This class is able to read the SAR leader data set summary record of the leader file. More...
#include <AlosPalsarFacilityData.h>
| AlosPalsarFacilityData () | |
| Constructor. More... | |
| virtual | ~AlosPalsarFacilityData () |
| Destructor. More... | |
| AlosPalsarFacilityData (const AlosPalsarFacilityData &rhs) | |
| Copy constructor. More... | |
| AlosPalsarFacilityData & | operator= (const AlosPalsarFacilityData &rhs) |
| Copy operator. More... | |
| AlosPalsarRecord * | Instanciate () |
| This function is able to create a new instance of the class. More... | |
| AlosPalsarRecord * | Clone () |
| This function is able to create a new instance of the class initialised with the data of the calling instance. More... | |
| void | Read (std::istream &is) |
| Read the class data from a stream. More... | |
| void | Write (std::ostream &os) |
| Write the class to a stream. More... | |
| std::string | get_name_of_facil_rec () const |
| name_of_facil_rec More... | |
| std::string | get_last_release_qc_date () const |
| last_release_qc_date More... | |
| std::string | get_last_release_cal_date () const |
| last_release_cal_date More... | |
| int | get_qa_summary_flag () const |
| qa_summary_flag More... | |
| int | get_prf_code_change_flag () const |
| prf_code_change_flag More... | |
| int | get_sampling_win_change_flag () const |
| sampling_win_change_flag More... | |
| int | get_cal_gain_change_flag () const |
| cal_gain_change_flag More... | |
| int | get_quirp_qu_flag () const |
| quirp_qu_flag More... | |
| int | get_inp_data_stat_flag () const |
| inp_data_stat_flag More... | |
| int | get_dopp_cent_conf_meas_flag () const |
| dopp_cent_conf_meas_flag More... | |
| int | get_dopp_cent_val_flag () const |
| dopp_cent_val_flag More... | |
| int | get_dopp_ambig_conf_meas_flag () const |
| dopp_ambig_conf_meas_flag More... | |
| int | get_outp_data_mean_flag () const |
| outp_data_mean_flag More... | |
| int | get_OGOB_flag () |
| OGOB_flag. More... | |
| int | get_PRF_changes () |
| PRF_changes. More... | |
| int | get_sampling_win_changes () const |
| sampling_win_changes More... | |
| int | get_cal_gain_changes () const |
| cal_gain_changes More... | |
| int | get_missing_lines () const |
| missing_lines More... | |
| int | get_rec_gain_changes () const |
| rec_gain_changes More... | |
| double | get_pulse_width_of_ACF_3db () |
| pulse_width_of_ACF_3db More... | |
| double | get_first_side_lobe_lev_of_ACF () |
| first_side_lobe_lev_of_ACF More... | |
| double | get_ISLR_of_ACF () |
| ISLR_of_ACF. More... | |
| double | get_dopp_cent_conf_meas () const |
| dopp_cent_conf_meas More... | |
| double | get_dopp_ambig_conf_meas () const |
| dopp_ambig_conf_meas More... | |
| double | get_inp_data_I_mean () |
| inp_data_I_mean More... | |
| double | get_inp_data_Q_mean () |
| inp_data_Q_mean More... | |
| double | get_inp_data_I_stddev () |
| inp_data_I_stddev More... | |
| double | get_inp_data_Q_stddev () |
| inp_data_Q_stddev More... | |
| double | get_cal_sys_gain () const |
| cal_sys_gain More... | |
| double | get_first_rec_gain_read () const |
| first_rec_gain_read More... | |
| double | get_dopp_ambig_num () const |
| dopp_ambig_num More... | |
| double | get_I_channel_bias_correction () |
| I_channel_bias_correction. More... | |
| double | get_Q_channel_bias_correction () |
| Q_channel_bias_correction. More... | |
| double | get_I_channel_gain_correction () |
| I_channel_gain_correction. More... | |
| double | get_Q_channel_gain_correction () |
| Q_channel_gain_correction. More... | |
| double | get_Q_channel_I_Q_correction () |
| Q_channel_I_Q_correction. More... | |
| double | get_noise_power () const |
| noise_power More... | |
| int | get_int_cal_utc () const |
| int_cal_utc More... | |
| int | get_num_valid_cal_pulses () const |
| num_valid_cal_pulses More... | |
| int | get_num_valid_noise_pulses () const |
| num_valid_noise_pulses More... | |
| int | get_num_valid_replicas () const |
| num_valid_replicas More... | |
| double | get_first_replica_sample () const |
| first_replica_sample More... | |
| double | get_mean_cal_pulse_power () const |
| mean_cal_pulse_power More... | |
| double | get_mean_noise_power () const |
| mean_noise_power More... | |
| double | get_range_comp_norm_fact () const |
| range_comp_norm_fact More... | |
| double | get_replica_power () const |
| replica_power More... | |
| double | get_first_range_pixel_mid_az_inc () const |
| first_range_pixel_mid_az_inc More... | |
| double | get_center_range_pix_mid_az_inc () const |
| center_range_pix_mid_az_inc More... | |
| double | get_last_range_pix_mid_az_inc () const |
| last_range_pix_mid_az_inc More... | |
| double | get_norm_ref_range_ro () const |
| norm_ref_range_ro More... | |
| int | get_antenna_elev_flag () const |
| antenna_elev_flag More... | |
| double | get_abs_cal_const_K () |
| abs_cal_const_K More... | |
| double | get_upp_bound_K () |
| upp_bound_K More... | |
| double | get_low_bound_K () |
| low_bound_K More... | |
| double | get_proc_noise_scale_fact () const |
| proc_noise_scale_fact More... | |
| std::string | get_K_gen_date () |
| K_gen_date. More... | |
| std::string | get_K_vers_num () |
| K_vers_num. More... | |
| int | get_num_duplic_input_lines () const |
| num_duplic_input_lines More... | |
| double | get_estim_bit_error_rate () const |
| estim_bit_error_rate More... | |
| double | get_out_image_mean () const |
| out_image_mean More... | |
| double | get_out_image_std_dev () const |
| out_image_std_dev More... | |
| double | get_out_image_max_value () const |
| out_image_max_value More... | |
| std::string | get_time_raw_data_first_input () const |
| time_raw_data_first_input More... | |
| std::string | get_time_asc_node_state_vectors () const |
| time_asc_node_state_vectors More... | |
| std::string | get_asc_node_pos_X_comp () |
| asc_node_pos_X_comp More... | |
| std::string | get_asc_node_pos_Y_comp () |
| asc_node_pos_Y_comp More... | |
| std::string | get_asc_node_pos_Z_comp () |
| asc_node_pos_Z_comp More... | |
| std::string | get_asc_node_vel_X_comp () |
| asc_node_vel_X_comp More... | |
| std::string | get_asc_node_vel_Y_comp () |
| asc_node_vel_Y_comp More... | |
| std::string | get_asc_node_vel_Z_comp () |
| asc_node_vel_Z_comp More... | |
| int | get_out_pixel_bit_length () const |
| out_pixel_bit_length More... | |
| double | get_proc_gain_param_1 () |
| proc_gain_param_1 More... | |
| double | get_proc_gain_param_2 () |
| proc_gain_param_2 More... | |
| double | get_proc_gain_param_3 () |
| proc_gain_param_3 More... | |
| int | get_peak_loc_cross_correl_fun () const |
| peak_loc_cross_correl_fun More... | |
| double | get_3_dB_width_CCF () |
| 3_dB_width_CCF More... | |
| double | get_first_side_lobe_level () const |
| first_side_lobe_level More... | |
| double | get_ISLR_CCF_between_last () |
| ISLR_CCF_between_last. More... | |
| int | get_peak_loc_CCF_betw_last () |
| peak_loc_CCF_betw_last More... | |
| int | get_Roll_Tilt_Mode_flag () |
| Roll_Tilt_Mode_flag. More... | |
| int | get_raw_data_correction_flag () const |
| raw_data_correction_flag More... | |
| int | get_look_detecion_flag () const |
| look_detecion_flag More... | |
| int | get_doppler_ambiguity_estimat_flag () const |
| doppler_ambiguity_estimat_flag More... | |
| int | get_azimuth_baseband_convers_flag () const |
| azimuth_baseband_convers_flag More... | |
| int | get_samples_per_line_used () const |
| samples_per_line_used More... | |
| int | get_range_lines_skip_factor () const |
| range_lines_skip_factor More... | |
| std::string | get_time_of_inp_state_vectors () const |
| time_of_inp_state_vectors More... | |
| std::string | get_inp_state_vect_pos_X_comp () |
| inp_state_vect_pos_X_comp More... | |
| std::string | get_inp_state_vect_pos_Y_comp () |
| inp_state_vect_pos_Y_comp More... | |
| std::string | get_inp_state_vect_pos_Z_comp () |
| inp_state_vect_pos_Z_comp More... | |
| std::string | get_inp_state_vect_vel_Vx_comp () |
| inp_state_vect_vel_Vx_comp More... | |
| std::string | get_inp_state_vect_vel_Vy_comp () |
| inp_state_vect_vel_Vy_comp More... | |
| std::string | get_inp_state_vect_vel_Vz_comp () |
| inp_state_vect_vel_Vz_comp More... | |
| int | get_inp_state_vector_type_flag () const |
| inp_state_vector_type_flag More... | |
| double | get_win_coeff_for_range_match () const |
| win_coeff_for_range_match More... | |
| double | get_win_coeff_for_azi_match () const |
| win_coeff_for_azi_match More... | |
| int | get_update_period_range_match () const |
| update_period_range_match More... | |
| double | get_look_scalar_gain_1 () |
| look_scalar_gain_1 More... | |
| double | get_look_scalar_gain_2 () |
| look_scalar_gain_2 More... | |
| double | get_look_scalar_gain_3 () |
| look_scalar_gain_3 More... | |
| double | get_look_scalar_gain_4 () |
| look_scalar_gain_4 More... | |
| double | get_look_scalar_gain_5 () |
| look_scalar_gain_5 More... | |
| double | get_look_scalar_gain_6 () |
| look_scalar_gain_6 More... | |
| double | get_look_scalar_gain_7 () |
| look_scalar_gain_7 More... | |
| double | get_look_scalar_gain_8 () |
| look_scalar_gain_8 More... | |
| int | get_samp_window_start_time_bias () const |
| samp_window_start_time_bias More... | |
| double | get_doppler_centroid_cubic_coeff () const |
| doppler_centroid_cubic_coeff More... | |
| int | get_PRF_code_first_range_line () |
| PRF_code_first_range_line. More... | |
| int | get_PRF_code_last_range_line () |
| PRF_code_last_range_line. More... | |
| int | get_samp_win_start_first () const |
| samp_win_start_first More... | |
| int | get_samp_win_start_last () const |
| samp_win_start_last More... | |
| int | get_cal_syst_gain_last_proc () const |
| cal_syst_gain_last_proc More... | |
| int | get_receiver_gain_last_proc () const |
| receiver_gain_last_proc More... | |
| int | get_first_processed_range_sample () const |
| first_processed_range_sample More... | |
| int | get_azimuth_FFT_IFFT_ratio () |
| azimuth_FFT_IFFT_ratio More... | |
| int | get_num_azimuth_blocks_proc () const |
| num_azimuth_blocks_proc More... | |
| int | get_num_input_raw_data_lines () const |
| num_input_raw_data_lines More... | |
| int | get_initial_doppler_ambiguity_num () const |
| initial_doppler_ambiguity_num More... | |
| double | get_thresh_no_1_flag () |
| thresh_no_1_flag More... | |
| double | get_thresh_no_2_flag () |
| thresh_no_2_flag More... | |
| double | get_thresh_no_3_flag () |
| thresh_no_3_flag More... | |
| double | get_thresh_no_4_flag () |
| thresh_no_4_flag More... | |
| double | get_thresh_no_5_flag () |
| thresh_no_5_flag More... | |
| double | get_thresh_no_6_flag () |
| thresh_no_6_flag More... | |
| double | get_thresh_no_7_flag () |
| thresh_no_7_flag More... | |
| double | get_thresh_no_8_flag () |
| thresh_no_8_flag More... | |
| double | get_thresh_no_9_flag () |
| thresh_no_9_flag More... | |
| double | get_thresh_no_10_flag () |
| thresh_no_10_flag More... | |
| double | get_thresh_no_11_flag () |
| thresh_no_11_flag More... | |
| int | get_sat_binary_time_of_first () const |
| sat_binary_time_of_first More... | |
| int | get_num_valid_pixels_per_range () const |
| num_valid_pixels_per_range More... | |
| int | get_num_range_samp_discarded () const |
| num_range_samp_discarded More... | |
| double | get_I_gain_imb_lower_bound () |
| I_gain_imb_lower_bound. More... | |
| double | get_I_gain_imb_upper_bound () |
| I_gain_imb_upper_bound. More... | |
| double | get_I_Q_quad_depar_lower_bound () |
| I_Q_quad_depar_lower_bound. More... | |
| double | get_I_Q_quad_depar_upper_bound () |
| I_Q_quad_depar_upper_bound. More... | |
| double | get_3_dB_look_bandwidth () |
| 3_dB_look_bandwidth More... | |
| double | get_3_dB_look_proc_dopp_bandw () |
| 3_dB_look_proc_dopp_bandw More... | |
| int | get_range_spread_loss_comp_flag () const |
| range_spread_loss_comp_flag More... | |
| bool | get_datation_flag () const |
| datation_flag More... | |
| int | get_max_error_range_line_timing () const |
| max_error_range_line_timing More... | |
| int | get_form_num_range_line_used () const |
| form_num_range_line_used More... | |
| bool | get_autom_look_scal_gain_flag () const |
| autom_look_scal_gain_flag More... | |
| int | get_max_value_look_scalar_gain () const |
| max_value_look_scalar_gain More... | |
| int | get_replica_norm_method_flag () const |
| replica_norm_method_flag More... | |
| double | get_coef_ground_range_1 () const |
| coef_ground_range_1 More... | |
| double | get_coef_ground_range_2 () const |
| coef_ground_range_2 More... | |
| double | get_coef_ground_range_3 () const |
| coef_ground_range_3 More... | |
| double | get_coef_ground_range_4 () const |
| coef_ground_range_4 More... | |
| double | get_coef_ant_elev_1 () const |
| coef_ant_elev_1 More... | |
| double | get_coef_ant_elev_2 () const |
| coef_ant_elev_2 More... | |
| double | get_coef_ant_elev_3 () const |
| coef_ant_elev_3 More... | |
| double | get_coef_ant_elev_4 () const |
| coef_ant_elev_4 More... | |
| double | get_coef_ant_elev_5 () const |
| coef_ant_elev_5 More... | |
| double | get_range_time_origin_ant () const |
| range_time_origin_ant More... | |
Public Member Functions inherited from ossimplugins::AlosPalsarRecord | |
| AlosPalsarRecord (std::string mnemonic) | |
| virtual | ~AlosPalsarRecord () |
| AlosPalsarRecord (const AlosPalsarRecord &rhs) | |
| std::string | get_mnemonic () |
Protected Attributes | |
| std::string | _name_of_facil_rec |
| std::string | _last_release_qc_date |
| std::string | _last_release_cal_date |
| int | _qa_summary_flag |
| int | _prf_code_change_flag |
| int | _sampling_win_change_flag |
| int | _cal_gain_change_flag |
| int | _quirp_qu_flag |
| int | _inp_data_stat_flag |
| int | _dopp_cent_conf_meas_flag |
| int | _dopp_cent_val_flag |
| int | _dopp_ambig_conf_meas_flag |
| int | _outp_data_mean_flag |
| int | _OGOB_flag |
| int | _PRF_changes |
| int | _sampling_win_changes |
| int | _cal_gain_changes |
| int | _missing_lines |
| int | _rec_gain_changes |
| double | _pulse_width_of_ACF_3db |
| double | _first_side_lobe_lev_of_ACF |
| double | _ISLR_of_ACF |
| double | _dopp_cent_conf_meas |
| double | _dopp_ambig_conf_meas |
| double | _inp_data_I_mean |
| double | _inp_data_Q_mean |
| double | _inp_data_I_stddev |
| double | _inp_data_Q_stddev |
| double | _cal_sys_gain |
| double | _first_rec_gain_read |
| double | _dopp_ambig_num |
| double | _I_channel_bias_correction |
| double | _Q_channel_bias_correction |
| double | _I_channel_gain_correction |
| double | _Q_channel_gain_correction |
| double | _Q_channel_I_Q_correction |
| double | _noise_power |
| int | _int_cal_utc |
| int | _num_valid_cal_pulses |
| int | _num_valid_noise_pulses |
| int | _num_valid_replicas |
| double | _first_replica_sample |
| double | _mean_cal_pulse_power |
| double | _mean_noise_power |
| double | _range_comp_norm_fact |
| double | _replica_power |
| double | _first_range_pixel_mid_az_inc |
| double | _center_range_pix_mid_az_inc |
| double | _last_range_pix_mid_az_inc |
| double | _norm_ref_range_ro |
| int | _antenna_elev_flag |
| double | _abs_cal_const_K |
| double | _upp_bound_K |
| double | _low_bound_K |
| double | _proc_noise_scale_fact |
| std::string | _K_gen_date |
| std::string | _K_vers_num |
| int | _num_duplic_input_lines |
| double | _estim_bit_error_rate |
| double | _out_image_mean |
| double | _out_image_std_dev |
| double | _out_image_max_value |
| std::string | _time_raw_data_first_input |
| std::string | _time_asc_node_state_vectors |
| std::string | _asc_node_pos_X_comp |
| std::string | _asc_node_pos_Y_comp |
| std::string | _asc_node_pos_Z_comp |
| std::string | _asc_node_vel_X_comp |
| std::string | _asc_node_vel_Y_comp |
| std::string | _asc_node_vel_Z_comp |
| int | _out_pixel_bit_length |
| double | _proc_gain_param_1 |
| double | _proc_gain_param_2 |
| double | _proc_gain_param_3 |
| int | _peak_loc_cross_correl_fun |
| double | _3_dB_width_CCF |
| double | _first_side_lobe_level |
| double | _ISLR_CCF_between_last |
| int | _peak_loc_CCF_betw_last |
| int | _Roll_Tilt_Mode_flag |
| int | _raw_data_correction_flag |
| int | _look_detecion_flag |
| int | _doppler_ambiguity_estimat_flag |
| int | _azimuth_baseband_convers_flag |
| int | _samples_per_line_used |
| int | _range_lines_skip_factor |
| std::string | _time_of_inp_state_vectors |
| std::string | _inp_state_vect_pos_X_comp |
| std::string | _inp_state_vect_pos_Y_comp |
| std::string | _inp_state_vect_pos_Z_comp |
| std::string | _inp_state_vect_vel_Vx_comp |
| std::string | _inp_state_vect_vel_Vy_comp |
| std::string | _inp_state_vect_vel_Vz_comp |
| int | _inp_state_vector_type_flag |
| double | _win_coeff_for_range_match |
| double | _win_coeff_for_azi_match |
| int | _update_period_range_match |
| double | _look_scalar_gain_1 |
| double | _look_scalar_gain_2 |
| double | _look_scalar_gain_3 |
| double | _look_scalar_gain_4 |
| double | _look_scalar_gain_5 |
| double | _look_scalar_gain_6 |
| double | _look_scalar_gain_7 |
| double | _look_scalar_gain_8 |
| int | _samp_window_start_time_bias |
| double | _doppler_centroid_cubic_coeff |
| int | _PRF_code_first_range_line |
| int | _PRF_code_last_range_line |
| int | _samp_win_start_first |
| int | _samp_win_start_last |
| int | _cal_syst_gain_last_proc |
| int | _receiver_gain_last_proc |
| int | _first_processed_range_sample |
| int | _azimuth_FFT_IFFT_ratio |
| int | _num_azimuth_blocks_proc |
| int | _num_input_raw_data_lines |
| int | _initial_doppler_ambiguity_num |
| double | _thresh_no_1_flag |
| double | _thresh_no_2_flag |
| double | _thresh_no_3_flag |
| double | _thresh_no_4_flag |
| double | _thresh_no_5_flag |
| double | _thresh_no_6_flag |
| double | _thresh_no_7_flag |
| double | _thresh_no_8_flag |
| double | _thresh_no_9_flag |
| double | _thresh_no_10_flag |
| double | _thresh_no_11_flag |
| int | _sat_binary_time_of_first |
| int | _num_valid_pixels_per_range |
| int | _num_range_samp_discarded |
| double | _I_gain_imb_lower_bound |
| double | _I_gain_imb_upper_bound |
| double | _I_Q_quad_depar_lower_bound |
| double | _I_Q_quad_depar_upper_bound |
| double | _3_dB_look_bandwidth |
| double | _3_dB_look_proc_dopp_bandw |
| int | _range_spread_loss_comp_flag |
| bool | _datation_flag |
| int | _max_error_range_line_timing |
| int | _form_num_range_line_used |
| bool | _autom_look_scal_gain_flag |
| int | _max_value_look_scalar_gain |
| int | _replica_norm_method_flag |
| double | _coef_ground_range_1 |
| double | _coef_ground_range_2 |
| double | _coef_ground_range_3 |
| double | _coef_ground_range_4 |
| double | _coef_ant_elev_1 |
| double | _coef_ant_elev_2 |
| double | _coef_ant_elev_3 |
| double | _coef_ant_elev_4 |
| double | _coef_ant_elev_5 |
| double | _range_time_origin_ant |
Protected Attributes inherited from ossimplugins::AlosPalsarRecord | |
| std::string | _mnemonic |
Friends | |
| std::ostream & | operator<< (std::ostream &os, const AlosPalsarFacilityData &data) |
| This function write the AlosPalsarFacilityData in a stream. More... | |
| std::istream & | operator>> (std::istream &is, AlosPalsarFacilityData &data) |
| This function read a AlosPalsarFacilityData from a stream. More... | |
Definition at line 28 of file AlosPalsarFacilityData.h.
| ossimplugins::AlosPalsarFacilityData::AlosPalsarFacilityData | ( | ) |
Constructor.
Definition at line 18 of file AlosPalsarFacilityData.cpp.
Referenced by Clone(), and Instanciate().
| ossimplugins::AlosPalsarFacilityData::AlosPalsarFacilityData | ( | const AlosPalsarFacilityData & | rhs | ) |
Copy constructor.
Definition at line 850 of file AlosPalsarFacilityData.cpp.
inlinevirtual |
Implements ossimplugins::AlosPalsarRecord.
Definition at line 72 of file AlosPalsarFacilityData.h.
References AlosPalsarFacilityData().
inline |
3_dB_look_bandwidth
Definition at line 1049 of file AlosPalsarFacilityData.h.
References _3_dB_look_bandwidth.
inline |
Definition at line 1056 of file AlosPalsarFacilityData.h.
References _3_dB_look_proc_dopp_bandw.
inline |
3_dB_width_CCF
Definition at line 622 of file AlosPalsarFacilityData.h.
References _3_dB_width_CCF.
inline |
abs_cal_const_K
Definition at line 454 of file AlosPalsarFacilityData.h.
References _abs_cal_const_K.
inline |
antenna_elev_flag
Definition at line 447 of file AlosPalsarFacilityData.h.
References _antenna_elev_flag.
inline |
asc_node_pos_X_comp
Definition at line 545 of file AlosPalsarFacilityData.h.
References _asc_node_pos_X_comp.
inline |
asc_node_pos_Y_comp
Definition at line 552 of file AlosPalsarFacilityData.h.
References _asc_node_pos_Y_comp.
inline |
asc_node_pos_Z_comp
Definition at line 559 of file AlosPalsarFacilityData.h.
References _asc_node_pos_Z_comp.
inline |
asc_node_vel_X_comp
Definition at line 566 of file AlosPalsarFacilityData.h.
References _asc_node_vel_X_comp.
inline |
asc_node_vel_Y_comp
Definition at line 573 of file AlosPalsarFacilityData.h.
References _asc_node_vel_Y_comp.
inline |
asc_node_vel_Z_comp
Definition at line 580 of file AlosPalsarFacilityData.h.
References _asc_node_vel_Z_comp.
inline |
Definition at line 1091 of file AlosPalsarFacilityData.h.
References _autom_look_scal_gain_flag.
inline |
Definition at line 678 of file AlosPalsarFacilityData.h.
References _azimuth_baseband_convers_flag.
inline |
Definition at line 895 of file AlosPalsarFacilityData.h.
References _azimuth_FFT_IFFT_ratio.
inline |
Definition at line 139 of file AlosPalsarFacilityData.h.
References _cal_gain_change_flag.
inline |
cal_gain_changes
Definition at line 209 of file AlosPalsarFacilityData.h.
References _cal_gain_changes.
inline |
cal_sys_gain
Definition at line 293 of file AlosPalsarFacilityData.h.
References _cal_sys_gain.
inline |
Definition at line 874 of file AlosPalsarFacilityData.h.
References _cal_syst_gain_last_proc.
inline |
Definition at line 426 of file AlosPalsarFacilityData.h.
References _center_range_pix_mid_az_inc.
inline |
coef_ant_elev_1
Definition at line 1140 of file AlosPalsarFacilityData.h.
References _coef_ant_elev_1.
inline |
coef_ant_elev_2
Definition at line 1147 of file AlosPalsarFacilityData.h.
References _coef_ant_elev_2.
inline |
coef_ant_elev_3
Definition at line 1154 of file AlosPalsarFacilityData.h.
References _coef_ant_elev_3.
inline |
coef_ant_elev_4
Definition at line 1161 of file AlosPalsarFacilityData.h.
References _coef_ant_elev_4.
inline |
coef_ant_elev_5
Definition at line 1168 of file AlosPalsarFacilityData.h.
References _coef_ant_elev_5.
inline |
coef_ground_range_1
Definition at line 1112 of file AlosPalsarFacilityData.h.
References _coef_ground_range_1.
inline |
coef_ground_range_2
Definition at line 1119 of file AlosPalsarFacilityData.h.
References _coef_ground_range_2.
inline |
coef_ground_range_3
Definition at line 1126 of file AlosPalsarFacilityData.h.
References _coef_ground_range_3.
inline |
coef_ground_range_4
Definition at line 1133 of file AlosPalsarFacilityData.h.
References _coef_ground_range_4.
inline |
datation_flag
Definition at line 1070 of file AlosPalsarFacilityData.h.
References _datation_flag.
inline |
Definition at line 258 of file AlosPalsarFacilityData.h.
References _dopp_ambig_conf_meas.
inline |
Definition at line 174 of file AlosPalsarFacilityData.h.
References _dopp_ambig_conf_meas_flag.
inline |
dopp_ambig_num
Definition at line 307 of file AlosPalsarFacilityData.h.
References _dopp_ambig_num.
inline |
dopp_cent_conf_meas
Definition at line 251 of file AlosPalsarFacilityData.h.
References _dopp_cent_conf_meas.
inline |
Definition at line 160 of file AlosPalsarFacilityData.h.
References _dopp_cent_conf_meas_flag.
inline |
dopp_cent_val_flag
Definition at line 167 of file AlosPalsarFacilityData.h.
References _dopp_cent_val_flag.
inline |
Definition at line 671 of file AlosPalsarFacilityData.h.
References _doppler_ambiguity_estimat_flag.
inline |
Definition at line 839 of file AlosPalsarFacilityData.h.
References _doppler_centroid_cubic_coeff.
inline |
Definition at line 503 of file AlosPalsarFacilityData.h.
References _estim_bit_error_rate.
inline |
Definition at line 888 of file AlosPalsarFacilityData.h.
References _first_processed_range_sample.
inline |
Definition at line 419 of file AlosPalsarFacilityData.h.
References _first_range_pixel_mid_az_inc.
inline |
first_rec_gain_read
Definition at line 300 of file AlosPalsarFacilityData.h.
References _first_rec_gain_read.
inline |
Definition at line 384 of file AlosPalsarFacilityData.h.
References _first_replica_sample.
inline |
Definition at line 237 of file AlosPalsarFacilityData.h.
References _first_side_lobe_lev_of_ACF.
inline |
Definition at line 629 of file AlosPalsarFacilityData.h.
References _first_side_lobe_level.
inline |
Definition at line 1084 of file AlosPalsarFacilityData.h.
References _form_num_range_line_used.
inline |
Definition at line 314 of file AlosPalsarFacilityData.h.
References _I_channel_bias_correction.
inline |
Definition at line 328 of file AlosPalsarFacilityData.h.
References _I_channel_gain_correction.
inline |
Definition at line 1021 of file AlosPalsarFacilityData.h.
References _I_gain_imb_lower_bound.
inline |
Definition at line 1028 of file AlosPalsarFacilityData.h.
References _I_gain_imb_upper_bound.
inline |
Definition at line 1035 of file AlosPalsarFacilityData.h.
References _I_Q_quad_depar_lower_bound.
inline |
Definition at line 1042 of file AlosPalsarFacilityData.h.
References _I_Q_quad_depar_upper_bound.
inline |
Definition at line 916 of file AlosPalsarFacilityData.h.
References _initial_doppler_ambiguity_num.
inline |
inp_data_I_mean
Definition at line 265 of file AlosPalsarFacilityData.h.
References _inp_data_I_mean.
inline |
inp_data_I_stddev
Definition at line 279 of file AlosPalsarFacilityData.h.
References _inp_data_I_stddev.
inline |
inp_data_Q_mean
Definition at line 272 of file AlosPalsarFacilityData.h.
References _inp_data_Q_mean.
inline |
inp_data_Q_stddev
Definition at line 286 of file AlosPalsarFacilityData.h.
References _inp_data_Q_stddev.
inline |
inp_data_stat_flag
Definition at line 153 of file AlosPalsarFacilityData.h.
References _inp_data_stat_flag.
inline |
Definition at line 706 of file AlosPalsarFacilityData.h.
References _inp_state_vect_pos_X_comp.
inline |
Definition at line 713 of file AlosPalsarFacilityData.h.
References _inp_state_vect_pos_Y_comp.
inline |
Definition at line 720 of file AlosPalsarFacilityData.h.
References _inp_state_vect_pos_Z_comp.
inline |
Definition at line 727 of file AlosPalsarFacilityData.h.
References _inp_state_vect_vel_Vx_comp.
inline |
Definition at line 734 of file AlosPalsarFacilityData.h.
References _inp_state_vect_vel_Vy_comp.
inline |
Definition at line 741 of file AlosPalsarFacilityData.h.
References _inp_state_vect_vel_Vz_comp.
inline |
Definition at line 748 of file AlosPalsarFacilityData.h.
References _inp_state_vector_type_flag.
inline |
int_cal_utc
Definition at line 356 of file AlosPalsarFacilityData.h.
References _int_cal_utc.
inline |
Definition at line 636 of file AlosPalsarFacilityData.h.
References _ISLR_CCF_between_last.
inline |
ISLR_of_ACF.
Definition at line 244 of file AlosPalsarFacilityData.h.
References _ISLR_of_ACF.
inline |
K_gen_date.
Definition at line 482 of file AlosPalsarFacilityData.h.
References _K_gen_date.
inline |
K_vers_num.
Definition at line 489 of file AlosPalsarFacilityData.h.
References _K_vers_num.
inline |
Definition at line 433 of file AlosPalsarFacilityData.h.
References _last_range_pix_mid_az_inc.
inline |
Definition at line 111 of file AlosPalsarFacilityData.h.
References _last_release_cal_date.
inline |
Definition at line 104 of file AlosPalsarFacilityData.h.
References _last_release_qc_date.
inline |
look_detecion_flag
Definition at line 664 of file AlosPalsarFacilityData.h.
References _look_detecion_flag.
inline |
look_scalar_gain_1
Definition at line 776 of file AlosPalsarFacilityData.h.
References _look_scalar_gain_1.
inline |
look_scalar_gain_2
Definition at line 783 of file AlosPalsarFacilityData.h.
References _look_scalar_gain_2.
inline |
look_scalar_gain_3
Definition at line 790 of file AlosPalsarFacilityData.h.
References _look_scalar_gain_3.
inline |
look_scalar_gain_4
Definition at line 797 of file AlosPalsarFacilityData.h.
References _look_scalar_gain_4.
inline |
look_scalar_gain_5
Definition at line 804 of file AlosPalsarFacilityData.h.
References _look_scalar_gain_5.
inline |
look_scalar_gain_6
Definition at line 811 of file AlosPalsarFacilityData.h.
References _look_scalar_gain_6.
inline |
look_scalar_gain_7
Definition at line 818 of file AlosPalsarFacilityData.h.
References _look_scalar_gain_7.
inline |
look_scalar_gain_8
Definition at line 825 of file AlosPalsarFacilityData.h.
References _look_scalar_gain_8.
inline |
low_bound_K
Definition at line 468 of file AlosPalsarFacilityData.h.
References _low_bound_K.
inline |
Definition at line 1077 of file AlosPalsarFacilityData.h.
References _max_error_range_line_timing.
inline |
Definition at line 1098 of file AlosPalsarFacilityData.h.
References _max_value_look_scalar_gain.
inline |
Definition at line 391 of file AlosPalsarFacilityData.h.
References _mean_cal_pulse_power.
inline |
mean_noise_power
Definition at line 398 of file AlosPalsarFacilityData.h.
References _mean_noise_power.
inline |
missing_lines
Definition at line 216 of file AlosPalsarFacilityData.h.
References _missing_lines.
inline |
name_of_facil_rec
Definition at line 96 of file AlosPalsarFacilityData.h.
References _name_of_facil_rec.
inline |
noise_power
Definition at line 349 of file AlosPalsarFacilityData.h.
References _noise_power.
inline |
norm_ref_range_ro
Definition at line 440 of file AlosPalsarFacilityData.h.
References _norm_ref_range_ro.
inline |
Definition at line 902 of file AlosPalsarFacilityData.h.
References _num_azimuth_blocks_proc.
inline |
Definition at line 496 of file AlosPalsarFacilityData.h.
References _num_duplic_input_lines.
inline |
Definition at line 909 of file AlosPalsarFacilityData.h.
References _num_input_raw_data_lines.
inline |
Definition at line 1014 of file AlosPalsarFacilityData.h.
References _num_range_samp_discarded.
inline |
Definition at line 363 of file AlosPalsarFacilityData.h.
References _num_valid_cal_pulses.
inline |
Definition at line 370 of file AlosPalsarFacilityData.h.
References _num_valid_noise_pulses.
inline |
Definition at line 1007 of file AlosPalsarFacilityData.h.
References _num_valid_pixels_per_range.
inline |
num_valid_replicas
Definition at line 377 of file AlosPalsarFacilityData.h.
References _num_valid_replicas.
inline |
OGOB_flag.
Definition at line 188 of file AlosPalsarFacilityData.h.
References _OGOB_flag.
inline |
out_image_max_value
Definition at line 524 of file AlosPalsarFacilityData.h.
References _out_image_max_value.
inline |
out_image_mean
Definition at line 510 of file AlosPalsarFacilityData.h.
References _out_image_mean.
inline |
out_image_std_dev
Definition at line 517 of file AlosPalsarFacilityData.h.
References _out_image_std_dev.
inline |
Definition at line 587 of file AlosPalsarFacilityData.h.
References _out_pixel_bit_length.
inline |
outp_data_mean_flag
Definition at line 181 of file AlosPalsarFacilityData.h.
References _outp_data_mean_flag.
inline |
Definition at line 643 of file AlosPalsarFacilityData.h.
References _peak_loc_CCF_betw_last.
inline |
Definition at line 615 of file AlosPalsarFacilityData.h.
References _peak_loc_cross_correl_fun.
inline |
PRF_changes.
Definition at line 195 of file AlosPalsarFacilityData.h.
References _PRF_changes.
inline |
Definition at line 125 of file AlosPalsarFacilityData.h.
References _prf_code_change_flag.
inline |
Definition at line 846 of file AlosPalsarFacilityData.h.
References _PRF_code_first_range_line.
inline |
Definition at line 853 of file AlosPalsarFacilityData.h.
References _PRF_code_last_range_line.
inline |
proc_gain_param_1
Definition at line 594 of file AlosPalsarFacilityData.h.
References _proc_gain_param_1.
inline |
proc_gain_param_2
Definition at line 601 of file AlosPalsarFacilityData.h.
References _proc_gain_param_2.
inline |
proc_gain_param_3
Definition at line 608 of file AlosPalsarFacilityData.h.
References _proc_gain_param_3.
inline |
Definition at line 475 of file AlosPalsarFacilityData.h.
References _proc_noise_scale_fact.
inline |
Definition at line 230 of file AlosPalsarFacilityData.h.
References _pulse_width_of_ACF_3db.
inline |
Definition at line 321 of file AlosPalsarFacilityData.h.
References _Q_channel_bias_correction.
inline |
Definition at line 335 of file AlosPalsarFacilityData.h.
References _Q_channel_gain_correction.
inline |
Definition at line 342 of file AlosPalsarFacilityData.h.
References _Q_channel_I_Q_correction.
inline |
qa_summary_flag
Definition at line 118 of file AlosPalsarFacilityData.h.
References _qa_summary_flag.
inline |
quirp_qu_flag
Definition at line 146 of file AlosPalsarFacilityData.h.
References _quirp_qu_flag.
inline |
Definition at line 405 of file AlosPalsarFacilityData.h.
References _range_comp_norm_fact.
inline |
Definition at line 692 of file AlosPalsarFacilityData.h.
References _range_lines_skip_factor.
inline |
Definition at line 1063 of file AlosPalsarFacilityData.h.
References _range_spread_loss_comp_flag.
inline |
Definition at line 1175 of file AlosPalsarFacilityData.h.
References _range_time_origin_ant.
inline |
Definition at line 657 of file AlosPalsarFacilityData.h.
References _raw_data_correction_flag.
inline |
rec_gain_changes
Definition at line 223 of file AlosPalsarFacilityData.h.
References _rec_gain_changes.
inline |
Definition at line 881 of file AlosPalsarFacilityData.h.
References _receiver_gain_last_proc.
inline |
Definition at line 1105 of file AlosPalsarFacilityData.h.
References _replica_norm_method_flag.
inline |
replica_power
Definition at line 412 of file AlosPalsarFacilityData.h.
References _replica_power.
inline |
Definition at line 650 of file AlosPalsarFacilityData.h.
References _Roll_Tilt_Mode_flag.
inline |
Definition at line 860 of file AlosPalsarFacilityData.h.
References _samp_win_start_first.
inline |
samp_win_start_last
Definition at line 867 of file AlosPalsarFacilityData.h.
References _samp_win_start_last.
inline |
Definition at line 832 of file AlosPalsarFacilityData.h.
References _samp_window_start_time_bias.
inline |
Definition at line 685 of file AlosPalsarFacilityData.h.
References _samples_per_line_used.
inline |
Definition at line 132 of file AlosPalsarFacilityData.h.
References _sampling_win_change_flag.
inline |
Definition at line 202 of file AlosPalsarFacilityData.h.
References _sampling_win_changes.
inline |
Definition at line 1000 of file AlosPalsarFacilityData.h.
References _sat_binary_time_of_first.
inline |
thresh_no_10_flag
Definition at line 986 of file AlosPalsarFacilityData.h.
References _thresh_no_10_flag.
inline |
thresh_no_11_flag
Definition at line 993 of file AlosPalsarFacilityData.h.
References _thresh_no_11_flag.
inline |
thresh_no_1_flag
Definition at line 923 of file AlosPalsarFacilityData.h.
References _thresh_no_1_flag.
inline |
thresh_no_2_flag
Definition at line 930 of file AlosPalsarFacilityData.h.
References _thresh_no_2_flag.
inline |
thresh_no_3_flag
Definition at line 937 of file AlosPalsarFacilityData.h.
References _thresh_no_3_flag.
inline |
thresh_no_4_flag
Definition at line 944 of file AlosPalsarFacilityData.h.
References _thresh_no_4_flag.
inline |
thresh_no_5_flag
Definition at line 951 of file AlosPalsarFacilityData.h.
References _thresh_no_5_flag.
inline |
thresh_no_6_flag
Definition at line 958 of file AlosPalsarFacilityData.h.
References _thresh_no_6_flag.
inline |
thresh_no_7_flag
Definition at line 965 of file AlosPalsarFacilityData.h.
References _thresh_no_7_flag.
inline |
thresh_no_8_flag
Definition at line 972 of file AlosPalsarFacilityData.h.
References _thresh_no_8_flag.
inline |
thresh_no_9_flag
Definition at line 979 of file AlosPalsarFacilityData.h.
References _thresh_no_9_flag.
inline |
Definition at line 538 of file AlosPalsarFacilityData.h.
References _time_asc_node_state_vectors.
inline |
Definition at line 699 of file AlosPalsarFacilityData.h.
References _time_of_inp_state_vectors.
inline |
Definition at line 531 of file AlosPalsarFacilityData.h.
References _time_raw_data_first_input.
inline |
Definition at line 769 of file AlosPalsarFacilityData.h.
References _update_period_range_match.
inline |
upp_bound_K
Definition at line 461 of file AlosPalsarFacilityData.h.
References _upp_bound_K.
inline |
Definition at line 762 of file AlosPalsarFacilityData.h.
References _win_coeff_for_azi_match.
inline |
Definition at line 755 of file AlosPalsarFacilityData.h.
References _win_coeff_for_range_match.
inlinevirtual |
Definition at line 64 of file AlosPalsarFacilityData.h.
| AlosPalsarFacilityData & ossimplugins::AlosPalsarFacilityData::operator= | ( | const AlosPalsarFacilityData & | rhs | ) |
Copy operator.
Definition at line 1008 of file AlosPalsarFacilityData.cpp.
References _3_dB_look_bandwidth, _3_dB_look_proc_dopp_bandw, _3_dB_width_CCF, _abs_cal_const_K, _antenna_elev_flag, _asc_node_pos_X_comp, _asc_node_pos_Y_comp, _asc_node_pos_Z_comp, _asc_node_vel_X_comp, _asc_node_vel_Y_comp, _asc_node_vel_Z_comp, _autom_look_scal_gain_flag, _azimuth_baseband_convers_flag, _azimuth_FFT_IFFT_ratio, _cal_gain_change_flag, _cal_gain_changes, _cal_sys_gain, _cal_syst_gain_last_proc, _center_range_pix_mid_az_inc, _coef_ant_elev_1, _coef_ant_elev_2, _coef_ant_elev_3, _coef_ant_elev_4, _coef_ant_elev_5, _coef_ground_range_1, _coef_ground_range_2, _coef_ground_range_3, _coef_ground_range_4, _datation_flag, _dopp_ambig_conf_meas, _dopp_ambig_conf_meas_flag, _dopp_ambig_num, _dopp_cent_conf_meas, _dopp_cent_conf_meas_flag, _dopp_cent_val_flag, _doppler_ambiguity_estimat_flag, _doppler_centroid_cubic_coeff, _estim_bit_error_rate, _first_processed_range_sample, _first_range_pixel_mid_az_inc, _first_rec_gain_read, _first_replica_sample, _first_side_lobe_lev_of_ACF, _first_side_lobe_level, _form_num_range_line_used, _I_channel_bias_correction, _I_channel_gain_correction, _I_gain_imb_lower_bound, _I_gain_imb_upper_bound, _I_Q_quad_depar_lower_bound, _I_Q_quad_depar_upper_bound, _initial_doppler_ambiguity_num, _inp_data_I_mean, _inp_data_I_stddev, _inp_data_Q_mean, _inp_data_Q_stddev, _inp_data_stat_flag, _inp_state_vect_pos_X_comp, _inp_state_vect_pos_Y_comp, _inp_state_vect_pos_Z_comp, _inp_state_vect_vel_Vx_comp, _inp_state_vect_vel_Vy_comp, _inp_state_vect_vel_Vz_comp, _inp_state_vector_type_flag, _int_cal_utc, _ISLR_CCF_between_last, _ISLR_of_ACF, _K_gen_date, _K_vers_num, _last_range_pix_mid_az_inc, _last_release_cal_date, _last_release_qc_date, _look_detecion_flag, _look_scalar_gain_1, _look_scalar_gain_2, _look_scalar_gain_3, _look_scalar_gain_4, _look_scalar_gain_5, _look_scalar_gain_6, _look_scalar_gain_7, _look_scalar_gain_8, _low_bound_K, _max_error_range_line_timing, _max_value_look_scalar_gain, _mean_cal_pulse_power, _mean_noise_power, _missing_lines, _noise_power, _norm_ref_range_ro, _num_azimuth_blocks_proc, _num_duplic_input_lines, _num_input_raw_data_lines, _num_range_samp_discarded, _num_valid_cal_pulses, _num_valid_noise_pulses, _num_valid_pixels_per_range, _num_valid_replicas, _OGOB_flag, _out_image_max_value, _out_image_mean, _out_image_std_dev, _out_pixel_bit_length, _outp_data_mean_flag, _peak_loc_CCF_betw_last, _peak_loc_cross_correl_fun, _PRF_changes, _prf_code_change_flag, _PRF_code_first_range_line, _PRF_code_last_range_line, _proc_gain_param_1, _proc_gain_param_2, _proc_gain_param_3, _proc_noise_scale_fact, _pulse_width_of_ACF_3db, _Q_channel_bias_correction, _Q_channel_gain_correction, _Q_channel_I_Q_correction, _qa_summary_flag, _quirp_qu_flag, _range_comp_norm_fact, _range_lines_skip_factor, _range_spread_loss_comp_flag, _range_time_origin_ant, _raw_data_correction_flag, _rec_gain_changes, _receiver_gain_last_proc, _replica_norm_method_flag, _replica_power, _Roll_Tilt_Mode_flag, _samp_win_start_first, _samp_win_start_last, _samp_window_start_time_bias, _samples_per_line_used, _sampling_win_change_flag, _sampling_win_changes, _sat_binary_time_of_first, _thresh_no_10_flag, _thresh_no_11_flag, _thresh_no_1_flag, _thresh_no_2_flag, _thresh_no_3_flag, _thresh_no_4_flag, _thresh_no_5_flag, _thresh_no_6_flag, _thresh_no_7_flag, _thresh_no_8_flag, _thresh_no_9_flag, _time_asc_node_state_vectors, _time_of_inp_state_vectors, _time_raw_data_first_input, _update_period_range_match, _upp_bound_K, _win_coeff_for_azi_match, and _win_coeff_for_range_match.
inlinevirtual |
Definition at line 80 of file AlosPalsarFacilityData.h.
inlinevirtual |
Definition at line 88 of file AlosPalsarFacilityData.h.
friend |
Definition at line 26 of file AlosPalsarFacilityData.cpp.
friend |
Definition at line 340 of file AlosPalsarFacilityData.cpp.
protected |
3_dB_look_bandwidth
Definition at line 1730 of file AlosPalsarFacilityData.h.
Referenced by get_3_dB_look_bandwidth(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1734 of file AlosPalsarFacilityData.h.
Referenced by get_3_dB_look_proc_dopp_bandw(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
3_dB_width_CCF
Definition at line 1486 of file AlosPalsarFacilityData.h.
Referenced by get_3_dB_width_CCF(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
abs_cal_const_K
Definition at line 1390 of file AlosPalsarFacilityData.h.
Referenced by get_abs_cal_const_K(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
antenna_elev_flag
Definition at line 1386 of file AlosPalsarFacilityData.h.
Referenced by get_antenna_elev_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
asc_node_pos_X_comp
Definition at line 1442 of file AlosPalsarFacilityData.h.
Referenced by get_asc_node_pos_X_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
asc_node_pos_Y_comp
Definition at line 1446 of file AlosPalsarFacilityData.h.
Referenced by get_asc_node_pos_Y_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
asc_node_pos_Z_comp
Definition at line 1450 of file AlosPalsarFacilityData.h.
Referenced by get_asc_node_pos_Z_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
asc_node_vel_X_comp
Definition at line 1454 of file AlosPalsarFacilityData.h.
Referenced by get_asc_node_vel_X_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
asc_node_vel_Y_comp
Definition at line 1458 of file AlosPalsarFacilityData.h.
Referenced by get_asc_node_vel_Y_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
asc_node_vel_Z_comp
Definition at line 1462 of file AlosPalsarFacilityData.h.
Referenced by get_asc_node_vel_Z_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1754 of file AlosPalsarFacilityData.h.
Referenced by get_autom_look_scal_gain_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1518 of file AlosPalsarFacilityData.h.
Referenced by get_azimuth_baseband_convers_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1642 of file AlosPalsarFacilityData.h.
Referenced by get_azimuth_FFT_IFFT_ratio(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1210 of file AlosPalsarFacilityData.h.
Referenced by get_cal_gain_change_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
cal_gain_changes
Definition at line 1250 of file AlosPalsarFacilityData.h.
Referenced by get_cal_gain_changes(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
cal_sys_gain
Definition at line 1298 of file AlosPalsarFacilityData.h.
Referenced by get_cal_sys_gain(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1630 of file AlosPalsarFacilityData.h.
Referenced by get_cal_syst_gain_last_proc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1374 of file AlosPalsarFacilityData.h.
Referenced by get_center_range_pix_mid_az_inc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
coef_ant_elev_1
Definition at line 1782 of file AlosPalsarFacilityData.h.
Referenced by get_coef_ant_elev_1(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
coef_ant_elev_2
Definition at line 1786 of file AlosPalsarFacilityData.h.
Referenced by get_coef_ant_elev_2(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
coef_ant_elev_3
Definition at line 1790 of file AlosPalsarFacilityData.h.
Referenced by get_coef_ant_elev_3(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
coef_ant_elev_4
Definition at line 1794 of file AlosPalsarFacilityData.h.
Referenced by get_coef_ant_elev_4(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
coef_ant_elev_5
Definition at line 1798 of file AlosPalsarFacilityData.h.
Referenced by get_coef_ant_elev_5(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
coef_ground_range_1
Definition at line 1766 of file AlosPalsarFacilityData.h.
Referenced by get_coef_ground_range_1(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
coef_ground_range_2
Definition at line 1770 of file AlosPalsarFacilityData.h.
Referenced by get_coef_ground_range_2(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
coef_ground_range_3
Definition at line 1774 of file AlosPalsarFacilityData.h.
Referenced by get_coef_ground_range_3(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
coef_ground_range_4
Definition at line 1778 of file AlosPalsarFacilityData.h.
Referenced by get_coef_ground_range_4(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
datation_flag
Definition at line 1742 of file AlosPalsarFacilityData.h.
Referenced by get_datation_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1278 of file AlosPalsarFacilityData.h.
Referenced by get_dopp_ambig_conf_meas(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1230 of file AlosPalsarFacilityData.h.
Referenced by get_dopp_ambig_conf_meas_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
dopp_ambig_num
Definition at line 1306 of file AlosPalsarFacilityData.h.
Referenced by get_dopp_ambig_num(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
dopp_cent_conf_meas
Definition at line 1274 of file AlosPalsarFacilityData.h.
Referenced by get_dopp_cent_conf_meas(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1222 of file AlosPalsarFacilityData.h.
Referenced by get_dopp_cent_conf_meas_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
dopp_cent_val_flag
Definition at line 1226 of file AlosPalsarFacilityData.h.
Referenced by get_dopp_cent_val_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1514 of file AlosPalsarFacilityData.h.
Referenced by get_doppler_ambiguity_estimat_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1610 of file AlosPalsarFacilityData.h.
Referenced by get_doppler_centroid_cubic_coeff(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1418 of file AlosPalsarFacilityData.h.
Referenced by get_estim_bit_error_rate(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1638 of file AlosPalsarFacilityData.h.
Referenced by get_first_processed_range_sample(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1370 of file AlosPalsarFacilityData.h.
Referenced by get_first_range_pixel_mid_az_inc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
first_rec_gain_read
Definition at line 1302 of file AlosPalsarFacilityData.h.
Referenced by get_first_rec_gain_read(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1350 of file AlosPalsarFacilityData.h.
Referenced by get_first_replica_sample(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1266 of file AlosPalsarFacilityData.h.
Referenced by get_first_side_lobe_lev_of_ACF(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1490 of file AlosPalsarFacilityData.h.
Referenced by get_first_side_lobe_level(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1750 of file AlosPalsarFacilityData.h.
Referenced by get_form_num_range_line_used(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1310 of file AlosPalsarFacilityData.h.
Referenced by get_I_channel_bias_correction(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1318 of file AlosPalsarFacilityData.h.
Referenced by get_I_channel_gain_correction(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1714 of file AlosPalsarFacilityData.h.
Referenced by get_I_gain_imb_lower_bound(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1718 of file AlosPalsarFacilityData.h.
Referenced by get_I_gain_imb_upper_bound(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1722 of file AlosPalsarFacilityData.h.
Referenced by get_I_Q_quad_depar_lower_bound(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1726 of file AlosPalsarFacilityData.h.
Referenced by get_I_Q_quad_depar_upper_bound(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1654 of file AlosPalsarFacilityData.h.
Referenced by get_initial_doppler_ambiguity_num(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
inp_data_I_mean
Definition at line 1282 of file AlosPalsarFacilityData.h.
Referenced by get_inp_data_I_mean(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
inp_data_I_stddev
Definition at line 1290 of file AlosPalsarFacilityData.h.
Referenced by get_inp_data_I_stddev(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
inp_data_Q_mean
Definition at line 1286 of file AlosPalsarFacilityData.h.
Referenced by get_inp_data_Q_mean(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
inp_data_Q_stddev
Definition at line 1294 of file AlosPalsarFacilityData.h.
Referenced by get_inp_data_Q_stddev(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
inp_data_stat_flag
Definition at line 1218 of file AlosPalsarFacilityData.h.
Referenced by get_inp_data_stat_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1534 of file AlosPalsarFacilityData.h.
Referenced by get_inp_state_vect_pos_X_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1538 of file AlosPalsarFacilityData.h.
Referenced by get_inp_state_vect_pos_Y_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1542 of file AlosPalsarFacilityData.h.
Referenced by get_inp_state_vect_pos_Z_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1546 of file AlosPalsarFacilityData.h.
Referenced by get_inp_state_vect_vel_Vx_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1550 of file AlosPalsarFacilityData.h.
Referenced by get_inp_state_vect_vel_Vy_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1554 of file AlosPalsarFacilityData.h.
Referenced by get_inp_state_vect_vel_Vz_comp(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1558 of file AlosPalsarFacilityData.h.
Referenced by get_inp_state_vector_type_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
int_cal_utc
Definition at line 1334 of file AlosPalsarFacilityData.h.
Referenced by get_int_cal_utc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1494 of file AlosPalsarFacilityData.h.
Referenced by get_ISLR_CCF_between_last(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
ISLR_of_ACF.
Definition at line 1270 of file AlosPalsarFacilityData.h.
Referenced by get_ISLR_of_ACF(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
K_gen_date.
Definition at line 1406 of file AlosPalsarFacilityData.h.
Referenced by get_K_gen_date(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
K_vers_num.
Definition at line 1410 of file AlosPalsarFacilityData.h.
Referenced by get_K_vers_num(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1378 of file AlosPalsarFacilityData.h.
Referenced by get_last_range_pix_mid_az_inc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1194 of file AlosPalsarFacilityData.h.
Referenced by get_last_release_cal_date(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1190 of file AlosPalsarFacilityData.h.
Referenced by get_last_release_qc_date(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
look_detecion_flag
Definition at line 1510 of file AlosPalsarFacilityData.h.
Referenced by get_look_detecion_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
look_scalar_gain_1
Definition at line 1574 of file AlosPalsarFacilityData.h.
Referenced by get_look_scalar_gain_1(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
look_scalar_gain_2
Definition at line 1578 of file AlosPalsarFacilityData.h.
Referenced by get_look_scalar_gain_2(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
look_scalar_gain_3
Definition at line 1582 of file AlosPalsarFacilityData.h.
Referenced by get_look_scalar_gain_3(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
look_scalar_gain_4
Definition at line 1586 of file AlosPalsarFacilityData.h.
Referenced by get_look_scalar_gain_4(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
look_scalar_gain_5
Definition at line 1590 of file AlosPalsarFacilityData.h.
Referenced by get_look_scalar_gain_5(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
look_scalar_gain_6
Definition at line 1594 of file AlosPalsarFacilityData.h.
Referenced by get_look_scalar_gain_6(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
look_scalar_gain_7
Definition at line 1598 of file AlosPalsarFacilityData.h.
Referenced by get_look_scalar_gain_7(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
look_scalar_gain_8
Definition at line 1602 of file AlosPalsarFacilityData.h.
Referenced by get_look_scalar_gain_8(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
low_bound_K
Definition at line 1398 of file AlosPalsarFacilityData.h.
Referenced by get_low_bound_K(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1746 of file AlosPalsarFacilityData.h.
Referenced by get_max_error_range_line_timing(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1758 of file AlosPalsarFacilityData.h.
Referenced by get_max_value_look_scalar_gain(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1354 of file AlosPalsarFacilityData.h.
Referenced by get_mean_cal_pulse_power(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
mean_noise_power
Definition at line 1358 of file AlosPalsarFacilityData.h.
Referenced by get_mean_noise_power(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
missing_lines
Definition at line 1254 of file AlosPalsarFacilityData.h.
Referenced by get_missing_lines(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1178 of file AlosPalsarFacilityData.h.
Referenced by get_name_of_facil_rec(), and ossimplugins::operator>>().
protected |
noise_power
Definition at line 1330 of file AlosPalsarFacilityData.h.
Referenced by get_noise_power(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
norm_ref_range_ro
Definition at line 1382 of file AlosPalsarFacilityData.h.
Referenced by get_norm_ref_range_ro(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1646 of file AlosPalsarFacilityData.h.
Referenced by get_num_azimuth_blocks_proc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1414 of file AlosPalsarFacilityData.h.
Referenced by get_num_duplic_input_lines(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1650 of file AlosPalsarFacilityData.h.
Referenced by get_num_input_raw_data_lines(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1710 of file AlosPalsarFacilityData.h.
Referenced by get_num_range_samp_discarded(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1338 of file AlosPalsarFacilityData.h.
Referenced by get_num_valid_cal_pulses(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1342 of file AlosPalsarFacilityData.h.
Referenced by get_num_valid_noise_pulses(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1706 of file AlosPalsarFacilityData.h.
Referenced by get_num_valid_pixels_per_range(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
num_valid_replicas
Definition at line 1346 of file AlosPalsarFacilityData.h.
Referenced by get_num_valid_replicas(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
OGOB_flag.
Definition at line 1238 of file AlosPalsarFacilityData.h.
Referenced by get_OGOB_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
out_image_max_value
Definition at line 1430 of file AlosPalsarFacilityData.h.
Referenced by get_out_image_max_value(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
out_image_mean
Definition at line 1422 of file AlosPalsarFacilityData.h.
Referenced by get_out_image_mean(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
out_image_std_dev
Definition at line 1426 of file AlosPalsarFacilityData.h.
Referenced by get_out_image_std_dev(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1466 of file AlosPalsarFacilityData.h.
Referenced by get_out_pixel_bit_length(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
outp_data_mean_flag
Definition at line 1234 of file AlosPalsarFacilityData.h.
Referenced by get_outp_data_mean_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1498 of file AlosPalsarFacilityData.h.
Referenced by get_peak_loc_CCF_betw_last(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1482 of file AlosPalsarFacilityData.h.
Referenced by get_peak_loc_cross_correl_fun(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
PRF_changes.
Definition at line 1242 of file AlosPalsarFacilityData.h.
Referenced by get_PRF_changes(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1202 of file AlosPalsarFacilityData.h.
Referenced by get_prf_code_change_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1614 of file AlosPalsarFacilityData.h.
Referenced by get_PRF_code_first_range_line(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1618 of file AlosPalsarFacilityData.h.
Referenced by get_PRF_code_last_range_line(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
proc_gain_param_1
Definition at line 1470 of file AlosPalsarFacilityData.h.
Referenced by get_proc_gain_param_1(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
proc_gain_param_2
Definition at line 1474 of file AlosPalsarFacilityData.h.
Referenced by get_proc_gain_param_2(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
proc_gain_param_3
Definition at line 1478 of file AlosPalsarFacilityData.h.
Referenced by get_proc_gain_param_3(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1402 of file AlosPalsarFacilityData.h.
Referenced by get_proc_noise_scale_fact(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1262 of file AlosPalsarFacilityData.h.
Referenced by get_pulse_width_of_ACF_3db(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1314 of file AlosPalsarFacilityData.h.
Referenced by get_Q_channel_bias_correction(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1322 of file AlosPalsarFacilityData.h.
Referenced by get_Q_channel_gain_correction(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1326 of file AlosPalsarFacilityData.h.
Referenced by get_Q_channel_I_Q_correction(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
qa_summary_flag
Definition at line 1198 of file AlosPalsarFacilityData.h.
Referenced by get_qa_summary_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
quirp_qu_flag
Definition at line 1214 of file AlosPalsarFacilityData.h.
Referenced by get_quirp_qu_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1362 of file AlosPalsarFacilityData.h.
Referenced by get_range_comp_norm_fact(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1526 of file AlosPalsarFacilityData.h.
Referenced by get_range_lines_skip_factor(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1738 of file AlosPalsarFacilityData.h.
Referenced by get_range_spread_loss_comp_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1802 of file AlosPalsarFacilityData.h.
Referenced by get_range_time_origin_ant(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1506 of file AlosPalsarFacilityData.h.
Referenced by get_raw_data_correction_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
rec_gain_changes
Definition at line 1258 of file AlosPalsarFacilityData.h.
Referenced by get_rec_gain_changes(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1634 of file AlosPalsarFacilityData.h.
Referenced by get_receiver_gain_last_proc(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1762 of file AlosPalsarFacilityData.h.
Referenced by get_replica_norm_method_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
replica_power
Definition at line 1366 of file AlosPalsarFacilityData.h.
Referenced by get_replica_power(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1502 of file AlosPalsarFacilityData.h.
Referenced by get_Roll_Tilt_Mode_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1622 of file AlosPalsarFacilityData.h.
Referenced by get_samp_win_start_first(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
samp_win_start_last
Definition at line 1626 of file AlosPalsarFacilityData.h.
Referenced by get_samp_win_start_last(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1606 of file AlosPalsarFacilityData.h.
Referenced by get_samp_window_start_time_bias(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1522 of file AlosPalsarFacilityData.h.
Referenced by get_samples_per_line_used(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1206 of file AlosPalsarFacilityData.h.
Referenced by get_sampling_win_change_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1246 of file AlosPalsarFacilityData.h.
Referenced by get_sampling_win_changes(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1702 of file AlosPalsarFacilityData.h.
Referenced by get_sat_binary_time_of_first(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
thresh_no_10_flag
Definition at line 1694 of file AlosPalsarFacilityData.h.
Referenced by get_thresh_no_10_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
thresh_no_11_flag
Definition at line 1698 of file AlosPalsarFacilityData.h.
Referenced by get_thresh_no_11_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
thresh_no_1_flag
Definition at line 1658 of file AlosPalsarFacilityData.h.
Referenced by get_thresh_no_1_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
thresh_no_2_flag
Definition at line 1662 of file AlosPalsarFacilityData.h.
Referenced by get_thresh_no_2_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
thresh_no_3_flag
Definition at line 1666 of file AlosPalsarFacilityData.h.
Referenced by get_thresh_no_3_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
thresh_no_4_flag
Definition at line 1670 of file AlosPalsarFacilityData.h.
Referenced by get_thresh_no_4_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
thresh_no_5_flag
Definition at line 1674 of file AlosPalsarFacilityData.h.
Referenced by get_thresh_no_5_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
thresh_no_6_flag
Definition at line 1678 of file AlosPalsarFacilityData.h.
Referenced by get_thresh_no_6_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
thresh_no_7_flag
Definition at line 1682 of file AlosPalsarFacilityData.h.
Referenced by get_thresh_no_7_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
thresh_no_8_flag
Definition at line 1686 of file AlosPalsarFacilityData.h.
Referenced by get_thresh_no_8_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
thresh_no_9_flag
Definition at line 1690 of file AlosPalsarFacilityData.h.
Referenced by get_thresh_no_9_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1438 of file AlosPalsarFacilityData.h.
Referenced by get_time_asc_node_state_vectors(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1530 of file AlosPalsarFacilityData.h.
Referenced by get_time_of_inp_state_vectors(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1434 of file AlosPalsarFacilityData.h.
Referenced by get_time_raw_data_first_input(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1570 of file AlosPalsarFacilityData.h.
Referenced by get_update_period_range_match(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
upp_bound_K
Definition at line 1394 of file AlosPalsarFacilityData.h.
Referenced by get_upp_bound_K(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1566 of file AlosPalsarFacilityData.h.
Referenced by get_win_coeff_for_azi_match(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 1562 of file AlosPalsarFacilityData.h.
Referenced by get_win_coeff_for_range_match(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
