for an srtm file. More...
#include <ossimSrtmHandler.h>
Public Types | |
| enum | { NULL_POST = -32768 } |
| ossimSrtmHandler () | |
| Constructor that takes a file name. More... | |
| ossimSrtmHandler (const ossimSrtmHandler &) | |
| virtual double | getHeightAboveMSL (const ossimGpt &) |
| METHOD: getHeightAboveMSL Height access methods. More... | |
| virtual ossimIpt | getSizeOfElevCell () const |
| METHOD: getSizeOfElevCell Returns the number of post in the cell. More... | |
| virtual double | getPostValue (const ossimIpt &gridPt) const |
| METHOD: getPostValue Returns the value at a given grid point as a double. More... | |
| virtual bool | open (const ossimFilename &file, bool memoryMapFlag=false) |
| Opens a stream to the srtm cell. More... | |
| virtual void | close () |
| Closes the stream to the file. More... | |
Public Member Functions inherited from ossimElevCellHandler | |
| ossimElevCellHandler (const char *elev_filename) | |
| Constructors: More... | |
| ossimElevCellHandler (const ossimElevCellHandler &src) | |
| virtual double | getMeanSpacingMeters () const |
| METHOD: meanSpacingMeters() Implements pure virtual for. More... | |
| virtual bool | pointHasCoverage (const ossimGpt &) const |
| METHOD: pointIsInsideRect() Method to check if the ground point elevation is defined: More... | |
| virtual bool | getAccuracyInfo (ossimElevationAccuracyInfo &info, const ossimGpt &gpt) const |
| METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence): More... | |
Public Member Functions inherited from ossimElevSource | |
| virtual double | getHeightAboveEllipsoid (const ossimGpt &) |
| bool | intersectRay (const ossimEcefRay &ray, ossimGpt &gpt, double defaultElevValue=0.0) |
| METHOD: intersectRay() More... | |
| virtual double | getMinHeightAboveMSL () const |
| Access methods for the bounding elevations: More... | |
| virtual double | getMaxHeightAboveMSL () const |
| double | getNullHeightValue () const |
| Special numeric quantities as defined by this source: More... | |
| double | getSeaLevelValue () const |
| virtual const ossimGrect & | getBoundingGndRect () const |
| METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence) in the region of gpt: More... | |
| Implement ossimSource base-class pure virtuals: More... | |
| virtual bool | getComputeStatisticsFlag () const |
| Opens a stream to an elevation cell. More... | |
| virtual void | setComputeStatisticsFlag (bool flag) |
| Sets the flag which controls whether or not statistics will be computed upon opening a cell and not finding a corresponding statistics file. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimSrtmHandler () |
| destructor More... | |
| template<class T > | |
| double | getHeightAboveMSLFileTemplate (T dummy, const ossimGpt &gpt) |
| double | getHeightAboveMSLMemoryTemplate (T dummy, const ossimGpt &gpt) |
Protected Member Functions inherited from ossimElevCellHandler | |
| ossimElevCellHandler () | |
| virtual | ~ossimElevCellHandler () |
Protected Member Functions inherited from ossimElevSource | |
| virtual | ~ossimElevSource () |
| ossimElevSource () | |
| Constructors/Destructors: More... | |
| ossimElevSource (const ossimElevSource &src) | |
for an srtm file.
Definition at line 29 of file ossimSrtmHandler.h.
| anonymous enum |
| Enumerator | |
| NULL_POST | |
Definition at line 38 of file ossimSrtmHandler.h.
| ossimSrtmHandler::ossimSrtmHandler | ( | ) |
Definition at line 30 of file ossimSrtmHandler.cpp.
| ossimSrtmHandler::ossimSrtmHandler | ( | const ossimSrtmHandler & | src | ) |
Definition at line 384 of file ossimSrtmHandler.cpp.
References ossimString::c_str(), ossimElevCellHandler::getFilename(), isOpen(), m_fileStr, and m_memoryMap.
protectedvirtual |
destructor
Definition at line 44 of file ossimSrtmHandler.cpp.
References close(), and m_swapper.
Reimplemented from ossimElevCellHandler.
Definition at line 492 of file ossimSrtmHandler.cpp.
References m_fileStr, m_memoryMap, and m_streamOpen.
Referenced by ~ossimSrtmHandler().
inlinevirtual |
Implements ossimElevSource.
Definition at line 77 of file ossimSrtmHandler.h.
References open().
Definition at line 54 of file ossimSrtmHandler.cpp.
References getHeightAboveMSLFileTemplate(), getHeightAboveMSLMemoryTemplate(), isOpen(), m_memoryMap, m_scalarType, ossim::nan(), OSSIM_FLOAT32, and OSSIM_SINT16.
protected |
Definition at line 98 of file ossimSrtmHandler.cpp.
References ossimDpt::lat, ossimGpt::lat, ossimDpt::lon, ossimGpt::lon, m_fileStr, m_fileStrMutex, m_latSpacing, m_lonSpacing, m_numberOfLines, m_numberOfSamples, m_nwCornerPost, m_srtmRecordSizeInBytes, m_swapper, ossim::nan(), ossimEndian::swap(), and ossimElevSource::theNullHeightValue.
Referenced by getHeightAboveMSL().
protected |
Definition at line 227 of file ossimSrtmHandler.cpp.
References ossim::almostEqual(), ossimDpt::lat, ossimGpt::lat, ossimDpt::lon, ossimGpt::lon, ossimGrect::lr(), m_latSpacing, m_lonSpacing, m_memoryMap, m_numberOfLines, m_numberOfSamples, m_nwCornerPost, m_srtmRecordSizeInBytes, m_swapper, ossim::nan(), ossimEndian::swap(), ossimElevSource::theGroundRect, and ossimElevSource::theNullHeightValue.
Satisfies pure virtual.
Implements ossimElevCellHandler.
Definition at line 333 of file ossimSrtmHandler.cpp.
References ossim::nan(), ossimNotify(), ossimNotifyLevel_WARN, and ossimElevSource::theNullHeightValue.
Satisfies pure virtual. Note: x = longitude, y = latitude
Definition at line 379 of file ossimSrtmHandler.cpp.
References m_numberOfLines, and m_numberOfSamples.
Definition at line 405 of file ossimSrtmHandler.cpp.
References m_fileStrMutex, m_memoryMap, and m_streamOpen.
Referenced by getHeightAboveMSL(), and ossimSrtmHandler().
Definition at line 415 of file ossimSrtmHandler.cpp.
References ossim::byteOrder(), ossimString::c_str(), ossimErrorStatusInterface::clearErrorStatus(), ossimFilename::fileSize(), ossimSrtmSupportData::getLatitudeSpacing(), ossimSrtmSupportData::getLongitudeSpacing(), ossimSrtmSupportData::getNumberOfLines(), ossimSrtmSupportData::getNumberOfSamples(), ossimSrtmSupportData::getScalarType(), ossimSrtmSupportData::getSouthwestLatitude(), ossimSrtmSupportData::getSouthwestLongitude(), ossimDpt::lat, ossimDpt::lon, m_fileStr, m_latSpacing, m_lonSpacing, m_memoryMap, m_numberOfLines, m_numberOfSamples, m_nwCornerPost, m_scalarType, m_srtmRecordSizeInBytes, m_streamOpen, m_supportData, m_swapper, ossimGpt::metersPerDegree(), ossimErrorCodes::OSSIM_ERROR, OSSIM_LITTLE_ENDIAN, ossim::scalarSizeInBytes(), ossimSrtmSupportData::setFilename(), ossimErrorStatusInterface::theErrorStatus, ossimElevCellHandler::theFilename, ossimElevSource::theGroundRect, ossimElevCellHandler::theMeanSpacing, ossimElevSource::theNullHeightValue, and ossimDpt::y.
Referenced by ossimSrtmElevationDatabase::createCell(), and dup().
protected |
Definition at line 89 of file ossimSrtmHandler.h.
Referenced by close(), getHeightAboveMSLFileTemplate(), open(), and ossimSrtmHandler().
mutableprotected |
Definition at line 88 of file ossimSrtmHandler.h.
Referenced by getHeightAboveMSLFileTemplate(), and isOpen().
protected |
Definition at line 97 of file ossimSrtmHandler.h.
Referenced by getHeightAboveMSLFileTemplate(), getHeightAboveMSLMemoryTemplate(), and open().
protected |
Definition at line 98 of file ossimSrtmHandler.h.
mutableprotected |
Definition at line 103 of file ossimSrtmHandler.h.
Referenced by close(), getHeightAboveMSL(), getHeightAboveMSLMemoryTemplate(), isOpen(), open(), and ossimSrtmHandler().
protected |
Definition at line 94 of file ossimSrtmHandler.h.
Referenced by getHeightAboveMSLFileTemplate(), getHeightAboveMSLMemoryTemplate(), getSizeOfElevCell(), and open().
protected |
Definition at line 95 of file ossimSrtmHandler.h.
protected |
Definition at line 99 of file ossimSrtmHandler.h.
protected |
Definition at line 101 of file ossimSrtmHandler.h.
Referenced by getHeightAboveMSL(), and open().
protected |
Definition at line 96 of file ossimSrtmHandler.h.
protected |
true if stream is open.
Definition at line 92 of file ossimSrtmHandler.h.
protected |
Definition at line 87 of file ossimSrtmHandler.h.
Referenced by open().
protected |
Definition at line 100 of file ossimSrtmHandler.h.
Referenced by getHeightAboveMSLFileTemplate(), getHeightAboveMSLMemoryTemplate(), open(), and ~ossimSrtmHandler().
