This class is able to read the SAR leader file descriptor record of the leader file. More...
#include <AlosPalsarFileDescriptor.h>
| AlosPalsarFileDescriptor () | |
| Constructor. More... | |
| virtual | ~AlosPalsarFileDescriptor () |
| Destructor. More... | |
| AlosPalsarFileDescriptor (const AlosPalsarFileDescriptor &rhs) | |
| Copy constructor. More... | |
| AlosPalsarFileDescriptor & | operator= (const AlosPalsarFileDescriptor &rhs) |
| Copy operator. More... | |
| AlosPalsarRecord * | Instanciate () |
| This function is able to create a new instance of the class. More... | |
| AlosPalsarRecord * | Clone () |
| This function is able to create a new instance of the class initialised with the data of the calling instance. More... | |
| void | Read (std::istream &is) |
| Read the class data from a stream. More... | |
| void | Write (std::ostream &os) |
| Write the class to a stream. More... | |
| std::string | get_ascii_flag () const |
| ASCII flag. More... | |
| std::string | get_continuation_flag () const |
| Continuation flag. More... | |
| std::string | get_format_doc () const |
| Format control documentation. More... | |
| std::string | get_format_ver () const |
| Format doc version. More... | |
| std::string | get_design_rev () const |
| Format doc revision. More... | |
| std::string | get_software_id () const |
| Software identifier. More... | |
| int | get_file_num () const |
| File number. More... | |
| std::string | get_file_name () const |
| File name. More... | |
| std::string | get_rec_seq () const |
| Record sequence/location flag. More... | |
| int | get_seq_loc () const |
| Sequence number location. More... | |
| int | get_seq_len () const |
| Sequence number lenght. More... | |
| std::string | get_rec_code () const |
| Record code/location flag. More... | |
| int | get_code_loc () const |
| Record code location. More... | |
| int | get_code_len () const |
| Record code length. More... | |
| std::string | get_rec_len () const |
| Record length/location flag. More... | |
| int | get_rlen_loc () const |
| Record lenght location. More... | |
| int | get_rlen_len () const |
| Record length, bytes. More... | |
| int | get_n_dataset () const |
| Number of dataset summ records. More... | |
| int | get_l_dataset () const |
| Data set summary record length, bytes. More... | |
| int | get_n_map_proj () const |
| Number of map proj records. More... | |
| int | get_l_map_proj () const |
| Map projection record length, bytes. More... | |
| int | get_n_plat_pos () const |
| Number of platform position records. More... | |
| int | get_l_plat_pos () const |
| Platform position record length, bytes. More... | |
| int | get_n_att_data () const |
| Number of attitude data records. More... | |
| int | get_l_att_data () const |
| Attitude data record length, bytes. More... | |
| int | get_n_radi_data () const |
| Number of radiometric data records. More... | |
| int | get_l_radi_data () const |
| Radiometric data record length, bytes. More... | |
| int | get_n_radi_comp () const |
| Number of radiometric compensation records. More... | |
| int | get_l_radi_comp () const |
| Radiometric compensation record length, bytes. More... | |
| int | get_n_qual_sum () const |
| Number of data quality summary records. More... | |
| int | get_l_qual_sum () const |
| Data quality summary record length, bytes. More... | |
| int | get_n_data_his () const |
| Number of data histogram records. More... | |
| int | get_l_data_his () const |
| Data histogram record length, bytes. More... | |
| int | get_n_rang_spec () const |
| Number of range spectra records. More... | |
| int | get_l_rang_spec () const |
| Range spectra record length, bytes. More... | |
| int | get_n_dem_desc () const |
| Number of DEM descriptor records. More... | |
| int | get_l_dem_desc () const |
| DEM desc record length, bytes. More... | |
| int | get_n_radar_par () const |
| Number of RADAR par records. More... | |
| int | get_l_radar_par () const |
| RADAR par record length, bytes. More... | |
| int | get_n_anno_data () const |
| Number of annotation data records. More... | |
| int | get_l_anno_data () const |
| Annotation data record length, bytes. More... | |
| int | get_n_det_proc () const |
| Number of processing parameter records. More... | |
| int | get_l_det_proc () const |
| Processing parameter record length, bytes. More... | |
| int | get_n_cal () const |
| Number of calibration records. More... | |
| int | get_l_cal () const |
| Calibration record length, bytes. More... | |
| int | get_n_gcp () const |
| Number of GCP records. More... | |
| int | get_l_gcp () const |
| GCP record length, bytes. More... | |
| int | get_n_fac_data () const |
| Number of facility data records. More... | |
| int | get_l_fac_data () const |
| Fac data record length, bytes. More... | |
| int | get_n_fac_data2 () |
| int | get_l_fac_data2 () |
| int | get_n_fac_data3 () |
| int | get_l_fac_data3 () |
| int | get_n_fac_data4 () |
| int | get_l_fac_data4 () |
| int | get_n_fac_data5 () |
| int | get_l_fac_data5 () |
| int | get_n_fac_data6 () |
| int | get_l_fac_data6 () |
| int | get_n_fac_data7 () |
| int | get_l_fac_data7 () |
| int | get_n_fac_data8 () |
| int | get_l_fac_data8 () |
| int | get_n_fac_data9 () |
| int | get_l_fac_data9 () |
| int | get_n_fac_data10 () |
| int | get_l_fac_data10 () |
| int | get_n_fac_data11 () |
| int | get_l_fac_data11 () |
Public Member Functions inherited from ossimplugins::AlosPalsarRecord | |
| AlosPalsarRecord (std::string mnemonic) | |
| virtual | ~AlosPalsarRecord () |
| AlosPalsarRecord (const AlosPalsarRecord &rhs) | |
| std::string | get_mnemonic () |
Protected Attributes | |
| std::string | _ascii_flag |
| std::string | _continuation_flag |
| std::string | _format_doc |
| std::string | _format_ver |
| std::string | _design_rev |
| std::string | _software_id |
| int | _file_num |
| std::string | _file_name |
| std::string | _rec_seq |
| int | _seq_loc |
| int | _seq_len |
| std::string | _rec_code |
| int | _code_loc |
| int | _code_len |
| std::string | _rec_len |
| int | _rlen_loc |
| int | _rlen_len |
| int | _n_dataset |
| int | _l_dataset |
| int | _n_map_proj |
| int | _l_map_proj |
| int | _n_plat_pos |
| int | _l_plat_pos |
| int | _n_att_data |
| int | _l_att_data |
| int | _n_radi_data |
| int | _l_radi_data |
| int | _n_radi_comp |
| int | _l_radi_comp |
| int | _n_qual_sum |
| int | _l_qual_sum |
| int | _n_data_his |
| int | _l_data_his |
| int | _n_rang_spec |
| int | _l_rang_spec |
| int | _n_dem_desc |
| int | _l_dem_desc |
| int | _n_radar_par |
| int | _l_radar_par |
| int | _n_anno_data |
| int | _l_anno_data |
| int | _n_det_proc |
| int | _l_det_proc |
| int | _n_cal |
| int | _l_cal |
| int | _n_gcp |
| int | _l_gcp |
| int | _n_fac_data |
| int | _l_fac_data |
| int | _n_fac_data2 |
| int | _l_fac_data2 |
| int | _n_fac_data3 |
| int | _l_fac_data3 |
| int | _n_fac_data4 |
| int | _l_fac_data4 |
| int | _n_fac_data5 |
| int | _l_fac_data5 |
| int | _n_fac_data6 |
| int | _l_fac_data6 |
| int | _n_fac_data7 |
| int | _l_fac_data7 |
| int | _n_fac_data8 |
| int | _l_fac_data8 |
| int | _n_fac_data9 |
| int | _l_fac_data9 |
| int | _n_fac_data10 |
| int | _l_fac_data10 |
| int | _n_fac_data11 |
| int | _l_fac_data11 |
Protected Attributes inherited from ossimplugins::AlosPalsarRecord | |
| std::string | _mnemonic |
Friends | |
| std::ostream & | operator<< (std::ostream &os, const AlosPalsarFileDescriptor &data) |
| This function write the AlosPalsarFileDescriptor in a stream. More... | |
| std::istream & | operator>> (std::istream &is, AlosPalsarFileDescriptor &data) |
| This function read a AlosPalsarFileDescriptor from a stream. More... | |
Definition at line 30 of file AlosPalsarFileDescriptor.h.
| ossimplugins::AlosPalsarFileDescriptor::AlosPalsarFileDescriptor | ( | ) |
Constructor.
Definition at line 19 of file AlosPalsarFileDescriptor.cpp.
Referenced by Clone(), and Instanciate().
| ossimplugins::AlosPalsarFileDescriptor::AlosPalsarFileDescriptor | ( | const AlosPalsarFileDescriptor & | rhs | ) |
Copy constructor.
Definition at line 296 of file AlosPalsarFileDescriptor.cpp.
inlinevirtual |
Implements ossimplugins::AlosPalsarRecord.
Definition at line 73 of file AlosPalsarFileDescriptor.h.
References AlosPalsarFileDescriptor().
inline |
ASCII flag.
Definition at line 97 of file AlosPalsarFileDescriptor.h.
References _ascii_flag.
inline |
Record code length.
Definition at line 191 of file AlosPalsarFileDescriptor.h.
References _code_len.
inline |
Definition at line 184 of file AlosPalsarFileDescriptor.h.
References _code_loc.
inline |
Continuation flag.
Definition at line 105 of file AlosPalsarFileDescriptor.h.
References _continuation_flag.
inline |
Definition at line 128 of file AlosPalsarFileDescriptor.h.
References _design_rev.
inline |
File name.
Definition at line 149 of file AlosPalsarFileDescriptor.h.
References _file_name.
Referenced by ossimplugins::AlosPalsarLeader::saveState().
inline |
File number.
Definition at line 142 of file AlosPalsarFileDescriptor.h.
References _file_num.
inline |
Definition at line 114 of file AlosPalsarFileDescriptor.h.
References _format_doc.
inline |
Format doc version.
Definition at line 121 of file AlosPalsarFileDescriptor.h.
References _format_ver.
inline |
Definition at line 380 of file AlosPalsarFileDescriptor.h.
References _l_anno_data.
inline |
Definition at line 268 of file AlosPalsarFileDescriptor.h.
References _l_att_data.
inline |
Definition at line 408 of file AlosPalsarFileDescriptor.h.
References _l_cal.
inline |
Definition at line 324 of file AlosPalsarFileDescriptor.h.
References _l_data_his.
inline |
Definition at line 226 of file AlosPalsarFileDescriptor.h.
References _l_dataset.
inline |
Definition at line 352 of file AlosPalsarFileDescriptor.h.
References _l_dem_desc.
inline |
Definition at line 394 of file AlosPalsarFileDescriptor.h.
References _l_det_proc.
inline |
Definition at line 436 of file AlosPalsarFileDescriptor.h.
References _l_fac_data.
inline |
Definition at line 563 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 577 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 451 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 465 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 479 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 493 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 507 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 521 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 535 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 549 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 422 of file AlosPalsarFileDescriptor.h.
References _l_gcp.
inline |
Definition at line 240 of file AlosPalsarFileDescriptor.h.
References _l_map_proj.
inline |
Definition at line 254 of file AlosPalsarFileDescriptor.h.
References _l_plat_pos.
inline |
Definition at line 310 of file AlosPalsarFileDescriptor.h.
References _l_qual_sum.
inline |
Definition at line 366 of file AlosPalsarFileDescriptor.h.
References _l_radar_par.
inline |
Definition at line 296 of file AlosPalsarFileDescriptor.h.
References _l_radi_comp.
inline |
Definition at line 282 of file AlosPalsarFileDescriptor.h.
References _l_radi_data.
inline |
Definition at line 338 of file AlosPalsarFileDescriptor.h.
References _l_rang_spec.
inline |
Definition at line 373 of file AlosPalsarFileDescriptor.h.
References _n_anno_data.
inline |
Definition at line 261 of file AlosPalsarFileDescriptor.h.
References _n_att_data.
inline |
Definition at line 401 of file AlosPalsarFileDescriptor.h.
References _n_cal.
inline |
Definition at line 317 of file AlosPalsarFileDescriptor.h.
References _n_data_his.
inline |
Definition at line 219 of file AlosPalsarFileDescriptor.h.
References _n_dataset.
inline |
Definition at line 345 of file AlosPalsarFileDescriptor.h.
References _n_dem_desc.
inline |
Definition at line 387 of file AlosPalsarFileDescriptor.h.
References _n_det_proc.
inline |
Definition at line 429 of file AlosPalsarFileDescriptor.h.
References _n_fac_data.
inline |
Definition at line 556 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 570 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 444 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 458 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 472 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 486 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 500 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 514 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 528 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 542 of file AlosPalsarFileDescriptor.h.
inline |
Definition at line 415 of file AlosPalsarFileDescriptor.h.
References _n_gcp.
inline |
Definition at line 233 of file AlosPalsarFileDescriptor.h.
References _n_map_proj.
inline |
Definition at line 247 of file AlosPalsarFileDescriptor.h.
References _n_plat_pos.
inline |
Definition at line 303 of file AlosPalsarFileDescriptor.h.
References _n_qual_sum.
inline |
Definition at line 359 of file AlosPalsarFileDescriptor.h.
References _n_radar_par.
inline |
Definition at line 289 of file AlosPalsarFileDescriptor.h.
References _n_radi_comp.
inline |
Definition at line 275 of file AlosPalsarFileDescriptor.h.
References _n_radi_data.
inline |
Definition at line 331 of file AlosPalsarFileDescriptor.h.
References _n_rang_spec.
inline |
Definition at line 177 of file AlosPalsarFileDescriptor.h.
References _rec_code.
inline |
Definition at line 198 of file AlosPalsarFileDescriptor.h.
References _rec_len.
inline |
Definition at line 156 of file AlosPalsarFileDescriptor.h.
References _rec_seq.
inline |
Definition at line 212 of file AlosPalsarFileDescriptor.h.
References _rlen_len.
inline |
Definition at line 205 of file AlosPalsarFileDescriptor.h.
References _rlen_loc.
inline |
Definition at line 170 of file AlosPalsarFileDescriptor.h.
References _seq_len.
inline |
Definition at line 163 of file AlosPalsarFileDescriptor.h.
References _seq_loc.
inline |
Definition at line 135 of file AlosPalsarFileDescriptor.h.
References _software_id.
inlinevirtual |
Definition at line 65 of file AlosPalsarFileDescriptor.h.
| AlosPalsarFileDescriptor & ossimplugins::AlosPalsarFileDescriptor::operator= | ( | const AlosPalsarFileDescriptor & | rhs | ) |
Copy operator.
Definition at line 371 of file AlosPalsarFileDescriptor.cpp.
References _ascii_flag, _code_len, _code_loc, _continuation_flag, _design_rev, _file_name, _file_num, _format_doc, _format_ver, _l_anno_data, _l_att_data, _l_cal, _l_data_his, _l_dataset, _l_dem_desc, _l_det_proc, _l_fac_data, _l_fac_data10, _l_fac_data11, _l_fac_data2, _l_fac_data3, _l_fac_data4, _l_fac_data5, _l_fac_data6, _l_fac_data7, _l_fac_data8, _l_fac_data9, _l_gcp, _l_map_proj, _l_plat_pos, _l_qual_sum, _l_radar_par, _l_radi_comp, _l_radi_data, _l_rang_spec, _n_anno_data, _n_att_data, _n_cal, _n_data_his, _n_dataset, _n_dem_desc, _n_det_proc, _n_fac_data, _n_fac_data10, _n_fac_data11, _n_fac_data2, _n_fac_data3, _n_fac_data4, _n_fac_data5, _n_fac_data6, _n_fac_data7, _n_fac_data8, _n_fac_data9, _n_gcp, _n_map_proj, _n_plat_pos, _n_qual_sum, _n_radar_par, _n_radi_comp, _n_radi_data, _n_rang_spec, _rec_code, _rec_len, _rec_seq, _rlen_len, _rlen_loc, _seq_len, _seq_loc, and _software_id.
inlinevirtual |
Definition at line 81 of file AlosPalsarFileDescriptor.h.
inlinevirtual |
Definition at line 89 of file AlosPalsarFileDescriptor.h.
friend |
Definition at line 27 of file AlosPalsarFileDescriptor.cpp.
friend |
Definition at line 101 of file AlosPalsarFileDescriptor.cpp.
protected |
ASCII flag.
Definition at line 580 of file AlosPalsarFileDescriptor.h.
Referenced by get_ascii_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Record code length.
Definition at line 640 of file AlosPalsarFileDescriptor.h.
Referenced by get_code_len(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 636 of file AlosPalsarFileDescriptor.h.
Referenced by get_code_loc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Continuation flag.
Definition at line 591 of file AlosPalsarFileDescriptor.h.
Referenced by get_continuation_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 604 of file AlosPalsarFileDescriptor.h.
Referenced by get_design_rev(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
File name.
Definition at line 616 of file AlosPalsarFileDescriptor.h.
Referenced by get_file_name(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
File number.
Definition at line 612 of file AlosPalsarFileDescriptor.h.
Referenced by get_file_num(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 596 of file AlosPalsarFileDescriptor.h.
Referenced by get_format_doc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Format doc version.
Definition at line 600 of file AlosPalsarFileDescriptor.h.
Referenced by get_format_ver(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 750 of file AlosPalsarFileDescriptor.h.
Referenced by get_l_anno_data(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 686 of file AlosPalsarFileDescriptor.h.
Referenced by get_l_att_data(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 766 of file AlosPalsarFileDescriptor.h.
Referenced by get_l_cal(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 718 of file AlosPalsarFileDescriptor.h.
Referenced by get_l_data_his(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 662 of file AlosPalsarFileDescriptor.h.
Referenced by get_l_dataset(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 734 of file AlosPalsarFileDescriptor.h.
Referenced by get_l_dem_desc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 758 of file AlosPalsarFileDescriptor.h.
Referenced by get_l_det_proc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 783 of file AlosPalsarFileDescriptor.h.
Referenced by get_l_fac_data(), get_l_fac_data10(), get_l_fac_data11(), get_l_fac_data2(), get_l_fac_data3(), get_l_fac_data4(), get_l_fac_data5(), get_l_fac_data6(), get_l_fac_data7(), get_l_fac_data8(), get_l_fac_data9(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 864 of file AlosPalsarFileDescriptor.h.
Referenced by ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 873 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 792 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 801 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 810 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 819 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 828 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 837 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 846 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 855 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 774 of file AlosPalsarFileDescriptor.h.
Referenced by get_l_gcp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 670 of file AlosPalsarFileDescriptor.h.
Referenced by get_l_map_proj(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 678 of file AlosPalsarFileDescriptor.h.
Referenced by get_l_plat_pos(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 710 of file AlosPalsarFileDescriptor.h.
Referenced by get_l_qual_sum(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 742 of file AlosPalsarFileDescriptor.h.
Referenced by get_l_radar_par(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 702 of file AlosPalsarFileDescriptor.h.
Referenced by get_l_radi_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 694 of file AlosPalsarFileDescriptor.h.
Referenced by get_l_radi_data(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 726 of file AlosPalsarFileDescriptor.h.
Referenced by get_l_rang_spec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 746 of file AlosPalsarFileDescriptor.h.
Referenced by get_n_anno_data(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 682 of file AlosPalsarFileDescriptor.h.
Referenced by get_n_att_data(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 762 of file AlosPalsarFileDescriptor.h.
Referenced by get_n_cal(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 714 of file AlosPalsarFileDescriptor.h.
Referenced by get_n_data_his(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 658 of file AlosPalsarFileDescriptor.h.
Referenced by get_n_dataset(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 730 of file AlosPalsarFileDescriptor.h.
Referenced by get_n_dem_desc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 754 of file AlosPalsarFileDescriptor.h.
Referenced by get_n_det_proc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 779 of file AlosPalsarFileDescriptor.h.
Referenced by get_n_fac_data(), get_n_fac_data10(), get_n_fac_data11(), get_n_fac_data2(), get_n_fac_data3(), get_n_fac_data4(), get_n_fac_data5(), get_n_fac_data6(), get_n_fac_data7(), get_n_fac_data8(), get_n_fac_data9(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 860 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 869 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 788 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 797 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 806 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 815 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 824 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 833 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 842 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 851 of file AlosPalsarFileDescriptor.h.
protected |
Definition at line 770 of file AlosPalsarFileDescriptor.h.
Referenced by get_n_gcp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 666 of file AlosPalsarFileDescriptor.h.
Referenced by get_n_map_proj(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 674 of file AlosPalsarFileDescriptor.h.
Referenced by get_n_plat_pos(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 706 of file AlosPalsarFileDescriptor.h.
Referenced by get_n_qual_sum(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 738 of file AlosPalsarFileDescriptor.h.
Referenced by get_n_radar_par(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 698 of file AlosPalsarFileDescriptor.h.
Referenced by get_n_radi_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 690 of file AlosPalsarFileDescriptor.h.
Referenced by get_n_radi_data(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 722 of file AlosPalsarFileDescriptor.h.
Referenced by get_n_rang_spec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 632 of file AlosPalsarFileDescriptor.h.
Referenced by get_rec_code(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 644 of file AlosPalsarFileDescriptor.h.
Referenced by get_rec_len(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 620 of file AlosPalsarFileDescriptor.h.
Referenced by get_rec_seq(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 652 of file AlosPalsarFileDescriptor.h.
Referenced by get_rlen_len(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 648 of file AlosPalsarFileDescriptor.h.
Referenced by get_rlen_loc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 628 of file AlosPalsarFileDescriptor.h.
Referenced by get_seq_len(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 624 of file AlosPalsarFileDescriptor.h.
Referenced by get_seq_loc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 608 of file AlosPalsarFileDescriptor.h.
Referenced by get_software_id(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
