Class ossimVertexExtractor. More...
#include <ossimVertexExtractor.h>
| ossimVertexExtractor (ossimImageSource *inputSource=NULL) | |
| void | setAreaOfInterest (const ossimIrect &rect) |
| virtual void | setOutputName (const ossimString &filename) |
| virtual bool | open () |
| virtual void | close () |
| virtual bool | execute () |
| virtual ossimObject * | getObjectInterface () |
| virtual ossimListenerManager * | getListenerManagerInterface () |
| virtual void | setPercentComplete (double percentComplete) |
| bool | canConnectMyInputTo (ossim_int32, const ossimConnectableObject *object) const |
| const vector< ossimIpt > & | getVertices () const |
Public Member Functions inherited from ossimOutputSource | |
| ossimOutputSource (ossimObject *owner=NULL) | |
| ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
| virtual | ~ossimOutputSource () |
| virtual bool | open (const ossimString &outputName) |
| virtual const ossimString & | getOutputName () |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| virtual | ~ossimVertexExtractor () |
| bool | scanForEdges () |
| bool | extractVertices () |
| template<class T1 > | |
| void | getMinAndIndex (T1 *start, T1 *end, T1 &minValue, ossim_int32 &offsetFromStart) |
| template<class T2 > | |
| void | getMaxAndIndex (T2 *start, T2 *end, T2 &maxValue, ossim_int32 &offsetFromStart) |
| bool | writeVertices () |
| ossimVertexExtractor (const ossimVertexExtractor &) | |
| Disallow copy constructor and operator=. More... | |
| const ossimVertexExtractor & | operator= (const ossimVertexExtractor &rhs) |
Public Types inherited from ossimProcessInterface | |
| enum | ossimProcessStatus { PROCESS_STATUS_UNKNOWN = 0, PROCESS_STATUS_EXECUTING = 1, PROCESS_STATUS_ABORTED = 2, PROCESS_STATUS_ABORT_REQUEST = 3, PROCESS_STATUS_NOT_EXECUTING = 4 } |
Class designed to scan the area of interest and detect the valid vertices of non null image data.
Definition at line 31 of file ossimVertexExtractor.h.
| ossimVertexExtractor::ossimVertexExtractor | ( | ossimImageSource * | inputSource = NULL | ) |
Definition at line 25 of file ossimVertexExtractor.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimIrect::makeNan(), ossimNotify(), ossimNotifyLevel_WARN, and theAreaOfInterest.
protectedvirtual |
inlineprotected |
inlinevirtual |
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 105 of file ossimVertexExtractor.h.
References PTR_CAST.
Closes "theFileStream".
Implements ossimOutputSource.
Definition at line 1903 of file ossimVertexExtractor.cpp.
References isOpen(), and theFileStream.
Referenced by open(), and setOutputName().
Calls protected methods scanForEdges, extractVertices, and writeVertices. Will error out if "theFilename" or "theAreaOfInterest has not been set or "theFilename" could not be opened.
Implements ossimProcessInterface.
Definition at line 66 of file ossimVertexExtractor.cpp.
Referenced by ossimVerticesFinderTool::execute().
protected |
Extracts the vertices of the source. Uses "theLeftEdge" and "theRightEdge" data members. Returns true on success, false on error.
Definition at line 311 of file ossimVertexExtractor.cpp.
inlinevirtual |
Definition at line 91 of file ossimVertexExtractor.h.
protected |
Definition at line 1930 of file ossimVertexExtractor.cpp.
protected |
Definition at line 1909 of file ossimVertexExtractor.cpp.
inlinevirtual |
Definition at line 38 of file ossimVertexExtractor.h.
inlinevirtual |
Definition at line 42 of file ossimVertexExtractor.h.
inlinevirtual |
Definition at line 89 of file ossimVertexExtractor.h.
inline |
Definition at line 112 of file ossimVertexExtractor.h.
Returns true if "theFileStream" is open, false if not.
Definition at line 1878 of file ossimVertexExtractor.cpp.
References theFileStream.
Referenced by close(), open(), and setOutputName().
Opens "theFilename" for output. Returns true on success, false on error. Notes:
Definition at line 1883 of file ossimVertexExtractor.cpp.
References ossimString::c_str(), close(), isOpen(), ossimFilename::NIL, ossimNotify(), ossimNotifyLevel_WARN, theFilename, and theFileStream.
inlineprotected |
Definition at line 153 of file ossimVertexExtractor.h.
protected |
Walks each line from left and right side detecting first non null pixel. Returns true on success, false on error.
Definition at line 115 of file ossimVertexExtractor.cpp.
| void ossimVertexExtractor::setAreaOfInterest | ( | const ossimIrect & | rect | ) |
Sets the area of interest in the source to extract the vertices from.
| rect | ossimIrec representing source area of interest. |
Definition at line 1873 of file ossimVertexExtractor.cpp.
References theAreaOfInterest.
Sets the name of the output keyword list file which the vertices will be dumped to.
| filename | ossimFilename representing the output file. |
Note:
Reimplemented from ossimOutputSource.
Definition at line 1864 of file ossimVertexExtractor.cpp.
References close(), isOpen(), ossimOutputSource::setOutputName(), and theFilename.
inlinevirtual |
Reimplemented from ossimProcessInterface.
Definition at line 97 of file ossimVertexExtractor.h.
References ossimListenerManager::fireEvent(), and ossimProcessInterface::setPercentComplete().
protected |
Writes the result to the output file (theFilename). Returns true on success, false on error.
Definition at line 1834 of file ossimVertexExtractor.cpp.
protected |
Definition at line 144 of file ossimVertexExtractor.h.
Referenced by ossimVertexExtractor(), and setAreaOfInterest().
protected |
Definition at line 145 of file ossimVertexExtractor.h.
protected |
Definition at line 146 of file ossimVertexExtractor.h.
protected |
Definition at line 148 of file ossimVertexExtractor.h.
Referenced by ~ossimVertexExtractor().
protected |
Definition at line 149 of file ossimVertexExtractor.h.
protected |
Definition at line 147 of file ossimVertexExtractor.h.
