#include <ossimRpcProjection.h>
Public Types | |
| enum | PolynomialType { A ='A', B ='B' } |
| ossimRpcProjection () | |
| ossimRpcProjection (const ossimRpcProjection ©_this) | |
| ~ossimRpcProjection () | |
| ossimRpcProjection & | operator= (const ossimRpcProjection &source) |
| void | initAdjustableParameters () |
| void | setAttributes (ossim_float64 theSampleOffset, ossim_float64 theLineOffset, ossim_float64 theSampleScale, ossim_float64 theLineScale, ossim_float64 theLatOffset, ossim_float64 theLonOffset, ossim_float64 theHeightOffset, ossim_float64 theLatScale, ossim_float64 theLonScale, ossim_float64 theHeightScale, const std::vector< double > &xNumeratorCoeffs, const std::vector< double > &xDenominatorCoeffs, const std::vector< double > &yNumeratorCoeffs, const std::vector< double > &yDenominatorCoeffs, PolynomialType polyType=B) |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &world_point) const |
| virtual bool | operator== (const ossimProjection &projection) const |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
| virtual double | optimizeFit (const ossimTieGptSet &tieSet, double *targetVariance=NULL) |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| needsInitialState() More... | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Provides the derived adjustable class an opportunity to update its state after a param change. More... | |
| Dumps the currently active adjustment to ostream. More... | |
| double | polynomial (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
| double | dPoly_dLat (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
| double | dPoly_dLon (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Protected Attributes | |
| PolynomialType | thePolyType |
| double | theLineScale |
| double | theSampScale |
| double | theLatScale |
| double | theLonScale |
| double | theHgtScale |
| double | theLineOffset |
| double | theSampOffset |
| double | theLatOffset |
| double | theLonOffset |
| double | theHgtOffset |
| double | theLineNumCoef [20] |
| double | theLineDenCoef [20] |
| double | theSampNumCoef [20] |
| double | theSampDenCoef [20] |
| double | theIntrackOffset |
| double | theCrtrackOffset |
| double | theIntrackScale |
| double | theCrtrackScale |
| double | theYawSkew |
| double | theCosMapRot |
| double | theSinMapRot |
| Enumerator | |
| A | |
| B | |
Definition at line 36 of file ossimRpcProjection.h.
| ossimRpcProjection::ossimRpcProjection | ( | ) |
CONSTRUCTORS:
Definition at line 87 of file ossimRpcProjection.cpp.
| ossimRpcProjection::ossimRpcProjection | ( | const ossimRpcProjection & | copy_this | ) |
Definition at line 109 of file ossimRpcProjection.cpp.
| ossimRpcProjection::~ossimRpcProjection | ( | ) |
Definition at line 149 of file ossimRpcProjection.cpp.
Reimplemented from ossimAdjustableParameterInterface.
Definition at line 924 of file ossimRpcProjection.cpp.
References ossimAdjustableParameterInterface::computeParameterOffset(), and theIntrackOffset.
protected |
METHOD: buildNormalEquation builds linearized system (LMS equivalent) A*dp = projResidue
A: symetric matrix = tJ*J dp: system parameter shift that we want to estimate projResidue = tJ * residue
t: transposition operator J = jacobian of transform relative to parameters p, transform can be forward() or inverse() jacobian is obtained via finite differences residue can be image (2D) or ground residue(3D)
TODO: use image/ground points covariance matrices
Definition at line 1050 of file ossimRpcProjection.cpp.
References A, ossimProjection::forward(), getForwardDeriv(), getInverseDeriv(), ossimAdjustableParameterInterface::getNumberOfAdjustableParameters(), ossimTieGptSet::getTiePoints(), ossimGpt::hgt, ossimProjection::inverse(), ossimGpt::lat, ossimGpt::lon, M_PI, ossimTieGptSet::size(), useForward(), ossimDpt::x, and ossimDpt::y.
degreesOfFreedom() number of degrees of freedom (eg: 8 for bilinear, 6 for affine, 2 for translation) especially useful when not inheriting from AdjustableParameterInterface
Implements ossimOptimizableProjection.
Definition at line 960 of file ossimRpcProjection.cpp.
References ossimAdjustableParameterInterface::getNumberOfAdjustableParameters(), and ossimAdjustableParameterInterface::isParameterLocked().
protected |
Definition at line 575 of file ossimRpcProjection.cpp.
References A, and thePolyType.
protected |
Definition at line 600 of file ossimRpcProjection.cpp.
inlinevirtual |
METHOD: dup() Returns pointer to a new instance, copy of this.
Implements ossimProjection.
Definition at line 112 of file ossimRpcProjection.h.
Implements ossimAdjustableParameterInterface.
Definition at line 156 of file ossimRpcProjection.cpp.
Definition at line 161 of file ossimRpcProjection.cpp.
METHOD: getForwardDeriv() gives forward() partial derivative regarding parameter parmIdx (>=0) default implementation is centered finite difference -should be reimplemented with formal derivative in child class
Definition at line 1002 of file ossimRpcProjection.cpp.
References ossimProjection::forward(), ossimAdjustableParameterInterface::getAdjustableParameter(), and ossimAdjustableParameterInterface::setAdjustableParameter().
Referenced by buildNormalEquation().
METHOD: getInverseDeriv() gives inverse() partial derivative regarding parameter parmIdx (>=0) default implementation is centered finite difference -should be reimplemented with formal derivative in child class
Definition at line 977 of file ossimRpcProjection.cpp.
References ossimAdjustableParameterInterface::getAdjustableParameter(), ossimGpt::hgt, ossimProjection::inverse(), ossimGpt::lat, ossimGpt::lon, M_PI, and ossimAdjustableParameterInterface::setAdjustableParameter().
ACCESS METHODS:
Definition at line 500 of file ossimRpcProjection.cpp.
References lineSampleToWorld(), theLineOffset, theSampOffset, ossimDpt::x, and ossimDpt::y.
protected |
METHOD: getResidue() returns ground opr image residue
Definition at line 1157 of file ossimRpcProjection.cpp.
References ossimProjection::forward(), ossimTieGptSet::getTiePoints(), ossimGpt::hgt, ossimProjection::inverse(), ossimGpt::lat, ossimGpt::lon, M_PI, ossimTieGptSet::size(), useForward(), ossimDpt::x, and ossimDpt::y.
Definition at line 906 of file ossimRpcProjection.cpp.
References ossimAdjustableParameterInterface::resizeAdjustableParameterArray().
protected |
Definition at line 1223 of file ossimRpcProjection.cpp.
References SVD().
Referenced by solveLeastSquares().
inlinevirtual |
Implementation of pure virtual ossimProjection::isAffectedByElevation method.
Definition at line 146 of file ossimRpcProjection.h.
METHOD: lineSampleHeightToWorld This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. Useful for projections that are sensitive to elevation (such as sensor models).
Definition at line 341 of file ossimRpcProjection.cpp.
Referenced by lineSampleToWorld().
METHOD: lineSampleToWorld() Performs the inverse projection from line, sample to ground (world):
Definition at line 316 of file ossimRpcProjection.cpp.
References ossimDpt::hasNans(), ossimGpt::height(), lineSampleHeightToWorld(), and ossimGpt::makeNan().
Referenced by getMetersPerPixel().
Reimplemented from ossimProjection.
Definition at line 715 of file ossimRpcProjection.cpp.
Referenced by optimizeFit(), and setupOptimizer().
| ossimRpcProjection & ossimRpcProjection::operator= | ( | const ossimRpcProjection & | source | ) |
Definition at line 167 of file ossimRpcProjection.cpp.
References ossimOptimizableProjection::operator=(), theHgtOffset, theHgtScale, theLatOffset, theLatScale, theLineDenCoef, theLineNumCoef, theLineOffset, theLineScale, theLonOffset, theLonScale, thePolyType, theSampDenCoef, theSampNumCoef, theSampOffset, and theSampScale.
OPERATOR: == Compares this instance with arg projection.
Definition at line 529 of file ossimRpcProjection.cpp.
optimizeFit() adjusts projection to GLOBALLY fit best to ALL tie points (no outlier rejection) can select an optional threshold for accuracy
RETURNS : resulting image error variance of fitted model, or negative value for error
IMPORTANT : the unit for *targetVariance and the returned value is : meters^2 when useForward() is true OR pixel^2 if useForward() is false
Definition at line 1024 of file ossimRpcProjection.cpp.
References ossimRpcSolver::getRmsError(), ossimRpcSolver::getRpcModel(), ossimTieGptSet::getSlaveMasterPoints(), loadState(), ossimNotify(), ossimNotifyLevel_FATAL, ossimRpcModel::saveState(), and ossimRpcSolver::solveCoefficients().
METHOD: origin() Returns projection's ground point origin. That is the GP corresponding to line=0, sample=0.
Definition at line 492 of file ossimRpcProjection.cpp.
References theHgtOffset, theLatOffset, and theLonOffset.
protected |
Definition at line 544 of file ossimRpcProjection.cpp.
METHOD: print() Extends base-class implementation. Dumps contents of object to ostream.
Definition at line 624 of file ossimRpcProjection.cpp.
METHODS: saveState, loadState Fulfills ossimObject base-class pure virtuals. Loads and saves geometry KWL files. Returns true if successful.
Definition at line 665 of file ossimRpcProjection.cpp.
| void ossimRpcProjection::setAttributes | ( | ossim_float64 | theSampleOffset, |
| ossim_float64 | theLineOffset, | ||
| ossim_float64 | theSampleScale, | ||
| ossim_float64 | theLineScale, | ||
| ossim_float64 | theLatOffset, | ||
| ossim_float64 | theLonOffset, | ||
| ossim_float64 | theHeightOffset, | ||
| ossim_float64 | theLatScale, | ||
| ossim_float64 | theLonScale, | ||
| ossim_float64 | theHeightScale, | ||
| const std::vector< double > & | xNumeratorCoeffs, | ||
| const std::vector< double > & | xDenominatorCoeffs, | ||
| const std::vector< double > & | yNumeratorCoeffs, | ||
| const std::vector< double > & | yDenominatorCoeffs, | ||
| PolynomialType | polyType = B |
Definition at line 195 of file ossimRpcProjection.cpp.
References theHgtOffset, theHgtScale, theLatOffset, theLatScale, theLineDenCoef, theLineNumCoef, theLineOffset, theLineScale, theLonOffset, theLonScale, thePolyType, theSampDenCoef, theSampNumCoef, theSampOffset, and theSampScale.
Reimplemented from ossimOptimizableProjection.
Definition at line 936 of file ossimRpcProjection.cpp.
References ossimKeywordlist::addFile(), ossimKeywordlist::clear(), ossimProjectionFactoryRegistry::createProjection(), ossimProjectionFactoryRegistry::instance(), loadState(), ossimProjection::saveState(), and ossimRefPtr< T >::valid().
protected |
solves Ax = r , with A symmetric positive definite A can be rank deficient size of A is typically between 10 and 100 rows
Definition at line 1213 of file ossimRpcProjection.cpp.
References A, invert(), and x.
inlinevirtual |
useForward() return true when it's better (more accurate / fast) to use forward (from ground to image) than inverse(from image to ground)
Definition at line 122 of file ossimRpcProjection.h.
Referenced by buildNormalEquation(), and getResidue().
METHOD: worldToLineSample() Overrides base class implementation. Directly computes line-sample from the polynomials.
Definition at line 257 of file ossimRpcProjection.cpp.
protected |
Definition at line 232 of file ossimRpcProjection.h.
protected |
Definition at line 228 of file ossimRpcProjection.h.
protected |
Definition at line 230 of file ossimRpcProjection.h.
protected |
Definition at line 214 of file ossimRpcProjection.h.
Referenced by operator=(), origin(), and setAttributes().
protected |
Definition at line 209 of file ossimRpcProjection.h.
Referenced by operator=(), and setAttributes().
protected |
Definition at line 227 of file ossimRpcProjection.h.
Referenced by adjustableParametersChanged().
protected |
Definition at line 229 of file ossimRpcProjection.h.
protected |
Definition at line 212 of file ossimRpcProjection.h.
protected |
Definition at line 207 of file ossimRpcProjection.h.
protected |
Definition at line 220 of file ossimRpcProjection.h.
protected |
Definition at line 219 of file ossimRpcProjection.h.
protected |
Definition at line 210 of file ossimRpcProjection.h.
Referenced by getMetersPerPixel(), operator=(), and setAttributes().
protected |
Definition at line 205 of file ossimRpcProjection.h.
protected |
Definition at line 213 of file ossimRpcProjection.h.
protected |
Definition at line 208 of file ossimRpcProjection.h.
protected |
Definition at line 200 of file ossimRpcProjection.h.
Referenced by dPoly_dLat(), dPoly_dLon(), operator=(), polynomial(), and setAttributes().
protected |
Definition at line 222 of file ossimRpcProjection.h.
protected |
Definition at line 221 of file ossimRpcProjection.h.
protected |
Definition at line 211 of file ossimRpcProjection.h.
protected |
Definition at line 206 of file ossimRpcProjection.h.
protected |
Definition at line 233 of file ossimRpcProjection.h.
protected |
Definition at line 231 of file ossimRpcProjection.h.
