This class is able to read the ASAR GeolocationGrid record. More...
#include <GeolocationGrid.h>
| GeolocationGrid () | |
| Constructor. More... | |
| virtual | ~GeolocationGrid () |
| Destructor. More... | |
| GeolocationGrid (const GeolocationGrid &rhs) | |
| Copy constructor. More... | |
| GeolocationGrid & | operator= (const GeolocationGrid &rhs) |
| Copy operator. More... | |
| EnvisatAsarRecord * | Instanciate () |
| This function is able to create a new instance of the class. More... | |
| EnvisatAsarRecord * | Clone () |
| This function is able to create a new instance of the class initialised with the data of the calling instance. More... | |
| void | Read (std::istream &is) |
| Reads the class data from a stream. More... | |
| void | Write (std::ostream &os) |
| Writes the class to a stream. More... | |
| int | get_first_zero_doppler_time_day () |
| first_zero_doppler_time day More... | |
| unsigned int | get_first_zero_doppler_time_sec () |
| first_zero_doppler_time second More... | |
| unsigned int | get_first_zero_doppler_time_microsec () |
| first_zero_doppler_time micro sec More... | |
| bool | get_attach_flag () |
| attach_flag More... | |
| unsigned int | get_line_num () |
| line_num More... | |
| unsigned int | get_num_lines () |
| num_lines More... | |
| float | get_sub_sat_track () |
| sub_sat_track More... | |
| unsigned int * | get_samp_numbers () |
| samp_numbvers More... | |
| float * | get_slant_range_times () |
| slant_range_times More... | |
| float * | get_angles () |
| angles More... | |
| int * | get_lats () |
| lats More... | |
| int * | get_longs () |
| longs More... | |
| std::string | get_last_zero_doppler_time () |
| last_zero_doppler_time More... | |
| std::string | get_last_line_tie_points () |
| last_line_tie_points More... | |
Public Member Functions inherited from ossimplugins::EnvisatAsarRecord | |
| EnvisatAsarRecord (std::string mnemonic) | |
| virtual | ~EnvisatAsarRecord () |
| EnvisatAsarRecord (const EnvisatAsarRecord &rhs) | |
| std::string | get_mnemonic () |
| Returns the mnemonic of the record. More... | |
Public Attributes | |
| int | _first_zero_doppler_time_day |
| unsigned int | _first_zero_doppler_time_sec |
| first_zero_doppler_time sec More... | |
| unsigned int | _first_zero_doppler_time_microsec |
| first_zero_doppler_time microsec More... | |
| bool | _attach_flag |
| unsigned int | _line_num |
| unsigned int | _num_lines |
| float | _sub_sat_track |
| unsigned int | _samp_numbers [11] |
| samp_numbers More... | |
| float | _slant_range_times [11] |
| slant_range_times[11] More... | |
| float | _angles [11] |
| angles[11] More... | |
| int | _lats [11] |
| lats[11] More... | |
| int | _longs [11] |
| longs[11] More... | |
| std::string | _last_zero_doppler_time |
| std::string | _last_line_tie_points |
Friends | |
| std::ostream & | operator<< (std::ostream &os, const GeolocationGrid &data) |
| This function writes the GeolocationGrid in a stream. More... | |
| std::istream & | operator>> (std::istream &is, GeolocationGrid &data) |
| This function reads a GeolocationGrid from a stream. More... | |
Protected Member Functions inherited from ossimplugins::EnvisatAsarRecord | |
| template<typename T > | |
| void | SwitchEndian (T &value) |
| This function switches the LSB value and the MSB value of the parameter. More... | |
Protected Attributes inherited from ossimplugins::EnvisatAsarRecord | |
| std::string | _mnemonic |
Definition at line 24 of file GeolocationGrid.h.
| ossimplugins::GeolocationGrid::GeolocationGrid | ( | ) |
Constructor.
Definition at line 16 of file GeolocationGrid.cpp.
Referenced by Clone(), and Instanciate().
| ossimplugins::GeolocationGrid::GeolocationGrid | ( | const GeolocationGrid & | rhs | ) |
Copy constructor.
Definition at line 170 of file GeolocationGrid.cpp.
References _angles, _lats, _longs, _samp_numbers, and _slant_range_times.
inlinevirtual |
Implements ossimplugins::EnvisatAsarRecord.
Definition at line 68 of file GeolocationGrid.h.
References GeolocationGrid().
inline |
inline |
attach_flag
Definition at line 113 of file GeolocationGrid.h.
References _attach_flag.
inline |
Definition at line 92 of file GeolocationGrid.h.
References _first_zero_doppler_time_day.
Referenced by ossimplugins::ossimEnvisatAsarModel::saveState().
inline |
Definition at line 106 of file GeolocationGrid.h.
References _first_zero_doppler_time_microsec.
inline |
Definition at line 99 of file GeolocationGrid.h.
References _first_zero_doppler_time_sec.
inline |
Definition at line 183 of file GeolocationGrid.h.
References _last_line_tie_points.
inline |
Definition at line 176 of file GeolocationGrid.h.
References _last_zero_doppler_time.
inline |
lats
Definition at line 162 of file GeolocationGrid.h.
References _lats.
inline |
line_num
Definition at line 120 of file GeolocationGrid.h.
References _line_num.
inline |
longs
Definition at line 169 of file GeolocationGrid.h.
References _longs.
inline |
num_lines
Definition at line 127 of file GeolocationGrid.h.
References _num_lines.
inline |
samp_numbvers
Definition at line 141 of file GeolocationGrid.h.
References _samp_numbers.
inline |
slant_range_times
Definition at line 148 of file GeolocationGrid.h.
References _slant_range_times.
inline |
sub_sat_track
Definition at line 134 of file GeolocationGrid.h.
References _sub_sat_track.
inlinevirtual |
Definition at line 60 of file GeolocationGrid.h.
| GeolocationGrid & ossimplugins::GeolocationGrid::operator= | ( | const GeolocationGrid & | rhs | ) |
Copy operator.
Definition at line 195 of file GeolocationGrid.cpp.
References _angles, _attach_flag, _first_zero_doppler_time_day, _first_zero_doppler_time_microsec, _first_zero_doppler_time_sec, _last_line_tie_points, _last_zero_doppler_time, _lats, _line_num, _longs, _num_lines, _samp_numbers, _slant_range_times, and _sub_sat_track.
inlinevirtual |
Definition at line 76 of file GeolocationGrid.h.
inlinevirtual |
Definition at line 84 of file GeolocationGrid.h.
friend |
Definition at line 25 of file GeolocationGrid.cpp.
friend |
Definition at line 69 of file GeolocationGrid.cpp.
| float ossimplugins::GeolocationGrid::_angles[11] |
angles[11]
Definition at line 228 of file GeolocationGrid.h.
Referenced by GeolocationGrid(), get_angles(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| bool ossimplugins::GeolocationGrid::_attach_flag |
attach_flag
Definition at line 204 of file GeolocationGrid.h.
Referenced by get_attach_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::GeolocationGrid::_first_zero_doppler_time_day |
Definition at line 186 of file GeolocationGrid.h.
Referenced by get_first_zero_doppler_time_day(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::GeolocationGrid::_first_zero_doppler_time_microsec |
Definition at line 200 of file GeolocationGrid.h.
Referenced by get_first_zero_doppler_time_microsec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::GeolocationGrid::_first_zero_doppler_time_sec |
Definition at line 196 of file GeolocationGrid.h.
Referenced by get_first_zero_doppler_time_sec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::GeolocationGrid::_last_line_tie_points |
Definition at line 244 of file GeolocationGrid.h.
Referenced by get_last_line_tie_points(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::GeolocationGrid::_last_zero_doppler_time |
Definition at line 240 of file GeolocationGrid.h.
Referenced by get_last_zero_doppler_time(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::GeolocationGrid::_lats[11] |
lats[11]
Definition at line 232 of file GeolocationGrid.h.
Referenced by GeolocationGrid(), get_lats(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::GeolocationGrid::_line_num |
line_num
Definition at line 208 of file GeolocationGrid.h.
Referenced by get_line_num(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::GeolocationGrid::_longs[11] |
longs[11]
Definition at line 236 of file GeolocationGrid.h.
Referenced by GeolocationGrid(), get_longs(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::GeolocationGrid::_num_lines |
num_lines
Definition at line 212 of file GeolocationGrid.h.
Referenced by get_num_lines(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::GeolocationGrid::_samp_numbers[11] |
samp_numbers
Definition at line 220 of file GeolocationGrid.h.
Referenced by GeolocationGrid(), get_samp_numbers(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::GeolocationGrid::_slant_range_times[11] |
Definition at line 224 of file GeolocationGrid.h.
Referenced by GeolocationGrid(), get_slant_range_times(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::GeolocationGrid::_sub_sat_track |
sub_sat_track
Definition at line 216 of file GeolocationGrid.h.
Referenced by get_sub_sat_track(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
