This class is able to read a Attitude data record. More...
#include <AttitudeData.h>
| AttitudeData () | |
| Constructor. More... | |
| ~AttitudeData () | |
| Destructor. More... | |
| AttitudeData (const AttitudeData &rhs) | |
| Copy constructor. More... | |
| AttitudeData & | operator= (const AttitudeData &rhs) |
| Copy operator. More... | |
| RadarSatRecord * | Instanciate () |
| This function is able to create a new instance of the class. More... | |
| RadarSatRecord * | Clone () |
| This function is able to create a new instance of the class initialised with the data of the calling instance. More... | |
| void | Read (std::istream &is) |
| Reads the class data from a stream. More... | |
| void | Write (std::ostream &os) |
| Writes the class to a stream. More... | |
| int | get_npoint () |
| Number of data points. More... | |
| DataPointDataRecord * | get_att_vect () |
Data points More... | |
| double | get_pitch_bias () |
Pitch bias (degrees) More... | |
| double | get_roll_bias () |
Roll bias (degrees) More... | |
| double | get_yaw_bias () |
Yaw bias (degrees) More... | |
Public Member Functions inherited from ossimplugins::RadarSatRecord | |
| RadarSatRecord (std::string mnemonic) | |
| virtual | ~RadarSatRecord () |
| RadarSatRecord (const RadarSatRecord &rhs) | |
| std::string | get_mnemonic () |
Protected Attributes | |
| int | _npoint |
| DataPointDataRecord | _att_vect [20] |
| double | _pitch_bias |
| double | _roll_bias |
| double | _yaw_bias |
Protected Attributes inherited from ossimplugins::RadarSatRecord | |
| std::string | _mnemonic |
Friends | |
| std::ostream & | operator<< (std::ostream &os, const AttitudeData &data) |
| This function writes the AttitudeData in a stream. More... | |
| std::istream & | operator>> (std::istream &is, AttitudeData &data) |
| This function reads a AttitudeData from a stream. More... | |
Definition at line 28 of file AttitudeData.h.
| ossimplugins::AttitudeData::AttitudeData | ( | ) |
Constructor.
Definition at line 18 of file AttitudeData.cpp.
Referenced by Clone(), and Instanciate().
| ossimplugins::AttitudeData::~AttitudeData | ( | ) |
| ossimplugins::AttitudeData::AttitudeData | ( | const AttitudeData & | rhs | ) |
Copy constructor.
Definition at line 69 of file AttitudeData.cpp.
References _att_vect, _npoint, _pitch_bias, _roll_bias, and _yaw_bias.
inlinevirtual |
Implements ossimplugins::RadarSatRecord.
Definition at line 71 of file AttitudeData.h.
References AttitudeData().
inline |
Data points
Definition at line 102 of file AttitudeData.h.
References _att_vect.
inline |
inline |
Definition at line 109 of file AttitudeData.h.
References _pitch_bias.
inline |
Roll bias (degrees)
Definition at line 116 of file AttitudeData.h.
References _roll_bias.
inline |
Yaw bias (degrees)
Definition at line 123 of file AttitudeData.h.
References _yaw_bias.
inlinevirtual |
Definition at line 63 of file AttitudeData.h.
| AttitudeData & ossimplugins::AttitudeData::operator= | ( | const AttitudeData & | rhs | ) |
Copy operator.
Definition at line 82 of file AttitudeData.cpp.
inlinevirtual |
Definition at line 79 of file AttitudeData.h.
inlinevirtual |
Definition at line 87 of file AttitudeData.h.
friend |
friend |
protected |
Data points
Definition at line 137 of file AttitudeData.h.
Referenced by AttitudeData(), get_att_vect(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 126 of file AttitudeData.h.
Referenced by AttitudeData(), get_npoint(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 141 of file AttitudeData.h.
Referenced by AttitudeData(), get_pitch_bias(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Roll bias (degrees)
Definition at line 145 of file AttitudeData.h.
Referenced by AttitudeData(), get_roll_bias(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Yaw bias (degrees)
Definition at line 149 of file AttitudeData.h.
Referenced by AttitudeData(), get_yaw_bias(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
