class ossimNBandLutDataObject More...
#include <ossimNBandLutDataObject.h>
Public Types | |
| typedef ossim_int32 | LUT_ENTRY_TYPE |
| ossimNBandLutDataObject (ossim_uint32 numberOfEntries=0, ossim_uint32 numberOfBands=0, ossimScalarType bandScalarType=OSSIM_UINT8, ossim_int32 nullPixelIndex=-1) | |
| ossimNBandLutDataObject (const ossimNBandLutDataObject &lut) | |
| ossimObject * | dup () const |
| void | create (ossim_uint32 numberOfEntries, ossim_uint32 numberOfBands=3) |
| const LUT_ENTRY_TYPE * | operator[] (ossim_uint32 idx) const |
| LUT_ENTRY_TYPE * | operator[] (ossim_uint32 idx) |
| const LUT_ENTRY_TYPE * | operator[] (ossim_int32 idx) const |
| LUT_ENTRY_TYPE * | operator[] (ossim_int32 idx) |
| const LUT_ENTRY_TYPE * | operator[] (double normalizedIndex) const |
| LUT_ENTRY_TYPE * | operator[] (double normalizedIndex) |
| bool | hasNullPixelIndex () const |
| void | getMinMax (ossim_uint32 band, LUT_ENTRY_TYPE &minValue, LUT_ENTRY_TYPE &maxValue) |
| Will return the min max value for a given band. More... | |
| ossim_int32 | getFirstNullAlphaIndex () const |
| void | setNullPixelIndex (ossim_int32 idx) |
| Allows you to specify which entry is to be designated as an invalid entry. More... | |
| ossim_int32 | getNullPixelIndex () const |
| ossim_uint32 | getNumberOfBands () const |
| ossim_uint32 | getNumberOfEntries () const |
| ossim_uint32 | findIndex (ossim_int32 *values) const |
| This method gives you a way to find an entry index closest to the passed in band values. More... | |
| ossim_uint32 | findIndex (ossim_int32 *values, ossim_uint32 size) const |
| void | clearLut () |
| Will do a simple memset to '\0' all. More... | |
| const ossimNBandLutDataObject & | operator= (const ossimNBandLutDataObject &lut) |
| does a deep copy from the passed in lut to the object. More... | |
| bool | operator== (const ossimNBandLutDataObject &lut) const |
| Determines if the state of this lut is identical to the passed in lut. More... | |
| bool | open (const ossimFilename &lutFile) |
| Reads in an external lut file. More... | |
| std::vector< ossimString > | getEntryLabels (ossim_uint32 band) |
| void | setEntryLables (ossim_uint32 band, std::vector< ossimString > entryLabels) |
| Loads the state of the object by reading in the keywords listed in the save state. More... | |
| ossimObject () | |
| virtual | ~ossimNBandLutDataObject () |
Protected Attributes | |
| LUT_ENTRY_TYPE * | theLut |
| ossim_uint32 | theNumberOfEntries |
| ossim_uint32 | theNumberOfBands |
| ossimScalarType | theBandScalarType |
| ossim_int32 | theNullPixelIndex |
| std::map< ossim_uint32, std::vector< ossimString > > | m_entryLabels |
Friends | |
| std::ostream & | operator<< (std::ostream &out, const ossimNBandLutDataObject &lut) |
Sample CADRG LUT taken from an arbitrary CADRG image entry. This is a keywordlist support by the loadstate of this class.
entry0: 25 39 116 entry1: 245 242 242 entry10: 92 89 115 entry100: 74 55 85 entry101: 233 165 53 entry102: 75 2 4 entry103: 162 118 42 entry104: 233 159 130 entry105: 189 129 40 entry106: 154 109 66 entry107: 145 97 85 entry108: 121 86 31 entry109: 238 151 118 entry11: 52 31 76 entry110: 239 167 42 entry111: 236 137 100 entry112: 179 112 88 entry113: 92 37 33 entry114: 121 66 24 entry115: 120 133 151 entry116: 76 92 192 entry117: 36 50 117 entry118: 57 75 191 entry119: 125 45 50 entry12: 235 217 204 entry120: 102 65 81 entry121: 172 148 199 entry122: 204 145 95 entry123: 81 19 5 entry124: 91 4 1 entry125: 109 54 31 entry126: 137 114 118 entry127: 230 150 52 entry128: 82 38 87 entry129: 190 120 76 entry13: 244 218 172 entry130: 170 109 45 entry131: 95 20 22 entry132: 150 80 61 entry133: 225 122 82 entry134: 122 37 16 entry135: 146 88 49 entry136: 122 94 122 entry137: 230 135 63 entry138: 137 73 75 entry139: 119 46 29 entry14: 189 167 141 entry140: 190 142 128 entry141: 242 216 187 entry142: 176 125 95 entry143: 193 117 143 entry144: 19 0 0 entry145: 12 1 42 entry146: 24 4 26 entry147: 38 40 52 entry148: 8 24 175 entry149: 40 23 45 entry15: 245 213 142 entry150: 39 11 58 entry151: 10 0 22 entry152: 236 148 41 entry153: 101 41 11 entry154: 230 113 67 entry155: 148 44 46 entry156: 225 144 133 entry157: 115 2 13 entry158: 159 79 49 entry159: 164 95 33 entry16: 246 241 205 entry160: 97 6 22 entry161: 175 90 133 entry162: 112 23 20 entry163: 105 22 6 entry164: 148 59 33 entry165: 215 118 104 entry166: 211 122 41 entry167: 233 129 34 entry168: 153 73 25 entry169: 208 102 39 entry17: 240 215 89 entry170: 206 101 133 entry171: 229 113 96 entry172: 127 16 25 entry173: 224 104 28 entry174: 171 76 74 entry175: 221 94 78 entry176: 229 86 94 entry177: 213 80 57 entry178: 161 44 36 entry179: 155 54 19 entry18: 115 92 157 entry180: 130 25 5 entry181: 150 29 24 entry182: 198 54 34 entry183: 224 61 70 entry184: 213 82 37 entry185: 186 28 31 entry186: 200 64 15 entry187: 110 2 2 entry188: 195 38 12 entry189: 151 6 8 entry19: 160 163 37 entry190: 193 13 10 entry191: 205 1 3 entry192: 44 62 193 entry193: 35 14 16 entry194: 15 30 118 entry195: 28 47 189 entry196: 25 3 80 entry197: 7 16 118 entry198: 33 10 6 entry199: 39 24 95 entry2: 216 212 237 entry20: 38 29 21 entry200: 82 58 159 entry201: 55 29 142 entry202: 33 4 23 entry203: 17 14 36 entry204: 58 26 41 entry205: 11 13 14 entry206: 74 87 85 entry207: 50 60 41 entry208: 119 123 98 entry209: 193 187 172 entry21: 208 202 156 entry210: 124 126 128 entry211: 47 68 84 entry212: 110 119 60 entry213: 63 145 121 entry214: 154 166 147 entry215: 107 156 104 entry22: 242 202 152 entry23: 168 148 140 entry24: 31 22 25 entry25: 245 205 114 entry26: 245 191 137 entry27: 175 161 172 entry28: 17 6 11 entry29: 172 170 137 entry3: 247 230 113 entry30: 51 27 20 entry31: 239 210 73 entry32: 185 176 129 entry33: 35 2 13 entry34: 60 52 51 entry35: 101 78 70 entry36: 141 124 101 entry37: 206 184 107 entry38: 244 174 106 entry39: 82 98 136 entry4: 246 231 132 entry40: 190 191 239 entry41: 241 188 161 entry42: 67 51 38 entry43: 244 184 122 entry44: 211 201 142 entry45: 61 27 16 entry46: 182 182 82 entry47: 243 188 87 entry48: 86 83 60 entry49: 61 40 43 entry5: 204 198 166 entry50: 146 141 93 entry51: 44 4 4 entry52: 231 210 51 entry53: 85 74 39 entry54: 197 169 127 entry55: 182 151 60 entry56: 121 98 73 entry57: 243 182 145 entry58: 58 18 21 entry59: 241 157 91 entry6: 2 0 2 entry60: 59 4 1 entry61: 155 162 223 entry62: 154 133 80 entry63: 73 21 16 entry64: 195 183 116 entry65: 76 51 29 entry66: 234 181 63 entry67: 58 59 98 entry68: 42 22 79 entry69: 134 143 219 entry7: 204 204 239 entry70: 106 117 205 entry71: 48 65 117 entry72: 63 54 117 entry73: 125 93 62 entry74: 137 138 41 entry75: 104 68 59 entry76: 113 99 41 entry77: 76 30 11 entry78: 239 184 48 entry79: 161 129 98 entry8: 31 4 66 entry80: 241 170 126 entry81: 145 109 105 entry82: 207 163 116 entry83: 79 41 40 entry84: 175 138 41 entry85: 10 0 56 entry86: 180 151 77 entry87: 72 12 24 entry88: 242 154 105 entry89: 91 26 15 entry9: 246 238 162 entry90: 160 118 53 entry91: 228 166 141 entry92: 231 160 69 entry93: 61 2 11 entry94: 132 83 60 entry95: 86 46 24 entry96: 243 143 86 entry97: 108 60 46 entry98: 109 76 38 entry99: 96 86 84 null_value: -1 number_bands: 3 number_entries: 216 scalar_type: ossim_uint8 type: ossimNBandLutDataObject
NOTES:
Definition at line 259 of file ossimNBandLutDataObject.h.
Definition at line 263 of file ossimNBandLutDataObject.h.
| ossimNBandLutDataObject::ossimNBandLutDataObject | ( | ossim_uint32 | numberOfEntries = 0, |
| ossim_uint32 | numberOfBands = 0, |
| ossimScalarType | bandScalarType = OSSIM_UINT8, |
| ossim_int32 | nullPixelIndex = -1 |
Will allocate 256 values for the color table
Definition at line 51 of file ossimNBandLutDataObject.cpp.
References create().
| ossimNBandLutDataObject::ossimNBandLutDataObject | ( | const ossimNBandLutDataObject & | lut | ) |
Definition at line 64 of file ossimNBandLutDataObject.cpp.
protectedvirtual |
Definition at line 75 of file ossimNBandLutDataObject.cpp.
References m_entryLabels, theLut, theNumberOfBands, and theNumberOfEntries.
| void ossimNBandLutDataObject::clearLut | ( | ) |
Definition at line 150 of file ossimNBandLutDataObject.cpp.
References theLut, theNumberOfBands, and theNumberOfEntries.
Referenced by loadState().
| void ossimNBandLutDataObject::create | ( | ossim_uint32 | numberOfEntries, |
| ossim_uint32 | numberOfBands = 3 |
Definition at line 87 of file ossimNBandLutDataObject.cpp.
Referenced by ossimNitfImageHeader::createLut(), loadState(), operator=(), and ossimNBandLutDataObject().
inlinevirtual |
Definition at line 275 of file ossimNBandLutDataObject.h.
Referenced by ossimGdalWriter::setLut(), and ossimTiffWriter::setLut().
| ossim_uint32 ossimNBandLutDataObject::findIndex | ( | ossim_int32 * | values | ) | const |
| values | Is an array of band values. This array must be equal to the number of bands for the lut. |
Definition at line 108 of file ossimNBandLutDataObject.cpp.
References theNumberOfBands.
Referenced by ossimNBandToIndexFilter::convertInputTileToOutputTemplate().
| ossim_uint32 ossimNBandLutDataObject::findIndex | ( | ossim_int32 * | values, |
| ossim_uint32 | size | ||
| ) | const |
| values | Is an array of band values. |
| size | Size of values array. Note if size is less than the LUT number of bands, the trailing bands get dropped. This allows finding an index dropping the alpha channel. |
Definition at line 114 of file ossimNBandLutDataObject.cpp.
References DBL_EPSILON, distance(), size, theLut, theNumberOfBands, and theNumberOfEntries.
| std::vector< ossimString > ossimNBandLutDataObject::getEntryLabels | ( | ossim_uint32 | band | ) |
Definition at line 376 of file ossimNBandLutDataObject.cpp.
References m_entryLabels.
Referenced by ossimGdalWriter::writeColorMap().
| ossim_int32 ossimNBandLutDataObject::getFirstNullAlphaIndex | ( | ) | const |
Currently only works on 4 band data. May consider adding an alpha channel class data member in the future.
Definition at line 189 of file ossimNBandLutDataObject.cpp.
Referenced by ossimGdalTileSource::setPreservePaletteIndexesFlag().
| void ossimNBandLutDataObject::getMinMax | ( | ossim_uint32 | band, |
| ossimNBandLutDataObject::LUT_ENTRY_TYPE & | minValue, | ||
| ossimNBandLutDataObject::LUT_ENTRY_TYPE & | maxValue | ||
| band | band number to query. This is 0 based so the first band is indicated by the value of 0. |
| minValue | is the minimum value returned for the passed in band |
| maxValue | is the maximum value returned for the passed in band |
Definition at line 158 of file ossimNBandLutDataObject.cpp.
References theLut, theNullPixelIndex, theNumberOfBands, and theNumberOfEntries.
Referenced by ossimNBandToIndexFilter::initialize().
inline |
Definition at line 379 of file ossimNBandLutDataObject.h.
Referenced by ossimNBandToIndexFilter::getNullPixelValue(), ossimGdalTileSource::getNullPixelValue(), and ossimNBandToIndexFilter::initialize().
inline |
Definition at line 384 of file ossimNBandLutDataObject.h.
Referenced by ossimNBandToIndexFilter::convertInputTileToOutputTemplate(), ossimNBandToIndexFilter::getNumberOfOutputBands(), ossimNBandToIndexFilter::initialize(), ossimNitfTileSource::lutUncompress(), ossimNitfTileSource::vqUncompressC4(), and ossimGdalWriter::writeColorMap().
inline |
Definition at line 389 of file ossimNBandLutDataObject.h.
Referenced by ossimGdalTileSource::getMaxPixelValue(), ossimNBandToIndexFilter::getOutputScalarType(), ossimNBandToIndexFilter::initialize(), ossimNBandToIndexFilter::isSourceEnabled(), ossimGdalWriter::writeColorMap(), and ossimTiffWriter::writeTiffTags().
inline |
Definition at line 342 of file ossimNBandLutDataObject.h.
| kwl | The keywordlist to extract the classes keywords from to restore its state. |
| prefix | Optional prefix value used to prefix each keyword. |
Definition at line 299 of file ossimNBandLutDataObject.cpp.
References ossimKeywordlist::addFile(), ossimString::c_str(), clearLut(), create(), ossimFilename::exists(), ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), ossimLookUpTable::getEntryNumber(), ossimScalarTypeLut::instance(), ossimLookUpTable::NOT_FOUND, ossimKeywordNames::NULL_VALUE_KW, ossimKeywordNames::NUMBER_BANDS_KW, ossimKeywordNames::NUMBER_ENTRIES_KW, theBandScalarType, theLut, theNullPixelIndex, theNumberOfBands, theNumberOfEntries, ossimString::toInt32(), ossimString::toString(), and ossimString::trim().
Referenced by ossimNBandToIndexFilter::loadState(), open(), and ossimNBandToIndexFilter::setProperty().
| bool ossimNBandLutDataObject::open | ( | const ossimFilename & | lutFile | ) |
The external file is in a keywordlist format specified by the saveState.
Definition at line 291 of file ossimNBandLutDataObject.cpp.
References ossimKeywordlist::addFile(), and loadState().
Referenced by ossimGdalWriter::setProperty(), and ossimTiffWriter::setProperty().
| const ossimNBandLutDataObject & ossimNBandLutDataObject::operator= | ( | const ossimNBandLutDataObject & | lut | ) |
| lut | The lut to copy. |
Definition at line 208 of file ossimNBandLutDataObject.cpp.
References create(), theBandScalarType, theLut, theNullPixelIndex, theNumberOfBands, and theNumberOfEntries.
| bool ossimNBandLutDataObject::operator== | ( | const ossimNBandLutDataObject & | lut | ) | const |
| lut | Checks equality of the this object to the lut parameter. |
Definition at line 229 of file ossimNBandLutDataObject.cpp.
References theBandScalarType, theLut, theNullPixelIndex, theNumberOfBands, and theNumberOfEntries.
inline |
Definition at line 281 of file ossimNBandLutDataObject.h.
inline |
Definition at line 290 of file ossimNBandLutDataObject.h.
inline |
Definition at line 299 of file ossimNBandLutDataObject.h.
inline |
Definition at line 308 of file ossimNBandLutDataObject.h.
inline |
Definition at line 317 of file ossimNBandLutDataObject.h.
inline |
| normalizedIndex | If a double precision value is passed in then it is assumed to be in normalized space where the value ranges from 0.0 to 1.0 |
Definition at line 332 of file ossimNBandLutDataObject.h.
Keywords:
entry0: entry1: : entry<number_entries-1>: null_value: -1 number_bands: 3 number_entries: 216 scalar_type: ossim_uint8 type: ossimNBandLutDataObject
Where entry<idx> is repeasted for each entry number where idx start from 0 and goes to number_entries-1 each entry must have number_bands values.
| kwl | The keyword list to store the keywords to. Each keyword could be prefixed by an optional prefix parameter. |
| prefix | The optional prefix parameter used to prefix each keyword. |
Definition at line 247 of file ossimNBandLutDataObject.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimKeywordNames::ENTRY_KW, ossimObject::getClassName(), ossimScalarTypeLut::instance(), ossimKeywordNames::NULL_VALUE_KW, ossimKeywordNames::NUMBER_BANDS_KW, ossimKeywordNames::NUMBER_ENTRIES_KW, ossimKeywordNames::SCALAR_TYPE_KW, theBandScalarType, theLut, theNullPixelIndex, theNumberOfBands, theNumberOfEntries, ossimString::toString(), and ossimKeywordNames::TYPE_KW.
Referenced by ossimInfo::getImagePalette(), and ossimNBandToIndexFilter::saveState().
| void ossimNBandLutDataObject::setEntryLables | ( | ossim_uint32 | band, |
| std::vector< ossimString > | entryLabels | ||
Definition at line 386 of file ossimNBandLutDataObject.cpp.
Referenced by ossimGdalTileSource::populateLut().
inline |
Note: setting this to -1 indicates no null entry is set.
| idx | is the entry number that will be used for the null value |
Definition at line 372 of file ossimNBandLutDataObject.h.
Referenced by ossimGdalTileSource::populateLut(), and ossimGdalTileSource::setPreservePaletteIndexesFlag().
friend |
Definition at line 23 of file ossimNBandLutDataObject.cpp.
protected |
Definition at line 484 of file ossimNBandLutDataObject.h.
Referenced by getEntryLabels(), setEntryLables(), and ~ossimNBandLutDataObject().
protected |
Definition at line 482 of file ossimNBandLutDataObject.h.
Referenced by loadState(), operator=(), operator==(), and saveState().
protected |
Definition at line 479 of file ossimNBandLutDataObject.h.
Referenced by clearLut(), create(), findIndex(), getFirstNullAlphaIndex(), getMinMax(), loadState(), operator<<(), operator=(), operator==(), saveState(), and ~ossimNBandLutDataObject().
protected |
Definition at line 483 of file ossimNBandLutDataObject.h.
Referenced by getMinMax(), loadState(), operator<<(), operator=(), operator==(), and saveState().
protected |
Definition at line 481 of file ossimNBandLutDataObject.h.
protected |
Definition at line 480 of file ossimNBandLutDataObject.h.
