ossimTiffTileSource.h
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: MIT
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Author: David Burken
8 // Frank Warmerdam ([email protected])
9 //
10 // Description:
11 //
12 // Contains class declaration for ossimTiffTileSource.
13 // ossimTiffTileSource is derived from ImageHandler which is derived from
14 // TileSource.
15 //*******************************************************************
16 // $Id$
17
18 #ifndef ossimTiffTileSource_HEADER
19 #define ossimTiffTileSource_HEADER 1
20
22 #include <ossim/base/ossimIrect.h>
23 #include <vector>
26 /*
27  * TIFF is defined as an incomplete type to hide the tiff library's internal
28  * data structures from clients.
29  */
30 typedef struct tiff TIFF;
31
32 class ossimImageData;
33 class ossimTiffOverviewTileSource;
34 class TiffStreamAdaptor;
36 {
37 public:
38  friend class TiffStreamAdaptor;
40  {
47  READ_U16_STRIP
48  };
49
51
52  virtual ossimString getLongName() const;
53  virtual ossimString getShortName() const;
54
58  virtual bool open(const ossimFilename& image_file);
59
67  bool open( std::shared_ptr<ossim::istream>& str,
68  const std::string& connectionString );
69
70  virtual void close();
71
78  ossim_uint32 resLevel=0);
79
92  virtual bool getTile(ossimImageData* result, ossim_uint32 resLevel=0);
93
98  virtual ossim_uint32 getNumberOfInputBands() const;
99  virtual ossim_uint32 getNumberOfOutputBands () const;
100
109  virtual bool isBandSelector() const;
110
119  virtual bool setOutputBandList(const std::vector<ossim_uint32>& band_list);
120
122  virtual void getOutputBandList(std::vector<ossim_uint32>& bandList) const;
123
128  virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel = 0) const;
129
134  virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel = 0) const;
135
139  virtual ossim_uint32 getNumberOfDirectories() const;
140
152
157  virtual bool saveState(ossimKeywordlist& kwl,
158  const char* prefix=0)const;
159
164  virtual bool loadState(const ossimKeywordlist& kwl,
165  const char* prefix=0);
166
167  virtual bool isOpen()const;
168
172  virtual ossimScalarType getOutputScalarType() const;
173
177  virtual ossim_uint32 getTileWidth() const;
178
182  virtual ossim_uint32 getTileHeight() const;
183
188  bool hasR0() const;
189
190  virtual ossim_float64 getMinPixelValue(ossim_uint32 band=0)const;
191  virtual ossim_float64 getMaxPixelValue(ossim_uint32 band=0)const;
192  virtual ossim_float64 getNullPixelValue(ossim_uint32 band=0)const;
193
194  virtual bool isValidRLevel(ossim_uint32 resLevel) const;
195
202  virtual ossim_uint32 getImageTileWidth() const;
203
210  virtual ossim_uint32 getImageTileHeight() const;
211
212  void setApplyColorPaletteFlag(bool flag);
213  bool getApplyColorPaletteFlag()const;
214
215  virtual void setProperty(ossimRefPtr<ossimProperty> property);
216  virtual ossimRefPtr<ossimProperty> getProperty(const ossimString& name)const;
217  virtual void getPropertyNames(std::vector<ossimString>& propertyNames)const;
218  bool isColorMapped() const;
219
220  virtual std::ostream& print(std::ostream& os) const;
221
223  {
224  return theTiffPtr;
225  }
226 #if 0
227
237 #endif
238 protected:
239  virtual ~ossimTiffTileSource();
249  bool open();
250
251  // Must be protected for derived ossimTerraSarTiffReader.
253
254
255 private:
256
261  void adjustToStartOfTile(ossimIpt& pt) const;
262
268  ossim_uint32 getCurrentTiffRLevel() const;
269
270  ossimString getReadMethod(ossim_uint32 directory) const;
271
272  bool loadTile(const ossimIrect& tile_rect,
273  const ossimIrect& clip_rect,
274  ossimImageData* result);
275
276  bool loadFromRgbaU8Tile(const ossimIrect& tile_rect,
277  const ossimIrect& clip_rect,
278  ossimImageData* result);
279
280  bool loadFromRgbaU8Strip(const ossimIrect& tile_rect,
281  const ossimIrect& clip_rect,
282  ossimImageData* result);
283
284  bool loadFromRgbaU8aStrip(const ossimIrect& tile_rect,
285  const ossimIrect& clip_rect,
286  ossimImageData* result);
287
288  bool loadFromU16Strip(const ossimIrect& clip_rect,
289  ossimImageData* result);
290
291  bool loadFromScanLine(const ossimIrect& clip_rect,
292  ossimImageData* result);
293
294  bool loadFromTile(const ossimIrect& clip_rect,
295  ossimImageData* result);
296
297  void setReadMethod();
298
304  bool setTiffDirectory(ossim_uint16 directory);
305
306  void populateLut();
307
312  void validateMinMaxNull();
313
329  bool isPowerOfTwoDecimation(ossim_uint32 dir) const;
330
332  void allocateTile();
333
338  bool allocateBuffer();
339
341
348
352
356
363
364  // Things we need from each directory as they can be different.
365  std::vector<ossim_uint32> theImageWidth;
366  std::vector<ossim_uint32> theImageLength;
367  std::vector<ReadMethod> theReadMethod;
368  std::vector<ossim_uint16> thePlanarConfig;
369  std::vector<ossim_uint16> thePhotometric;
370  std::vector<ossim_uint32> theRowsPerStrip;
371  std::vector<ossim_uint32> theImageTileWidth;
372  std::vector<ossim_uint32> theImageTileLength;
373  std::vector<ossim_uint32> theImageDirectoryList;
374
377  std::vector<ossim_uint32> theOutputBandList;
378  std::shared_ptr<ossim::TiffIStreamAdaptor> m_streamAdaptor;
379
380 TYPE_DATA
381 };
382
383 #endif /* #ifndef ossimTiffTileSource_HEADER */
virtual bool open()=0
Pure virtual open.
std::vector< ossim_uint32 > theImageTileWidth
std::vector< ossim_uint32 > theOutputBandList
ossim_float64 theMaxSampleValue
ossim_uint32 theCurrentTiffRlevel
ossim_uint32 theCurrentTileWidth
#define OSSIMDLLEXPORT
std::shared_ptr< ossim::TiffIStreamAdaptor > m_streamAdaptor
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
std::vector< ossim_uint32 > theRowsPerStrip
Returns the default processing tile height.
unsigned short ossim_uint16
ossim_uint32 theCurrentTileHeight
Definition: ossimObject.cpp:48
ossim_uint16 theSamplesPerPixel
Returns the default processing tile width.
ossim_uint16 theNumberOfDirectories
std::vector< ossim_uint32 > theImageDirectoryList
virtual ossim_uint32 getNumberOfDecimationLevels() const
This returns the total number of decimation levels.
Determines if the passed in reslution level is valid.
virtual bool isOpen() const =0
Retuns the min pixel value.
double ossim_float64
virtual void getOutputBandList(std::vector< ossim_uint32 > &bandList) const
Initializes bandList.
ossim_float64 theNullSampleValue
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
#define TYPE_DATA
Definition: ossimRtti.h:339
virtual ossim_uint32 getImageTileHeight() const =0
unsigned int ossim_uint32
struct tiff TIFF
Definition: ossimObject.cpp:53
ossim_float64 theMinSampleValue
Indicates whether or not the image handler can control output band selection via the setOutputBandLis...
std::vector< ossim_uint32 > theImageLength
ossimScalarType
virtual ossim_uint32 getImageTileWidth() const =0
ossimScalarType theScalarType
std::vector< ossim_uint16 > thePhotometric
std::vector< ossim_uint16 > thePlanarConfig
This class defines an abstract Handler which all image handlers(loaders) should derive from...
std::vector< ossim_uint32 > theImageTileLength
ossim_uint16 theCurrentDirectory
ossim_uint16 theSampleFormatUnit
std::vector< ReadMethod > theReadMethod
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
std::vector< ossim_uint32 > theImageWidth
virtual ossim_uint32 getNumberOfInputBands() const =0
virtual bool setOutputBandList(const std::vector< ossim_uint32 > &band_list)
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled...
unsigned char ossim_uint8
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
int ossim_int32
