| bool | canConnectMyInputTo (ossim_int32, const ossimConnectableObject *object) const |
| | required to be overriden by derived classes More...
| virtual void | setOutputName (const ossimString &out) |
| virtual void | setTitle (const ossimString &title)=0 |
| virtual bool | isMinimized () const =0 |
| virtual bool | isMaximized () const =0 |
| virtual void | refreshDisplay ()=0 |
| virtual void | minimize ()=0 |
| virtual void | maximize ()=0 |
| virtual void | show ()=0 |
| | ossimImageWriter (ossimObject *owner=NULL) |
| | ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed) |
| virtual | ~ossimImageWriter () |
| virtual bool | setViewingRect (const ossimIrect &aRect) |
| virtual ossimIrect | getAreaOfInterest () const |
| virtual void | setAreaOfInterest (const ossimIrect &inputAreaOfInterest) |
| | ossimOutputSource (ossimObject *owner=NULL) |
| | ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) |
| virtual | ~ossimOutputSource () |
| virtual bool | isOpen () const =0 |
| virtual bool | open ()=0 |
| virtual bool | open (const ossimString &outputName) |
| virtual const ossimString & | getOutputName () |
| virtual void | close ()=0 |
| | ossimSource (ossimObject *owner=0) |
| | ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) |
| virtual | ~ossimSource () |
| | Outputs theErrorStatus as an ossimErrorCode and an ossimString. More...
| | ossimConnectableObject (ossimObject *owner=0) |
| | Base constructor of this object. More...
| | ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) |
| | All connectable objects will have id's. More...
| | Will allow us to get this object's id. More...
| | Fetches the current owner, most likely a container but not limited to one. More...
| | Permits changing the object's owner. More...
| | will check the direction specified to see if all slots are full. More...
| | OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) |
| | OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) |
| | OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) |
| | OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) |
| | Return a valid index of the input list if the passed in object is found else return -1. More...
| | Return a valid index of the input list if the passed id is found else return -1. More...
| | Return a valid index of the output list if the passed in object is found else return -1. More...
| | Should return the first available index to connect to. More...
| | default implementation is to allow anyone to connect to us. More...
| | Will disconnect the object passed in. More...
| | Will disconnect the object at the given input index and generate a connection event. More...
| | Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More...
| | Will disconnect the object at the given output index and generate a connection event. More...
| | Will disconnect the output object. More...
| | Will disconnect all of the input objects. More...
| | Will disconnect all of the output objects. More...
| | Will try to connect this objects input to the passed in object. More...
| | Will connect the specified input to the passed in object. More...
| | Will try to connect this objects output to the passed in object. More...
| | Will disconnect itself from all inputs and reset to the passed in input list. More...
| | Will disconnect itself from all outputs and reset to the passed in output list. More...
| | Returns the number of input objects. More...
| | Return the number of output objects. More...
| | returns the object at the specified index. More...
| | Will set the number of inputs. More...
| | Will set the number of outputs. More...
| | OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) |
| | OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) |
| | Save the state of all inputs to a keyword list. More...
| | Inserts this object and all of its children and inputs into the container provided. More...
| | Moves the input connection matching id up one in the connection list. More...
| | Moves the input connection matching id down one in the connection list. More...
| | Moves the input connection matching id to the top of the connection list. More...
| | Moves the input connection matching id to the bottom of the connection list. More...
| | We will add a visitor interface for all connectable objects. More...
| | ossimObject () |
| | ossimReferenced () |
| | ossimReferenced (const ossimReferenced &) |
| | increment the reference count by one, indicating that this object has another pointer which is referencing it. More...
| | decrement the reference count by one, indicating that a pointer to this object is referencing it. More...
| | ossimListenerManager () |
| | ossimPropertyInterface () |
| | ossimErrorStatusInterface () |
| bool | hasError () const |
| | ossimDisplayInterface () |
| virtual | ~ossimDisplayInterface () |
| virtual void * | getDisplayDevice ()=0 |
| virtual void | getTitle (ossimString &title) const =0 |
| virtual ossimString | getTitle () const |
| | ossimConnectableObjectListener () |
| | ProcessEvent. More...
| virtual void | disconnectInputEvent (ossimConnectionEvent &) |
| virtual void | connectInputEvent (ossimConnectionEvent &) |
| virtual void | propertyEvent (ossimPropertyEvent &) |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| | ossimListener () |
| void | enableListener () |
| void | disableListener () |
