#include <ossimElevationCellDatabase.h>
Classes | |
| struct | CellInfo |
Public Types | |
| typedef std::map< ossim_uint64, ossimRefPtr< CellInfo > > | CellMap |
| ossimElevationCellDatabase () | |
| ossimElevationCellDatabase (const ossimElevationCellDatabase &src) | |
| virtual ossim_uint32 | getMinOpenCells () const |
| virtual ossim_uint32 | getMaxOpenCells () const |
| virtual void | setMinMaxOpenCells (ossim_uint64 minCellCount, ossim_uint64 maxCellCount) |
| virtual bool | getMemoryMapCellsFlag () const |
| virtual void | setMemoryMapCellsFlag (bool flag) |
| virtual void | getOpenCellList (std::vector< ossimFilename > &list) const |
| void | getCellsForBounds (const ossim_float64 &minLat, const ossim_float64 &minLon, const ossim_float64 &maxLat, const ossim_float64 &maxLon, std::vector< ossimFilename > &cells, ossim_uint32 maxNumberOfCells=0) |
| Gets a list of elevation cells needed to cover bounding box. More... | |
| virtual ossim_uint64 | createId (const ossimGpt &) const |
| virtual ossimRefPtr< ossimElevCellHandler > | getOrCreateCellHandler (const ossimGpt &gpt) |
Public Member Functions inherited from ossimElevationDatabase | |
| ossimElevationDatabase () | |
| ossimElevationDatabase (const ossimElevationDatabase &src) | |
| virtual bool | getAccuracyInfo (ossimElevationAccuracyInfo &, const ossimGpt &) const |
| virtual double | getMeanSpacingMeters () const |
| METHOD: meanSpacingMeters() This method returns the post spacing in the region of gpt: More... | |
| virtual void | setGeoid (ossimGeoid *geoid) |
| ossimGeoid * | getGeoid () |
| const ossimGeoid * | getGeoid () const |
| virtual bool | open (const ossimString &connectionString)=0 |
| Open a connection to a database. More... | |
| const ossimString & | getConnectionString () const |
Public Member Functions inherited from ossimElevSource | |
| virtual double | getHeightAboveMSL (const ossimGpt &)=0 |
| Height access methods: More... | |
| virtual double | getHeightAboveEllipsoid (const ossimGpt &) |
| virtual ossimObject * | dup () const =0 |
| bool | intersectRay (const ossimEcefRay &ray, ossimGpt &gpt, double defaultElevValue=0.0) |
| METHOD: intersectRay() More... | |
| virtual double | getMinHeightAboveMSL () const |
| Access methods for the bounding elevations: More... | |
| virtual double | getMaxHeightAboveMSL () const |
| double | getNullHeightValue () const |
| Special numeric quantities as defined by this source: More... | |
| double | getSeaLevelValue () const |
| virtual bool | pointHasCoverage (const ossimGpt &) const =0 |
| METHOD: pointHasCoverage(gpt) Returns TRUE if coverage exists over gpt: More... | |
| virtual const ossimGrect & | getBoundingGndRect () const |
| METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence) in the region of gpt: More... | |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| Implement ossimSource base-class pure virtuals: More... | |
| virtual bool | getComputeStatisticsFlag () const |
| Opens a stream to an elevation cell. More... | |
| virtual void | setComputeStatisticsFlag (bool flag) |
| Sets the flag which controls whether or not statistics will be computed upon opening a cell and not finding a corresponding statistics file. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual ossimRefPtr< ossimElevCellHandler > | createCell (const ossimGpt &) |
| virtual void | remove (ossim_uint64 id) |
| void | flushCacheToMinOpenCells () |
Protected Member Functions inherited from ossimElevationDatabase | |
| virtual | ~ossimElevationDatabase () |
| virtual double | getOffsetFromEllipsoid (const ossimGpt &gpt) |
Protected Member Functions inherited from ossimElevSource | |
| virtual | ~ossimElevSource () |
| ossimElevSource () | |
| Constructors/Destructors: More... | |
| ossimElevSource (const ossimElevSource &src) | |
Definition at line 6 of file ossimElevationCellDatabase.h.
| typedef std::map<ossim_uint64, ossimRefPtr<CellInfo> > ossimElevationCellDatabase::CellMap |
Definition at line 56 of file ossimElevationCellDatabase.h.
inline |
Definition at line 58 of file ossimElevationCellDatabase.h.
inline |
Definition at line 65 of file ossimElevationCellDatabase.h.
inlineprotectedvirtual |
Reimplemented in ossimImageElevationDatabase, ossimGeneralRasterElevationDatabase, ossimDtedElevationDatabase, and ossimSrtmElevationDatabase.
Definition at line 129 of file ossimElevationCellDatabase.h.
Referenced by getOrCreateCellHandler().
inlinevirtual |
Reimplemented in ossimGeneralRasterElevationDatabase, ossimDtedElevationDatabase, and ossimSrtmElevationDatabase.
Definition at line 120 of file ossimElevationCellDatabase.h.
inlineprotected |
Definition at line 141 of file ossimElevationCellDatabase.h.
Referenced by getOrCreateCellHandler(), and ossimImageElevationDatabase::getOrCreateCellHandler().
| void ossimElevationCellDatabase::getCellsForBounds | ( | const ossim_float64 & | minLat, |
| const ossim_float64 & | minLon, | ||
| const ossim_float64 & | maxLat, | ||
| const ossim_float64 & | maxLon, | ||
| std::vector< ossimFilename > & | cells, | ||
| ossim_uint32 | maxNumberOfCells = 0 |
| connectionString | Typically elevation repository, e.g.: "/data1/elevation/srtm/1arc" |
| minLat | Minimum latitude of bounding box. |
| minLon | Minimum longitude of bounding box. |
| maxLat | Maximum latitude of bounding box. |
| maxLon | Maximum longitude of bounding box. |
| cells | Initialized by this. |
| maxNumberOfCells | Value of 0 indicates return as many as you can. Any positive number will only return that number of cells. |
Definition at line 20 of file ossimElevationCellDatabase.cpp.
References ossimString::begin(), ossimElevCellHandler::getFilename(), getOrCreateCellHandler(), ossimGpt::lat, ossimGpt::lon, ossim::min< ossim_float64 >(), ossimString::size(), and ossimRefPtr< T >::valid().
Referenced by ossimElevManager::getCellsForBounds().
inlinevirtual |
Definition at line 80 of file ossimElevationCellDatabase.h.
inlinevirtual |
Definition at line 90 of file ossimElevationCellDatabase.h.
inlinevirtual |
Definition at line 76 of file ossimElevationCellDatabase.h.
Definition at line 5 of file ossimElevationCellDatabase.cpp.
References m_cacheMap.
Referenced by ossimElevManager::getOpenCellList().
Reimplemented in ossimImageElevationDatabase.
Definition at line 99 of file ossimElevationCellDatabase.cpp.
References createCell(), createId(), flushCacheToMinOpenCells(), ossimRefPtr< T >::get(), m_cacheMap, m_cacheMapMutex, and m_maxOpenCells.
Referenced by ossimDtedElevationDatabase::getAccuracyInfo(), getCellsForBounds(), ossimSrtmElevationDatabase::getHeightAboveMSL(), ossimDtedElevationDatabase::getHeightAboveMSL(), and ossimGeneralRasterElevationDatabase::getHeightAboveMSL().
Reimplemented from ossimElevationDatabase.
Reimplemented in ossimImageElevationDatabase, ossimDtedElevationDatabase, ossimGeneralRasterElevationDatabase, and ossimSrtmElevationDatabase.
Definition at line 178 of file ossimElevationCellDatabase.cpp.
References ossimString::empty(), ossimKeywordlist::find(), ossimElevationDatabase::loadState(), m_maxOpenCells, m_memoryMapCellsFlag, m_minOpenCells, ossimString::toBool(), and ossimString::toUInt32().
Referenced by ossimSrtmElevationDatabase::loadState(), ossimDtedElevationDatabase::loadState(), and ossimGeneralRasterElevationDatabase::loadState().
Reimplemented in ossimImageElevationDatabase, ossimGeneralRasterElevationDatabase, and ossimDtedElevationDatabase.
Definition at line 214 of file ossimElevationCellDatabase.cpp.
References saveState().
Definition at line 133 of file ossimElevationCellDatabase.h.
Referenced by ossimImageElevationDatabase::remove().
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Definition at line 200 of file ossimElevationCellDatabase.cpp.
References ossimKeywordlist::add(), ossimObject::getShortName(), ossimElevationDatabase::m_geoid, m_maxOpenCells, m_memoryMapCellsFlag, m_minOpenCells, ossimElevationDatabase::saveState(), and ossimRefPtr< T >::valid().
Referenced by print(), ossimSrtmElevationDatabase::saveState(), ossimDtedElevationDatabase::saveState(), ossimGeneralRasterElevationDatabase::saveState(), and ossimImageElevationDatabase::saveState().
inlinevirtual |
Definition at line 94 of file ossimElevationCellDatabase.h.
inlinevirtual |
Definition at line 84 of file ossimElevationCellDatabase.h.
protected |
Definition at line 165 of file ossimElevationCellDatabase.h.
Referenced by getOpenCellList(), getOrCreateCellHandler(), and ossimImageElevationDatabase::getOrCreateCellHandler().
mutableprotected |
Definition at line 164 of file ossimElevationCellDatabase.h.
Referenced by ossimImageElevationDatabase::createCell(), getOrCreateCellHandler(), and ossimImageElevationDatabase::getOrCreateCellHandler().
protected |
Definition at line 163 of file ossimElevationCellDatabase.h.
Referenced by getOrCreateCellHandler(), ossimImageElevationDatabase::getOrCreateCellHandler(), loadState(), and saveState().
protected |
Definition at line 166 of file ossimElevationCellDatabase.h.
Referenced by ossimSrtmElevationDatabase::createCell(), ossimDtedElevationDatabase::createCell(), loadState(), ossimGeneralRasterElevationDatabase::openGeneralRasterDirectory(), and saveState().
protected |
Definition at line 162 of file ossimElevationCellDatabase.h.
Referenced by loadState(), and saveState().
protected |
Definition at line 168 of file ossimElevationCellDatabase.h.
