This class is able to read the header of the Signal Data Records of the image file. More...
#include <AlosPalsarSignalData.h>
| AlosPalsarSignalData () | |
| Constructor. More... | |
| virtual | ~AlosPalsarSignalData () |
| Destructor. More... | |
| AlosPalsarSignalData (const AlosPalsarSignalData &rhs) | |
| Copy constructor. More... | |
| AlosPalsarSignalData & | operator= (const AlosPalsarSignalData &rhs) |
| Copy operator. More... | |
| AlosPalsarRecord * | Instanciate () |
| This function is able to create a new instance of the class. More... | |
| AlosPalsarRecord * | Clone () |
| This function is able to create a new instance of the class initialised with the data of the calling instance. More... | |
| void | Read (std::istream &is) |
| Read the class data from a stream. More... | |
| void | Write (std::ostream &os) |
| Write the class to a stream. More... | |
| int | get_pulse_repetition_frequency () const |
| int | get_slant_range_to_1st_data_sample () const |
Public Member Functions inherited from ossimplugins::AlosPalsarRecord | |
| AlosPalsarRecord (std::string mnemonic) | |
| virtual | ~AlosPalsarRecord () |
| AlosPalsarRecord (const AlosPalsarRecord &rhs) | |
| std::string | get_mnemonic () |
Protected Attributes | |
| int | _pulse_repetition_frequency |
| pulse_repetition_frequency More... | |
| int | _slant_range_to_1st_data_sample |
| slant_range_to_1st_data_sample More... | |
Protected Attributes inherited from ossimplugins::AlosPalsarRecord | |
| std::string | _mnemonic |
Friends | |
| std::ostream & | operator<< (std::ostream &os, const AlosPalsarSignalData &data) |
| This function writes AlosPalsarSignalData to a stream. More... | |
| std::istream & | operator>> (std::istream &is, AlosPalsarSignalData &data) |
| This function reads to AlosPalsarSignalData from a stream. More... | |
Definition at line 29 of file AlosPalsarSignalData.h.
| ossimplugins::AlosPalsarSignalData::AlosPalsarSignalData | ( | ) |
Constructor.
Definition at line 21 of file AlosPalsarSignalData.cpp.
Referenced by Clone(), and Instanciate().
| ossimplugins::AlosPalsarSignalData::AlosPalsarSignalData | ( | const AlosPalsarSignalData & | rhs | ) |
Copy constructor.
Definition at line 181 of file AlosPalsarSignalData.cpp.
inlinevirtual |
Implements ossimplugins::AlosPalsarRecord.
Definition at line 72 of file AlosPalsarSignalData.h.
References AlosPalsarSignalData().
inline |
Definition at line 94 of file AlosPalsarSignalData.h.
References _pulse_repetition_frequency.
Referenced by ossimplugins::AlosPalsarData::saveState().
inline |
Definition at line 99 of file AlosPalsarSignalData.h.
References _slant_range_to_1st_data_sample.
inlinevirtual |
Definition at line 64 of file AlosPalsarSignalData.h.
| AlosPalsarSignalData & ossimplugins::AlosPalsarSignalData::operator= | ( | const AlosPalsarSignalData & | rhs | ) |
Copy operator.
Definition at line 188 of file AlosPalsarSignalData.cpp.
References _pulse_repetition_frequency, and _slant_range_to_1st_data_sample.
inlinevirtual |
Definition at line 80 of file AlosPalsarSignalData.h.
inlinevirtual |
Definition at line 88 of file AlosPalsarSignalData.h.
friend |
Definition at line 29 of file AlosPalsarSignalData.cpp.
friend |
Definition at line 39 of file AlosPalsarSignalData.cpp.
protected |
Definition at line 102 of file AlosPalsarSignalData.h.
Referenced by get_pulse_repetition_frequency(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 115 of file AlosPalsarSignalData.h.
Referenced by get_slant_range_to_1st_data_sample(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
