This class manages and solves an equation of the fourth degree. More...
#include <Equation.h>
| Equation () | |
| Constructor. More... | |
| ~Equation () | |
| Destructor. More... | |
| Equation (const Equation &rhs) | |
| Equation & | operator= (const Equation &rhs) |
| Equation (int degree, std::complex< double > *coefficients) | |
| void | CreateEquation (int degree, std::complex< double > *coefficients) |
| void | Solve () |
| int | get_nbrSol () const |
| const std::complex< double > * | get_solutions () const |
| std::vector< int > | get_order () const |
| void | ComputeTrueDegree () |
| void | Normalisation () |
| void | DeNormalisation () |
Protected Attributes | |
| std::complex< double > * | _coefficients |
| Equation coefficients. More... | |
| int | _degree |
| Equation degree. More... | |
| int | _nbrSol |
| std::vector< int > | _order |
| std::complex< double > * | _solutions |
Static Protected Attributes | |
| static const double | Epsilon = 1.e-12 |
Private Types | |
| enum | NormalisationType { GreatValues, SmallValues } |
Private Member Functions | |
| void | Solve1 () |
| void | Solve2 () |
| void | Solve3 (int d4=0) |
| void | Solve4 () |
| std::complex< double > | Proche (std::complex< double > z, double epsilon) |
| ?? More... | |
| int | TestDegree3Triple (std::complex< double > *a, double epsilon) |
| Tests whether a triple root exists in a third degree equation. More... | |
| int | TestDegree3SimpleDouble (std::complex< double > *a, double epsilon) |
| Tests whether a double root and a simple root exist in a third degree equation. More... | |
| int | IndiceMin (int n, double *list) |
| Returns the index of the smaller list element. More... | |
| int | IndiceMax (int n, double *list) |
| Returns the index of the greater list element. More... | |
| int | TestDegree4Quad (std::complex< double > *a, double epsilon) |
| Tests whether a quadruple root exists in a fourth degree equation. More... | |
| int | TestDegree4DoubleDouble (std::complex< double > *a, std::complex< double > *k, double epsilon) |
| Tests whether two double roots exist in a fourth degree equation. More... | |
| int | TestDegree4SimpleTriple (std::complex< double > *a, std::complex< double > *k, double epsilon) |
| Tests whether one simple root and one triple root exist in a fourth degree equation. More... | |
| int | TestDegreeSimpleSimpleDouble (std::complex< double > *a, double epsilon) |
| Tests whether two simple root and one double root exist in a fourth degree equation. More... | |
Private Attributes | |
| NormalisationType | _normalisationType |
| double | _normalisationCoefficient |
| int | _trueDegree |
Definition at line 26 of file Equation.h.
private |
| Enumerator | |
| GreatValues | |
| SmallValues | |
Definition at line 85 of file Equation.h.
| ossimplugins::Equation::Equation | ( | ) |
Constructor.
Definition at line 20 of file Equation.cpp.
References _order.
| ossimplugins::Equation::~Equation | ( | ) |
Destructor.
Definition at line 29 of file Equation.cpp.
References _coefficients, and _solutions.
| ossimplugins::Equation::Equation | ( | const Equation & | rhs | ) |
Definition at line 68 of file Equation.cpp.
References _coefficients, _degree, and CreateEquation().
| ossimplugins::Equation::Equation | ( | int | degree, |
| std::complex< double > * | coefficients | ||
Definition at line 37 of file Equation.cpp.
References _order, and CreateEquation().
protected |
Definition at line 79 of file Equation.cpp.
References _coefficients, _degree, _trueDegree, and abs.
Referenced by Solve().
| void ossimplugins::Equation::CreateEquation | ( | int | degree, |
Definition at line 47 of file Equation.cpp.
References _coefficients, _degree, _order, and _solutions.
Referenced by Equation(), and operator=().
protected |
Definition at line 149 of file Equation.cpp.
References _nbrSol, _normalisationCoefficient, _normalisationType, _solutions, and GreatValues.
inline |
Definition at line 48 of file Equation.h.
Referenced by ossimplugins::SarSensor::localisationSAR().
inline |
Definition at line 58 of file Equation.h.
inline |
Definition at line 53 of file Equation.h.
Referenced by ossimplugins::SarSensor::localisationSAR(), and Solve4().
private |
Definition at line 804 of file Equation.cpp.
References n.
Referenced by Solve4(), TestDegree3SimpleDouble(), TestDegree4DoubleDouble(), TestDegree4SimpleTriple(), and TestDegreeSimpleSimpleDouble().
private |
Definition at line 785 of file Equation.cpp.
References n.
Referenced by Solve3(), and Solve4().
protected |
Definition at line 90 of file Equation.cpp.
References _coefficients, _normalisationCoefficient, _normalisationType, _trueDegree, abs, Epsilon, GreatValues, and SmallValues.
Definition at line 73 of file Equation.cpp.
private |
| void ossimplugins::Equation::Solve | ( | ) |
Definition at line 195 of file Equation.cpp.
References _trueDegree, ComputeTrueDegree(), DeNormalisation(), Normalisation(), Solve1(), Solve2(), Solve3(), and Solve4().
private |
Definition at line 219 of file Equation.cpp.
References _coefficients, _nbrSol, _order, _solutions, Epsilon, and Proche().
private |
Definition at line 234 of file Equation.cpp.
References _coefficients, _nbrSol, _order, _solutions, abs, Epsilon, and Proche().
private |
Definition at line 300 of file Equation.cpp.
References _coefficients, _nbrSol, _order, _solutions, abs, Epsilon, IndiceMin(), Proche(), TestDegree3SimpleDouble(), and TestDegree3Triple().
Referenced by Solve(), and Solve4().
private |
Definition at line 458 of file Equation.cpp.
References _coefficients, _nbrSol, _order, _solutions, abs, Epsilon, get_solutions(), IndiceMax(), IndiceMin(), Proche(), Solve3(), TestDegree4DoubleDouble(), TestDegree4Quad(), TestDegree4SimpleTriple(), TestDegreeSimpleSimpleDouble(), x, and y.
private |
Definition at line 758 of file Equation.cpp.
References abs, and IndiceMax().
Referenced by Solve3().
private |
Definition at line 733 of file Equation.cpp.
References abs.
private |
Definition at line 833 of file Equation.cpp.
Referenced by Solve4().
private |
Definition at line 822 of file Equation.cpp.
References abs.
private |
Definition at line 865 of file Equation.cpp.
private |
Definition at line 903 of file Equation.cpp.
protected |
Definition at line 61 of file Equation.h.
Referenced by ComputeTrueDegree(), CreateEquation(), Equation(), Normalisation(), operator=(), Solve1(), Solve2(), Solve3(), Solve4(), and ~Equation().
protected |
Equation degree.
Definition at line 72 of file Equation.h.
Referenced by ComputeTrueDegree(), CreateEquation(), Equation(), and operator=().
protected |
Definition at line 80 of file Equation.h.
Referenced by DeNormalisation(), Solve1(), Solve2(), Solve3(), and Solve4().
private |
Definition at line 92 of file Equation.h.
Referenced by DeNormalisation(), and Normalisation().
private |
Definition at line 91 of file Equation.h.
protected |
Definition at line 81 of file Equation.h.
Referenced by CreateEquation(), Equation(), Solve1(), Solve2(), Solve3(), and Solve4().
protected |
Definition at line 82 of file Equation.h.
Referenced by CreateEquation(), DeNormalisation(), Solve1(), Solve2(), Solve3(), Solve4(), and ~Equation().
private |
Definition at line 93 of file Equation.h.
Referenced by ComputeTrueDegree(), Normalisation(), and Solve().
staticprotected |
Definition at line 78 of file Equation.h.
Referenced by Normalisation(), Solve1(), Solve2(), Solve3(), and Solve4().
