#include <ossimElevCellHandler.h>
| ossimElevCellHandler (const char *elev_filename) | |
| Constructors: More... | |
| ossimElevCellHandler (const ossimElevCellHandler &src) | |
| virtual ossimIpt | getSizeOfElevCell () const =0 |
| METHOD: getSizeOfElevCell Returns the number of post in the cell. More... | |
| virtual double | getPostValue (const ossimIpt &gridPt) const =0 |
| METHOD: getPostValue Returns the value at a given grid point as a double. More... | |
| virtual double | getMeanSpacingMeters () const |
| METHOD: meanSpacingMeters() Implements pure virtual for. More... | |
| virtual bool | pointHasCoverage (const ossimGpt &) const |
| METHOD: pointIsInsideRect() Method to check if the ground point elevation is defined: More... | |
| virtual bool | getAccuracyInfo (ossimElevationAccuracyInfo &info, const ossimGpt &gpt) const |
| METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence): More... | |
| virtual void | close () |
| virtual bool | open (const ossimFilename &, bool=false) |
Public Member Functions inherited from ossimElevSource | |
| virtual double | getHeightAboveMSL (const ossimGpt &)=0 |
| Height access methods: More... | |
| virtual double | getHeightAboveEllipsoid (const ossimGpt &) |
| virtual ossimObject * | dup () const =0 |
| bool | intersectRay (const ossimEcefRay &ray, ossimGpt &gpt, double defaultElevValue=0.0) |
| METHOD: intersectRay() More... | |
| virtual double | getMinHeightAboveMSL () const |
| Access methods for the bounding elevations: More... | |
| virtual double | getMaxHeightAboveMSL () const |
| double | getNullHeightValue () const |
| Special numeric quantities as defined by this source: More... | |
| double | getSeaLevelValue () const |
| virtual const ossimGrect & | getBoundingGndRect () const |
| METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence) in the region of gpt: More... | |
| Implement ossimSource base-class pure virtuals: More... | |
| virtual bool | getComputeStatisticsFlag () const |
| Opens a stream to an elevation cell. More... | |
| virtual void | setComputeStatisticsFlag (bool flag) |
| Sets the flag which controls whether or not statistics will be computed upon opening a cell and not finding a corresponding statistics file. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ossimElevCellHandler () | |
| virtual | ~ossimElevCellHandler () |
Protected Member Functions inherited from ossimElevSource | |
| virtual | ~ossimElevSource () |
| ossimElevSource () | |
| Constructors/Destructors: More... | |
| ossimElevSource (const ossimElevSource &src) | |
Definition at line 34 of file ossimElevCellHandler.h.
| ossimElevCellHandler::ossimElevCellHandler | ( | const char * | elev_filename | ) |
Constructors:
Definition at line 55 of file ossimElevCellHandler.cpp.
| ossimElevCellHandler::ossimElevCellHandler | ( | const ossimElevCellHandler & | src | ) |
Definition at line 46 of file ossimElevCellHandler.cpp.
protected |
Definition at line 37 of file ossimElevCellHandler.cpp.
protectedvirtual |
Definition at line 63 of file ossimElevCellHandler.cpp.
Reimplemented from ossimElevSource.
Definition at line 86 of file ossimElevCellHandler.cpp.
inlinevirtual |
Reimplemented in ossimGeneralRasterElevHandler, ossimDtedHandler, ossimSrtmHandler, and ossimImageElevationHandler.
Definition at line 83 of file ossimElevCellHandler.h.
Implements ossimElevSource.
Reimplemented in ossimDtedHandler.
Definition at line 76 of file ossimElevCellHandler.cpp.
References ossimElevationAccuracyInfo::hasValidAbsoluteError(), ossimElevationAccuracyInfo::m_absoluteCE, ossimElevationAccuracyInfo::m_absoluteLE, ossimElevationAccuracyInfo::m_confidenceLevel, theAbsCE90, and theAbsLE90.
Referenced by ossimDtedElevationDatabase::getAccuracyInfo().
Definition at line 66 of file ossimElevCellHandler.cpp.
References theFilename.
Referenced by ossimImageElevationHandler::dup(), ossimDtedHandler::dup(), ossimElevationCellDatabase::getCellsForBounds(), and ossimSrtmHandler::ossimSrtmHandler().
This method is used for deterrming preferred DEM among multiple overlapping elev sources:
Definition at line 71 of file ossimElevCellHandler.cpp.
References theMeanSpacing.
Referenced by ossimImageElevationDatabase::getHeightAboveMSL(), and ossimGeneralRasterElevationDatabase::openGeneralRasterDirectory().
pure virtual |
Implemented in ossimDtedHandler, ossimGeneralRasterElevHandler, ossimSrtmHandler, and ossimImageElevationHandler.
pure virtual |
Note: x = longitude, y = latitude
inlinevirtual |
Reimplemented in ossimGeneralRasterElevHandler, ossimDtedHandler, and ossimSrtmHandler.
Definition at line 84 of file ossimElevCellHandler.h.
inlinevirtual |
Reimplemented in ossimGeneralRasterElevHandler, and ossimImageElevationHandler.
Definition at line 105 of file ossimElevCellHandler.h.
References ossimGrect::pointWithin(), and ossimElevSource::theGroundRect.
Referenced by ossimDtedElevationDatabase::getHeightAboveMSL().
Definition at line 93 of file ossimElevCellHandler.cpp.
References theAbsCE90, theAbsLE90, theFilename, and theMeanSpacing.
protected |
Definition at line 98 of file ossimElevCellHandler.h.
Referenced by getAccuracyInfo(), and print().
protected |
Definition at line 97 of file ossimElevCellHandler.h.
protected |
Virtual method for reading.
Definition at line 95 of file ossimElevCellHandler.h.
Referenced by ossimDtedHandler::gatherStatistics(), getFilename(), ossimImageElevationHandler::open(), ossimSrtmHandler::open(), ossimImageElevationHandler::operator=(), print(), and ossimGeneralRasterElevHandler::setFilename().
protected |
Definition at line 96 of file ossimElevCellHandler.h.
Referenced by getMeanSpacingMeters(), ossimImageElevationHandler::open(), ossimSrtmHandler::open(), print(), and ossimGeneralRasterElevHandler::setFilename().
