This class is able to read a Compensation data record. More...
#include <CompensationDataRecord.h>
| CompensationDataRecord () | |
| Constructor. More... | |
| ~CompensationDataRecord () | |
| Destructor. More... | |
| CompensationDataRecord (const CompensationDataRecord &rhs) | |
| Copy constructor. More... | |
| CompensationDataRecord & | operator= (const CompensationDataRecord &rhs) |
| Copy operator. More... | |
| std::string | get_comp_desig () |
| Compensation data designator. More... | |
| std::string | get_comp_descr () |
Compensation data descriptor More... | |
| int | get_n_comp_rec () |
Number of compensation records More... | |
| int | get_comp_seq_no () |
Compensation record sequence number More... | |
| int | get_beam_tab_size () |
Number of beam table entries More... | |
| double * | get_beam_tab () |
Elevation gain beam profile More... | |
| std::string | get_beam_type () |
Beam type More... | |
| double | get_look_angle () |
Look angle of beam table centre More... | |
| double | get_beam_tab_inc () |
Increment between beam table entries More... | |
Protected Attributes | |
| std::string | _comp_desig |
| std::string | _comp_descr |
| int | _n_comp_rec |
| int | _comp_seq_no |
| int | _beam_tab_size |
| double | _beam_tab [256] |
| std::string | _beam_type |
| double | _look_angle |
| double | _beam_tab_inc |
Friends | |
| std::ostream & | operator<< (std::ostream &os, const CompensationDataRecord &data) |
| This function writes the CompensationDataRecord in a stream. More... | |
| std::istream & | operator>> (std::istream &is, CompensationDataRecord &data) |
| This function reads a CompensationDataRecord from a stream. More... | |
Definition at line 26 of file CompensationDataRecord.h.
| ossimplugins::CompensationDataRecord::CompensationDataRecord | ( | ) |
| ossimplugins::CompensationDataRecord::~CompensationDataRecord | ( | ) |
| ossimplugins::CompensationDataRecord::CompensationDataRecord | ( | const CompensationDataRecord & | rhs | ) |
Copy constructor.
Definition at line 97 of file CompensationDataRecord.cpp.
References _beam_tab, _beam_tab_inc, _beam_tab_size, _beam_type, _comp_descr, _comp_desig, _comp_seq_no, _look_angle, and _n_comp_rec.
inline |
Definition at line 96 of file CompensationDataRecord.h.
References _beam_tab.
inline |
Definition at line 117 of file CompensationDataRecord.h.
References _beam_tab_inc.
inline |
Definition at line 89 of file CompensationDataRecord.h.
References _beam_tab_size.
inline |
Beam type
Definition at line 103 of file CompensationDataRecord.h.
References _beam_type.
inline |
Definition at line 68 of file CompensationDataRecord.h.
References _comp_descr.
inline |
Definition at line 61 of file CompensationDataRecord.h.
References _comp_desig.
inline |
Definition at line 82 of file CompensationDataRecord.h.
References _comp_seq_no.
inline |
Definition at line 110 of file CompensationDataRecord.h.
References _look_angle.
inline |
Definition at line 75 of file CompensationDataRecord.h.
References _n_comp_rec.
| CompensationDataRecord & ossimplugins::CompensationDataRecord::operator= | ( | const CompensationDataRecord & | rhs | ) |
Copy operator.
Definition at line 121 of file CompensationDataRecord.cpp.
friend |
Definition at line 24 of file CompensationDataRecord.cpp.
friend |
Definition at line 49 of file CompensationDataRecord.cpp.
protected |
Definition at line 146 of file CompensationDataRecord.h.
Referenced by CompensationDataRecord(), get_beam_tab(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 158 of file CompensationDataRecord.h.
Referenced by CompensationDataRecord(), get_beam_tab_inc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 142 of file CompensationDataRecord.h.
Referenced by CompensationDataRecord(), get_beam_tab_size(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Beam type
Definition at line 150 of file CompensationDataRecord.h.
Referenced by CompensationDataRecord(), get_beam_type(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 130 of file CompensationDataRecord.h.
Referenced by CompensationDataRecord(), get_comp_descr(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 120 of file CompensationDataRecord.h.
Referenced by CompensationDataRecord(), get_comp_desig(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 138 of file CompensationDataRecord.h.
Referenced by CompensationDataRecord(), get_comp_seq_no(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 154 of file CompensationDataRecord.h.
Referenced by CompensationDataRecord(), get_look_angle(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 134 of file CompensationDataRecord.h.
Referenced by CompensationDataRecord(), get_n_comp_rec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
