class for ground to image polynomial projection: (x,y,z)|->(x,y) polynom order is configurable More...
#include <ossimPolynomProjection.h>
| ossimPolynomProjection () | |
| Constructors. More... | |
| ossimPolynomProjection (const ossimPolynomProjection ©me) | |
| ~ossimPolynomProjection () | |
| virtual bool | operator== (const ossimProjection &projection) const |
| Basic operations. More... | |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| Projection / localization methods. More... | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &world_point) const |
| virtual bool | setupOptimizer (const ossimString &setup) |
| optimizableProjection implementation More... | |
| virtual double | optimizeFit (const ossimTieGptSet &tieSet, double *targetVariance=NULL) |
| const ossimPolynom< ossim_float64, 3 >::EXPT_SET & | getExpSet () const |
| accessors (not all of them inline) More... | |
| void | setExpSet (const ossimPolynom< ossim_float64, 3 >::EXPT_SET &nset) |
| void | setupDesiredExponents (int horizonal_ord, int vertical_ord) |
| bool | setupDesiredExponents (const ossimString &monoms) |
| added for easy setup More... | |
| const ossimPolynom< ossim_float64, 3 > & | getPolyLine () const |
| void | setPolyLine (const ossimPolynom< ossim_float64, 3 > &poly) |
| const ossimPolynom< ossim_float64, 3 > & | getPolySamp () const |
| void | setPolySamp (const ossimPolynom< ossim_float64, 3 > &poly) |
| const ossim_float64 & | getLonOffset () const |
| void | setLonOffset (const ossim_float64 &v) |
| const ossim_float64 & | getLonScale () const |
| void | setLonScale (const ossim_float64 &v) |
| const ossim_float64 & | getLatOffset () const |
| void | setLatOffset (const ossim_float64 &v) |
| const ossim_float64 & | getLatScale () const |
| void | setLatScale (const ossim_float64 &v) |
| const ossim_float64 & | getHgtOffset () const |
| void | setHgtOffset (const ossim_float64 &v) |
| const ossim_float64 & | getHgtScale () const |
| void | setHgtScale (const ossim_float64 &v) |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| needsInitialState() More... | |
| void | buildDerivatives () |
| protected methods More... | |
| void | buildLineDerivatives () |
| void | buildSampDerivatives () |
| bool | stringToExp (const ossimString &s, ossimPolynom< ossim_float64, 3 >::EXP_TUPLE &et) const |
| int | getSymbol (ossimString &ts, const ossimString &symbols) const |
| takes string of xyz monoms, x2z3 More... | |
| int | getExponent (ossimString &ts) const |
Protected Attributes | |
| ossimPolynom< ossim_float64, 3 >::EXPT_SET | theExpSet |
| desired exponents tuples set (for both line and sample polynoms) used for optimization More... | |
| ossimPolynom< ossim_float64, 3 > | thePolyLine |
| ground (3d) to image(2D) polynoms More... | |
| ossimPolynom< ossim_float64, 3 > | thePolySamp |
| xyz polynom More... | |
| ossimPolynom< ossim_float64, 3 > | thePolyLine_DLon |
| polynom partial derivatives More... | |
| ossimPolynom< ossim_float64, 3 > | thePolyLine_DLat |
| ossimPolynom< ossim_float64, 3 > | thePolySamp_DLon |
| ossimPolynom< ossim_float64, 3 > | thePolySamp_DLat |
| ossim_float64 | theLonOffset |
| normalization parameters More... | |
| ossim_float64 | theLonScale |
| ossim_float64 | theLatOffset |
| ossim_float64 | theLatScale |
| ossim_float64 | theHgtOffset |
| ossim_float64 | theHgtScale |
Definition at line 18 of file ossimPolynomProjection.h.
| ossimPolynomProjection::ossimPolynomProjection | ( | ) |
Constructors.
Definition at line 36 of file ossimPolynomProjection.cpp.
| ossimPolynomProjection::ossimPolynomProjection | ( | const ossimPolynomProjection & | copyme | ) |
Definition at line 47 of file ossimPolynomProjection.cpp.
| ossimPolynomProjection::~ossimPolynomProjection | ( | ) |
Definition at line 68 of file ossimPolynomProjection.cpp.
protected |
protected methods
Definition at line 498 of file ossimPolynomProjection.cpp.
References buildLineDerivatives(), and buildSampDerivatives().
Referenced by optimizeFit().
protected |
Definition at line 505 of file ossimPolynomProjection.cpp.
References ossimPolynom< T, DIM >::pdiff(), thePolyLine, thePolyLine_DLat, and thePolyLine_DLon.
Referenced by buildDerivatives(), and setPolyLine().
protected |
Definition at line 512 of file ossimPolynomProjection.cpp.
References ossimPolynom< T, DIM >::pdiff(), thePolySamp, thePolySamp_DLat, and thePolySamp_DLon.
Referenced by buildDerivatives(), and setPolySamp().
degreesOfFreedom() number of degrees of freedom (eg: 8 for bilinear, 6 for affine, 2 for translation) especially useful when not inheriting from AdjustableParameterInterface
Implements ossimOptimizableProjection.
Definition at line 526 of file ossimPolynomProjection.cpp.
References theExpSet.
inlinevirtual |
Implements ossimProjection.
Definition at line 39 of file ossimPolynomProjection.h.
protected |
Definition at line 745 of file ossimPolynomProjection.cpp.
References ossimString::afterPos(), and ossimString::size().
Referenced by stringToExp().
inline |
Definition at line 65 of file ossimPolynomProjection.h.
inline |
Definition at line 85 of file ossimPolynomProjection.h.
inline |
Definition at line 87 of file ossimPolynomProjection.h.
inline |
Definition at line 80 of file ossimPolynomProjection.h.
inline |
Definition at line 82 of file ossimPolynomProjection.h.
inline |
Definition at line 75 of file ossimPolynomProjection.h.
inline |
Definition at line 77 of file ossimPolynomProjection.h.
ACCESS METHODS:
Definition at line 262 of file ossimPolynomProjection.cpp.
References lineSampleToWorld(), theHgtOffset, theLatOffset, theLonOffset, worldToLineSample(), ossimDpt::x, and ossimDpt::y.
inline |
Definition at line 70 of file ossimPolynomProjection.h.
inline |
Definition at line 72 of file ossimPolynomProjection.h.
protected |
Definition at line 731 of file ossimPolynomProjection.cpp.
inlinevirtual |
Implementation of pure virtual ossimProjection::isAffectedByElevation method.
Definition at line 95 of file ossimPolynomProjection.h.
METHOD: lineSampleHeightToWorld This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. Useful for projections that are sensitive to elevation (such as sensor models).
Definition at line 135 of file ossimPolynomProjection.cpp.
References ossim::almostEqual(), ossimPolynom< T, DIM >::eval(), ossimGpt::hgt, ossim::isnan(), ossimGpt::lat, ossimGpt::lon, ossimNotify(), ossimNotifyLevel_WARN, theHgtOffset, theHgtScale, theLatOffset, theLatScale, theLonOffset, theLonScale, thePolyLine, thePolyLine_DLat, thePolyLine_DLon, thePolySamp, thePolySamp_DLat, thePolySamp_DLon, ossimDpt::x, and ossimDpt::y.
Referenced by lineSampleToWorld().
METHOD: lineSampleToWorld() Performs the inverse projection from line, sample to ground (world):
Definition at line 110 of file ossimPolynomProjection.cpp.
References ossimDpt::hasNans(), ossimGpt::height(), lineSampleHeightToWorld(), and ossimGpt::makeNan().
Referenced by getMetersPerPixel().
Reimplemented from ossimProjection.
Definition at line 364 of file ossimPolynomProjection.cpp.
References ossimProjection::loadState(), ossimNotify(), and ossimNotifyLevel_DEBUG.
Basic operations.
Definition at line 293 of file ossimPolynomProjection.cpp.
optimizeFit() adjusts projection to GLOBALLY fit best to ALL tie points (no outlier rejection) can select an optional threshold for accuracy
RETURNS : resulting image error variance of fitted model, or negative value for error
IMPORTANT : the unit for *targetVariance and the returned value is : meters^2 when useForward() is true OR pixel^2 if useForward() is false
Definition at line 566 of file ossimPolynomProjection.cpp.
References buildDerivatives(), DBL_EPSILON, ossimTieGptSet::getGroundBoundaries(), ossimTieGptSet::getTiePoints(), ossimGpt::hgt, ossimGpt::isLatNan(), ossimGpt::isLonNan(), ossim::isnan(), ossimGpt::lat, ossimPolynom< T, DIM >::LMSfit(), ossimGpt::lon, OSSIM_DEFAULT_MIN_PIX_DOUBLE, ossimNotify(), ossimNotifyLevel_FATAL, ossimTieGptSet::size(), theExpSet, theHgtOffset, theHgtScale, theLatOffset, theLatScale, theLonOffset, theLonScale, thePolyLine, and thePolySamp.
METHOD: origin() Returns projection's ground point origin. That is the GP corresponding to line=0, sample=0.
Definition at line 253 of file ossimPolynomProjection.cpp.
References theHgtOffset, theLatOffset, and theLonOffset.
Definition at line 309 of file ossimPolynomProjection.cpp.
METHODS: saveState, loadState Fulfills ossimObject base-class pure virtuals.
Definition at line 331 of file ossimPolynomProjection.cpp.
References ossimKeywordlist::add(), and ossimKeywordNames::TYPE_KW.
inline |
Definition at line 66 of file ossimPolynomProjection.h.
inline |
Definition at line 86 of file ossimPolynomProjection.h.
inline |
Definition at line 88 of file ossimPolynomProjection.h.
inline |
Definition at line 81 of file ossimPolynomProjection.h.
inline |
Definition at line 83 of file ossimPolynomProjection.h.
inline |
Definition at line 76 of file ossimPolynomProjection.h.
inline |
Definition at line 78 of file ossimPolynomProjection.h.
| void ossimPolynomProjection::setPolyLine | ( | const ossimPolynom< ossim_float64, 3 > & | poly | ) |
Definition at line 484 of file ossimPolynomProjection.cpp.
References buildLineDerivatives(), and thePolyLine.
| void ossimPolynomProjection::setPolySamp | ( | const ossimPolynom< ossim_float64, 3 > & | poly | ) |
Definition at line 491 of file ossimPolynomProjection.cpp.
References buildSampDerivatives(), and thePolySamp.
| void ossimPolynomProjection::setupDesiredExponents | ( | int | horizonal_ord, |
| int | vertical_ord | ||
Definition at line 557 of file ossimPolynomProjection.cpp.
References ossimPolynom< T, DIM >::addExpTupleRight(), theExpSet, and thePolySamp.
Referenced by setupOptimizer().
| bool ossimPolynomProjection::setupDesiredExponents | ( | const ossimString & | monoms | ) |
Definition at line 533 of file ossimPolynomProjection.cpp.
References ossimString::explode(), ossimNotify(), ossimNotifyLevel_FATAL, stringToExp(), and theExpSet.
Reimplemented from ossimOptimizableProjection.
Definition at line 519 of file ossimPolynomProjection.cpp.
References setupDesiredExponents().
protected |
Definition at line 685 of file ossimPolynomProjection.cpp.
References getExponent(), getSymbol(), ossimNotify(), ossimNotifyLevel_FATAL, ossimString::size(), ossimString::trim(), and ossimString::upcase().
Referenced by setupDesiredExponents().
inlinevirtual |
useForward() return true when it's better (more accurate / fast) to use forward (from ground to image) than inverse(from image to ground)
Definition at line 58 of file ossimPolynomProjection.h.
Definition at line 78 of file ossimPolynomProjection.cpp.
References ossim::almostEqual(), ossimPolynom< T, DIM >::eval(), ossimGpt::hgt, ossimGpt::isLatNan(), ossimGpt::isLonNan(), ossim::isnan(), ossimGpt::lat, ossimGpt::lon, ossimDpt::makeNan(), theHgtOffset, theHgtScale, theLatOffset, theLatScale, theLonOffset, theLonScale, thePolyLine, thePolySamp, ossimDpt::x, and ossimDpt::y.
protected |
Definition at line 102 of file ossimPolynomProjection.h.
Referenced by degreesOfFreedom(), optimizeFit(), and setupDesiredExponents().
protected |
Definition at line 125 of file ossimPolynomProjection.h.
Referenced by getMetersPerPixel(), lineSampleHeightToWorld(), optimizeFit(), origin(), and worldToLineSample().
protected |
Definition at line 126 of file ossimPolynomProjection.h.
Referenced by lineSampleHeightToWorld(), optimizeFit(), and worldToLineSample().
protected |
Definition at line 123 of file ossimPolynomProjection.h.
protected |
Definition at line 124 of file ossimPolynomProjection.h.
protected |
Definition at line 121 of file ossimPolynomProjection.h.
protected |
Definition at line 122 of file ossimPolynomProjection.h.
protected |
Definition at line 107 of file ossimPolynomProjection.h.
Referenced by buildLineDerivatives(), lineSampleHeightToWorld(), optimizeFit(), setPolyLine(), and worldToLineSample().
protected |
Definition at line 114 of file ossimPolynomProjection.h.
Referenced by buildLineDerivatives(), and lineSampleHeightToWorld().
protected |
Definition at line 113 of file ossimPolynomProjection.h.
protected |
xyz polynom
Definition at line 108 of file ossimPolynomProjection.h.
Referenced by buildSampDerivatives(), lineSampleHeightToWorld(), optimizeFit(), setPolySamp(), setupDesiredExponents(), and worldToLineSample().
protected |
Definition at line 116 of file ossimPolynomProjection.h.
Referenced by buildSampDerivatives(), and lineSampleHeightToWorld().
protected |
Definition at line 115 of file ossimPolynomProjection.h.
