This class is able to read a radiometric data record. More...
#include <AlosPalsarRadiometricData.h>
| AlosPalsarRadiometricData () | |
| Constructor. More... | |
| virtual | ~AlosPalsarRadiometricData () |
| Destructor. More... | |
| AlosPalsarRadiometricData (const AlosPalsarRadiometricData &rhs) | |
| Copy constructor. More... | |
| AlosPalsarRadiometricData & | operator= (const AlosPalsarRadiometricData &rhs) |
| Copy operator. More... | |
| AlosPalsarRecord * | Instanciate () |
| This function is able to create a new instance of the class. More... | |
| AlosPalsarRecord * | Clone () |
| This function is able to create a new instance of the class initialised with the data of the calling instance. More... | |
| void | Read (std::istream &is) |
| Read the class data from a stream. More... | |
| void | Write (std::ostream &os) |
| Write the class to a stream. More... | |
| double | get_calibration_factor () const |
| Calibration factor. More... | |
Public Member Functions inherited from ossimplugins::AlosPalsarRecord | |
| AlosPalsarRecord (std::string mnemonic) | |
| virtual | ~AlosPalsarRecord () |
| AlosPalsarRecord (const AlosPalsarRecord &rhs) | |
| std::string | get_mnemonic () |
Protected Attributes | |
| double | _calibration_factor |
| Data sampling interval. More... | |
Protected Attributes inherited from ossimplugins::AlosPalsarRecord | |
| std::string | _mnemonic |
Friends | |
| std::ostream & | operator<< (std::ostream &os, const AlosPalsarRadiometricData &data) |
| This function writes the Alos Palsar radiometric data in a stream. More... | |
| std::istream & | operator>> (std::istream &is, AlosPalsarRadiometricData &data) |
| This function reads Alos Palsar radiometric data from a stream. More... | |
Definition at line 29 of file AlosPalsarRadiometricData.h.
| ossimplugins::AlosPalsarRadiometricData::AlosPalsarRadiometricData | ( | ) |
Constructor.
Definition at line 19 of file AlosPalsarRadiometricData.cpp.
Referenced by Clone(), and Instanciate().
| ossimplugins::AlosPalsarRadiometricData::AlosPalsarRadiometricData | ( | const AlosPalsarRadiometricData & | rhs | ) |
Copy constructor.
Definition at line 50 of file AlosPalsarRadiometricData.cpp.
References _calibration_factor.
inlinevirtual |
Implements ossimplugins::AlosPalsarRecord.
Definition at line 72 of file AlosPalsarRadiometricData.h.
References AlosPalsarRadiometricData().
inline |
Calibration factor.
Definition at line 96 of file AlosPalsarRadiometricData.h.
Referenced by ossimplugins::AlosPalsarLeader::saveState().
inlinevirtual |
Definition at line 64 of file AlosPalsarRadiometricData.h.
| AlosPalsarRadiometricData & ossimplugins::AlosPalsarRadiometricData::operator= | ( | const AlosPalsarRadiometricData & | rhs | ) |
Copy operator.
Definition at line 56 of file AlosPalsarRadiometricData.cpp.
inlinevirtual |
Definition at line 80 of file AlosPalsarRadiometricData.h.
inlinevirtual |
Definition at line 88 of file AlosPalsarRadiometricData.h.
friend |
Definition at line 27 of file AlosPalsarRadiometricData.cpp.
friend |
Definition at line 34 of file AlosPalsarRadiometricData.cpp.
protected |
Definition at line 99 of file AlosPalsarRadiometricData.h.
Referenced by AlosPalsarRadiometricData(), get_calibration_factor(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
