This class is able to read a Radiometric Compensation data record. More...
#include <RadiometricCompensationData.h>
| RadiometricCompensationData () | |
| Constructor. More... | |
| ~RadiometricCompensationData () | |
| Destructor. More... | |
| RadiometricCompensationData (const RadiometricCompensationData &rhs) | |
| Copy constructor. More... | |
| RadiometricCompensationData & | operator= (const RadiometricCompensationData &rhs) |
| Copy operator. More... | |
| RadarSatRecord * | Instanciate () |
| This function is able to create a new instance of the class. More... | |
| RadarSatRecord * | Clone () |
| This function is able to create a new instance of the class initialised with the data of the calling instance. More... | |
| void | Read (std::istream &is) |
| Reads the class data from a stream. More... | |
| void | Write (std::ostream &os) |
| Writes the class to a stream. More... | |
| int | get_seq_num () |
| Record sequence number. More... | |
| int | get_chan_ind () |
| SAR channel indicator. More... | |
| int | get_n_dset () |
Number of data sets in record More... | |
| int | get_dset_size () |
Compensation data set size More... | |
| CompensationDataRecord * | get_dset () |
| Compensation data set records. More... | |
Public Member Functions inherited from ossimplugins::RadarSatRecord | |
| RadarSatRecord (std::string mnemonic) | |
| virtual | ~RadarSatRecord () |
| RadarSatRecord (const RadarSatRecord &rhs) | |
| std::string | get_mnemonic () |
Protected Attributes | |
| int | _seq_num |
| int | _chan_ind |
| int | _n_dset |
| int | _dset_size |
| CompensationDataRecord | _dset [4] |
Protected Attributes inherited from ossimplugins::RadarSatRecord | |
| std::string | _mnemonic |
Friends | |
| std::ostream & | operator<< (std::ostream &os, const RadiometricCompensationData &data) |
| This function writes the RadiometricCompensationData in a stream. More... | |
| std::istream & | operator>> (std::istream &is, RadiometricCompensationData &data) |
| This function reads a RadiometricCompensationData from a stream. More... | |
Definition at line 28 of file RadiometricCompensationData.h.
| ossimplugins::RadiometricCompensationData::RadiometricCompensationData | ( | ) |
Constructor.
Definition at line 16 of file RadiometricCompensationData.cpp.
Referenced by Clone(), and Instanciate().
| ossimplugins::RadiometricCompensationData::~RadiometricCompensationData | ( | ) |
| ossimplugins::RadiometricCompensationData::RadiometricCompensationData | ( | const RadiometricCompensationData & | rhs | ) |
Copy constructor.
Definition at line 70 of file RadiometricCompensationData.cpp.
References _chan_ind, _dset, _dset_size, _n_dset, and _seq_num.
inlinevirtual |
Implements ossimplugins::RadarSatRecord.
Definition at line 71 of file RadiometricCompensationData.h.
References RadiometricCompensationData().
inline |
Definition at line 102 of file RadiometricCompensationData.h.
References _chan_ind.
inline |
Definition at line 123 of file RadiometricCompensationData.h.
References _dset.
inline |
Definition at line 116 of file RadiometricCompensationData.h.
References _dset_size.
inline |
Definition at line 109 of file RadiometricCompensationData.h.
References _n_dset.
inline |
Definition at line 95 of file RadiometricCompensationData.h.
References _seq_num.
inlinevirtual |
Definition at line 63 of file RadiometricCompensationData.h.
| RadiometricCompensationData & ossimplugins::RadiometricCompensationData::operator= | ( | const RadiometricCompensationData & | rhs | ) |
Copy operator.
Definition at line 87 of file RadiometricCompensationData.cpp.
inlinevirtual |
Definition at line 79 of file RadiometricCompensationData.h.
inlinevirtual |
Definition at line 87 of file RadiometricCompensationData.h.
friend |
Definition at line 24 of file RadiometricCompensationData.cpp.
friend |
Definition at line 41 of file RadiometricCompensationData.cpp.
protected |
Definition at line 136 of file RadiometricCompensationData.h.
Referenced by get_chan_ind(), ossimplugins::operator<<(), ossimplugins::operator>>(), and RadiometricCompensationData().
protected |
Definition at line 148 of file RadiometricCompensationData.h.
Referenced by get_dset(), ossimplugins::operator<<(), ossimplugins::operator>>(), and RadiometricCompensationData().
protected |
Definition at line 144 of file RadiometricCompensationData.h.
Referenced by get_dset_size(), ossimplugins::operator<<(), ossimplugins::operator>>(), and RadiometricCompensationData().
protected |
Definition at line 140 of file RadiometricCompensationData.h.
Referenced by get_n_dset(), ossimplugins::operator<<(), ossimplugins::operator>>(), and RadiometricCompensationData().
protected |
Definition at line 126 of file RadiometricCompensationData.h.
Referenced by get_seq_num(), ossimplugins::operator<<(), ossimplugins::operator>>(), and RadiometricCompensationData().
