#include <ossimBilinearProjection.h>
| ossimBilinearProjection () | |
| ossimBilinearProjection (const ossimBilinearProjection &rhs) | |
| ossimBilinearProjection (const ossimDpt &ul, const ossimDpt &ur, const ossimDpt &lr, const ossimDpt &ll, const ossimGpt &ulg, const ossimGpt &urg, const ossimGpt &lrg, const ossimGpt &llg) | |
| virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSampPt) const |
| virtual void | lineSampleToWorld (const ossimDpt &lineSampPt, ossimGpt &worldPt) const |
| virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
| virtual bool | operator== (const ossimProjection &projection) const |
| virtual ossim_float64 | setTiePoints (const std::vector< ossimDpt > &lsPt, const std::vector< ossimGpt > &geoPt) |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
| better go from image to ground, also means that errors variance are in squared meters More... | |
| void | getTiePoints (std::vector< ossimDpt > &lsPt, std::vector< ossimGpt > &geoPt) const |
| Access method for tie point information. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| needsInitialState() More... | |
| virtual | ~ossimBilinearProjection () |
| void | initializeBilinear () |
| bool | dPtsHaveNan () const |
| Checks theLineSamplePt for nans. More... | |
| bool | gPtsHaveNan () const |
| Checks theGeographicPt for nans. More... | |
| ossimDpt | midLineSamplePt () const |
Protected Attributes | |
| std::vector< ossimDpt > | theLineSamplePt |
| std::vector< ossimGpt > | theGeographicPt |
| ossimLeastSquaresBilin | theLatFit |
| ossimLeastSquaresBilin | theLonFit |
| ossimLeastSquaresBilin | theXFit |
| ossimLeastSquaresBilin | theYFit |
| bool | theInterpolationPointsHaveNanFlag |
| bool | theInverseSupportedFlag |
Definition at line 19 of file ossimBilinearProjection.h.
| ossimBilinearProjection::ossimBilinearProjection | ( | ) |
Definition at line 37 of file ossimBilinearProjection.cpp.
Referenced by dup().
| ossimBilinearProjection::ossimBilinearProjection | ( | const ossimBilinearProjection & | rhs | ) |
Definition at line 50 of file ossimBilinearProjection.cpp.
| ossimBilinearProjection::ossimBilinearProjection | ( | const ossimDpt & | ul, |
| const ossimDpt & | ur, | ||
| const ossimDpt & | lr, | ||
| const ossimDpt & | ll, | ||
| const ossimGpt & | ulg, | ||
| const ossimGpt & | urg, | ||
| const ossimGpt & | lrg, | ||
| const ossimGpt & | llg | ||
Definition at line 59 of file ossimBilinearProjection.cpp.
References initializeBilinear(), theGeographicPt, and theLineSamplePt.
protectedvirtual |
Definition at line 87 of file ossimBilinearProjection.cpp.
Implements ossimOptimizableProjection.
Definition at line 534 of file ossimBilinearProjection.cpp.
protected |
Definition at line 391 of file ossimBilinearProjection.cpp.
References theLineSamplePt.
Referenced by initializeBilinear(), and midLineSamplePt().
Implements ossimProjection.
Definition at line 91 of file ossimBilinearProjection.cpp.
References ossimBilinearProjection().
ACCESS METHODS:
Definition at line 313 of file ossimBilinearProjection.cpp.
References lineSampleToWorld(), ossimEcefVector::magnitude(), midLineSamplePt(), and ossimDpt::x.
| void ossimBilinearProjection::getTiePoints | ( | std::vector< ossimDpt > & | lsPt, |
| std::vector< ossimGpt > & | geoPt | ||
| ) | const |
Definition at line 552 of file ossimBilinearProjection.cpp.
References theGeographicPt, and theLineSamplePt.
protected |
Definition at line 410 of file ossimBilinearProjection.cpp.
References theGeographicPt.
Referenced by initializeBilinear(), and origin().
protected |
Definition at line 341 of file ossimBilinearProjection.cpp.
References ossimLeastSquaresBilin::addSample(), ossimLeastSquaresBilin::clear(), dPtsHaveNan(), ossimProjection::getRoundTripError(), gPtsHaveNan(), ossimDpt::length(), ossimLeastSquaresBilin::solveLS(), theGeographicPt, theInterpolationPointsHaveNanFlag, theInverseSupportedFlag, theLatFit, theLineSamplePt, theLonFit, theXFit, theYFit, x, and y.
Referenced by ossimBilinearProjection(), and setTiePoints().
inlinevirtual |
Implementation of pure virtual ossimProjection::isAffectedByElevation method.
Definition at line 90 of file ossimBilinearProjection.h.
METHOD: lineSampleHeightToWorld This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. Useful for projections that are sensitive to elevation (such as sensor models).
Definition at line 155 of file ossimBilinearProjection.cpp.
References ossimGpt::datum(), ossimGpt::hgt, ossim::isnan(), ossimGpt::lat, ossimGpt::lon, ossimLeastSquaresBilin::lsFitValue(), ossimGpt::makeNan(), theGeographicPt, theInterpolationPointsHaveNanFlag, theLatFit, theLonFit, ossimDpt::x, and ossimDpt::y.
Referenced by lineSampleToWorld().
METHOD: lineSampleToWorld() Performs the inverse projection from line, sample to ground (world):
Definition at line 146 of file ossimBilinearProjection.cpp.
References lineSampleHeightToWorld(), and ossim::nan().
Referenced by getMetersPerPixel().
Reimplemented from ossimProjection.
Definition at line 228 of file ossimBilinearProjection.cpp.
References ossimString::empty(), ossimKeywordlist::find(), ossimGpt::height(), ossimGpt::isHgtNan(), ossimProjection::loadState(), ossimKeywordlist::numberOf(), theGeographicPt, theLineSamplePt, ossimDpt::toPoint(), ossimGpt::toPoint(), ossimString::toString(), and ossim::toVector().
protected |
Definition at line 433 of file ossimBilinearProjection.cpp.
References dPtsHaveNan(), ossimDpt::makeNan(), theLineSamplePt, ossimDpt::x, x, ossimDpt::y, and y.
OPERATOR: == Compares this instance with arg projection.
Definition at line 308 of file ossimBilinearProjection.cpp.
optimizeFit() adjusts projection to GLOBALLY fit best to ALL tie points (no outlier rejection) can select an optional threshold for accuracy
RETURNS : resulting image error variance of fitted model, or negative value for error
IMPORTANT : the unit for *targetVariance and the returned value is : meters^2 when useForward() is true OR pixel^2 if useForward() is false
Definition at line 540 of file ossimBilinearProjection.cpp.
References ossimTieGptSet::getSlaveMasterPoints(), and setTiePoints().
METHOD: origin() Returns projection's ground point origin. That is the GP corresponding to line=0, sample=0.
Definition at line 96 of file ossimBilinearProjection.cpp.
References ossimGpt::datum(), gPtsHaveNan(), ossimGpt::height(), ossimGpt::latd(), ossimGpt::lond(), ossimGpt::makeNan(), and theGeographicPt.
Definition at line 459 of file ossimBilinearProjection.cpp.
References ossimNotify(), ossimNotifyLevel_INFO, ossimProjection::print(), theGeographicPt, and theLineSamplePt.
METHODS: saveState, loadState Fulfills ossimObject base-class pure virtuals.
Definition at line 180 of file ossimBilinearProjection.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), os2, ossimProjection::saveState(), theGeographicPt, theLineSamplePt, ossimString::toString(), and ossim::toStringList().
METHOD: setTiePoints add any number of tie points and calculate bilinear fit returns the ground error variance (=RMS^2), in meters^2
Definition at line 489 of file ossimBilinearProjection.cpp.
References ossimGpt::hgt, initializeBilinear(), ossimGpt::lat, ossimGpt::lon, ossimLeastSquaresBilin::lsFitValue(), ossimNotify(), ossimNotifyLevel_INFO, theGeographicPt, theLatFit, theLineSamplePt, and theLonFit.
Referenced by ossim_hdf5::getBilinearProjection(), and optimizeFit().
Reimplemented from ossimOptimizableProjection.
Definition at line 528 of file ossimBilinearProjection.cpp.
inlinevirtual |
useForward() return true when it's better (more accurate / fast) to use forward (from ground to image) than inverse(from image to ground)
Definition at line 79 of file ossimBilinearProjection.h.
METHOD: worldToLineSample() Performs the forward projection from ground point to line, sample.
Definition at line 125 of file ossimBilinearProjection.cpp.
References ossimGpt::latd(), ossimGpt::lond(), ossimLeastSquaresBilin::lsFitValue(), ossimDpt::makeNan(), theInterpolationPointsHaveNanFlag, theInverseSupportedFlag, theXFit, theYFit, ossimProjection::worldToLineSample(), ossimDpt::x, and ossimDpt::y.
protected |
Definition at line 119 of file ossimBilinearProjection.h.
Referenced by getTiePoints(), gPtsHaveNan(), initializeBilinear(), lineSampleHeightToWorld(), loadState(), origin(), ossimBilinearProjection(), print(), saveState(), and setTiePoints().
protected |
Definition at line 125 of file ossimBilinearProjection.h.
Referenced by initializeBilinear(), lineSampleHeightToWorld(), and worldToLineSample().
protected |
Definition at line 126 of file ossimBilinearProjection.h.
Referenced by initializeBilinear(), and worldToLineSample().
protected |
Definition at line 120 of file ossimBilinearProjection.h.
Referenced by initializeBilinear(), lineSampleHeightToWorld(), and setTiePoints().
protected |
Definition at line 118 of file ossimBilinearProjection.h.
Referenced by dPtsHaveNan(), getTiePoints(), initializeBilinear(), loadState(), midLineSamplePt(), ossimBilinearProjection(), print(), saveState(), and setTiePoints().
protected |
Definition at line 121 of file ossimBilinearProjection.h.
protected |
Definition at line 122 of file ossimBilinearProjection.h.
protected |
Definition at line 123 of file ossimBilinearProjection.h.
