| double | _pwin_end |
| std::string | _recd_type |
| double | _temp_set_inc |
| int | _n_temp_set |
| TemperatureSettingsRecord | _temp [20] |
| int | _n_image_pix |
| double | _prc_zero_pix |
| double | _prc_satur_pix |
| double | _img_hist_mean |
| double | _img_cumu_dist [3] |
| double | _pre_img_gn |
| double | _post_img_gn |
| double | _dopcen_inc |
| int | _n_dopcen |
| DopplerCentroidEstimateRecord | _dopcen_est [20] |
| int | _dop_amb_err |
| double | _dopamb_conf |
| double | _eph_orb_data [7] |
| std::string | _appl_type |
| double | _slow_time_coef [5] |
| int | _n_srgr |
| SRGRCoefficientSetRecord | _srgr_coefset [20] |
| double | _pixel_spacing |
| std::string | _gics_reqd |
| std::string | _wo_number |
| std::string | _wo_date |
| std::string | _satellite_id |
| std::string | _user_id |
User id More... | |
| std::string | _complete_msg |
| std::string | _scene_id |
| std::string | _density_in |
| std::string | _media_id |
| double | _angle_first |
| double | _angle_last |
| std::string | _prod_type |
| std::string | _map_system |
| double | _centre_lat |
| double | _centre_long |
| double | _span_x |
| double | _span_y |
| std::string | _apply_dtm |
| std::string | _density_out |
| std::string | _state_time |
| int | _num_state_vectors |
| double | _state_time_inc |
Protected Attributes inherited from ossimplugins::RadarSatRecord | |
| std::string | _mnemonic |
Friends | |
| std::ostream & | operator<< (std::ostream &os, const ProcessingParameters &data) |
| This function writes the ProcessingParameters in a stream. More... | |
| std::istream & | operator>> (std::istream &is, ProcessingParameters &data) |
| This function reads a ProcessingParameters from a stream. More... | |
Definition at line 31 of file ProcessingParameters.h.
| ossimplugins::ProcessingParameters::ProcessingParameters | ( | ) |
Constructor.
Definition at line 16 of file ProcessingParameters.cpp.
Referenced by Clone(), and Instanciate().
| ossimplugins::ProcessingParameters::~ProcessingParameters | ( | ) |
| ossimplugins::ProcessingParameters::ProcessingParameters | ( | const ProcessingParameters & | rhs | ) |
Copy constructor.
Definition at line 695 of file ProcessingParameters.cpp.
inlinevirtual |
Implements ossimplugins::RadarSatRecord.
Definition at line 74 of file ProcessingParameters.h.
References ProcessingParameters().
inline |
Definition at line 141 of file ProcessingParameters.h.
References _act_ing_start.
inline |
Definition at line 148 of file ProcessingParameters.h.
References _act_ing_stop.
inline |
ADC sampling rate
Definition at line 351 of file ProcessingParameters.h.
References _adc_samp_rate.
inline |
Definition at line 681 of file ProcessingParameters.h.
References _angle_first.
inline |
Definition at line 688 of file ProcessingParameters.h.
References _angle_last.
inline |
Application type
Definition at line 582 of file ProcessingParameters.h.
References _appl_type.
inline |
Definition at line 737 of file ProcessingParameters.h.
References _apply_dtm.
inline |
Definition at line 407 of file ProcessingParameters.h.
References _beam_edge_conf.
inline |
Definition at line 400 of file ProcessingParameters.h.
References _beam_edge_rqd.
inline |
Beam info
Definition at line 428 of file ProcessingParameters.h.
References _beam_info.
inline |
Definition at line 204 of file ProcessingParameters.h.
References _bit_err_rate.
inline |
Definition at line 709 of file ProcessingParameters.h.
References _centre_lat.
inline |
Definition at line 716 of file ProcessingParameters.h.
References _centre_long.
inline |
Definition at line 653 of file ProcessingParameters.h.
References _complete_msg.
inline |
Definition at line 218 of file ProcessingParameters.h.
References _date_incons.
inline |
Definition at line 232 of file ProcessingParameters.h.
References _delay_changes.
inline |
Definition at line 667 of file ProcessingParameters.h.
References _density_in.
inline |
Definition at line 744 of file ProcessingParameters.h.
References _density_out.
inline |
Definition at line 561 of file ProcessingParameters.h.
References _dop_amb_err.
inline |
Definition at line 568 of file ProcessingParameters.h.
References _dopamb_conf.
inline |
Definition at line 554 of file ProcessingParameters.h.
References _dopcen_est.
inline |
Definition at line 540 of file ProcessingParameters.h.
References _dopcen_inc.
inline |
Definition at line 575 of file ProcessingParameters.h.
References _eph_orb_data.
inline |
Definition at line 330 of file ProcessingParameters.h.
References _err_amp_coef.
inline |
Definition at line 337 of file ProcessingParameters.h.
References _err_phas_coef.
inline |
Definition at line 127 of file ProcessingParameters.h.
References _exp_ing_start.
inline |
Definition at line 134 of file ProcessingParameters.h.
References _exp_ing_stop.
inline |
Definition at line 211 of file ProcessingParameters.h.
References _fm_crc_err.
inline |
Definition at line 618 of file ProcessingParameters.h.
References _gics_reqd.
inline |
Definition at line 365 of file ProcessingParameters.h.
References _gn_corctn_fctr.
inline |
Definition at line 519 of file ProcessingParameters.h.
References _img_cumu_dist.
inline |
Definition at line 512 of file ProcessingParameters.h.
References _img_hist_mean.
inline |
Input media
Definition at line 106 of file ProcessingParameters.h.
References _inp_media.
inline |
Definition at line 197 of file ProcessingParameters.h.
References _large_gap.
inline |
Definition at line 702 of file ProcessingParameters.h.
References _map_system.
inline |
Definition at line 674 of file ProcessingParameters.h.
References _media_id.
inline |
Definition at line 183 of file ProcessingParameters.h.
References _miss_ln.
inline |
Definition at line 169 of file ProcessingParameters.h.
References _mn_sig_lev.
inline |
Number of beams
Definition at line 421 of file ProcessingParameters.h.
References _n_beams.
inline |
Definition at line 547 of file ProcessingParameters.h.
References _n_dopcen.
inline |
Definition at line 491 of file ProcessingParameters.h.
References _n_image_pix.
inline |
Definition at line 435 of file ProcessingParameters.h.
References _n_pix_updates.
inline |
Definition at line 597 of file ProcessingParameters.h.
References _n_srgr.
Referenced by ossimplugins::ossimRadarSatModel::internalSaveState().
inline |
Definition at line 113 of file ProcessingParameters.h.
References _n_tape_id.
inline |
Definition at line 477 of file ProcessingParameters.h.
References _n_temp_set.
inline |
Definition at line 758 of file ProcessingParameters.h.
References _num_state_vectors.
inline |
Orbit data source
Definition at line 379 of file ProcessingParameters.h.
References _orb_data_src.
inline |
Beam pixel counts.
Definition at line 442 of file ProcessingParameters.h.
References _pix_count.
inline |
Definition at line 414 of file ProcessingParameters.h.
References _pix_overlap.
inline |
Definition at line 611 of file ProcessingParameters.h.
References _pixel_spacing.
inline |
Definition at line 533 of file ProcessingParameters.h.
References _post_img_gn.
inline |
Definition at line 505 of file ProcessingParameters.h.
References _prc_satur_pix.
inline |
Percent zero pixels
Definition at line 498 of file ProcessingParameters.h.
References _prc_zero_pix.
inline |
Definition at line 526 of file ProcessingParameters.h.
References _pre_img_gn.
inline |
Definition at line 225 of file ProcessingParameters.h.
References _prf_changes.
inline |
Definition at line 155 of file ProcessingParameters.h.
References _proc_start.
inline |
Definition at line 162 of file ProcessingParameters.h.
References _proc_stop.
inline |
Definition at line 695 of file ProcessingParameters.h.
References _prod_type.
inline |
Definition at line 344 of file ProcessingParameters.h.
References _pulse_bandw.
inline |
Pulse count 1
Definition at line 386 of file ProcessingParameters.h.
References _pulse_cnt_1.
inline |
Pulse count 2
Definition at line 393 of file ProcessingParameters.h.
References _pulse_cnt_2.
inline |
Definition at line 456 of file ProcessingParameters.h.
References _pwin_end.
inline |
Definition at line 449 of file ProcessingParameters.h.
References _pwin_start.
inline |
Definition at line 98 of file ProcessingParameters.h.
References _rec_seq.
inline |
Recording type
Definition at line 463 of file ProcessingParameters.h.
References _recd_type.
inline |
Definition at line 246 of file ProcessingParameters.h.
References _rej_bf_start.
inline |
Definition at line 253 of file ProcessingParameters.h.
References _rej_few_fram.
inline |
Definition at line 190 of file ProcessingParameters.h.
References _rej_ln.
inline |
Definition at line 260 of file ProcessingParameters.h.
References _rej_many_fram.
inline |
Definition at line 267 of file ProcessingParameters.h.
References _rej_mchn_err.
inline |
Definition at line 281 of file ProcessingParameters.h.
References _rej_rec_type.
inline |
Definition at line 274 of file ProcessingParameters.h.
References _rej_vchn_err.
inline |
Definition at line 358 of file ProcessingParameters.h.
References _rep_agc_attn.
inline |
Definition at line 372 of file ProcessingParameters.h.
References _rep_energy_gn.
inline |
Definition at line 316 of file ProcessingParameters.h.
References _rng_amp_coef.
inline |
Definition at line 323 of file ProcessingParameters.h.
References _rng_phas_coef.
inline |
Definition at line 309 of file ProcessingParameters.h.
References _rng_ref_src.
inline |
Definition at line 639 of file ProcessingParameters.h.
References _satellite_id.
inline |
Definition at line 660 of file ProcessingParameters.h.
References _scene_id.
inline |
Definition at line 176 of file ProcessingParameters.h.
References _scr_data_ind.
inline |
Definition at line 288 of file ProcessingParameters.h.
References _sens_config.
inline |
Sensor orientation
Definition at line 295 of file ProcessingParameters.h.
References _sens_orient.
inline |
Definition at line 239 of file ProcessingParameters.h.
References _skipd_frams.
inline |
Definition at line 590 of file ProcessingParameters.h.
References _slow_time_coef.
inline |
Definition at line 723 of file ProcessingParameters.h.
References _span_x.
inline |
Definition at line 730 of file ProcessingParameters.h.
References _span_y.
inline |
Definition at line 604 of file ProcessingParameters.h.
References _srgr_coefset.
inline |
Definition at line 751 of file ProcessingParameters.h.
References _state_time.
inline |
Definition at line 765 of file ProcessingParameters.h.
References _state_time_inc.
inline |
Frame synch marker
Definition at line 302 of file ProcessingParameters.h.
References _sych_marker.
inline |
Tape identifiers
Definition at line 120 of file ProcessingParameters.h.
References _tape_id.
inline |
Definition at line 484 of file ProcessingParameters.h.
References _temp.
inline |
Definition at line 470 of file ProcessingParameters.h.
References _temp_set_inc.
inline |
User id
Definition at line 646 of file ProcessingParameters.h.
References _user_id.
inline |
Definition at line 632 of file ProcessingParameters.h.
References _wo_date.
inline |
Definition at line 625 of file ProcessingParameters.h.
References _wo_number.
inlinevirtual |
Definition at line 66 of file ProcessingParameters.h.
| ProcessingParameters & ossimplugins::ProcessingParameters::operator= | ( | const ProcessingParameters & | rhs | ) |
inlinevirtual |
Definition at line 82 of file ProcessingParameters.h.
inlinevirtual |
Definition at line 90 of file ProcessingParameters.h.
friend |
Definition at line 24 of file ProcessingParameters.cpp.
friend |
Definition at line 264 of file ProcessingParameters.cpp.
protected |
Definition at line 799 of file ProcessingParameters.h.
Referenced by get_act_ing_start(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 803 of file ProcessingParameters.h.
Referenced by get_act_ing_stop(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
ADC sampling rate
Definition at line 919 of file ProcessingParameters.h.
Referenced by get_adc_samp_rate(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1108 of file ProcessingParameters.h.
Referenced by get_angle_first(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1112 of file ProcessingParameters.h.
Referenced by get_angle_last(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Application type
Definition at line 1051 of file ProcessingParameters.h.
Referenced by get_appl_type(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1140 of file ProcessingParameters.h.
Referenced by get_apply_dtm(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 951 of file ProcessingParameters.h.
Referenced by get_beam_edge_conf(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 947 of file ProcessingParameters.h.
Referenced by get_beam_edge_rqd(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Beam info
Definition at line 963 of file ProcessingParameters.h.
Referenced by get_beam_info(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 835 of file ProcessingParameters.h.
Referenced by get_bit_err_rate(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1124 of file ProcessingParameters.h.
Referenced by get_centre_lat(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1128 of file ProcessingParameters.h.
Referenced by get_centre_long(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1092 of file ProcessingParameters.h.
Referenced by get_complete_msg(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 843 of file ProcessingParameters.h.
Referenced by get_date_incons(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 851 of file ProcessingParameters.h.
Referenced by get_delay_changes(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1100 of file ProcessingParameters.h.
Referenced by get_density_in(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1144 of file ProcessingParameters.h.
Referenced by get_density_out(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1039 of file ProcessingParameters.h.
Referenced by get_dop_amb_err(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1043 of file ProcessingParameters.h.
Referenced by get_dopamb_conf(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1035 of file ProcessingParameters.h.
Referenced by get_dopcen_est(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1027 of file ProcessingParameters.h.
Referenced by get_dopcen_inc(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1047 of file ProcessingParameters.h.
Referenced by get_eph_orb_data(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 907 of file ProcessingParameters.h.
Referenced by get_err_amp_coef(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 911 of file ProcessingParameters.h.
Referenced by get_err_phas_coef(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 791 of file ProcessingParameters.h.
Referenced by get_exp_ing_start(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 795 of file ProcessingParameters.h.
Referenced by get_exp_ing_stop(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 839 of file ProcessingParameters.h.
Referenced by get_fm_crc_err(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1072 of file ProcessingParameters.h.
Referenced by get_gics_reqd(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 927 of file ProcessingParameters.h.
Referenced by get_gn_corctn_fctr(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1015 of file ProcessingParameters.h.
Referenced by get_img_cumu_dist(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1011 of file ProcessingParameters.h.
Referenced by get_img_hist_mean(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Input media
Definition at line 779 of file ProcessingParameters.h.
Referenced by get_inp_media(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 831 of file ProcessingParameters.h.
Referenced by get_large_gap(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1120 of file ProcessingParameters.h.
Referenced by get_map_system(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1104 of file ProcessingParameters.h.
Referenced by get_media_id(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 823 of file ProcessingParameters.h.
Referenced by get_miss_ln(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 815 of file ProcessingParameters.h.
Referenced by get_mn_sig_lev(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Number of beams
Definition at line 959 of file ProcessingParameters.h.
Referenced by get_n_beams(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1031 of file ProcessingParameters.h.
Referenced by get_n_dopcen(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 999 of file ProcessingParameters.h.
Referenced by get_n_image_pix(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 967 of file ProcessingParameters.h.
Referenced by get_n_pix_updates(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1060 of file ProcessingParameters.h.
Referenced by get_n_srgr(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 783 of file ProcessingParameters.h.
Referenced by get_n_tape_id(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 991 of file ProcessingParameters.h.
Referenced by get_n_temp_set(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1152 of file ProcessingParameters.h.
Referenced by get_num_state_vectors(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Orbit data source
Definition at line 935 of file ProcessingParameters.h.
Referenced by get_orb_data_src(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Beam pixel counts.
Definition at line 971 of file ProcessingParameters.h.
Referenced by get_pix_count(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 955 of file ProcessingParameters.h.
Referenced by get_pix_overlap(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1068 of file ProcessingParameters.h.
Referenced by get_pixel_spacing(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1023 of file ProcessingParameters.h.
Referenced by get_post_img_gn(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1007 of file ProcessingParameters.h.
Referenced by get_prc_satur_pix(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Percent zero pixels
Definition at line 1003 of file ProcessingParameters.h.
Referenced by get_prc_zero_pix(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1019 of file ProcessingParameters.h.
Referenced by get_pre_img_gn(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 847 of file ProcessingParameters.h.
Referenced by get_prf_changes(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 807 of file ProcessingParameters.h.
Referenced by get_proc_start(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 811 of file ProcessingParameters.h.
Referenced by get_proc_stop(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1116 of file ProcessingParameters.h.
Referenced by get_prod_type(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 915 of file ProcessingParameters.h.
Referenced by get_pulse_bandw(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Pulse count 1
Definition at line 939 of file ProcessingParameters.h.
Referenced by get_pulse_cnt_1(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Pulse count 2
Definition at line 943 of file ProcessingParameters.h.
Referenced by get_pulse_cnt_2(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 979 of file ProcessingParameters.h.
Referenced by get_pwin_end(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 975 of file ProcessingParameters.h.
Referenced by get_pwin_start(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 768 of file ProcessingParameters.h.
Referenced by get_rec_seq(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Recording type
Definition at line 983 of file ProcessingParameters.h.
Referenced by get_recd_type(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 859 of file ProcessingParameters.h.
Referenced by get_rej_bf_start(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 863 of file ProcessingParameters.h.
Referenced by get_rej_few_fram(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 827 of file ProcessingParameters.h.
Referenced by get_rej_ln(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 867 of file ProcessingParameters.h.
Referenced by get_rej_many_fram(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 871 of file ProcessingParameters.h.
Referenced by get_rej_mchn_err(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 879 of file ProcessingParameters.h.
Referenced by get_rej_rec_type(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 875 of file ProcessingParameters.h.
Referenced by get_rej_vchn_err(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 923 of file ProcessingParameters.h.
Referenced by get_rep_agc_attn(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 931 of file ProcessingParameters.h.
Referenced by get_rep_energy_gn(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 899 of file ProcessingParameters.h.
Referenced by get_rng_amp_coef(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 903 of file ProcessingParameters.h.
Referenced by get_rng_phas_coef(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 895 of file ProcessingParameters.h.
Referenced by get_rng_ref_src(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1084 of file ProcessingParameters.h.
Referenced by get_satellite_id(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1096 of file ProcessingParameters.h.
Referenced by get_scene_id(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 819 of file ProcessingParameters.h.
Referenced by get_scr_data_ind(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 883 of file ProcessingParameters.h.
Referenced by get_sens_config(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Sensor orientation
Definition at line 887 of file ProcessingParameters.h.
Referenced by get_sens_orient(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 855 of file ProcessingParameters.h.
Referenced by get_skipd_frams(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1056 of file ProcessingParameters.h.
Referenced by get_slow_time_coef(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1132 of file ProcessingParameters.h.
Referenced by get_span_x(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1136 of file ProcessingParameters.h.
Referenced by get_span_y(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1064 of file ProcessingParameters.h.
Referenced by get_srgr_coefset(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1148 of file ProcessingParameters.h.
Referenced by get_state_time(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1156 of file ProcessingParameters.h.
Referenced by get_state_time_inc(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Frame synch marker
Definition at line 891 of file ProcessingParameters.h.
Referenced by get_sych_marker(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Tape identifiers
Definition at line 787 of file ProcessingParameters.h.
Referenced by get_tape_id(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 995 of file ProcessingParameters.h.
Referenced by get_temp(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 987 of file ProcessingParameters.h.
Referenced by get_temp_set_inc(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
User id
Definition at line 1088 of file ProcessingParameters.h.
Referenced by get_user_id(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1080 of file ProcessingParameters.h.
Referenced by get_wo_date(), ossimplugins::operator<<(), and ossimplugins::operator>>().
protected |
Definition at line 1076 of file ProcessingParameters.h.
Referenced by get_wo_number(), ossimplugins::operator<<(), and ossimplugins::operator>>().
