This class is able to read the ASAR SRGRConversionParameters record. More...
#include <SRGRConversionParameters.h>
| SRGRConversionParameters () | |
| Constructor. More... | |
| virtual | ~SRGRConversionParameters () |
| Destructor. More... | |
| SRGRConversionParameters (const SRGRConversionParameters &rhs) | |
| Copy constructor. More... | |
| SRGRConversionParameters & | operator= (const SRGRConversionParameters &rhs) |
| Copy operator. More... | |
| EnvisatAsarRecord * | Instanciate () |
| This function is able to create a new instance of the class. More... | |
| EnvisatAsarRecord * | Clone () |
| This function is able to create a new instance of the class initialised with the data of the calling instance. More... | |
| void | Read (std::istream &is) |
| Reads the class data from a stream. More... | |
| void | Write (std::ostream &os) |
| Writes the class to a stream. More... | |
| int | get_first_zero_doppler_time_day () |
| first_zero_doppler_time day More... | |
| unsigned int | get_first_zero_doppler_time_sec () |
| first_zero_doppler_time second More... | |
| unsigned int | get_first_zero_doppler_time_microsec () |
| first_zero_doppler_time micro sec More... | |
| bool | get_attach_flag () |
| attach_flag More... | |
| float | get_slant_range_time () |
| input_mean_flag More... | |
| float | get_ground_range_origin () |
| input_std_dev_flag More... | |
| float * | get_srgr_coef () |
| input_gaps_flag More... | |
Public Member Functions inherited from ossimplugins::EnvisatAsarRecord | |
| EnvisatAsarRecord (std::string mnemonic) | |
| virtual | ~EnvisatAsarRecord () |
| EnvisatAsarRecord (const EnvisatAsarRecord &rhs) | |
| std::string | get_mnemonic () |
| Returns the mnemonic of the record. More... | |
Public Attributes | |
| int | _first_zero_doppler_time_day |
| unsigned int | _first_zero_doppler_time_sec |
| first_zero_doppler_time sec More... | |
| unsigned int | _first_zero_doppler_time_microsec |
| first_zero_doppler_time microsec More... | |
| bool | _attach_flag |
| float | _slant_range_time |
| float | _ground_range_origin |
| float | _srgr_coef [5] |
Friends | |
| std::ostream & | operator<< (std::ostream &os, const SRGRConversionParameters &data) |
| This function writes the SRGRConversionParameters in a stream. More... | |
| std::istream & | operator>> (std::istream &is, SRGRConversionParameters &data) |
| This function reads a SRGRConversionParameters from a stream. More... | |
Protected Member Functions inherited from ossimplugins::EnvisatAsarRecord | |
| template<typename T > | |
| void | SwitchEndian (T &value) |
| This function switches the LSB value and the MSB value of the parameter. More... | |
Protected Attributes inherited from ossimplugins::EnvisatAsarRecord | |
| std::string | _mnemonic |
Definition at line 25 of file SRGRConversionParameters.h.
| ossimplugins::SRGRConversionParameters::SRGRConversionParameters | ( | ) |
Constructor.
Definition at line 16 of file SRGRConversionParameters.cpp.
Referenced by Clone(), and Instanciate().
| ossimplugins::SRGRConversionParameters::SRGRConversionParameters | ( | const SRGRConversionParameters & | rhs | ) |
Copy constructor.
Definition at line 82 of file SRGRConversionParameters.cpp.
References _srgr_coef.
inlinevirtual |
Implements ossimplugins::EnvisatAsarRecord.
Definition at line 69 of file SRGRConversionParameters.h.
References SRGRConversionParameters().
inline |
attach_flag
Definition at line 115 of file SRGRConversionParameters.h.
References _attach_flag.
inline |
Definition at line 94 of file SRGRConversionParameters.h.
References _first_zero_doppler_time_day.
Referenced by ossimplugins::ossimEnvisatAsarModel::saveState().
inline |
Definition at line 108 of file SRGRConversionParameters.h.
References _first_zero_doppler_time_microsec.
inline |
Definition at line 101 of file SRGRConversionParameters.h.
References _first_zero_doppler_time_sec.
inline |
input_std_dev_flag
Definition at line 129 of file SRGRConversionParameters.h.
References _ground_range_origin.
inline |
input_mean_flag
Definition at line 122 of file SRGRConversionParameters.h.
References _slant_range_time.
inline |
input_gaps_flag
Definition at line 136 of file SRGRConversionParameters.h.
inlinevirtual |
Definition at line 61 of file SRGRConversionParameters.h.
| SRGRConversionParameters & ossimplugins::SRGRConversionParameters::operator= | ( | const SRGRConversionParameters & | rhs | ) |
Copy operator.
Definition at line 96 of file SRGRConversionParameters.cpp.
References _attach_flag, _first_zero_doppler_time_day, _first_zero_doppler_time_microsec, _first_zero_doppler_time_sec, _slant_range_time, and _srgr_coef.
inlinevirtual |
Definition at line 77 of file SRGRConversionParameters.h.
inlinevirtual |
Definition at line 85 of file SRGRConversionParameters.h.
friend |
Definition at line 24 of file SRGRConversionParameters.cpp.
friend |
Definition at line 46 of file SRGRConversionParameters.cpp.
| bool ossimplugins::SRGRConversionParameters::_attach_flag |
attach_flag
Definition at line 156 of file SRGRConversionParameters.h.
Referenced by get_attach_flag(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| int ossimplugins::SRGRConversionParameters::_first_zero_doppler_time_day |
Definition at line 139 of file SRGRConversionParameters.h.
Referenced by get_first_zero_doppler_time_day(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::SRGRConversionParameters::_first_zero_doppler_time_microsec |
Definition at line 152 of file SRGRConversionParameters.h.
Referenced by get_first_zero_doppler_time_microsec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| unsigned int ossimplugins::SRGRConversionParameters::_first_zero_doppler_time_sec |
Definition at line 148 of file SRGRConversionParameters.h.
Referenced by get_first_zero_doppler_time_sec(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::SRGRConversionParameters::_ground_range_origin |
input_std_dev_flag
Definition at line 164 of file SRGRConversionParameters.h.
Referenced by get_ground_range_origin(), ossimplugins::operator<<(), and ossimplugins::operator>>().
| float ossimplugins::SRGRConversionParameters::_slant_range_time |
input_mean_flag
Definition at line 160 of file SRGRConversionParameters.h.
Referenced by get_slant_range_time(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
| float ossimplugins::SRGRConversionParameters::_srgr_coef[5] |
input_gaps_flag
Definition at line 168 of file SRGRConversionParameters.h.
Referenced by get_srgr_coef(), ossimplugins::operator<<(), operator=(), ossimplugins::operator>>(), and SRGRConversionParameters().
