This class is able to read a data histogram record - Processed data. More...
#include <DataHistogramProcessedData.h>
| DataHistogramProcessedData () | |
| Constructor. More... | |
| virtual | ~DataHistogramProcessedData () |
| Destructor. More... | |
| DataHistogramProcessedData (const DataHistogramProcessedData &rhs) | |
| Copy constructor. More... | |
| DataHistogramProcessedData & | operator= (const DataHistogramProcessedData &rhs) |
| Copy operator. More... | |
| RadarSatRecord * | Instanciate () |
| This function is able to create a new instance of the class. More... | |
| RadarSatRecord * | Clone () |
| This function is able to create a new instance of the class initialised with the data of the calling instance. More... | |
| void | Read (std::istream &is) |
| Reads the class data from a stream. More... | |
| void | Write (std::ostream &os) |
| Writes the class to a stream. More... | |
| int | get_rec_seq () |
| Record sequence number. More... | |
| int | get_sar_chn () |
| SAR channel indicator. More... | |
| int | get_ntab () |
| Number of histogram table data sets in this record. More... | |
| int | get_ltab () |
| Histogram table data set size. More... | |
| DataHistogramRecord | get_histogram1 () |
| Histogram data record #1. More... | |
| DataHistogramRecord | get_histogram2 () |
| Histogram data record #2. More... | |
Public Member Functions inherited from ossimplugins::RadarSatRecord | |
| RadarSatRecord (std::string mnemonic) | |
| virtual | ~RadarSatRecord () |
| RadarSatRecord (const RadarSatRecord &rhs) | |
| std::string | get_mnemonic () |
Protected Attributes | |
| int | _rec_seq |
| int | _sar_chn |
| int | _ntab |
| int | _ltab |
| DataHistogramRecord | _histogram1 |
| DataHistogramRecord | _histogram2 |
Protected Attributes inherited from ossimplugins::RadarSatRecord | |
| std::string | _mnemonic |
Friends | |
| std::ostream & | operator<< (std::ostream &os, const DataHistogramProcessedData &data) |
| This function writes the DataHistogramProcessedData in a stream. More... | |
| std::istream & | operator>> (std::istream &is, DataHistogramProcessedData &data) |
| This function reads a DataHistogramProcessedData from a stream. More... | |
Definition at line 30 of file DataHistogramProcessedData.h.
| ossimplugins::DataHistogramProcessedData::DataHistogramProcessedData | ( | ) |
Constructor.
Definition at line 16 of file DataHistogramProcessedData.cpp.
Referenced by Clone(), and Instanciate().
| ossimplugins::DataHistogramProcessedData::DataHistogramProcessedData | ( | const DataHistogramProcessedData & | rhs | ) |
Copy constructor.
Definition at line 72 of file DataHistogramProcessedData.cpp.
inlinevirtual |
Implements ossimplugins::RadarSatRecord.
Definition at line 73 of file DataHistogramProcessedData.h.
References DataHistogramProcessedData().
inline |
Definition at line 128 of file DataHistogramProcessedData.h.
References _histogram1.
inline |
Definition at line 136 of file DataHistogramProcessedData.h.
References _histogram2.
inline |
Definition at line 120 of file DataHistogramProcessedData.h.
References _ltab.
inline |
Definition at line 112 of file DataHistogramProcessedData.h.
References _ntab.
inline |
Definition at line 97 of file DataHistogramProcessedData.h.
References _rec_seq.
inline |
Definition at line 104 of file DataHistogramProcessedData.h.
References _sar_chn.
inlinevirtual |
Definition at line 65 of file DataHistogramProcessedData.h.
| DataHistogramProcessedData & ossimplugins::DataHistogramProcessedData::operator= | ( | const DataHistogramProcessedData & | rhs | ) |
Copy operator.
Definition at line 84 of file DataHistogramProcessedData.cpp.
References _histogram1, _histogram2, _ltab, _ntab, _rec_seq, and _sar_chn.
inlinevirtual |
Definition at line 81 of file DataHistogramProcessedData.h.
inlinevirtual |
Definition at line 89 of file DataHistogramProcessedData.h.
friend |
Definition at line 24 of file DataHistogramProcessedData.cpp.
friend |
Definition at line 41 of file DataHistogramProcessedData.cpp.
protected |
Definition at line 161 of file DataHistogramProcessedData.h.
Referenced by get_histogram1(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 165 of file DataHistogramProcessedData.h.
Referenced by get_histogram2(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 157 of file DataHistogramProcessedData.h.
Referenced by get_ltab(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 153 of file DataHistogramProcessedData.h.
Referenced by get_ntab(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 139 of file DataHistogramProcessedData.h.
Referenced by get_rec_seq(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
protected |
Definition at line 148 of file DataHistogramProcessedData.h.
Referenced by get_sar_chn(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
