Class for computing a mask from an input image source and writing the mask file to disk. More...
#include <ossimBitMaskWriter.h>
| ossimBitMaskWriter () | |
| Default constructor typically used when reading a mask from disk. More... | |
| ~ossimBitMaskWriter () | |
| void | setBogusPixel (double pixel_value) |
| Sets the NULL pixel value to consider when computing mask: More... | |
| void | setBogusPixelRange (double min, double max) |
| Sets the range of pixels (inclusive) to be regarded as NULL pixels when computing mask. More... | |
| void | setStartingResLevel (ossim_uint32 res_level) |
| Sets the starting resolution level for the mask. More... | |
| void | generateMask (ossimRefPtr< ossimImageData > tile, ossim_uint32 rLevel) |
| Given a source's tile, derives the alpha mask and saves it in buffer for later writing to disk. More... | |
| bool | buildOverviews (ossim_uint32 total_num_rlevels) |
| For imagery that already has overviews built, but with artifact edge pixels (such as JP2- compressed data), it is preferred to build the mask overviews directly from the R0 mask. More... | |
| virtual bool | loadState (const ossimKeywordlist &spec, const char *prefix=0) |
| Computes and writes the mask file according to the specification in the KWL. More... | |
| virtual bool | open () |
| virtual void | close () |
| Writes the mask file to path specified. Returns TRUE if successful. More... | |
| virtual bool | canConnectMyInputTo (ossim_int32 myInputIndex, const ossimConnectableObject *object) const |
Public Member Functions inherited from ossimOutputSource | |
| ossimOutputSource (ossimObject *owner=NULL) | |
| ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
| virtual | ~ossimOutputSource () |
| virtual bool | open (const ossimString &outputName) |
| virtual void | setOutputName (const ossimString &outputName) |
| virtual const ossimString & | getOutputName () |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Static Public Attributes | |
| static const char * | BM_STARTING_RLEVEL_KW = "starting_rlevel" |
| static const char * | MASK_FILE_MAGIC_NUMBER = "OSSIM_BIT_MASK" |
| void | initializeFlipper () |
| Initializes the flipper (used for identifying pixels for masking) to default values. More... | |
| void | reset () |
| Deletes allocated buffers and resets all values to defaults. More... | |
| ossimIpt | computeImageSize (ossim_uint32 rlevel, ossimImageData *tile) const |
| Since overviews may not yet exist when the mask is being written, we must compute the size of the source image based on the original R0 image size. More... | |
Friends | |
| class | ossimBitMaskTileSource |
This class takes care of all details associated with computing, writing and reading the custom, bit-compressed OSSIM bit mask file format.
When the developer needs to mask an image, the following needs to be done:
Creating the Mask:
Using the Mask:
The OSSIM bit mask file contains a small header that consists of: magic number, starting res level, number of res levels num columns at starting res level, num rows at starting res level, num columns at 2nd res level, num rows at 2nd res level, etc., for all res levels <space> <compressed binary="" mask="" data>="">
The number of rows and columns represents the number of bytes in the mask, with each byte containing 8 alpha mask bits representing 8 pixels in the original image.
The mask is computed here using the specified values for bogus pixels. If a pixel in the source image is in the range of bogus values, a mask of 0 is assigned to that pixel, otherwise 1.
Definition at line 69 of file ossimBitMaskWriter.h.
| ossimBitMaskWriter::ossimBitMaskWriter | ( | ) |
Definition at line 29 of file ossimBitMaskWriter.cpp.
| ossimBitMaskWriter::~ossimBitMaskWriter | ( | ) |
Definition at line 39 of file ossimBitMaskWriter.cpp.
References close(), and isOpen().
| bool ossimBitMaskWriter::buildOverviews | ( | ossim_uint32 | total_num_rlevels | ) |
This method will build the remaining number of R-levels from the last defined mask buffer such that the total number of R-levels (counting R0) are represented. Returns TRUE if successful.
Definition at line 387 of file ossimBitMaskWriter.cpp.
References m_buffers, m_bufferSizes, m_startingResLevel, ossimIpt::x, x, ossimIpt::y, and y.
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 285 of file ossimBitMaskWriter.cpp.
Implements ossimOutputSource.
Definition at line 188 of file ossimBitMaskWriter.cpp.
References ossimString::chars(), ossimString::empty(), m_buffers, m_bufferSizes, m_startingResLevel, MASK_FILE_MAGIC_NUMBER, ossimNotify(), ossimNotifyLevel_WARN, reset(), ossimOutputSource::theOutputName, x, and y.
Referenced by ~ossimBitMaskWriter().
protected |
Since overviews may not yet exist when the mask is being written, we must compute the size of the mask buffer based on the original R0 image size.
Definition at line 361 of file ossimBitMaskWriter.cpp.
References ossimImageData::getHeight(), ossimImageData::getWidth(), m_imageSize, ossimIpt::x, and ossimIpt::y.
Referenced by generateMask().
Will try to connect this objects input to the passed in object.
It will return a valid index >= 0 if successful. Will use the getMyInputIndexToConnectTo method to implement the connection
Reimplemented from ossimConnectableObject.
Definition at line 295 of file ossimBitMaskWriter.cpp.
References ossimConnectableObject::accept(), ossimConnectableObject::connectMyInputTo(), ossimString::contains(), ossimConnectableObject::disconnectAllInputs(), ossimString::empty(), ossimRefPtr< T >::get(), ossimImageHandler::getBoundingRect(), ossimImageHandler::getFilename(), ossimCollectionVisitor::getObject(), initializeFlipper(), m_flipper, m_imageSize, ossimFilename::noExtension(), ossimFilename::setExtension(), ossimIrect::size(), ossimOutputSource::theOutputName, ossimRefPtr< T >::valid(), ossimVisitor::VISIT_CHILDREN, and ossimVisitor::VISIT_INPUTS.
Referenced by ossimOverviewSequencer::setImageHandler().
| void ossimBitMaskWriter::generateMask | ( | ossimRefPtr< ossimImageData > | tile, |
| ossim_uint32 | rLevel | ||
Definition at line 105 of file ossimBitMaskWriter.cpp.
References computeImageSize(), ossimRefPtr< T >::get(), ossimImageData::getImageRectangle(), ossimPixelFlipper::getTile(), ossimPixelFlipper::initialize(), initializeFlipper(), ossimImageData::isNull(), m_buffers, m_bufferSizes, m_flipper, m_memoryImage, m_startingResLevel, ossimMemoryImageSource::setImage(), ossimRefPtr< T >::valid(), ossimIpt::x, x, ossimIpt::y, and y.
protected |
Definition at line 259 of file ossimBitMaskWriter.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimRefPtr< T >::get(), m_flipper, m_memoryImage, ossimPixelFlipper::REPLACE_ONLY_FULL_TARGETS, ossimPixelFlipper::setReplacementMode(), ossimPixelFlipper::setReplacementValue(), ossimPixelFlipper::setTargetValue(), ossimConnectableObject::theInputObjectList, and ossimRefPtr< T >::valid().
Referenced by connectMyInputTo(), generateMask(), loadState(), setBogusPixel(), and setBogusPixelRange().
Definition at line 49 of file ossimBitMaskWriter.cpp.
References m_buffers.
Constructor accepts keywordlist with all info necessary to compute a mask.
The caller will still need to call writeMask().
Reimplemented from ossimOutputSource.
Definition at line 234 of file ossimBitMaskWriter.cpp.
References BM_STARTING_RLEVEL_KW, ossimString::empty(), ossimKeywordlist::find(), initializeFlipper(), ossimPixelFlipper::loadState(), m_flipper, m_startingResLevel, ossimKeywordNames::OUTPUT_FILE_KW, ossimOutputSource::theOutputName, and ossimString::toUInt32().
Allows a generic interface to open a consumer for writing. If you are a display writer then you would probably show the window or init the device context for writing.
Definition at line 57 of file ossimBitMaskWriter.cpp.
protected |
Definition at line 67 of file ossimBitMaskWriter.cpp.
References m_buffers, and m_bufferSizes.
Referenced by close().
| void ossimBitMaskWriter::setBogusPixel | ( | double | pixel_value | ) |
Definition at line 83 of file ossimBitMaskWriter.cpp.
References initializeFlipper(), m_flipper, ossimPixelFlipper::setTargetValue(), and ossimRefPtr< T >::valid().
| void ossimBitMaskWriter::setBogusPixelRange | ( | double | min, |
| double | max | ||
Definition at line 94 of file ossimBitMaskWriter.cpp.
References initializeFlipper(), m_flipper, max, min, ossimPixelFlipper::setTargetRange(), and ossimRefPtr< T >::valid().
inline |
Definition at line 87 of file ossimBitMaskWriter.h.
friend |
Definition at line 114 of file ossimBitMaskWriter.h.
static |
Definition at line 72 of file ossimBitMaskWriter.h.
Referenced by loadState().
protected |
Definition at line 128 of file ossimBitMaskWriter.h.
Referenced by buildOverviews(), close(), generateMask(), ossimBitMaskTileSource::getTile(), isOpen(), ossimBitMaskTileSource::isValidRLevel(), and reset().
protected |
Definition at line 129 of file ossimBitMaskWriter.h.
Referenced by buildOverviews(), close(), generateMask(), ossimBitMaskTileSource::getNumberOfLines(), ossimBitMaskTileSource::getNumberOfSamples(), and reset().
protected |
Definition at line 126 of file ossimBitMaskWriter.h.
Referenced by connectMyInputTo(), generateMask(), initializeFlipper(), loadState(), setBogusPixel(), and setBogusPixelRange().
protected |
Size of full res source image.
Definition at line 131 of file ossimBitMaskWriter.h.
Referenced by computeImageSize(), and connectMyInputTo().
protected |
Definition at line 127 of file ossimBitMaskWriter.h.
Referenced by generateMask(), and initializeFlipper().
protected |
Definition at line 130 of file ossimBitMaskWriter.h.
Referenced by buildOverviews(), close(), generateMask(), loadState(), and ossimBitMaskTileSource::setAssociatedMaskWriter().
static |
Definition at line 73 of file ossimBitMaskWriter.h.
Referenced by close(), and ossimBitMaskTileSource::open().
