This class is a facory able to construct Record base classes given the id of the record wanted. More...
#include <ErsSarRecordFactory.h>
| ErsSarRecordFactory () | |
| Constructor. More... | |
| virtual | ~ErsSarRecordFactory () |
| Destructor. More... | |
| void | RegisterRecord (int id, ErsSarRecord *record) |
| Add a new Record type available in this factory. More... | |
| ErsSarRecord * | Instanciate (int id) |
| Instanciate a new Record. More... | |
Protected Attributes | |
| std::map< int, ErsSarRecord * > | _availableRecords |
| Contain all the available Records for the factory. More... | |
Definition at line 31 of file ErsSarRecordFactory.h.
| ossimplugins::ErsSarRecordFactory::ErsSarRecordFactory | ( | ) |
| ErsSarRecord * ossimplugins::ErsSarRecordFactory::Instanciate | ( | int | id | ) |
| id | Id of the Record we want to instanciate |
Definition at line 25 of file ErsSarRecordFactory.cpp.
References _availableRecords, and ossimplugins::ErsSarRecord::Instanciate().
Referenced by ossimplugins::operator>>().
| void ossimplugins::ErsSarRecordFactory::RegisterRecord | ( | int | id, |
| ErsSarRecord * | record | ||
| record | Record to add in the factory |
| id | Id of the new avalaible Record |
Definition at line 38 of file ErsSarRecordFactory.cpp.
References _availableRecords.
Referenced by ossimplugins::ErsSarLeaderFactory::ErsSarLeaderFactory().
protected |
Definition at line 60 of file ErsSarRecordFactory.h.
Referenced by Instanciate(), RegisterRecord(), and ossimplugins::ErsSarLeaderFactory::~ErsSarLeaderFactory().
