#include <ossimSrtmElevationDatabase.h>
Public Types | |
| typedef std::vector< ossimRefPtr< CellInfo > > | DirectMap |
Public Types inherited from ossimElevationCellDatabase | |
| typedef std::map< ossim_uint64, ossimRefPtr< CellInfo > > | CellMap |
| ossimSrtmElevationDatabase () | |
| ossimSrtmElevationDatabase (const ossimSrtmElevationDatabase &rhs) | |
| virtual | ~ossimSrtmElevationDatabase () |
| virtual bool | open (const ossimString &connectionString) |
| Open a connection to a database. More... | |
| bool | getAccuracyInfo (ossimElevationAccuracyInfo &info, const ossimGpt &) const |
| virtual bool | pointHasCoverage (const ossimGpt &gpt) const |
| METHOD: pointHasCoverage(gpt) Returns TRUE if coverage exists over gpt: More... | |
| virtual double | getHeightAboveMSL (const ossimGpt &) |
| Height access methods: More... | |
| virtual double | getHeightAboveEllipsoid (const ossimGpt &gpt) |
| virtual ossim_uint64 | createId (const ossimGpt &pt) const |
Public Member Functions inherited from ossimElevationCellDatabase | |
| ossimElevationCellDatabase () | |
| ossimElevationCellDatabase (const ossimElevationCellDatabase &src) | |
| virtual ossim_uint32 | getMinOpenCells () const |
| virtual ossim_uint32 | getMaxOpenCells () const |
| virtual void | setMinMaxOpenCells (ossim_uint64 minCellCount, ossim_uint64 maxCellCount) |
| virtual bool | getMemoryMapCellsFlag () const |
| virtual void | setMemoryMapCellsFlag (bool flag) |
| virtual void | getOpenCellList (std::vector< ossimFilename > &list) const |
| void | getCellsForBounds (const ossim_float64 &minLat, const ossim_float64 &minLon, const ossim_float64 &maxLat, const ossim_float64 &maxLon, std::vector< ossimFilename > &cells, ossim_uint32 maxNumberOfCells=0) |
| Gets a list of elevation cells needed to cover bounding box. More... | |
| virtual ossimRefPtr< ossimElevCellHandler > | getOrCreateCellHandler (const ossimGpt &gpt) |
Public Member Functions inherited from ossimElevationDatabase | |
| ossimElevationDatabase () | |
| ossimElevationDatabase (const ossimElevationDatabase &src) | |
| virtual double | getMeanSpacingMeters () const |
| METHOD: meanSpacingMeters() This method returns the post spacing in the region of gpt: More... | |
| virtual void | setGeoid (ossimGeoid *geoid) |
| ossimGeoid * | getGeoid () |
| const ossimGeoid * | getGeoid () const |
| const ossimString & | getConnectionString () const |
Public Member Functions inherited from ossimElevSource | |
| bool | intersectRay (const ossimEcefRay &ray, ossimGpt &gpt, double defaultElevValue=0.0) |
| METHOD: intersectRay() More... | |
| virtual double | getMinHeightAboveMSL () const |
| Access methods for the bounding elevations: More... | |
| virtual double | getMaxHeightAboveMSL () const |
| double | getNullHeightValue () const |
| Special numeric quantities as defined by this source: More... | |
| double | getSeaLevelValue () const |
| virtual const ossimGrect & | getBoundingGndRect () const |
| METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence) in the region of gpt: More... | |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| Implement ossimSource base-class pure virtuals: More... | |
| virtual bool | getComputeStatisticsFlag () const |
| Opens a stream to an elevation cell. More... | |
| virtual void | setComputeStatisticsFlag (bool flag) |
| Sets the flag which controls whether or not statistics will be computed upon opening a cell and not finding a corresponding statistics file. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| bool | openSrtmDirectory (const ossimFilename &dir) |
| void | createRelativePath (ossimFilename &file, const ossimGpt &gpt) const |
| void | createFullPath (ossimFilename &file, const ossimGpt &gpt) const |
| ossimRefPtr< ossimElevCellHandler > | createCell (const ossimGpt &gpt) |
Protected Member Functions inherited from ossimElevationCellDatabase | |
| virtual void | remove (ossim_uint64 id) |
| void | flushCacheToMinOpenCells () |
Protected Member Functions inherited from ossimElevationDatabase | |
| virtual | ~ossimElevationDatabase () |
| virtual double | getOffsetFromEllipsoid (const ossimGpt &gpt) |
Protected Member Functions inherited from ossimElevSource | |
| virtual | ~ossimElevSource () |
| ossimElevSource () | |
| Constructors/Destructors: More... | |
| ossimElevSource (const ossimElevSource &src) | |
Definition at line 16 of file ossimSrtmElevationDatabase.h.
| typedef std::vector<ossimRefPtr<CellInfo> > ossimSrtmElevationDatabase::DirectMap |
Definition at line 19 of file ossimSrtmElevationDatabase.h.
| ossimSrtmElevationDatabase::ossimSrtmElevationDatabase | ( | ) |
Definition at line 23 of file ossimSrtmElevationDatabase.cpp.
Referenced by dup().
| ossimSrtmElevationDatabase::ossimSrtmElevationDatabase | ( | const ossimSrtmElevationDatabase & | rhs | ) |
Definition at line 28 of file ossimSrtmElevationDatabase.cpp.
Definition at line 33 of file ossimSrtmElevationDatabase.cpp.
protectedvirtual |
Reimplemented from ossimElevationCellDatabase.
Definition at line 250 of file ossimSrtmElevationDatabase.cpp.
References createFullPath(), ossimFilename::exists(), ossimRefPtr< T >::get(), ossimElevationCellDatabase::m_memoryMapCellsFlag, and ossimSrtmHandler::open().
inlineprotected |
Definition at line 60 of file ossimSrtmElevationDatabase.h.
References ossimFilename::dirCat().
Referenced by createCell().
inlinevirtual |
Definition at line 40 of file ossimSrtmElevationDatabase.h.
References ossimGpt::latd(), ossimGpt::lond(), ossim::wrap(), x, and y.
protected |
Definition at line 184 of file ossimSrtmElevationDatabase.cpp.
References abs, ossimString::c_str(), ossimGpt::latd(), ossimGpt::lond(), os2, and ossimFilename::setExtension().
Implements ossimElevSource.
Definition at line 37 of file ossimSrtmElevationDatabase.cpp.
References ossimSrtmElevationDatabase().
Reimplemented from ossimElevationDatabase.
Definition at line 77 of file ossimSrtmElevationDatabase.cpp.
References ossimElevationAccuracyInfo::m_absoluteCE, ossimElevationAccuracyInfo::m_absoluteLE, ossimElevationDatabase::m_meanSpacing, ossimElevationAccuracyInfo::m_surfaceName, ossimElevationAccuracyInfo::makeNan(), and pointHasCoverage().
Reimplemented from ossimElevSource.
Definition at line 57 of file ossimSrtmElevationDatabase.cpp.
References getHeightAboveMSL(), ossimElevationDatabase::getOffsetFromEllipsoid(), and ossim::nan().
Definition at line 44 of file ossimSrtmElevationDatabase.cpp.
References ossimElevSource::getHeightAboveMSL(), ossimElevationCellDatabase::getOrCreateCellHandler(), ossimSource::isSourceEnabled(), ossim::nan(), and ossimRefPtr< T >::valid().
Referenced by getHeightAboveEllipsoid().
Definition at line 222 of file ossimSrtmElevationDatabase.cpp.
References ossimString::empty(), ossimFilename::exists(), ossimElevationCellDatabase::loadState(), ossimElevationDatabase::m_connectionString, and open().
In most cases this will be a pointer to a directory like in a Dted directory reader.
Implements ossimElevationDatabase.
Definition at line 68 of file ossimSrtmElevationDatabase.cpp.
References ossimElevationDatabase::m_connectionString, and openSrtmDirectory().
Referenced by loadState().
protected |
Definition at line 112 of file ossimSrtmElevationDatabase.cpp.
Referenced by open().
inlinevirtual |
Definition at line 31 of file ossimSrtmElevationDatabase.h.
References ossimFilename::exists().
Referenced by getAccuracyInfo().
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Definition at line 244 of file ossimSrtmElevationDatabase.cpp.
References ossimElevationCellDatabase::saveState().
