This class is able to read a Beam information record. More...
#include <BeamInformationRecord.h>
| BeamInformationRecord () | |
| Constructor. More... | |
| ~BeamInformationRecord () | |
| Destructor. More... | |
| BeamInformationRecord (const BeamInformationRecord &rhs) | |
| Copy constructor. More... | |
| BeamInformationRecord & | operator= (const BeamInformationRecord &rhs) |
| Copy operator. More... | |
| std::string | get_beam_type () |
| Beam type. More... | |
| std::string | get_beam_look_src () |
| Elevation beam look angle source. More... | |
| double | get_beam_look_ang () |
Applied elevation beam look angle (deg) More... | |
| double | get_prf () |
| Actual PRF (Hz) More... | |
Protected Attributes | |
| std::string | _beam_type |
| std::string | _beam_look_src |
| double | _beam_look_ang |
| double | _prf |
Friends | |
| std::ostream & | operator<< (std::ostream &os, const BeamInformationRecord &data) |
| This function writes the BeamInformationRecord in a stream. More... | |
| std::istream & | operator>> (std::istream &is, BeamInformationRecord &data) |
| This function reads a BeamInformationRecord from a stream. More... | |
Definition at line 25 of file BeamInformationRecord.h.
| ossimplugins::BeamInformationRecord::BeamInformationRecord | ( | ) |
| ossimplugins::BeamInformationRecord::~BeamInformationRecord | ( | ) |
| ossimplugins::BeamInformationRecord::BeamInformationRecord | ( | const BeamInformationRecord & | rhs | ) |
Copy constructor.
Definition at line 61 of file BeamInformationRecord.cpp.
inline |
Definition at line 77 of file BeamInformationRecord.h.
References _beam_look_ang.
inline |
Definition at line 69 of file BeamInformationRecord.h.
References _beam_look_src.
inline |
Beam type.
Definition at line 61 of file BeamInformationRecord.h.
References _beam_type.
inline |
Actual PRF (Hz)
Definition at line 85 of file BeamInformationRecord.h.
References _prf.
| BeamInformationRecord & ossimplugins::BeamInformationRecord::operator= | ( | const BeamInformationRecord & | rhs | ) |
Copy operator.
Definition at line 70 of file BeamInformationRecord.cpp.
References _beam_look_ang, _beam_look_src, _beam_type, and _prf.
friend |
Definition at line 24 of file BeamInformationRecord.cpp.
friend |
Definition at line 37 of file BeamInformationRecord.cpp.
protected |
Definition at line 104 of file BeamInformationRecord.h.
Referenced by get_beam_look_ang(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 99 of file BeamInformationRecord.h.
Referenced by get_beam_look_src(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Beam type.
Definition at line 88 of file BeamInformationRecord.h.
Referenced by get_beam_type(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Actual PRF (Hz)
Definition at line 109 of file BeamInformationRecord.h.
Referenced by get_prf(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
