This class allows for direct localisation and indirect localisation using the CosmoSkymed sensor model. More...
#include <ossimCosmoSkymedModel.h>
| ossimCosmoSkymedModel () | |
| Constructor. More... | |
| ~ossimCosmoSkymedModel () | |
| Destructor. More... | |
| virtual double | getSlantRangeFromGeoreferenced (double col) const |
| This function associates an image column number to a slant range when the image is georeferenced (ground projected) More... | |
Public Member Functions inherited from ossimplugins::ossimGeometricSarSensorModel | |
| ossimGeometricSarSensorModel () | |
| ossimGeometricSarSensorModel (const ossimGeometricSarSensorModel &rhs) | |
| copy constructor More... | |
| virtual | ~ossimGeometricSarSensorModel () |
| virtual double | getSlantRange (double col) const |
| This function associates an image column number to a slant range. More... | |
| virtual JSDDateTime | getTime (double line) const |
| This function associates an image line number to an azimuth time. More... | |
| virtual bool | getPlatformPositionAtLine (double line, vector< double > &position, vector< double > &speed) |
| This function associates an image line number to a platform position and speed. More... | |
| This function is able to convert image coordinates into world coordinates the geometric model of SAR sensors. More... | |
| virtual bool | optimizeModel (const std::list< ossimGpt > &groundCoordinates, const std::list< ossimDpt > &imageCoordinates) |
| This function optimizes the model according to a list of Ground Control Points. More... | |
| virtual void | clearGCPlist () |
| Clears _optimizationGCPsGroundCoordinates and _optimizationGCPsImageCoordinates attributes Updates the optimisation factors and bias. More... | |
| virtual void | getGCPlist (std::list< ossimGpt > &groundCoordinates, std::list< ossimDpt > &imageCoordinates) |
| Returns _optimizationGCPsGroundCoordinates and _optimizationGCPsImageCoordinates attributes. More... | |
| Method to save object state to a keyword list. More... | |
| Method to the load (recreate) the state of the object from a keyword list. More... | |
| double | get_optimizationFactorX () const |
| Accessors to the optimization parameters. More... | |
| double | get_optimizationFactorY () const |
| double | get_optimizationBiasX () const |
| double | get_optimizationBiasY () const |
| ossimRefPtr< ossimCoarseGridModel > | getReplacementOcgModel () |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &gpt) const |
| void | set_platformPosition (PlatformPosition *platformPosition) |
| Accessors to the plateform, sensor parameters and reference point. More... | |
| void | set_sensorParams (SensorParams *sensorParams) |
| void | set_refPoint (RefPoint *refPoint) |
| PlatformPosition * | get_platformPosition () const |
| SensorParams * | get_sensorParams () const |
| RefPoint * | get_refPoint () const |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| virtual ossimObject * | dup () const =0 |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| virtual void | initAdjustableParameters () |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
Private Member Functions | |
| virtual bool | InitPlatformPosition (const ossimKeywordlist &kwl, const char *prefix) |
| Initializes the Platform Position from a projection keywordlist. More... | |
| virtual bool | InitSensorParams (const ossimKeywordlist &kwl, const char *prefix) |
| Initializes the Sensor Params from a projection keywordlist. More... | |
| virtual bool | InitRefPoint (const ossimKeywordlist &kwl, const char *prefix) |
| Initializes the Reference Point from a projection keywordlist. More... | |
| virtual bool | InitSRGR (const ossimKeywordlist &kwl, const char *prefix) |
| Initializes the Slant Range to Ground Range data sets : _SrToGr_R0,_SrToGr_coeffs_number,_SrToGr_exponent,_SrToGr_coeffs,_nbCol. More... | |
| bool | UtcDateTimeStringToCivilDate (const std::string &utcString, CivilDateTime &outputDate) |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Static Public Member Functions inherited from ossimSensorModel | |
| static void | writeGeomTemplate (ostream &os) |
Static Public Attributes inherited from ossimplugins::ossimGeometricSarSensorModel | |
| static const char * | CREATE_OCG_PREF_KW = "geometric_sar_sensor_model.create_ocg" |
Protected Member Functions inherited from ossimplugins::ossimGeometricSarSensorModel | |
| bool | createReplacementOCG () |
| Creates replacement coarse grid model if user requested via ossim preferences keyword "geometric_sar_sensor_model.create_ocg: <bool>". More... | |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Definition at line 37 of file ossimCosmoSkymedModel.h.
| ossimplugins::ossimCosmoSkymedModel::ossimCosmoSkymedModel | ( | ) |
Constructor.
Definition at line 31 of file ossimCosmoSkymedModel.cpp.
| ossimplugins::ossimCosmoSkymedModel::~ossimCosmoSkymedModel | ( | ) |
| col | Column coordinate of the image point |
Implements ossimplugins::ossimGeometricSarSensorModel.
Definition at line 43 of file ossimCosmoSkymedModel.cpp.
References _pixel_spacing, ossimplugins::ossimGeometricSarSensorModel::_refPoint, ossimplugins::ossimGeometricSarSensorModel::_sensor, _SrGr_coeffs, _SrGr_R0, ossimplugins::SensorParams::get_col_direction(), ossimplugins::RefPoint::get_distance(), and ossimplugins::RefPoint::get_pix_col().
privatevirtual |
Definition at line 128 of file ossimCosmoSkymedModel.cpp.
References ossimplugins::ossimGeometricSarSensorModel::_platformPosition, ossimKeywordlist::find(), ossimplugins::CivilDateTime::get_day(), ossimplugins::CivilDateTime::get_month(), ossimplugins::CivilDateTime::get_year(), and UtcDateTimeStringToCivilDate().
privatevirtual |
Definition at line 215 of file ossimCosmoSkymedModel.cpp.
References ossimplugins::ossimGeometricSarSensorModel::_isProductGeoreferenced, _pixel_spacing, ossimplugins::ossimGeometricSarSensorModel::_platformPosition, ossimplugins::ossimGeometricSarSensorModel::_refPoint, ossimplugins::ossimGeometricSarSensorModel::_sensor, distance(), ossimKeywordlist::find(), ossimplugins::CivilDateTime::get_day(), ossimplugins::CivilDateTime::get_month(), ossimplugins::SensorParams::get_nRangeLook(), ossimplugins::RefPoint::get_pix_col(), ossimplugins::SensorParams::get_prf(), ossimplugins::SensorParams::get_sf(), ossimplugins::CivilDateTime::get_year(), ossimplugins::PlatformPosition::Interpolate(), ossimplugins::ossimGeometricSarSensorModel::optimizeModel(), ossimplugins::RefPoint::set_distance(), ossimplugins::RefPoint::set_ephemeris(), ossimplugins::RefPoint::set_pix_col(), ossimplugins::RefPoint::set_pix_line(), ossimSensorModel::theImageClipRect, ossimSensorModel::theImageSize, UtcDateTimeStringToCivilDate(), ossimIpt::x, and ossimIpt::y.
privatevirtual |
Definition at line 58 of file ossimCosmoSkymedModel.cpp.
References ossimplugins::ossimGeometricSarSensorModel::_sensor, ossimKeywordlist::find(), ossimplugins::SensorParams::Left, ossimplugins::SensorParams::Right, ossimplugins::SensorParams::set_col_direction(), ossimplugins::SensorParams::set_lin_direction(), ossimplugins::SensorParams::set_nAzimuthLook(), ossimplugins::SensorParams::set_nRangeLook(), ossimplugins::SensorParams::set_prf(), ossimplugins::SensorParams::set_rwl(), ossimplugins::SensorParams::set_semiMajorAxis(), ossimplugins::SensorParams::set_semiMinorAxis(), ossimplugins::SensorParams::set_sf(), and ossimplugins::SensorParams::set_sightDirection().
privatevirtual |
Definition at line 324 of file ossimCosmoSkymedModel.cpp.
References ossimplugins::ossimGeometricSarSensorModel::_isProductGeoreferenced, _nbCol, _pixel_spacing, _SrGr_coeffs, _SrGr_R0, and ossimKeywordlist::find().
private |
Definition at line 357 of file ossimCosmoSkymedModel.cpp.
References ossimplugins::CivilDateTime::set_day(), ossimplugins::CivilDateTime::set_decimal(), ossimplugins::CivilDateTime::set_month(), ossimplugins::CivilDateTime::set_second(), ossimplugins::CivilDateTime::set_year(), and true.
Referenced by InitPlatformPosition(), and InitRefPoint().
protected |
protected |
Pixel spacing.
Definition at line 77 of file ossimCosmoSkymedModel.h.
Referenced by getSlantRangeFromGeoreferenced(), InitRefPoint(), and InitSRGR().
protected |
Scene Center range time.
Definition at line 73 of file ossimCosmoSkymedModel.h.
protected |
Slant Range for each Ground Range Projection coefficients.
Definition at line 69 of file ossimCosmoSkymedModel.h.
Referenced by getSlantRangeFromGeoreferenced(), and InitSRGR().
protected |
Slant Range for each Ground Range Projection reference point.
Definition at line 65 of file ossimCosmoSkymedModel.h.
