This class is able to read the ASAR AntennaElevationPatterns record. More...
#include <AntennaElevationPatterns.h>
| AntennaElevationPatterns () | |
| Constructor. More... | |
| virtual | ~AntennaElevationPatterns () |
| Destructor. More... | |
| AntennaElevationPatterns (const AntennaElevationPatterns &rhs) | |
| Copy constructor. More... | |
| AntennaElevationPatterns & | operator= (const AntennaElevationPatterns &rhs) |
| Copy operator. More... | |
| EnvisatAsarRecord * | Instanciate () |
| This function is able to create a new instance of the class. More... | |
| EnvisatAsarRecord * | Clone () |
| This function is able to create a new instance of the class initialised with the data of the calling instance. More... | |
| void | Read (std::istream &is) |
| Reads the class data from a stream. More... | |
| void | Write (std::ostream &os) |
| Writes the class to a stream. More... | |
| std::string | get_zero_doppler_time () |
| zero_doppler_time More... | |
| bool | get_attach_flag () |
| attach_flag More... | |
| std::string | get_swath () |
| swath More... | |
| float * | get_elevation_pattern () |
| Elevation Pattern. More... | |
Public Member Functions inherited from ossimplugins::EnvisatAsarRecord | |
| EnvisatAsarRecord (std::string mnemonic) | |
| virtual | ~EnvisatAsarRecord () |
| EnvisatAsarRecord (const EnvisatAsarRecord &rhs) | |
| std::string | get_mnemonic () |
| Returns the mnemonic of the record. More... | |
Public Attributes | |
| std::string | _zero_doppler_time |
| bool | _attach_flag |
| std::string | _swath |
| swath More... | |
| float | _elevation_pattern [33] |
Friends | |
| std::ostream & | operator<< (std::ostream &os, const AntennaElevationPatterns &data) |
| This function writes the AntennaElevationPatterns in a stream. More... | |
| std::istream & | operator>> (std::istream &is, AntennaElevationPatterns &data) |
| This function reads a AntennaElevationPatterns from a stream. More... | |
Protected Member Functions inherited from ossimplugins::EnvisatAsarRecord | |
| template<typename T > | |
| void | SwitchEndian (T &value) |
| This function switches the LSB value and the MSB value of the parameter. More... | |
Protected Attributes inherited from ossimplugins::EnvisatAsarRecord | |
| std::string | _mnemonic |
Definition at line 25 of file AntennaElevationPatterns.h.
| ossimplugins::AntennaElevationPatterns::AntennaElevationPatterns | ( | ) |
Constructor.
Definition at line 16 of file AntennaElevationPatterns.cpp.
Referenced by Clone(), and Instanciate().
| ossimplugins::AntennaElevationPatterns::AntennaElevationPatterns | ( | const AntennaElevationPatterns & | rhs | ) |
Copy constructor.
Definition at line 72 of file AntennaElevationPatterns.cpp.
References _elevation_pattern.
inlinevirtual |
Implements ossimplugins::EnvisatAsarRecord.
Definition at line 69 of file AntennaElevationPatterns.h.
References AntennaElevationPatterns().
inline |
attach_flag
Definition at line 101 of file AntennaElevationPatterns.h.
References _attach_flag.
inline |
Elevation Pattern.
Definition at line 115 of file AntennaElevationPatterns.h.
inline |
swath
Definition at line 108 of file AntennaElevationPatterns.h.
References _swath.
inline |
zero_doppler_time
Definition at line 94 of file AntennaElevationPatterns.h.
References _zero_doppler_time.
inlinevirtual |
Definition at line 61 of file AntennaElevationPatterns.h.
| AntennaElevationPatterns & ossimplugins::AntennaElevationPatterns::operator= | ( | const AntennaElevationPatterns & | rhs | ) |
Copy operator.
Definition at line 84 of file AntennaElevationPatterns.cpp.
References _attach_flag, _elevation_pattern, _swath, and _zero_doppler_time.
inlinevirtual |
Definition at line 77 of file AntennaElevationPatterns.h.
inlinevirtual |
Definition at line 85 of file AntennaElevationPatterns.h.
friend |
Definition at line 25 of file AntennaElevationPatterns.cpp.
friend |
Definition at line 41 of file AntennaElevationPatterns.cpp.
| bool ossimplugins::AntennaElevationPatterns::_attach_flag |
attach_flag
Definition at line 128 of file AntennaElevationPatterns.h.
Referenced by get_attach_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::AntennaElevationPatterns::_elevation_pattern[33] |
Elevation Pattern.
Definition at line 136 of file AntennaElevationPatterns.h.
Referenced by AntennaElevationPatterns(), get_elevation_pattern(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::AntennaElevationPatterns::_swath |
swath
Definition at line 132 of file AntennaElevationPatterns.h.
Referenced by get_swath(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| std::string ossimplugins::AntennaElevationPatterns::_zero_doppler_time |
zero_doppler_time
Definition at line 118 of file AntennaElevationPatterns.h.
Referenced by get_zero_doppler_time(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
